06-Layer 3—IP Services Command Reference
HomeSupportNFVH3C VSRReference GuidesCommand ReferencesH3C VSR Series Virtual Services Routers Command References(V7)-R1340-6W10006-Layer 3—IP Services Command Reference
18-Tunneling commands
18-Tunneling commands 155.56 KB
Tunneling commands
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth (in kbps) is the interface maximum rate divided by 1000.
Tunnel interface view
bandwidth-value: Specifies the expected bandwidth, in the range of 1 to 400000000 kbps.
The expected bandwidth for an interface affects the link costs.
For more information, see OSPF, OSPFv3, and IS-IS in Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth for Tunnel 1 to 100 kbps.
[Sysname] interface tunnel 1
[Sysname-Tunnel1] bandwidth 100
default
Use default to restore the default settings for a tunnel interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands. Use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings of Tunnel 1.
[Sysname-Tunnel1] default
description
The description of a tunnel interface is Tunnelnumber Interface, for example, Tunnel1 Interface.
Configure descriptions for different interfaces for identification and management purposes.
You can use the display interface command to display the configured interface description.
# Configure the description of Tunnel 1 as tunnel1.
[Sysname-Tunnel1] description tunnel1
display interface tunnel
destination
Use destination to specify the destination address of a tunnel.
Use undo destination to restore the default.
destination { ipv4-address | ipv6-address | dhcp-alloc interface-type interface-number }
undo destination
No tunnel destination address is configured.
ipv4-address: Specifies the tunnel destination IPv4 address.
ipv6-address: Specifies the tunnel destination IPv6 address.
dhcp-alloc interface-type interface-number: Specifies an interface by its type and number to obtain AFTR's IPv6 address from DHCPv6 packets.
For a manual tunnel, you must configure the destination address. For an automatic tunnel, you do not need to configure the destination address.
The tunnel destination address must be the address of the receiving interface on the tunnel peer. It is used as the destination address of tunneled packets.
The destination address of a tunnel at the local end must be the source address of the tunnel at the peer end. The source address of the tunnel at the local end must be the destination address of the tunnel at the peer end.
Do not specify the same tunnel source and destination addresses for different tunnels on the same device.
For a B4 router to automatically establish a DS-Lite tunnel with an AFTR, configure DHCPv6 client, IPv6 DNS client, and the destination dhcp-alloc command on the B4 router. In addition, make sure a DHCPv6 server and an IPv6 DNS server (for dynamic DNS) exist in the network.
After receiving a DHCPv6 packet from the interface specified by the destination dhcp-alloc command, the B4 router performs the following operations:
1.     Obtains the domain name of the AFTR from the packet.
2.     Sends a name query to the IPv6 DNS server to obtain the AFTR's IPv6 address.
The server resolves the domain name to the IPv6 address of AFTR.
For more information about DHCPv6 server, DHCPv6 client, and IPv6 DNS, see Layer 3—IP Services Configuration Guide.
# Interface GigabitEthernet 1/0 on Sysname 1 uses IP address 193.101.1.1 and interface GigabitEthernet 1/0 on Sysname 2 uses IP address 192.100.1.1. Configure the tunnel source address as 193.101.1.1 and tunnel destination address as 192.100.1.1 for tunnel 1 on Sysname 1.
<Sysname1> system-view
[Sysname1] interface tunnel 1 mode gre
[Sysname1-Tunnel1] source 193.101.1.1
[Sysname1-Tunnel1] destination 192.100.1.1
# Configure the tunnel source address as 192.100.1.1 and tunnel destination address as 193.101.1.1 for tunnel 1 on Sysname 2.
<Sysname2> system-view
[Sysname2] interface tunnel 1 mode gre
[Sysname2-Tunnel1] source 192.100.1.1
[Sysname2-Tunnel1] destination 193.101.1.1
interface tunnel
ipv6 address dhcp-alloc
source
display ds-lite b4 information
Use display ds-lite b4 information to display information about the connected B4 routers on the AFTR, including the IPv6 addresses of the B4 routers, and the assigned tunnel IDs.
