03-Security Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath Firewall Series Configuration Guides(V7)-6W60203-Security Configuration Guide
11-Portal configuration
11-Portal configuration 1.27 MB
Configuring portal authentication· 1
About portal authentication· 1
Advantages of portal authentication· 1
Extended portal functions· 1
Portal system·· 1
Portal authentication using a remote portal server 2
Local portal service· 3
Portal authentication modes· 3
Portal authentication process· 4
Portal support for EAP· 6
Portal filtering rules· 6
MAC-based quick portal authentication· 7
Portal support for NAT444· 8
Restrictions and guidelines: Portal configuration· 8
Portal authentication tasks at a glance· 9
Prerequisites for portal authentication· 10
Configuring a remote portal authentication server 11
Configuring a portal Web server 12
Portal Web server tasks at a glance· 12
Configure basic parameters for a portal Web server 12
Enabling the captive-bypass feature· 12
Configuring a match rule for URL redirection· 13
Configuring the local portal service features· 14
About the local portal service· 14
Restrictions and guidelines for configuring local portal service features· 14
Customizing authentication pages· 14
Configuring a local portal Web service· 16
Configuring the User-Agent match string· 17
Enabling portal authentication on an interface· 18
Specifying a portal Web server on an interface· 19
Configuring a portal preauthentication domain· 19
Specifying a preauthentication IP address pool 20
Specifying a portal authentication domain· 21
About portal authentication domains· 21
Restrictions and guidelines for specifying a portal authentication domain· 21
Specifying a portal authentication domain on an interface· 22
Controlling portal user access· 22
Configuring a portal-free rule· 22
Configuring an authentication source subnet 23
Configuring an authentication destination subnet 24
Configuring a portal-forbidden rule· 25
Specifying port numbers of Web proxy servers· 25
Setting the maximum number of portal users· 26
Enabling strict-checking on portal authorization information· 27
Allowing only users with DHCP-assigned IP addresses to pass portal authentication· 27
Blocking portal users that fail portal authentication· 28
Configuring support of portal authentication for dual stack· 28
Enabling intra-VLAN roaming for portal users· 29
Enabling outgoing packets filtering· 29
Configuring the portal fail-permit feature· 30
Configuring portal detection features· 30
Configuring online detection of portal users· 30
Configuring portal authentication server detection· 31
Configuring portal Web server detection· 32
Enabling DHCP packet capture· 33
Configuring portal user synchronization· 34
Configuring portal packet attributes· 34
Configuring the BAS-IP or BAS-IPv6 attribute· 34
Specifying the device ID·· 35
Configuring attributes for RADIUS packets· 36
Specifying a format for the NAS-Port-Id attribute· 36
Applying a NAS-ID profile to an interface· 36
Configuring MAC-based quick portal authentication· 37
Restrictions and guidelines for configuring MAC-based quick portal authentication· 37
Configuring a remote MAC binding server 37
Configuring a local MAC binding server 38
Specifying a MAC binding server on an interface· 39
Configure cloud MAC-trigger authentication· 39
Logging out online portal users· 39
Setting the user traffic backup threshold· 40
Disabling the Rule ARP or ND entry feature for portal clients· 40
Disabling traffic accounting for portal users· 41
Configuring Web redirect 41
About Web redirect 41
Configuring Web redirect on an interface· 41
Configuring destination-based portal redirection rules· 42
Configuring portal safe-redirect 42
Setting the maximum number of portal redirection sessions for a single user 44
Excluding an attribute from portal protocol packets· 44
Configuring support of portal authentication for third-party authentication· 45
About third-party authentication· 45
Restrictions and guidelines for third-party authentication· 45
Editing buttons and pages for third-party authentication· 45
Configuring QQ authentication· 46
Configuring email authentication· 47
Configuring WeChat authentication· 47
Configuring Facebook authentication· 48
Specifying an authentication domain for third-party authentication· 49
Configuring portal temporary pass· 49
Setting the user synchronization interval for portal authentication using OAuth· 50
Configuring user synchronization for portal authentication using the WiFiDog protocol 51
Configuring portal authentication information report interval 51
Enabling portal logging· 51
Configuring the portal authentication monitoring feature· 52
Configuring portal advertisement push· 53
Display and maintenance commands for portal 54
Portal configuration examples· 56
Example: Configuring direct portal authentication· 56
Example: Configuring re-DHCP portal authentication· 63
Example: Configuring cross-subnet portal authentication· 68
Example: Configuring extended direct portal authentication· 72
Example: Configuring extended re-DHCP portal authentication· 77
Example: Configuring extended cross-subnet portal authentication· 82
Example: Configuring portal server detection and portal user synchronization· 87
Example: Configuring direct portal authentication with a preauthentication domain· 93
Example: Configuring re-DHCP portal authentication with a preauthentication domain· 96
Example: Configuring direct portal authentication using a local portal Web service· 100
Example: Configuring MAC-based quick portal authentication· 104
Troubleshooting portal 112
No portal authentication page is pushed for users· 112
Cannot log out portal users on the access device· 113
Cannot log out portal users on the RADIUS server 113
Users logged out by the access device still exist on the portal authentication server 114
Re-DHCP portal authenticated users cannot log in successfully· 114
Portal authentication controls user access to networks. Portal authenticates a user by the username and password the user enters on a portal authentication page. Typically, portal authentication is deployed on the access layer and vital data entries.
In a portal-enabled network, users can actively initiate portal authentication by visiting the authentication website provided by the portal Web server. Or, they are redirected to the portal authentication page for authentication when they visit other websites.
The device supports Portal 1.0, Portal 2.0, and Portal 3.0.
Portal authentication has the following advantages:
·     Allows users to perform authentication through a Web browser without installing client software.
·     Provides ISPs with diversified management choices and extended functions. For example, the ISPs can place advertisements, provide community services, and publish information on the authentication page.
·     Supports multiple authentication modes. For example, re-DHCP authentication implements a flexible address assignment scheme and saves public IP addresses. Cross-subnet authentication can authenticate users who reside in a different subnet than the access device.
By forcing patching and anti-virus policies, extended portal functions help hosts to defend against viruses. Portal supports the following extended functions:
·     Security check—Detects after authentication whether or not a user host installs anti-virus software, virus definition file, unauthorized software, and operating system patches.
·     Resource access restriction—Allows an authenticated user to access certain network resources such as the virus server and the patch server. Users can access more network resources after passing security check.
Security check must cooperate with the IMC security policy server and the iNode client.
Portal system
A typical portal system consists of these basic components: authentication client, access device, portal authentication server, portal Web server, AAA server, and security policy server.
Figure 1 Portal system
Authentication client
An authentication client is a Web browser that runs HTTP/HTTPS or a user host that runs a portal client. Security check for the user host is implemented through the interaction between the portal client and the security policy server. Only the iNode client is supported.
Access device
An access device provides access services. It has the following functions:
·     Redirects all HTTP or HTTPS requests of unauthenticated users to the portal Web server.
·     Interacts with the portal authentication server and the AAA server to complete authentication, authorization, and accounting.
·     Allows users that pass portal authentication to access authorized network resources.
Portal server
A portal server collectively refers to a portal authentication server and portal Web server.
The portal Web server pushes the Web authentication page to authentication clients and forwards user authentication information (username and password) to the portal authentication server. The portal authentication server receives authentication requests from authentication clients and interacts with the access device to authenticate users. The portal Web server is typically integrated with the portal authentication server and it can also be an independent server.
AAA server
The AAA server interacts with the access device to implement authentication, authorization, accounting for portal users. In a portal system, a RADIUS server can perform authentication, authorization, accounting for portal users, and an LDAP server can perform authentication for portal users.
Security policy server
The security policy server interacts with the portal client and the access device for security check and authorization for users. Only hosts that run portal clients can interact with the security policy server.
The components of a portal system interact as follows:
1.     An unauthenticated user initiates authentication by accessing an Internet website through a Web browser. When receiving the HTTP or HTTPS request, the access device redirects it to the Web authentication page provided by the portal Web server. The user can also visit the authentication website to log in. The user must log in through the iNode client for extended portal functions.
2.     The user enters the authentication information on the authentication page/dialog box and submits the information. The portal Web server forwards the information to the portal authentication server. The portal authentication server processes the information and forwards it to the access device.
3.     The access device interacts with the AAA server to implement authentication, authorization, accounting for the user.
4.     If security policies are not imposed on the user, the access device allows the authenticated user to access networks.
If security policies are imposed on the user, the portal client, the access device, and the security policy server interact to check the user host. If the user passes the security check, the security policy server authorizes the user to access resources based on the check result.
System components
As shown in Figure 2, a local portal system consists of an authentication client, access device, and AAA server. The access device acts as both the portal Web server and the portal authentication server to provide the local portal Web service for the authentication client. The authentication client can only be a Web browser, and it cannot be a user host that runs a portal client. Therefore, extended portal functions are not supported and no security policy server is required.
Figure 2 System components
Portal page customization
To provide the local portal web service, you must customize a set of authentication pages that the device will push to users. You can customize multiple sets of authentication pages, compress each set of the pages to a .zip file, and upload the compressed files to the storage medium of the device. On the device, you must specify one of the files as the default authentication page file by using the default-logon-page command.
For more information about authentication page customization, see "Customizing authentication pages."
Portal authentication has three modes: direct authentication, re-DHCP authentication, and cross-subnet authentication. In direct authentication and re-DHCP authentication, no Layer 3 forwarding devices exist between the authentication client and the access device. In cross-subnet authentication, Layer 3 forwarding devices can exist between the authentication client and the access device.
Direct authentication
A user manually configures a public IP address or obtains a public IP address through DHCP. Before authentication, the user can access only the portal Web server and predefined authentication-free websites. After passing authentication, the user can access other network resources. The process of direct authentication is simpler than that of re-DHCP authentication.
Re-DHCP authentication
Before a user passes authentication, DHCP allocates an IP address (a private IP address) to the user. The user can access only the portal Web server and predefined authentication-free websites. After the user passes authentication, DHCP reallocates an IP address (a public IP address) to the user. The user then can access other network resources. No public IP address is allocated to users who fail authentication. Re-DHCP authentication saves public IP addresses. For example, an ISP can allocate public IP addresses to broadband users only when they access networks beyond the residential community network.
Only the iNode client supports re-DHCP authentication. IPv6 portal authentication does not support the re-DHCP authentication mode.
Cross-subnet authentication is similar to direct authentication, except it allows Layer 3 forwarding devices to exist between the authentication client and the access device.
In direct authentication, re-DHCP authentication, and cross-subnet authentication, a user's IP address uniquely identifies the user. After a user passes authentication, the access device generates an ACL for the user based on the user's IP address to control forwarding of the packets from the user. Because no Layer 3 forwarding device exists between authentication clients and the access device in direct authentication and re-DHCP authentication, the access device can learn the user MAC addresses. The access device can enhance its capability of controlling packet forwarding by using the learned MAC addresses.
Direct authentication and cross-subnet authentication share the same authentication process. Re-DHCP authentication has a different process as it has two address allocation procedures.
Direct authentication/cross-subnet authentication process (with CHAP/PAP authentication)
Figure 3 Direct authentication/cross-subnet authentication process
The direct/cross-subnet authentication process is as follows:
1.     A portal user access the Internet through HTTP or HTTPS, and the HTTP or HTTPS packet arrives at the access device.
¡     If the packet matches a portal free rule, the access device allows the packet to pass.
¡     If the packet does not match any portal-free rule, the access device redirects the packet to the portal Web server. The portal Web server pushes the Web authentication page to the user for him to enter his username and password.
2.     The portal Web server submits the user authentication information to the portal authentication server.
3.     The portal authentication server and the access device exchange CHAP messages. This step is skipped for PAP authentication. The portal authentication server decides the method (CHAP or PAP) to use.
4.     The portal authentication server adds the username and password into an authentication request packet and sends it to the access device. Meanwhile, the portal authentication server starts a timer to wait for an authentication reply packet.
5.     The access device and the RADIUS server exchange RADIUS packets.
6.     The access device sends an authentication reply packet to the portal authentication server to notify authentication success or failure.
7.     The portal authentication server sends an authentication success or failure packet to the client.
8.     If the authentication is successful, the portal authentication server sends an authentication reply acknowledgment packet to the access device.
If the client is an iNode client, the authentication process includes step 9 and step 10 for extended portal functions. Otherwise the authentication process is complete.
9.     The client and the security policy server exchange security check information. The security policy server detects whether or not the user host installs anti-virus software, virus definition files, unauthorized software, and operating system patches.
10.     The security policy server authorizes the user to access certain network resources based on the check result. The access device saves the authorization information and uses it to control access of the user.
Re-DHCP authentication process (with CHAP/PAP authentication)
Figure 4 Re-DHCP authentication process
The re-DHCP authentication process is as follows:
Step 1 through step 7 are the same as those in the direct authentication/cross-subnet authentication process.
8.     After receiving the authentication success packet, the client obtains a public IP address through DHCP. The client then notifies the portal authentication server that it has a public IP address.
9.     The portal authentication server notifies the access device that the client has obtained a public IP address.
10.     The access device detects the IP change of the client through DHCP and then notifies the portal authentication server that it has detected an IP change of the client IP.
11.     After receiving the IP change notification packets sent by the client and the access device, the portal authentication server notifies the client of login success.
12.     The portal authentication server sends an IP change acknowledgment packet to the access device.
Step 13 and step 14 are for extended portal functions.
13.     The client and the security policy server exchanges security check information. The security policy server detects whether or not the user host installs anti-virus software, virus definition files, unauthorized software, and operating system patches.
14.     The security policy server authorizes the user to access certain network resources based on the check result. The access device saves the authorization information and uses it to control access of the user.
To use portal authentication that supports EAP, the portal authentication server and client must be the IMC portal server and the iNode portal client. Local portal authentication does not support EAP authentication.
Compared with username and password based authentication, digital certificate-based authentication ensures higher security.
The Extensible Authentication Protocol (EAP) supports several digital certificate-based authentication methods, for example, EAP-TLS. Working together with EAP, portal authentication can implement digital certificate-based user authentication.
Figure 5 Portal support for EAP working flow diagram
As shown in Figure 5, the authentication client and the portal authentication server exchange EAP authentication packets. The portal authentication server and the access device exchange portal authentication packets that carry the EAP-Message attributes. The access device and the RADIUS server exchange RADIUS packets that carry the EAP-Message attributes. The RADIUS server that supports the EAP server function processes the EAP packets encapsulated in the EAP-Message attributes, and provides the EAP authentication result.
The access device does not process but only transports EAP-Message attributes between the portal authentication server and the RADIUS server. Therefore, the access device requires no additional configuration to support EAP authentication.
The access device uses portal filtering rules to control user traffic forwarding.
Based on the configuration and authentication status of portal users, the device generates the following categories of portal filtering rules:
·     Category-1—The rule permits user packets that are destined for the portal Web server and packets that match the portal-free rules to pass through.
·     Category-2—For an authenticated user with no ACL authorized, the rule allows the user to access any destination network resources. For an authenticated user with an ACL authorized, the rule allows users to access resources permitted by the ACL. The device adds the rule when a user comes online and deletes the rule when the user goes offline.
The device supports the following types of authorization ACLs:
¡     Basic ACLs (ACL 2000 to ACL 2999).
¡     Advanced ACLs (ACL 3000 to ACL 3999).
For an authorization ACL to take effect, make sure the ACL exists and has ACL rules excluding rules configured with the counting, established, fragment, source-mac, or logging keyword. For more information about ACL rules, see ACL commands in ACL and QoS Command Reference.
·     Category-3—The rule redirects all HTTP or HTTPS requests from unauthenticated users to the portal Web server.
·     Category-4—For direct authentication and cross-subnet authentication, the rule forbids any user packets to pass through. For re-DHCP authentication, the device forbids user packets with private source addresses to pass.
After receiving a user packet, the device compares the packet against the filtering rules from category-1 to category-4. Once the packet matches a rule, the matching process completes.
MAC-based quick portal authentication is applicable to scenarios where users access the network frequently. It allows users to pass authentication without entering a username and password. MAC-based quick portal authentication is also called MAC-trigger authentication or transparent portal authentication.
A MAC binding server is required for MAC-trigger authentication. The MAC binding server records the MAC-to-account bindings of portal users for authentication. The account contains the portal authentication information of the user, including username and password.
Only IPv4 direct authentication supports MAC-based quick portal authentication.
The authentication is implemented as follows:
1.     When a user accesses the network for the first time, the access device generates a MAC-trigger entry that records the user's MAC address and access interface. The user can access the network without performing portal authentication if the user's network traffic is below the free-traffic threshold.
2.     When the user's network traffic reaches the threshold, the access device sends a MAC binding query to the MAC binding server.
3.     The MAC binding server checks whether the MAC address of the user is bound with a portal user account.
¡     If a matching MAC-account binding exists, the MAC binding server sends the user authentication information to the access device to initiate portal authentication. The user is authenticated without entering the username and password.
-     If the user fails portal authentication, an authentication failure message is returned to the user. The MAC-trigger entry of the user on the access device is deleted when the entry ages out.
-     If the user passes portal authentication, the access device deletes the MAC-trigger entry of the user.
¡     If no matching MAC-account binding exists, the MAC binding server notifies the access device to perform normal portal authentication for the user.
-     If the user fails portal authentication, an authentication failure message is returned to the user. The whole process is finished.
-     If the user passes portal authentication, the access device sends the user's MAC address and authentication information to the MAC binding server for MAC-account binding. Additionally, the access device deletes the MAC-trigger entry of the user.
·     For information about MAC binding server configuration, see the user manual of the server.
On a network where portal is used in conjunction with NAT444, portal and NAT444 cooperate as follows:
1.     After a portal user passes AAA authentication and is assigned a private IP address, portal notifies NAT444 of the user login.
2.     The NAT444 gateway assigns a public IP address and a port block to the portal user. Then, it sends the user private address, public address, and port block mapping to portal.
On the NAT444 gateway, if no public IP address is available to allocate to the user, portal logs out the user.
