10-High Availability Configuration Guide
HomeSupportSwitchesIE4520 SeriesConfigure & DeployConfiguration GuidesH3C IE4520 Switch Series Configuration Guides-R66xx-6W10010-High Availability Configuration Guide
01-Ethernet OAM configuration
01-Ethernet OAM configuration 187.13 KB
Configuring Ethernet OAM·· 1
About Ethernet OAM·· 1
Major functions of Ethernet OAM·· 1
Ethernet OAMPDUs· 1
How Ethernet OAM works· 1
Protocols and standards· 3
Restrictions and guidelines: Ethernet OAM configuration· 3
Ethernet OAM tasks at a glance· 4
Configuring basic Ethernet OAM functions· 4
Configuring the Ethernet OAM connection detection timers· 5
About the Ethernet OAM connection detection timers· 5
Restrictions and guidelines for configuring Ethernet OAM connection detection timers· 5
Configuring the Ethernet OAM connection detection timers globally· 5
Configuring the Ethernet OAM connection detection timers on a port 5
Configuring errored symbol event detection· 6
Restrictions and guidelines for configuring errored symbol event detection· 6
Configuring errored symbol event detection globally· 6
Configuring errored symbol event detection on a port 6
Configuring errored frame event detection· 7
Restrictions and guidelines for configuring errored frame event detection· 7
Configuring errored frame event detection globally· 7
Configuring errored frame event detection on a port 7
Configuring errored frame period event detection· 7
Restrictions and guidelines for configuring errored frame period event detection· 7
Configuring errored frame period event detection globally· 7
Configuring errored frame period event detection on a port 8
Configuring errored frame seconds event detection· 8
Restrictions and guidelines for configuring errored frame seconds event detection· 8
Configuring errored frame seconds event detection globally· 8
Configuring errored frame seconds event detection on a port 9
Configuring the action a port takes after it receives an Ethernet OAM event from the remote end· 9
Enabling Ethernet OAM remote loopback for a port 9
About Ethernet OAM remote loopback· 9
Restrictions and guidelines for enabling Ethernet OAM remote loopback· 10
Enabling Ethernet OAM remote loopback for a port in system view· 10
Enabling Ethernet OAM remote loopback for a port in interface view· 10
Rejecting the Ethernet OAM remote loopback request from a remote port 11
Display and maintenance commands for Ethernet OAM·· 11
Ethernet OAM configuration examples· 12
Example: Configuring Ethernet OAM·· 12
About Ethernet OAM
Ethernet Operation, Administration, and Maintenance (OAM) is a tool that monitors Layer 2 link status and addresses common link-related issues on the "last mile." Ethernet OAM improves Ethernet management and maintainability. You can use it to monitor the status of the point-to-point link between two directly connected devices.
Ethernet OAM provides the following functions:
·     Link performance monitoring—Monitors the performance indices of a link, including packet loss, delay, and jitter, and collects traffic statistics of various types.
·     Fault detection and alarm—Checks the connectivity of a link by sending OAM protocol data units (OAMPDUs) and reports to the network administrators when a link error occurs.
·     Remote loopback—Checks link quality and locates link errors by looping back OAMPDUs.
Ethernet OAMPDUs
Ethernet OAM operates on the data link layer. Ethernet OAM reports the link status by periodically exchanging OAMPDUs between devices, so that the administrator can effectively manage the network.
Ethernet OAMPDUs include the following types shown in Table 1.
Table 1 Functions of different types of OAMPDUs
OAMPDU type
Function
Information OAMPDU
Used for transmitting state information of an Ethernet OAM entity, including the information about the local device and remote devices, and customized information, to the remote Ethernet OAM entity, and maintaining OAM connections.
Event Notification OAMPDU
Used by link monitoring to notify the remote OAM entity when it detects problems on the link in between.
Loopback Control OAMPDU
Used for remote loopback control. By inserting the information used to enable/disable loopback to a loopback control OAMPDU, you can enable/disable loopback on a remote OAM entity.
Throughout this document, an Ethernet OAM-enabled port is called an Ethernet OAM entity or an OAM entity.
This section describes the working procedures of Ethernet OAM.
Ethernet OAM connection establishment
OAM connection establishment is also known as the Discovery phase, where an Ethernet OAM entity discovers the remote OAM entity to establish a session.
In this phase, two connected OAM entities exchange Information OAMPDUs to advertise their OAM configuration and capabilities to each other for a comparison. If their Loopback, link detection, and link event settings match, the OAM entities establish an OAM connection.
An OAM entity operates in active mode or passive mode. OAM entities in active mode initiate OAM connections, and OAM entities in passive mode wait and respond to the OAM connection requests. To set up an OAM connection between two OAM entities, you must set at least one entity to operate in active mode.