# (In standalone mode.) Display information about the connected B4 routers.
<Sysname> display ds-lite b4 information
 B4 address                                     Tunnel ID  Tunnel interface  Idle time
 1234:5678:1234:5678:abcd:abcd:efff:1234        0x00000023       1              12
 2000::100:1                                    0x80000013       2              13
 3000::2                                        0x00000015       3              8
 3001::2                                        0x00000032       --             15
Total B4 addresses: 4
# (In IRF mode.) Display information about the connected B4 routers.
Slot 0 Cpu 0:
 3000::2                                        0x00000015       3              2
 3001::2                                        0x00000032       --             --
Slot 1 Cpu 0:
 1234:5678:1234:5678:abcd:abcd:efff:ffff        0x00000125       1              12
 5000::100:1                                    0x80000010       5              13
Total B4 addresses: 2
B4 address
IPv6 address of the B4 router.
Tunnel ID
Tunnel ID that the IPv6 address of the B4 router maps to.
Tunnel interface
ID of the tunnel interface on the DS-Lite tunnel to which the mapping belongs.
When the tunnel to which the mapping belongs is removed or a tunnel with the same ID but different mode is created, this field displays hyphens (--).
Idle time
Remaining time in minutes for the mapping between the IPv6 address of the B4 router and tunnel ID.
When the mapping ages out but is still used by a session, this field displays hyphens (--).
Total B4 addresses
Number of IPv6 addresses of the B4 routers.
Use display interface tunnel to display tunnel interface information.
display interface [ tunnel [ number ] ] [ brief [ description | down ] ]
tunnel [ number ]: Specifies a tunnel interface. The number argument specifies the tunnel interface number. The specified tunnel interface must have been created. If you do not specify the tunnel keyword, this command displays information about all interfaces except VA interfaces on the device. For information about VA interfaces, see PPP in Layer 2—WAN Access Configuration Guide. If you specify the tunnel keyword without the number argument, this command displays information about all existing tunnel interfaces.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays information about interfaces in the physical state of DOWN and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display detailed information about Tunnel 1.
<Sysname> display interface tunnel 1
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64kbps
Maximum transmission unit: 1476
Tunnel source 2002::1:1 (Vlan-interface10), destination 2001::2:1
Tunnel TOS 0xC8, Tunnel TTL 255
Tunnel protocol/transport GRE/IPv6
    GRE key disabled
    Checksumming of GRE packets disabled
Tunnel1
Information about the tunnel interface Tunnel 1.
Current state
Physical link state of the tunnel interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     DOWN (Tunnel-Bundle administratively down)—The tunnel bundle interface to which the interface belongs has been shut down by using the shutdown command.
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces.
Description of the tunnel interface.
Bandwidth
Expected bandwidth of the tunnel interface.
MTU of the tunnel interface.
The tunnel interface is not assigned an IP address and cannot process IP packets.
IP address of the interface and type of the address in parentheses.
Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
·     DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3IP Services Configuration Guide.
·     BOOTP-allocatedBOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3IP Services Configuration Guide.
·     PPP-negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2WAN Access Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
·     MAD—IP address assigned to an IRF member device for MAD on the interface. For more information, see IRF configuration in Virtual Technologies Configuration Guide.
·     MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in IP Multicast Configuration Guide.
Tunnel source
Source address of the tunnel. If a source interface is specified, this field also displays the source interface in parentheses.
destination
Destination address of the tunnel.
Tunnel keepalive enabled, Period(50 s), Retries(3)
GRE keepalive is enabled. In this example, the keepalive interval is 50 seconds and the keepalive number is 3.
Tunnel TOS
ToS of tunneled packets.
Tunnel TTL
TTL of tunneled packets.
