| 01-NAT commands | 1.05 MB |
action dnat (NAT64-type rule view)
action dnat (NAT66-type rule view)
action dnat (NAT-type rule view)
action snat (NAT64-type rule view)
action snat (NAT66-type rule view)
action snat (NAT-type rule view)
display nat outbound port-block-group
display nat periodic-statistics
display nat probe address-group
nat configuration-for-new-connection
nat link-switch recreate-session
nat log port-block usage threshold
nat mapping-behavior endpoint-independent
nat periodic-statistics enable
nat periodic-statistics interval
nat port-block global-share enable
nat port-block synchronization enable
nat session create-rate enable
nat static inbound net-to-net rule move
nat static inbound object-group
nat static outbound net-to-net
nat static outbound net-to-net rule move
nat static outbound object-group
rule move (interface-based NAT policy view)
NAT commands
Interface-based NAT is not supported on the F1000-C8385, F1000-C8380, F1000-C8370, F1000-C8360, F1000-C8350, F1000-C8330, F1000-9330-AI, F1000-9320-AI, F1000-9360-AI, F1000-9350-AI, F1000-9380-AI, F1000-9370-AI, F1000-E-XI, F1000-C-XI, F1000-750-HI, F1000-740-HI, F1000-730-HI, F1000-770-HI, F100-A91-WiNet, F100-A81-WiNet, F100-A-G5, F100-E-G5, F1000-A-G5, F1000-S-G5, F1000-C-G5, and F1000-C-G5-LI devices.
action
Use action to specify an address translation method for a NAT rule.
Use undo action to delete the address translation method configuration for a NAT rule.
Easy IP method:
action easy-ip
NO-NAT method:
action no-nat
NO-PAT method:
action address-group { group-id | name group-name } no-pat [ reversible ]
PAT method:
action address-group { group-id | name group-name } [ port-preserved ]
No address translation method is specified in a NAT rule.
NAT rule view
context-admin
address-group: Uses the NAT address group for address translation.
group-id: Specifies the ID of the address group. The value range for this argument is 0 to 65535.
name group-name: Specifies the name of the address group. The name is a case-sensitive string of 1 to 63 characters.
easy-ip: Uses the Easy IP method on the interface where the NAT rule is configured. The IP address of the interface is used as the NAT IP address.
no-nat: Disables the rule and its subsequent rules from translating matching packets.
no-pat: Uses the NO-PAT mode in which port numbers are not translated.
reversible: Allows reverse address translation. Reverse address translation uses existing NO-PAT entries to translate destination addresses for packets of connections actively initiated by external hosts to internal hosts.
port-preserved: Tries to preserve port number for PAT.
PAT supports TCP, UDP, and UDPLITE packets, and ICMP request packets.
A NAT address group cannot be used by both the PAT and NO-PAT methods.
If excessive NAT rules exist and you want to disable address translation for specific traffic temporarily, locate the NAT rule matching the traffic and specify the no-nat keyword in the rule.
# Configure NAT rule aaa to use the PAT mode and NAT address group 0 for address translation.
<Sysname> system
[Sysname] nat policy
[Sysname-nat-policy] rule name aaa
[Sysname-nat-policy-rule-aaa] action address-group 0
# Configure NAT rule aaa to use the NO-PAT mode and address group 0 for address translation.
<Sysname> system
[Sysname-nat-policy-rule-aaa] action address-group 0 no-pat
# Configure NAT rule aaa to use Easy IP for address translation.
<Sysname> system
[Sysname-nat-policy-rule-aaa] action easy-ip
# Disable NAT rule aaa and its subsequent rules from translating matching packets.
<Sysname> system
[Sysname-nat-policy-rule-aaa] action no-nat
display nat all
display nat policy
nat address-group
Use action dnat to specify a destination address translation method for a NAT rule.
Use undo action dnat to delete the destination address translation method configuration for a NAT rule.
Static NAT method:
action dnat static ip-address local-ipv4-address [ ipv6-vrrp virtual-router-id ] [ vrf vrf-name ]
action dnat static ip-address local-ipv6-address [ ipv4-vrrp virtual-router-id ] [ vrf vrf-name ]
undo action dnat
Server mapping method:
action dnat server ip-address local-ipv4-address [ local-port local-port ] [ vrf vrf-name ]
action dnat server ip-address local-ipv6-address [ local-port local-port ] [ ipv4-vrrp virtual-router-id ] [ vrf vrf-name ]
undo action dnat
Prefix method:
action dnat prefix { general v6tov4 | nat64 v6tov4 } [ vrf vrf-name ]
action dnat prefix { general v4tov6 prefix-general prefix-length | ivi v4tov6 prefix-ivi } [ ipv4-vrrp virtual-router-id ] [ vrf vrf-name ]
undo action dnat
No destination address translation method is specified in a NAT rule.
NAT rule view
context-admin
static: Uses the static NAT method. Mappings between IPv6 and IPv4 addresses are manually configured.
server: Uses the internal server method for address translation.
ip-address: Specifies the IP address after translation.
local-ipv4-address: Specifies the internal destination IPv4 address after translation.
local-ipv6-address: Specifies the internal destination IPv6 address after translation.
local-port port-number: Specifies the internal destination port number after translation, in the range of 1 to 65535. If you do not specify this keyword, the destination port number is not translated. This feature is supported only for TCP, UDP, and ICMP query packets. Because ICMP IPv4/IPv6 packets do not have port numbers, the ICMP IDs in these packets are used as their destination port numbers.
prefix: Uses the prefix method for address translation.
general: Uses the general prefix method for destination address translation.
v4tov6: Translates IPv4 addresses to IPv6 addresses.
v6tov4: Translates IPv6 addresses to IPv4 addresses.
ivi: Uses the IVI prefix method for IPv6-to-IPv4 destination address translation.
prefix-ivi: Specifies an IVI prefix, which is fixed at 32.
nat64: Uses the NAT64 prefix method for destination address translation.
prefix-general: Specifies a general prefix.
general-prefix-length: Specifies the general prefix length. Available values include 32, 40, 48, 56, 64, and 96. When 96 is specified as the general prefix length, make sure the 64th bit through the 71st bit of the general prefix are 0.
ipv4-vrrp virtual-router-id: Specifies an IPv4 VRRP group by its virtual router ID in the range of 1 to 255.
ipv6-vrrp virtual-router-id: Specifies an IPv6 VRRP group by its virtual router ID in the range of 1 to 255.
vrf vrf-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command applies to IPv4 or IPv6 addresses after destination address translation on the public network.
When an IPv6 user accesses an IPv4 network, the following methods are available:
· Static method—In this method, you must manually configure the one-to-one IPv4-to-IPv6 address mappings. An IPv6 user uses the IPv6 address in the matching address mapping as the destination address, and the NAT64 device translates the destination IPv6 address to an IPv4 address according to the address mapping.
· Internal server method—In this method, an IPv4 server address and its port number are mapped to the IPv6 network. An IPv6 user can access the server in the IPv4 network through accessing the translated IPv6 address and port number.
· Prefix method—In this method, a NAT64 prefix or general prefix is used to translate a destination IPv6 address to an IPv4 address.
When an IPv4 user accesses an IPv6 network, the address translation procedure is similar to that when an IPv6 user accesses an IPv4 network.
In a hot backup system collaborating with VRRP, bind the translation actions in the following address translation methods to VRRP groups:
· Static NAT—Bind the IPv6-to-IPv4 destination address translation action to the VRRP group on the IPv6 side.
· Static NAT—Bind the IPv4-to-IPv6 destination address translation action to the VRRP group on the IPv4 side.
· Server mapping—Bind the IPv4-to-IPv6 destination address translation action to the VRRP group on the IPv4 side.
· Prefix—Bind the IPv4-to-IPv6 destination address translation action to the VRRP group on the IPv4 side.
If you do not bind the translation actions to VRRP groups, the uplink Layer 3 device directly connected to the hot backup system might send downlink packets to the backup device, causing service anomalies.
When you use this command together with the packet match criteria, if you first execute the destination-ip command and then the action dnat static ip-address command, you cannot repeatedly execute the destination-ip command to modify the packet match criteria.
To perform source and destination address translations simultaneously in a VPN environment, make sure the translated addresses belong to the same VPN instance. To perform address translation, execute the action snat and action dnat commands.
This command is available only in NAT rule view of the global NAT policy.
# Configure NAT rule rule1 to use the server mapping method to translate the destination IP address to 1.1.1.5.
[Sysname] nat global-policy
[Sysname-nat-global-policy] rule name rule1 type nat64
[Sysname-nat-global-policy-rule-nat64-rule1] action dnat ip-address 1.1.1.5
action snat
destination-ip
action dnat ip-address local-ipv6-address [ local-port local-port ] [ vrf vrf-name ]
undo action dnat
NPTv6 method:
action dnat nptv6 translated-ipv6-prefix prefix-length [ vrf vrf-name ]
undo action dnat
NO-NAT method:
action dnat no-nat
undo action dnat
NAT rule view
context-admin
static: Uses the static method for address translation. The mappings between destination IPv6 addresses before and after translation are manually configured.
ip-address local-ipv6-address: Specifies the internal destination IPv6 address after translation.
local-port port-number: Specifies the internal destination port number after translation, in the range of 1 to 65535. If you do not specify this keyword, the destination port number is not translated. This feature is supported only for TCP, UDP, and ICMPv6 query packets. Because ICMPv6 packets do not have port numbers, the ICMP IDs in these packets are used as their destination port numbers.
nptv6: Uses the NPTv6 method for IPv6 address prefix translation.
translated-ipv6-prefix prefix-length: Specifies the IPv6 address prefix after translation. The translated-ipv6-prefix argument indicates the address prefix. The prefix-length argument specifies the IPv6 address prefix length in the range of 1 to 112.
no-nat: Disables the rule and its subsequent rules from translating the destination IP address of the matching packets.
vrf vrf-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command applies to IPv6 addresses after destination address translation on the public network.
This command is applicable to scenarios where a server in an internal network provides services (for example, Web or FTP service) for external networks. Through configuring mappings between internal servers and external servers in a NAT66-type rule, users in external networks can access servers in internal networks through the specified external network address.
If excessive NAT rules exist and you want to disable address translation for specific traffic temporarily, locate the NAT rule that matches the traffic and specify the no-nat keyword in the rule.
When you use this command together with packet match criteria, follow these restrictions and guidelines:
· When you use the action dnat nptv6 command together with the destination-ip command, if you first execute the destination-ip command and then the action dnat nptv6 command, you cannot repeatedly execute the destination-ip command to modify the packet match criteria.
· You cannot use this command together with the security zone match criteria. To use destination security zones as the packet match criteria for a NAT rule, first execute the undo action dnat command and then the destination-zone command.
# Configure NAT rule rule1 to use the server mapping method to translate the destination IPv6 address to 3001::5.
[Sysname-nat-global-policy] rule name rule1 type nat66
[Sysname-nat-global-policy-rule-nat66-rule1] action dnat ip-address 3001::5
action snat
destination-ip
destination-zone
Use undo action dnat to delete the configuration of a destination address translation method for a NAT rule.
action dnat { ip-address local-address | object-group ipv4-object-group-name } [ local-port local-port ] [ vrrp virtual-router-id ] [ vrf vrf-name ]
undo action dnat
NO-NAT method:
action dnat no-nat
undo action dnat
NAT rule view
context-admin
ip-address local-address: Specifies a private destination IP address after translation.
object-group ipv4-object-group-name: Specifies an object group by its name. The name is a case-insensitive string of 1 to 63 characters, and it cannot be any. If spaces are included in the name, enclose the name in quotation marks ("), for example, "XXX XXX".
local-port local-port: Specifies a private destination port number after translation, in the range of 1 to 65535. If you do not specify this option, the device does not translate destination ports of the packets. Only TCP, UDP, and ICMP query packets are supported. For an ICMP packet, the ICMP ID is used as its destination port number.
vrrp virtual-router-id: Binds the destination translation method to a VRRP group. The virtual-router-id parameter represents the virtual router ID in the range of 1 to 255.
vrf vrf-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command applies to IPv4 addresses after destination address translation on the public network.
When external users access an internal server, the NAT device translates the destination IP addresses and ports of the matching packets to the IP address and port of the internal server.
In a hot backup system collaborating with VRRP, bind the destination address translation method on the primary device in the hot backup system to the VRRP group facing the external network. If you do not perform the binding, the uplink Layer 3 device directly connected to the hot backup system might send downlink packets to the backup device, causing service anomalies.
A NAT rule that uses the destination address translation method does support using a destination security zone as the packet match criterion. To use the destination security zone as the packet match criterion for the rule, execute the undo action dnat command first and then execute the destination-zone command.
# For NAT rule rule1, specify the server mapping method and specify 1.1.1.5 as the destination address after translation.
[Sysname-nat-global-policy-rule-rule1] action dnat ip-address 1.1.1.5
action snat
destination-zone
Use action snat to specify a source address translation method for a NAT rule.
Use undo action snat to delete the source address translation method configuration for a NAT rule.
NO-PAT method:
action snat object-group ipv4-object-group-name no-pat [ ipv4-vrrp virtual-router-id ] [ vrf vrf-name ]
action snat object-group ipv6-object-group-name no-pat [ vrf vrf-name ]
undo action snat
PAT method:
action snat object-group ipv4-object-group-name [ ipv4-vrrp virtual-router-id ] [ vrf vrf-name ]
action snat object-group ipv6-object-group-name [ vrf vrf-name ]
undo action snat
Prefix translation method:
action snat prefix { general { v4tov6 prefix-general general-prefix-length | v6tov4 } | ivi v6tov4 | nat64 v4tov6 prefix-nat64 nat64-prefix-length } [ vrf vrf-name ]
undo action snat
Static NAT method:
action snat static ip-address global-ipv4-address [ ipv4-vrrp virtual-router-id ] [ vrf vrf-name ]
action snat static ip-address global-ipv6-address [ ipv6-vrrp virtual-router-id ] [ vrf vrf-name ]
undo action snat
No source address translation method is specified in a NAT rule.
NAT rule view
context-admin
object-group: Specifies the address object group used for address translation.
ipv4-object-group-name: Specifies an IPv4 address object group by its name. The name is a case-insensitive string of 1 to 63 characters, and it cannot be any. If spaces are included in the name, enclose the name in quotation marks ("), for example, "XXX XXX".
ipv6-object-group-name: Specifies an IPv6 address object group by its name. The name is a case-insensitive string of 1 to 63 characters, and it cannot be any. If spaces are included in the name, enclose the name in quotation marks ("), for example, "XXX XXX".
prefix: Uses the prefix method for source address translation.
general: Uses the general prefix method for source address translation.
ivi: Uses the IVI prefix method for source address translation.
nat64: Uses the NAT64 prefix method for source address translation.
prefix-nat64: Specifies a NAT64 prefix.
nat64-prefix-length: Specifies the NAT64 prefix length. Available values include 32, 40, 48, 56, 64, and 96. When 96 is specified as the NAT64 prefix length, make sure the 64th bit through the 71st bit of the NAT64 prefix are 0.
static: Uses the static method for source address translation.
global-ipv4-address: Specifies the source IPv4 address after translation.
global-ipv6-address: Specifies source IPv6 address after translation.
vrf vrf-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command applies to IPv4 or IPv6 addresses after source address translation on the public network.
You can use different source IP address match criteria together with different source address translation methods to perform address translation. For example, when the source-ip host {ipv4-address | ipv6-address } command is used to configure packet match criteria for a NAT rule, the command can be used together with the action snat static ip-address { global-ipv4-address | global-ipv6-address } command to implement one-to-one static address translation.
· When you use the action snat static ip-address command together with the source-ip command, if you first execute the source-ip command and then the action snat static ip-address command, you cannot repeatedly execute the source-ip command to modify packet match criteria.
· When you use the static method for address translation, make sure the number of IP addresses in the packet match criteria for matching the source addresses of packets is the same as that in the static address translation method.
When a source address translation method references an address object group, follow these restrictions and guidelines:
· For an address object group to be successfully referenced by the source address translation method, make sure the objects in the referenced address object group are created through the following methods:
¡ [ object-id ] network host address ip-address
¡ [ object-id ] network subnet ip-address { mask-length | mask }
¡ [ object-id ] network range ip-address1 ip-address2
For more information about these commands, see object group commands in Security Command Reference.
· The number of IP addresses in the address object groups referenced by the source address translation method cannot exceed 65535.
· The address object group referenced by the static address translation method cannot contain excluded addresses.
· NO-PAT method—Bind the IPv6-to-IPv4 source address translation action to the VRRP group on the IPv4 side.
· PAT method—Bind the IPv6-to-IPv4 source address translation action to the VRRP group on the IPv4 side.
· Static NAT method—Bind the IPv6-to-IPv4 source address translation action to the VRRP group on the IPv4 side.
· Static NAT method—Bind the IPv4-to-IPv6 source address translation action to the VRRP group on the IPv6 side.
# Configure NAT rule aaa to use the PAT method and reference source IPv4 address object group srcIP1.
<Sysname> system
[Sysname-nat-global-policy] rule name aaa type nat64
[Sysname-nat-global-policy-rule-nat64-aaa] action snat object-group srcIP1
action dnat
display nat all
display nat global-policy
network (Security Command Reference)
Use undo action snat to delete the configuration of a source address translation method for a NAT rule.
NO-PAT method:
undo action snat
PAT method:
undo action snat
Static NAT method:
undo action snat
NPTv6 method:
action snat nptv6 translated-ipv6-prefix prefix-length [ vrf vrf-name ]
undo action snat
NO-NAT method:
action snat no-nat
undo action snat
NAT rule view
context-admin
object-group ipv6-object-group-name: Specifies an IPv6 address object group by its name for address translation. The name is a case-insensitive string of 1 to 63 characters, and it cannot be any. If spaces are included in the name, enclose the name in quotation marks ("), for example, "XXX XXX".
static: Uses the static method for address translation. The mappings between source IPv6 addresses before and after translation are manually configured.
ipv6-address global-ipv6-address: Specifies the source IPv6 address after translation.
translated-ipv6-prefix nptv6-prefix-length: Specifies the IPv6 address prefix after translation. The translated-ipv6-prefix argument indicates the address prefix. The nptv6-prefix-length argument specifies the IPv6 address prefix length in the range of 1 to 112.
no-nat: Disables the rule and its subsequent rules from translating the source IP address of the matching packets.
vrf vrf-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command applies to IPv6 addresses after source address translation on the public network.
If you have configured a large number of NAT rules, to exclude some packets with addresses in a small range from source address translation, use the NO-PAT method.
· The action snat nptv6 command can be used together with only the source-ip subnet command. If you first execute the source-ip subnet command and then the action snat nptv6 command, you cannot repeatedly execute the source-ip command to modify the packet match criteria.
· The number of IP addresses in the address object group referenced by the source address translation method cannot exceed 65535.
· An address object group referenced by the static address translation method cannot contain excluded addresses.
In a hot backup system collaborating with VRRP, bind the static address translation action to the VRRP group on the IPv6 side. If you do not perform the binding, the uplink Layer 3 device directly connected to the hot backup system might send downlink packets to the backup device, causing service anomalies.
# Configure NAT rule aaa to use the NAT66 prefix method to translate the source IPv6 address prefix to 2101::/64 for packets whose source IP addresses match subnet fd9C:58ed:7d73:2::/64.
<Sysname> system
[Sysname-nat-global-policy] rule name aaa type nat66
[Sysname-nat-global-policy-rule-nat66-aaa] source-ip subnet fd9C:58ed:7d73:2:: 64
[Sysname-nat-global-policy-rule-nat66-aaa] action snat prefix 2101:: 64
action dnat
display nat all
source-ip
NO-PAT method:
action snat { address-group { group-id | name group-name } | object-group ipv4-object-group-name } no-pat [ reversible ] [ vrrp virtual-router-id ] [ vrf vrf-name ]
undo action snat
PAT method:
action snat { address-group { group-id | name group-name } | object-group ipv4-object-group-name } [ port-preserved ] [ vrrp virtual-router-id ] [ vrf vrf-name ]
undo action snat
Easy IP:
action snat easy-ip [ port-preserved ] [ vrf vrf-name ]
undo action snat
Static NAT:
action snat static { ip-address global-address | object-group object-group-name | subnet subnet-ip-address mask-length } [ vrrp virtual-router-id ] [ vrf vrf-name ]
undo action snat
NO-NAT method:
action snat no-nat
undo action snat
NAT rule view
context-admin
group-id: Specifies the ID of the NAT address group. The value range is 0 to 65535.
name group-name: Specifies the name of an address group, a case-sensitive string of 1 to 63 characters.
easy-ip: Uses the Easy IP method. The IP address of the packet output interface is used as the NAT IP address.
ip-address global-address: Specifies a public IP address as the NAT IP address for source address translation.
reversible: Enables reverse address translation. Reverse address translation uses existing NO-PAT entries to translate the destination address for connections actively initiated from the internal network to the external network.
static: Uses the static NAT method. Mappings between private and public addresses are manually configured.
object-group object-group-name: Specifies the name of an address object group. The name is a case-insensitive string of 1 to 63 characters, and it cannot be any. If spaces are included in the name, enclose the name in quotation marks ("), for example, "XXX XXX".
subnet subnet-ip-address mask-length: Specifies a subnet as NAT IP address resources for address translation. The subnet-ip-address argument specifies the subnet address. The mask-length argument specifies the mask length, which can be 8, 16, or an integer in the range of 24 to 31.
vrrp virtual-router-id: Binds the source translation method to a VRRP group. The virtual-router-id parameter represents the virtual router ID in the range of 1 to 255.
vrf vrf-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command applies to IPv4 addresses after source address translation on the public network.
You can configure combinations between source IP address match criteria and source IP address translation methods. In each static combination, the number of IP addresses in the match criteria must equal the number of NAT IP addresses in the translation method. For example, the action snat static ip-address global-address command and the source-ip host ip-address command can define a one-to-one static source address translation.
When the source address translation method references an address object group, follow these restrictions and guidelines:
In a hot backup system collaborating with VRRP, bind the source address translation method on the primary device in the hot backup system to the VRRP group facing the external network. If you do not perform the binding, the uplink Layer 3 device directly connected to the hot backup system might send downlink packets to the backup device, causing service anomalies.
For dual-active hot backup, select one of the following configuration methods:
· The two devices can share the same NAT address group. To prevent different master devices from using the same IP-port mapping for different hosts, specify the PAT translation mode and execute the nat remote-backup port-alloc command on the primary device.
· As a best practice to prevent different master devices from using the same IP-port mapping for different hosts, configure the two devices to use different public IP addresses for address translation. For example, if the two devices use different NAT addresses, user traffic with different source IP addresses is identified by source IP address match criteria in NAT rules. To enable different master devices to translate the forward user traffic, specify different gateway addresses for different internal users. To direct the reverse traffic to different master devices, configure VRRP group binding on the primary device for load sharing.
<Sysname> system
[Sysname-nat-global-policy-rule-aaa] action address-group 0
<Sysname> system
[Sysname-nat-global-policy-rule-aaa] action address-group 0 no-pat
# Configure NAT rule aaa to use the static NAT method to translate source IP address 1.1.1.1 to 100.10.0.1.
<Sysname> system
[Sysname-nat-global-policy-rule-aaa] source-ip host 1.1.1.1
[Sysname-nat-global-policy-rule-aaa] action snat static ip-address 100.10.0.1
# Disable address translation for NAT rule aaa.
<Sysname> system
[Sysname-nat-global-policy-rule-aaa] action snat no-nat
action dnat
display nat all
display nat policy
nat address-group
address
Use address to add an address range to a NAT address group.
Use undo address to remove an address range from a NAT address group.
address start-address end-address
undo address start-address end-address
No address ranges exist.
NAT address group view
context-admin
start-address end-address: Specifies the start and end IP addresses of the address range. The end address must not be lower than the start address. If they are the same, the address range has only one IP address.