3.     Portal records the mapping, and reports the mapping to the AAA server. Then, the portal user can use the public IP address and port block to access the external network.
Through the portal and NAT444 cooperation, the AAA server can obtain and maintain NAT mapping information for all portal users, which facilitates user tracing.
To use portal in conjunction with NAT444, specify the user address type as private IPv4 address in the authentication ISP domain for portal users by using the user-address-type private-ipv4 command. For more information about specifying the user address type in an ISP domain, see "Configuring AAA." For more information about NAT444, see NAT in Layer 3—IP Services Configuration Guide.
In portal authentication, the device can redirect users' HTTPS requests to the portal Web server. You can use one of the following local certificates for the HTTPS redirect service according to the security requirements and the configuration complexity:
·     Self-signed certificate—Using this type of certificate is simple in configuration but has low security. You do not need to associate an SSL server policy with the HTTPS redirect service and the default SSL parameters are used. However, a self-signed certificate is not trusted by the browser. When the device redirects HTTPS requests to the portal Web server, a certificate security warning prompt might appear on the browser. If you accept the security risks stated in the prompt, you can ignore the prompt to browse the page.
·     CA-signed certificate—Using this type of certificate is complex in configuration but has high security. You must obtain a CA certificate, request a local certificate from the CA, create an SSL server policy (with policy name of https_redirect), and associate the SSL server policy with the HTTPS redirect service.
For more information about digital certificates, see "Configuring PKI." For more information about the SSL server policy configuration, see "Configuring SSL."
Portal authentication through Web does not support security check for users. To implement security check, the client must be the iNode client.
Portal authentication supports NAT traversal whether it is initiated by a Web client or an iNode client. NAT traversal must be configured when the portal client is on a private network and the portal server is on a public network.
To configure portal authentication, perform the following tasks:
1.     Configuring a remote portal service
Perform this task if a remote portal server is used.
¡     Configuring a remote portal authentication server
¡     Configuring a portal Web server
2.     Configuring a local portal service
Perform this task if the access device acts as a portal authentication server and portal Web server.
¡     Configuring the local portal service features
3.     Enabling portal authentication and specifying a portal Web server
Choose the options to configure on an interface.
¡     Enabling portal authentication on an interface
¡     Specifying a portal Web server on an interface
4.     (Optional.) Configure parameters for preauthentication portal users
¡     Configuring a portal preauthentication domain
¡     Specifying a preauthentication IP address pool
5.     (Optional.) Specifying a portal authentication domain
6.     (Optional.) Controlling portal user access
¡     Configuring a portal-free rule
¡     Configuring an authentication source subnet
¡     Configuring an authentication destination subnet
¡     Configuring a portal-forbidden rule
¡     Specifying port numbers of Web proxy servers
¡     Setting the maximum number of portal users
¡     Enabling strict-checking on portal authorization information
¡     Allowing only users with DHCP-assigned IP addresses to pass portal authentication
¡     Blocking portal users that fail portal authentication
¡     Configuring support of portal authentication for dual stack
¡     Enabling intra-VLAN roaming for portal users
¡     Enabling outgoing packets filtering
¡     Configuring the portal fail-permit feature
7.     (Optional.) Configuring portal detection features
¡     Configuring online detection of portal users
¡     Configuring portal authentication server detection
¡     Configuring portal Web server detection
¡     Enabling DHCP packet capture
¡     Configuring portal user synchronization
8.     (Optional.) Configuring attributes for portal packets and RADIUS packets
¡     Configuring portal packet attributes
You can configure the BAS-IP or BAS-IPv6 attribute for portal packets and specify the device ID.
¡     Configuring attributes for RADIUS packets
You can configure the NAS-Port-Id attribute  and apply a NAS-ID profile to an interface.
9.     (Optional.) Configuring MAC-based quick portal authentication
a.     Configuring a remote MAC binding server
b.     Configuring a local MAC binding server
c.     Specifying a MAC binding server on an interface
d.     Configure cloud MAC-trigger authentication
10.     (Optional.) Configuring online and offline related features for portal users
¡     Logging out online portal users
11.     (Optional.) Configuring extended portal authentication features
¡     Setting the user traffic backup threshold
¡     Disabling the Rule ARP or ND entry feature for portal clients
¡     Disabling traffic accounting for portal users
¡     Configuring Web redirect
¡     Configuring portal safe-redirect
¡     Setting the maximum number of portal redirection sessions for a single user
¡     Excluding an attribute from portal protocol packets
¡     Configuring support of portal authentication for third-party authentication
¡     Setting the user synchronization interval for portal authentication using OAuth
¡     Configuring user synchronization for portal authentication using the WiFiDog protocol
¡     Configuring portal authentication information report interval
¡     Configuring portal advertisement push
12.     (Optional.) Monitoring portal authentication
¡     Enabling portal logging
¡     Configuring the portal authentication monitoring feature
The portal feature provides a solution for user identity authentication and security check. To complete user identity authentication, portal must cooperate with RADIUS.
Before you configure portal, you must complete the following tasks:
·     The portal authentication server, portal Web server, and RADIUS server have been installed and configured correctly.
·     To use the re-DHCP portal authentication mode, make sure the DHCP relay agent is enabled on the access device, and the DHCP server is installed and configured correctly.
·     The portal client, access device, and servers can reach each other.
·     To use the remote RADIUS server, configure usernames and passwords on the RADIUS server, and configure the RADIUS client on the access device. For information about RADIUS client configuration, see "Configuring AAA."
·     To implement extended portal functions, install and configure IMC EAD. Make sure the ACLs configured on the access device correspond to the isolation ACL and the security ACL on the security policy server. For information about security policy server configuration on the access device, see "Configuring AAA." For installation and configuration about the security policy server, see IMC EAD Security Policy Help.
With portal authentication enabled, the device searches for a portal authentication server for a received portal request packet according to the source IP address and VPN instance information of the packet.
·     If a matching portal authentication server is found, the device regards the packet valid and sends an authentication response packet to the portal authentication server. After a user logs in to the device, the user interacts with the portal authentication server as needed.
·     If no matching portal authentication server is found, the device drops the packet.
Do not delete a portal authentication server in use. Otherwise, users authenticated by that server cannot log out correctly.
2.     Create a portal authentication server and enter its view.
portal server server-name
You can create multiple portal authentication servers.
3.     Specify the IP address of the portal authentication server.
IPv4:
ip ipv4-address [ vpn-instance vpn-instance-name ] [ key { cipher | simple } string ]
IPv6:
ipv6 ipv6-address [ vpn-instance vpn-instance-name ] [ key { cipher | simple } string ]
4.     (Optional.) Set the destination UDP port number used by the device to send unsolicited portal packets to the portal authentication server.
port port-number
By default, the UDP port number is 50100.
This port number must be the same as the listening port number specified on the portal authentication server.
5.     (Optional.) Specify the portal authentication server type.
server-type { cmcc | imc }
By default, the portal authentication server type is IMC.
The specified server type must be the same as the type of the portal authentication server actually used.
6.     (Optional.) Set the maximum number of times and the interval for retransmitting a logout notification packet.
logout-notify retry retries interval interval
By default, the device does not retransmit a logout notification packet.
7.     (Optional.) Configure the device to periodically register with the portal authentication server.
server-register [ interval interval-value ]
By default, the device does not register with a portal authentication server.
To configure a portal Web server, perform the following tasks:
1.     Configure basic parameters for a portal Web server
2.     (Optional.) Enabling the captive-bypass feature
3.     (Optional.) Configuring a match rule for URL redirection
2.     Create a portal Web server and enter its view.
portal web-server server-name
You can create multiple portal Web servers.
3.     Specify the VPN instance to which the portal Web server belongs.
By default, the portal Web server belongs to the public network.
4.     Specify the URL of the portal Web server.
url url-string
By default, no URL is specified for a portal Web server.
5.     Configure the parameters to be carried in the URL when the device redirects it to users.
url-parameter param-name { nas-id | nas-port-id | original-url | source-address | source-mac [ format section { 1 | 3 | 6 } { lowercase | uppercase } ] [ encryption { aes | des } key { cipher | simple } string ] | value expression | vlan }
By default, no redirection URL parameters are configured.
6.     (Optional.) Specify the portal Web server type.
server-type { cmcc | imc | ise | oauth | wifidog }
By default, the portal Web server type is IMC.
This configuration is applicable to only to the remote portal service.
The specified server type must be the same as the type of the portal Web server actually used.
Typically, when iOS mobile devices or some Android mobile devices are connected a portal-enabled network, the device pushes the authentication page to the mobile devices.
The captive-bypass feature enables the device to push the portal authentication page to the iOS and Android devices only when the users access the Internet by using a browser. If the users do not perform authentication but press the home button to return to the desktop, the Wi-Fi connection is terminated. To maintain the Wi-Fi connection in such cases, you can enable the optimized captive-bypass feature.
When optimized captive-bypass is enabled, the portal authentication page is automatically pushed to iOS mobile devices after they connects to the network. Users can perform authentication on the page or press the home button to return to the desktop without performing authentication, and the Wi-Fi connection is not terminated.
When an iOS client is connected to a network, it automatically sends a server reachability detection packet to determine whether the Apple server is reachable. If the server is reachable, the Wi-Fi connection displays connected. If the server is not reachable, the Wi-Fi connection is terminated.
When the network condition is poor, the device cannot detect a server reachability detection packet from an iOS mobile client within the captive-bypass detection timeout time. The client cannot receive a response for the server reachability detection packet, and therefore it determines the server to be unreachable and terminates the Wi-Fi connection. To avoid Wi-Fi disconnections caused by server reachability detection failure, set a longer captive-bypass detection timeout time when the network condition is poor.
2.     Enter portal Web server view.
3.     Enable the captive-pass feature.
captive-bypass [ android | ios [ optimize ] ] enable
By default, the captive-bypass feature is disabled. The device automatically pushes the portal authentication page to iOS mobile devices and some Android mobile devices when they are connected to a portal-enabled network.
4.     (Optional.) Set the captive-bypass detection timeout time.
a.     Return to system view.
b.     Set the captive-bypass detection timeout time.
portal captive-bypass optimize delay seconds
By default, the captive-bypass detection timeout time is 6 seconds.
A URL redirection match rule matches HTTP or HTTPS requests by user-requested URL or User-Agent information, and redirects the matching HTTP or HTTPS requests to the specified redirection URL.
For a portal Web server, you can configure the url command and the if-match command for URL redirection. The url command redirects all HTTP or HTTPS requests from unauthenticated users to the portal Web server for authentication. The if-match command allows for flexible URL redirection by redirecting specific HTTP or HTTPS requests to specific redirection URLs.
For a user to successfully access a redirection URL, configure a portal-free rule to allow HTTP or HTTPS requests destined for the redirection URL to pass. For information about configuring portal-free rules, see the portal free-rule command.
If both the url and if-match commands are executed, the if-match command takes priority to perform URL redirection.
If both portal safe-redirect and URL redirection match rules are configured, the device preferentially uses URL redirection match rules to perform URL redirection.
3.     Configure a match rule for URL redirection.
if-match { original-url url-string redirect-url url-string [ url-param-encryption { aes | des } key { cipher | simple } string ] | user-agent string redirect-url url-string }
After a local portal service is configured, the device acts as the portal Web server and portal authentication server to perform portal authentication on users. The portal authentication page file is saved in the root directory of the device.
For an interface to use the local portal service, the URL of the portal Web server specified for the interface must meet the following requirements:
·     The IP address in the URL must be the IP address of a Layer 3 interface (except 127.0.0.1) on the device, and the IP address must be reachable to portal clients.
·     The URL must be ended with /portal/. For example: http://1.1.1.1/portal/.
You must customize the authentication pages and upload them to the device.
Authentication pages are HTML files. Local portal authentication requires the following authentication pages:
·     Logon page
·     Logon success page
·     Logon failure page
·     Online page
·     System busy page
·     Logoff success page
You must customize the authentication pages, including the page elements that the authentication pages will use, for example, back.jpg for authentication page Logon.htm.
Follow the authentication page customization rules when you edit the authentication page files.
File name rules
The names of the main authentication page files are fixed (see Table 1). You can define the names of the files other than the main authentication page files. File names and directory names are case insensitive.
Table 1 Main authentication page file names
File name
Logon page
logon.htm
Logon success page
logonSuccess.htm
Logon failure page
logonFail.htm
Online page
Pushed after the user gets online for online notification
online.htm
System busy page
Pushed when the system is busy or the user is in the logon process
busy.htm
Logoff success page
logoffSuccess.htm
Page request rules
A local portal Web service supports only Get and Post requests.
·     Get requests—Used to get the static files in the authentication pages and allow no recursion. For example, if file Logon.htm includes contents that perform Get action on file ca.htm, file ca.htm cannot include any reference to file Logon.htm.
·     Post requests—Used when users submit username and password pairs, log in, and log out.
Post request attribute rules
1.     Observe the following requirements when editing a form of an authentication page:
¡     An authentication page can have multiple forms, but there must be one and only one form whose action is logon.cgi. Otherwise, user information cannot be sent to the access device.
¡     The username attribute is fixed as PtUser. The password attribute is fixed as PtPwd.
¡     The value of the PtButton attribute is either Logon or Logoff, which indicates the action that the user requests.
¡     A logon Post request must contain PtUser, PtPwd, and PtButton attributes.
¡     A logoff Post request must contain the PtButton attribute.
2.     Authentication pages logon.htm and logonFail.htm must contain the logon Post request.
The following example shows part of the script in page logon.htm.
<form action=logon.cgi method = post >
<p>User name:<input type="text" name = "PtUser" style="width:160px;height:22px" maxlength=64>
<p>Password :<input type="password" name = "PtPwd" style="width:160px;height:22px" maxlength=32>
<p><input type=SUBMIT value="Logon" name = "PtButton" style="width:60px;" onclick="form.action=form.action+location.search;">
</form>
3.     Authentication pages logonSuccess.htm and online.htm must contain the logoff Post request.
The following example shows part of the script in page online.htm.
<p><input type=SUBMIT value="Logoff" name="PtButton" style="width:60px;">
</form>
Page file compression and saving rules
You must compress the authentication pages and their page elements into a standard zip file.
·     The name of a zip file can contain only letters, numbers, and underscores.
·     The authentication pages must be placed in the root directory of the zip file.
·     Zip files can be transferred to the device through FTP or TFTP and must be saved in the root directory of the device.
Examples of zip files on the device:
<Sysname> dir
Directory of flash:
   1     -rw-      1405  Feb 28 2008 15:53:20   abc1.zip
   0     -rw-      1405  Feb 28 2008 15:53:31   abc2.zip
   2     -rw-      1405  Feb 28 2008 15:53:39   abc3.zip
   3     -rw-      1405  Feb 28 2008 15:53:44   abc4.zip
2540 KB total (1319 KB free)
Redirecting authenticated users to a specific webpage
To make the device automatically redirect authenticated users to a specific webpage, do the following in logon.htm and logonSuccess.htm:
1.     In logon.htm, set the target attribute of Form to _blank.
See the contents in gray:
    <form method=post action=logon.cgi target="_blank">
2.     Add the function for page loading pt_init() to LogonSuccess.htm.
    <html>
    <head>
    <title>LogonSuccess</title>
    <script type="text/javascript" language="javascript" src="pt_private.js"></script>
    </head>
    <body onload="pt_init();" onbeforeunload="return pt_unload();">
    </body>
</html>
Before you configure an HTTPS-based local portal Web service, you must complete the following tasks:
·     Configure a PKI policy, obtain the CA certificate, and request a local certificate. For more information, see "Configuring PKI."
·     Configure an SSL server policy, and specify the PKI domain configured in the PKI policy.
During SSL connection establishment, the user browser might display a message that it cannot verify server identity by certificate. For users to perform portal authentication without checking such a message, configure an SSL server policy to request a client-trusted certificate on the device. The name of the policy must be https_redirect. For more information about SSL server policy configuration, see "Configuring SSL."
2.     Create an HTTP- or HTTPS-based local portal Web service and enter its view.
portal local-web-server { http | https [ ssl-server-policy policy-name ] [ tcp-port port-number ] }
3.     Specify the default authentication page file for the local portal Web service.
default-logon-page filename
The default setting varies by device model. For more information, see the command reference.
4.     (Optional.) Configure the listening TCP port for the local portal Web service.
By default, the HTTP service listening port number is 80 and the HTTPS service listening port number is the TCP port number set by the portal local-web-server command.
1.     (Optional.) Bind an endpoint type to an authentication page file.
logon-page bind { device-type { computer | pad | phone } | device-name device-name } * file file-name
By default, no endpoint type is bound to an authentication page file.
2.     (Optional.) Enable local portal user password modification.
user-password modify enable
By default, local portal user password modification is disabled.
If global password control is enabled by using the password-control enable network-class command, the new password of a local portal user must meet the password control requirements. For more information about password control, see "Configuring password control."
3.     Configure the redirect URL for authentication success.
login success-url url-string
By default, no redirection URL for authentication success is configured.
4.     Configure the redirect URL for authentication failure.
login failed-url url-string
By default, no redirection URL for authentication failure is configured.
When portal users use third-party software to perform portal authentication, the device checks the User-Agent string in portal authentication requests. If the User-Agent string does not include the match string specified on the device, users will fail portal authentication.
The User-Agent string includes hardware vendor, software operating system, browser, and search engine information. Perform this task to specify a string that can match the User-Agent information of the third-party software, so users can pass portal authentication by using that third-party software. For example, for users to pass portal authentication by following a WeChat official account, configure the User-Agent match string on the device as MicroMessenger.
2.     Enter local portal Web service view.
3.     Configure the User-Agent match string.
user-agent user-agent-string
By default, the User-Agent match string is MicroMessenger.
When you enable portal authentication on an interface, follow these restrictions and guidelines:
·     For portal authentication to take effect on an Ethernet interface, do not add the Ethernet interface to an aggregation group.
