07-IP Multicast Configuration Examples
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-11xx[R1213Pxx][R9126Pxx]-6W10107-IP Multicast Configuration Examples
07-BIDIR-PIM Configuration Examples
07-BIDIR-PIM Configuration Examples 158.83 KB
XXX
H3C_彩色.emf
Adobe Systems
HPE XXXX
© Copyright 2019 Hewlett Packard Enterprise Development LP
Introduction
This document introduces BIDIR-PIM configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of BIDIR-PIM.
Example: Configuring BIDIR-PIM
As shown in Figure 1:
·     Switch A, Switch B, and Switch C run OSPF.
·     Source 1 and Source 2 send multicast data to multicast group 225.1.1.1.
·     Host A and Host B are member hosts of multicast group 225.1.1.1.
Configure BIDIR-PIM on the switches to implement multicast forwarding.
Figure 1 Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int100
10.10.1.1/24
Switch C
Vlan-int102
10.102.1.1/24
Switch A
Vlan-int12
10.12.1.1/24
Switch C
Vlan-int13
10.13.1.3/24
Switch A
Vlan-int13
10.13.1.1/24
Switch C
Vlan-int23
10.23.1.3/24
Switch B
Vlan-int101
10.101.1.1/24
Switch C
Vlan-int33
10.33.1.3/24
Switch B
Vlan-int12
10.12.1.2/24
Source 1
10.10.1.2/24
Switch B
Vlan-int23
10.23.1.2/24
Source 2
10.33.1.4/24
Analysis
To meet the network requirements, perform the following tasks:
·     To establish the bidirectional RPT, configure VLAN-interface 12 on Switch A as a C-RP.
·     To use the BSR mechanism to dynamically elect the RP, configure VLAN-interface 12 on Switch A as a C-BSR.
·     To avoid multicast forwarding interruption when the RP fails, specify the unused IP address 10.13.1.4/24 as the static RP. In this way, the link on the subnet 10.13.1.0/24 becomes the RPL. Switch A and Switch C on the link function as the RPs.
Hardware
Software version
S6550X-HI switch series
Release 1213P51 and later
S6880 switch series
S9820-8M switch
S5580X-HI switch series
Release 1213P50 and later
S5580X-EI switch series
S5580S-EI switch series
When you configure BIDIR-PIM, follow these restrictions and guidelines:
·     Enable the same PIM mode on the interfaces that belong to the same VPN instance on each switch.
·     Configure the same static RP on all the switches in the BIDIR-PIM domain.
·     Enable PIM-SM for all interfaces on the switches in the BIDIR-PIM domain.
·     Enable IGMP for the interfaces that connect to the stub networks on all the switches in the BIDIR-PIM domain.