A NAT address group is a set of address ranges. The source address in a packet destined for an external network is translated into an address in one of the address ranges.
You can specify a maximum of 65535 addresses in one command execution. Make sure the address ranges do not overlap.
The address command and the address interface command are mutually exclusive for one NAT address group.
# Add address ranges to an address group.
[Sysname] nat address-group 2
[Sysname-address-group-2] address 10.1.1.1 10.1.1.15
[Sysname-address-group-2] address 10.1.1.20 10.1.1.30
address interface
nat address-group
block-size
Use block-size to set the port block size.
Use undo block-size to restore the default.
block-size block-size
undo block-size
The port block size is 256.
NAT port block group view
context-admin
block-size: Specifies the number of ports for a port block. The value range for this argument is 1 to 65535.
Set an appropriate port block size based on the number of private IP addresses, the number of public IP addresses, and the port range in the port block group.
The port block size cannot be larger than the number of ports in the port range.
# Set the port block size to 1024 for port block group 1.
[Sysname] nat port-block-group 1
[Sysname-port-block-group-1] block-size 1024
counting enable
Use counting enable to enable hit counting for a NAT rule.
Use undo counting enable to disable hit counting for a NAT rule.
counting enable
NAT rule hit counting is disabled.
NAT rule view
context-admin
This command enables the devices to count the number of times the rule is matched (or hit). To view hit statistics for the rule, execute the display nat policy command.
# Enable hit counting for NAT rule aaa in the interface-based NAT policy.
<Sysname> system
[Sysname-nat-policy-rule-aaa] counting enable
# Enable hit counting for NAT rule aaa in the global NAT policy.
<Sysname> system
[Sysname-nat-global-policy-rule-aaa] counting enable
display nat all
display nat policy
description
Use description to configure a description for the NAT rule.
A NAT rule does not have any description.
NAT rule view
context-admin
text: Specifies the description, a case-sensitive string of 1 to 63 characters.
# Configure a description for NAT rule aaa in the interface-based NAT policy.
<Sysname> system
[Sysname-nat-policy-rule-aaa] description This is a nat rule of abc policy
# Configure a description for NAT rule aaa in the global NAT policy.
<Sysname> system
[Sysname-nat-global-policy-rule-aaa] description This is a nat rule of abc policy
destination-ip
Use destination-ip to specify a destination IP address match criterion in a NAT rule.
Use undo destination-ip to delete a destination IP address match criterion from a NAT rule.
NAT-type rule view in the interface-based NAT policy:
destination-ip ipv4-object-group-name
undo destination-ip [ ipv4-object-group-name ]
NAT-type rule view in the global NAT policy:
destination-ip { host ip-address | subnet subnet-ip-address mask-length }
undo destination-ip { host [ ip-address ] | subnet [subnet-ip-address mask-length ] }
NAT64-type rule view in the global NAT policy:
destination-ip { ipv4-object-group-name | ipv6-object-group-name }
undo destination-ip [ ipv4-object-group-name | ipv6-object-group-name ]
destination-ip { host { ipv4-address | ipv6-address } | subnet { subnet-ipv4-address mask-length | ipv6-prefix prefix-length } }
undo destination-ip { host [ ipv4-address | ipv6-address ] | subnet [ subnet-ipv4-address mask-length | ipv6-prefix prefix-length ] }
NAT66-type rule view in the global NAT policy:
destination-ip ipv6-object-group-name
undo destination-ip [ ipv6-object-group-name ]
destination-ip { host ipv6-address | subnet ipv6-prefix prefix-length }
undo destination-ip { host [ ipv6-address ] | subnet [ ipv6-prefix prefix-length ] }
A NAT rule does not have any destination IP address match criteria.
NAT rule view
context-admin
ipv4-object-group-name: Specifies the name of an IPv4 address object group. The name is a case-insensitive string of 1 to 63 characters, and it cannot be any. If spaces are included in the name, enclose the name in quotation marks ("), for example, "XXX XXX".
ipv6-object-group-name: Specifies the name of an IPv6 address object group. The name is a case-insensitive string of 1 to 63 characters, and it cannot be any. If spaces are included in the name, enclose the name in quotation marks ("), for example, "XXX XXX".
host ipv4-address: Specifies an IPv4 address to match destination IP address. The IPv4 address cannot be an all-zero address, all-one address, Class D address, Class E address, or loopback address.
host ipv6-address: Specifies an IPv6 address to match destination IP address.
subnet subnet-ipv4-address mask-length: Specifies a subnet to match destination IPv4 addresses. The subnet-ip-address argument specifies the subnet address. The mask-length argument specifies the mask length, which can be 8, 16, or an integer in the range of 24 to 31.
subnet ipv6-prefix prefix-length: Specifies an IPv6 prefix for a NAT rule. The ipv6-prefix argument indicates an IPv6 prefix. The prefix-length argument indicates the prefix length in the range of 1 to 128.
The NAT device uses the destination IP addresses specified in this command to identify matching packets. Only packets with the matching destination IP addresses are translated.
To translate destination IP addresses of packets from the internal network to the external network, use this command with the action dnat command.
When referencing an address object group, follow these restrictions and guidelines:
· The address object group must already exist.
· For an address object group to be successfully referenced by the destination address translation method, make sure the objects in the referenced address object group are created through the following methods:
If you do not specify any parameters in the undo destination-ip command, the command deletes all destination address match criteria in the NAT rule.
When you configure match criteria for a NAT rule, follow these restrictions and guidelines:
· A NAT rule can have a maximum of 256 destination address object groups.
· A NAT rule can have a maximum of 256 destination IP addresses.
· If you configure multiple packet match criteria in a NAT64-type rule, the IP address type in the later configured packet match criteria must be the same as that in the earlier configured packet match criteria. For example, if you first execute the destination-ip host 192.168.1.1 command, the destination-ip host 100::1 command executed later does not take effect. Select an IP type as needed.
· If you execute the following commands in the same NAT rule, the most recent configuration takes effect:
¡ destination-ip subnet
¡ destination-ip
¡ destination-ip host
# In the interface-based NAT policy, configure NAT rule aaa to use destination address object groups desIP1, desIP2, and desIP3 as the packet match criteria.
<Sysname> system
[Sysname-nat-policy-rule-aaa] destination-ip desIP1
[Sysname-nat-policy-rule-aaa] destination-ip desIP2
[Sysname-nat-policy-rule-aaa] destination-ip desIP3
# In the global NAT policy, configure NAT rule aaa to use destination address object groups desIP1, desIP2, and desIP3 as the packet match criteria.
[Sysname-nat-global-policy-rule-aaa] destination-ip desIP1
[Sysname-nat-global-policy-rule-aaa] destination-ip desIP2
[Sysname-nat-global-policy-rule-aaa] destination-ip desIP3
display nat all
display nat policy
object-group (Security Command Reference)
destination-zone
Use destination-zone to specify a destination security zone in a NAT rule.
Use undo destination-zone to delete a destination security zone from a NAT rule.
destination-zone destination-zone-name
undo destination-zone [ destination-zone-name ]
No destination security zones are specified in a NAT rule.
NAT rule view
context-admin
destination-zone-name: Specifies the name of a destination security zone. The name is a case-insensitive string of 1 to 31 characters, and it cannot be any. You can specify a nonexistent security zone. This command takes effect after you use the security-zone name command to create the security zone. For more information about security zones, see Security Configuration Guide.
The NAT device uses the destination security zones specified in this command to identify matching packets. Only packets with the matching destination security zones are translated.
To translate source IP addresses of outgoing packets, use this command with the action snat command. This command cannot be used with the action dnat command.
This command does not support modifying destination security zones. To modify the destination security zone for a NAT rule, first execute the undo destination-zone command to delete the zone, and then execute the destination-zone command to specify a new one.
If you do not specify a destination security zone in the undo destination-zone command, the command deletes all destination security zones in the rule.
This command is available only in NAT-type rule view and NAT66-type rule view of the global NAT policy.
A NAT rule can have a maximum of 16 destination security zones.
# Specify destination security zone trust for NAT rule rule1.
[Sysname-nat-global-policy-rule-rule1] destination-zone trust
rule name
security-zone name (Security Command Reference)
disable
Use disable to disable a NAT rule.
Use undo disable to enable a NAT rule.
disable
undo disable
A NAT rule is enabled.
NAT rule view
context-admin
This command does not delete a NAT rule, but makes the rule ineffective. You can use the display nat policy command or the display nat global-policy command to view the status of the NAT rules. If you want to delete a NAT rule, use the undo rule name command.
# Disable the NAT rule aaa in the interface-based NAT policy.
<Sysname> system
[Sysname-nat-policy-rule-aaa] disable
# Disable the NAT rule aaa in the global NAT policy.
<Sysname> system
[Sysname-nat-global-policy-rule-aaa] disable
display nat all
display nat policy
display nat address-group
Use display nat address-group to display NAT address group information.
display nat address-group [ group-id ]
context-admin
context-operator
group-id: Specifies the ID of a NAT address group. The value range for this argument is 0 to 65535. If you do not specify the group-id argument, this command displays information about all NAT address groups.
# Display information about all NAT address groups.
<Sysname> display nat address-group
NAT address group information:
Totally 5 NAT address groups.
Address group ID: 1 Address group name: a
Port range: 1-65535
Address information:
Start address End address
202.110.10.10 202.110.10.15
Address group ID: 2
Port range: 1-65535
VRID : 1
202.110.10.20 202.110.10.25
202.110.10.30 202.110.10.35
Address group ID: 3
Port range: 1024-65535
202.110.10.40 202.110.10.50
Address group ID: 4
Port range: 10001-65535
Port block size: 500
Extended block number: 1
202.110.10.60 202.110.10.65
Address group ID: 5
Port range: 1-1024
20.1.1.1 (GigabitEthernet1/0/1)
Address group ID: 6
Port range: 1-65535
# Display information about NAT address group 1.
<Sysname> display nat address-group 1
VRID : 1
Port range: 1-65535
NAT address group information |
Information about the NAT address group |
Address group ID |
ID of the NAT address group. |
Totally n NAT address groups |
Total number of NAT address groups. |
Address group name |
Name of the NAT address group. If no address group name is configured, this field is not displayed. |
VRID |
Virtual router ID (VRRP group number). If no VRRP group is specified, this field is not displayed. |
Port range |
Port range for public IP addresses. |
Port block size |
Number of ports in a port block. This field is not displayed if the port block size is not set. |
Extended block number |
Number of extended port blocks. This field is not displayed if the number of extended port blocks is not set. |
Address information |
Information about the IP addresses in the address group. · For addresses added by using the address command: ¡ Start address—Start IP address of an address range. If you do not specify a start address for the range, this field displays hyphens (---). ¡ End address—End IP address of an address range. If you do not specify an end address for the range, this field displays hyphens (---). · For addresses added by using the address interface command: ¡ 20.1.1.1 (GigabitEthernet1/0/1)—IP address 20.1.1.1 of GigabitEthernet 1/0/1 has been added to the NAT address group. ¡ --- (GigabitEthernet1/0/2)—Failed to add the IP address of GigabitEthernet 1/0/2 to the NAT address group because this interface does not have an IP address. |
nat address-group
display nat alg
Use display nat alg to display the NAT ALG status for all supported protocols.
display nat alg
context-admin
context-operator
# Display the NAT ALG status for all supported protocols.
<Sysname> display nat alg
NAT ALG:
DNS : Enabled
FTP : Disabled
H323 : Disabled
ICMP-ERROR : Disabled
ILS : Disabled
MGCP : Disabled
NBT : Disabled
PPTP : Disabled
RTSP : Disabled
RSH : Disabled
SCCP : Disabled
SCTP : Disabled
SIP : Disabled
SQLNET : Disabled
TFTP : Disabled
XDMCP : Disabled
display nat all
display nat all
Use display nat all to display all NAT configuration information.
display nat all
context-admin
context-operator
# Display all NAT configuration information.
<Sysname> display nat all
Address group 1:
Port range: 1-65535
Address group 2:
Port range: 1-65535
Address group 3:
Address group 4:
Address group 6:
Port range: 1-65535
NAT server group information:
Totally 3 NAT server groups.
Group Number Inside IP Port Weight
1 192.168.0.26 23 100
192.168.0.27 23 500
2 --- --- ---
3 192.168.0.26 69 100
NAT global-policy information:
Totally 1 NAT global-policy rules.
Rule name: rule1
Description : global nat rule
SrcIP object group : srcObj1
SrcIP object group : srcObj2
SrcIP object group : srcObj3
DestIP object group : desObj1
DestIP object group : desObj2
DestIP object group : desObj3
Service object group : serviceObj1
Service object group : serviceObj2
Service object group : serviceObj3
Source zone name : Trust
Destination zone name : Local
SNAT action:
Address group ID: 2 Address group name: a
NO-PAT: Y
Reversible: N
Port-preserved: N
DNAT action:
IP address: 1.1.2.1
Port: 80
NAT counting : 0
Config status: Active
NAT policy information:
Totally 1 NAT policy rules.
Rule name: rule1
Description : first rule
Routing-interface : GigabitEthernet1/0/2
Action
NO-PAT: Y
Reversible: N
Port-preserved: N
NAT inbound information:
Totally 1 NAT inbound rules.
ACL: 2038
Address group ID: 2
Add route: Y NO-PAT: Y Reversible: N
VPN instance: vpn_nat
Rule name: abcdefg
Priority: 1000
Description: NatInbound1
NAT outbound information:
Totally 2 NAT outbound rules.
ACL: 2036
Address group ID: 1
Port-preserved: Y NO-PAT: N Reversible: N
Configuration mode : NETCONF (action)
Rule name: cdefg
Priority: 1001
Description: NatOutbound1
Config status: Inactive
Reasons for inactive status:
The following items don't exist or aren't effective: address group, and ACL.
ACL: 2037
Address group ID: 1
Port-preserved: N NO-PAT: Y Reversible: Y
Rule name: blue
Priority: 1002
Config status: Active.
NAT internal server information (object-group):
Totally 1 object-group-based NAT server rules.
Rule name: aaa
Local IP/Port: 1.1.1.1/80
DestIP Object group: abc
NAT counting : 0
Config status : Active
NAT internal server information:
Totally 5 internal servers.
Global ACL : 2000
Local IP/port : 192.168.10.1/23
Rule name : cdefgab
Priority : 1000
NAT counting : 0
Description : NatServerDescription1
Protocol: 6(TCP)
Global IP/port: 50.1.1.1/23
Local IP/port : 192.168.10.15/23
ACL : 2000
Rule name : green
NAT counting : 0
Interface: GigabitEthernet1/0/3
Protocol: 6(TCP)
Global IP/port: 50.1.1.1/23-30
Local IP/port : 192.168.10.15-192.168.10.22/23
Global VPN : vpn1
Local VPN : vpn3
Rule name : blue
NAT counting : 0
Interface: GigabitEthernet1/0/4
Protocol: 255(Reserved)
Global IP/port: 50.1.1.100/---
Local IP/port : 192.168.10.150/---
Global VPN : vpn2
Local VPN : vpn4
ACL : 3000
Rule name : white
NAT counting : 0
Config status : Inactive
The following items don't exist or aren't effective: ACL.
Interface: GigabitEthernet1/0/5
Protocol: 17(UDP)
Global IP/port: 50.1.1.2/23
Local IP/port : server group 1
192.168.0.26/23 (Connections: 10)
192.168.0.27/23 (Connections: 20)
Global VPN : vpn1
Local VPN : vpn3
Rule name : black
NAT counting : 0
Static NAT mappings:
Totally 2 inbound static NAT mappings.
Net-to-net:
Global IP : 2.2.2.1 – 2.2.2.255
Local IP : 1.1.1.0
Netmask : 255.255.255.0
Global VPN : vpn2
Local VPN : vpn1
ACL : 2000
Reversible : Y
Rule name : pink
Priority : 1000
Global flow-table status: Active
Local flow-table status: Active
IP-to-IP:
Global IP : 5.5.5.5
Local IP : 4.4.4.4
ACL : 2001
Reversible : Y
Rule name : yellow
Priority : 1000
Description : NatStaticDescription1
Totally 2 outbound static NAT mappings.
Net-to-net:
Local IP : 1.1.1.1 - 1.1.1.255
Global IP : 2.2.2.0
ACL : 2000
Reversible : Y
Rule name : grey
Priority : 1000
IP-to-IP:
Local IP : 4.4.4.4
Global IP : 5.5.5.5
ACL: : 2001
Reversible : Y
Rule name : orange
Priority : 10000
Description : NatStaticDescription2
Interfaces enabled with static NAT:
Totally 2 interfaces enabled with static NAT.
Interface: GigabitEthernet1/0/6
NAT DNS mappings:
Totally 2 NAT DNS mappings.
Domain name : www.server.com
Global IP : 6.6.6.6
Global port : 23
Protocol : TCP(6)
Domain name : www.service.com
Global IP : ---
Global port : 12
Protocol : TCP(6)
The following items don't exist or aren't effective: interface IP address.
NAT logging:
Log enable : Enabled(ACL 2000)
Flow-begin : Disabled
Flow-end : Disabled
Flow-active : Enabled(10 minutes)
Port-block-assign : Disabled
Port-block-withdraw : Disabled
Alarm : Disabled
NO-PAT IP usage : Disabled
NAT hairpinning:
Totally 2 interfaces enabled with NAT hairpinning.
NAT mapping behavior:
Mapping mode : Endpoint-Independent
ACL : 2050
NAT ALG:
DNS : Enabled
FTP : Enabled
H323 : Enabled
ICMP-ERROR : Enabled
ILS : Enabled
MGCP : Enabled
NBT : Enabled
PPTP : Enabled
RTSP : Enabled
RSH : Enabled
SCCP : Enabled
SCTP : Disabled
SIP : Enabled
SQLNET : Enabled
TFTP : Enabled
XDMCP : Disabled
NAT port block group information:
Totally 3 NAT port block groups.
Port block group 1:
Port range: 1-65535
Block size: 256
Local IP address information:
Start address End address VPN instance
172.16.1.1 172.16.1.254 ---
192.168.1.1 192.168.1.254 ---
192.168.3.1 192.168.3.254 ---
Global IP pool information:
201.1.1.1 201.1.1.10
201.1.1.21 201.1.1.25
Port block group 2:
Port range: 10001-30000
Block size: 500
10.1.1.1 10.1.10.255 ---
202.10.10.101 202.10.10.120
Port block group 3:
Port range: 1-65535
Block size: 256
NAT outbound port block group information:
Totally 2 outbound port block group items.
port-block-group: 2
Rule name: stone
port-block-group: 10
The following items don't exist or aren't effective: port block group.
Static NAT load balancing: Disabled
NAT link-switch recreate-session: Disabled
NAT configuration-for-new-connection: Disabled
The output shows all NAT configuration information. Table 2 describes only the fields for the output of the nat hairpin enable, nat mapping-behavior, and nat alg commands.
Information about the NAT address group. See Table 1 for output description. |
NAT server group information |
Information about the internal server group. See Table 19 for output description. |
NAT inbound information: |
Inbound dynamic NAT configuration. See Table 6 for output description. |
NAT outbound information |
Outbound dynamic NAT configuration. See Table 10 for output description. |
NAT internal server information |
NAT server mapping configuration. See Table 18 for output description. |
NAT global-policy information |
Configuration of the global NAT policy. See Table 5 for output description. |
NAT policy information |
Configuration of the NAT policy. See Table 13 for output description. |
Static NAT mappings |
Static NAT mappings. See Table 21 for output description. |
NAT DNS mappings |
NAT DNS mappings. See Table 3 for output description. |
NAT logging |
NAT logging configuration. See Table 7 for output description. |
NAT hairpinning |
NAT hairpin configuration. |
Totally n interfaces enabled NAT hairpinning |
Number of interfaces with NAT hairpin enabled. |
NAT hairpin-enabled interface. |
Rule name |
Name of the NAT rule. |
Priority |
Priority of the NAT rule. |
Config status |
Status of the NAT hairpin configuration: Active or Inactive. |
NAT mapping behavior |
Mapping behavior mode of PAT: Endpoint-Independent or Address and Port-Dependent. |
ACL |
ACL number or name. If no ACL is specified for NAT, this field displays hyphens (---). |
Config status |
Status of the NAT mapping behavior configuration: Active or Inactive. |
Reasons for inactive status |
Reasons why the NAT mapping behavior configuration does not take effect. This field is available when the Config status is Inactive. |
NAT ALG |
NAT ALG configuration for different protocols. |
NAT port block group information |
Configuration information about NAT port block groups. See Table 15 for output description. |
NAT outbound port block group information |
Configuration information about static outbound port block mapping rules. See Table 11 for output description. |
Static NAT load balancing |
Whether load balancing is enabled for static NAT on service engines: · Enabled. · Disabled. |
NAT link-switch recreate-session |
Whether NAT session recreation after link switchover is enabled: · Enabled. · Disabled. |
NAT configuration-for-new-connection |
Whether NAT configuration changes taking effect only on new connections is enabled: · Enabled. · Disabled. |
display nat dns-map
Use display nat dns-map to display NAT DNS mappings.
display nat dns-map
context-admin
context-operator
# Display NAT DNS mappings.
<Sysname> display nat dns-map
NAT DNS mapping information:
Global IP : 6.6.6.6
Global port : 23
Protocol : TCP(6)
Global IP : ---
Global port : 12
Protocol : TCP(6)
NAT DNS mapping information |
Information about NAT DNS mappings. |
Totally n NAT DNS mappings |
Total number of NAT DNS mappings. |
Domain name |
Domain name of the internal server. |
Global IP |
Public IP address of the internal server. · If Easy IP is configured, this field displays the IP address of the specified interface. · If you do not specify a public IP address, this field displays hyphens (---). |
Global port |
Public port number of the internal server. |
Protocol |
Protocol name and number of the internal server. |
Config status |
Status of the DNS mapping: Active or Inactive. |
Reasons why the DNS mapping does not take effect. This field is available when the Config status is Inactive. |
nat dns-map
display nat eim
Use display nat eim to display information about NAT Endpoint-Independent Mapping (EIM) entries.
display nat eim [ slot slot-number ]
context-admin
context-operator
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays EIM entry information for all member devices.
EIM entries are created when PAT operates in EIM mode. An EIM entry is a 3-tuple entry, and it records the mapping between a private address/port and a public address/port.
The EIM entry provides the following functions:
· The same EIM entry applies to subsequent connections initiated from the same source IP and port.
· The EIM entries allow reverse translation for connections initiated from external hosts to internal hosts.
# Display information about EIM entries for the specified slot.
<Sysname> display nat eim slot 1
Slot 1:
Local IP/port: 192.168.100.100/1024
Global IP/port: 200.100.1.100/2048
Local VPN: vpn1
Global VPN: vpn2
Protocol: TCP(6)
Local IP/port: 192.168.100.200/2048
Global IP/port: 200.100.1.200/4096
Protocol: UDP(17)
Total entries found: 2
Local VPN |
MPLS L3VPN instance to which the private IP address belongs. If the private IP address does not belong to any VPN instance, this field is not displayed. |
Global VPN |
MPLS L3VPN instance to which the public IP address belongs. If the public IP address does not belong to any VPN instance, this field is not displayed. |
Protocol |
Protocol name and number. |
Total entries found |
Total number of EIM entries. |
nat outbound
Use display nat global-policy to display configuration of the global NAT policy.
display nat global-policy [ rule-type { nat | nat64 | nat66 } ]
context-admin
context-operator
rule-type: Specifies a NAT rule type. If you do not specify this keyword, this command displays information about all types of NAT rules.
nat: Specifies NAT-type rules.
nat64: Specifies NAT64-type rules.
nat66: Specifies NAT66-type rules.
# Display configuration of all types of NAT rules in the global NAT policy.
<Sysname> display nat global-policy
Totally 8 NAT global-policy rules.