Table 2 shows the actions that a device can perform in different modes.
Table 2 Active Ethernet OAM mode and passive Ethernet OAM mode
Item
Passive Ethernet OAM mode
Initiating OAM Discovery
Available
Unavailable
Responding to OAM Discovery
Available
Available
Transmitting Information OAMPDUs
Available
Available
Transmitting Event Notification OAMPDUs
Available
Available
Transmitting Information OAMPDUs without any TLV
Available
Available
Transmitting Loopback Control OAMPDUs
Available
Unavailable
Responding to Loopback Control OAMPDUs
Available
Available
After an Ethernet OAM connection is established, the Ethernet OAM entities exchange Information OAMPDUs at the handshake packet transmission interval to detect the availability of the Ethernet OAM connection. If an Ethernet OAM entity receives no Information OAMPDU within the Ethernet OAM connection timeout time, the Ethernet OAM connection is considered disconnected.
Link monitoring
Error detection in an Ethernet is difficult, especially when the physical connection in the network is not disconnected, but network performance is degrading gradually.
Link monitoring detects link faults in various environments. Ethernet OAM entities monitor link status by exchanging Event Notification OAMPDUs. When detecting one of the link error events listed in Table 3, an OAM entity sends an Event Notification OAMPDU to its peer OAM entity. The network administrator can keep track of network status changes by retrieving the log.
Table 3 Ethernet OAM link error events
Ethernet OAM link events
Errored symbol event
An errored symbol event occurs when the number of detected symbol errors in the detection window (specified number of received symbols) exceeds the predefined threshold.
Errored frame event
An errored frame event occurs when the number of detected error frames in the detection window (specified detection interval) exceeds the predefined threshold.
Errored frame period event
An errored frame period event occurs when the number of frame errors in the detection window (specified number of received frames) exceeds the predefined threshold.
Errored frame seconds event
An errored frame seconds event occurs when the number of errored frame seconds (the second in which an errored frame appears is called an errored frame second) detected on a port in the detection window (specified detection interval) reaches the predefined threshold.
Remote fault detection
Information OAMPDUs are exchanged periodically among Ethernet OAM entities across established OAM connections. When traffic is interrupted due to device failure or unavailability, the Ethernet OAM entity at the faulty end sends error information to its peer. The Ethernet OAM entity uses the flag field in Information OAMPDUs to indicate the error information (any critical link event type as shown in Table 4). You can use the log information to track ongoing link status and troubleshoot problems promptly.
Table 4 Critical link events
OAMPDU transmission frequencies
Link Fault
Peer link signal is lost.
Once per second.
Dying Gasp
An unexpected fault, such as power failure, occurred.
Non-stop.
Critical Event
An undetermined critical event happened.
Non-stop.
Remote loopback
Remote loopback is available only after the Ethernet OAM connection is established. With remote loopback enabled, the Ethernet OAM entity in active mode sends non-OAMPDUs to its peer. After receiving these frames, the peer does not forward them according to their destination addresses. Instead, it returns them to the sender along the original path.
Remote loopback enables you to check the link status and locate link failures. Performing remote loopback periodically helps to detect network faults promptly. Furthermore, performing remote loopback by network segments helps to locate network faults.
IEEE 802.3ah, Carrier Sense Multiple Access with Collision Detection (CSMA/CD) Access Method and Physical Layer Specifications
The device's support for sending and receiving Information OAMPDUs carrying critical link events is as follows:
·     Can receive Information OAMPDUs carrying the critical link events listed in Table 4.
·     Can send Information OAMPDUs carrying Link Fault events.
·     Can send Information OAMPDUs carrying Dying Gasp events when the device is rebooted or relevant ports are manually shut down. Physical IRF ports, however, are unable to send this type of OAMPDUs.
·     Cannot send Information OAMPDUs carrying Critical Events.
To configure Ethernet OAM, perform the following tasks:
1.     Configuring basic Ethernet OAM functions
2.     (Optional.) Configuring the Ethernet OAM connection detection timers
3.     (Optional.) Configuring link event detection
¡     Configuring errored symbol event detection
¡     Configuring errored frame event detection
¡     Configuring errored frame period event detection
¡     Configuring errored frame seconds event detection
4.     (Optional.) Configuring the action a port takes after it receives an Ethernet OAM event from the remote end
5.     (Optional.) Configuring Ethernet OAM remote loopback
¡     Enabling Ethernet OAM remote loopback for a port
¡     Rejecting the Ethernet OAM remote loopback request from a remote port
To set up an Ethernet OAM connection between two Ethernet OAM entities, you must set at least one entity to operate in active mode. An Ethernet OAM entity can initiate OAM connection only in active mode.
