| 03-WAN interface configuration | 91.26 KB |
WAN interface and hardware compatibility
Configuring common WAN interface settings
Configuring a serial interface
Restrictions: Hardware compatibility with serial interfaces
Configuring a synchronous serial interface
Verifying and maintaining serial interfaces
Restrictions: Hardware compatibility with E1-F interfaces
Configuring an E1-F interface in framed mode
Configuring an E1-F interface in unframed mode
Configuring other E1-F interface parameters
Enabling local loopback on an E1-F interface
Configuring WAN interfaces
About WAN interfaces
This chapter describes how to configure the following types of WAN interfaces:
· Synchronous serial interface.
· E1-F interface.
This feature is supported on devices installed with SIC-2E1-F or SIC-E1-F cards. For interfaces provided by a device, see the install guide and card manuals.
This section only describes the common properties configuration for WAN interfaces.
1. Enter system view.
¡ Enter synchronous serial/E1-F interface view.
interface serial interface-number
2. Configure the interface description.
By default, the description of an asynchronous serial interface is interface name Interface, for example, Serial2/1 Interface.
3. Set the expected bandwidth for the interface.
bandwidth bandwidth-value
By default, the expected bandwidth (in kbps) is the interface baud rate divided by 1000.
Interfaces that support this feature include serial interfaces and E1-F interfaces.
4. Configure the keepalive interval and retry limit.
¡ Set the keepalive interval.
timer-hold seconds
The default setting is 10 seconds.
¡ Set the keepalive retry limit.
timer-hold retry retries
The default setting is 5.
5. Set the MTU.
mtu size
The default setting is 1500 bytes.
6. Bring up the interface.
By default, an interface is up.
About serial interfaces
Synchronous serial interfaces on this device refer to logical interfaces channelized from E1-F interfaces. They have the same properties as synchronous serial interfaces and can be configured in the same way as synchronous serial interfaces are configured.
Models |
Serial interface compatibility |
MSR1008 |
No |
MSR2630E-X1 |
Yes |
MSR3610E-X1, MSR3610E-X1-DP |
· MSR3610E-X1: Yes · MSR3610E-X1-DP: No |
Models |
MSR2660-XS |
No |
MSR2680-XS |
No |
Models |
MSR2600-12X-WiNet |
No |
MSR2610-13X-WiNet |
No |
This section only describes the interface properties configuration. Depending on the network requirements, you might also need to configure PPP, IP address, and interface backup.
2. Enter synchronous serial interface view.
3. Set the link layer protocol.
link-protocol { hdlc | ppp }
The default is PPP.
4. Configure line detection settings.
¡ Set the CRC mode.
crc { 16 | 32 | none }
The default is 16-bit CRC.
¡ Initiate a loopback test.
loopback-test [ -c count | -p { pattern | special { ascending | descending | random } } | -s packetsize | -t timeout ] * interface interface-type interface-number
By default, no loopback test is performed on an interface.
This command is available only on synchronous serial interfaces that are created for E1-F interfaces.
Clearing serial interface statistics
Perform all clear tasks in user view.
· Clear statistics for serial interfaces.
reset counters interface serial [ interface-number ]
Displaying serial interface information
Perform all display tasks in any view.
· Display serial interface information.
display interface serial [ interface-number ] [ brief [ description | down ] ]
About E1-F interfaces
E1-F interfaces, which are fractional E1 interfaces, are simplified CE1 interfaces. They are a cost-effective alternative to CE1 interfaces for E1 access services that do not require multiple channel sets.
An E1-F interface has the following features:
· In framed mode, an E1-F interface can bind timeslots into only one channel set.
· An E1-F interface does not support PRI mode.
An E1-F interface can operate in either framed (the default) or unframed mode.
· In unframed mode, an E1-F interface provides 2048 kbps of data bandwidth. For the interface, a synchronous serial interface is created automatically.
· In framed mode, an E1-F interface is physically divided into 32 timeslots numbered 0 through 31. Timeslot 0 is used for transmitting synchronization information. All other timeslots can randomly form one channel set. For the channel set, a synchronous serial interface is created automatically. The interface rate is n × 64 kbps, where n is the number of bundled timeslots.
The synchronous serial interface created in either mode has the same logical features as a standard synchronous serial interface and supports the following protocols:
· Data link layer protocols, such as PPP, HDLC, and LAPB.
· Network layer protocols, such as IP.
You can configure this interface in the same way a standard synchronous serial interface is configured.
Models |
E1-F interface compatibility |
MSR1008 |
No |
MSR2630E-X1 |
Yes |
Models |
MSR2660-XS |
No |
MSR2680-XS |
No |
Models |
MSR2600-12X-WiNet |
No |
MSR2610-13X-WiNet |
No |
2. Enter E1-F interface view.
3. Configure the interface to operate in framed mode.
undo fe1 unframed
The default is framed mode.
4. Bundle timeslots on the interface.
fe1 timeslot-list range
By default, if no timeslot range is specified, all timeslots are bundled.
5. Set the framing format.
fe1 frame-format { crc4 | no-crc4 }
The default is no-CRC4.
6. Enable RAI detection on the interface.
fe1 alarm-detect rai
By default, RAI detection is enabled on the interface.
7. Set other interface parameters.
See "Configuring other E1-F interface parameters."
3. Configure the interface to operate in unframed mode.
fe1 unframed
4. Enable AIS detection.
fe1 detect-ais
By default, AIS detection is disabled.
5. Set other interface parameters.
interface serial serial-number
3. Set the line code format.
fe1 code { ami | hdb3 }
The default is HDB3.
4. Enable or disable user data inversion.
fe1 data-coding { inverted | normal }
By default, user data inversion is disabled.
5. Set the clock mode.
fe1 clock { master | slave }
The default is slave, which is line clock.
6. Enable automatic clock mode change.
clock-change auto
By default, automatic clock mode change is disabled.
When automatic clock mode switchover is enabled, the interface automatically switches to the master clock mode when both of the following conditions exist:
¡ The interface uses the slave clock mode.
¡ The interface receives an alarm indication signal (AIS), loss of signal (LOS), or loss of frame (LOF) alarm.
After the alarm is cleared, the interface automatically switches back to the slave clock mode.
7. Set the CRC mode.
8. Configuring interface properties
¡ Set the line idle code type.
fe1 idle-code { 7e | ff }
The default is 0x7E.
¡ Set the cable type.
fe1 cable { long | short }
By default, the cable type is long.
¡ Set the cable impedance.
fe1 cable-type { 75 | 120 }
The default is 75 ohm.
¡ Set the type and the number of interframe filling tags.
fe1 itf { number number | type { 7e | ff } }
By default:
- The type of the interframe filling tag is 0x7E.
- The number of interframe filling tags is four.
Loopback is intended for testing only. Disable loopback when the interface is operating correctly.
After you enable this feature on an E1-F interface, the interface does not forward data traffic.
3. Enable loopback and set the loopback mode.
fe1 loopback { local | payload | remote }
By default, loopback is disabled.
Verifying and maintaining E1-F interfaces
Clearing statistics for E1-F interfaces
To clear statistics for E1-F interfaces, execute the following command in user view:
Displaying E1-F interface information
· Display information about E1-F interfaces.
display fe1 [ serial interface-number ]
· Display the operating status of an E1-F interface.
display interface serial interface-number
Restoring the default settings for an interface
This feature might interrupt ongoing network services. Make sure you are fully aware of the impact of this feature when you use it on a live network.
This feature might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to check for these commands and perform their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
2. Enter interface view.
3. Restore the default settings for the interface.
default