Procedures
Configure Switch A
1.     Enable IP multicast routing.
[SwitchA] multicast routing
[SwitchA-mrib] quit
2.     Configure each interface and enable PIM-SM.
# Create VLAN 100, and assign Twenty-FiveGigE 1/0/1 to this VLAN.
[SwitchA] vlan 100
[SwitchA-vlan100] port twenty-fivegige 1/0/1
[SwitchA-vlan100] quit
# Assign an IP address to VLAN-interface 100, and enable PIM-SM on the interface.
[SwitchA-Vlan-interface100] ip address 10.10.1.1 24
# Create VLAN 12, and assign Twenty-FiveGigE 1/0/2 to the VLAN.
[SwitchA] vlan 12
[SwitchA-vlan12] port twenty-fivegige 1/0/2
[SwitchA-vlan12] quit
# Assign an IP address to VLAN-interface 12, enable PIM-SM on the interface.
[SwitchA-vlan12] interface vlan-interface 12
[SwitchA-Vlan-interface12] ip address 10.12.1.1 24
[SwitchA-Vlan-interface12] pim sm
[SwitchA-Vlan-interface12] quit
# Create VLAN 13, and assign Twenty-FiveGigE 1/0/3 to the VLAN.
[SwitchA] vlan 13
[SwitchA-vlan13] port twenty-fivegige 1/0/3
[SwitchA-vlan13] quit
# Assign an IP address to VLAN-interface 13, enable PIM-SM on the interface.
[SwitchA] interface vlan-interface 13
[SwitchA-Vlan-interface13] ip address 10.13.1.1 24
[SwitchA-Vlan-interface13] pim sm
[SwitchA-Vlan-interface13] quit
3.     Configure a C-RP, a C-BSR, and the static RP.
# Configure VLAN-interface 12 as a C-BSR and a C-RP.
[SwitchA] pim
[SwitchA-pim] c-bsr 10.12.1.1
[SwitchA-pim] c-rp 10.12.1.1 bidir
# Specify the unused IP address 10.13.1.4 as a static RP.
[SwitchA-pim] static-rp 10.13.1.4 bidir
4.     Enable BIDIR-PIM.
[SwitchA-pim] bidir-pim enable
[SwitchA-pim] quit
5.     Configure OSPF.
[SwitchA] ospf 1
[SwitchA-ospf-1] import-route direct
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] network 10.0.0.0 0.255.255.255