Rule name: rule1
Type : nat
Source-zone name : Trust
Destination-zone name : Local
SNAT action:
NO-PAT: Y
Reversible: N
Port-preserved: N
NAT counting : 0
Rule name: rule2
Type : nat
Description : second rule
SrcIP address : 10.0.0.1
SrcIP address : 10.0.0.2
DestIP address : 100.0.0.11
DestIP address : 100.0.0.12
Destination-zone name : local
SNAT action:
Easy-IP
NO-PAT: N
Reversible: N
Port-preserved: N
NAT counting : 0
Rule name: rule3
Type : nat
Description : third rule
Source-zone name : trust
Vrf : vpn1
SNAT action:
Ipv4 address: 20.0.0.1
Vrf: vpn2
DNAT action:
IPv4 address: 1.1.2.1
Port: 80
Vrf: vpn2
NAT counting : 0
Rule name: rule4
Type : nat
SrcIP subnet : 10.1.1.0 24
DestIP subnet : 100.1.3.0 24
SNAT action:
Subnet: 20.0.0.0 24
DNAT action:
Port: 80
NAT counting : 0
Rule name: rule5
Type : nat
Description : fifth rule
VRID: 1
SNAT action:
Object group: obj1
DNAT action:
NAT counting : 0
Rule name: 44_1
Type : nat
SrcIP address : 10.1.1.10
DestIP address : 10.1.1.100
SNAT action:
IPv4 address: 2.1.1.100
IPv4 VRRP VRID: 1
DNAT action:
IPv4 address: 2.1.1.15
IPv4 VRRP VRID: 2
NAT counting : 0
Rule name: 4to6_1
Type : nat64
SNAT action:
IPv6 address: 3003::100
IPv6 VRRP VRID: 1
DNAT action:
IPv6 address: 3003::15
IPv4 VRRP VRID: 2
NAT counting : 0
Rule name: 66_1
Type : nat66
SrcIPV6 address : 3001::10
SNAT action:
IPv6 address: 3003::800
IPv6 VRRP VRID: 1
NAT counting : 0
Configuration of the global NAT policy. |
Totally n NAT global-policy rules |
Total number of NAT rules in the policy. |
Rule name |
Type |
NAT rule type: · nat—NAT rule, which is used for translation between IPv4 addresses. · nat64—NAT64-type rule, which is used for translation between IPv4 addresses and IPv6 addresses. · nat66—NAT66-type rule, which is used for translation between IPv6 addresses or IPv6 address prefixes. |
Description of the NAT rule. |
SrcIP object group |
Source IP address object group in the NAT rule. |
SrcIP address |
IP address that the NAT rule uses to match packet source IP addresses. |
SrcIP subnet |
Subnet address that the NAT rule uses to match packet source IP addresses. |
DestIP object group |
Destination IP address object group in the NAT rule. |
DestIP address |
IP address that the NAT rule uses to match packet destination IP addresses. |
DestIP subnet |
Subnet address that the NAT rule uses to match packet destination IP addresses. |
Service object group |
Service object group in the NAT rule. |
Source-zone name |
Source security zone in the NAT rule. |
Destination-zone name |
Destination security zone in the NAT rule. |
Vrf |
VPN instance in the NAT rule. |
IPv4 VRRP VRID |
Virtual router ID (IPv4 VRRP group number) bound to the NAT rule. |
IPv6 VRRP VRID |
Virtual router ID (IPv6 VRRP group number) bound to the NAT rule. |
SNAT action |
Source address translation method in the NAT rule. |
NO-NAT |
No address translation. |
Address group ID |
ID of the NAT address group used in the NAT rule. If no NAT address group is specified, this field is not displayed. |
Name of the NAT address group used in the NAT rule. If no NAT address group is specified, this field is not displayed. |
Easy-IP |
Easy IP method used in the NAT rule. This field is not displayed if the Easy IP method is not specified. |
IPv4 address |
NAT IP address for source address translation. This field is not displayed if no translated source IP address is configured. |
IPv6 address |
NAT IPv6 address for source address translation. This field is not displayed if no translated source IPv6 address is configured. |
Subnet |
A range of NAT IP addresses for source address translation. This field is not displayed if no translated source subnet is configured. |
NO-PAT |
Whether NO-PAT or PAT is used: · Y—NO-PAT is used. · N—PAT is used. |
Reversible |
Whether reverse address translation is allowed: · Y—Reverse address translation is allowed. · N—Reverse address translation is not allowed. |
Prefix |
Prefix translation method used for source address translation in a NAT64-type rule: · nat64 v4tov6—Uses the NAT64 prefix to translate source IPv4 addresses to IPv6 addresses. · General v4tov6—Uses the general prefix to translate source IPv4 addresses to IPv6 addresses. · General v6tov4—Uses the general prefix to translate source IPv6 addresses to IPv4 addresses. This field is not displayed if the prefix method is not configured for source address translation. |
Port-preserved |
Whether to try to preserve the port numbers for PAT. · Y—Tries to preserve the port numbers. · N—Allows translating port numbers. |
NPTv6 |
IPv6 address prefix used for source IPv6 address translation in NPTv6 method. The format is translated-ipv6-prefix nptv6-prefix-length, where the translated-ipv6-prefix argument indicates the address prefix and the nptv6-prefix-length argument specifies the IPv6 address prefix length. This field is not displayed if the NPTv6 method is not configured for source IPv6 address translation. |
Vrf |
VPN instance to which the source IP address after translation belongs. |
DNAT action |
Destination IP address translation method of the NAT rule. |
IPv4 address |
NAT IPv4 address for destination IP address translation. |
IPv6 address |
NAT IPv6 address for destination IP address translation. |
Port |
Translated port number for destination IP address translation. |
Prefix |
Prefix translation method used for destination address translation in a NAT64-type rule: · nat64 v6tov4—Uses the NAT64 prefix to translate destination IPv6 addresses to IPv4 addresses. · General v4tov6—Uses the general prefix to translate destination IPv4 addresses to IPv6 addresses. · General v6tov4—Uses the general prefix to translate destination IPv6 addresses to IPv4 addresses. · IVI v4tov6—Uses the IVI prefix to translate IPv4 addresses to IPv6 addresses. This field is not displayed if the prefix method is not configured for destination address translation. |
NPTv6 |
IPv6 address prefix used for destination IPv6 address translation in NPTv6 method. The format is translated-ipv6-prefix nptv6-prefix-length, where the translated-ipv6-prefix argument indicates the address prefix and the nptv6-prefix-length argument specifies the IPv6 address prefix length. This field is not displayed if the NPTv6 method is not configured for source IPv6 address translation. |
Vrf |
VPN instance to which the destination IP address after translation belongs. |
NAT counting |
Number of times the NAT rule is matched. |
Config status |
Status of the global NAT policy: Active or Inactive. |
Reasons why the NAT rule does not take effect. This field is available when the Config status is Inactive. |
display nat inbound
Use display nat inbound to display inbound dynamic NAT configuration.
display nat inbound
context-admin
context-operator
# Display inbound dynamic NAT configuration.
<Sysname> display nat inbound
Totally 2 NAT inbound rules.
ACL: 2038
Address group ID: 2
VPN instance: vpn1
Rule name: abcd
Priority: 1000
NAT counting: 0
Address group ID: 1
Rule name: eif
Priority: 1001
NAT counting: 0
NAT inbound information |
Information about inbound dynamic NAT configuration. |
Totally n NAT inbound rules |
Total number of inbound dynamic NAT rules. |
Interface where the inbound dynamic NAT rule is configured. |
ACL |
ACL number or name. |
Address group ID |
ID of the NAT address group used by the inbound dynamic NAT rule. |
Add route |
Whether to add a route when a packet matches the inbound dynamic NAT rule: · Y—Adds a route. · N—Does not add a route. |
NO-PAT |
Reversible |
VPN instance |
MPLS L3VPN instance to which the NAT address group belongs. If the NAT address group does not belong to any VPN instance, the field is not displayed. |
Rule name |
Priority |
Description of the NAT rule. This field is not displayed if no description is configured for the rule. |
NAT counting |
Config status |
Status of the inbound dynamic NAT rule: Active or Inactive. |
Reasons why the inbound dynamic NAT rule does not take effect: This field is available when the Config status is Inactive. |
nat inbound
display nat log
Use display nat log to display NAT logging configuration.
display nat log
context-admin
context-operator
# Display NAT logging configuration.
<Sysname> display nat log
NAT logging:
Flow-end : Disabled
Alarm : Disabled
NAT logging |
NAT logging configuration. |
Log enable |
Enabling status of NAT logging. If an ACL is specified for NAT logging, this field also displays the ACL number or name. |
Flow-begin |
Enabling status of logging for NAT session establishment events. |
Flow-end |
Enabling status of logging for NAT session removal events. |
Flow-active |
Enabling status of logging for active NAT flows. If it is enabled, this field also displays the interval in minutes at which active flow logs are generated. |
Port-block-assign |
Enabling status of NAT444 user logging for port block assignment. |
Port-block-withdraw |
Enabling status of NAT444 user logging for port block withdrawal. |
Alarm |
Enabling status of logging for NAT444 alarms. |
NO-PAT IP usage |
Enabling status of logging for IP usage of NAT address groups when NO-PAT mode is used. If it is enabled, this field also displays IP usage for each configured NAT address group, in percentage. |
nat log enable
nat log flow-active
nat log flow-begin
nat log no-pat ip-usage
display nat no-pat
Use display nat no-pat command to display information about NAT NO-PAT entries.
display nat no-pat { ipv4 | ipv6 } [ slot slot-number ]
Default user roles
context-admin
context-operator
ipv4: Displays NO-PAT entry information for IPv4 NAT sessions.
ipv6: Displays NO-PAT entry information for IPv6 NAT sessions.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays NO-PAT entry information for all member devices.
A NO-PAT entry records the mapping between a private address and a public address.
The NO-PAT entry provides the following functions:
· The same entry applies to subsequent connections initiated from the same source IP address.
· The NO-PAT entries allow reverse translation for connections initiated from external hosts to internal hosts.
Outbound and inbound NO-PAT address translations create their own NO-PAT tables. These two types of tables are displayed separately.
# Display information about NO-PAT entries for IPv4 NAT sessions on the specified slot.
<Sysname> display nat no-pat ipv4 slot 1
Slot 1:
Global IPv4: 200.100.1.100
Local IPv4: 192.168.100.100
Global VPN: vpn2
Local VPN: vpn1
Reversible: N
Type : Inbound
Local IPv4: 192.168.100.200
Global IPv4: 200.100.1.200
Reversible: Y
Type : Outbound
Total Ipv4 entries found: 2
# Display information about NO-PAT entries for IPv6 NAT sessions on all cards.
<Sysname> display nat no-pat ipv6
Slot 0:
Global IPv6: FD01:203:405::1
Local IPv6: 2001:DB8:1::100
Global VPN: vpn2
Local VPN: vpn1
Reversible: N
Type : Inbound
Total Ipv6 entries found: 1
# Display information about NO-PAT entries for IPv6 NAT sessions on the specified slot.
<Sysname> display nat no-pat slot 1 ipv6
Slot 1:
Global VPN: vpn2
Local VPN: vpn1
Reversible: N
Type : Inbound
Table 8 Command output
Global IPv4 |
Public IPv4 address. |
Local IPv4 |
Private IPv4 address. |
Global IPv6 |
Public IPv6 address. |
Local IPv6 |
Private IPv6 address. |
Local VPN |
Global VPN |
Reversible |
Type |
Type of the NO-PAT entry: · Inbound—A NO-PAT entry created during inbound dynamic NAT. · Outbound—A NO-PAT entry created during outbound dynamic NAT. |
Total Ipv4 entries found |
Total number of IPv4 NO-PAT entries. |
Total Ipv6 entries found |
Total number of IPv6 NO-PAT entries. |
nat inbound
nat outbound
display nat no-pat ip-usage
Use display nat no-pat ip-usage to display IP usage of NAT address groups or object groups in NO-PAT mode.
display nat no-pat ip-usage [ address-group { group-id | name group-name } | object-group object-group-name ] [ slot slot-number ]
Predefines user roles
context-admin
context-operator
address-group: Displays the IP usage of the specified NAT address group. If you do not specify this keyword, the command displays the IP usage of each NAT address group.
group-id: Specifies the ID of a NAT address group. The value range is 0 to 65535.
name group-name: Specifies the name of a NAT address group, a case-insensitive string of 1 to 63 characters.
object-group object-group-name: Specifies the IP usage of the specified object group. The name is a case-insensitive string of 1 to 63 characters.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the IP usage of NAT address groups or object groups in NO-PAT mode for all member devices.
# Display IP usage of address resources for all types in NO-PAT mode for the specified slot.
<Sysname> display nat no-pat ip-usage slot 1
CPU 0 on slot 1:
Totally 2 pieces of information about address usage.
Address group 0:
Total IP addresses :10
Used IP addresses :9
Unused IP addresses :1
NO-PAT IP usage :90% (channel 0)
Object group name: obj1
Used IP addresses :0
Unused IP addresses :10
NO-PAT IP usage :0%
Table 9 Command output
Address group |
NAT address group ID. |
NO-PAT IP usage |
IP usage of the NAT address group or object group in NO-PAT mode. |
channel |
Field-programmable gate array (FPGA) ID. |
nat log no-pat ip-usage threshold
display nat outbound
Use display nat outbound to display outbound dynamic NAT configuration.
context-admin
context-operator
# Display outbound dynamic NAT configuration.
<Sysname> display nat outbound
ACL: 2036
Address group ID: 1
Rule name: abefg
Priority: 1000
NAT counting: 0
ACL: 2037
Address group ID: 2
Rule name: cdefg
Priority: 1001
NAT counting: 0
DS-Lite B4 ACL: 2100
Address group ID: 2
Port-preserved: N NO-PAT: N Reversible: N
Priority: 0
NAT counting: 0
Information about outbound dynamic NAT configuration. |
Totally n NAT outbound rules |
Total number of outbound dynamic NAT rules. |
Interface where the outbound dynamic NAT rule is configured. |
ACL |
IPv4 ACL number or name. If no IPv4 ACL is specified for outbound dynamic NAT rule, this field displays hyphens (---). |
DS-Lite B4 ACL |
Number or name of the IPv6 ACL used by DS-Lite B4 address translation. |
Address group ID |
ID of the address group used by the outbound dynamic NAT rule. If no address group is specified, the field displays hyphens (---). |
Port-preserved |
NO-PAT |
Whether NO-PAT is used: · Y—NO-PAT is used. · N—PAT is used. |
Reversible |
VPN instance |
Rule name |
Priority |
Configuration mode |
Configuration method of the device. · This field displays NETCONF (action) if the device is configured by using a NETCONF action operation. · This field is not displayed if the device is configured by using other methods. |
NAT counting |
Config status |
Status of the outbound dynamic NAT rule: Active or Inactive. |
Reasons why the outbound dynamic NAT rule does not take effect. This field is available when the Config status is Inactive. |
nat outbound
display nat outbound port-block-group
Use display nat outbound port-block-group to display static outbound port block mapping rules for NAT444.
context-admin
context-operator
# Display static outbound port block mapping rules for NAT444.
<Sysname> display nat outbound port-block-group
port-block-group: 2
Rule name: abcdefg
NAT counting: 0
Rule name: abcfg
NAT counting: 0
Information about static outbound port block mapping rules. |
Totally n outbound port block group items |
Total number of static outbound port block mapping rules. |
Interface where the static outbound port block mapping rules configured. |
port-block-group |
ID of the port block group. |
Rule name |
Name of the static outbound port block mapping rule |
NAT counting |
Number of times the mapping rule is matched. |
Config status |
Status of the port block mapping rule: Active or Inactive. |
Reasons why the port block mapping rule does not take effect. This field is available when the Config status is Inactive. |
display nat periodic-statistics
Use display nat periodic-statistics to display periodic NAT statistics.
display nat periodic-statistics { address-group [ group-id | name group-name ] | ip global-ip } [ slot slot-number ]
The following compatibility matrixes show the support of hardware platforms for this command:
F1000 series |
Models |
Command compatibility |
F1000-X-G5 series |
F1000-A-G5, F1000-S-G5 |
No |
F1000-E-G5, F1000-H-G5, F1000-C-G5, F1000-C-G5-LI |
Yes |
F1000-X-G3 series |
F1000-A-G3, F1000-C-G3, F1000-E-G3, F1000-S-G3 |
Yes |
F1000-X-G2 series |
F1000-A-G2, F1000-C-G2, F1000-E-G2, F1000-S-G2 |
Yes |
F1000-9X0-AI series |
F1000-9380-AI, F1000-9370-AI |
No |
F1000-9390-AI, F1000-9385-AI, F1000-9360-AI, F1000-9350-AI, F1000-9330-AI, F1000-9320-AI, F1000-910-AI, F1000-905-AI, F1000-990-AI, F1000-980-AI, F1000-970-AI, F1000-960-AI, F1000-950-AI, F1000-930-AI, F1000-920-AI |
Yes |
F1000-C83X0 series |
F1000-C8395, F1000-C8370, F1000-C8360, F1000-C8350, F1000-C8330 |
Yes |
F1000-C8390, F1000-C8385, F1000-C8380 |
No |
F1000-C81X0 series |
F1000-C8180, F1000-C8170, F1000-C8160, F1000-C8110, F1000-C8150, F1000-C8130, F1000-C8120 |
Yes |
F1000-7X0-HI series |
F1000-770-HI |
No |
F1000-750-HI, F1000-740-HI, F1000-730-HI, F1000-720-HI, F1000-710-HI |
Yes |
F1000-C-X series |
F1000-C-XI |
No |
F1000-C-EI, F1000-C-HI, F1000-E-XI |
Yes |
F1000-V series |
F1000-E-VG, F1000-S-VG |
Yes |
SecBlade IV |
LSPM6FWD8, LSQM2FWDSC8 |
No |
F100 series |
Models |
F100-X-G5 series |
F100-A-G5, F100-C-G5, F100-E-G5, F100-M-G5, F100-S-G5 |
Yes |
F100-X-G3 series |
F100-A-G3, F100-C-G3, F100-E-G3, F100-M-G3, F100-S-G3 |
Yes |
F100-X-G2 series |
F100-A-G2, F100-C-G2, F100-E-G2, F100-M-G2, F100-S-G2 |
Yes |
F100-WiNet series |
F100-A80-WiNet, F100-C80-WiNet, F100-C60-WiNet, F100-S80-WiNet, F100-A81-WiNet, F100-A91-WiNet, F100-C50-WiNet |
Yes |
F100-C-A series |
F100-C-A6, F100-C-A5, F100-C-A3, F100-C-A2, F100-C-A1, F100-C-A6-WL, F100-C-A5-W, F100-C-A3-W |
Yes |
F100-X-XI series |
F100-A-EI, F100-A-HI, F100-A-SI, F100-C-EI, F100-C-HI, F100-C-XI, F100-E-EI, F100-S-HI, F100-S-XI |
Yes |
context-admin
context-operator
address-group: Displays periodic NAT statistics for the specified NAT address group.
name group-name: Specifies the name of a NAT address group. The name is a case-insensitive string of 1 to 63 characters.
ip global-ip: Displays periodic NAT statistics for the specified IP address. The global-ip argument specifies an IP address.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays periodic NAT statistics for all member devices.
If you do not specify the group-id argument or the name keyword, this command displays periodic NAT statistics for all NAT address groups.
# Display periodic NAT statistics for address groups for slot 1.
<Sysname> display nat periodic-statistics address-group slot 1
Slot 1:
Totally 1 NAT address groups.
Address group ID: 1 Address group name: abc
NAT sessions : 10
NAT port-block assign failures : 0
# Display periodic NAT statistics for IP address 202.38.6.12 for slot 1.
<Sysname> display nat periodic-statistics ip 202.38.6.12 slot 1
Slot 1:
Global IP: 202.38.6.12
NAT sessions : 10
Table 12 Command output
Address group ID |
ID of the NAT address group. If no address group is specified, this field displays hyphens (---). |
Global IP |
IP address used for address translation. If the address is not in the specified address group, this field displays hyphens (---). |
NAT sessions |
Number of NAT sessions. |
NAT port-block assign failures |
Number of port block assignment failures. |
nat periodic-statistics enable
nat periodic-statistics interval
reset nat periodic-statistics
display nat policy
Use display nat policy to display the NAT policy configuration.
display nat policy
F1000 series |
Models |
F1000-X-G5 series |
F1000-A-G5, F1000-S-G5, F1000-C-G5, F1000-C-G5-LI |
No |
F1000-E-G5, F1000-H-G5 |
Yes |
F1000-X-G3 series |
Yes |
F1000-X-G2 series |
Yes |
F1000-9390-AI, F1000-9385-AI, F1000-990-AI, F1000-980-AI, F1000-970-AI, F1000-960-AI, F1000-950-AI, F1000-930-AI, F1000-920-AI, F1000-910-AI, F1000-905-AI |
Yes |
F1000-9380-AI, F1000-9370-AI, F1000-9360-AI, F1000-9350-AI, F1000-9330-AI, F1000-9320-AI |
No |
F1000-C8395 |
Yes |
F1000-C8390, F1000-C8385, F1000-C8380, F1000-C8370, F1000-C8360, F1000-C8350, F1000-C8330 |
Yes |
Yes |
F1000-770-HI, F1000-750-HI, F1000-740-HI, F1000-730-HI, F1000-720-HI, F1000-710-HI |
Yes |
F1000-C-X series |
F1000-C-EI, F1000-C-HI, F1000-C-XI, F1000-E-XI |
Yes |
F1000-V series |
Yes |
SecBlade IV |
No |
F100 series |
Models |
F100-X-G5 series |
Yes |
F100-X-G3 series |
F100-A-G3, F100-C-G3, F100-E-G3 , F100-M-G3, F100-S-G3 |
Yes |
F100-X-G2 series |
Yes |
F100-WiNet series |
F100-A80-WiNet, F100-C80-WiNet, F100-C60-WiNet, F100-C50-WiNet, F100-S80-WiNet, F100-A81-WiNet, F100-A91-WiNet |
Yes |
F100-C-A series |
Yes |
F100-X-XI series |
Yes |
context-admin
context-operator
# Display the NAT policy configuration.
<Sysname> display nat policy
Rule name: rule1
Outbound-interface : GigabitEthernet1/0/2
Action:
NO-PAT: Y
Reversible: N
Port-preserved: N
NAT counting : 0
Information about the NAT policy configuration. |
Totally n NAT policy rules |
Total number of NAT rules in the NAT policy. |
Rule name |
NAT rule name. |
Outbound-interface |
Direction of the traffic that the NAT rule applies. |
Action |
Address translation method in the NAT rule. |
Easy-IP |
Easy IP method. |
NO-NAT |
Address translation is disabled. |
Address group ID |
ID of the NAT address group in the NAT rule. If no NAT address group ID is configured, this field is not displayed. |
Reversible |
Whether reverse address translation is allowed. · Y—Reverse address translation is allowed. · N—Reverse address translation is not allowed. |
Port-preserved |
Whether to try to preserve the port numbers for PAT: · Y—Tries to preserve the port numbers. · N—Allows translating port numbers. |
NAT counting |
Number of times the rule is matched. |
Config status |
Status of the NAT policy configuration: Active or Inactive. |
Reasons why the NAT policy does not take effect. This field is available when the Config status is Inactive. |
display nat port-block
Use display nat port-block to display NAT port block mappings.
display nat port-block { dynamic [ address-group { group-id | name group-name } ] [ ds-lite-b4 ] | static [ port-block-group group-id ] } [ slot slot-number ]
context-admin
context-operator
dynamic: Displays dynamic port block mappings.
address-group: Displays port block mappings for the specified address group. If you do not specify a NAT address group, this command displays port block mappings for all address groups.
group-id: Specifies the ID of the address group. The value range for this argument is 0 to 65535.
name group-name: Specifies the name of the address group. The name is a case-insensitive string of 1 to 63 characters.
ds-lite-b4: Displays port block mappings for DS-Lite B4 address translation.
static: Displays static port block mappings.
port-block-group group-id: Displays port block mappings for the specified port block group. The group-id argument specifies the ID of the port block group. The value range for the group-id argument is 0 to 65535. If you do not specify a port block group, this command displays port block mappings for all port block groups.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays port block mappings for all member devices.