Tunnel mode and transport protocol:
·     CR_LSP—MPLS TE tunnel mode.
·     GRE/IP—GRE/IPv4 tunnel mode.
·     GRE/IPv6—GRE/IPv6 tunnel mode.
·     GRE P2MP—GRE/IPv4 P2MP tunnel mode.
·     GRE P2MP/IPv6—GRE/IPv6 P2MP tunnel mode.
·     GRE_ADVPN/IP—GRE-encapsulated IPv4 ADVPN tunnel mode.
·     GRE_ADVPN/IPv6—GRE-encapsulated IPv6 ADVPN tunnel mode.
·     UDP_ADVPN/IP—UDP-encapsulated IPv4 ADVPN tunnel mode.
·     UDP_ADVPN/IPv6—UDP-encapsulated IPv6 ADVPN tunnel mode.
·     IP/IP—IPv4 over IPv4 tunnel mode.
·     IPv6—IPv6 tunnel mode.
·     IPv6/IP—IPv6 over IPv4 manual tunnel mode.
·     IPv6/IP 6to4—IPv6 over IPv4 6to4 tunnel mode.
·     IPv6/IP auto-tunnel—Automatic IPv6 over IPv4 tunnel mode.
·     IPv6/IP ISATAP—IPv6 over IPv4 ISATAP tunnel mode.
·     IPSEC P2MP—IPsec P2MP tunnel mode.
·     DSLITE—DS-Lite tunnel mode on the AFTR.
·     Segment-Routing/IPv6—SRv6 tunnel mode.
·     UDP_VXLAN/IP—UDP-encapsulated IPv4 VXLAN tunnel mode.
·     UDP_VXLAN/IPv6—UDP-encapsulated IPv6 VXLAN tunnel mode.
·     UDP_VXLAN_DCI/IP—UDP-encapsulated IPv4 VXLAN-DCI tunnel mode.
·     UDP_VXLAN_DCI/IPv6—UDP-encapsulated IPv6 VXLAN-DCI tunnel mode.
·     NVE/IP—IPv4 NVE tunnel mode.
GRE key disabled
No GRE tunnel interface key is configured.
The GRE packet checksum feature is disabled.
Source port number is 18001
The source port number is 18001 in ADVPN packets sent by the UDP-encapsulated ADVPN tunnel interface.
Urgent output queue statistics:
Number of packets in the queue/maximum number of packets that the queue can contain/number of packets discarded in the queue.
Protocol output queue statistics:
FIFO output queue statistics:
When a CBQ or WFQ queue is configured, this field displays statistics for the CBQ or WFQ queue.
Last time when counters were cleared.
Average input rate in the last 300 seconds.
Average output rate in the last 300 seconds.
Total input packets, total input bytes, and total input packets dropped.
Total output packets, total output bytes, and total output packets dropped.
# Display brief information about Tunnel 1.
<Sysname> display interface tunnel 1 brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP     Description
Tun1                 UP   UP       1.1.1.1        Tunnel1
# Display brief information about Tunnel 1, including the complete interface description.
<Sysname> display interface tunnel 1 brief description
# Display information about interfaces in DOWN state and the causes.
<Sysname> display interface tunnel brief down
Interface            Link Cause
Tun0                  DOWN Not connected
Tun1                  DOWN Not connected
Abbreviated interface name.
Link
Physical link state of the interface:
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Description of the interface.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Not connected—The tunnel is not established.
·     DOWN (Tunnel-Bundle administratively down)—The tunnel bundle interface to which the tunnel interface belongs has been shut down by using the shutdown command.
destination
interface tunnel
source
ds-lite enable
Use ds-lite enable to enable DS-Lite tunneling on an interface.
Use undo ds-lite enable to disable DS-Lite tunneling on an interface.
ds-lite enable
undo ds-lite enable
DS-Lite tunneling is disabled on an interface.