[SwitchA-ospf-1] quit
Configure Switch B
[SwitchB] multicast routing
[SwitchB-mrib] quit
# Create VLAN 12, and assign Twenty-FiveGigE 1/0/2 to this VLAN.
[SwitchB] vlan 12
[SwitchB-vlan12] port twenty-fivegige 1/0/2
[SwitchB-vlan12] quit
[SwitchB] interface vlan-interface 12
[SwitchB-Vlan-interface12] ip address 10.12.1.2 24
[SwitchB-Vlan-interface12] pim sm
[SwitchB-Vlan-interface12] quit
# Create VLAN 23, and assign Twenty-FiveGigE 1/0/3 to this VLAN.
[SwitchB] vlan 23
[SwitchB-vlan23] port twenty-fivegige 1/0/3
[SwitchB-vlan23] quit
# Assign an IP address to VLAN-interface 23, enable PIM-SM on the interface.
[SwitchB] interface vlan-interface 23
[SwitchB-Vlan-interface23] ip address 10.23.1.2 24
[SwitchB-Vlan-interface23] pim sm
[SwitchB-Vlan-interface23] quit
# Create VLAN 101, and assign Twenty-FiveGigE 1/0/1 to this VLAN.
[SwitchB] vlan 101
[SwitchB-vlan101] port twenty-fivegige 1/0/1
[SwitchB-vlan101] quit
# Assign an IP address to VLAN-interface 101, enable PIM-SM and IGMP on the interface.
[SwitchB-Vlan-interface101] ip address 10.101.1.1 24
[SwitchB-Vlan-interface101] igmp enable
3.     Specify the unused IP address 10.13.1.4 as a static RP.
[SwitchB] pim
[SwitchB-pim] static-rp 10.13.1.4 bidir
[SwitchB-pim] bidir-pim enable
[SwitchB-pim] quit
5.     Configure OSPF.
[SwitchB] ospf 1
[SwitchB-ospf-1] import-route direct
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 10.0.0.0 0.255.255.255
[SwitchB-ospf-1] quit
Configure Switch C
[SwitchC] multicast routing
[SwitchC-mrib] quit
# Create VLAN 33, and assign Twenty-FiveGigE 1/0/4 to this VLAN.
[SwitchC] vlan 33
[SwitchC-vlan33] port twenty-fivegige 1/0/4
[SwitchC-vlan33] quit
# Assign an IP address to VLAN-interface 33, enable PIM-SM on the interface.
[SwitchC] interface vlan-interface 33
[SwitchC-Vlan-interface33] ip address 10.33.1.3 24
[SwitchC-Vlan-interface33] pim sm
[SwitchC-Vlan-interface33] quit
# Create VLAN 13, and assign Twenty-FiveGigE 1/0/3 to this VLAN.
[SwitchC] vlan 13
[SwitchC-vlan13] port twenty-fivegige 1/0/3
[SwitchC-vlan13] quit
[SwitchC] interface vlan-interface 13
[SwitchC-Vlan-interface13] ip address 10.13.1.3 24
[SwitchC-Vlan-interface13] pim sm
[SwitchC-Vlan-interface13] quit
# Create VLAN 23, and assign Twenty-FiveGigE 1/0/2 to this VLAN.
[SwitchC] vlan 23
[SwitchC-vlan23] port twenty-fivegige 1/0/2
[SwitchC-vlan23] quit
[SwitchC] interface vlan-interface 23
[SwitchC-Vlan-interface23] ip address 10.23.1.3 24
[SwitchC-Vlan-interface23] pim sm
[SwitchC-Vlan-interface23] quit
# Create VLAN 102, and assign Twenty-FiveGigE 1/0/1 to this VLAN.
[SwitchC] vlan 102
[SwitchC-vlan102] port twenty-fivegige 1/0/1
[SwitchC-vlan102] quit
# Assign an IP address to VLAN-interface 102, enable PIM-SM and IGMP on the interface.
[SwitchC-Vlan-interface102] ip address 10.102.1.1 24
[SwitchC-Vlan-interface102] igmp enable
[SwitchC] pim
[SwitchC-pim] static-rp 10.13.1.4 bidir
4.     Enable BIDIR-PIM
[SwitchC-pim] bidir-pim enable
[SwitchC-pim] quit
5.     Configure OSPF.
[SwitchC] ospf 1
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 10.0.0.0 0.255.255.255
[SwitchC-ospf-1] quit
1.     Verify that Switch A, Switch B, and Switch C have established PIM neighbor relationships.
# Display PIM neighbor information on Switch A.
[SwitchA] display pim neighbor
 Total pim neighbors: 2
  Neighbor: 10.12.1.2
    Interface: Vlan12
    Uptime: 00:09:55
    Expiry time: 00:01:41
    DR priority: 1
    Mode: B P
  Neighbor: 10.13.1.3
    Interface: Vlan13
    Uptime: 00:05:24
    Expiry time: 00:01:18
    DR priority: 1
    Mode: B P
# Display PIM neighbor information on Switch B.
[SwitchB] display pim neighbor
  Neighbor: 10.23.1.3
    Interface: Vlan23
    Uptime: 00:05:51
    Expiry time: 00:01:27
    DR priority: 1
    Mode: B P
  Neighbor: 10.12.1.1
    Interface: Vlan12
    Uptime: 00:10:50
    Expiry time: 00:01:40
    DR priority: 1
    Mode: B P
# Display PIM neighbor information on Switch C.
[SwitchC] display pim neighbor
  Neighbor: 10.23.1.2
    Interface: Vlan23
    Uptime: 00:15:52
    Expiry time: 00:01:17
    DR priority: 1
    Mode: B P
  Neighbor: 10.13.1.1
    Interface: Vlan13
    Uptime: 00:00:08
    Expiry time: 00:01:37
    DR priority: 1
    Mode: B P
2.     Verify that VLAN-interface 12 on Switch A has been elected as the BSR on each switch.
# Display BSR information on Switch A.
[SwitchA] display pim bsr-info
 Scope: non-scoped
     State: Elected
     Bootstrap timer: 00:01:18
     Elected BSR address: 10.12.1.1
       Priority: 64
       Hash mask length: 30
       Uptime: 00:04:01
     Candidate BSR address: 10.12.1.1
       Priority: 64
# Display BSR information on Switch B.
[SwitchB] display pim bsr-info
 Scope: non-scoped
     State: Accept Preferred
     Bootstrap timer: 00:00:26
       Priority: 64
       Uptime: 00:10:41
# Display BSR information on Switch C.
[SwitchC] display pim bsr-info
 Scope: non-scoped
     Bootstrap timer: 00:02:08
       Priority: 64
       Uptime: 00:15:41
3.     Verify that VLAN-interface 12 on Switch A has been elected as the RP, and verify that the IP address of the static RP is 10.13.1.4 on each switch.
# Display RP information on Switch A.
[SwitchA] display pim rp-info
 BSR RP information:
   Scope: non-scoped
     Group/MaskLen: 224.0.0.0/4 [B]
       RP address               Priority  HoldTime  Uptime    Expires
       10.12.1.1 (local)        192       180       00:06:01  00:02:58
 Static RP information:
       RP address               ACL   Mode    Preferred
       10.13.1.4                ----  bidir   No
# Display RP information on Switch B.
[SwatchB] display pim rp-info
 BSR RP information:
   Scope: non-scoped
       10.12.1.1                192       180       00:06:33  00:02:26
# Display RP information on Switch C.
[SwitchC] display pim rp-info
 BSR RP information:
   Scope: non-scoped
       10.12.1.1                192       150       00:06:51  00:02:05
4.     Verify that the DFs have been elected for BIDIR-PIM on each switch.
# Display information about DFs for BIDIR-PIM on Switch A.
[SwitchA] display pim df-info
RP address: 10.12.1.1
  Interface: Vlan-interface100
    State     : Win        DF preference: 0
    DF metric : 0          DF uptime    : 00:01:09
    DF address: 10.10.1.1 (local)
  Interface: Vlan-interface12
    State     : -          DF preference: -
    DF metric : -          DF uptime    : -
    DF address: -
  Interface: Vlan-interface13
    DF metric : 0          DF uptime    : 00:01:10
    DF address: 10.13.1.1 (local)
RP address: 10.13.1.4
    DF metric : 0          DF uptime    : 00:00:07
    DF address: 10.12.1.1 (local)