·     Cross-subnet authentication mode (layer3) does not require Layer 3 forwarding devices between the access device and the portal authentication clients. However, if a Layer 3 forwarding device exists between the authentication client and the access device, you must use the cross-subnet portal authentication mode.
·     You can enable both IPv4 portal authentication and IPv6 portal authentication on an interface.
When you configure re-DHCP portal authentication on an interface, follow these restrictions and guidelines:
·     Make sure the interface has a valid IP address before you enable re-DHCP portal authentication on the interface.
·     With re-DHCP portal authentication, configure authorized ARP on the interface as a best practice to make sure only valid users can access the network. With authorized ARP configured on the interface, the interface learns ARP entries only from the users who have obtained a public address from DHCP.
·     For successful re-DHCP portal authentication, make sure the BAS-IP or BAS-IPv6 attribute value is the same as the device IP address specified on the portal authentication server. To configure the attribute, use the portal { bas-ip | bas-ipv6 } command.
·     An IPv6 portal server does not support re-DHCP portal authentication.
2.     Enter Layer 3 interface view.
3.     Enable portal authentication.
IPv4:
portal enable method { direct | layer3 | redhcp }
IPv6:
portal ipv6 enable method { direct | layer3 }
By default, portal authentication is disabled.
With a portal Web server specified on an interface, the device redirects the HTTP requests of portal users on the interface to the portal Web server.
You can specify both an IPv4 portal Web server and an IPv6 portal Web server on an interface.
3.     Specify a portal Web server on the interface.
portal [ ipv6 ] apply web-server server-name [ secondary ]
By default, no portal Web servers are specified on an interface.
A portal preauthentication domain defines user attributes assigned to preauthentication portal users on a portal-enabled interface after the users obtain IP addresses. Before the preauthentication users pass portal authentication, they have limited access to the network based on the assigned user attributes (such as ACL and CAR). After the users pass portal authentication, they are assigned new attributes by the AAA server. After the users go offline, they are re-assigned user attributes in the preauthentication domain.
The portal preauthentication domain takes effect only on portal users with IP addresses obtained through DHCP or DHCPv6.
The portal preauthentication domain does not take effect on interfaces enabled with cross-subnet portal authentication.
Make sure you specify an existing ISP domain as a portal preauthentication domain. If the specified ISP domain does not exist, the device might operate incorrectly.
You must delete a preauthentication domain (by using the undo portal [ ipv6 ] pre-auth domain command) and reconfigure it in the following situations:
·     You create the ISP domain after specifying it as the preauthentication domain.
·     You delete the specified ISP domain and then re-create it.
For the authorization ACL in the preauthentication domain, the following rules apply:
·     If the traffic of preauthentication users matches a rule in the ACL, the device processes the traffic based on the permit or deny statement of the rule.
·     If the ACL does not exist or the destination address permitted by a rule in the ACL is set to any, the device does not control user access. Users can access any network resources without passing portal authentication.
·     If the ACL does not have any rules, the device allows users to access network resources only after the users pass authentication.
·     If the traffic of preauthentication users does not match any rule in the ACL, the device pushes the authentication page to the users. The users can access the network resources after passing authentication.
·     If the ACL contains rules that specify a source address, users might not be able to get online. Do not specify a source IPv4, IPv6, or MAC address when you configure a rule in the ACL.
3.     Specify a portal preauthentication domain.
portal [ ipv6 ] pre-auth domain domain-name
By default, no portal preauthentication domain is specified.
You must specify a preauthentication IP address pool on a portal-enabled Layer 3 interface in the following situation:
·     Portal users access the network through a subinterface of the portal-enabled Layer 3 interface.
·     The subinterface does not have an IP address.
·     Portal users need to obtain IP addresses through DHCP.
After a user connects to a portal-enabled interface, the user uses an IP address for portal authentication according to the following rules:
·     If the interface is configured with a preauthentication IP address pool, the user uses the following IP address:
¡     If the client is configured to obtain an IP address automatically through DHCP, the user obtains an address from the specified IP address pool.
¡     If the client is configured with a static IP address, the user uses the static IP address. However, if the interface does not have an IP address, users using static IP addresses cannot pass authentication.
·     If the interface has an IP address but no preauthentication IP pool specified, the user uses the static IP address or the IP address obtained from a DHCP server.
·     If the interface has no IP address or preauthentication IP pool specified, the user cannot perform portal authentication.
After the user passes portal authentication, the AAA server authorizes an IP address pool for re-assigning an IP address to the user. If no authorized IP address pool is deployed, the user continues using the previous IP address.
This configuration takes effect only when the direct IPv4 portal authentication is enabled on the interface.
Make sure the specified IP address pool exists and is complete. Otherwise, the user cannot obtain the IP address and cannot perform portal authentication.
If the portal user does not perform authentication or fails to pass authentication, the assigned IP address is still retained.
3.     Specify a preauthentication IP address pool on the interface.
portal [ ipv6 ] pre-auth ip-pool pool-name
By default, no preauthentication IP address pool is specified on an interface.
An authentication domain defines a set of authentication, authorization, and accounting policies. Each portal user belongs to an authentication domain and is authenticated, authorized, and accounted in the domain.
With an authentication domain specified on an interface, the device uses the authentication domain for AAA of portal users. This allows for flexible portal access control.
The device selects the authentication domain for a portal user in this order:
1.     ISP domain specified for the interface.
2.     ISP domain carried in the username.
3.     System default ISP domain.
If the chosen domain does not exist on the device, the device searches for the ISP domain configured to accommodate users assigned to nonexistent domains. If no such ISP domain is configured, user authentication fails. For information about ISP domains, see "Configuring AAA."
If an authorization VPN instance is specified in the authentication domain, follow these restrictions and guidelines:
·     Make sure the authorization VPN instance exists. If you specify a nonexistent VPN instance, users cannot come online.
·     When users are online, do not delete the authorization VPN instance. Deleting the authorization VPN instance will log out the users.
For the authorization ACL in the authentication domain, the following rules apply:
·     If the user traffic matches a rule in the ACL, the device processes the traffic based on the permit or deny statement of the rule.
·     If the user traffic does not match any rule in the ACL, the device permits the traffic. To deny such traffic, configure the last rule in the ACL to deny all packets by using the rule deny ip command.
3.     Specify an portal authentication domain on the interface.
portal [ ipv6 ] domain domain-name
By default, no portal authentication domain is specified on an interface.
You can specify both an IPv4 portal authentication domain and an IPv6 portal authentication domain on an interface.
A portal-free rule allows specified users to access specified external websites without portal authentication.
The matching items for a portal-free rule include the host name, source/destination IP address, TCP/UDP port number, source MAC address, access interface, and VLAN. Packets matching a portal-free rule will not trigger portal authentication, so users sending the packets can directly access the specified external websites.
Restrictions and guidelines for configuring a portal-free rule
If you specify both a VLAN and an interface, the interface must belong to the VLAN. If the interface does not belong to the VLAN, the portal-free rule does not take effect.
You cannot configure two or more portal-free rules with the same filtering criteria. Otherwise, the system prompts that the rule already exists.
Regardless of whether portal authentication is enabled or not, you can only add or remove a portal-free rule. You cannot modify it.
The ACL used by a portal-free rule can contain only IP address object groups and IP quintuples (source and destination IP addresses, source and destination port numbers, and transport layer protocol).
Configuring an IP-based portal-free rule
2.     Configure an IP-based portal-free rule.
IPv4:
portal free-rule rule-number { destination ip { ipv4-address { mask-length | mask } | any } [ tcp tcp-port-number | udp udp-port-number ] | source ip { ipv4-address { mask-length | mask } | any } [ tcp tcp-port-number | udp udp-port-number ] } * [ interface interface-type interface-number ]
IPv6:
portal free-rule rule-number { destination ipv6 { ipv6-address prefix-length | any } [ tcp tcp-port-number | udp udp-port-number ] | source ipv6 { ipv6-address prefix-length | any } [ tcp tcp-port-number | udp udp-port-number ] } * [ interface interface-type interface-number ]
By default, no IP-based portal-free rules are configured.
Configuring a source-based portal-free rule
2.     Configure a source-based portal-free rule.
portal free-rule rule-number source { interface interface-type interface-number | mac mac-address | object-group object-group-name | vlan vlan-id } * }
By default, no source-based portal-free rules are configured.
The vlan vlan-id option takes effect only on portal users that access the network through VLAN interfaces.
Configuring a destination-based portal-free rule
2.     Configure a destination-based portal-free rule.
portal free-rule rule-number destination host-name
By default, no destination-based portal-free rules are configured.
Before you configure destination-based portal-free rules, make sure a DNS server has been deployed in the network.
Configuring an ACL-based portal-free rule
2.     Configure an ACL-based portal-free rule.
IPv4:
portal free-rule rule-number acl acl-number
IPv6:
portal free-rule rule-number acl ipv6 acl-number
Configuring a description for a portal-free rule
2.     Configure a description for a portal-free rule.
portal free-rule rule-number description text
By default, no description is configured for a portal-free rule.
By configuring authentication source subnets, you specify that only HTTP or HTTPS packets from users on the authentication source subnets can trigger portal authentication. If an unauthenticated user is not on any authentication source subnet, the access device discards all the user's HTTP or HTTPS packets that do not match any portal-free rule.
Authentication source subnets apply only to cross-subnet portal authentication.
In direct or re-DHCP portal authentication mode, a portal user and its access interface (portal-enabled) are on the same subnet. It is not necessary to specify the subnet as the authentication source subnet.
·     In direct mode, the access device regards the authentication source subnet as any source IP address.
·     In re-DHCP mode, the access device regards the authentication source subnet on an interface as the subnet to which the private IP address of the interface belongs.
If both authentication source subnets and destination subnets are configured on an interface, only the authentication destination subnets take effect.
You can configure multiple authentication source subnets. If the source subnets overlap, the subnet with the largest address scope (with the smallest mask or prefix) takes effect.
3.     Configure a portal authentication source subnet.
IPv4:
portal layer3 source ipv4-network-address { mask-length | mask }
By default, users from any subnets must pass portal authentication.
IPv6:
portal ipv6 layer3 source ipv6-network-address prefix-length
By configuring authentication destination subnets, you specify that users trigger portal authentication only when they accessing the specified subnets (excluding the destination IP addresses and subnets specified in portal-free rules). Users can access other subnets without portal authentication.
You can configure multiple authentication destination subnets. If the destination subnets overlap, the subnet with the largest address scope (with the smallest mask or prefix) takes effect.
3.     Configure a portal authentication destination subnet.
IPv4:
portal free-all except destination ipv4-network-address { mask-length | mask }
IPv6:
portal ipv6 free-all except destination ipv6-network-address prefix-length
By default, users accessing any subnets must pass portal authentication.
Portal-forbidden rules are used to filter user packets from the specified sources or destined for the specified destinations. The device drops HTTP or HTTPS packets that match the portal-forbidden rules.
In a portal-forbidden rule, the source and destination IP addresses must be of the same IP type, and the source and destination ports must be of the same transport protocol type.
You can configure multiple portal-forbidden rules.
If the source or destination information in a portal-free rule and that in a portal-forbidden rule overlap, the portal-forbidden rule takes effect.
If you specify a destination host name in a portal-forbidden rule, the device drops users' DNS query packets for the specified host name. In addition, if a DNS server is correctly configured on the device, the device also drops user packets destined for the IP address resolved from the specified host name. If the DNS server is not correctly configured, the rule does not take effect on user packets destined for that IP address.
2.     Configure a portal-forbidden rule.
IPv4:
portal forbidden-rule rule-number [ source { ip { ipv4-address { mask-length | mask } | any } [ tcp tcp-port-number | udp udp-port-number ] | ssid ssid-name } * ] destination { host-name | ip { ipv4-address { mask-length | mask } | any } [ tcp tcp-port-number | udp udp-port-number ] }
IPv6:
portal forbidden-rule rule-number [ source { ipv6 { ipv6-address prefix-length | any } [ tcp tcp-port-number | udp udp-port-number ] | ssid ssid-name } * ] destination { host-name | ipv6 { ipv6-address prefix-length | any } [ tcp tcp-port-number | udp udp-port-number ] }
By default, portal-forbidden rules are configured.
To allow HTTP or HTTPS requests proxied by Web proxy servers to trigger portal authentication, specify the port numbers of the Web proxy servers on the device. If a Web proxy server port is not specified on the device, HTTP or HTTPS requests proxied by the Web proxy server are dropped, and portal authentication cannot be triggered.
Do not specify TCP port number 80 or 443 as the port numbers for Web proxy servers because 80 and 443 are port numbers reserved for portal.
You can specify a maximum of 64 Web proxy server ports for HTTP and HTTPS.
Do not specify the same Web proxy server port for HTTP and HTTPS.
If a user's browser uses the Web Proxy Auto-Discovery (WPAD) protocol to discover Web proxy servers, you must perform the following tasks on the device:
·     Specify the port numbers of the Web proxy servers on the device.
·     Configure portal-free rules to allow user packets destined for the IP address of the WPAD server to pass without authentication.
If portal users enable Web proxy in their browsers, the users must add the IP address of the portal authentication server as a proxy exception in their browsers. Then, HTTP or HTTPS packets that the users send to the portal authentication server will not be sent to Web proxy servers.
2.     Specify the port number of a Web proxy server.
portal web-proxy { http | https } port port-number
By default, no port numbers of Web proxy servers are specified. Proxied HTTP and HTTPS requests are dropped.
Perform this task to control the total number of portal users in the system, and the maximum number of IPv4 or IPv6 portal users on an interface.
Restrictions and guidelines for setting the maximum number of portal users
Make sure the maximum combined number of IPv4 and IPv6 portal users specified on all interfaces does not exceed the system-allowed maximum number. Otherwise, the exceeding number of portal users will not be able to log in to the device.
Setting the global maximum number of portal users
2.     Set the global maximum number of portal users.
portal max-user max-number
By default, no limit is placed on the number of portal users allowed in the system.
If you set the global maximum number smaller than the number of current online portal users on the device, this configuration still takes effect. The online users are not affected but the system forbids new portal users to log in.
Setting the maximum number of portal users on an interface
3.     Set the maximum number of portal users.
portal { ipv4-max-user | ipv6-max-user } max-number
By default, no limit is placed on the number of portal users on an interface.
If you set the maximum number smaller than the current number of portal users on an interface, this configuration still takes effect. The online users are not affected but the system forbids new portal users to log in from the interface.
The strict checking feature allows a portal user to stay online only when the authorization information for the user is successfully deployed.
Enabling strict checking on portal authentication information on an interface
3.     Enable strict checking on portal authorization information.
portal authorization acl strict-checking
By default, strict checking on portal authorization information is disabled on an interface. Portal users stay online even when the authorized ACL or user profile does not exist or the device fails to deploy the authorized ACL or user profile
CAUTION
CAUTION:
·     The device logs out a portal user if the authorized ACL does not exist on the device or the device fails to deploy the authorized ACL.
This feature allows only users with DHCP-assigned IP addresses to pass portal authentication. Use this feature to ensure that only users with valid IP addresses can access the network.
This feature takes effect only when the device acts as both the access device and the DHCP server.
Configuration of this feature does not affect the online portal users.
Allowing only users with DHCP-assigned IP addresses to pass portal authentication on an interface
3.     Allow only users with DHCP-assigned IP addresses to pass portal authentication.
portal [ ipv6 ] user-dhcp-only
By default, both users with IP addresses obtained through DHCP and users with static IP addresses can pass authentication to come online.
CAUTION
CAUTION:
·     With this feature enabled, users with static IP addresses cannot pass portal authentication to come online.
·     To ensure that IPv6 users can pass portal authentication when this feature is enabled, disable the temporary IPv6 address feature on terminal devices. Otherwise, IPv6 users will use temporary IPv6 addresses to access the IPv6 network and will fail portal authentication.
This feature prevents exhaustive password cracking. It blocks a portal user if the user consecutively fails authentication for the specified times within the failure detection period. All authentication requests from the user are dropped by the device till the blocking times out. The blocked portal user can perform portal authentication again when the blocking timeout time expires.
This feature does not block preauthentication portal users.
2.     Configure the device to block portal users that fail portal authentication for the specified times within the specified period.
portal user-block failed-times failed-times period period [ method { ip | mac | username } ]
By default, the device does not block portal users that fail portal authentication.
3.     Set the portal user blocking timeout time.
portal user-block reactive period
By default, the portal user blocking timeout time is 30 minutes.
If you set the portal user blocking timeout time to 0 minutes, blocked portal users cannot perform portal authentication any more.
Typically, IPv4 portal users can access only the IPv4 network after passing portal authentication, and IPv6 portal users can access only the IPv6 network after passing portal authentication. To allow portal users to access both IPv4 and IPv6 networks after passing one type (IPv4 or IPv6) of portal authentication, enable the portal dual-stack feature.
Configuring support of portal authentication for dual stack on an interface
2.     Enable separate IPv4 and IPv6 traffic statistics in portal user offline logs.
portal user-log traffic-separate
By default, IPv4 and IPv6 traffic statistics of a portal user are collectively counted as IPv4 traffic statistics in portal user offline logs.
3.     Enter Layer 3 interface view.
4.     Enable the portal dual-stack feature on the interface.
portal dual-stack enable
By default, the portal dual-stack feature is disabled on an interface.
5.     Enable separate IPv4 and IPv6 traffic statistics for dual-stack portal users on the interface.
portal dual-stack traffic-separate enable
By default, separate IPv4 and IPv6 traffic statistics is disabled for dual-stack portal users on an interface. The device collects IPv4 and IPv6 traffic statistics collectively.
6.     Enable the dual IP feature to carry both IPv4 and IPv6 addresses for single-stack users in remote portal authentication.
portal dual-ip enable
By default, the dual IP feature is disabled.
If intra-VLAN roaming is enabled for portal users on a VLAN interface, an online portal user can access resources from any Layer 2 port in the VLAN without re-authentication.