To change the Ethernet OAM mode on an Ethernet OAM-enabled port, first disable Ethernet OAM on the port.
System-view
2.     Enter Layer 2/Layer 3 Ethernet port view.
3.     Set the Ethernet OAM mode.
oam mode { active | passive }
The default is active Ethernet OAM mode.
4.     Enable Ethernet OAM.
oam enable
Ethernet OAM is disabled by default.
By adjusting the handshake packet transmission interval and the connection timeout timer, you can change the detection time resolution for Ethernet OAM connections.
When you configure Ethernet OAM, follow these restrictions and guidelines:
·     You can configure this command in system view or port view. The configuration in system view takes effect on all ports, and the configuration in port view takes effect on the specified port. For a port, the configuration in port view takes precedence.
·     After the timeout timer of an Ethernet OAM connection expires, the local OAM entity ages out and terminates its connection with the peer OAM entity. To keep the Ethernet OAM connections stable, set the connection timeout timer to be at least five times the handshake packet transmission interval.
System-view
2.     Configure the Ethernet OAM handshake packet transmission interval.
oam global timer hello interval
The default is 1000 milliseconds.
3.     Configure the Ethernet OAM connection timeout timer.
oam global timer keepalive interval
The default is 5000 milliseconds.
System-view
3.     Configure the Ethernet OAM handshake packet transmission interval.
oam timer hello interval
By default, an interface uses the value configured globally.
4.     Configure the Ethernet OAM connection timeout timer.
oam timer keepalive interval
You can configure this function in system view or port view. The configuration in system view takes effect on all ports, and the configuration in port view takes effect on the specified port. For a port, the configuration in port view takes precedence.
2.     Configure the errored symbol event detection window.
oam global errored-symbol-period window window-value
By default, the errored symbol event detection window is 100000000.
3.     Configure the errored symbol event triggering threshold.
oam global errored-symbol-period threshold threshold-value
By default, the errored symbol event triggering threshold is 1.
3.     Configure the errored symbol event detection window.
oam errored-symbol-period window window-value
4.     Configure the errored symbol event triggering threshold.
oam errored-symbol-period threshold threshold-value
2.     Configure the errored frame event detection window.
oam global errored-frame window window-value
By default, the errored frame event detection window is 1000 milliseconds.
3.     Configure the errored frame event triggering threshold.
oam global errored-frame threshold threshold-value
By default, the errored frame event triggering threshold is 1.
3.     Configure the errored frame event detection window.
oam errored-frame window window-value
4.     Configure the errored frame event triggering threshold.
oam errored-frame threshold threshold-value
2.     Configure the errored frame period event detection window.
oam global errored-frame-period window window-value
By default, the errored frame period event detection window is 10000000.
3.     Configure the errored frame period event triggering threshold.
oam global errored-frame-period threshold threshold-value
By default, the errored frame period event triggering threshold is 1.
3.     Configure the errored frame period event detection window.
oam errored-frame-period window window-value
4.     Configure the errored frame period event triggering threshold.
oam errored-frame-period threshold threshold-value
·     You can configure this function in system view or port view. The configuration in system view takes effect on all ports, and the configuration in port view takes effect on the specified port. For a port, the configuration in port view takes precedence.
·     Make sure the errored frame seconds triggering threshold is less than the errored frame seconds detection window. Otherwise, no errored frame seconds event can be generated.
2.     Configure the errored frame seconds event detection window.
oam global errored-frame-seconds window window-value
By default, the errored frame seconds event detection window is 60000 milliseconds.
3.     Configure the errored frame seconds event triggering threshold.
oam global errored-frame-seconds threshold threshold-value
By default, the errored frame seconds event triggering threshold is 1.
3.     Configure the errored frame seconds event detection window.
oam errored-frame-seconds window window-value
4.     Configure the errored frame seconds event triggering threshold.
oam errored-frame-seconds threshold threshold-value
This feature enables a port to log events and automatically terminate the OAM connection and set the link state to down.
3.     Configure the action the port takes after it receives an Ethernet OAM event from the remote end.
oam remote-failure { connection-expired | critical-event | dying-gasp | link-fault } action error-link-down
By default, the port only logs the Ethernet OAM event it receives from the remote end.
CAUTION
CAUTION:
Use this feature with caution, because enabling Ethernet OAM remote loopback impacts other services.
When you enable Ethernet OAM remote loopback on a port, the port sends Loopback Control OAMPDUs to a remote port. After receiving the Loopback Control OAMPDUs, the remote port enters the loopback state. The remote port then returns any packets sent from the local port except OAMPDUs. By observing how many of these packets return, you can calculate the packet loss ratio on the link and evaluate the link performance.