Interface view
Use this command on the AFTR's interface connected to the public IPv4 network, so the AFTR can forward IPv4 packets to the B4 router through the DS-Lite tunnel.
You cannot enable DS-Lite tunneling on a DS-Lite tunnel interface on the AFTR.
# Enable DS-Lite tunneling on GigabitEthernet 1/0.
[Sysname] interface gigabitethernet 1/0
[Sysname-GigabitEthernet1/0] ds-lite enable
encapsulation-limit
Use encapsulation-limit to set the maximum number of nested encapsulations of a packet allowed on a tunnel interface.
Use undo encapsulation-limit to restore the default.
encapsulation-limit number
There is no limit to the nested encapsulations of a packet.
number: Specifies the number of nested encapsulations, in the range of 0 to 10.
A packet added with excessive headers becomes oversized. If it exceeds the MTU, it must be fragmented. The fragmentation decreases forwarding rate and increases processing complexity. To avoid this situation, use this command to limit the number of encapsulations.
This command is applicable only to IPv6 over IPv6 tunnels.
# Set the maximum number of nested encapsulations to 3 on Tunnel 1.
[Sysname] interface tunnel 1 mode ipv6
[Sysname-Tunnel1] encapsulation-limit 3
interface tunnel
Use interface tunnel to create a tunnel interface, specify the tunnel mode, and enter tunnel interface view, or enter the view of an existing tunnel interface.
Use undo interface tunnel to delete a tunnel interface.
interface tunnel number [ mode { advpn { gre | udp } [ ipv6 ] | ds-lite-aftr | gre [ ipv6 ] | gre-p2mp [ ipv6 ] | ipsec [ ipv6 ] | ipsec-p2mp | ipv4-ipv4 | ipv6 | ipv6-ipv4 [ 6to4 | auto-tunnel | isatap ] | mpls-te | nve | nvgre | sr ipv6 | { vxlan | vxlan-dci } [ ipv6 ] } ]
undo interface tunnel number
No tunnel interfaces exist.
number: Specifies the number of the tunnel interface. The value range is 0 to 65534. The number of tunnel interfaces that can be created is restricted by the total number of interfaces and the memory.
mode advpn gre: Specifies the GRE-encapsulated IPv4 ADVPN tunnel mode.
mode advpn udp: Specifies the UDP-encapsulated IPv4 ADVPN tunnel mode.
mode advpn gre ipv6: Specifies the GRE-encapsulated IPv6 ADVPN tunnel mode.
mode advpn udp ipv6: Specifies the UDP-encapsulated IPv6 ADVPN tunnel mode.
mode ds-lite-aftr: Specifies the DS-Lite tunnel mode on the AFTR.
mode gre: Specifies the GRE/IPv4 tunnel mode.
mode gre ipv6: Specifies the GRE/IPv6 tunnel mode.
mode gre-p2mp: Specifies the GRE/IPv4 P2MP tunnel mode.
mode gre-p2mp ipv6: Specifies the GRE/IPv6 P2MP tunnel mode.
mode ipsec: Specifies the IPsec/IPv4 tunnel mode.
mode ipsec ipv6: Specifies the IPsec/IPv6 tunnel mode.
mode ipsec-p2mp: Specifies the IPsec P2MP tunnel mode.
mode ipv4-ipv4: Specifies the IPv4 over IPv4 tunnel mode.
mode ipv6: Specifies the IPv6 tunnel mode. Set this mode for IPv4 over IPv6 manual and IPv6 over IPv6 tunnels.
mode ipv6-ipv4: Specifies the IPv6 over IPv4 manual tunnel mode.
mode ipv6-ipv4 6to4: Specifies the 6to4 tunnel mode.
mode ipv6-ipv4 auto-tunnel: Specifies the IPv4-compatible IPv6 automatic tunnel mode.
mode ipv6-ipv4 isatap: Specifies the ISATAP tunnel mode.
mode mpls-te: Specifies the MPLS TE tunnel mode.
mode nve: Specifies the NVE tunnel mode.
mode nvgre: Specifies the NVGRE tunnel mode.
mode sr ipv6: Specifies the SRv6 tunnel mode.
mode vxlan: Specifies the IPv4 VXLAN tunnel mode.
mode vxlan ipv6: Specifies the IPv6 VXLAN tunnel mode.
mode vxlan-dci: Specifies the IPv4 VXLAN-DCI tunnel mode.
mode vxlan-dci ipv6: Specifies the IPv6 VXLAN-DCI tunnel mode.
