| 07-sFlow Configuration Examples | 135.43 KB |
Introduction
This document provides sFlow configuration examples.
This document assumes that you have basic knowledge of sFlow.
When you configure sFlow, follow these restrictions and guidelines:
· You can specify only the random sampling mode (the default).
· For the remote sFlow collector to receive sFlow packets, the IP address of the sFlow collector specified on the sFlow agent must be the same with that of the remote sFlow collector.
· If the number of packets sampled by an interface is too much in a heavy traffic network, increase the flow sampling interval. If an interface samples insufficient packets in a light traffic network, decrease the flow sampling interval.
· If an interface collects data too frequently in a heavy traffic network, increase the counter sampling interval. If the sampling statistics is not accurate in a light traffic network, decrease the counter sampling interval.
Example: Configuring sFlow
As shown in Figure 1, perform the following tasks:
· Configure flow sampling to sample packets on Device A and Device B.
· Configure counter sampling to periodically collect the counter information on Device A and Device B.
Analysis
To obtain interface counter information and packet information, you must configure both flow sampling and counter sampling.
Hardware |
Software version |
S6550X-HI switch series |
Release 1116 and later, Release 1213P51 and later |
S6880 switch series |
S9820-8M switch |
S5580X-HI switch series |
Release 1213P50 and later |
S5580X-EI switch series |
S5580S-EI switch series |
S9855 switch series |
Release 9126 and later |
S9825 switch series |
Procedures
Configuring Device A
# Create VLAN 10. Assign Twenty-FiveGigE 1/0/1 through Twenty-FiveGigE 1/0/3 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port twenty-fivegige 1/0/1 to twenty-fivegige 1/0/3
[DeviceA-vlan10] quit
# Assign an IP address to VLAN-interface 10.
[DeviceA-Vlan-interface10] ip address 10.1.1.1 255.255.255.0
# Assign IP addresses to other interfaces. (Details not shown.)
# Assign an IP address to the sFlow agent.
[DeviceA] sflow agent ip 10.1.1.1
# Specify the sFlow collector ID as 1, IP address as 30.1.1.2, and port number as 5000.
[DeviceA] sflow collector 1 ip 30.1.1.2 port 5000
# Enable counter sampling and set the counter sampling interval to 120 seconds on Twenty-FiveGigE 1/0/1.
[DeviceA] interface twenty-fivegige 1/0/1
[DeviceA-Twenty-FiveGigE1/0/1] sflow counter interval 120
# Specify sFlow collector 1 for counter sampling on Twenty-FiveGigE 1/0/1.
[DeviceA-Twenty-FiveGigE1/0/1] sflow counter collector 1
[DeviceA-Twenty-FiveGigE1/0/1] quit
# Enable counter sampling and set the counter sampling interval to 120 seconds on Twenty-FiveGigE 1/0/2.
[DeviceA] interface twenty-fivegige 1/0/2
[DeviceA-Twenty-FiveGigE1/0/2] sflow counter interval 120
# Specify sFlow collector 1 for counter sampling on Twenty-FiveGigE 1/0/2.
[DeviceA-Twenty-FiveGigE1/0/2] sflow counter collector 1
[DeviceA-Twenty-FiveGigE1/0/2] quit
# Enable flow sampling and set the sampling interval to 10000 on Twenty-FiveGigE 1/0/1.
[DeviceA-Twenty-FiveGigE1/0/1] sflow sampling-rate 10000
# Specify sFlow collector 1 for flow sampling on Twenty-FiveGigE 1/0/1.
[DeviceA-Twenty-FiveGigE1/0/1] sflow flow collector 1
# Enable flow sampling and set the sampling interval to 10000 on Twenty-FiveGigE 1/0/2.
[DeviceA-Twenty-FiveGigE1/0/2] sflow sampling-rate 10000
# Specify sFlow collector 1 for flow sampling on Twenty-FiveGigE 1/0/2.
[DeviceA-Twenty-FiveGigE1/0/2] sflow flow collector 1
Configuring Device B
# Create VLAN 20. Assign Twenty-FiveGigE 1/0/1 and Twenty-FiveGigE 1/0/2 to VLAN 20.
[DeviceB] vlan 20
[DeviceB-vlan20] port twenty-fivegige 1/0/1 to twenty-fivegige 1/0/2
[DeviceB-vlan20] quit
# Assign an IP address to VLAN-interface 20.
[DeviceB] interface vlan-interface 20
[DeviceB-Vlan-interface20] ip address 20.1.1.1 255.255.255.0
[DeviceB-Vlan-interface20] quit
[DeviceB] sflow agent ip 20.1.1.1
[DeviceB] sflow collector 1 ip 30.1.1.2 port 5000
# Enable counter sampling and set the counter sampling interval to 30 seconds on Twenty-FiveGigE 1/0/1.
[DeviceB] interface twenty-fivegige 1/0/1
[DeviceB-Twenty-FiveGigE1/0/1] sflow counter interval 30
[DeviceB-Twenty-FiveGigE1/0/1] sflow counter collector 1
# Enable flow sampling and set the sampling interval to 20000 on Twenty-FiveGigE 1/0/1.
[DeviceB-Twenty-FiveGigE1/0/1] sflow sampling-rate 20000
[DeviceB-Twenty-FiveGigE1/0/1] sflow flow collector 1
[DeviceB-Twenty-FiveGigE1/0/1] quit
# Verify the following items on Device A:
· Twenty-FiveGigE 1/0/1 and Twenty-FiveGigE 1/0/2 enabled with sFlow are active.
· The counter sampling interval is 120 seconds.
· The flow sampling interval is 10000.
[DeviceA] display sflow
sFlow datagram version: 5
Global information:
Agent IP: 10.1.1.1(CLI)
Source address:
Collector information:
ID IP Port Aging Size VPN-instance Description
1 30.1.1.2 5000 N/A 1400 CLI Collector
Port information:
Interface CID Interval(s) FID MaxHLen Rate Mode Status
WGE1/0/1 1 120 1 128 10000 random Active
WGE1/0/2 1 120 1 128 10000 random Active
Configuration files
· Device A:
vlan 10
interface Vlan-interface10
sflow collector 1 ip 30.1.1.2 port 5000 description "CLI Collector"
interface Twenty-FiveGigE1/0/1
port link-mode bridge
port access vlan 10
interface Twenty-FiveGigE1/0/2
port access vlan 10
interface Twenty-FiveGigE1/0/3
port access vlan 10
· Device B:
vlan 20
interface Vlan-interface20
port access vlan 20
port access vlan 20