·     Ethernet OAM remote loopback is available only after the Ethernet OAM connection is established. It can be performed only by Ethernet OAM entities operating in active Ethernet OAM mode.
·     Remote loopback is available only on full-duplex links that support remote loopback at both ends.
·     Ethernet OAM remote loopback must be supported by both the remote port and the sending port.
·     Enabling Ethernet OAM remote loopback interrupts data communications. After Ethernet OAM remote loopback is disabled, all the ports involved will go down and then come up. Ethernet OAM remote loopback can be disabled by any of the following events:
¡     Disabling Ethernet OAM.
¡     Disabling Ethernet OAM remote loopback.
¡     Timeout of the Ethernet OAM connection.
·     Enabling internal loopback test on a port in remote loopback test can terminate the remote loopback test. For more information about loopback test, see Layer 2—LAN Switching Configuration Guide.
·     You can enable Ethernet OAM remote loopback on a specific port in user view, system view, or Ethernet port view. The configuration effects are the same.
1.     (Optional.) Enter system view.
You can also perform this task in user view.
2.     Enable Ethernet OAM remote loopback for a port.
oam remote-loopback start interface interface-type interface-number
By default, Ethernet OAM remote loopback is disabled.
3.     Enable Ethernet OAM remote loopback on the port.
The Ethernet OAM remote loopback feature impacts other services. To solve this problem, you can disable a port from being controlled by the Loopback Control OAMPDUs sent by a remote port. The local port then rejects the Ethernet OAM remote loopback request from the remote port.
This feature does not affect the ongoing remote loopback test on the port. It takes effect when the next remote loopback starts on the port.
3.     Reject the Ethernet OAM remote loopback request from a remote port.
oam remote-loopback reject-request
By default, a port does not reject the Ethernet OAM remote loopback request from a remote port.
Execute display commands in any view and reset commands in user view:
Display information about an Ethernet OAM connection.
display oam { local | remote } [ interface interface-type interface-number ]
Display Ethernet OAM configuration.
display oam configuration [ interface interface-type interface-number ]
Display the statistics on critical events after an Ethernet OAM connection is established.
display oam critical-event [ interface interface-type interface-number ]
Display the statistics on Ethernet OAM link error events after an Ethernet OAM connection is established.
display oam link-event { local | remote } [ interface interface-type interface-number ]
Clear statistics on Ethernet OAM packets and Ethernet OAM link error events.
reset oam [ interface interface-type interface-number ]
On the network shown in Figure 1, perform the following operations:
·     Enable Ethernet OAM on Device A and Device B to auto-detect link errors between the two devices
·     Determine the performance of the link between Device A and Device B by collecting statistics about the error frames received by Device A
Figure 1 Network diagram
1.     Configure Device A:
# Configure GigabitEthernet 1/0/1 to operate in active Ethernet OAM mode, and enable Ethernet OAM for it.
[DeviceA-GigabitEthernet1/0/1] oam mode active
[DeviceA-GigabitEthernet1/0/1] oam enable
# Set the errored frame event detection window to 20000 milliseconds, and set the errored frame event triggering threshold to 10.
[DeviceA-GigabitEthernet1/0/1] oam errored-frame window 200
[DeviceA-GigabitEthernet1/0/1] oam errored-frame threshold 10
2.     Configure Device B:
# Configure GigabitEthernet 1/0/1 to operate in passive Ethernet OAM mode (the default), and enable Ethernet OAM for it.
[DeviceB-GigabitEthernet1/0/1] oam mode passive
[DeviceB-GigabitEthernet1/0/1] oam enable
Use the display oam critical-event command to display the statistics of Ethernet OAM critical link events. For example:
# Display the statistics of Ethernet OAM critical link events on all the ports of Device A.
[DeviceA] display oam critical-event
-----------[GigabitEthernet1/0/1] -----------
 Local link status   : UP
 Event statistics
   Link fault        : Not occurred
   Dying gasp        : Not occurred
   Critical event    : Not occurred
The output shows that no critical link event occurred on the link between Device A and Device B.
Use the display oam link-event command to display the statistics of Ethernet OAM link events. For example:
# Display Ethernet OAM link event statistics of the local end of Device A.
[DeviceA] display oam link-event local
------------ [GigabitEthernet1/0/1] -----------
 Link status: UP
 OAM local errored frame event
   Event time stamp        : 5789 x 100 milliseconds
   Errored frame window    : 200 x 100 milliseconds
   Errored frame threshold : 10 error frames
   Errored frame           : 13 error frames
   Error running total     : 350 error frames
   Event running total     : 17 events
¡     350 errors occurred after Ethernet OAM is enabled on Device A.
¡     17 errors were caused by error frames.
¡     The link is unstable.