If intra-VLAN roaming is disabled for portal users, to access external network resources from a Layer 2 port different from the current access port in the VLAN, the user must do the following:
1.     Logs out from the current port.
2.     Re-authenticates on the new Layer 2 port.
Intra-VLAN roaming takes effect only on portal users logging in from VLAN interfaces. It does not take effect on portal users logging in from common Layer 3 interface.
You cannot enable intra-VLAN roaming when online portal users or preauthentication portal users exist on the device.
For intra-VLAN roaming to take effect, you must disable the Rule ARP or ND entry feature by using the undo portal refresh { arp | nd } enable command.
2.     Enable intra-VLAN roaming for portal users.
portal roaming enable
By default, intra-VLAN roaming is disabled for portal users.
When you enable this feature on a portal-enabled interface, the device permits the interface to send the following packets:
·     Packets whose destination IP addresses are IP addresses of authenticated portal users.
·     Packets that match portal-free rules.
Other outgoing packets on the interface are dropped.
Enabling outgoing packets filtering on an interface
3.     Enable outgoing packets filtering on the interface.
portal [ ipv6 ] outbound-filter enable
By default, outgoing packets filtering is disabled on an interface. The interface can send any packets.
You can configure the portal fail-permit feature on an interface. When the access device detects that the portal authentication server or portal Web server is unreachable, it allows users to have network access without portal authentication.
If you enable fail-permit for both the portal authentication server and the portal Web servers, the device does the following:
·     Disables portal authentication when the portal authentication server is unreachable or all the portal Web servers are unreachable.
·     Resumes portal authentication when both the portal authentication and Web servers are reachable.
After portal authentication resumes, unauthenticated users must pass portal authentication to access the network. Users who have passed portal authentication before the fail-permit event can continue accessing the network.
Configuring portal fail-permit on an interface
3.     Enable portal fail-permit for a portal authentication server on the interface.
portal [ ipv6 ] fail-permit server server-name
By default, portal fail-permit is disabled for a portal authentication server on an interface.
4.     Enable portal fail-permit for portal Web servers on the interface.
portal [ ipv6 ] fail-permit web-server
By default, portal fail-permit is disabled for portal Web servers on an interface.
Use the online detection feature to quickly detect abnormal logouts of portal users. Configure ARP or ICMP detection for IPv4 portal users. Configure ND or ICMPv6 detection for IPv6 portal users.
If the device receives no packets from a portal user within the idle time, the device detects the user's online status as follows:
·     ICMP or ICMPv6 detection—Sends ICMP or ICMPv6 requests to the user at configurable intervals to detect the user status.
¡     If the device receives a reply within the maximum number of detection attempts, it considers that the user is online and stops sending detection packets. Then the device resets the idle timer and repeats the detection process when the timer expires.
¡     If the device receives no reply after the maximum number of detection attempts, the device logs out the user.
·     ARP or ND detection—Sends ARP or ND requests to the user and detects the ARP or ND entry status of the user at configurable intervals.
¡     If the ARP or ND entry of the user is refreshed within the maximum number of detection attempts, the device considers that the user is online and stops detection. Then the device resets the idle timer and repeats the detection process when the timer expires.
¡     If the ARP or ND entry of the user is not refreshed after the maximum number of detection attempts, the device logs out the user.
ARP detection and ND detection apply only to direct and re-DHCP portal authentication. ICMP detection applies to all portal authentication modes.
3.     Configure online detection of portal users.
IPv4:
portal user-detect type { arp | icmp } [ retry retries ] [ interval interval ] [ idle time ]
IPv6:
portal ipv6 user-detect type { icmpv6 | nd } [ retry retries ] [ interval interval ] [ idle time ]
By default, online detection is disabled for portal users on an interface.
During portal authentication, if the communication between the access device and portal authentication server is broken, new portal users are not able to log in. Online portal users are not able to log out normally.
To address this problem, the access device needs to be able to detect the reachability changes of the portal server quickly and take corresponding actions to deal with the changes.
The portal authentication server detection feature enables the device to periodically detect portal packets sent by a portal authentication server to determine the reachability of the server. If the device receives a portal packet within a detection timeout (timeout timeout) and the portal packet is valid, the device considers the portal authentication server to be reachable. Otherwise, the device considers the portal authentication server to be unreachable.
Portal packets include user login packets, user logout packets, and heartbeat packets. Heartbeat packets are periodically sent by a server. By detecting heartbeat packets, the device can detect the server's actual status more quickly than by detecting other portal packets.
The portal authentication server detection feature takes effect only when the device has a portal-enabled interface.
Only the IMC portal authentication server supports sending heartbeat packets. To test server reachability by detecting heartbeat packets, you must enable the server heartbeat feature on the IMC portal authentication server.
You can configure the device to take one or more of the following actions when the server reachability status changes:
·     Sending a trap message to the NMS. The trap message contains the name and current state of the portal authentication server.
·     Sending a log message, which contains the name, the current state, and the original state of the portal authentication server.
·     Enabling portal fail-permit. When the portal authentication server is unreachable, the portal fail-permit feature on an interface allows users on the interface to have network access. When the server recovers, it resumes portal authentication on the interface. For more information, see "Configuring the portal fail-permit feature."
Make sure the detection timeout configured on the device is greater than the server heartbeat interval configured on the portal authentication server.
2.     Enter portal authentication server view.
3.     Configure portal authentication server detection.
server-detect [ timeout timeout ] { log | trap } *
By default, portal authentication server detection is disabled.
A portal authentication process cannot complete if the communication between the access device and the portal Web server is broken. To address this problem, you can enable portal Web server detection on the access device.
With the portal Web server detection feature, the access device simulates a Web access process to initiate a TCP connection to the portal Web server. If the TCP connection can be established successfully, the access device considers the detection successful, and the portal Web server is reachable. Otherwise, it considers the detection to have failed.
You can configure the following detection parameters:
·     Detection interval—Interval at which the device detects the server reachability.
·     Maximum number of consecutive failures—If the number of consecutive detection failures reaches this value, the access device considers that the portal Web server is unreachable.
·     Sending a trap message to the NMS. The trap message contains the name and current state of the portal Web server.
·     Sending a log message, which contains the name, the current state, and the original state of the portal Web server.
·     Enabling portal fail-permit. When the portal Web server is unreachable, the portal fail-permit feature on an interface allows users on the interface to have network access. When the server recovers, it resumes portal authentication on the interface. For more information, see "Configuring the portal fail-permit feature."
The portal Web server detection feature takes effect only when the URL of the portal Web server is specified and the device has a portal-enabled interface.
3.     Configure portal Web server detection.
server-detect [ interval interval ] [ retry retries ] { log | trap } *
By default, portal Web server detection is disabled.
4.     Configure the URL and the type for portal Web server detection.
server-detect url string [ detect-type { http | tcp } ]
By default, the URL for portal Web server detection is the URL of the portal Web server. The type of portal Web server detection is TCP detection.
This feature enables the AC to detect the online status of portal users by capturing DHCP packets of the portal users.
When this feature is enabled, the AC captures DHCP packets between a portal user and the DHCP server and obtains the IP address lease information of the user. The AC then detects the online status of the portal user as follows:
·     If the AC captures a DHCP lease renewal packet from the portal user before the lease expires, the AC determines that the portal user is online.
·     If no DHCP lease renewal packet is captured before the lease expires, the AC forcibly logs out the portal user.
For more information about DHCP packets, see DHCP configuration in Layer 3—IP Services Configuration Guide.
The timeout time of the DHCP packet capture timer is the same as the IP address lease time in DHCP packets. This timer resets each time a DHCP packet is captured.
2.     Enable DHCP packet capture to detect online status of portal users.
portal idle-cut dhcp-capture enable
By default, DHCP packet capture is disabled.
Once the access device loses communication with a portal authentication server, the portal user information on the access device and that on the portal authentication server might be inconsistent after the communication resumes. To address this problem, the device provides the portal user synchronization feature. This feature is implemented by sending and detecting portal synchronization packets, as follows:
1.     The portal authentication server sends the online user information to the access device in a synchronization packet at the user heartbeat interval.
The user heartbeat interval is set on the portal authentication server.
2.     Upon receiving the synchronization packet, the access device compares the users carried in the packet with its own user list and performs the following operations:
¡     If a user contained in the packet does not exist on the access device, the access device informs the portal authentication server to delete the user. The access device starts the synchronization detection timer (timeout timeout) immediately when a user logs in.
¡     If the user does not appear in any synchronization packet within a synchronization detection interval, the access device considers the user does not exist on the portal authentication server and logs the user out.
Portal user synchronization requires a portal authentication server to support the portal user heartbeat function. Only the IMC portal authentication server supports the portal user heartbeat function. To implement the portal user synchronization feature, you also need to configure the user heartbeat function on the portal authentication server. Make sure the user heartbeat interval configured on the portal authentication server is not greater than the synchronization detection timeout configured on the access device.
Deleting a portal authentication server on the access device also deletes the user synchronization configuration for the portal authentication server.
3.     Configure portal user synchronization.
user-sync timeout timeout
By default, portal user synchronization is disabled.
Configuring the BAS-IP or BAS-IPv6 attribute
If the device runs Portal 2.0, the unsolicited packets sent to the portal authentication server must carry the BAS-IP attribute. If the device runs Portal 3.0, the unsolicited packets sent to the portal authentication server must carry the BAS-IP or BAS-IPv6 attribute.
After this attribute is configured, the source IP address for unsolicited notification portal packets the device sends to the portal authentication server is the configured BAS-IP or BAS-IPv6 address. If the attribute is not configured, the source IP address of the portal packets is the IP address of the packet output interface.
During a re-DHCP portal authentication or mandatory user logout process, the device sends portal notification packets to the portal authentication server. For the authentication or logout process to complete, make sure the BAS-IP or BAS-IPv6 attribute is the same as the device IP address specified on the portal authentication server.
You must configure the BAS-IP or BAS-IPv6 attribute on a portal authentication-enabled interface if the following conditions are met:
·     The portal authentication server is an IMC server.
·     The portal device IP address specified on the portal authentication server is not the IP address of the portal packet output interface.
Configuring the BAS-IP or BAS-IPv6 attribute on an interface
3.     Configure the BAS-IP or BAS-IPv6 attribute.
IPv4:
portal bas-ip ipv4-address
By default, the BAS-IP attribute of an IPv4 portal reply packet is the source IPv4 address of the packet. The BAS-IP attribute of an IPv4 portal notification packet is the IPv4 address of the packet's output interface.
IPv6:
portal bas-ipv6 ipv6-address
By default, the BAS-IPv6 attribute of an IPv6 portal reply packet is the source IPv6 address of the packet. The BAS-IPv6 attribute of an IPv6 portal notification packet is the IPv6 address of the packet's output interface.
Specifying the device ID
The portal authentication server uses device IDs to identify the devices that send protocol packets to the portal server.
Make sure the configured device ID is different than any other access devices communicating with the same portal authentication server.
2.     Specify the device ID.
portal device-id device-id
By default, a device is not configured with a device ID.
Specifying a format for the NAS-Port-Id attribute
RADIUS servers from different vendors might require different formats of the NAS-Port-Id attribute in the RADIUS packets. You can specify the NAS-Port-Id attribute format as required.
The device supports predefined formats (format 1, 2, 3, and 4). For more information about the formats, see portal commands in Security Command Reference.
2.     Specify the format for the NAS-Port-Id attribute.
portal nas-port-id format { 1 | 2 | 3 | 4 }
By default, the format for the NAS-Port-Id attribute is format 2.
Applying a NAS-ID profile to an interface
By default, the device sends its device name in the NAS-Identifier attribute of all RADIUS requests.
A NAS-ID profile enables you to send different NAS-Identifier attribute strings in RADIUS requests from different VLANs. The strings can be organization names, service names, or any user categorization criteria, depending on the administrative requirements.
For example, map the NAS-ID companyA to all VLANs of company A. The device will send companyA in the NAS-Identifier attribute for the RADIUS server to identify requests from any Company A users.
You can apply a NAS-ID profile to a portal-enabled interface. If no NAS-ID profile is specified on the interface or no matching NAS-ID is found in the specified profile, the device uses the device name as the interface NAS-ID.
2.     Create a NAS-ID profile and enter NAS-ID profile view.
For more information about this command, see AAA commands in Security Command Reference.
3.     Configure a NAS ID and VLAN binding in the profile.
nas-id nas-identifier bind vlan vlan-id
4.     Specify the NAS-ID profile on the interface.
b.     Enter Layer 3 interface view.
c.     Specify the NAS-ID profile on the interface.
portal nas-id-profile profile-name
Restrictions and guidelines for configuring MAC-based quick portal authentication
Only IPv4 direct authentication supports MAC-based quick portal authentication.
For MAC-based quick portal authentication to take effect on an interface configured with a portal preauthentication domain, set the free-traffic threshold to 0 bytes.
You can configure multiple MAC binding servers on the device. For each server, you can configure MAC binding server parameters, such as the server's IP address, VPN instance, port number, and the free-traffic threshold.
2.     Create a MAC binding server and enter its view.
portal mac-trigger-server server-name
3.     Configure a MAC binding server.
¡     Specify the IP address of the MAC binding server.
By default, no IP address is specified for a MAC binding server.
¡     (Optional.) Set the UDP port number on which the MAC binding server listens for MAC binding query packets.
port port-number
By default, the MAC binding server listens for MAC binding query packets on UDP port 50100.
¡     (Optional.) Set the maximum number of attempts and the interval for sending MAC binding queries to the MAC binding server.
binding-retry { retries | interval interval } *
By default, the maximum number of query attempts is 3 and the query interval is 1 second.
¡     (Optional.) Specify the type of the MAC binding server.
By default, the type of a MAC binding server is IMC.
4.     (Optional.) Set the free-traffic threshold.
free-traffic threshold value
By default, the free-traffic threshold is 0 bytes.
5.     (Optional.) Set the NAS-Port-Type value carried in RADIUS requests sent to the RADIUS server.
nas-port-type value
By default, the NAS-Port-Type value carried in RADIUS requests is 15.
6.     (Optional.) Specify the version of the portal protocol.
version version-number
By default, the version of the portal protocol is 1.
7.     (Optional.) Set the timeout the device waits for portal authentication to complete after receiving the MAC binding query response.
authentication-timeout minutes
By default, the portal authentication timeout time is 3 minutes.
8.     (Optional.) Set the aging time for MAC-trigger entries.
aging-time seconds
By default, the aging time for MAC-trigger entries is 300 seconds.
9.     (Optional.) Enable AAA failure unbinding.
aaa-fail nobinding enable
By default, AAA failure unbinding is disabled.
To provide MAC-based quick portal authentication for local portal users, perform this task so that the access device acts as the local MAC binding server.
You can configure multiple MAC binding servers on the device. For each server, you can configure parameters related to MAC-based quick portal authentication.
3.     Enable local MAC-based quick portal authentication.
local-binding enable
By default, local MAC-based quick portal authentication is disabled.
5.     (Optional.) Set the aging time for local MAC-account binding entries.
local-binding aging-time minutes
By default, the aging time for local MAC-account binding entries is 720 minutes.
6.     (Optional.) Set the aging time for MAC-trigger entries.
aging-time seconds
7.     (Optional.) Enable AAA failure unbinding.
After a MAC binding server is specified on an interface, the device can implement MAC-based quick portal authentication for portal users on the interface.
3.     Specify a MAC binding server on the interface.
portal apply mac-trigger-server server-name
By default, no MAC binding server is specified on an interface.
This feature enables the cloud portal server to act as a MAC binding server to perform cloud MAC-trigger authentication on portal users.
3.     Enable cloud MAC-trigger authentication.
cloud-binding enable
By default, cloud MAC-trigger authentication is disabled.
4.     Specify the URL of the cloud portal authentication server.
cloud-server url url-string
By default, the cloud portal authentication server URL is not specified. The device uses the URL of the portal Web server as the URL of the cloud portal authentication server.
Logging out online portal users
This feature deletes users that have passed portal authentication and terminates ongoing portal authentications.
If any device in a VSRP group executes the portal delete-user command to log out a user, all devices in this group log out the user.
When the number of online users exceeds 2000, executing the portal delete-user command takes a few minutes.
To ensure successful logout of online users, do not perform the following operations during the command execution:
·     Master/backup device switchover.
·     Breaking the data channel in the VSRP group.
·     Active/standby MPU switchover.
·     Disabling portal authentication on the interface.
2.     Log out online portal users.
IPv4:
portal delete-user { ipv4-address | all | auth-type { cloud | email | facebook | local | normal | qq | wechat } | interface interface-type interface-number | mac mac-address | username username }
IPv6:
portal delete-user { all | auth-type { cloud | email | facebook | local | normal | qq | wechat } | interface interface-type interface-number | ipv6 ipv6-address | mac mac-address | username username }
Setting the user traffic backup threshold
The device backs up traffic for a user when the user's traffic reaches the user traffic backup threshold. A smaller threshold provides more accurate backup for user traffic. However, when a large number of users exist, a small threshold results in frequent user traffic backups, affecting the user online, offline, and accounting processes. Set a proper threshold to balance between service performance and traffic backup accuracy.
2.     Set the user traffic backup threshold.
portal traffic-backup threshold value
By default, the user traffic backup threshold is 10 MB.
Disabling the Rule ARP or ND entry feature for portal clients
When the Rule ARP or ND entry feature is enabled for portal clients, ARP or ND entries for portal clients are Rule entries after the clients come online. The Rule entries will not age out and will be deleted immediately after the portal clients go offline. If a portal client goes offline and then tries to get online before the ARP or ND entry is relearned for the client, the client will fail the authentication. To avoid such authentication failure, disable this feature. Then, ARP or ND entries for portal clients are dynamic entries after the clients come online and are deleted only when they age out.
Enabling or disabling of this feature does not affect existing Rule/dynamic ARP or ND entries.
2.     Disable the Rule ARP or ND entry feature for portal clients.
By default, the Rule ARP or ND entry feature is disabled.
Disabling traffic accounting for portal users
The accounting server might perform time-based or traffic-based accounting, or it might not perform accounting.
