- 01-Fundamentals Command Reference
- 01-Feature Matrix
- 02-CLI Command
- 03-Controlling Login Users Commands
- 04-File Management Commands
- 05-FTP and TFTP Commands
- 06-Device Management Commands
- 07-Basic System Configuration Commands
- 08-HTTP Commands
- 09-Logging In to the AP Commands
- 10-Command Index
| 01-Feature Matrix | 37.90 KB |
l The models listed in this document are not applicable to all regions. Please consult your local sales office for the models applicable to your region.
l Read this chapter before using an H3C WA series WLAN access point.
H3C WA series WLAN access points include the WA2200 series and WA2600 series. Table 1-1 shows the applicable models and software versions.
Table 1-1 Applicable models and software versions
Series |
Model |
Software version |
WA2200 series |
WA2200 series access points (indoors) |
WA2210-AG |
R 1115 |
WA2220-AG |
WA2200 series access points (outdoors) |
WA2210X-G |
WA2220X-AG |
WA2600 series |
WA2600 series access points (indoors) |
WA2610-AGN |
R 1106 |
WA2612-AGN |
WA2620-AGN |
WA2600 series access points (enhanced) |
WA2610E-AGN |
R 1109 |
WA2620E-AGN |
l Support of the H3C WA series WLAN access points for features, commands and parameters may vary by device model. See this document for more information.
l For information about feature support, see Table 2-1. For information about command and parameter support, see Table 3-1.
l The term AP in this document refers to common APs, wireless bridges, or mesh APs.
Document |
Feature |
WA2200 series |
WA2600 series |
Fundamentals Configuration Guide |
HTTPS |
Not supported |
Supported |
WLAN Configuration Guide |
802.11n radio mode |
Not supported |
Supported |
802.11n bandwidth mode |
Not supported |
Supported |
802.11n rate configuration |
Not supported |
Supported |
Layer 2 – LAN Switching Configuration Guide |
Optical Ethernet interface |
Supported on WA2210X-G/WA2220X-AG only |
Not supported |
GE interface |
Not supported |
Supported |
Layer 3 – IP Services Configuration Guide |
DHCP server configuration |
Not supported |
Supported |
DHCPv6 configuration |
Not supported |
Supported |
IP Multicast Configuration Guide |
IGMP snooping configuration |
Not supported |
Supported |
MLD snooping configuration |
Not supported |
Supported |
Security Configuration Guide |
SSH2.0 |
Not supported |
Supported |
Table 3-1 Command/Parameter matrix
Document |
Module |
Command/Parameter |
WA2200 series |
WA2600 series |
Fundamentals Command Reference |
HTTP commands |
display ip https |
Not supported |
Supported |
ip https acl |
Not supported |
Supported |
ip https certificate access-control-policy |
Not supported |
Supported |
ip https enable |
Not supported |
Supported |
WLAN Command Reference |
WLAN service commands |
a-mpdu enable |
Not supported |
Supported |
a-msdu enable |
Not supported |
Supported |
channel band-width |
Not supported |
Supported |
client dot11n-only |
Not supported |
Supported |
preamble { long | short } |
Only APs that support the 802.11b/g radio mode support this command. |
radio-type |
Keywords dot11an and dot11gn not supported |
Supported |
short-gi enable |
Not supported |
Supported |
WLAN RRM commands |
dot11a { disabled-rate | mandatory-rate | supported-rate } rate-value |
Only APs that support 802.11a radio mode support this command. |
dot11n mandatory maximum-mcs |
Not supported |
Supported |
dot11n support maximum-mcs |
Not supported |
Supported |
power-constraint power-constraint |
Only APs that support the 802.11a radio mode support this command. |
Layer 2 – LAN Switching Command Reference |
The maximum number of broadcast packets that can be forwarded on an Ethernet interface per second |
broadcast-suppression { ratio | pps max-pps } |
pps max-pps ranges from 1 to 148810. |
pps max-pps ranges from 1 to 1488100. |
The maximum number of multicast packets allowed on an Ethernet interface per second |
multicast-suppression { ratio | pps max-pps } |
The maximum number of unknown unicast packets allowed on an Ethernet interface per second |
unicast-suppression { ratio | pps max-pps } |
Layer 3 - IP Services Command Reference |
DHCP commands |
DHCP server configuration commands |
Not supported |
Supported |
DHCPv6 commands |
display ipv6 dhcp client [ interface interface-type interface-number ] |
Not supported |
Supported |
display ipv6 dhcp client statistics [ interface interface-type interface-number ] |
Not supported |
Supported |
display ipv6 dhcp duid |
Not supported |
Supported |
reset ipv6 dhcp client statistics [ interface interface-type interface-number ] |
Not supported |
Supported |