# Display static port block mappings for the specified slot.
<Sysname> display nat port-block static slot 1
Slot 1:
Local VPN Local IP Global IP Port block Connections
--- 100.100.100.111 202.202.100.101 10001-10256 0
--- 100.100.100.112 202.202.100.101 10257-10512 0
--- 100.100.100.113 202.202.100.101 10513-10768 0
--- 100.100.100.113 202.202.100.101 10769-11024 0
Total entries found: 4
# Display dynamic port block mappings.
<Sysname> display nat port-block dynamic slot 1
Slot 1:
--- 101.1.1.12 192.168.135.201 10001-11024 1
Total entries found: 1
# Display port block mappings for DS-Lite B4 address translation.
<Sysname> display nat port-block dynamic ds-lite-b4 slot 1
Slot 1:
Local VPN DS-Lite B4 addr Global IP Port block Connections
--- 2000::2 192.168.135.201 10001-11024 1
Table 14 Command output
Local VPN |
MPLS L3VPN instance to which the private IP address belongs. If the private IP address does not belong to any VPN instance, this field displays hyphens (---). |
Local IP |
Private IP address. |
DS-Lite B4 addr |
IPv6 address of the DS-Lite B4 element. |
Global IP |
Public IP address. |
Port block |
Port block defined by a start port number and an end port number. |
Connections |
Number of connections established by using the ports in the port block. |
display nat port-block-group
Use display nat port-block-group to display NAT port block group configuration.
display nat port-block-group [ group-id ]
context-admin
context-operator
group-id: Specifies the ID of a NAT port block group. The value range for this argument is 0 to 65535. If you do not specify this argument, the command displays configuration of all NAT port block groups.
# Display configuration of all NAT port block groups.
<Sysname> display nat port-block-group
Port block group 1:
VRID : 2
Port range: 1-65535
Block size: 256
Port block group 2:
Block size: 500
Port block group 3:
Port range: 1-65535
Block size: 256
# Display information about NAT port block group 1.
<Sysname> display nat port-block-group 1
Port block group 1:
VRID : 2
Port range: 1-65535
Block size: 256
Information about the port block group configuration. |
Totally n NAT port block groups |
Total number of port block groups. |
Port block group |
VRID |
Port range |
Port range for the public IP addresses. |
Block size |
Number of ports in a port block. |
Local IP address information |
Information about the private IP addresses. |
Global IP pool information |
Information about the public IP addresses. |
Start address |
Start IP address of a private or public IP address range. If no start IP address is specified for the address range, this field displays hyphens (---). |
End address |
End IP address of a private or public IP address range. If no end IP address is specified for the address range, this field displays hyphens (---). |
VPN instance |
MPLS L3VPN instance to which the private IP address range belongs. If no VPN instance is specified for the private address range, this field displays hyphens (---). |
display nat port-block-usage
Use display nat port-block-usage to display the port block usage for address groups.
display nat port-block-usage [ address-group group-id ] [ slot slot-number ]
context-admin
context-operator
address-group group-id: Specifies the ID of an address group. The value range for the group-id argument is 0 to 65535. If you do not specify an address group, this command displays the port block usage for all address groups.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the port block usage for all member devices.
# Display the port block usage for address groups for slot 1.
<Sysname> display nat port-block-usage slot 1
Slot 1:
Address group 0 on channel 0:
Total port block entries :10
Active port block entries:9
Current port block usage :90%
Total NAT address groups found: 1
Table 16 Command output
Address group |
channel |
Total port block entries |
Total number of port blocks in the address group. |
Active port block entries |
Total number of assigned port blocks in the address group. |
Current port block usage |
Port block usage in the address group. |
Total NAT address groups found |
Total number of address groups. |
display nat probe address-group
Use display nat probe address-group to display NAT address group probe information.
display nat probe address-group [ group-id ]
context-admin
context-operator
group-id: Specifies the address group ID. The value range for this argument is 0 to 65535. If you do not specify this argument, the command displays probe information for all address groups.
The excluded IP addresses displayed by this command only refers to those detected by the address group probe. The excluded IP addresses configured by the exclude-ip command are not included.
# Display NAT address group probe information
<Sysname> display nat probe address-group
Address group ID: 1
Address-group name: dududu1
Address-group probe status: Partial available
Detected IP count: 5
Excluded IP count: 4
IP address Excluded Excluded time
1.1.1.1 YES 2017/12/26 09:30:39
1.1.1.2 YES 2017/12/26 09:30:39
1.1.1.3 YES 2017/12/26 09:30:39
1.1.1.4 YES 2017/12/26 09:30:39
1.1.1.5 NO ----
Address group ID: 2
Address-group name: dududu2
2.1.1.1 YES 2017/12/26 09:31:39
2.1.1.2 YES 2017/12/26 09:31:39
2.1.1.3 YES 2017/12/26 09:31:39
2.1.1.4 YES 2017/12/26 09:31:39
2.1.1.5 NO ----
# Display NAT address group probe information for slot 1.
<Sysname> display nat probe address-group 1
Address group ID: 1
1.1.1.5 NO ----
Table 17 Command output
Address group ID |
Name of the address group. If the address group does not have a name, this field is not displayed. |
Address-group probe status |
Status of the address group status: · Inactive—The probe is not enabled. · In progress—The probe is in progress. · All available—All IP addresses in the group are available. · Partial available—Partial IP addresses are available. · None available—None of the IP addresses are available. |
Detected IP count |
Number of IP addresses that have been detected. |
Excluded IP count |
Number of IP addresses that are excluded from address translation. |
IP address |
IP addresses in the NAT address group. |
Excluded |
Whether the IP address is excluded from address translation: · YES—The IP address is excluded from address translation. · NO—The IP address is not excluded and can be used for address translation. |
Excluded time |
Time when the IP address is excluded from address translation. |
exclude-ip
probe
display nat server
Use display nat server to display NAT server mappings.
display nat server
context-admin
context-operator
# Display NAT server mappings.
<Sysname> display nat server
Rule name: aaa
Interface: Vlan-interface1
DestIP Object group: a1
NAT counting : 0
VRID : 1
Global ACL : 2000
Rule name : cdefgab
Priority : 1000
NAT counting : 0
Protocol: 6(TCP)
Rule name : ace
NAT counting : 0
Protocol: 6(TCP)
Global VPN : vpn1
Local VPN : vpn3
Rule name : abcdef
NAT counting : 0
Rule name : cdefg
NAT counting : 0
Protocol: 17(UDP)
1.1.1.1/21 (Connections: 10)
192.168.100.200/80 (Connections: 20)
Rule name : white
NAT counting : 0
NAT internal server information (object-group) |
Information about the object group-based NAT server mappings. |
Totally n object-group-based NAT server rules |
Total number of object group-based NAT server mappings. |
Rule name |
Name of the NAT server mapping. |
Priority |
Priority of the NAT server mapping. |
Information about NAT server mapping. |
Interface where the NAT server mapping is configured. |
Protocol |
Protocol number and name of the internal server. |
VRID |
Global IP/port |
Public IP address and port number of the internal server. · Global IP—A single IP address or an IP address range. If you use Easy IP, this field displays the IP address of the specified interface. If you do not specify an address for the interface, the Global IP field displays hyphens (---). · port—A single port number or a port number range. If no port number is in the specified protocol, the port field displays hyphens (---). |
Local IP/port |
For common NAT server mappings and object group-based NAT server mappings, this field displays the private IP address and port number of the internal server. · Local IP—A single IP address or an IP address range. · port—A single port number or a port number range. If no port number is in the specified protocol, the port field displays hyphens (---). For a load sharing NAT server mapping, this field displays the internal server group ID, IP address, port number, and number of connections of each member. |
DestIP Object group |
Destination IP object group used by the NAT server mapping. |
Service Object group |
Service object group used by the NAT server mapping. |
Global VPN |
MPLS L3VPN instance to which the public IP addresses belong. If the public IP addresses do not belong to any VPN instance, this field is not displayed. |
Local VPN |
MPLS L3VPN instance to which the private IP addresses belong. If the private IP addresses do not belong to any VPN instance, this field is not displayed. |
ACL |
ACL number or name. If no ACL is specified, this field is not displayed. |
Rule name |
NAT counting |
Number of times the NAT server mapping is matched. |
Description of the NAT server mapping. This field is not displayed if no description is configured for the mapping. |
Config status |
Status of the NAT server mapping: Active or Inactive. |
Reasons why the NAT server mapping does not take effect. This field is available when the Config status is Inactive. |
nat server
display nat server-group
Use display nat server-group to display internal server group configuration.
display nat server-group [ group-id ]
context-admin
context-operator
group-id: Specifies the ID of the internal server group. The value range for this argument is 0 to 65535. If you do not specify this argument, the command displays the configuration of all internal server groups.
# Display the configuration of all internal server groups.
<Sysname> display nat server-group
192.168.0.27 23 500
2 --- --- ---
# Display the configuration of internal server group 1.
<Sysname> display nat server-group 1
192.168.0.27 23 500
Information about the NAT server group configuration. |
Totally n NAT server groups |
Total number of NAT server groups. |
Group Number |
ID of the internal server group. |
Inside IP |
Private IP address of a server in the internal server group. If no address is specified, this field displays hyphens (---). |
Port |
Private port number of a server in the internal server group. If no port number is specified, this field displays hyphens (---). |
Weight |
Weight of a server in the internal server group. If no weight value is specified, this field displays hyphens (---). |
nat server-group
display nat session
Use display nat session to display NAT sessions.
display nat session [ [ responder ] { source-ip source-ip | destination-ip destination-ip } * [ vpn-instance vpn-instance-name ] ] [ slot slot-number ] [ brief | verbose ]
context-admin
context-operator
responder: Displays NAT sessions by responder. If you do not specify this keyword, this command displays NAT sessions by initiator.
source-ip source-ip: Displays NAT sessions for the source IP address specified by the source-ip argument. The IP address must be the source IP address of the packet that triggers the session establishment.
destination-ip destination-ip: Displays NAT sessions for the destination IP address specified by the destination-ip argument. The IP address must be the destination IP address of the packet that triggers the session establishment.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The VPN must be the VPN inside the packet. If you do not specify a VPN instance, this command displays NAT sessions that do not belong to any VPN instance.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays NAT sessions for all member devices.
brief: Displays brief information about NAT sessions.
verbose: Displays detailed information about NAT sessions.
If you do not specify any parameters, this command displays detailed information about session initiators of all NAT sessions.
# Display detailed information about NAT sessions for the specified slot.
<Sysname> display nat session slot 1 verbose
Slot 1:
Initiator:
Source IP/port: 192.168.1.18/1877
Destination IP/port: 192.168.1.55/22
DS-Lite tunnel peer: -
Protocol: TCP(6)
Inbound interface: GigabitEthernet1/0/1
Source security zone: SrcZone
Responder:
Source IP/port: 192.168.1.55/22
Destination IP/port: 192.168.1.10/1877
Protocol: TCP(6)
Inbound interface: GigabitEthernet1/0/2
Source security zone: DestZone
State: TCP_SYN_SENT
Application: SSH
Rule ID: -/-/-
Rule name:
Start time: 2011-07-29 19:12:36 TTL: 28s
Initiator->Responder: 1 packets 48 bytes
Responder->Initiator: 0 packets 0 bytes
Total sessions found: 1
# Display brief information about NAT sessions for the specified slot.
<Sysname> display nat session brief
Slot 1:
Protocol Source IP/port Destination IP/port Global IP/port
TCP 2.1.1.20/1351 10.1.1.110/21 2.1.1.50/1025
Table 20 Command output
Initiator |
Session information about the initiator. |
Responder |
Session information about the responder. |
Source IP/port |
Source IP address and port number. |
Destination IP/port |
Destination IP address and port number. |
Global IP/port |
Public IP address and port number. |
DS-Lite tunnel peer |
Destination address of the DS-Lite tunnel interface. If the session does not belong to any DS-Lite tunnel, this field displays a hyphen (-). |
VPN instance/VLAN ID/Inline ID |
The fields identify the following information: · VPN instance—MPLS L3VPN instance to which the session belongs. · VLAN ID—VLAN ID to which the session belongs for Layer 2 forwarding. · Inline ID——INLINE to which the session belongs for Layer 2 forwarding. If no VPN instance, VLAN ID, or inline ID is specified, a hyphen (-) is displayed for the related field. |
Protocol |
Transport layer protocol type: DCCP, ICMP, Raw IP, SCTP, TCP, UDP, or UDP-Lite. |
Inbound interface |
Input interface. |
Source security zone |
Security zone to which the input interface belongs. If the input interface does not belong to any security zone, this field displays a hyphen (-). |
State |
NAT session status. |
Application |
Application layer protocol type, such as FTP and DNS. This field displays OTHER for the protocol types identified by non-well-known ports. |
Rule ID |
ID of the security policy rule. |
Rule name |
Name of the security policy rule. |
Start time |
Time when the session starts. |
TTL |
Remaining NAT session lifetime in seconds. |
Initiator->Responder |
Number of packets and packet bytes from the initiator to the responder. |
Responder->Initiator |
Number of packets and packet bytes from the responder to the initiator. |
Total sessions found |
Total number of sessions. |
reset nat session
display nat static
Use display nat static to display static NAT mappings.
display nat static
context-admin
context-operator
# Display static NAT mappings.
<Sysname> display nat static
Net-to-net:
VRID : 1
Global IP : 1.1.1.1 - 1.1.1.255
Local IP : 2.2.2.0
Global VPN : vpn2
Local VPN : vpn1
ACL : 2000
Reversible : Y
Rule name : adefg
Priority : 1000
NAT counting : 0
IP-to-IP:
VRID : 1
Global IP : 5.5.5.5
Local IP : 4.4.4.4
ACL : 2001
Reversible : Y
Rule name : abefg
Priority : 1000
NAT counting : 0
Net-to-net:
Global IP : 2.2.2.0
ACL : 2000
Reversible : Y
Rule name : abcd
Priority : 1000
NAT counting : 0
IP-to-IP:
Local IP : 4.4.4.4
Global IP : 5.5.5.5
ACL: : 2000
Rule name : defg
Priority : 1000
NAT counting : 0
Reversible : Y
Totally 1 interfaces enabled with static NAT.
Information about static NAT mapping configuration. |
Totally n inbound static NAT mappings |
Total number of inbound static NAT mappings. |
Totally n outbound static NAT mappings |
Total number of outbound static NAT mappings. |
Net-to-net |
Net-to-net static NAT mapping. |
IP-to-IP |
One-to-one static NAT mapping. |
Local IP |
Private IP address or address range. |
Global IP |
Public IP address or address range. |
Netmask |
Network mask. |
Local VPN |
Global VPN |
ACL |
Reversible |
Whether reverse address translation is allowed. If reverse address translation is allowed, this field displays Y. If reverse address translation is not allowed, this field is not displayed. |
Interfaces enabled with static NAT |
Interfaces on which static NAT is enabled. |
Totally n interfaces enabled with static NAT |
Total number of interfaces where static NAT is enabled. |
Interface on which static NAT is enabled. |
Rule name |
Priority |
VRID |
NAT counting |
Config status |
Status of the static NAT mapping: Active or Inactive. |
Reasons why the static NAT mapping does not take effect. This field is available when the Config status is Inactive. |
nat static enable
nat static inbound
nat static inbound net-to-net
nat static inbound object-group
nat static outbound
nat static outbound net-to-net
nat static outbound object-group
display nat statistics
Use display nat statistics to display NAT statistics.
display nat statistics [ summary ] [ slot slot-number ]
context-admin
context-operator
summary: Displays NAT statistics summary. If you do not specify this keyword, this command displays detailed NAT statistics.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays NAT statistics for all member devices.
# Display detailed information about NAT statistics.
<Sysname> display nat statistics
Slot 1:
Total session entries: 100
Session creation rate: 0
Total EIM entries: 1
Total inbound NO-PAT entries: 0
Total outbound NO-PAT entries: 0
Total static port block entries: 10
Total dynamic port block entries: 15
Active static port block entries: 0
Active dynamic port block entries: 0
Table 22 Command output
Total session entries |
Number of NAT session entries. |
Session creation rate |
Number of NAT sessions created per second. |
Total EIM entries |
Total inbound NO-PAT entries |
Total number of inbound NO-PAT entries. |
Total outbound NO-PAT entries |
Total number of outbound NO-PAT entries. |
Total static port block entries |
Total number of static NAT444 mappings. |
Total dynamic port block entries |
Total number of dynamic port block mappings that can be created. It equals the number of port blocks for dynamic assignment, including the assigned and unassigned port blocks. |
Active static port block entries |
Number of static port block mappings that are in use. |
Active dynamic port block entries |
Number of dynamic port block mappings that have been created. It equals the number of dynamically assigned port blocks. |
# Display NAT statistics summary.
<Sysname> display nat statistics summary
EIM: Total EIM entries.
SPB: Total static port block entries.
DPB: Total dynamic port block entries.
ASPB: Active static port block entries.
ADPB: Active dynamic port block entries.
Slot Sessions EIM SPB DPB ASPB ADPB
2 0 0 0 1572720 0 0
Table 23 Command output
Sessions |
EIM |
Number of EIM entries. |
SPB |
Number of static NAT444 mappings. |
DPB |
Number of dynamic port block mappings that can be created. It equals the number of port blocks for dynamic assignment, including the assigned and unassigned port blocks. |
ASPB |
Number of static port block mappings in use. |
ADPB |
exclude-ip
Use exclude-ip to exclude IP addresses from being used in address translation.
Use undo exclude-ip to allow the IP addresses to be used in address translation.
exclude-ip start-address end-address
undo exclude-ip start-address end-address
All IP addresses in the NAT address group can be used as the NAT addresses.
NAT address group view
context-admin
start-address end-address: Specifies the start and end IP addresses of the address range. The end address must not be lower than the start address. If they are the same, you specify only one IP address.
If some IP addresses in a NAT address group cannot be used for address translation, you can use this command to exclude them.
You can configure this command multiple times to specify a maximum of 100 IP address ranges excluded from address translation. No address ranges can overlap. The start IP address and the end IP address in an excluded range must be in the range configured in the address start-address end-address command. Each excluded IP address range can contain a maximum of 4096 IP addresses.
# Exclude IP addresses 10.1.1.2, 10.1.1.3 to 10.1.1.5 in NAT address group from being used in address translation.
[Sysname] nat address-group 2
[Sysname-address-group-2] address 10.1.1.1 10.1.1.15
[Sysname-address-group-2] exclude-ip 10.1.1.2 10.1.1.2
[Sysname-address-group-2] exclude-ip 10.1.1.3 10.1.1.5
address
global-ip-pool
Use global-ip-pool to add a public IP address range to a NAT port block group.
Use undo global-ip-pool to remove a public IP address range from a NAT port block group.
global-ip-pool start-address end-address
undo global-ip-pool start-address
No public IP address ranges exist.
NAT port block group view
context-admin
start-address end-address: Specifies the start IP address and end IP address of a public IP address range. The end IP address cannot be lower than the start IP address. If the start and end IP addresses are the same, only one public IP address is specified.
A static port block mapping maps a public IP address to multiple private IP addresses and assigns a unique port block to each private IP address. The number of port blocks that a public IP address can assign is determined by dividing the number of ports in the port range by the port block size.
Every time you execute this command, an address range can contain a maximum of 256 public IP addresses. All public IP address ranges in one port block group cannot overlap.
Public IP address ranges in different port block groups can overlap. The port ranges for overlapped public IP address ranges cannot overlap.
# Add a public IP address range to the port block group 1. The public IP address range consists of IP addresses from 202.10.1.1 to 202.10.1.10.
[Sysname] nat port-block-group 1
[Sysname-port-block-group-1] global-ip-pool 202.10.1.1 202.10.1.10
inside ip
Use inside ip to add a server to an internal server group.
Use undo inside ip to remove a server from an internal server group.
inside ip inside-ip port port-number [ weight weight-value ]
undo inside ip inside-ip port port-number
An internal server group has no server members.
Internal server group view
context-admin
inside-ip: Specifies the IP address of an internal server.
port port-number: Specifies the port number of an internal server, in the range of 1 to 65535, excluding FTP port 20.
weight weight-value: Specifies the weight of the internal server. The value range is 1 to 1000, and the default value is 100.
An internal server with a larger weight receives a larger percentage of connections in the internal server group.
# Add a server with IP address 10.1.1.2 and port number 30 to internal server group 1.
[Sysname] nat server-group 1
[Sysname-nat-server-group-1] inside ip 10.1.1.2 port 30
nat server-group
local-ip-address
Use local-ip-address to add a private IP address range to a NAT port block group.
Use undo local-ip-address to remove a private IP address range from a NAT port block group.
local-ip-address start-address end-address [ vpn-instance vpn-instance-name ]
undo local-ip-address start-address end-address [ vpn-instance vpn-instance-name ]
No private IP address ranges exist in a NAT port block group.
context-admin
start-address end-address: Specifies the start IP address and end IP address of a private IP address range. The end IP address cannot be lower than the start IP address. If the start and end IP addresses are the same, only one private IP address is specified.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the private IP address range belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the private IP address range does not belong to any VPN instance, do not specify this option.
A static port block mapping maps one public IP address to multiple private IP addresses and assigns a unique port block to each private IP address.
When you add multiple private IP address ranges to the same port block group, follow these restrictions:
· The private IP address ranges in the same VPN instance cannot overlap.
· The private IP address ranges that do not belong to any VPN instances cannot overlap.
In a NAT port block group, the number of private IP addresses cannot be larger than the number of assignable port blocks. Otherwise, some private IP addresses cannot obtain port blocks. The number of port blocks that a public IP address can assign is determined by dividing the number of ports in the port range by the port block size.
# Add a private IP address range to port block group 1. The private IP address range consists of IP addresses from 172.16.1.1 to 172.16.1.255.
[Sysname-port-block-group-1] local-ip-address 172.16.1.1 172.16.1.255
nat address-group
Use nat address-group to create a NAT address group and enter its view, or enter the view of an existing NAT address group.
Use undo nat address-group to delete a NAT address group.
nat address-group group-id [ name group-name ]
undo nat address-group group-id
No NAT address groups exist.
context-admin
group-id: Specifies the ID of a NAT address group. The value range for this argument is 0 to 65535.
name group-name: Assigns a name to the NAT address group. The group-name argument is a case-sensitive string of 1 to 63 characters.
A NAT address group is a set of address ranges. Use the address command to add an address range to a NAT address group. Dynamic NAT translates the source IP address of a packet into an IP address in the address group.
# Create a NAT address group numbered 1 and named abc.
[Sysname] nat address-group 1 name abc
address
display nat address-group
display nat all
nat inbound
nat outbound
nat alg
Use nat alg to enable NAT ALG for the specified or all supported protocols.
Use undo nat alg to disable NAT ALG for the specified or all supported protocols.
nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sctp | | sip | sqlnet | tftp | xdmcp }
undo nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sctp | | sip | sqlnet | tftp | xdmcp }
NAT ALG is enabled for DNS, FTP, ICMP error messages, PPTP, and RTSP, and is disabled for the other supported protocols.
context-admin
all: Enables NAT ALG for all supported protocols.
dns: Enables NAT ALG for DNS.
ftp: Enables NAT ALG for FTP.
h323: Enables NAT ALG for H.323.
icmp-error: Enables NAT ALG for ICMP error packets.
ils: Enables NAT ALG for ILS.
mgcp: Enables NAT ALG for MGCP.
nbt: Enables NAT ALG for NBT.
pptp: Enables NAT ALG for PPTP.
rsh: Enables NAT ALG for RSH.
rtsp: Enables NAT ALG for RTSP.
sccp: Enables NAT ALG for SCCP.
sctp: Enables NAT ALG for SCTP.
sip: Enables NAT ALG for SIP.
sqlnet: Enables NAT ALG for SQLNET.
tftp: Enables NAT ALG for TFTP.
xdmcp: Enables NAT ALG for XDMCP.