If the accounting server does not perform traffic-based accounting, disable traffic accounting for portal users on the device. The device will provide quick accounting for portal users, and the traffic statistics will be imprecise.
If the accounting server performs traffic-based accounting, enable traffic accounting for portal users. The device will provide precise traffic statistics for portal users.
2.     Disable traffic accounting for portal users.
portal traffic-accounting disable
By default, traffic accounting is enabled for portal users.
Configuring Web redirect
About Web redirect
Web redirect is a simplified portal feature. With Web redirect, a user does not perform portal authentication but is directly redirected to the specified URL on the first Web access attempt in a browser. After the specified redirect interval, the user is redirected from the visiting website to the specified URL again.
Web redirect can provide ISPs with extended services. For example, the ISPs can place advertisements and publish information on the redirected webpage.
Configuring Web redirect on an interface
The Web redirect feature takes effect only on HTTP packets that use the default port number 80.
To use the device URL as the Web redirect URL or allow users to successfully access the device URL, you must enable the HTTP service. To enable the HTTP service, use the ip http enable command.
When Web redirect and portal authentication are all enabled on an interface, the device redirects users on the interface as follows:
·     The device redirects the first HTTP request of a user to the specified URL. Then, the device redirects the next HTTP request of the user to the portal authentication page. After the user logs out, the user is redirected to the specified URL again at the first Web access.
·     After the specified redirect interval, a user is redirected to the specified URL regardless of whether the user is online or not. This process does not cause online users to be offline.
3.     Configure Web redirect.
web-redirect [ ipv6 ] url url-string [ interval interval ]
By default, Web redirect is disabled.
Configuring destination-based portal redirection rules
The device uses destination-based portal redirection rules to perform URL redirection. If the Web request of a portal user matches the specified destination in a redirection rule, the device redirects the user to the URL specified in the redirection rule.
If the Web request of a portal user matches a destination-based portal redirection rule and a URL redirection match rule (configured by using the if-match command), the redirection rule takes effect.
If you specify a host name or IP address in a destination-based portal redirection rule, do not specify a URL that includes the host name or IP address as the redirection URL in another rule. A violation will cause redirect loops.
The system supports a maximum of 10 destination-based portal redirection rules. For the same host or IP address, only one destination-based portal redirection rule is supported.
2.     Configure a destination-based portal redirection rule.
portal redirect-rule destination { host { host-name | ip-address } | ipv6 ipv6-address } [ redirect-url url ]
By default, no destination-based portal redirection rules are configured.
Configuring portal safe-redirect
Portal safe-redirect filters HTTP requests by HTTP request method, browser type (in HTTP User Agent), and destination URL, and redirects only the permitted HTTP requests. This reduces the risk that the portal Web server cannot respond to HTTP requests because of overload.
Table 2 Browser types supported by portal safe-redirect
Browser type
Safari
Apple browser
Chrome
Google browser
Firefox
Firefox browser
UC
UC browser
QQBrowser
QQ browser
LBBROWSER
Cheetah browser
TaoBrowser
Taobao browser
Maxthon
Maxthon browser
BIDUBrowser
Baidu browser
MSIE 10.0
Microsoft IE 10.0 browser
MSIE 9.0
Microsoft IE 9.0 browser
MSIE 8.0
Microsoft IE 8.0 browser
MSIE 7.0
Microsoft IE 7.0 browser
MSIE 6.0
Microsoft IE 6.0 browser
MetaSr
Sogou browser
2.     Enable portal safe-redirect.
portal safe-redirect enable
By default, the portal safe-redirect feature is disabled.
3.     (Optional.) Specify HTTP request methods permitted by portal safe-redirect.
portal safe-redirect method { get | post }
By default, the device can redirect only HTTP requests with GET method after portal safe-redirect is enabled.
4.     (Optional.) Specify a browser type permitted by portal safe-redirect.
portal safe-redirect user-agent user-agent-string
By default, no browser types are specified. The device can redirect HTTP requests sent by all supported browsers (see Table 2) after portal safe-redirect is enabled.
5.     (Optional.) Configure a URL forbidden by portal safe-redirect.
By default, no forbidden URLs are configured. The device can redirect HTTP requests with any URLs.
6.     (Optional.) Configure a filename extension forbidden by portal safe-redirect.
portal safe-redirect forbidden-url user-url-string
By default, no forbidden filename extensions are configured. The device redirects HTTP requests regardless of the file extension in the URL.
7.     (Optional.) Configure a URL keyword forbidden by portal safe-redirect.
portal safe-redirect forbidden-keyword keyword
By default, no forbidden URL keywords are configured. The device redirects HTTP requests regardless of the keywords in the URL.
8.     (Optional.) Configure the default action for portal safe-redirect.
portal safe-redirect default-action { forbidden | permit }
By default, no default action is configured for portal safe-redirect.
9.     Configure a URL permitted by portal safe-redirect.
portal safe-redirect permit-url user-url-string
By default, the device can redirect Web requests that contain any URLs.
Setting the maximum number of portal redirection sessions for a single user
If a user client is attacked by malicious software or viruses, it might initiate a large number of portal redirect sessions. You can perform this task to limit the number of portal redirect sessions that can be established for that user.
The maximum number applies to the HTTP redirect sessions and HTTPS redirect sessions separately. For example, assume you set the maximum number to 50. Then, a portal user can establish a maximum of 50 HTTP redirect sessions and a maximum of 50 HTTPS redirect sessions.
2.     Set the maximum number of portal redirection sessions for a single user.
portal redirect max-session per-user number
By default, no limit is set on the number of portal redirect sessions for a single user.
Excluding an attribute from portal protocol packets
Support of the portal authentication server for portal protocol attributes varies by the server type. If the device sends the portal authentication server a packet that contains an attribute unsupported by the server, the device and the server cannot communicate.
To address this issue, you can configure portal protocol packets to not carry the attributes unsupported by the portal authentication server.
Excluding an attribute from portal protocol packets for a portal authentication server
portal server server-name
3.     Exclude an attribute from portal protocol packets.
exclude-attribute number { ack-auth | ntf-logout | ack-logout }
By default, no attributes are excluded from portal protocol packets.
Excluding an attribute from portal protocol packets for a MAC binding server
2.     Enter MAC binding server view.
exclude-attribute attribute-number
Configuring support of portal authentication for third-party authentication
About third-party authentication
The device supports using a third-party authentication server, such as QQ, email, WeChat, or Facebook authentication server as the portal authentication server to complete portal authentication. No portal authentication servers are required to be deployed, and no local portal users are required to be created on the device. This reduces the management and maintenance cost.
You need to add a third-party authentication button on the portal authentication page. A user clicks the button and is redirected to the third-party authentication page. The user then uses the third-party authentication account to perform portal authentication.
Restrictions and guidelines for third-party authentication
Only direct portal authentication that uses a local portal Web service supports third-party authentication.
Editing buttons and pages for third-party authentication
No authentication button or authentication page is required for WeChat authentication.
Editing a third-party authentication button
To provide QQ, email, or Facebook authentication for portal users, you must add a QQ, email, or Facebook authentication button to the portal logon page.
When you edit the QQ authentication button, you must call the pt_getQQSubmitUrl() function to get the URL of the QQ authentication page. The following example shows part of the script of the QQ authentication button.
    <html>
    <head>
    <title>Logon</title>
<script type="text/javascript">
      function setQQUrl(){
          document.getElementById("qqurl").href = pt_getQQSubmitUrl();
</script>
    </head>
    <body>
<a href="javascript:void(null)" id="qqurl" onclick="setQQUrl()">QQ</a>
    </body>
</html>
No special requirements exist in the process of editing an email or Facebook authentication button.
Editing a third-party authentication page
You need to edit the email authentication page and the Facebook authentication page. The QQ authentication page is provided by Tencent.
When you edit the email authentication page, follow the rules in "Customizing authentication pages" and the following rules:
·     Set the action attribute of the beginning form tag to maillogin.html. Otherwise, the device cannot send the user information
·     Save the login page as emailLogon.htm.
The following example shows part of the script of the emailLogon.htm page.
<form action= maillogin.html method = post >
<p>User name:<input type="text" name = "PtUser" style="width:160px;height:22px" maxlength=64>
<p>Password :<input type="password" name = "PtPwd" style="width:160px;height:22px" maxlength=32>
<p><input type=SUBMIT value="Logon" name = "PtButton" style="width:60px;" onclick="form.action=form.action+location.search;">
</form>
When you edit the Facebook authentication page, follow the rules in "Customizing authentication pages."
Configuring QQ authentication
After a portal user passes QQ authentication, the QQ authentication server sends the authorization code of the user to the portal Web server. After the portal Web server receives the authorization code, it sends the authorization code of the user, the app ID, and the app key to the QQ authentication server for verification. If the information is verified as correct, the device determines that the user passes QQ authentication.
To provide QQ authentication for portal users, you must go to Tencent Open Platform (http://connect.qq.com/intro/login) to finish the following tasks:
1.     Register as a developer by using a valid QQ account.
2.     Apply the access to the platform for your website. The website is the webpage to which users are redirected after passing QQ authentication.
You will obtain the app ID and app key from the Tencent Open Platform after your application succeeds.
2.     Create a QQ authentication server and enter its view.
portal extend-auth-server qq
3.     (Optional.) Specify the URL of the QQ authentication server.
auth-url url-string
By default, the URL of a QQ authentication server is https://graph.qq.com.
4.     (Optional.) Specify the URL to which portal users are redirected after they pass QQ authentication.
redirect-url url-string
By default, portal users are redirected to URL http://oauthindev.h3c.com/portal/qqlogin.html after they pass QQ authentication.
5.     (Optional.) Specify the app ID for QQ authentication.
app-id app-id
By default, an app ID for QQ authentication exists.
6.     (Optional.) Specify the app key for QQ authentication.
app-key app-key
By default, an app key for QQ authentication exists.
Configuring email authentication
If a portal user chooses email authentication, the user can access the network after passing email authentication.
2.     Create an email authentication server and enter its view.
portal extend-auth-server mail
3.     Specify protocols for email authentication.
mail-protocol { imap | pop3 } *
By default, no protocols are specified for email authentication.
4.     Specify an email domain name for email authentication.
mail-domain-name string
By default, no email domain names are specified for email authentication.
Configuring WeChat authentication
During WeChat authentication, the device first sends the credentials (app ID, app key, and shop ID) for WeChat authentication to the WeChat Official Account Platform for verification. After the credentials are verified, the device continues the portal authentication and allows the user to use the WiFi network after the authentication.
The subscribe-required feature requires users to follow the WeChat official account during WeChat authentication. If the users do not follow the WeChat official account, they fail WeChat authentication.
When subscribe-required feature is configured, the device sends the app ID and app secret to the WeChat Official Account Admin Platform to obtain the access token. Upon receiving authentication requests from portal users, the device sends the access token and the open ID in the authentication requests to the WeChat server to obtain user information. Based on the returned user information, the device determines whether the portal users have followed the WeChat official account.
Before you configure WeChat authentication, you must go to the WeChat Official Account Admin Platform (https://mp.weixin.qq.com) to finish the following tasks:
1.     Apply a WeChat official account.
2.     Use the account to log in to the platform and enable the WeChat WiFi hotspot feature.
3.     Click the device management tab, add the device: select the shop where the device is deployed, select the portal device type, and enter the device settings.
After the previous configurations, you will obtain the credentials (app ID, app key, and shop ID) for WeChat authentication.
To obtain the app secret for WeChat authentication, perform the following tasks:
1.     Use the WeChat official account to log in to the WeChat Official Account Admin Platform.
2.     From the navigation tree, select Developer Centers.
In the Configuration Items area, you can see the app secret for the WeChat Official account.
2.     Create a WeChat authentication server and enter its view.
portal extend-auth-server wechat
3.     (Optional.) Specify the app ID for WeChat authentication.
app-id app-id
By default, no app ID is specified for WeChat authentication.
4.     (Optional.) Specify the app key for WeChat authentication.
app-key app-key
By default, no app key is specified for WeChat authentication.
5.     (Optional.) Specify the shop ID for WeChat authentication.
shop-id shop-id
6.     (Optional.) Configure the subscribe-required feature.
a.     Enable the subscribe-required feature:
subscribe-required enable
By default, the subscribe-required feature is disabled.
This feature must be used with the portal temporary pass feature. As a best practice, set the temporary pass period to 600 seconds.
b.     Specify the app secret for WeChat authentication.
app-secret { cipher | simple } string
By default, no app secret is specified for WeChat authentication.
Configuring Facebook authentication
To use Facebook authentication for portal users, you must register as a developer on the Facebook website to obtain an app ID and app key.
2.     Create a Facebook authentication server and enter its view.
portal extend-auth-server facebook
3.     (Optional.) Specify the URL of the Facebook authentication server.
auth-url url-string
By default, the URL of Facebook authentication server is https://graph.facebook.com.
4.     (Optional.) Specify the URL to which portal users are redirected after they pass Facebook authentication.
By default, portal users are redirected to URL http://oauthindev.h3c.com/portal/fblogin.html after they pass Facebook authentication.
5.     (Optional.) Specify the app ID for Facebook authentication.
app-id app-id
By default, no app ID is specified for Facebook authentication.
6.     (Optional.) Specify the app key for Facebook authentication.
app-key app-key
By default, no app key is specified for Facebook authentication.
Specifying an authentication domain for third-party authentication
Specify an authentication domain for third-party authentication on an interface to apply the authentication, authorization, and accounting methods in the domain to portal users.
Make sure the authentication, authorization, and accounting methods in the specified authentication domain are none.
Specifying an authentication domain for third-party authentication on an interface
2.     Enter Layer 3 interface view.
3.     Specify an authentication domain for third-party authentication on the interface.
portal extend-auth domain domain-name
By default, no authentication domain is specified for third-party authentication on an interface.
Configuring portal temporary pass
Typically, a portal user cannot access the Internet before passing portal authentication. This feature allows a user to access the Internet temporarily if the user uses a WeChat account to perform portal authentication. During the temporary pass period, the user can provide WeChat authentication information to the WeChat server for the server to interact with the access device to finish portal authentication.
This feature is available only for direct portal authentication mode.
If both portal safe-redirect and portal temporary pass match rules are configured, portal temporary pass match rules take precedence.
Configuring portal temporary pass on an interface
3.     Enable portal temporary pass and set the temporary pass period on the interface.
portal temp-pass [ period period-value ] enable
By default, portal temporary pass is disabled on an interface.
4.     Configure a match rule for portal temporary pass:
a.     Return to system view.
b.     Enter portal Web server view.
portal web-server server-name
c.     Configure a match rule for portal temporary pass.
if-match { original-url url-string | user-agent user-agent } * temp-pass [ redirect-url url-string | original ]
By default, no match rules for portal temporary pass are configured.
Setting the user synchronization interval for portal authentication using OAuth
If portal authentication uses OAuth, the device periodically reports user information to the portal authentication server for user synchronization on the server. To disable user synchronization from the device to the portal authentication server, set the user synchronization interval to 0 seconds on the device.
2.     Set the user synchronization interval for portal authentication using OAuth.
portal oauth user-sync interval interval
By default, the user synchronization interval is 60 seconds.
Configuring user synchronization for portal authentication using the WiFiDog protocol
Use this feature when users perform portal authentication using the WiFiDog protocol. This feature enables the device to periodically synchronize user information with the portal server to ensure user information consistency between the device and the portal server.
For this feature to take effect, make sure the type of the portal Web server is WiFiDog before you perform this task. To specify the type of the portal Web server, use the server-type command.
2.     Enable user information synchronization and set the synchronization interval for portal authentication using WiFiDog.
portal wifidog user-sync interval interval
By default, user information synchronization is disabled for portal authentication using WiFiDog.
Configuring portal authentication information report interval
After you configure this feature, the device reports portal authentication failure and error information to the cloud server. The first report is sent to the cloud server 30 seconds after the device is connected to the server. The subsequent reports are sent at regularly intervals as configured by this feature.
If you modify the report interval, the modified interval takes effect on the next report.
2.     Configure the time interval at which portal authentication information is reported to the cloud server.
portal cloud report interval minutes
By default, the portal authentication information is reported to the cloud server at intervals of 5 minutes.
Enabling portal logging
To help with security audits, you can enable portal logging to record portal authentication information.
For portal log messages to be sent correctly, you must also configure the information center on the device. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
2.     Enable logging for portal user logins and logouts.
portal user log enable
By default, portal user login and logout logging is disabled.
3.     Enable logging for portal protocol packets.
portal packet log enable
By default, portal protocol packet logging is disabled.
4.     Enable logging for portal redirect.
portal redirect log enable
By default, portal redirect logging is disabled.
Configuring the portal authentication monitoring feature
The portal authentication monitoring feature records portal user offlines, authentication failures, and authentication errors. These records help the administrator quickly identify causes of authentication faults.
2.     Enable portal user offline recording.
portal logout-record enable
By default, portal user offline recording is disabled.
3.     Set the maximum number of portal user offline records.
portal logout-record max number
The default setting varies by device model. For more information, see the command reference.
4.     Export portal user offline records to a path.
portal logout-record export url url-string [ start-time start-date start-time end-time end-date end-time ]
5.     Enable portal authentication failure recording.
portal auth-fail-record enable
By default, portal authentication failure recording is enabled.
6.     Set the maximum number of portal authentication failure records.
portal auth-fail-record max number
7.     Export portal authentication failure records to a path.
portal auth-fail-record export url url-string [ start-time start-date start-time end-time end-date end-time ]
8.     Enable portal authentication error recording.
portal auth-error-record enable
By default, portal authentication error recording is enabled.
9.     Set the maximum number of portal authentication error records.
portal auth-error-record max number
10.     Export portal authentication error records to a path.
portal auth-error-record export url url-string [ start-time start-date start-time end-time end-date end-time ]
Configuring portal advertisement push
This feature enables the device to push advertisements to portal users after they pass portal authentication.
