06-Layer 3 - IP Routing Command Reference
HomeSupportReference GuidesCommand ReferencesH3C WA Series WLAN Access Points Command Reference-6W10006-Layer 3 - IP Routing Command Reference
02-IP Routing Basics Commands
02-IP Routing Basics Commands 42.15 KB
l          The models listed in this document are not applicable to all regions. Please consult your local sales office for the models applicable to your region.
l          Support of the H3C WA series WLAN access points (APs) for commands may vary by AP model. For more information, see Feature Matrix.
l          The interface types and the number of interfaces vary by AP model.
l          The term router in this document refers to both routers and APs configured with routing capabilities.
l          Support for IPv6 depends on the AP model.
IP Routing Basics Configuration Commands
display ip routing-table
display ip routing-table [ verbose ]
View
Default Level
1: Monitor level
verbose: Displays detailed routing table information, including that for inactive routes. With this keyword absent, the command displays only summary information about active routes.
Use the display ip routing-table command to display brief information about active routes in the routing table.
This command displays brief information about a routing table, with a routing entry contained in one line. The information displayed includes destination IP address/mask length, protocol, preference, cost, next hop and outbound interface. This command only displays the routes currently in use, that is, the optimal routes.
Use the display ip routing-table verbose command to display detailed information about all routes in the routing table.
This command displays detailed information about all active and inactive routes, including the statistics of the entire routing table and information for each route.
# Display brief information about active routes in the routing table.
<Sysname> display ip routing-table
Routing Tables: Public
         Destinations : 3        Routes : 3
127.0.0.1/32        Direct 0    0            127.0.0.1       InLoop0
192.168.0.0/24      Static 60   0            0.0.0.0         NULL0
Table 1-1 display ip routing-table command output description
Destinations
Number of destination addresses
Routes
Number of routes
Destination/Mask
Destination address/mask length
Proto
Protocol that presents the route
Pre
Priority of the route
Cost
Cost of the route
Nexthop
Address of the next hop on the route
Outbound interface for packets to be forwarded along the route
# Display detailed information about all routes in the routing table.
<Sysname> display ip routing-table verbose
Routing Table : Public
         Destinations : 5        Routes : 5
  Destination: 0.0.0.0/0
     Protocol: Static          Process ID: 0
   Preference: 60                    Cost: 0
      NextHop: 1.1.4.2          Interface:
    BkNexthop: 0.0.0.0        BkInterface:
  RelyNextHop: 0.0.0.0          Neighbor : 0.0.0.0
    Tunnel ID: 0x0                  Label: NULL
        State: Inactive Adv WaitQ     Age: 05h37m52s
          Tag: 0
  Destination: 1.1.1.0/24
      NextHop: 2.2.2.2          Interface:
        State: Inactive Adv WaitQ     Age: 05h04m52s
          Tag: 0
  Destination: 127.0.0.0/8
     Protocol: Direct          Process ID: 0
   Preference: 0                     Cost: 0
      NextHop: 127.0.0.1        Interface: InLoopBack0
        State: Active NoAdv           Age: 1d19h42m41s
          Tag: 0
  Destination: 127.0.0.1/32
        State: Active NoAdv           Age: 1d19h42m43s
          Tag: 0
  Destination: 192.168.0.0/24
      NextHop: 0.0.0.0          Interface: NULL0
        State: Active Adv             Age: 00h00m33s
          Tag: 0
Displayed first are statistics for the whole routing table, followed by detailed description of each route (in sequence).
Table 1-2 display ip routing-table verbose command output description
Destination
Protocol
Process ID
Process ID
Preference
Cost
Cost of the route
NextHop
BkNexthop
Address of the backup next hop
BkInterface
Backup interface
RelyNextHop
The next hop address obtained through routing stack.
Neighbour
Neighboring address determined by Routing Protocol
Tunnel ID
Tunnel ID
Label
Label
Route status:
Active
This is an active unicast route.
Adv
This route can be advertised.
Delete
This route is deleted.
Gateway
This is an indirect route.
Holddown
Number of holddown routes. Holddown is a route advertisement policy used in some distance vector (D-V) routing protocols, such as RIP, to avoid the propagation of some incorrect routes. It distributes a Holddown route during a period regardless of whether a new route to the same destination is found. For details, refer to corresponding routing protocols.
Int
The route was discovered by an Interior Gateway Protocol (IGP).
NoAdv
The route is not advertised when the router advertises routes based on policies.
NotInstall
Normally, among routes to a destination, the route with the highest preference is installed into the core routing table and advertised, while a NotInstall route cannot be installed into the core routing table but may be advertised.
Reject
The packets matching a Reject route will be dropped. Besides, the router sends ICMP unreachable messages to the sources of the dropped packets. The Reject routes are usually used for network testing.
Static
A static route is not lost when you perform the save operation and then restart the router. Routes configured manually are marked as static.
Unicast
Unicast routes
Inactive
Inactive routes
Invalid
Invalid routes
WaitQ
The route is the WaitQ during route recursion.
TunE
Tunnel
GotQ
The route is in the GotQ during route recursion.
Age
Time for which the route has been in the routing table, in the sequence of hour, minute, and second from left to right.
Tag
Route tag
display ipv6 routing-table
View
Default Level
1: Monitor level
None
Use the display ipv6 routing-table command to display brief routing table information, including destination IP address and prefix, protocol type, priority, metric, next hop and outbound interface.
The command displays only active routes, namely, the brief information about the current optimal routes.
# Display brief routing table information
<Sysname> display ipv6 routing-table
Routing Table :
        Destinations : 1        Routes : 1
Destination : ::1/128                           Protocol      : Direct
NextHop     : ::1                               Preference    : 0
Interface   : InLoop0                           Cost          : 0
Table 1-3 display ipv6 routing-table command output description
Destination
IPv6 address of the destination network/host
NextHop
Nexthop address
Preference
Route preference
Outbound interface
Protocol
Routing protocol
Cost
Route cost
display ipv6 routing-table verbose
View
Default Level
1: Monitor level
None
Use the display ipv6 routing-table verbose command to display detailed information about all active and inactive routes, including the statistics of the entire routing table and information for each route.
# Display detailed information about all active and inactive routes.
<Sysname> display ipv6 routing-table verbose
Routing Table :
Destination  : ::1                                     PrefixLength : 128
 Interface    : InLoopBack0                             Protocol     : Direct
 State        : Active                                  Cost         : 0
 Age          : 21659sec
Table 1-4 display ipv6 routing-table verbose command output description
Destination
Destination IPv6 address
PrefixLength
Prefix length of the address
Nexthop
Next hop
Preference
Routing preference
Outbound interface
Protocol
Routing protocol
State of the route, Active, Inactive, Adv (advertised), or NoAdv (not advertised)
Cost
Cost of the route
Age
Time that has elapsed since the route was generated