To create a new tunnel interface, you must specify the tunnel mode in this command. To enter the view of an existing tunnel interface, you do not need to specify the tunnel mode.
A tunnel interface number is locally significant. The tunnel interfaces on the two ends of a tunnel can use the same or different interface numbers.
# Create GRE/IPv4 tunnel interface Tunnel 1 and enter tunnel interface view.
[Sysname] interface tunnel 1 mode gre
[Sysname-Tunnel1]
destination
source
mtu
Use mtu to set the MTU on a tunnel interface.
mtu size
undo mtu
If the tunnel interface has never been up, the MTU is 64000 bytes.
If the tunnel interface is up, its MTU is identical to the outgoing interface's MTU minus the length of the tunnel headers. The outgoing interface is automatically obtained through routing table lookup based on the tunnel destination address.
size: Specifies the MTU, in the range of 100 to 64000 bytes.
After you configure an MTU for a tunnel interface, the configured MTU applies regardless of the tunnel interface status (up/down) and the outgoing interface MTU.
To avoid fragmentation after tunnel encapsulation, set the tunnel interface MTU no greater than the value of the outgoing interface MTU minus the length of the tunnel headers.
# Set the MTU on Tunnel 1 to 1000 bytes.
[Sysname-Tunnel1] mtu 1000
reset counters interface tunnel
Use reset counters interface tunnel to clear tunnel interface statistics.
reset counters interface [ tunnel [ number ] ]
tunnel [ number ]: Specifies a tunnel interface. The number argument specifies the tunnel interface number. If you do not specify the tunnel keyword, this command clears statistics for all interfaces except VA interfaces. If you specify the tunnel keyword without the number argument, this command clears statistics for all tunnel interfaces.
Use this command to clear old statistics so you can observe new traffic statistics on a tunnel interface.
# Clear statistics for Tunnel 1.
<Sysname> reset counters interface tunnel 1
shutdown
Use shutdown to shut down a tunnel interface.
Use undo shutdown to bring up a tunnel interface.
shutdown
A tunnel interface is not administratively down.
This command disconnects all links set up on the interface. Make sure you fully understand the impact of the command on your network.
# Shut down Tunnel 1.
[Sysname-Tunnel1] shutdown
source
Use source to specify the source address or source interface of a tunnel.
Use undo source to restore the default.
source { ipv4-address | ipv6-address | interface-type interface-number }
undo source
No source address or source interface is specified for a tunnel.
ipv4-address: Specifies the tunnel source IPv4 address.
ipv6-address: Specifies the tunnel source IPv6 address.
interface-type interface-number: Specifies the source interface by its type and number. The interface must be up and must have an IP address.
The specified source address or the address of the specified source interface is used as the source address of tunneled packets. To display the configured tunnel source address, use the display interface tunnel command.
You cannot specify the tunnel interface of the DS-Lite tunnel on the AFTR as the source interface.
# Specify GigabitEthernet 1/0 as the source interface of Tunnel 1.
[Sysname-Tunnel1] source gigabitethernet 1/0
# Specify 192.100.1.1 as the source address of Tunnel 1.
[Sysname-Tunnel1] source 192.100.1.1
destination
interface tunnel
tunnel dfbit enable
Use tunnel dfbit enable to set the Don't Fragment (DF) bit for tunneled packets.
Use undo tunnel dfbit enable to restore the default.
tunnel dfbit enable
The DF bit is not set for tunneled packets.