NAT ALG translates address or port information in the application layer payload to ensure connection establishment.
For example, an FTP application includes a data connection and a control connection. The IP address and port number for the data connection depend on the payload information of the control connection. This requires NAT ALG to translate the address and port information to establish the data connection.
# Enable NAT ALG for FTP.
[Sysname] nat alg ftp
display nat all
nat configuration-for-new-connection
Use nat configuration-for-new-connection enable to enable NAT configuration changes to take effect only on new connections.
Use undo configuration-for-new-connection enable to disable NAT configuration changes from taking effect only on new connections.
undo nat configuration-for-new-connection enable
NAT configuration change taking effect only on new connections is disabled.
context-admin
Non-default vSystems do not support this command.
By default, NAT configuration changes (such as adding, deleting, editing, or moving NAT rules) might cause traffic on an established connection to match a new NAT rule. As a result, you must create a new connection.
Execute this command if you do not want the NAT configuration change to affect existing connections. After you execute this command on the device, it still performs address translation according to the NAT rules before the configuration change for traffic on existing connections. For traffic on new connections, the device matches the traffic according to the priority of NAT rules after the configuration change and performs address translation based on the matching NAT rules.
# Enable NAT configuration change to take effect only on new connections.
[Sysname] nat configuration-for-new-connection enable
display nat all
nat dns-map
Use nat dns-map to configure a NAT DNS mapping.
Use undo nat dns-map to remove a NAT DNS mapping.
nat dns-map domain domain-name protocol pro-type { interface interface-type interface-number | ip global-ip } port global-port
undo nat dns-map domain domain-name
No NAT DNS mappings exist.
context-admin
domain domain-name: Specifies the domain name of an internal server. A domain name is a dot-separated case-insensitive string that can include letters, digits, hyphens (-), underscores (_), and dots (.) (for example, aabbcc.com). The domain name can contain a maximum of 253 characters, and each separated string contains no more than 63 characters.
protocol pro-type: Specifies the type of the protocol used by the internal server, tcp or udp.
ip global-ip: Specifies the public IP address used by the internal server to provide services for the external network.
port global-port: Specifies the public port number used by the internal server to provide services for the external network. The port number format can be one of the following:
· A number in the range of 1 to 65535.
· A protocol name, a string of 1 to 15 characters. For example, ftp and telnet.
NAT DNS mapping must cooperate with the NAT Server feature.
· A NAT DNS mapping maps the domain name of an internal server to the public IP address, public port number, and protocol type of the internal server.
· A NAT server mapping maps the public IP and port to the private IP and port of the internal server.
The cooperation allows an internal host to access an internal server on the same private network by using the domain name of the internal server when the DNS server is on the public network. The DNS reply from the external DNS server contains only the domain name and public IP address of the internal server in the payload. The NAT interface might have multiple internal servers configured with the same public IP address but different private IP addresses. DNS ALG might find an incorrect internal server by using only the public IP address. If a DNS mapping is configured, DNS ALG can obtain the public IP address, public port number, and protocol type of the internal server by using the domain name. Then it can find the correct internal server by using the public IP address, public port number, and protocol type of the internal server.
You can configure multiple NAT DNS mappings.
# Configure a NAT DNS mapping to map the domain name www.server.com to the public IP address 202.112.0.1, public port number 12345, and protocol type TCP.
[Sysname] nat dns-map domain www.server.com protocol tcp ip 202.112.0.1 port 12345
display nat all
display nat dns-map
nat server
nat global-policy
Use nat global-policy to create the global NAT policy and enter its view, or enter the view of the existing global NAT policy.
Use undo nat global-policy to delete the global NAT policy and all the configuration in the global NAT policy.
nat global-policy
No global NAT policy exists.
context-admin
The global NAT policy contains a set of NAT rules to identify and translate matching packets. The packet match criteria includes source IP address, destination IP address, service type, source security zone, and destination security zone. The global NAT policy supports translating the source IP address and destination IP address of the matching packets.
You do not need to apply the global NAT policy to any interface.
The global NAT policy has priority over interface-based NAT. If both are configured, the matching packets are translated as follows:
· If the global NAT policy contains only source address translation rules, the source address translation follows the NAT policy, and the destination address translation follows the interface-based rules.
· If the global NAT policy contains only destination address translation rules, the destination address translation follows the NAT policy, and the source address translation follows the interface-based rules.
· If the global NAT policy contains both source and destination address translation rules, both the source and destination address translations follow the NAT policy. The interface-based source and destination address translation rules do not take effect.
# Create the global NAT policy and enter its view.
[Sysname] nat global-policy
[Sysname-nat-global-policy]
display nat all
nat hairpin enable
Use nat hairpin enable to enable NAT hairpin.
Use undo nat hairpin enable to disable NAT hairpin.
nat hairpin enable
NAT hairpin is disabled.
Interface view
context-admin
NAT hairpin allows internal hosts to access each other or allows internal hosts to access internal servers. It must cooperate with NAT Server, outbound dynamic NAT, or outbound static NAT. The source and destination IP addresses of the packets are translated on the interface connected to the internal network.
When NAT hairpin works in conjunction with NAT Server, you must configure NAT server mappings in one of the following methods with a protocol type specified:
· Configuring common NAT server mappings
· Configuring load sharing NAT server mappings
# Enable NAT hairpin on interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] nat hairpin enable
display nat all
nat outbound
nat server
nat static outbound
nat icmp-error reply
Use nat icmp-error reply to enable sending ICMP error messages upon NAT failures.
Use undo nat icmp-error reply to restore the default.
No ICMP error messages are sent upon NAT failures.
context-admin
By default, sending ICMP error messages upon NAT failures is disabled on the NAT device. Applications using the ICMP protocol cannot be notified when an event occurs. With this feature enabled, the NAT device sends ICMP error messages upon NAT failures for the applications to locate and troubleshoot the failures.
# Enable sending ICMP error messages upon NAT failures.
[Sysname] nat icmp-error reply
nat inbound
Use nat inbound to configure an inbound dynamic NAT rule.
Use undo nat inbound to delete an inbound dynamic NAT rule.
nat inbound { ipv4-acl-number | name ipv4-acl-name } address-group { group-id | name group-name } [ vpn-instance vpn-instance-name ] [ no-pat [ reversible ] [ add-route ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ] [ description text ]
undo nat inbound { ipv4-acl-number | name ipv4-acl-name }
No inbound dynamic NAT rules exist.
Interface view
context-admin
ipv4-acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
name ipv4-acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must start with an English letter and to avoid confusion, it cannot be all.
address-group group-id: Specifies an address group for address translation.
name group-name: Specifies the address group name, a case-insensitive string of 1 to 63 characters.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the addresses in the address group belong. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the addresses in the address group do not belong to any VPN instance, do not specify this option.
no-pat: Uses the NO-PAT mode. If you do not specify this keyword, PAT is used. PAT supports only TCP, UDP, and ICMP query packets. For an ICMP packet, the ICMP ID is used as its source port number.
reversible: Enables reverse address translation. Reverse address translation uses existing NO-PAT entries to translate the destination address for connections actively initiated from the internal network to the external network.
add-route: Automatically adds a route to the source address after translation. The output interface is the NAT interface and the next hop is the source address before translation.
rule rule-name: Specifies a name for the rule, a case-sensitive string of 1 to 63 characters. It cannot contain backward slashes (\), forward slashes (/), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), vertical bars (|), quotation marks ("), or at signs (@). If you do not specify this option, the rule does not have a name.
priority priority: Specifies a priority for the rule, in the range of 0 to 2147483647. The default value is 4294967295. A smaller value represents a higher priority. If you do not specify this option, the rule has the lowest priority among the same type of NAT rules.
disable: Disables the inbound dynamic NAT rule. If you do not specify this keyword, the rule is enabled.
counting: Enables NAT counting. The number of flows that use the address mapping is counted.
description text: Specifies a description for the inbound dynamic NAT rule. The text argument is a case-insensitive string of 1 to 63 characters.
Inbound dynamic NAT translates the source IP addresses of incoming packets permitted by the ACL into IP addresses in the address group.
Inbound dynamic NAT supports the following modes:
· PAT—Performs both IP address translation and port translation.
· NO-PAT—Performs only IP address translation.
The NO-PAT mode supports reverse address translation. Reverse address translation uses ACL reverse matching to identify packets to be translated. ACL reverse matching works as follows:
· Compares the source IP address/port of a packet with the destination IP addresses/ports in the ACL.
· Translates the destination IP address of the packet according to the matching NO-PAT entry, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
Inbound dynamic NAT typically cooperates with one of the following to implement bidirectional NAT:
· Outbound dynamic NAT (the nat outbound command).
· NAT Server (the nat server command).
· Outbound static NAT (the nat static command).
An address group cannot be used by both the nat inbound and nat outbound commands. It cannot be used by the nat inbound command in both PAT and NO-PAT modes.
Do not specify the add-route keyword if the subnets where the internal and external networks reside overlap. For other network scenarios:
· If you specify the add-route keyword, the device automatically adds a route to the source address after translation for a packet. The destination address is the NAT address in the NAT address group, the output interface is the interface where the command is executed, and the next hop is the source address before translation.
· If you do not specify the add-route keyword, you must manually add the route. As a best practice, add routes manually because automatic route adding is slow.
An ACL can be used by only one inbound dynamic NAT rule on an interface.
You can configure multiple inbound dynamic NAT rules on an interface.
The vpn-instance parameter is required if you deploy inbound dynamic NAT for VPNs. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
Inbound dynamic NAT rules configured with the same priority value are matched by using their ACLs.
· NAT rules with named ACLs have higher priorities than NAT rules with unnamed ACLs.
· NAT rules with named ACLs are matched in alphabetical order of their ACL names.
· NAT rules with unnamed ACLs are matched in descending order of their ACL numbers.
# Configure ACL 2001 to permit packets only from subnet 10.110.10.0/24 in VPN vpn10 to pass through.
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit vpn-instance vpn10 source 10.110.10.0 0.0.0.255
[Sysname-acl-ipv4-basic-2001] rule deny
# Configure the MPLS L3VPN instance named vpn10.
[Sysname] ip vpn-instance vpn10
[Sysname-vpn-instance-vpn10] route-distinguisher 100:001
[Sysname-vpn-instance-vpn10] vpn-target 100:1 export-extcommunity
[Sysname-vpn-instance-vpn10] vpn-target 100:1 import-extcommunity
[Sysname-vpn-instance-vpn10] quit
# Create address group 1 and add the address range of 202.110.10.10 to 202.110.10.12 to the group.
[Sysname-address-group-1] address 202.110.10.10 202.110.10.12
[Sysname-address-group-1] quit
# Configure an inbound NO-PAT rule on interface GigabitEthernet 1/0/1. NAT translates the source addresses of incoming packets into the addresses in address group 1, and automatically adds routes for translated packets. Set the rule name to abc, and the priority to 0.
[Sysname-GigabitEthernet1/0/1] nat inbound 2001 address-group 1 vpn-instance vpn10 no-pat add-route rule abc priority 0
display nat all
display nat inbound
display nat no-pat
nat inbound rule move
Use nat inbound rule move to change the priority of an inbound dynamic NAT rule.
nat inbound rule move nat-rule-name1 { after | before } nat-rule-name2
Interface view
context-admin
nat-rule-name1: Specifies the name of the rule be moved.
after: Moves the rule nat-rule-name1 to the line after the rule nat-rule-name2 (called the reference rule). The priority value of the reference rule is not changed. The priority value of the moved rule equals the priority value of the reference rule plus one.
before: Moves the rule nat-rule-name1 to the line before the rule nat-rule-name2. The priority value of the reference rule is not changed. The priority value of the moved rule equals the priority value of the reference rule minus one.
nat-rule-name2: Specifies the name of the NAT rule as a reference rule for the NAT rule to be moved.
This command is applicable only to named inbound dynamic NAT rules.
A NAT rule appearing earlier on the rule list has a higher priority for packet matching.
# Move the inbound dynamic NAT rule abc to the line before the rule def.
[Sysname-GigabitEthernet1/0/1] nat inbound rule move abc before def
nat inbound
nat link-switch recreate-session
Use nat link-switch recreate-session to enable NAT session recreation after link switchover.
Use undo nat link-switch recreate-session to disable NAT session recreation after link switchover.
NAT session recreation is disabled after link switchover.
context-admin
This command is applicable to a WAN network where two interfaces of the NAT device are configured with outbound dynamic NAT rules using different address groups. When the link of one interface fails, traffic on this link is switched to the link of another interface and the NAT device operates as follows:
· If the two interfaces are in different security zones, the NAT device deletes old session entries after link switchover. When user traffic later arrives, it triggers the NAT session recreation. This mechanism ensures that internal users can access the external network.
· If the two interfaces are in the same security zone, the NAT device retains old session entries after link switchover. Internal users cannot access the external network because the device uses old session entries to match the user traffic. To avoid this issue, enable this feature to ensure availability of NAT services.
# Enable NAT session recreation after link switchover.
[Sysname] nat link-switch recreate-session
display nat all
nat log alarm
Use nat log alarm to enable NAT alarm logging.
Use undo nat log alarm to disable NAT alarm logging.
nat log alarm
undo nat log alarm
NAT alarm logging is disabled.
context-admin
Packets that need to be translated are dropped if the NAT resources are not enough. In NO-PAT, the NAT resources refer to the public IP addresses. In EIM PAT, the NAT resources refer to public IP addresses and ports. In NAT444, the NAT resources refer to public IP addresses, port blocks, or ports in port blocks. NAT alarm logging monitors the usage of NAT resources and outputs logs if the NAT resources are not enough.
For NAT444 dynamic port block mappings, an alarm log is generated upon the port block assignment failure or the failure that port resources cannot meet the user address translation requirement.
Before configuring alarm logging for NAT, you must configure the custom NAT log generation and outputting features. For more information about information center, see Network Management and Monitoring Configuration Guide.
This command take effect only after you use the nat log enable command to enable NAT logging.
# Enable NAT alarm logging.
[Sysname] nat log alarm
display nat all
display nat log
nat log enable
nat log enable
Use nat log enable to enable NAT logging.
Use undo nat log enable to disable NAT logging.
nat log enable [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat log enable
NAT logging is disabled.
context-admin
acl: Specifies an ACL.
You must enable NAT logging before you enable NAT session logging, NAT444 user logging (including port block assignment and withdrawal logging), NAT alarm logging, or NAT NO-PAT logging.
The acl keyword takes effect only for NAT session logging. If an ACL is specified, flows matching the permit rule might trigger NAT session logs. If you do not specify an ACL, all flows processed by NAT might trigger NAT session logs.
# Enable NAT logging.
[Sysname] nat log enable
display nat all
display nat log
nat log alarm
nat log flow-active
nat log flow-begin
nat log flow-end
· nat log port-block-assign
· nat log port-block-withdraw
nat log flow-active
Use nat log flow-active to enable logging for active NAT flows and set the logging interval.
Use undo nat log flow-active to disable logging for active NAT flows.
nat log flow-active time-value
Logging for active NAT flows is disabled.
context-admin
time-value: Specifies the interval for logging active NAT flows, in the range of 10 to 120 minutes.
Active NAT flows are NAT sessions that last for a long time. The logging feature helps track active NAT flows by periodically logging the active NAT flows.
Logging for active NAT flows takes effect only after you enable NAT logging.
# Enable logging for active NAT flows and set the logging interval to 10 minutes.
[Sysname] nat log flow-active 10
display nat all
display nat log
nat log enable
nat log flow-begin
Use nat log flow-begin to enable logging for NAT session establishment events.
Use undo nat log flow-begin to disable logging for NAT session establishment events.
nat log flow-begin
Logging for NAT session establishment events is disabled.
context-admin
Logging for NAT session establishment events takes effect only after you enable NAT logging.
# Enable logging for NAT session establishment events.
[Sysname] nat log flow-begin
display nat all
display nat log
nat log enable
nat log flow-end
Use nat log flow-end to enable logging for NAT session removal events.
Use undo nat log flow-end to disable logging for NAT session removal events.
nat log flow-end
Logging for NAT session removal events is disabled.
context-admin
Logging for NAT session removal events takes effect only after you enable NAT logging.
# Enable logging for NAT session removal events.
[Sysname] nat log flow-end
display nat all
display nat log
nat log enable
nat log no-pat ip-usage
Use nat log no-pat ip-usage to enable logging for the IP usage of a NAT address group in NO-PAT mode and set a usage threshold.
undo nat log no-pat ip-usage disable logging for the IP usage of a NAT address group in NO-PAT mode.
nat log no-pat ip-usage [ threshold value ]
Logging for the IP usage of a NAT address group is disabled.
Predefines user roles
context-admin
threshold value: Specifies the IP usage threshold of a NAT address group, in percentage. The value range is 40 to 100, and the default is 90%.
The system generates a log if the IP usage of a NAT address group exceeds the threshold.
This command takes effect only after you enable the NAT logging by using the nat log enable command.
# Enable logging for the IP usage of a NAT address group in NO-PAT mode and set the threshold to 60%.
[Sysname] nat log no-pat ip-usage threshold 60
display nat log
display nat no-pat ip-usage
nat log enable
nat log port-block usage threshold
Use nat log port-block usage threshold to set the port block usage threshold.
Use undo nat log port-block port-usage threshold to restore the default.
nat log port-block usage threshold threshold-value
undo nat log port-block usage threshold
The port block usage threshold is 90%.
context-admin
threshold-value: Specifies a threshold in the range of 40 to 100 in percentage.
A log is generated when the port block usage exceeds the threshold.
# Set the port block usage threshold to 60%.
[Sysname] nat log port-block usage threshold 60
display nat all
display nat log
nat log enable
Use nat log port-block-assign to enable NAT444 user logging for port block assignment.
Use undo nat log port-block-assign to disable NAT444 user logging for port block assignment.
NAT444 user logging is disabled for port block assignment.
context-admin
For static port block mappings, the NAT444 gateway generates a user log when it translates the first connection from a private IP address.
For dynamic port block mappings, the NAT444 gateway generates a user log when it assigns or extends a port block for a private IP address.
This command takes effect only after you use the nat log enable command to enable NAT logging.
# Enable NAT444 user logging for port block assignment.
[Sysname] nat log port-block-assign
display nat all
display nat log
nat log enable
Use nat log port-block-withdraw to enable NAT444 user logging for port block withdrawal.
Use undo nat log port-block-withdraw to disable NAT444 user logging for port block withdrawal.
NAT444 user logging is disabled for port block withdrawal.
context-admin
For static port block mappings, the NAT444 gateway generates a user log when all connections from a private IP address are disconnected.
For dynamic port block mappings, the NAT444 gateway generates a user log when all the following conditions are met:
· The port blocks (including the extended ones) assigned to the private IP address are withdrawn.
· The corresponding mapping entry is deleted.
# Enable NAT444 user logging for port block withdrawal.
[Sysname] nat log port-block-withdraw
display nat all
display nat log
nat log enable
nat mapping-behavior endpoint-independent
Use nat mapping-behavior endpoint-independent to specify the Endpoint-Independent Mapping (EIM) mode for PAT.
Use undo nat mapping-behavior to restore the default.
nat mapping-behavior endpoint-independent [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat mapping-behavior endpoint-independent
Address and Port-Dependent Mapping applies.
context-admin
acl: Specifies an ACL to define the applicable scope of Endpoint-Independent Mapping.
PAT supports the following NAT mapping modes:
· Endpoint-Independent Mapping—Uses the same IP and port mapping (EIM entry) for packets from the same source and port to any destination. EIM allows external hosts to access the internal hosts by using the NAT IP address and port. It allows internal hosts behind different NAT gateways to access each other.
· Address and Port-Dependent Mapping—Uses different IP and port mappings for packets with the same source IP and port to different destination IP addresses and ports. APDM allows an external host to access an internal host only under the condition that the internal host has previously accessed the external host. It is secure, but it does not allow internal hosts behind different NAT gateways to access each other.
This command takes effect only on outbound PAT. Address and Port-Dependent Mapping always applies to inbound PAT.
If you specify an ACL, Endpoint-Independent Mapping applies to packets that are permitted by the ACL. If you do not specify an ACL, Endpoint-Independent Mapping applies to all packets.
# Apply the Endpoint-Independent Mapping mode to all packets for address translation.
[Sysname] nat mapping-behavior endpoint-independent
# Apply the Endpoint-Independent Mapping mode to FTP and HTTP packets, and the Address and Port-Dependent Mapping mode to other packets for address translation.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit tcp destination-port eq 80
[Sysname-acl-ipv4-adv-3000] rule permit tcp destination-port eq 21
[Sysname] nat mapping-behavior endpoint-independent acl 3000
nat outbound
display nat eim
nat outbound
Use nat outbound to configure an outbound dynamic NAT rule.
Use undo nat outbound to delete an outbound dynamic NAT rule.
NO-PAT:
nat outbound [ ipv4-acl-number | name ipv4-acl-name ] address-group { group-id | name group-name } [ vpn-instance vpn-instance-name ] no-pat [ reversible ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ] [ description text ]
undo nat outbound [ ipv4-acl-number | name ipv4-acl-name ]
PAT:
nat outbound [ ipv4-acl-number | name ipv4-acl-name ] [ address-group { group-id | name group-name } ] [ vpn-instance vpn-instance-name ] [ port-preserved ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ] [ description text ]
No outbound dynamic NAT rules exist.
Interface view
context-admin
address-group: Specifies an address group for NAT. If you do not specify an address group, the IP address of the interface is used as the NAT address. Easy IP is used.
no-pat: Uses the NO-PAT mode. If you do not specify this keyword, PAT is used. PAT only supports TCP, UDP, and ICMP query packets. For an ICMP packet, the ICMP ID is used as its source port number.
reversible: Enables reverse address translation. Reverse address translation uses existing NO-PAT entries to translate the destination address for connections actively initiated from the external network to the internal network.
port-preserved: Tries to preserve port number for PAT. This keyword does not take effect on dynamic NAT port block mapping.
disable: Disables the outbound dynamic NAT rule. If you do not specify this keyword, the rule is enabled.
description text: Specifies a description for the outbound dynamic NAT rule. The text argument is a case-insensitive string of 1 to 63 characters.
Outbound dynamic NAT is typically configured on the interface connected to the external network. You can configure multiple outbound dynamic NAT rules on an interface.
Outbound dynamic NAT supports the following modes:
· PAT—Performs both IP address translation and port translation. The PAT mode allows external hosts to actively access the internal hosts if the Endpoint-Independent Mapping behavior is used.
· NO-PAT—Performs only IP address translation. The NO-PAT mode allows external hosts to actively access the internal hosts if you specify the reversible keyword. If an ACL is specified, reverse address translation only applies to packets permitted by ACL reverse matching. ACL reverse matching works as follows:
¡ Compares the source IP address/port of a packet with the destination IP addresses/ports in the ACL.
¡ Translates the destination IP address of the packet according to the matching NO-PAT entry, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
Dynamic NAT444 does not support the NO-PAT mode.
When you specify a NAT address group, follow these restrictions and guidelines:
· An address group cannot be used by both the nat inbound and nat outbound commands.
· An address group cannot be used by the nat outbound command in both PAT and NO-PAT modes.
· When port block parameters are specified in the NAT address group, this command configures a dynamic NAT port block mapping. Packets matching the ACL permit rule are processed by dynamic NAT444.
When you specify an ACL, follow these restrictions and guidelines:
· An ACL can be used by only one outbound dynamic NAT rule on an interface.
· If you configure multiple outbound dynamic NAT rules, only one outbound dynamic NAT rule can contain no ACL.
· If you specify an ACL, NAT translates the source IP addresses of outgoing packets permitted by the ACL into IP addresses in the address group. If you do not specify an ACL, NAT translates all packets.