3.     Enable portal advertisement push.
portal ad-push enable
By default, portal advertisement push is disabled.
4.     Configure the advertisement URL or advertisement group to be pushed to portal users.
portal [ ipv6 ] ad-push { url url-string [ interval interval | time-range time-range-name | traffic-threshold traffic-threshold ] | url-group group-name }
By default, no advertisement URL or advertisement group is configured.
5.     (Optional.) Return to system view.
6.     (Optional.) Configure a portal advertisement whitelist.
portal ad-push whitelist { ip ipv4-address | ipv6 ipv6-address | mac-address mac-address }
By default, no portal advertisement whitelist is configured.
7.     (Optional.) Create an advertisement group and enter its view.
portal ad-url-group group-name [ method { interval | time-range | traffic } ]
8.     (Optional.) Configure an advertisement URL in the advertisement group.
ad-url url-string [ time-range time-range-name ]
By default, no advertisement URLs are configured in an advertisement group.
9.     (Optional.) Set the time interval or traffic threshold for portal advertisement push in the advertisement group.
ad-url-group { interval interval | traffic-threshold traffic-threshold }
By default, the interval is 360 minutes and the traffic threshold is 100 MB for portal advertisement push in an advertisement group.
Display and maintenance commands for portal
Display portal configuration and portal running state.
display portal interface interface-type interface-number
Display statistics about portal advertisement push.
display portal ad-push statistics { ad-url-group | url }
Display portal authentication error records.
display portal auth-error-record { all | ipv4 ipv4-address | ipv6 ipv6-address | start-time start-date start-time end-time end-date end-time }
Display portal authentication failure records.
display portal auth-fail-record { all | ipv4 ipv4-address | ipv6 ipv6-address | start-time start-date start-time end-time end-date end-time | username username }
Display packet statistics for portal captive-bypass.
display portal captive-bypass statistics [ slot slot-number ]
Display IP addresses corresponding to host names in destination-based portal-free rules.
display portal dns free-rule-host [ host-name ]
Display IP addresses resolved by host names in destination-based portal redirection rules.
display portal dns redirect-rule-host [ host-name ]
Display information about third-party authentication servers.
display portal extend-auth-server { all | facebook | mail | qq | wechat }
Display information about local MAC-account binding entries.
display portal local-binding mac-address { all | mac-address }
Display portal user offline records.
display portal logout-record { all | ipv4 ipv4-address | ipv6 ipv6-address | start-time start-date start-time end-time end-date end-time | username username }
Display information about MAC-trigger authentication users (portal users that perform MAC-trigger authentication).
display portal mac-trigger user { all | ip ipv4-address | mac mac-address }
Display information about MAC binding servers.
display portal mac-trigger-server { all | name server-name }
Display packet statistics for portal authentication servers.
display portal packet statistics [ extend-auth-server { cloud | facebook | mail | qq | wechat } | mac-trigger-server server-name | server server-name ]
Display statistics for portal permit rules.
display portal permit-rule statistics
Display portal redirect session information
display portal redirect session [ ip ipv4-address | ipv6 ipv6-address ] [ slot slot-number ]
Display history records about portal redirect sessions.
display portal redirect session-record [ start-time start-date start-time ] [ end-time end-date end-time ] [ slot slot-number ]
Display summary statistics about portal redirect sessions.
display portal redirect session-statistics [ slot slot-number ]
Display portal redirect packet statistics.
display portal redirect statistics [ slot slot-number ]
Display portal rules.
display portal rule { all | dynamic | static } interface interface-type interface-number [ slot slot-number ]
Display packet statistics for portal safe-redirect
display portal safe-redirect statistics [ slot slot-number ]
Display portal authentication server information.
display portal server [ server-name ]
Display portal user information.
display portal user { all | auth-type { cloud | email | facebook | local | mac-trigger | normal | qq | wechat } | interface interface-type interface-number | ip ip-address | ipv6 ipv6-address | mac mac-address | pre-auth [ interface interface-type interface-number | ip ip-address | ipv6 ipv6-address ] | username username } [ brief | verbose ]
Display the number of portal users.
display portal user count
Display DHCP lease information of IPv4 portal users.
display portal user dhcp-lease [ ipv4 ipv4-address ]
Display DHCPv6 lease information of IPv6 portal users.
display portal user dhcpv6-lease [ ipv6 ipv6-address ]
Display information about portal users blocked for authentication failure.
display portal user-block [ ip ipv4-address | ipv6 ipv6-address | mac mac-address | username username ]
Display portal Web server information.
display portal web-server [ server-name ]
Display Web redirect rule information.
display web-redirect rule interface interface-type interface-number [ slot slot-number ]
Clear statistics about portal advertisement push.
reset portal ad-push statistics { ad-url-group | url }
Clear portal authentication error records.
reset portal auth-error-record { all | ipv4 ipv4-address | ipv6 ipv6-address | start-time start-date start-time end-time end-date end-time }
Clear portal authentication failure records.
reset portal auth-fail-record { all | ipv4 ipv4-address | ipv6 ipv6-address | start-time start-date start-time end-time end-date end-time | username username }
Clear packet statistics for portal captive-bypass.
reset portal captive-bypass statistics [ slot slot-number ]
Clear local MAC-account binding entries.
reset portal local-binding mac-address { mac-address | all }
Clear portal user offline records.
reset portal logout-record { all | ipv4 ipv4-address | ipv6 ipv6-address | start-time start-date start-time end-time end-date end-time | username username }
Clear packet statistics for portal authentication servers.
reset portal packet statistics [ extend-auth-server { cloud | facebook | mail | qq | wechat } | mac-trigger-server server-name | server server-name ]
Clear history records about portal redirect sessions.
reset portal redirect session-record [ slot slot-number ]
Clear summary statistics for portal redirect sessions.
reset portal redirect session-statistics [ slot slot-number ]
Clear portal redirect packet statistics.
reset portal redirect statistics [ slot slot-number ]
Clear packet statistics for portal safe-redirect.
reset portal safe-redirect statistics [ slot slot-number ]
Portal configuration examples
Example: Configuring direct portal authentication
As shown in Figure 6, the host is directly connected to the device (the access device). The host is assigned a public IP address either manually or through DHCP. An IMC server acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication and accounting server. In this example, the IMC server runs IMC 7.1 (E0303) and IMC UAM 7.1 (E0304).
Configure direct portal authentication, so the host can access only the portal server before passing the authentication and access other network resources after passing the authentication.
Figure 6 Network diagram
Configuring the RADIUS server
# Configure the RADIUS server correctly to provide authentication and accounting functions. (Details not shown.)
Configuring the portal server
1.     Configure the portal authentication server:
a.     Log in to IMC and click the User tab.
b.     Select User Access Policy > Portal Service > Server from the navigation tree to open the portal server configuration page, as shown in Figure 7.
c.     Configure the portal server parameters as needed.
This example uses the default settings.
d.     Click OK.
Figure 7 Portal server configuration
2.     Configure the IP address group:
a.     Select User Access Policy > Portal Service > IP Group from the navigation tree to open the portal IP address group configuration page.
b.     Click Add to open the page as shown in Figure 8.
c.     Enter the IP group name.
d.     Enter the start IP address and end IP address of the IP group.
Make sure the host IP address is in the IP group.
e.     Select a service group.
This example uses the default group Ungrouped.
f.     Select Normal from the Action list.
g.     Click OK.
Figure 8 Adding an IP address group
3.     Add a portal device:
a.     Select User Access Policy > Portal Service > Device from the navigation tree to open the portal device configuration page.
b.     Click Add to open the page as shown in Figure 9.
c.     Enter device name NAS.
d.     Enter the IP address of the device's interface connected to the host.
e.     Select whether to support server heartbeat and user heartbeat functions.
In this example, select No for both Support Server Heartbeat and Support User Heartbeat.
f.     Enter the key, which must be the same as that configured on the device.
g.     Select Directly Connected from the Access Method list.
h.     Use the default settings for other parameters.
i.     Click OK.
Figure 9 Adding a portal device
4.     Associate the portal device with the IP address group:
a.     As shown in Figure 10, click the Port Group Information Management icon  for device NAS to open the port group configuration page.
b.     Click Add to open the page as shown in Figure 11.
c.     Enter the port group name.
d.     Select the configured IP address group.
The IP address used by the user to access the network must be within this IP address group.
e.     Use the default settings for other parameters.
f.     Click OK.
Figure 10 Device list
Figure 11 Adding a port group
Configuring the device
1.     Assign IP addresses to interfaces:
# Assign an IP address to interface GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] ip address 192.168.0.100 255.255.255.0
2.     Add interfaces to security zones.
[Device] security-zone name dmz
[Device-security-zone-DMZ] import interface gigabitethernet 1/0/1
[Device-security-zone-DMZ] quit
[Device] security-zone name trust
[Device-security-zone-Trust] import interface gigabitethernet 1/0/2
3.     Configure a security policy:
# Configure a rule named trust-dmz to allow the host to access the portal server.
[Device] security-policy ip
[Device-security-policy-ip] rule name trust-dmz
[Device-security-policy-ip-1-trust-dmz] source-zone trust
[Device-security-policy-ip-1-trust-dmz] destination-zone dmz
[Device-security-policy-ip-1-trust-dmz] source-ip-host 2.2.2.2
[Device-security-policy-ip-1-trust-dmz] destination-ip-host 192.168.0.111
[Device-security-policy-ip-1-trust-dmz] action pass
[Device-security-policy-ip-1-trust-dmz] quit
# Configure a rule named portallocalout to allow the device to send packets to the RADIUS server and portal server.
[Device-security-policy-ip] rule name portallocalout
[Device-security-policy-ip-2-portallocalout] source-zone local
[Device-security-policy-ip-2-portallocalout] destination-zone dmz
[Device-security-policy-ip-2-portallocalout] destination-ip-host 192.168.0.111
[Device-security-policy-ip-2-portallocalout] destination-ip-host 192.168.0.112
[Device-security-policy-ip-2-portallocalout] action pass
[Device-security-policy-ip-2-portallocalout] quit
# Configure a rule named portallocalin to allow the device to receive and process packets from the RADIUS server and portal server.
[Device-security-policy-ip] rule name portallocalin
[Device-security-policy-ip-3-portallocalin] source-zone dmz
[Device-security-policy-ip-3-portallocalin] destination-zone local
[Device-security-policy-ip-3-portallocalin] source-ip-host 192.168.0.111
[Device-security-policy-ip-3-portallocalin] source-ip-host 192.168.0.112
[Device-security-policy-ip-3-portallocalin] action pass
[Device-security-policy-ip-3-portallocalin] quit
[Device-security-policy-ip] quit
4.     Configure a RADIUS scheme:
# Create a RADIUS scheme named rs1, configure the device to exclude the ISP domain name from the username sent to the RADIUS server, and enable RADIUS session control.
[Device] radius scheme rs1
[Device-radius-rs1] primary authentication 192.168.0.112
[Device-radius-rs1] primary accounting 192.168.0.112
[Device-radius-rs1] key authentication simple radius
[Device-radius-rs1] key accounting simple radius
[Device-radius-rs1] user-name-format without-domain
[Device-radius-rs1] quit
[Device] radius session-control enable
5.     Configure an authentication domain:
# Create an ISP domain named dm1, configure AAA methods for the ISP domain, and specify domain dm1 as the default ISP domain.
[Device] domain dm1
[Device-isp-dm1] authentication portal radius-scheme rs1
[Device-isp-dm1] authorization portal radius-scheme rs1
[Device-isp-dm1] accounting portal radius-scheme rs1
[Device-isp-dm1] quit
[Device] domain default enable dm1
6.     Configure portal authentication:
# Configure a portal authentication server and a portal Web server. On GigabitEthernet 1/0/2, enable direct portal authentication, specify the portal Web server, and configure the BAS-IP as 2.2.2.1.
[Device] portal server newpt
[Device-portal-server-newpt] ip 192.168.0.111 key simple portal
[Device-portal-server-newpt] port 50100
[Device-portal-server-newpt] quit
[Device] portal web-server newpt
[Device-portal-websvr-newpt] url http://192.168.0.111:8080/portal
[Device-portal-websvr-newpt] quit
[Device–GigabitEthernet1/0/2] portal enable method direct
[Device–GigabitEthernet1/0/2] portal apply web-server newpt
[Device–GigabitEthernet1/0/2] portal bas-ip 2.2.2.1
[Device–GigabitEthernet1/0/2] quit
# Verify that the portal configuration has taken effect.
[Device] display portal interface gigabitethernet 1/0/2
 Portal information of GigabitEthernet1/0/2
     NAS-ID profile: Not configured
     Authorization : Strict checking
     ACL           : Disabled
     User profile  : Disabled
     Dual stack    : Disabled
     Dual IP       : Disabled
     Advertisement-push     : Disabled
     Embedded advertisement : Disabled
 IPv4:
     Portal status: Enabled
     Portal authentication method: Direct
     Portal Web server: newpt(active)
     Secondary portal Web server: Not configured
     Portal mac-trigger-server: Not configured
     Authentication domain: Not configured
     Pre-auth domain: Not configured
     Extend-auth domain: Not configured
     User-dhcp-only: Disabled
     Pre-auth IP pool: Not configured
     Max portal users: Not configured
     Bas-ip: 2.2.2.1
     User detection: Not configured
     Portal temp-pass: Disabled
     Action for server detection:
         Server type    Server name                        Action
     Layer3 source network:
         IP address               Mask
     Destination authenticate subnet:
         IP address               Mask
     Advertisement push: Not configured
 IPv6:
     Portal status: Disabled
     Portal authentication type: Disabled
     Portal Web server: Not configured
     Bas-ipv6: Not configured
         IP address                                        Prefix length
A user can perform portal authentication by using the iNode client or a Web browser. Before passing the authentication, the user can access only the authentication page http://192.168.0.111:8080/portal. All Web requests from the user will be redirected to the authentication page. After passing the authentication, the user can access other network resources.
# After the user passes authentication, display information about the portal user.
[Device] display portal user interface gigabitethernet 1/0/2
Total portal users: 1
Username: abc
  Portal server: newpt
  State: Online
  VPN instance: N/A
  MAC                IP                 VLAN   Interface
  0015-e9a6-7cfe     2.2.2.2            --     GigabitEthernet1/0/2
  Authorization information:
    DHCP IP pool: N/A
    ACL number/name: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
Example: Configuring re-DHCP portal authentication
As shown in Figure 12, the host is directly connected to the device (the access device). The host obtains an IP address through the DHCP server. A portal server acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication and accounting server.
Configure re-DHCP portal authentication. Before passing the authentication, the host is assigned a private IP address. After passing the authentication, the host gets a public IP address and can access network resources.
Figure 12 Network diagram
Prerequisites and guidelines
·     For re-DHCP portal authentication, configure a public address pool (20.20.20.0/24) and a private address pool (10.0.0.0/24) on the DHCP server. (Details not shown.)
·     For re-DHCP portal authentication:
¡     The device must be configured as a DHCP relay agent.
¡     The portal-enabled interface must be configured with a primary IP address (a public IP address) and a secondary IP address (a private IP address).
For information about DHCP relay agent configuration, see Layer 3—IP Services Configuration Guide.
·     Make sure the IP address of the portal device added on the portal server is the public IP address (20.20.20.1) of the device's interface connecting the host. The private IP address range for the IP address group associated with the portal device is the private subnet 10.0.0.0/24 where the host resides. The public IP address range for the IP address group is the public subnet 20.20.20.0/24.
1.     Configure the RADIUS server correctly to provide authentication and accounting functions. (Details not shown.)
2.     Assign IP addresses to interfaces:
3.     Add interfaces to security zones.
4.     Configure a security policy:
# Configure a rule named portallocalout1 to allow the device to send packets to the RADIUS server, portal server, and DHCP server.
[Device-security-policy-ip] rule name portallocalout1
[Device-security-policy-ip-2-portallocalout1] source-zone local
[Device-security-policy-ip-2-portallocalout1] destination-zone dmz
[Device-security-policy-ip-2-portallocalout1] destination-ip-host 192.168.0.111
[Device-security-policy-ip-2-portallocalout1] destination-ip-host 192.168.0.112
[Device-security-policy-ip-2-portallocalout1] destination-ip-host 192.168.0.113
[Device-security-policy-ip-2-portallocalout1] action pass
[Device-security-policy-ip-2-portallocalout1] quit
# Configure a rule named portallocalin1 to allow the device to receive and process the packets from the RADIUS server, portal server, and DHCP server.
[Device-security-policy-ip] rule name portallocalin1
[Device-security-policy-ip-3-portallocalin1] source-zone dmz
[Device-security-policy-ip-3-portallocalin1] destination-zone local
[Device-security-policy-ip-3-portallocalin1] source-ip-host 192.168.0.111
[Device-security-policy-ip-3-portallocalin1] source-ip-host 192.168.0.112
[Device-security-policy-ip-3-portallocalin1] source-ip-host 192.168.0.113
[Device-security-policy-ip-3-portallocalin1] action pass
[Device-security-policy-ip-3-portallocalin1] quit
# Configure a rule named portallocalin2 to allow the host to send DHCP requests to the DHCP server.
[Device-security-policy-ip] rule 4 name portallocalin2
[Device-security-policy-ip-4-portallocalin2] source-zone trust
[Device-security-policy-ip-4-portallocalin2] service dhcp-relay
[Device-security-policy-ip-4-portallocalin2] destination-zone local
[Device-security-policy-ip-4-portallocalin2] action pass
[Device-security-policy-ip-4-portallocalin2] quit
# Configure a rule named portallocalout2 to allow the host to obtain the IP address allocated by the DHCP server.
[Device-security-policy-ip] rule 5 name portallocalout2
[Device-security-policy-ip-5-portallocalout2] source-zone local
[Device-security-policy-ip-5-portallocalout2] service dhcp-client
[Device-security-policy-ip-5-portallocalout2] destination-zone trust
[Device-security-policy-ip-5-portallocalout2] action pass
[Device-security-policy-ip-5-portallocalout2] quit
5.     Configure a RADIUS scheme:
[Device-radius-rs1] primary authentication 192.168.0.113
[Device-radius-rs1] primary accounting 192.168.0.113
6.     Configure an authentication domain:
[Device] domain dm1
7.     Configure DHCP relay and authorized ARP to allow the host to obtain an IP address from the DHCP server:
[Device] dhcp enable
[Device] dhcp relay client-information record
[Device–GigabitEthernet1/0/2] ip address 20.20.20.1 255.255.255.0
[Device–GigabitEthernet1/0/2] ip address 10.0.0.1 255.255.255.0 sub
[Device-GigabitEthernet1/0/2] dhcp select relay
[Device-GigabitEthernet1/0/2] dhcp relay server-address 192.168.0.112
[Device-GigabitEthernet1/0/2] arp authorized enable
8.     Configure portal authentication:
# Configure a portal authentication server and a portal Web server. On GigabitEthernet 1/0/2, enable re-DHCP portal authentication, specify the portal Web server, and configure the BAS-IP as 20.20.20.1.
