- 04-DPI Configuration Guide
- 01-DPI overview
- 02-DPI engine configuration
- 03-IPS configuration
- 04-URL filtering configuration
- 05-Data filtering configuration
- 06-File filtering configuration
- 07-Anti-virus configuration
- 08-Data analysis center configuration
- 09-Proxy policy configuration
- 10-WAF configuration
- 11-IP reputation configuration
- 12-APT defense configuration
- 13-Domain reputation configuration
| 00-Preface | 111.93 KB |
Preface
· This configuration guide describes the fundamentals and configuration procedures for DPI features, including DPI overview, DPI engine, IPS, URL filtering, data filtering, file filtering, anti-virus, data analysis center, proxy policy, WAF, IP reputation, APT defense and Domain reputation.
· Security zones, security policies, object groups, object policies, APR, and session management.
· User access and authentication features (such as AAA, portal, user identification, password control, and PKI).
· Data security features (such as public key management, SSL, SSH, and crypto engine).
· Attack protection features (such as ASPF, connection limit, IP source guard, ARP attack protection, ND attack defense, uRPF, attack detection and prevention, and IP-MAC binding).
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