To avoid fragmentation and delay, set the DF bit for tunneled packets. Make sure the path MTU is larger than the tunneled packet length. To avoid discarding tunneled packets whose length is larger than the path MTU, do not set the DF bit.
This command is not supported on a GRE/IPv6 tunnel interface and an IPv6 tunnel interface.
# Set the DF bit for tunneled packets on Tunnel 1.
[Sysname-Tunnel1] tunnel dfbit enable
tunnel discard ipv4-compatible-packet
Use tunnel discard ipv4-compatible-packet to enable dropping IPv6 packets that use IPv4-compatible IPv6 addresses.
Use undo tunnel discard ipv4-compatible-packet to restore the default.
IPv6 packets that use IPv4-compatible IPv6 addresses are not dropped.
This command enables the device to check the source and destination IPv6 addresses of the de-encapsulated IPv6 packets from a tunnel. If a packet uses an IPv4-compatible IPv6 address as the source or destination address, the device discards the packet.
# Enable dropping IPv6 packets that use IPv4-compatible IPv6 addresses.
[Sysname] tunnel discard ipv4-compatible-packet
tunnel log updown with-tag
Use tunnel log updown with-tag to add the TUNNEL string to the PHY_UPDOWN log mnemonic for tunnel interfaces.
Use undo tunnel log updown with-tag to remove the TUNNEL string from the PHY_UPDOWN log mnemonic for tunnel interfaces.
The PHY_UPDOWN log mnemonic for tunnel interfaces does not contain the TUNNEL string.
This command adds the TUNNEL string to the PHY_UPDOWN log mnemonic for tunnel interfaces. Use this command if you want to identify the interface state change logs for tunnel interfaces by using a regular expression that contains the TUNNEL string.
A tunnel interface state change log without the TUNNEL string in the mnemonic:
%Jan 8 18:45:33:621 2011 H3C IFNET/3/PHY_UPDOWN: Physical state on the interface Tunnel1 changed to down.
A tunnel interface state change log with the TUNNEL string in the mnemonic:
%Jan 8 18:45:33:621 2011 H3C IFNET/3/TUNNEL_PHY_UPDOWN: Physical state on the interface Tunnel1 changed to down.
# Add the TUNNEL string to the PHY_UPDOWN log mnemonic for tunnel interfaces.
[Sysname] tunnel log updown with-tag
tunnel out-interface
Use tunnel out-interface to specify an output interface for tunneled packets.
Use undo tunnel out-interface to restore the default.
tunnel out-interface interface-type interface-number
No output interface is specified for tunneled packets of a tunnel interface. If ECMP routes exist, the device randomly selects an output interface to forward the tunneled packets.
Use this command to control the forwarding path of tunneled packets. To ensure successful packet forwarding, the specified output interface must meet the following requirements:
·     The interface is up.
·     The interface has an IP address.
·     The interface has a route to reach the destination.
This command is applicable only to IPv4 ADVPN, IPv6 ADVPN, GRE/IPv4, GRE/IPv6, and VXLAN tunnel interfaces.
# Specify GigabitEthernet 1/0 as the output interface of GRE packets on tunnel interface Tunnel 0.
[Sysname] interface tunnel 0 mode gre
[Sysname-Tunnel0] tunnel out-interface gigabitethernet 1/0
tunnel path-mtu enable
Use tunnel path-mtu enable to enable path MTU learning on a tunnel interface.
Use undo tunnel path-mtu enable to disable path MTU learning on a tunnel interface.
Path MTU learning is disabled on a tunnel interface.
If the size of a tunneled packet exceeds the MTU of an interface in the tunnel path, the packet will be discarded. With the path MTU learning feature, the tunnel source can adjust the MTU of the tunnel interface according to the MTU information in received ICMP destination unreachable messages. After MTU adjustment, the tunnel source will resend the oversized tunneled packets, improving the forwarding reliability of tunnel packets.