· Outbound dynamic NAT rules with ACLs configured on an interface takes precedence over those without ACLs. If two ACL-based dynamic NAT rules are configured, the rule with the higher ACL number has higher priority.
The vpn-instance parameter is required if you deploy outbound dynamic NAT for VPNs. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
Outbound dynamic NAT rules configured with the same priority value and an ACL are matched by using the ACLs in the rule.
# Configure ACL 2001 to permit packets only from subnet 10.110.10.0/24 to pass through.
[Sysname-acl-ipv4-basic-2001] rule permit source 10.110.10.0 0.0.0.255
# Configure an outbound dynamic PAT rule on interface GigabitEthernet 1/0/1 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1.
[Sysname-GigabitEthernet1/0/1] nat outbound 2001 address-group 1
Or
# Configure an outbound NO-PAT rule on interface GigabitEthernet 1/0/1 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1.
[Sysname-GigabitEthernet1/0/1] nat outbound 2001 address-group 1 no-pat
Or
# Enable Easy IP to use the IP address of GigabitEthernet 1/0/1 as the NAT address.
[Sysname-GigabitEthernet 1/0/1] nat outbound 2001
[Sysname-GigabitEthernet 1/0/1] quit
Or
# Configure an outbound NO-PAT rule on GigabitEthernet 1/0/1 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1. Enable reverse address translation.
[Sysname-GigabitEthernet1/0/1] nat outbound 2001 address-group 1 no-pat reversible
display nat eim
display nat outbound
nat outbound ds-lite-b4
Use nat outbound ds-lite-b4 to configure DS-Lite B4 address translation.
Use undo nat outbound ds-lite-b4 to remove the DS-Lite B4 address translation configuration.
nat outbound ds-lite-b4 { ipv6-acl-number | name ipv6-acl-name } address-group group-id
undo nat outbound ds-lite-b4 { ipv6-acl-number | name ipv6-acl-name }
No DS-Lite B4 address translation configuration exists.
Interface view
context-admin
ipv6-acl-number: Specifies the number of an IPv6 ACL to match the IPv6 addresses of B4 elements. The value range for the argument is 2000 to 2999.
name ipv6-acl-name: Specifies the name of an IPv6 ACL to match the IPv6 addresses of B4 elements. The ACL name is a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, it cannot be all.
address-group group-id: Specifies an address group by its ID. The value range for the group-id argument is 0 to 65535. Port block parameters are required in the address group for DS-Lite B4 address translation.
DS-Lite B4 address translation applies to the scenario where a DS-Lite tunnel connects an IPv6 network to an IPv4 network. DS-Lite port block mapping is configured on the AFTR's interface connected to the external IPv4 network and performs dynamic port block mapping based on the B4 element. The B4 element refers to a B4 router or a DS-Lite host.
DS-Lite B4 address translation dynamically maps a public IPv4 address and a port block to the IPv6 address of the B4 element. The DS-Lite host or hosts behind the B4 router use the mapped public IPv4 address and port block to access the public IPv4 network.
# Configure IPv6 ACL 2100 to identify packets from subnet 2000::/64.
[Sysname] acl ipv6 basic 2100
[Sysname-acl-ipv6-basic-2100] rule permit source 2000::/64
[Sysname-acl-ipv6-basic-2100] quit
# Create address group 1 and add public addresses 202.110.10.10 through 202.110.10.12 to the group.
[Sysname-nat-address-group-1] address 202.110.10.10 202.110.10.12
# Set the port block size to 256.
[Sysname-nat-address-group-1] port-block block-size 256
[Sysname-nat-address-group-1] quit
# Configure DS-Lite port block mapping on GigabitEthernet 1/0/1 to use address group 1 to translate packets permitted by ACL 2100.
[Sysname-GigabitEthernet1/0/1] nat outbound ds-lite-b4 2100 address-group 1
nat outbound port-block-group
Use nat outbound port-block-group to configure a static outbound port block mapping rule on an interface.
Use undo nat outbound port-block-group to delete a static port block mapping rule on an interface.
nat outbound port-block-group group-id [ rule rule-name ] [ counting ]
undo nat outbound port-block-group group-id
No static outbound port block mapping rule is configured on an interface.
Interface view
context-admin
group-id: Specifies a NAT port block group by its ID. The value range for this argument is 0 to 65535.
After you configure this command on an interface, the system automatically computes the mappings and creates entries for them. When a private IP address accesses the public network, the private IP address is translated to the mapped public IP address, and the ports are translated to ports in the selected port block.
You can configure multiple port block mapping rules on an interface.
In an IRF fabric, you must execute the ip fast-forwarding load-sharing command. Otherwise, the port assignment conflict will occur.
# Configure a static outbound port block mapping rule on GigabitEthernet 1/0/1, and specify the rule name as abc.
[Sysname-GigabitEthernet1/0/1] nat outbound port-block-group 1 rule abc
display nat all
display nat outbound port-block-group
display nat port-block
nat outbound rule move
Use nat outbound rule move to change the priority of an outbound dynamic NAT rule.
nat outbound rule move nat-rule-name1 { after | before } nat-rule-name2
Interface view
context-admin
nat-rule-name1: Specifies the name of the NAT rule to be moved.
This command is applicable only to named outbound dynamic NAT rules.
# Move the outbound dynamic NAT rule abc to the line before the rule def.
[Sysname-GigabitEthernet1/0/1] nat outbound rule move abc before def
nat outbound
nat periodic-statistics enable
Use nat periodic-statistics enable to enable periodic NAT statistics collection.
Use undo nat periodic-statistics enable to disable periodic NAT statistics collection.
The following compatibility matrixes show the support of hardware platforms for this command:
F1000 series |
Models |
Command compatibility |
F1000-X-G5 series |
F1000-A-G5, F1000-S-G5 |
No |
F1000-E-G5, F1000-H-G5, F1000-C-G5, F1000-C-G5-LI |
Yes |
F1000-X-G3 series |
F1000-A-G3, F1000-C-G3, F1000-E-G3, F1000-S-G3 |
Yes |
F1000-X-G2 series |
F1000-A-G2, F1000-C-G2, F1000-E-G2, F1000-S-G2 |
Yes |
F1000-9X0-AI series |
F1000-9380-AI, F1000-9370-AI |
No |
F1000-9390-AI, F1000-9385-AI, F1000-9360-AI, F1000-9350-AI, F1000-9330-AI, F1000-9320-AI, F1000-910-AI, F1000-905-AI, F1000-990-AI, F1000-980-AI, F1000-970-AI, F1000-960-AI, F1000-950-AI, F1000-930-AI, F1000-920-AI |
Yes |
F1000-C83X0 series |
F1000-C8395, F1000-C8370, F1000-C8360, F1000-C8350, F1000-C8330 |
Yes |
F1000-C8390, F1000-C8385, F1000-C8380 |
No |
F1000-C81X0 series |
F1000-C8180, F1000-C8170, F1000-C8160, F1000-C8110, F1000-C8150, F1000-C8130, F1000-C8120 |
Yes |
F1000-7X0-HI series |
F1000-770-HI |
No |
F1000-750-HI, F1000-740-HI, F1000-730-HI, F1000-720-HI, F1000-710-HI |
Yes |
F1000-C-X series |
F1000-C-XI |
No |
F1000-C-EI, F1000-C-HI, F1000-E-XI |
Yes |
F1000-V series |
F1000-E-VG, F1000-S-VG |
Yes |
SecBlade IV |
LSPM6FWD8, LSQM2FWDSC8 |
No |
F100 series |
Models |
F100-X-G5 series |
F100-A-G5, F100-C-G5, F100-E-G5, F100-M-G5, F100-S-G5 |
Yes |
F100-X-G3 series |
F100-A-G3, F100-C-G3, F100-E-G3, F100-M-G3, F100-S-G3 |
Yes |
F100-X-G2 series |
F100-A-G2, F100-C-G2, F100-E-G2, F100-M-G2, F100-S-G2 |
Yes |
F100-WiNet series |
F100-A80-WiNet, F100-C80-WiNet, F100-C60-WiNet, F100-S80-WiNet, F100-A81-WiNet, F100-A91-WiNet, F100-C50-WiNet |
Yes |
F100-C-A series |
F100-C-A6, F100-C-A5, F100-C-A3, F100-C-A2, F100-C-A1, F100-C-A6-WL, F100-C-A5-W, F100-C-A3-W |
Yes |
F100-X-XI series |
F100-A-EI, F100-A-HI, F100-A-SI, F100-C-EI, F100-C-HI, F100-C-XI, F100-E-EI, F100-S-HI, F100-S-XI |
Yes |
Periodic NAT statistics collection is disabled.
context-admin
This feature periodically counts sessions and port block assignment failures for address groups.
This feature might cause intensive CPU usage. You can disable this feature when CPU resources are insufficient.
# Enable periodic NAT statistics collection.
[Sysname] nat periodic-statistics enable
nat periodic-statistics interval
Use nat periodic-statistics interval to set the interval for periodic NAT statistics collection.
Use undo nat periodic-statistics interval to restore the default.
nat periodic-statistics interval interval
F1000 series |
Models |
F1000-X-G5 series |
No |
Yes |
F1000-X-G3 series |
Yes |
F1000-X-G2 series |
Yes |
No |
Yes |
Yes |
No |
Yes |
F1000-770-HI |
No |
Yes |
F1000-C-X series |
F1000-C-XI |
No |
Yes |
F1000-V series |
Yes |
SecBlade IV |
No |
F100 series |
Models |
F100-X-G5 series |
Yes |
F100-X-G3 series |
Yes |
F100-X-G2 series |
Yes |
F100-WiNet series |
Yes |
F100-C-A series |
Yes |
F100-X-XI series |
Yes |
The interval for periodic NAT statistics collection is 300 seconds.
context-admin
interval: Specifies the interval for collecting periodic NAT statistics. The value range is 180 to 604800 seconds.
A narrower interval indicates intensive CPU usage. As a best practice, use the default interval value.
# Set the interval for periodic NAT statistics collection to 500 seconds.
[Sysname] nat periodic-statistics interval 500
nat policy
Use nat policy to create a NAT policy and enter its view, or enter the view of an existing NAT policy.
Use undo nat policy to delete the NAT policy and all the configuration in the NAT policy.
nat policy
undo nat policy
F1000 series |
Models |
F1000-X-G5 series |
F1000-A-G5, F1000-S-G5, F1000-C-G5, F1000-C-G5-LI |
No |
F1000-E-G5, F1000-H-G5 |
Yes |
F1000-X-G3 series |
Yes |
F1000-X-G2 series |
Yes |
F1000-9390-AI, F1000-9385-AI, F1000-990-AI, F1000-980-AI, F1000-970-AI, F1000-960-AI, F1000-950-AI, F1000-930-AI, F1000-920-AI, F1000-910-AI, F1000-905-AI |
Yes |
F1000-9380-AI, F1000-9370-AI, F1000-9360-AI, F1000-9350-AI, F1000-9330-AI, F1000-9320-AI |
No |
F1000-C8395 |
Yes |
F1000-C8390, F1000-C8385, F1000-C8380, F1000-C8370, F1000-C8360, F1000-C8350, F1000-C8330 |
Yes |
Yes |
F1000-770-HI, F1000-750-HI, F1000-740-HI, F1000-730-HI, F1000-720-HI, F1000-710-HI |
Yes |
F1000-C-X series |
F1000-C-EI, F1000-C-HI, F1000-C-XI, F1000-E-XI |
Yes |
F1000-V series |
Yes |
SecBlade IV |
No |
F100 series |
Models |
F100-X-G5 series |
Yes |
F100-X-G3 series |
F100-A-G3, F100-C-G3, F100-E-G3 , F100-M-G3, F100-S-G3 |
Yes |
F100-X-G2 series |
Yes |
F100-WiNet series |
F100-A80-WiNet, F100-C80-WiNet, F100-C60-WiNet, F100-C50-WiNet, F100-S80-WiNet, F100-A81-WiNet, F100-A91-WiNet |
Yes |
F100-C-A series |
Yes |
F100-X-XI series |
Yes |
No NAT policy exists.
context-admin
The NAT policy performs address translation for outgoing packets on the interfaces that the rules are applied. The NAT policy contains a set of NAT rules. The device identifies the packets based on the object groups in the NAT rules, and translates addresses according to the method in the matching rule.
The NAT policy supports only dynamic address translation, and the NAT policy has a higher priority than the dynamic address translation configuration on the interface.
# Create a NAT policy and enter its view.
<Sysname> system
[Sysname] nat policy
[Sysname-nat-policy]
display nat all
display nat policy
rule name
nat port-block global-share enable
Use nat port-block global-share enable to enable port block global sharing.
Use undo nat port-block global-share enable to disable port block global sharing.
Port block global sharing is disabled.
context-admin
When multiple interfaces have dynamic NAT port block mapping configured, the interfaces might create different port block mappings for packets from the same IP address. You can use this command to configure the interfaces to use the same port block mapping for translating packets from the same IP address.
# Enable port block global sharing.
[Sysname] nat port-block global-share enable
port-block
nat port-block synchronization enable
Use nat port-block synchronization enable to enable dynamic NAT port block mapping synchronization.
Use undo nat port-block synchronization enable to disable dynamic NAT port block mapping synchronization.
Dynamic NAT port block mapping synchronization is disabled.
context-admin
Dynamic NAT port block mapping synchronization enables the master and the backup to synchronize dynamic port block mappings, which ensures smooth switchover without service interruption.
# Enable dynamic NAT port block mapping synchronization.
[Sysname] nat port-block synchronization enable
Use nat port-block-group to create a NAT port block group and enter its view, or enter the view of an existing NAT port block group.
Use undo nat port-block-group to delete a NAT port block group.
nat port-block-group group-id
undo nat port-block-group group-id
No NAT port block groups exist.
context-admin
group-id: Assigns an ID to the NAT port block group. The value range for this argument is 0 to 65535.
A NAT port block group is configured to implement static port block mapping for NAT444.
You must configure the following items for a NAT port block group:
· A minimum of one private IP address range (see the local-ip-address command).
· A minimum of one public IP address range (see the global-ip-address command).
· A port range (see the port-range command).
· A port block size (see the block-size command).
The system computes static port block mappings according to the port block group configuration, and creates entries for the mappings.
# Create NAT port block group 1.
<Sysname>system-view
[Sysname]nat port-block-group 1
block-size
display nat all
display nat port-block-group
global-ip-pool
local-ip-address
port-range
nat port-load-balance enable
Use nat port-load-balance enable to enable NAT port halving.
Use undo nat port-load-balance enable to disable NAT port halving.
nat port-load-balance enable slot slot-number
undo nat port-load-balance enable slot slot-number
NAT port halving is disabled.
context-admin
slot slot-number: Specifies an IRF member device by its member ID. This device will use the lower half portion of the port block.
After you enable NAT port halving in VRRP load balancing on an IRF fabric, each port block will be equally divided between the two devices. The two devices will use different ports to translate packets from the same IP address, avoiding port assignment conflicts.
Before enabling this feature, for successfully port allocation, make sure the address group meets the following requirements:
· For dynamic outbound NAT, the number of ports for the public IP addresses in the address group must not less than 2.
· For dynamic NAT444, the number of port blocks and ports for public IP addresses in the address group must not less than 2.
Do not use this feature in VRRP standard mode.
# Enable NAT port halving.
<Sysname> system
[Sysname] nat port-load-balance enable slot 1
port-block
port-range
nat redirect reply-route
Use nat redirect reply-route enable to enable NAT reply redirection.
Use undo nat redirect reply-route enable to disable NAT reply redirection.
NAT reply redirection is disabled.
Interface view
context-admin
NAT reply redirection allows an interface to use the NAT session entry information to translate the destination IP addresses for NAT reply packets and find the output interfaces for the NATed reply packets.
# Enable NAT reply redirection on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] nat redirect reply-route enable
nat remote-backup port-alloc
Use nat remote-backup port-alloc to specify NAT port ranges for the two devices in the hot backup system.
Use undo nat remote-backup port-alloc to restore the default.
nat remote-backup port-alloc { primary | secondary }
The two devices in the hot backup system share NAT port resources.
context-admin
primary: Specifies the first half of the port range.
secondary: Specifies the second half of the port range.
For dual-active hot backup, different IP+port combinations on the two devices might be translated to the same NAT IP+port resources due to the following reasons:
· The two devices in the hot backup system share NAT addresses.
· The same NAT port range is assigned to each device.
To avoid this situation, execute this command on the primary device to equally divide the port resources for the two devices. Executing the command on the primary device also makes the remaining half of the port range be automatically assigned to the secondary device. For example, if you execute the nat remote-backup port-alloc secondary command on the primary device, the nat remote-backup port-alloc primary command is automatically executed on the secondary device. For more information about the hot backup system, see High Availability Configuration Guide.
You do not need to execute this command for active/standby hot backup. No port conflict exists in this mode because only one device processes NAT services.
# Specify one device in the hot backup system to use the first half of the port range.
[Sysname] nat remote-backup port-alloc primary
nat server
Use nat server to create a NAT server mapping (also called NAT server rule). The mapping maps the private IP address and port of an internal server to a public address and port.
Use undo nat server to delete a NAT server mapping.
Common NAT server mapping:
· A single public address with no or a single public port:
nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ] [ vpn-instance global-vpn-instance-name ] inside local-address [ local-port ] [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ reversible ] [ vrrp virtual-router-id ] [ rule rule-name ] [ disable ] [ counting ] [ description text ]
undo nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ] [ vpn-instance global-vpn-instance-name ]
· A single public address with consecutive public ports:
nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 [ vpn-instance global-vpn-instance-name ] inside { { local-address | local-address1 local-address2 } local-port | local-address local-port1 local-port2 } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ vrrp virtual-router-id ] [ rule rule-name ] [ disable ] [ counting ] [ description text ]
undo nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 [ vpn-instance global-vpn-instance-name ]
· Consecutive public addresses with no public port:
nat server protocol pro-type global global-address1 global-address2 [ vpn-instance global-vpn-instance-name ] inside { local-address | local-address1 local-address2 } [ local-port ] [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ vrrp virtual-router-id ] [ rule rule-name ] [ disable ] [ counting ] [ description text ]
undo nat server protocol pro-type global global-address1 global-address2 [ global-port ] [ vpn-instance global-vpn-instance-name ]
· Consecutive public addresses with one single public port:
nat server protocol pro-type global global-address1 global-address2 global-port [ vpn-instance global-vpn-instance-name ] inside { local-address [ local-port1 local-port2 ] | [ local-address | local-address1 local-address2 ] [ local-port ] } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ vrrp virtual-router-id ] [ rule rule-name ] [ disable ] [ counting ] [ description text ]
undo nat server protocol pro-type global global-address1 global-address2 global-port [ vpn-instance global-vpn-instance-name ]
Load sharing NAT server mapping:
nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port } [ vpn-instance global-vpn-instance-name ] inside server-group group-id [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ vrrp virtual-router-id ] [ rule rule-name ] [ disable ] [ counting ] [ description text ]
undo nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port } [ vpn-instance global-vpn-instance-name ]
ACL-based NAT server mapping:
nat server global { ipv4-acl-number | name ipv4-acl-name } inside local-address [ local-port ] [ vpn-instance local-vpn-instance-name ] [ vrrp virtual-router-id ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ] [ description text ]
undo nat server global { ipv4-acl-number | name ipv4-acl-name }
No NAT server mappings exist.
Interface view
context-admin
protocol pro-type: Specifies a protocol type. When the protocol is TCP or UDP, NAT Server can be configured with port information. If you do not specify a protocol type, the command applies to packets of all protocols. The protocol type format can be one of the following:
· A number in the range of 1 to 255.
· A protocol name of icmp, tcp, or udp.
global: Specifies the public network information about the internal server.
global-address: Specifies the public address of an internal server.
global-address1 global address2: Specifies a public IP address range, which can include a maximum of 10000 addresses. The global-address1 argument specifies the start address, and the global address2 argument specifies the end address that must be greater than the start address.
current-interface: Enables Easy IP on the current interface. The primary IP address of the interface is used as the public address for the internal server.
interface interface-type interface-number: Enables Easy IP on the interface specified by its type and number. The primary IP address of the interface is used as the public address for the internal server. Only loopback interfaces are supported.
global-port1 global-port2: Specifies a public port number range, which can include a maximum of 10000 ports. The global-port1 argument specifies the start port, and the global-port2 argument specifies the end port that must be greater than the start port. The public port number format can be one of the following:
· A number in the range of 1 to 65535. Both the start port and the end port support this format.
· A protocol name, a string of 1 to 15 characters. For example, http and telnet. Only the start port supports this format.
inside: Specifies the private network information about the internal server.
local-address1 local-address2: Specifies a private IP address range. The local-address1 argument specifies the start address, and the local-address2 argument specifies the end address that must be greater than the start address. The number of addresses in the range must equal the number of ports in the public port number range.
local-port: Specifies the private port number. The private port number format can be one of the following:
· A number in the range of 1 to 65535, excluding FTP port 20.
global-port: Specifies the public port number. The default value and value range are the same as those for the local-port argument.
local-address: Specifies the private IP address.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the advertised public IP addresses belong. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public IP addresses do not belong to any VPN instance, do not specify this option.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the internal server belongs. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the internal server does not belong to any VPN instance, do not specify this option.
server-group group-id: Specifies the internal server group to which the internal server belongs. With this parameter, the load sharing NAT Server feature is configured. The group-id argument specifies the internal server group ID. The value range for the group-id argument is 0 to 65535.
acl: Specifies an ACL. If you specify an ACL, only packets permitted by the ACL can be translated by using the mapping.
reversible: Allows reverse address translation. Reverse address translation applies to connections actively initiated by internal servers to the external network. It translates the private IP addresses of the internal servers to their public IP addresses.
vrrp virtual-router-id: Specifies a VRRP group by its virtual router ID in the range of 1 to 255.
rule rule-name: Specifies a name for the mapping, a case-sensitive string of 1 to 63 characters. It cannot contain backward slashes (\), forward slashes (/), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), vertical bars (|), quotation marks ("), or at signs (@). If you do not specify this option, the mapping does not have a name.
priority priority: Specifies a priority for the mapping, in the range of 0 to 2147483647. The default value is 4294967295. A smaller value represents a higher priority. If you do not specify this option, the mapping has the lowest priority among the same type of NAT rules.
disable: Disables the NAT server mapping. If you do not specify this keyword, the mapping is enabled.
description text: Specifies a description for the NAT server mapping. The text argument is a case-insensitive string of 1 to 63 characters.
You can configure the NAT server mapping to allow servers (such as Web, FTP, Telnet, POP3, and DNS servers) in the internal network or an MPLS VPN instance to provide services for external users.
NAT server mappings are usually configured on the interface connected to the external network on a NAT device. By using the global-address and global-port arguments, external users can access the internal server at local-address and local-port. When the protocol type is not udp (protocol number 17) or tcp (protocol number 6), you can configure only one-to-one IP address mappings. The following table describes the address-port mappings between an external network and an internal network for NAT Server.
Table 24 Address-port mappings for NAT Server
External network |
Internal network |
One public address |
One private address |
One public address and one public port number |
One private address and one private port number |
One public address and N consecutive public port numbers |
· One private address and one private port number · N consecutive private addresses and one private port number · One private address and N consecutive private port numbers |
N consecutive public addresses |
· One private address · N consecutive private addresses |
N consecutive public addresses and one public port number |
One internal server group |
Public addresses matching an ACL |
One private address and one private port |
The mapping of the protocol type, public address, and public port number must be unique for an internal server on an interface. This restriction also applies when Easy IP is used. The maximum number of NAT server mappings equals the number of public ports in the specified public port range.
The vpn-instance parameter is required if you configure NAT server mappings in VPN networks. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
As a best practice, do not configure Easy IP for multiple NAT server mappings by using the same interface.
If the IP address of an interface used by Easy IP changes and conflicts with the IP address of a NAT server mapping not using Easy IP, the Easy IP configuration becomes invalid. If the conflicting IP address is modified to another IP address or the NAT server mapping without Easy IP is removed, the Easy IP configuration takes effect.