[Device-GigabitEthernet1/0/2] portal enable method redhcp
[Device–GigabitEthernet1/0/2] portal bas-ip 20.20.20.1
     ACL           : Disabled
     Dual IP       : Disabled
 IPv4:
     Portal authentication type: Redhcp
     Bas-ip: 20.20.20.1
         IP address               Mask
         IP address               Mask
 IPv6:
Before passing the authentication, a user that uses the iNode client can access only the authentication page http://192.168.0.111:8080/portal. All Web requests from the user will be redirected to the authentication page. After passing the authentication, the user can access other network resources.
Username: abc
  State: Online
  VPN instance: N/A
  0015-e9a6-7cfe     20.20.20.2         --     GigabitEthernet1/0/2
    DHCP IP pool: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
Example: Configuring cross-subnet portal authentication
As shown in Figure 13, Device A supports portal authentication. The host accesses Device A through Device B. A portal server acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication and accounting server.
Configure Device A for cross-subnet portal authentication. Before passing the authentication, the host can access only the portal server. After passing the authentication, the user can access other network resources.
Figure 13 Network diagram
Make sure the IP address of the portal device added on the portal authentication server is the IP address (20.20.20.1) of the device's interface connecting the host. The IP address group associated with the portal device is the subnet of the host (8.8.8.0/24).
1.     Configure the RADIUS server and the portal server correctly to provide authentication and accounting functions. (Details not shown.)
[DeviceA-GigabitEthernet1/0/1] ip address 192.168.0.100 255.255.255.0
[DeviceA] security-zone name dmz
[DeviceA-security-zone-DMZ] import interface gigabitethernet 1/0/1
[DeviceA-security-zone-DMZ] quit
[DeviceA] security-zone name trust
[DeviceA-security-zone-Trust] import interface gigabitethernet 1/0/2
[DeviceA-security-zone-Trust] quit
4.     Configure settings for routing:
This example configures a static route, and the next hop in the route is 20.20.20.2.
[DeviceA] ip route-static 8.8.8.0 24 20.20.20.2
5.     Configure a security policy:
[DeviceA] security-policy ip
[DeviceA-security-policy-ip] rule name trust-dmz
[DeviceA-security-policy-ip-1-trust-dmz] source-zone trust
[DeviceA-security-policy-ip-1-trust-dmz] destination-zone dmz
[DeviceA-security-policy-ip-1-trust-dmz] source-ip-host 8.8.8.2
[DeviceA-security-policy-ip-1-trust-dmz] destination-ip-host 192.168.0.111
[DeviceA-security-policy-ip-1-trust-dmz] action pass
[DeviceA-security-policy-ip-1-trust-dmz] quit
# Configure a rule named portallocalout to allow Device A to send packets to the RADIUS server and portal server.
[DeviceA-security-policy-ip] rule name portallocalout
[DeviceA-security-policy-ip-2-portallocalout] source-zone local
[DeviceA-security-policy-ip-2-portallocalout] destination-zone dmz
[DeviceA-security-policy-ip-2-portallocalout] destination-ip-host 192.168.0.111
[DeviceA-security-policy-ip-2-portallocalout] destination-ip-host 192.168.0.112
[DeviceA-security-policy-ip-2-portallocalout] action pass
[DeviceA-security-policy-ip-2-portallocalout] quit
# Configure a rule named portallocalin to allow Device A to receive and process the packets from the RADIUS server and portal server.
[DeviceA-security-policy-ip] rule name portallocalin
[DeviceA-security-policy-ip-3-portallocalin] source-zone dmz
[DeviceA-security-policy-ip-3-portallocalin] destination-zone local
[DeviceA-security-policy-ip-3-portallocalin] source-ip-host 192.168.0.111
[DeviceA-security-policy-ip-3-portallocalin] source-ip-host 192.168.0.112
[DeviceA-security-policy-ip-3-portallocalin] action pass
[DeviceA-security-policy-ip-3-portallocalin] quit
[DeviceA-security-policy-ip] quit
6.     Configure a RADIUS scheme:
# Create a RADIUS scheme named rs1, configure Device A to exclude the ISP domain name from the username sent to the RADIUS server, and enable RADIUS session control.
[DeviceA] radius scheme rs1
[DeviceA-radius-rs1] primary authentication 192.168.0.112
[DeviceA-radius-rs1] primary accounting 192.168.0.112
[DeviceA-radius-rs1] key authentication simple radius
[DeviceA-radius-rs1] key accounting simple radius
[DeviceA-radius-rs1] user-name-format without-domain
[DeviceA-radius-rs1] quit
[DeviceA] radius session-control enable
7.     Configure an authentication domain:
[DeviceA] domain dm1
[DeviceA-isp-dm1] authentication portal radius-scheme rs1
[DeviceA-isp-dm1] authorization portal radius-scheme rs1
[DeviceA-isp-dm1] accounting portal radius-scheme rs1
[DeviceA-isp-dm1] quit
[DeviceA] domain default enable dm1
# Configure a portal authentication server and a portal Web server. On GigabitEthernet 1/0/2, enable cross-subnet portal authentication, specify the portal Web server, and configure the BAS-IP as 20.20.20.1.
[DeviceA] portal server newpt
[DeviceA-portal-server-newpt] ip 192.168.0.111 key simple portal
[DeviceA-portal-server-newpt] port 50100
[DeviceA-portal-server-newpt] quit
[DeviceA] portal web-server newpt
[DeviceA-portal-websvr-newpt] url http://192.168.0.111:8080/portal
[DeviceA-portal-websvr-newpt] quit
[DeviceA–GigabitEthernet1/0/2] portal enable method layer3
[DeviceA–GigabitEthernet1/0/2] portal apply web-server newpt
[DeviceA–GigabitEthernet1/0/2] portal bas-ip 20.20.20.1
[DeviceA–GigabitEthernet1/0/2] quit
[DeviceA] display portal interface gigabitethernet 1/0/2
     ACL           : Disabled
     Dual IP       : Disabled
 IPv4:
     Portal authentication type: Layer3
     Bas-ip: 20.20.20.1
         IP address               Mask
         IP address               Mask
 IPv6:
[DeviceA] display portal user interface gigabitethernet 1/0/2
Username: abc
  State: Online
  VPN instance: N/A
  0015-e9a6-7cfe     8.8.8.2            --     GigabitEthernet1/0/2
    DHCP IP pool: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
Example: Configuring extended direct portal authentication
As shown in Figure 14, the host is directly connected to the device (the access device). The host is assigned a public IP address either manually or through DHCP. A portal server acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication and accounting server.
Configure extended direct portal authentication. If the host fails security check after passing identity authentication, it can access only subnet 192.168.0.0/24. After passing security check, the host can access other network resources.
Figure 14 Network diagram
[Device-security-policy-ip-1-trust-dmz] destination-ip-host 192.168.0.113
# Configure a rule named portallocalout to allow the device to send packets to the RADIUS server, portal server, and security policy server.
[Device-security-policy-ip-2-portallocalout] destination-ip-host 192.168.0.113
# Configure a rule named portallocalin to allow the device to receive and process the packets from the RADIUS server, portal server, and security policy server.
[Device-security-policy-ip-3-portallocalin] source-ip-host 192.168.0.113
# Create a RADIUS scheme named rs1. and configure the device to exclude the ISP domain name from the username sent to the RADIUS server.
6.     Enable RADIUS session control, and specify a session-control client and shared key.
[Device] radius session-control client ip 192.168.0.112 key simple 12345
[Device] domain dm1
8.     Configure ACL 3000 as the isolation ACL and ACL 3001 as the security ACL.
[Device] acl advanced 3000
[Device-acl-ipv4-adv-3000] rule permit ip destination 192.168.0.0 0.0.0.255
[Device-acl-ipv4-adv-3000] rule deny ip
[Device] acl advanced 3001
[Device-acl-ipv4-adv-3001] rule permit ip
Make sure you specify ACL 3000 as the isolation ACL and ACL 3001 as the security ACL on the security policy server.
9.     Configure portal authentication:
     ACL           : Disabled
     Dual IP       : Disabled
 IPv4:
     Portal authentication type: Direct
     Bas-ip: 2.2.2.1
         IP address               Mask
         IP address               Mask
 IPv6:
Before passing portal authentication, a user that uses the iNode client can access only the authentication page http://192.168.0.111:8080/portal. All Web requests from the user will be redirected to the authentication page.
·     The user can access the resources permitted by ACL 3000 after passing only identity authentication.
·     The user can access network resources permitted by ACL 3001 after passing both identity authentication and security check.
# After the user passes identity authentication and security check, display information about the portal user.
Username: abc
  State: Online
  VPN instance: N/A
    DHCP IP pool: N/A
    ACL number/name: 3001
    Inbound CAR: N/A
    Outbound CAR: N/A
Example: Configuring extended re-DHCP portal authentication
As shown in Figure 15, the host is directly connected to the device (the access device). The host obtains an IP address through the DHCP server. A portal server acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication and accounting server.
Configure extended re-DHCP portal authentication. Before passing portal authentication, the host is assigned a private IP address. After passing portal identity authentication, the host obtains a public IP address and accepts security check. If the host fails the security check, it can access only subnet 192.168.0.0/24. After passing the security check, the host can access other network resources.
Figure 15 Network diagram
# Configure a rule named trust-dmz to allow the host to access the DHCP server, portal server, and security policy server.
[Device-security-policy-ip-1-trust-dmz] destination-ip-host 192.168.0.112
[Device-security-policy-ip-1-trust-dmz] destination-ip-host 192.168.0.114
# Configure a rule named portallocalout1 to allow the device to send packets to the RADIUS server, portal server, DHCP server, and security policy server.
[Device-security-policy-ip-2-portallocalout1] destination-ip-host 192.168.0.114
# Configure a rule named portallocalin1 to allow the device to receive and process the packets from the RADIUS server, portal server, DHCP server, and security policy server.
[Device-security-policy-ip-3-portallocalin1] source-ip-host 192.168.0.114
# Configure a rule named portallocalin2 to allow the host to send DHCP requests to the device.
[Device-security-policy-ip] rule name portallocalin2
[Device-security-policy-ip] rule name portallocalout2
[Device-security-policy-ip-4-portallocalout2] service dhcp-client
# Create a RADIUS scheme named rs1, and configure the device to exclude the ISP domain name from the username sent to the RADIUS server.
[Device] radius session-control client ip 192.168.0.113 key simple 12345
[Device] domain dm1
9.     Configure DHCP relay and authorized ARP:
10.     Configure portal authentication:
     ACL           : Disabled
     Dual IP       : Disabled
 IPv4:
     Bas-ip: 20.20.20.1
         IP address               Mask
         IP address               Mask
 IPv6:
Username: abc
  State: Online
  VPN instance: N/A
    DHCP IP pool: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
Example: Configuring extended cross-subnet portal authentication
As shown in Figure 16, Device A supports portal authentication. The host accesses Device A through Device B. A portal server acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication and accounting server.
Configure Device A for extended cross-subnet portal authentication. Before passing portal authentication, the host can access only the portal server. After passing portal identity authentication, the host accepts security check. If the host fails the security check it can access only the subnet 192.168.0.0/24. After passing the security check, the host can access other network resources.
Figure 16 Network diagram
Make sure the IP address of the portal device added on the portal server is the IP address (20.20.20.1) of the device's interface connecting the host. The IP address group associated with the portal device is the subnet of the host (8.8.8.0/24).
# Configure a rule named trust-dmz to allow the host to access the RADIUS server, portal server, and security policy server.
[DeviceA-security-policy-ip-1-trust-dmz] destination-ip-host 192.168.0.112
[DeviceA-security-policy-ip-1-trust-dmz] destination-ip-host 192.168.0.113
# Configure a rule named portallocalout to allow Device A to send packets to the RADIUS server, portal server, and security policy server.
[DeviceA-security-policy-ip-2-portallocalout] destination-ip-host 192.168.0.113
# Configure a rule named portallocalin to allow Device A to receive and process the packets from the RADIUS server, portal server, and security policy server.
[DeviceA-security-policy-ip-3-portallocalin] source-ip-host 192.168.0.113
# Create a RADIUS scheme named rs1, and configure Device A to exclude the ISP domain name from the username sent to the RADIUS server.
7.     Enable RADIUS session control, and specify a session-control client and shared key.
[DeviceA] radius session-control client ip 192.168.0.112 key simple 12345
8.     Configure an authentication domain:
9.     Configure ACL 3000 as the isolation ACL and ACL 3001 as the security ACL.
[DeviceA] acl advanced 3000
[DeviceA-acl-ipv4-adv-3000] rule permit ip destination 192.168.0.0 0.0.0.255
[DeviceA-acl-ipv4-adv-3000] rule deny ip
[DeviceA-acl-ipv4-adv-3000] quit
[DeviceA] acl advanced 3001
[DeviceA-acl-ipv4-adv-3001] rule permit ip
[DeviceA-acl-ipv4-adv-3001] quit
# Configure a portal authentication server and a portal Web server. On GigabitEthernet 1/0/2, enable cross-subnet portal authentication, specify the portal Web server newpt, and configure the BAS-IP as 20.20.20.1.
     ACL           : Disabled
     Dual IP       : Disabled
 IPv4:
     Bas-ip: 20.20.20.1
         IP address               Mask
         IP address               Mask
 IPv6:
     Authentication type: Disabled
Before passing portal authentication, a user that uses the iNode client can access only the authentication page http://192.168.0.111:8080/portal. All Web requests from the user are redirected to the authentication page.
Username: abc
  State: Online
  VPN instance: N/A
    DHCP IP pool: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
Example: Configuring portal server detection and portal user synchronization
As shown in Figure 17, the host is directly connected to the device (the access device). The host is assigned a public IP address either manually or through DHCP. An IMC server acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication and accounting server. In this example, the IMC server runs IMC 7.1 (E0303) and IMC UAM 7.1 (E0304).
Configure direct portal authentication on the device, so the host can access only the portal server before passing the authentication and access other network resources after passing the authentication.
Configure the device to do the following:
·     Detect the reachability state of the portal authentication server.
·     Send log messages upon state changes.
·     Disable portal authentication when the authentication server is unreachable.
·     Synchronize portal user information with the portal server periodically.
Figure 17 Network diagram
·     Configure the portal authentication server. Be sure to enable the server heartbeat function and the user heartbeat function.
·     Configure the device (access device) as follows:
¡     Configure direct portal authentication on GigabitEthernet 1/0/2, the interface to which the host is connected.
¡     Configure portal authentication server detection, so that the device can detect the reachability of the portal authentication server by cooperating with the portal server heartbeat function.
¡     Configure portal user synchronization, so that the device can synchronize portal user information with the portal authentication server by cooperating with the portal user heartbeat function.
1.     Configure the portal server:
a.     Log in to IMC and click the Service tab.
b.     Select User Access Policy > Portal Service > Server from the navigation tree to open the portal server configuration page as shown in Figure 18.
c.     Configure the portal server parameter as needed.
d.     Click OK.
Figure 18 Portal authentication server configuration
b.     Click Add to open the page as shown in Figure 19.
g.     Click OK.
Figure 19 Adding an IP address group
b.     Click Add to open the page as shown in Figure 20.
e.     Select whether to support sever heartbeat and user heartbeat functions.
In this example, select Yes for both Support Server Heartbeat and Support User Heartbeat.
i.     Click OK.
Figure 20 Adding a portal device
a.     As shown in Figure 21, click the Port Group Information Management icon  for device NAS to open the port group configuration page.
b.     Click Add to open the page as shown in Figure 22.
f.     Click OK.
Figure 21 Device list
Figure 22 Adding a port group
# Configure a rule named portallocalin to allow the device to receive and process the packets from the RADIUS server and portal server.
[Device] domain dm1
# Configure a portal authentication server, and configure reachability detection of the portal authentication server: set the server detection interval and specify the action upon reachability status changes.
[Device-portal-server-newpt] server-detect timeout 40 log
The value of timeout must be greater than or equal to the portal server heartbeat interval.
# Configure portal user synchronization with the portal authentication server, and set the synchronization detection interval to 600 seconds.
[Device-portal-server-newpt] user-sync timeout 600
The value of timeout must be greater than or equal to the portal user heartbeat interval.
# Configure a portal Web server. On GigabitEthernet 1/0/2, enable direct portal authentication, enable portal fail-permit for the portal authentication server, specify the portal Web server, and configure the BAS-IP as 2.2.2.1.
[Device–GigabitEthernet1/0/2] portal fail-permit server newpt
# Display information about the portal authentication server.
[Device] display portal server newpt
  Type                  : IMC
  IP                    : 192.168.0.111
  VPN instance          : Not configured
  Port                  : 50100
  Server Detection      : Timeout 40s  Action: log
  User synchronization  : Timeout 600s
  Status                : Up
  Exclude-attribute     : Not configured
  Logout notification   : Not configured
The Up status of the portal authentication server indicates that the portal authentication server is reachable. If the access device detects that the portal authentication server is unreachable, the Status field in the command output displays Down. The access device generates a server unreachable log "Portal server newpt turns down from up." and disables portal authentication on the access interface, so the host can access the external network without authentication.