This command cannot be used together with the mtu command on a tunnel interface.
This command is supported only on GRE/IPv4, GRE/IPv6, and VXLAN tunnel interfaces.
If path MTU learning is enabled on a GRE/IPv4 tunnel interface and the passenger protocol is IPv6, make sure the MTU of all interfaces in the tunnel path is equal to or greater than 1312 bytes. If the MTU of an interface in the tunnel path is less than 1312 bytes, forwarding failure will occur.
If path MTU learning is enabled on a GRE/IPv6 tunnel interface and the passenger protocol is IPv6, make sure the MTU of all interfaces in the tunnel path is equal to or greater than 1332 bytes. If the MTU of an interface in the tunnel path is less than 1332 bytes, forwarding failure will occur.
# Enable path MTU learning on tunnel interface Tunnel 0.
[Sysname-Tunnel0] tunnel path-mtu enable
tunnel tos
Use tunnel tos to set the ToS of tunneled packets.
Use undo tunnel tos to restore the default.
tunnel tos { copy-inner-tos | tos-value }
undo tunnel tos
For VXLAN tunneled packets, the ToS is 0.
For non-VXLAN tunneled packets, the ToS is the same as the ToS of the original packets.
copy-inner-tos: Configures tunneled packets to use the ToS of the original packets. This keyword is supported only by VXLAN tunnels.
tos-value: Specifies the ToS of tunneled packets, in the range of 0 to 255.
After you execute this command, all the tunneled packets of different services sent on the tunnel interface will use the same configured ToS. For more information about ToS, see ACL and QoS Configuration Guide.
# Set the ToS of tunneled packets to 20 on Tunnel 1.
[Sysname-Tunnel1] tunnel tos 20
# Configure VXLAN tunnel interface Tunnel 2 to use the ToS of the original packets as the ToS of tunneled packets.
[Sysname] interface tunnel 2 mode vxlan
[Sysname-Tunnel2] tunnel tos copy-inner-tos
tunnel ttl
Use tunnel ttl to set the Time to Live (TTL) of tunneled packets.
Use undo tunnel ttl to restore the default.
tunnel ttl ttl-value
undo tunnel ttl
The TTL of tunneled packets is 255.
ttl-value: Specifies the TTL of tunneled packets, in the range of 1 to 255.
The TTL determines the maximum number of hops that the tunneled packets can pass. When the TTL expires, the tunneled packets are discarded to avoid loops.
# Set the TTL of tunneled packets to 100 on Tunnel 1.
[Sysname-Tunnel1] tunnel ttl 100
tunnel vpn-instance
Use tunnel vpn-instance to specify a VPN instance for the destination address of a tunnel interface.
Use undo tunnel vpn-instance to restore the default.
tunnel vpn-instance vpn-instance-name
The destination address of a tunnel interface belongs to the public network.
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
After this command is executed, the device looks up the routing table of the specified VPN instance to forward tunneled packets on the tunnel interface.
For a tunnel interface to come up, the tunnel source and destination must belong to the same VPN instance. To specify a VPN instance for the tunnel source, use the ip binding vpn-instance command on the tunnel source interface.
# Specify VPN instance vpn10 for the tunnel destination on Tunnel 1.
[Sysname] ip vpn-instance vpn10
[Sysname-vpn-instance-vpn10] route-distinguisher 1:1
[Sysname-vpn-instance-vpn10] vpn-target 1:1
[Sysname-vpn-instance-vpn10] quit
[Sysname-GigabitEthernet1/0] ip binding vpn-instance vpn10
[Sysname-GigabitEthernet1/0] ip address 1.1.1.1 24
[Sysname-GigabitEthernet1/0] quit
[Sysname-Tunnel1] destination 1.1.1.2
[Sysname-Tunnel1] tunnel vpn-instance vpn10
ip binding vpn-instance (MPLS Command Reference)