When you configure a load sharing NAT server mapping, you must make sure a user uses the same public address and public port to access the same service on an internal server. For this purpose, make sure value N in the following mappings is equal to or less than the number of servers in the internal server group:
· One public address and N consecutive public port numbers are mapped to one internal server group.
· N consecutive public addresses and a public port number are mapped to one internal server group.
ACL-based NAT server mappings that are configured with the same priority value are matched by using the ACLs in their rules:
· Mappings with named ACLs have higher priorities than mappings with unnamed ACLs.
· Mappings with named ACLs are matched in alphabetical order of their ACL names.
· Mappings with unnamed ACLs are matched in descending order of their ACL numbers.
In a hot backup system collaborating with VRRP, when you configure a NAT server mapping on the primary device in the hot backup system, specify a VRRP group facing the external network. If you do not perform the binding, the uplink Layer 3 device directly connected to the hot backup system might send downlink packets to the backup device, causing service anomalies.
An error message for a rollback failure when you perform a configuration rollback for an internal server in the following situation:
· In the running configuration, the name of a NAT server mapping is assigned automatically by the system.
· In the replacement configuration file, the name does not exist.
The system will compare the running configuration file and the replacement file, and display an error message about the mismatch. You can ignore the error message because the NAT server mapping configuration in the configuration file is installed successfully. For example, the NAT server mapping configuration is nat server global 112.1.1.1 inside 192.168.20.1 in the running configuration, and the is nat server global 112.1.1.1 inside 192.168.20.1 rule ServerRule_num in the replacement configuration file. After the rollback operation, the new NAT server configuration is successfully installed.
# Allow external users to access the internal Web server at 10.110.10.10 through http://202.110.10.10:8080.
[Sysname-GigabitEthernet1/0/1] nat server protocol tcp global 202.110.10.10 8080 inside 10.110.10.10 http
# Allow external users to access the internal FTP server at 10.110.10.11 in the VPN instance vrf10 through ftp://202.110.10.10.
[Sysname-GigabitEthernet1/0/1] nat server protocol tcp global 202.110.10.10 21 inside 10.110.10.11 vpn-instance vrf10
# Allow external hosts to ping the host at 10.110.10.12 in the VPN instance vrf10 by using the ping 202.110.10.11 command.
[Sysname-GigabitEthernet1/0/1] nat server protocol icmp global 202.110.10.11 inside 10.110.10.12 vpn-instance vrf10
# Allow external hosts to access the Telnet services of internal servers at 10.110.10.1 to 10.110.10.100 in the VPN instance vrf10 through the public address 202.110.10.10 and port numbers from 1001 to 1100. As a result, a user can Telnet to 202.110.10.10:1001 to access 10.110.10.1, Telnet to 202.110.10.10:1002 to access 10.110.10.2, and so on.
[Sysname-GigabitEthernet1/0/1] nat server protocol tcp global 202.110.10.10 1001 1100 inside 10.110.10.1 10.110.10.100 telnet vpn-instance vrf10
# Configure an ACL-based NAT server mapping to allow users to use IP addresses in subnet 192.168.0.0/24 to access the internal server at 10.0.0.172.
[Sysname-acl-ipv4-adv-3000] rule 5 permit ip destination 192.168.0.0 0.0.0.255
[Sysname-GigabitEthernet1/0/1] nat server global 3000 inside 10.0.0.172
display nat all
display nat server
nat server-group
nat server rule
Use nat server rule global destination-ip inside to create an object group-based NAT server rule.
Use undo nat server rule to delete an object group-based NAT server mapping.
nat server rule rule-name global destination-ip object-group-name&<1-5> [ service object-group-name ] inside local-address [ local-port ] [ vrrp virtual-router-id ] [ disable ] [ counting ] [ description text ]
undo nat server rule rule-name
nat server rule rule-name global { destination-ip object-group-name&<1-5> | service object-group-name }
undo nat server rule rule-name global { destination-ip object-group-name&<1-5> | service object-group-name }
No object group-based NAT server mapping exists.
Interface view
context-admin
rule-name: Specifies a rule name. The name is a case-insensitive string of 1 to 63 characters, excluding hyphens (-) and percent signs (%). You must use the escape character (\) if you use a backslash (\) or quotation marks (") in the name.
global: Specifies the external network information that the internal server uses to provide services to the external network.
destination-ip object-group-name&<1-5>: Specifies a space-separated list of up to five address object group items. The object-group-name argument specifies the name of an address object group, a case-insensitive string of 1 to 5 characters. If spaces are included in the object group name, enclose the name in quotation marks, for example, "a 1".
service object-group-name: Specifies a service object group by its name, a case-insensitive string of 1 to 31 characters.
inside: Specifies the internal information of the server.
local-address: Specifies the private IP address of the internal server.
local-port: Specifies the private port number of the server. The private port number format can be one of the following:
disable: Disables the object group-based NAT Server rule.
description text: Specifies a description for the object group-based NAT Server rule. The text argument is a case-insensitive string of 1 to 63 characters.
When multiple object group-based NAT server rules are configured, the rule configured earlier has a higher priority. The match process of a packet stops when the packet matches a rule. Different object group-based NAT server rules can use the same address object group or service object group.
Before you use the nat server rule rule-name global destination-ip object-group-name or nat server rule rule-name global service object-group-name command, follow these restrictions and guidelines:
· Make sure the rule has been created.
· You cannot add duplicate address object groups to the same rule by using the nat server rule rule-name global destination-ip object-group-name command. If only one address object group is used by the rule, you cannot use the undo nat server rule rule-name global destination-ip object-group-name command to delete this address object group.
· Only one service object group can be used by one rule. If no service object group is specified when you create a rule, you can use the nat server rule rule-name global service object-group-name command to specify it. If a service object group has been specified when you create the rule, you cannot use this command to modify the service object group.
In a hot backup system collaborating with VRRP, when you configure an object group-based NAT server on the primary device in the hot backup system, specify a VRRP group facing the external network. If you do not perform the binding, the uplink Layer 3 device directly connected to the hot backup system might send downlink packets to the backup device, causing service anomalies.
Before you configure an object group-based NAT server rule, make sure the object groups to be used by the NAT server rule have been created.
Only IPv4 address object groups are supported, and the IPv4 address object groups cannot have excluded IPv4 addresses.
The private port number in the NAT server rule takes effect only when the protocol type is TCP or UDP for the service object group.
You can create a maximum of 4096 object group-based NAT server rules.
# Configure the NAT Server on GigabitEthernet 1/0/1 and use address object groups a1, a2, and a3 to match public IP addresses and use service object group b1 to match public ports.
[Sysname-GigabitEthernet1/0/1] nat server rule aaa global destination-ip a1 a2 a3 service b1 inside 1.1.1.1 80
# Configure the NAT Server on GigabitEthernet 1/0/1 and use address object group a1 to match public IP addresses, and then add address object groups a2 and a3 and service object group b1 to the rule.
[Sysname-GigabitEthernet1/0/1] nat server rule aaa global destination-ip a1 inside 1.1.1.1 80
[Sysname-GigabitEthernet1/0/1] nat server rule aaa global destination-ip a1 a2 service b1
display nat all
display nat server
nat server rule move
Use nat server rule move to change the priority of an ACL-based NAT server rule.
nat server rule move nat-rule-name1 { after | before } nat-rule-name2
Interface view
context-admin
This command is applicable only to named ACL-based NAT server rules.
# Move the ACL-based NAT server rule abc to the line before the ACL-based NAT server rule def.
[Sysname-GigabitEthernet1/0/1] nat server rule move abc before def
nat server
nat server-group
Use nat server-group to create an internal server group and enter its view, or enter the view of an existing internal server group.
Use undo nat server-group to delete an internal server group.
nat server-group group-id
undo nat server-group group-id
No internal server groups exist.
context-admin
group-id: Assigns an ID to the internal server group. The value range for this argument is 0 to 65535.
An internal server group can contain multiple members configured by the inside ip command.
# Create internal server group 1.
[Sysname] nat server-group 1
display nat all
display nat server-group
inside ip
nat server
nat session create-rate enable
Use nat session create-rate enable to enable statistics collection for NAT session creation rate.
Use undo nat session create-rate enable to disable statistics collection for NAT session creation rate.
Statistics collection for NAT session creation rate is disabled.
context-admin
This feature collects information about NAT session creation rates. To view the statistics, use the display nat statistics command.
# Enable statistics collection for NAT session creation rate.
[Sysname] nat session create-rate enable
nat static enable
Use nat static enable to enable static NAT on an interface.
Use undo nat static enable to disable static NAT on an interface.
nat static enable
Static NAT is disabled.
Interface view
context-admin
Static NAT mappings take effect on an interface only after static NAT is enabled on the interface.
# Configure an outbound static NAT mapping between private IP address 192.168.1.1 and public IP address 2.2.2.2, and enable static NAT on GigabitEthernet 1/0/1.
[Sysname] nat static outbound 192.168.1.1 2.2.2.2
[Sysname-GigabitEthernet1/0/1] nat static enable
display nat all
display nat static
nat static
nat static net-to-net
nat static inbound
Use nat static inbound to configure a one-to-one mapping for inbound static NAT.
Use undo nat static inbound to delete a one-to-one mapping for inbound static NAT.
nat static inbound global-ip [ vpn-instance global-vpn-instance-name ] local-ip [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ] [ description text ]
undo nat static inbound global-ip [ vpn-instance global-vpn-instance-name ] local-ip [ vpn-instance local-vpn-instance-name ]
No NAT mappings exist.
context-admin
global-ip: Specifies a public IP address.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the public IP address belongs. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public IP address does not belong to any VPN instance, do not specify this option.
local-ip: Specifies a private IP address.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the private IP address belongs. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the private IP address does not belong to any VPN instance, do not specify this option.
acl: Specifies an ACL to identify the internal hosts that can access the external network.
ipv4-acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
name ipv4-acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must start with an English letter and to avoid confusion, it cannot be all.
reversible: Enables reverse address translation for connections actively initiated from the internal network to the private IP address.
disable: Disables the one-to-one inbound static mapping. If you do not specify this keyword, the mapping is enabled.
counting: Enables NAT counting. The number of flows that use the address mapping is counted.
description text: Specifies a description for the one-to-one inbound static mapping. The text argument is a case-insensitive string of 1 to 63 characters.
When the source IP address of a packet from the external network to the internal network matches the global-ip, the source IP address is translated into the local-ip. When the destination IP address of a packet from the internal network to the external network matches the local-ip, the destination IP address is translated into the global-ip.
· If you do not specify an ACL, the source address of all incoming packets and the destination address of all outgoing packets are translated.
· If you specify an ACL and do not specify the reversible keyword, the source address of incoming packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the internal network to the private IP address.
· If you specify both an ACL and the reversible keyword, the source address of incoming packets permitted by the ACL is translated. If packets of connections actively initiated from the internal network to the private IP address are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
¡ Translates the destination IP address of the packet according to the mapping, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
Static NAT takes precedence over dynamic NAT when both are configured on an interface.
You can configure multiple inbound static NAT mappings by using the nat static inbound command and the nat static inbound net-to-net command.
The vpn-instance parameter is required if you deploy inbound static NAT in VPN networks. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
One-to-one mappings for inbound static NAT that are configured with the same priority value and an ACL are matched by using the ACLs in the mappings.
# Configure an inbound static NAT mapping between public IP address 2.2.2.2 and private IP address 192.168.1.1.
[Sysname] nat static inbound 2.2.2.2 192.168.1.1
display nat all
display nat static
nat static enable
Use nat static inbound net-to-net to configure a net-to-net mapping for inbound static NAT.
Use undo nat static inbound net-to-net to remove a net-to-net mapping for inbound static NAT.
nat static inbound net-to-net global-start-address global-end-address [ vpn-instance global-vpn-instance-name ] local local-network { mask-length | mask } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ]
undo nat static inbound net-to-net global-start-address global-end-address [ vpn-instance global-vpn-instance-name ] local local-network { mask-length | mask } [ vpn-instance local-vpn-instance-name ]
context-admin
global-start-address global-end-address: Specifies a public address range which can contain a maximum of 256 addresses. The global-end-address must not be lower than global-start-address. If they are the same, only one public address is specified.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the public IP addresses belong. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public IP addresses do not belong to any VPN instance, do not specify this option.
local-network: Specifies a private network address.
mask-length: Specifies the mask length of the private network address, in the range of 8 to 31.
mask: Specifies the mask of the private network address.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the private network address belongs. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the private network address does not belong to any VPN instance, do not specify this option.
reversible: Enables reverse address translation for connections actively initiated from the internal network to the private IP addresses.
disable: Disables the net-to-net inbound static mapping. If you do not specify this keyword, the mapping is enabled.
Specify a public network through a start address and an end address, and a private network through a private address and a mask.
When the source address of a packet from the external network matches the public address range, the source address is translated into a private address in the private address range. When the destination address of a packet from the internal network matches the private address range, the destination address is translated into a public address in the public address range.
The public end address cannot be greater than the greatest IP address in the subnet determined by the public start address and the private network mask. For example, if the private address is 2.2.2.0 with a mask 255.255.255.0 and the public start address is 1.1.1.100, the public end address cannot be greater than 1.1.1.255, the greatest IP address in the subnet 1.1.1.0/24.
· If you specify an ACL and do not specify the reversible keyword, the source address of incoming packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the internal network to the private IP addresses.
· If you specify both an ACL and the reversible keyword, the source address of incoming packets permitted by the ACL is translated. If packets of connections actively initiated from the internal network to the private IP addresses are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
Net-to-net mappings for inbound static NAT that are configured with the same priority value and an ACL are matched by using the ACLs in the mappings.
# Configure an inbound static NAT between public network address 202.100.1.0/24 and private network address 192.168.1.0/24.
[Sysname] nat static inbound net-to-net 202.100.1.1 202.100.1.255 local 192.168.1.0 24
display nat all
display nat static
nat static enable
nat static inbound net-to-net rule move
Use nat static inbound net-to-net rule move to change the priority of an inbound net-to-net static NAT rule.
nat static inbound net-to-net rule move nat-rule-name1 { after | before } nat-rule-name2
An inbound net-to-net static NAT rule appearing earlier on the rule list has a higher priority for packet matching.
context-admin
after: Moves the rule nat-rule-name1 to the line after the rule nat-rule-name2 (called the reference rule). The priority value of the reference rule is not changed. The priority value of the moved rule equals the priority value of the reference rule plus one.
before: Moves the rule nat-rule-name1 to the line before the rule nat-rule-name2. The priority value of the reference rule is not changed. The priority value of the moved rule equals the priority value of the reference rule minus one.
nat-rule-name2: Specifies the name of the NAT rule as a reference rule for the NAT rule to be moved.
# Move the inbound net-to-net static NAT rule abc to the line before the inbound net-to-net static NAT rule def.
[Sysname] nat static inbound net-to-net rule move abc before def
nat static inbound object-group
Use nat static inbound object-group to configure an object group-based inbound static NAT mapping.
Use undo nat static inbound object-group to remove an object group-based inbound static NAT mapping.
nat static inbound object-group global-object-group-name [ vpn-instance global-vpn-instance-name ] object-group local-object-group-name [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ disable ] [ counting ]
undo nat static inbound object-group global-object-group-name [ vpn-instance global-vpn-instance-name ]
context-admin
object-group global-object-group-name: Specifies an object group of public IPv4 addresses. The global-object-group-name argument is a case-insensitive string of 1 to 31 characters.
object-group local-object-group-name: Specifies an object group of private IPv4 addresses. The local-object-group-name argument is a case-insensitive string of 1 to 31 characters.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the private IP addresses belong. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the private IP addresses do not belong to any VPN instance, do not specify this option.
acl: Specifies an ACL to identify the packets that can use the mapping.
reversible: Enables reverse address translation. Reverse address translation applies to connections actively initiated by internal hosts to the external hosts. It uses the mapping to translate destination addresses for packets of these connections if the packets are permitted by ACL reverse matching.
disable: Disables the object group based inbound static mapping. If you do not specify this keyword, the mapping is enabled.
This command specifies public and private IP addresses through IPv4 address object groups.
When the source address of an income packet matches the public address object group, the source address is translated into a private address in the private address object group. When the destination address of an outgoing packet matches the private address object group, the destination address is translated into a public address in the public address object group.
When you specify object groups for an inbound static mapping, follow these restrictions and guidelines:
· The public or private IPv4 address object group can contain only one IPv4 address object.
· The quantity of IPv4 addresses in the private IPv4 address object group cannot be smaller than that in the public IPv4 address object group.
· The object in the private IPv4 address object group cannot be an address range.
· If the private IPv4 object group contains a host address, the host address cannot be on the same subnet as the interface configured with this mapping.
· One IPv4 address object group can only contain one host object or subnet object. Otherwise, the mapping does not take effect.
· A subnet object cannot have excluded addresses. Otherwise, the mapping does not take effect.
· If you do not specify an ACL, the source addresses of all incoming packets and the destination addresses of all outgoing packets are translated.
· If you specify an ACL and do not specify the reversible keyword, the source addresses of incoming packets permitted by the ACL are translated. The destination addresses of packets are not translated for connections actively initiated by internal hosts to the external hosts.
· If you specify both an ACL and the reversible keyword, the source addresses of incoming packets permitted by the ACL are translated. If packets of connections actively initiated by internal hosts to the external hosts are permitted by ACL reverse matching, the destination addresses are translated. ACL reverse matching works as follows:
Static NAT takes precedence over dynamic NAT when they are both configured on an interface.
You can configure multiple inbound static NAT mappings by using the nat static inbound , nat static inbound net-to-net , and nat static inbound object-group commands.
# Configure an object group-based inbound static NAT mapping between public IP address 2.2.2.2 and private IP address 192.168.1.1.
[Sysname] object-group ip address global
[Sysname-obj-grp-ip-global] network host address 2.2.2.2
[Sysname-obj-grp-ip-global] quit
[Sysname] object-group ip address local
[Sysname-obj-grp-ip-local] network host address 192.168.1.1
[Sysname-obj-grp-ip-local] quit
[Sysname] nat static inbound object-group global object-group local
display nat all
display nat static
nat static enable
nat static inbound rule move
Use nat static inbound rule move to change the priority of an inbound one-to-one static NAT rule.
nat static inbound rule move nat-rule-name1 { after | before } nat-rule-name2
context-admin
This command is applicable only to named inbound one-to-one static NAT rules.
A NAT rule appearing earlier on the rule list has a higher priority for packet matching.
# Move the inbound one-to-one static NAT rule abc to the line before the inbound one-to-one static NAT rule def.
[Sysname] nat static inbound rule move abc before def
nat static inbound
nat static outbound
Use nat static outbound to configure a one-to-one mapping for outbound static NAT.
Use undo nat static outbound to remove a one-to-one mapping for outbound static NAT.
nat static outbound local-ip [ vpn-instance local-vpn-instance-name ] global-ip [ vpn-instance global-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ vrrp virtual-router-id ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ] [ description text ]
undo nat static outbound local-ip [ vpn-instance local-vpn-instance-name ] global-ip [ vpn-instance global-vpn-instance-name ]
context-admin
acl: Specifies an ACL to define the destination IP addresses that internal hosts can access.
ipv4-acl-number: Specifies an ACL by its number in the range of 3000 to 3999.
reversible: Enables reverse address translation for connections actively initiated from the external network to the public IP address.
disable: Disables the one-to-one outbound static mapping. If you do not specify this keyword, the mapping is enabled.
description text: Specifies a description for the one-to-one outbound static mapping. The text argument is a case-insensitive string of 1 to 63 characters.
When the source IP address of an outgoing packet matches the local-ip, the IP address is translated into the global-ip. When the destination IP address of an incoming packet matches the global-ip, the destination IP address is translated into the local-ip.
· If you do not specify an ACL, the source address of all outgoing packets and the destination address of all incoming packets are translated.
· If you specify an ACL and do not specify the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the external network to the public IP address.
· If you specify both an ACL and the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. If packets of connections actively initiated from the external network to the public IP address are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
You can configure multiple outbound static NAT mappings by using the nat static outbound command and the nat static outbound net-to-net command.
The vpn-instance parameter is required if you deploy outbound static NAT in VPN networks. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
In a hot backup system collaborating with VRRP, when you configure a one-to-one mapping for outbound static NAT on the primary device in the hot backup system, specify a VRRP group facing the external network. If you do not perform the binding, the uplink Layer 3 device directly connected to the hot backup system might send downlink packets to the backup device, causing service anomalies.
One-to-one mappings for outbound static NAT that are configured with the same priority value and an ACL are matched by using the ACLs in the mappings.
# Configure an outbound static NAT mapping between public IP address 2.2.2.2 and private IP address 192.168.1.1.
# Configure outbound static NAT, and allow the internal user 192.168.1.1 to access the external network 3.3.3.0/24 by using the public IP address 2.2.2.2.
[Sysname] acl advanced 3001
[Sysname-acl-ipv4-adv-3001] rule permit ip destination 3.3.3.0 0.0.0.255
[Sysname-acl-ipv4-adv-3001] quit
[Sysname] nat static outbound 192.168.1.1 2.2.2.2 acl 3001
display nat all
display nat static
nat static enable
Use nat static outbound net-to-net to configure a net-to-net outbound static NAT mapping.
Use undo nat static outbound net-to-net to remove the specified net-to-net outbound static NAT mapping.
nat static outbound net-to-net local-start-address local-end-address [ vpn-instance local-vpn-instance-name ] global global-network { mask-length | mask } [ vpn-instance global-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ vrrp virtual-router-id ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ]
undo nat static outbound net-to-net local-start-address local-end-address [ vpn-instance local-vpn-instance-name ] global global-network { mask-length | mask } [ vpn-instance global-vpn-instance-name ]
context-admin
local-start-address local-end-address: Specifies a private address range which can contain a maximum of 256 addresses. The local-end-address must not be lower than local-start-address. If they are the same, only one private address is specified.
global-network: Specifies a public network address.
mask-length: Specifies the mask length of the public network address, in the range of 8 to 31.
mask: Specifies the mask of the public network address.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the public network address belongs. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public network address does not belong to any VPN instance, do not specify this option.
ipv4-acl-number: Specifies an ACL number in the range of 2000 to 3999.
reversible: Enables reverse address translation for connections actively initiated from the external network to the public IP addresses.
disable: Disables the net-to-net outbound static mapping. If you do not specify this keyword, the mapping is enabled.
Specify a private network through a start address and an end address, and a public network through a public address and a mask.
When the source address of a packet from the internal network matches the private address range, the source address is translated into a public address in the public address range. When the destination address of a packet from the external network matches the public address range, the destination address is translated into a private address in the private address range.
The private end address cannot be greater than the greatest IP address in the subnet determined by the private start address and the public network mask. For example, the public address is 2.2.2.0 with a mask 255.255.255.0, and the private start address is 1.1.1.100. The private end address cannot be greater than 1.1.1.255, the greatest IP address in the subnet 1.1.1.0/24.
When you specify an ACL, follow these restrictions and guidelines:
· If you specify an ACL and do not specify the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the external network to the public IP addresses.
· If you specify both an ACL and the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. If packets of connections actively initiated from the external network to the public IP addresses are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
¡ Compares the source IP address/port of a packet with the destination IP addresses/ports in the ACL.
In a hot backup system collaborating with VRRP, when you configure a net-to-net outbound static NAT mapping on the primary device in the hot backup system, specify a VRRP group facing the external network. If you do not perform the binding, the uplink Layer 3 device directly connected to the hot backup system might send downlink packets to the backup device, causing service anomalies.
Net-to-net mappings for outbound static NAT that are configured with the same priority value and an ACL are matched by using the ACLs in the mappings.
# Configure an outbound static NAT mapping between private network address 192.168.1.0/24 and public network address 2.2.2.0/24.
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24
# Configure outbound static NAT. Allow internal users on subnet 192.168.1.0/24 to access the external subnet 3.3.3.0/24 by using public IP addresses on subnet 2.2.2.0/24.