Example: Configuring direct portal authentication with a preauthentication domain
As shown in Figure 23, the host is directly connected to the device (the access device). The host is assigned a public IP address through DHCP. A portal server acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication and accounting server.
Configure direct portal authentication, so the host can access only subnet 192.168.0.0/24 before passing the authentication and access other network resources after passing the authentication.
Figure 23 Network diagram
# Configure a rule named portallocalin1 to allow the host to send DHCP requests to the device.
[Device-security-policy-ip-1-portallocalin1] source-zone trust
[Device-security-policy-ip-1-portallocalin1] service dhcp-server
[Device-security-policy-ip-1-portallocalin1] destination-zone local
[Device-security-policy-ip-1-portallocalin1] action pass
[Device-security-policy-ip-1-portallocalin1] quit
# Configure a rule named portallocalout1 to allow the device to send DHCP response packets to the host.
[Device-security-policy-ip-2-portallocalout1] service dhcp-client
[Device-security-policy-ip-2-portallocalout1] destination-zone trust
[Device-security-policy-ip-3-trust-dmz] source-zone trust
[Device-security-policy-ip-3-trust-dmz] destination-zone dmz
[Device-security-policy-ip-3-trust-dmz] source-ip-subnet 2.2.2.0 24
[Device-security-policy-ip-3-trust-dmz] destination-ip-host 192.168.0.111
[Device-security-policy-ip-3-trust-dmz] action pass
[Device-security-policy-ip-3-trust-dmz] quit
# Configure a rule named portallocalout2 to allow the device to send packets to the RADIUS server and portal server.
[Device-security-policy-ip-4-portallocalout2] source-zone local
[Device-security-policy-ip-4-portallocalout2] destination-zone dmz
[Device-security-policy-ip-4-portallocalout2] destination-ip-host 192.168.0.111
[Device-security-policy-ip-4-portallocalout2] destination-ip-host 192.168.0.112
[Device-security-policy-ip-4-portallocalout2] action pass
[Device-security-policy-ip-4-portallocalout2] quit
# Configure a rule named portallocalin2 to allow the device to receive and process packets from the RADIUS server and portal server.
[Device-security-policy-ip-5-portallocalin2] source-zone dmz
[Device-security-policy-ip-5-portallocalin2] destination-zone local
[Device-security-policy-ip-5-portallocalin2] source-ip-host 192.168.0.111
[Device-security-policy-ip-5-portallocalin2] source-ip-host 192.168.0.112
[Device-security-policy-ip-5-portallocalin2] action pass
[Device-security-policy-ip-5-portallocalin2] quit
5.     Configure a preauthentication IP address pool, and enable the DHCP server on GigabitEthernet 1/0/2.
[Device] dhcp server ip-pool pre
[Device-dhcp-pool-pre] gateway-list 2.2.2.1
[Device-dhcp-pool-pre] network 2.2.2.0 24
[Device-dhcp-pool-pre] quit
[Device–GigabitEthernet1/0/2] dhcp select server
6.     Configure a preauthentication domain:
# Create an ISP domain named abc, and specify authorization ACL 3010 in the domain. In ACL 3010, configure a rule to permit the traffic to the subnet 192.168.0.0/24. On GigabitEthernet 1/0/2, configure preauthentication domain as ISP domain abc.
[Device] domain abc
[Device-isp-abc] authorization-attribute acl 3010
[Device-isp-abc] quit
[Device] acl advanced 3010
[Device-acl-ipv4-adv-3010] rule 1 permit ip destination 192.168.0.0 0.0.0.255
[Device-acl-ipv4-adv-3010] quit
[Device–GigabitEthernet1/0/2] portal pre-auth domain abc
7.     Configure portal authentication:
# Verify the portal configuration by executing the display portal interface command. (Details not shown.)
# Display information about preauthentication portal users.
[Device] display portal user pre-auth interface gigabitethernet 1/0/2
Total portal pre-auth users: 1
0015-e9a6-7cfe     2.2.2.4            --     GigabitEthernet1/0/2
  State: Online
  VPN instance: --
    DHCP IP pool: N/A
    ACL number/name: 3010
    Inbound CAR: N/A
    Outbound CAR: N/A
Example: Configuring re-DHCP portal authentication with a preauthentication domain
As shown in Figure 24, the host is directly connected to the device (the access device). The host obtains an IP address through the DHCP server. A portal server acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication and accounting server.
Configure re-DHCP portal authentication. Before passing the authentication, the host is assigned a private IP address and can access only the subnet 192.168.0.0/24. After passing the authentication, the host gets a public IP address and can access other network resources.
Figure 24 Network diagram
·     If you have configured a preauthentication IP address pool on portal-enabled interfaces, configure a DHCP relay address pool with the same name on the device. For the DHCP relay address pool, specify the subnet address where the unauthenticated users reside (with the export-router keyword specified) and the DHCP server address.
[Device-security-policy-ip-1-portallocalin1] service dhcp-relay
[Device-security-policy-ip-1-trust-local] action pass
[Device-security-policy-ip-1-trust-local] quit
# Configure a rule named portallocalout2 to allow the device to send packets to the RADIUS server, portal server, and DHCP server.
[Device-security-policy-ip-3-portallocalout2] source-zone local
[Device-security-policy-ip-3-portallocalout2] destination-zone dmz
[Device-security-policy-ip-3-portallocalout2] destination-ip-host 192.168.0.111
[Device-security-policy-ip-3-portallocalout2] destination-ip-host 192.168.0.112
[Device-security-policy-ip-3-portallocalout2] destination-ip-host 192.168.0.113
[Device-security-policy-ip-3-portallocalout2] action pass
[Device-security-policy-ip-3-portallocalout2] quit
# Configure a rule named portallocalin2 to allow the device to receive and process the packets from the RADIUS server, portal server, and DHCP server.
[Device-security-policy-ip-4-portallocalin2] source-zone dmz
[Device-security-policy-ip-4-portallocalin2] source-ip-host 192.168.0.111
[Device-security-policy-ip-4-portallocalin2] source-ip-host 192.168.0.112
[Device-security-policy-ip-4-portallocalin2] source-ip-host 192.168.0.113
[Device-security-policy-ip-5-trust-dmz] source-zone trust
[Device-security-policy-ip-5-trust-dmz] destination-zone dmz
[Device-security-policy-ip-5-trust-dmz] destination-ip-host 192.168.0.111
[Device-security-policy-ip-5-trust-dmz] action pass
[Device-security-policy-ip-5-trust-dmz] quit
5.     Configure a preauthentication domain:
# Create an ISP domain named abc, and specify authorization ACL 3010 in the domain. In ACL 3010, configure a rule to permit the traffic to the subnet 192.168.0.0/24. On GigabitEthernet 1/0/2, configure the preauthentication domain as ISP domain abc.
[Device] domain abc
6.     Configure DHCP relay and authorized ARP to allow the host to obtain an IP address from the DHCP:
[Device–GigabitEthernet1/0/2] portal enable method redhcp
0015-e9a6-7cfe     10.10.10.4         --     GigabitEthernet1/0/2
  State: Online
  VPN instance: --
    DHCP IP pool: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
Example: Configuring direct portal authentication using a local portal Web service
As shown in Figure 25, the host is directly connected to the device (the access device). The host is assigned a public IP address either manually or through DHCP. The device acts as both a portal authentication server and a portal Web server. A RADIUS server acts as the authentication and accounting server.
Configure direct portal authentication on the device. Before a user passes portal authentication, the user can access only the portal Web server. After passing portal authentication, the user can access other network resources.
Figure 25 Network diagram
Customize the authentication pages, compress them to a file, and upload the file to the root directory of the storage medium of the device.
# Configure a rule named portallocalout to allow the device to send packets to the RADIUS server.
# Configure a rule named portallocalin1 to allow the device to receive and process the packets from the RADIUS server.
# Configure a rule named portallocalin2 to allow the host to send packets to the portal server.
[Device-security-policy-ip-4-portallocalin2] source-ip-host 2.2.2.2
# Create a RADIUS scheme named rs1, and configure the device to exclude the ISP domain name from the username sent to the RADIUS server, and enable RADIUS session control.
[Device] domain dm1
# Configure a portal Web server named newpt, and configure the URL of the portal Web server. On GigabitEthernet 1/0/2, enable direct portal authentication, and specify the portal Web server.
[Device-portal-websvr-newpt] url http://2.2.2.1:2331/portal
# Create an HTTP-based local portal Web service. Specify file abc.zip as the default authentication page file for the local portal Web service (Make sure the file exist under the root directory of the device). Then, set the HTTP listening port number to 2331 for the local portal Web service.
[Device] portal local-web-server http
[Device–portal-local-websvr-http] default-logon-page abc.zip
[Device–portal-local-websvr-http] tcp-port 2331
[Device–portal-local-websvr-http] quit
     ACL           : Disabled
     Dual IP       : Disabled
 IPv4:
     Bas-ip: Not configured
         IP address               Mask
         IP address               Mask
 IPv6:
A user can perform portal authentication through a Web page. Before passing the authentication, the user can access only the authentication page http://2.2.2.1:2331/portal and all Web requests will be redirected to the authentication page. After passing the authentication, the user can access other network resources.
Username: abc
  State: Online
  VPN instance: --
    DHCP IP pool: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
Example: Configuring MAC-based quick portal authentication
As shown in Figure 26, the host accesses the network through a device. The host is assigned a public IP address either manually or through DHCP. An IMC server acts as a portal authentication server, a portal Web server, and a MAC binding server. A RADIUS server acts as the authentication and accounting server. In this example, the IMC server runs IMC 7.1 (E0303) and IMC UAM 7.1 (E0303).
Configure direct portal authentication, so the host can access only the portal Web server before passing the authentication and can access other network resources after passing the authentication.
Figure 26 Network diagram
b.     Select User Access Policy > Portal Service > Server from the navigation tree to open the portal server configuration page, as shown in Figure 27.
d.     Click OK.
Figure 27 Portal server configuration
b.     Click Add to open the page as shown in Figure 28.
Make sure the client IP address (2.2.2.2) is in the IP group.
g.     Click OK.
Figure 28 Adding an IP address group
b.     Click Add to open the page as shown in Figure 29.
c.     Enter the device name.
e.     Set whether to support the portal server heartbeat and user heartbeat functions.
i.     Click OK.
Figure 29 Adding a portal device
a.     As shown in Figure 30, click the Port Group Information Management icon  for device NAS to open the port group configuration page.
b.     Click Add to open the page as shown in Figure 31.
e.     Select Supported for Transparent Authentication.
f.     Use the default settings for other parameters.
g.     Click OK.
Figure 30 Device list
Figure 31 Adding a port group
Configuring the MAC binding server
1.     Add an access policy:
a.     Select User Access Policy > Access Policy from the navigation tree to open the access policy page.
b.     Click Add to open the page as shown in Figure 32.
c.     Enter the access policy name.
d.     Select a service group.
f.     Click OK.
Figure 32 Adding an access policy
2.     Add an access service:
a.     Select User Access Policy > Access Service from the navigation tree to open the access service page.
b.     Click Add to open the page as shown in Figure 33.
c.     Enter the service name.
d.     Select the Transparent Authentication on Portal Endpoints option.
f.     Click OK.
Figure 33 Adding an access service
3.     Add an access user:
a.     Select Access User > All Access Users from the navigation tree to open the access user page.
b.     Click Add to open the page as shown in Figure 34.
c.     Select an access user.
d.     Set the password.
e.     Select a value from the Max. Transparent Portal Bindings list.
f.     Click OK.
Figure 34 Adding an access user
4.     Configure system parameters:
a.     Select User Access Policy > Service Parameters > System Settings from the navigation tree to open the system settings page.
b.     Click the Configure icon 2013-07-29_144255.png for User Endpoint Settings to open the page as shown in Figure 35.
c.     Select whether to enable transparent portal authentication on non-smart devices.
In this example, select Enable for Non-Terminal Authentication.
d.     Click OK.
e.     Click the Configure icon 2013-07-29_144255.png for Endpoint Aging Time to open the page as shown in Figure 36.
f.     Set the endpoint aging time as needed.
This example uses the default value.
Figure 35 Configuring user endpoint settings
Figure 36 Setting the endpoint aging time
[Device-security-policy-ip] rule 1 name trust-dmz
[Device-security-policy-ip] rule 2 name portallocalout
# Configure a rule named portallocalin to allow the device to receive and process the packets from the RADIUS server, portal server, and MAC-trigger server.
[Device-security-policy-ip] rule 3 name portallocalin
[Device] domain dm1
# Configure a portal authentication server and a portal Web server. On GigabitEthernet 1/0/2, enable direct authentication, specify the portal Web server, and configure the BAS-IP as 2.2.2.1.
[Device-GigabitEthernet1/0/2] portal enable method direct
[Device-GigabitEthernet1/0/2] portal apply web-server newpt
[Device-GigabitEthernet1/0/2] portal bas-ip 2.2.2.1
7.     Configure MAC-based quick portal authentication:
# Create the MAC binding server mts., set the free-traffic threshold, and specify the IP address of the MAC binding server. Specify the MAC binding server on GigabitEthernet 1/0/2.
[Device] portal mac-trigger-server mts
[Device-portal-mac-trigger-server-mts] free-traffic threshold 1024000
[Device-portal-mac-trigger-server-mts] ip 192.168.0.111
[Device-portal-mac-trigger-server-mts] quit
[Device-GigabitEthernet1/0/2] portal apply mac-trigger-server mts
# Display information about the MAC binding server.
[Device] display portal mac-trigger-server name mts
Portal mac-trigger server name: mts
  Version                    : 1.0
  Server type                : IMC
  IP                         : 192.168.0.111
  Port                       : 50100
  Aging time                 : 300 seconds
  Free-traffic threshold     : 1024000 bytes
  NAS-Port-Type              : Not configured
  Binding retry times        : 3
  Binding retry interval     : 1 seconds
  Authentication timeout     : 3 minutes
  Local-binding              : Disabled
  Local-binding aging-time   : 12 minutes
  aaa-fail nobinding         : Disabled
  Excluded attribute list    : Not configured
  Cloud-binding              : Disabled
  Cloud-server URL           : Not configured
For the first portal authentication, the user is required to enter the username and password. When the user goes offline and then accesses the network again, the user does not need to enter the authentication username and password.
# Display portal user information.
Username: Client1
  State: Online
  VPN instance: N/A
    DHCP IP pool: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
Troubleshooting portal
No portal authentication page is pushed for users
Symptom
When a user is redirected to the IMC portal authentication server, no portal authentication page or error message is prompted for the user. The login page is blank.
Analysis
The key configured on the portal access device and that configured on the portal authentication server are inconsistent. As a result, packet verification fails, and the portal authentication server refuses to push the authentication page.
Solution
Use the display this command in portal authentication server view on the access device to check whether a key is configured for the portal authentication server.
·     If no key is configured, configure the right key.
·     If a key is configured, use the ip or ipv6 command in the portal authentication server view to correct the key, or correct the key configured for the access device on the portal authentication server.
Cannot log out portal users on the access device
Symptom
You cannot use the portal delete-user command on the access device to log out a portal user, but the portal user can log out by clicking the Disconnect button on the portal authentication client.
Analysis
When you execute the portal delete-user command on the access device to log out a user, the access device sends an unsolicited logout notification message to the portal authentication server. The destination port number in the logout notification is the listening port number of the portal authentication server configured on the access device. If this listening port number is not the actual listening port number configured on the server, the server cannot receive the notification. As a result, the server does not log out the user.
When a user uses the Disconnect button on the authentication client to log out, the portal authentication server sends an unsolicited logout request message to the access device. The access device uses the source port in the logout request as the destination port in the logout ACK message. As a result, the portal authentication server can definitely receive the logout ACK message and log out the user.
Solution
1.     Use the display portal server command to display the listening port of the portal authentication server configured on the access device.
2.     Use the portal server command in system view to change the listening port number to the actual listening port of the portal authentication server.
Cannot log out portal users on the RADIUS server
Symptom
The access device uses the IMC server as the RADIUS server to perform identity authentication for portal users. You cannot log out the portal users on the RADIUS server.
Analysis
The IMC server uses session control packets to send disconnection requests to the access device. On the access device, the listening UDP port for session control packets is disabled by default. Therefore, the access device cannot receive the portal user logout requests from the RADIUS server.
Solution
On the access device, execute the radius session-control enable command in system view to enable the RADIUS session control function.
Users logged out by the access device still exist on the portal authentication server
Symptom
After you log out a portal user on the access device, the user still exists on the portal authentication server.
Analysis
When you execute the portal delete-user command on the access device to log out a user, the access device sends an unsolicited logout notification to the portal authentication server. If the BAS-IP or BAS-IPv6 address carried in the logout notification is different from the portal device IP address specified on the portal authentication server, the portal authentication server discards the logout notification. When sending of the logout notifications times out, the access device logs out the user. However, the portal authentication server does not receive the logout notification successfully, and therefore it regards the user is still online.
Solution
Configure the BAS-IP or BAS-IPv6 attribute on the interface enabled with portal authentication. Make sure the attribute value is the same as the portal device IP address specified on the portal authentication server.
Re-DHCP portal authenticated users cannot log in successfully
Symptom
The device performs re-DHCP portal authentication for users. A user enters the correct username and password, and the client successfully obtains the private and public IP addresses. However, the authentication result for the user is failure.
Analysis
When the access device detects that the client IP address is changed, it sends an unsolicited portal packet to notify of the IP change to the portal authentication server. The portal authentication server notifies of the authentication success only after it receives the IP change notification from both the access device and the client.
If the BAS-IP or BAS-IPv6 address carried in the portal notification packet is different from the portal device IP address specified on the portal authentication server, the portal authentication server discards the portal notification packet. As a result, the portal authentication server considers that the user has failed the authentication.
Solution
