- 13-Layer 3—IP Services Command Reference
- 01-IP addressing commands
- 02-IP forwarding basics commands
- 03-Fast forwarding commands
- 04-ARP commands
- 05-IPv6 basics commands
- 06-IPv6 fast forwarding commands
- 07-DHCP commands
- 08-DHCPv6 commands
- 09-DNS commands
- 10-IP performance optimization commands
- 11-Multi-CPU packet distribution commands
- 12-Adjacency table commands
- 13-Web caching commands
00-Preface | 110.43 KB |
Preface
This command reference describes the commands for configuring IP services features, including ARP, IP addressing, DHCP, DNS, IP forwarding basics, fast forwarding, adjacency table, IP performance optimization, IPv6 basics, DHCPv6, IPv6 fast forwarding, and multi-CPU packet distribution.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