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24 acl 3001
display nat all
display nat static
nat static enable
nat static outbound net-to-net rule move
Use nat static outbound net-to-net rule move to change the priority of an outbound net-to-net static NAT rule.
nat static outbound net-to-net rule move nat-rule-name1 { after | before } nat-rule-name2
An outbound net-to-net static NAT rule appearing earlier on the rule list has a higher priority for packet matching.
context-admin
# Move the outbound net-to-net static NAT rule abc to the line before the outbound net-to-net static NAT rule def.
[Sysname] nat static outbound net-to-net rule move abc before def
nat static outbound object-group
Use nat static outbound object-group to configure an object group-based outbound static NAT mapping.
Use undo nat static outbound object-group to remove an object group-based outbound static NAT mapping.
nat static outbound object-group local-object-group-name [ vpn-instance local-vpn-instance-name ] object-group global-object-group-name [ vpn-instance global-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ vrrp virtual-router-id ] [ disable ] [ counting ]
undo nat static outbound object-group local-object-group-name [ vpn-instance local-vpn-instance-name ]
context-admin
reversible: Allows reverse address translation. Reverse address translation applies to connections actively initiated by external hosts to the internal hosts. It uses the mapping to translate destination addresses for packets of these connections if the packets are permitted by ACL reverse matching.
disable: Disables the object group based outbound static mapping. If you do not specify this keyword, the mapping is enabled.
When the source address of a packet from the private network matches the private address object group, the source address is translated into a public address in the public address object group. When the destination address of a packet from the public network matches the public address object group, the destination address is translated into a private address in the private address object group.
When you specify object groups for an outbound static mapping, follow these restrictions and guidelines:
· The quantity of IPv4 addresses in the private IPv4 address object group cannot be larger than that in the public IPv4 address object group.
· The object in the public IPv4 address object group cannot be an address range.
· An IPv4 address object group can only contain a host object or a subnet object. Otherwise, the mapping does not take effect.
· A subnet object cannot have excluded IPv4 addresses. Otherwise, the mapping does not take effect.
· If you do not specify an ACL, the source addresses of all outgoing packets and the destination addresses of all incoming packets are translated.
· If you specify an ACL and do not specify the reversible keyword, the source addresses of outgoing packets permitted by the ACL are translated. The destination addresses of packets are not translated for connections actively initiated by external hosts to the internal hosts.
· If you specify both an ACL and the reversible keyword, the source addresses of outgoing packets permitted by the ACL are translated. If packets of connections actively initiated by external hosts to the internal hosts are permitted by ACL reverse matching, the destination addresses are translated. ACL reverse matching works as follows:
You can configure multiple outbound static NAT mappings by using the nat static outbound, nat static outbound net-to-net, and nat static outbound object-group commands.
In a hot backup system collaborating with VRRP, when you configure an object group-based outbound static NAT mapping on the primary device in the hot backup system, specify a VRRP group facing the external network. If you do not perform the binding, the uplink Layer 3 device directly connected to the hot backup system might send downlink packets to the backup device, causing service anomalies.
# Configure an object group-based outbound static NAT mapping between private IP address 192.168.1.1 and public IP address 2.2.2.2.
[Sysname] nat static outbound object-group local object-group global
display nat all
display nat static
nat static outbound rule move
Use nat static outbound rule move to change the priority of an outbound one-to-one static NAT rule.
nat static outbound rule move nat-rule-name1 { after | before } nat-rule-name2
context-admin
nat-rule-name1: Specifies the name of the NAT rule to be moved.
This command is applicable only to named outbound one-to-one static NAT rules..
# Move the outbound one-to-one static NAT rule abc to the line before the outbound one-to-one static NAT rule def.
[Sysname] nat static outbound rule move abc before def
nat static outbound
nat timestamp delete
Use nat timestamp delete to enable the deletion of timestamps in TCP SYN and SYN ACK packets.
Use undo nat timestamp delete to restore the default.
nat timestamp delete [ vpn-instance vpn-instance-name ]
undo nat timestamp delete [ vpn-instance vpn-instance-name ]
The TCP SYN and SYN ACK packets carry the timestamp.
context-admin
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the TCP SYN and SYN ACK packets belong. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command applies to TCP SYN and SYN ACK packets on the public network.
With this feature configured, the system deletes the timestamps from the TCP SYN and SYN ACK packets after dynamic address translation.
If PAT mode is configured on an interface by using nat inbound or nat outbound, and the tcp_timestamp and tcp_tw_recycle function is configured on the TCP server, TCP connections might not be established. To solve the problem, you can shut down the tcp_tw_recycle function or configure the nat timestamp delete command.
You can enable this feature for multiple VPN instances by repeating the command with different VPN parameters.
# Enable the deletion of the timestamp for TCP SYN and SYN ACK packets on the public network.
[Sysname] nat timestamp delete
# Enable the deletion of the timestamp for TCP SYN and SYN ACK packets on the VPN instance aa.
[Sysname] nat timestamp delete vpn-instance aa
nat outbound
nat inbound
outbound-interface
Use outbound-interface to apply the NAT rule to the outgoing traffic on an interface.
Use undo outbound-interface to restore the default.
outbound-interface interface-type interface-number
A NAT rule is not applied to the outgoing traffic on an interface.
NAT rule view
context-admin
After you execute the command, the NAT rule applies to the outgoing traffic passing through the specified interface.
# Apply the NAT rule aaa to the outgoing traffic on GigabitEthernet 1/0/2.
<Sysname> system
[Sysname-nat-policy] rule name aaa
[Sysname-nat-policy-rule-aaa] outbound-interface gigabitethernet 1/0/2
display nat all
display nat policy
port-block
Use port block to configure port block parameters for a NAT address group.
Use undo port block to restore the default.
port block block-size block-size [ extended-block-number extended-block-number ]
undo port block
No port block parameters are configured for a NAT address group.
NAT address group view
context-admin
block-size block-size: Specifies the port block size. The value range for the block-size argument is 1 to 65535. In a NAT address group, the port block size cannot be larger than the number of ports in the port range.
extended-block-number extended-block-number: Specifies the number of extended port blocks, in the range of 1 to 5. When a private IP address accesses the public network, but the ports in the selected port block are all occupied, the NAT444 gateway extends port blocks one by one for the private IP address.
To configure dynamic port block mappings, port block parameters are required in the NAT address group. When a private IP address initiates a connection to the public network, the NAT444 gateway assigns it a public IP address and a port block, and creates an entry for the mapping. For subsequent connections from the private IP address, the NAT444 gateway translates the private IP address to the mapped public IP address and the ports to ports in the selected port block.
# Set the port block size to 256 and the number of extended port blocks to 1 in NAT address group 2.
[Sysname] nat address-group 2
[Sysname-address-group-2] port-block block-size 256 extended-block-number 1
nat address-group
port-range
Use port-range to specify a port range for public IP addresses.
Use undo port-range to restore the default.
port-range start-port-number end-port-number
undo port-range
The port range for public IP addresses is 1 to 65535.
NAT port block group view
context-admin
start-port-number end-port-number: Specifies the start port number and end port number for the port range. The end port number cannot be smaller than the start port number. As a best practice, set the start port number to be equal to or larger than 1024 to avoid an application protocol identification error.
The port range must include all ports that public IP addresses use for address translation.
The number of ports in a port range cannot be smaller than the port block size.
# Specify the port range as 1024 to 65535 for NAT address group 1.
[Sysname] nat address-group 1
[Sysname-address-group-1] port-range 1024 65535
# Specify the port range as 30001 to 65535 for NAT port block group 1.
[Sysname] nat port-block-group 1
[Sysname-port-block-group-1] port-range 30001 65535
nat address-group
probe
Use probe to specify a probe method for a NAT address group.
Use undo probe to cancel the probe method for a NAT address group.
probe template-name
undo probe template-name
No probe method is specified for a NAT address group.
context-admin
template-name: Specifies the name of an NQA template used for address probe. The name is a case-insensitive string of 1 to 32 characters.
The NAT address group probing uses an NQA template to detect the reachability of the addresses in the group.
The device periodically sends probe packets to the specified destination address in the NQA template. The source IP addresses in the probe packets are the IP addresses in the NAT address group.
· If the device receives a response packet for a probe, the probed source IP address can be used for address translation.
· If the device does not receive a response packet for a probe, the probed source IP address will be excluded from address translation temporarily. However, in the next NQA operation period, this excluded IP address is also probed. If a response is received in this round, the IP address can be used for address translation.
You can specify multiple NQA templates for one NAT address group. An IP address in the address group is identified as reachable as long as one probe for this IP address succeeds.
This command is applicable to NAT address groups used for outbound address translation. The manually configured excluded IP addresses are not probed.
When you configure NQA template for probing IP addresses in NAT address group, do not configure the source IP address in the template.
# Create NQA ICMP template 4, and specify it as the probe method for NAT address group 1.
[Sysname] nqa template icmp t4
[Sysname-nqatplt-icmp-t4] quit
[Sysname-lb-lgroup-lg] probe t4
display nat probe address-group
exclude-ip
nqa template (Network Management and Monitoring Command Reference)
reset nat count statistics
Use reset nat count statistics to clear NAT counting statistics.
reset nat count statistics { all | dynamic | global-policy | server | static | static-port-block }
context-admin
all: Clears all counting statistics for NAT mappings.
dynamic: Clears counting statistics for dynamic NAT mappings.
global-policy: Clears counting statistics for the global NAT policy.
server: Clears counting statistics for NAT server mappings.
static: Clears counting statistics for static NAT mappings.
static-port-block: Clears counting statistics for NAT444 mappings.
# Clear all counting statistics for static NAT mappings.
<Sysname> reset nat count statistics all
display nat inbound
display nat outbound
display nat outbound port-block-group
display nat port-block
display nat static
display nat server
reset nat periodic-statistics
Use reset nat periodic-statistics to clear periodic NAT statistics.
reset nat periodic-statistics [ slot slot-number ]
context-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears periodic NAT statistics for all member devices.
# Clear periodic NAT statistics of slot 1.
<Sysname> reset nat periodic-statistics slot 1
display nat periodic-statistics
reset nat session
Use reset nat session to clear NAT sessions.
reset nat session [ slot slot-number ]
context-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears NAT sessions for all member devices.
# Clear NAT sessions for the specified slot.
<Sysname> reset nat session slot 1
display nat session
rule move (interface-based NAT policy view)
Use rule move to rearrange NAT rules to change their priority.
rule move rule-name1 { after | before } [ rule-name2 ]
Interface-based NAT policy view
context-admin
rule-name1: Specifies the name of the NAT rule to be moved. The rule name is a case-insensitive string of 1 to 63 characters.
after: Places the rule rule-name1 after the rule rule-name2 (called the reference rule).
before: Places the rule rule-name1 before the reference rule.
rule-name2: Specifies the NAT rule as a reference rule. The rule name is a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the priority of rule-name1 changes as follows:
· If after is specified, the rule rule-name1 will have the lowest priority.
· If before is specified, the rule rule-name1 will have the highest priority.
You can execute this command to rearrange only existing NAT rules to change their priority.
# Place the NAT rule aaa before the NAT rule bbb in the interface-based NAT policy.
<Sysname> system
[Sysname] nat policy
[Sysname-nat-policy] rule move aaa before bbb
rule move (global NAT policy view)
rule move rule-name1 [ type { nat | nat64 | nat66 } ] { after | before } [ rule-name2 [ type { nat | nat64 | nat66 } ] ]
Global NAT policy view
context-admin
type: Specifies a NAT rule type.
nat: Specifies the IPv4-to-IPv4 address translation rule.
nat64: Specifies the rule for translation between IPv4 and IPv6 addresses.
nat66: Specifies the IPv6-to-IPv6 address translation rule.
· If before is specified, rule-name1 will have the highest priority.
The rule type is optional in this command. Specify an exact rule type if you specify the type keyword.
When you rearrange global NAT rules to change their priority, make sure all NAT rules containing destination address translation methods are before the NAT rules containing only source address translation methods.
· Do not place a NAT rule containing a destination address translation method after a NAT rule containing only a source address translation method.
· Do not place a NAT rule containing only a source address translation method before a NAT rule containing a destination address translation method.
# Place the NAT rule aaa before the NAT rule bbb in the global NAT policy.
<Sysname> system
[Sysname] nat global-policy
[Sysname-nat-global-policy] rule move aaa before bbb
display nat all
display nat policy
rule name
Use rule name to create a NAT rule and enter NAT rule view, or enter the view of an existing NAT rule.
Use undo rule name to delete the specified NAT rule.
Interface-based NAT policy view:
rule name rule-name
undo rule name rule-name
Global NAT policy view:
rule name rule-name [ type { nat | nat64 | nat66 } ]
No NAT rule exists.
context-admin
rule-name: Specifies the name of the NAT rule. The rule name is a case-insensitive string of 1 to 63 characters. Valid characters cannot include hyphens (-) and percent signs (%). If you want to use a backslash (\) or a quotation mark ("), you must enter the escape character (\) before the backslash or the quotation mark. If you want to include spaces in the string, you must enclose the name string in quotation marks ("), for example, "XXX XXX".
type: Specifies the type of NAT rules in the global NAT policy. If you do not specify this keyword, the NAT rule type is NAT.
nat: Specifies the NAT-type rules in the global NAT policy, which are used for translation between IPv4 addresses.
nat64: Specifies the NAT64-type rules in the global NAT policy, which are used for translation between IPv4 addresses and IPv6 addresses.
nat66: Specifies the NAT66-type rules in the global NAT policy, which are used for translation between IPv6 addresses or translation between IPv6 prefixes.
When you create, move, or modify the type of a NAT rule, follow these restrictions and guidelines:
· In a NAT policy, the priority of NAT rules are determined by the configuration order. A rule configured earlier has a higher priority. You can use the rule move command to rearrange the NAT rules. To view the priority order of the NAT rules in a policy, use the display nat policy command.
· You cannot repeatedly execute the rule name rule-name type command to modify the type of a NAT rule. To modify the type of a NAT rule, first use the undo rule name command to delete the NAT rule, and then execute the rule name rule-name type command to create a NAT rule.
· The interface-based NAT policy supports a maximum of 4096 NAT rules. The global NAT policy supports a maximum of 10000 NAT rules.
# In the interface-based NAT policy, create a NAT rule named aaa and enter its view.
<Sysname> system
# In the global NAT policy, create a NAT rule named aaa and enter its view.
<Sysname> system
[Sysname-nat-global-policy] rule name aaa
[Sysname-nat-global-policy-rule-aaa]
display nat all
display nat global-policy
display nat policy
rule move
service
Use service to specify a service object group for the NAT rule.
Use undo service to delete a service object group from a NAT rule.
undo service [ object-group-name ]
No service object group is specified for a NAT rule.
NAT rule view
context-admin
object-group-name: Specifies the name of a service object group. The name is a case-insensitive string of 1 to 31 characters, and it cannot be any. If spaces are included in the name, enclose the name in quotation marks ("), for example, "XXX XXX".
The NAT device uses the services specified in this command to identify matching packets. Only packets with the matching services are translated.
To translate source IP addresses of outgoing packets, use this command with the action snat command. To translate both the source IP address and destination IP address of incoming packets, use this command together with the action snat and action dnat commands.
The service object group must already exist.
If you do not specify a service object group in the undo service command, the command deletes all service object groups in the NAT rule.
A NAT rule can have a maximum of 256 service object groups.
# In the interface-based policy, specify NAT rule aaa to use service1, service2, and service3 as the service object groups.
<Sysname> system
[Sysname-nat-policy-rule-aaa] service service1
[Sysname-nat-policy-rule-aaa] service service2
[Sysname-nat-policy-rule-aaa] service service3
# In the global NAT policy, specify NAT rule aaa to use service1, service2, and service3 as the service object groups.
<Sysname> system
[Sysname-nat-global-policy-rule-aaa] service service1
[Sysname-nat-global-policy-rule-aaa] service service2
[Sysname-nat-global-policy-rule-aaa] service service3
display nat all
display nat policy
object-group (Security Command Reference)
source-ip
Use source-ip to specify a source IP address match criterion for a NAT rule.
Use undo source-ip to delete a source IP address match criterion from a NAT rule.
NAT-type rule view in the interface-based NAT policy:
source-ip ipv4-object-group-name
undo source-ip [ ipv4-object-group-name ]
NAT-type rule view in the global NAT policy:
source-ip { host ip-address | subnet subnet-ip-address mask-length }
undo source-ip { host [ ip-address ] | subnet [subnet-ip-address mask-length ] }
NAT64-type rule view in the global NAT policy:
source-ip { ipv4-object-group-name | ipv6-object-group-name }
undo source-ip [ ipv4-object-group-name | ipv6-object-group-name ]
source-ip { host { ipv4-address | ipv6-address } | subnet { subnet-ipv4-address mask-length | ipv6-prefix prefix-length } }
undo source-ip { host [ ipv4-address | ipv6-address ] | subnet [ ipv4-address mask-length | ipv6-prefix prefix-length ] }
NAT66-type rule view in the global NAT policy:
source-ip ipv6-object-group-name
undo source-ip [ ipv6-object-group-name ]
source-ip { host ipv6-address | subnet ipv6-prefix prefix-length }
undo source-ip { host ipv6-address | subnet ipv6-prefix prefix-length }
A NAT rule does not have any source IP address match criteria.
NAT rule view
context-admin
ipv4-object-group-name: Specifies the name of a source IPv4 address object group. The name is a case-insensitive string of 1 to 63 characters, and it cannot be any. If spaces are included in the name, enclose the name in quotation marks ("), for example, "XXX XXX".
ipv6-object-group-name: Specifies the name of a source IPv6 address object group. The name is a case-insensitive string of 1 to 63 characters, and it cannot be any. If spaces are included in the name, enclose the name in quotation marks ("), for example, "XXX XXX".
host ipv4-address: Specifies an IPv4 address to match source IPv4 address. The IPv4 address cannot be an all-zero address, all-one address, Class D address, Class E address, or loopback address.
host ipv6-address: Specifies an IPv6 address to match source IPv6 address.
subnet subnet-ipv4-address mask-length: Specifies a subnet to match source IPv4 addresses. The subnet-ipv4-address argument specifies the subnet address. The mask-length argument specifies the mask length, which can be 8, 16, or an integer in the range of 24 to 31.
subnet ipv6-prefix prefix-length: Specifies an IPv6 prefix for a NAT rule. The ipv6-prefix argument indicates an IPv6 prefix. The prefix-length argument indicates the prefix length in the range of 1 to 128.
The NAT device uses the source IP addresses specified in this command to identify matching packets. Only packets with the matching source IP addresses are translated.
When you reference an address object group, follow these restrictions and guidelines:
· The address object group must already exist.
· For an address object group to be successfully referenced by the source address translation method, make sure the objects in the referenced address object group are created through the following methods:
¡ [ object-id ] network host address ip-address
¡ [ object-id ] network subnet ip-address { mask-length | mask }
¡ [ object-id ] network range ip-address1 ip-address2
For more information about these commands, see object group commands in Security Command Reference.
If you do not specify any parameters in the undo source-ip command, the command deletes all source address match criteria in the NAT rule.
When you configure match criteria for a NAT rule, follow these restrictions and guidelines:
· A NAT rule can have a maximum of 256 source address object groups.
· If you configure multiple packet match criteria in a NAT64-type rule, the IP address type in the later configured packet match criteria must be the same as that in the earlier configured packet match criteria. For example, if you first execute the source-ip host 192.168.1.1 command, the source-ip host 100::1 command executed later does not take effect. Select an IP type as needed.
· If you execute the following commands in the same NAT rule, the most recent configuration takes effect:
¡ source-ip
¡ source-ip host
¡ source-ip subnet
# In the interface-based NAT policy, configure NAT rule aaa to use source address object groups desIP1, desIP2, and desIP3 as the packet match criteria.
<Sysname> system
[Sysname-nat-policy-rule-aaa] source-ip srcip1
[Sysname-nat-policy-rule-aaa] source-ip srcip2
[Sysname-nat-policy-rule-aaa] source-ip srcip3
# In the global NAT policy, configure NAT rule aaa to use source address object groups desIP1, desIP2, and desIP3 as the packet match criteria.
<Sysname> system
[Sysname-nat-global-policy-rule-aaa] source-ip srcip1
[Sysname-nat-global-policy -rule-aaa] source-ip srcip2
[Sysname-nat-global-policy -rule-aaa] source-ip srcip3
display nat all
display nat policy
source-zone
Use source-zone to specify a source security zone in a NAT rule.
Use undo source-zone to delete a source security zone from a NAT rule.
source-zone source-zone-name
undo source-zone [ source-zone-name ]
No source security zones are specified in a NAT rule.
NAT rule view
context-admin
source-zone-name: Specifies the name of a source security zone. The name is a case-insensitive string of 1 to 31 characters, and it cannot be any. You can specify a nonexistent security zone. This command takes effect after you use the security-zone name command to create the security zone. For more information about security zones, see Security Configuration Guide.
The NAT device uses the source security zones specified in this command to identify matching packets. Only packets with the matching source security zones are translated.
This command does not support modifying source security zones. To modify the source security zone for a NAT rule, first execute the undo destination-zone command to delete the zone, and then execute the destination-zone command to specify a new one.
If you do not specify a source security zone in the undo source-zone command, the command deletes all source security zones in the NAT rule.
This command is available only in NAT rule view of the global NAT policy.
A NAT rule can have a maximum of 16 source security zones.
# Specify source security zone trust for NAT rule rule1.
[Sysname-nat-global-policy] rule name rule1
[Sysname-nat-global-policy-rule-rule1] source-zone trust
security-zone name (Security Command Reference)
vrf
Use vrf to specify a VPN instance in a NAT rule.
Use undo vrf to delete a VPN instance from a NAT rule.
vrf vrf-name
undo vrf vrf-name
No VPN instances are specified in a NAT rule.
NAT rule view
context-admin
vrf-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
If you use this command together with the action snat command, it works as follows:
1. The NAT device uses the VPN instance to which the packet belongs to identify matching packets. Only packets with the matching VPN instances are translated. The NAT device records the VPN information in the mapping entry.
2. When the server in the external network replies to the internal host, the NAT device translates addresses according to the mapping entry and forwards the packets after source address translation to the internal host.
If you use this command together with the action dnat command, it works as follows:
2. When the internal server replies to the host in the external network, the NAT device translates addresses according to the mapping entry and forwards the packets after destination address translation to the host.
# Specify VPN instance vpn1 for NAT rule rule1.
<sysname> system-view
[sysname] nat global-policy
[sysname-nat-global-policy] rule name rule1
[sysname-nat-global-policy-rule-rule1] vrf vpn1
action dnat
action snat
vrrp vrid (interface-based NAT)
Use vrrp vrid to bind a VRRP group to a NAT address group or a NAT port block group.
Use undo vrrp vrid to restore the default.
vrrp vrid virtual-router-id
undo vrrp vrid
A NAT address group or a NAT port block group is not bound to any VRRP group.
context-admin
virtual-router-id: Specifies a VRRP group by its virtual router ID in the range of 1 to 255.
In a hot backup system collaborating with VRRP,, source address translation that uses a NAT address group or port block group assigns the public IP address after translation to the address management module. Both the active and standby devices advertise the mappings between the public IP address and MAC addresses of their own physical interfaces to all nodes in the same LAN. As a result, the uplink Layer 3 device directly connected to the hot backup system might send downlink packets to the backup device, causing service anomalies.
To avoid such an issue, bind the NAT address group or port block group to a VRRP group. Then, only the master device responds to ARP requests with the virtual MAC address of the VRRP group. The uplink Layer 3 device directly connected to the hot backup system sends downlink packets only to the master device.
# Bind VRRP group 1 to NAT address group 2.
[Sysname-address-group-2] vrrp vrid 1
display nat address-group
display nat port-block-group
nat address-group
vrrp vrid (High Availability Command Reference)