    DF address: -
# Display information about DFs for BIDIR-PIM on Switch B.
[SwatchB] display pim df-info
    DF address: -
  Interface: Vlan-interface23
    DF metric : 0          DF uptime    : 00:01:46
    DF address: 10.23.1.2 (local)
    State     : Lose       DF preference: 0
    DF metric : 0          DF uptime    : 00:00:44
    DF metric : 0          DF uptime    : 00:00:53
    DF address: 10.23.1.3
# Display information about DFs for BIDIR-PIM on Switch C.
[SwitchC] display pim df-info
  Interface: Vlan-interface33
    State     : Win        DF preference: 10
    DF metric : 2          DF uptime    : 00:02:06
    DF address: 10.33.1.3 (local)
    DF metric : 0          DF uptime    : 00:02:07
    DF metric : 0          DF uptime    : 00:01:23
    DF address: -
    DF metric : 0          DF uptime    : 00:01:24
    DF address: 10.23.1.3 (local)
5.     Verify that DFs for multicast forwarding are correct on each switch.
# Display information about DFs for multicast forwarding on Switch A.
[SwitchA] display multicast forwarding df-info
Total 2 RPs, 2 matched
00001. RP address: 10.12.1.1
     Flags: 0x0
     Uptime: 00:02:42
     RPF interface: Vlan-interface12
     List of 2 DF interfaces:
       1: Vlan-interface100
       2: Vlan-interface13
00002. RP address: 10.13.1.4
     Flags: 0x0
     Uptime: 00:01:41
     RPF interface: Vlan-interface13
       2: Vlan-interface12
# Display information about DFs for multicast forwarding on Switch B.
[SwitchB] display multicast forwarding df-info
     Flags: 0x0
     Uptime: 01:00:03
     List of 1 DF interfaces:
       1: Vlan-interface23
     Flags: 0x0
     Uptime: 00:06:08
     RPF interface: Vlan-interface23
# Display information about DFs for multicast forwarding on Switch C.
[SwitchC] display multicast forwarding df-info
     Flags: 0x0
     Uptime: 00:56:51
       1: Vlan-interface33
     Flags: 0x0
     Uptime: 00:07:01
       1: Vlan-interface23
       2: Vlan-interface33
6.     Send IGMP reports from Host A and Host B to join multicast group 225.1.1.1, and send multicast data from Source 1 and Source 2 to the group. (Details not shown.)
7.     Verify that PIM forwarding entries have been correctly established on each switch.
# Display information about PIM routing entries on Switch A.
[SwitchA] display pim routing-table
 Total 1 (*, G) entries; 0 (S, G) entries
 (*, 225.1.1.1)
     RP: 10.12.1.1 (local)
     Protocol: pim-bidir, Flag: WC LOC ACT
     UpTime: 02:23:52
     Upstream interface: Vlan-interface12
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
     Downstream interface information:
         1: Vlan-interface12
             Protocol: pim-bidir, UpTime: 02:23:52, Expires: -
# Display information about PIM routing entries on Switch B.
[SwitchB] display pim routing-table
 (*, 225.1.1.1)
     RP: 10.12.1.1
     UpTime: 00:23:47
     Total number of downstreams: 3
         1: Vlan-interface12
             Protocol: pim-bidir, UpTime: 00:23:47, Expires: -
         2: Vlan-interface23
             Protocol: pim-bidir, UpTime: 00:21:56, Expires: -
         3: Vlan-interface101
             Protocol: igmp, UpTime: 00:23:47, Expires: -
# Display information about PIM routing entries on Switch C.
[SwitchC] display pim routing-table
 (*, 225.1.1.1)
     RP: 10.12.1.1
     Protocol: pim-bidir, Flag: WC ACT
     UpTime: 00:01:45
     Upstream interface: Vlan-interface23
         Upstream neighbor: 10.23.1.2
         RPF prime neighbor: 10.23.1.2
     Total number of downstreams: 2
         1: Vlan-interface102
             Protocol: igmp, UpTime: 00:01:05, Expires: -
         2: Vlan-interface23
             Protocol: pim-bidir, UpTime: 00:00:53, Expires: -
Configuration files
·     Switch A:
ospf 1
 area 0.0.0.0
vlan 12 to 13
vlan 100
interface Vlan-interface12
 ip address 10.12.1.1 255.255.255.0
 pim sm
interface Vlan-interface13
 ip address 10.13.1.1 255.255.255.0
 pim sm
interface Vlan-interface100
 ip address 10.10.1.1 255.255.255.0
 pim sm
interface Twenty-FiveGigE1/0/1
 port link-mode bridge
 port access vlan 100
interface Twenty-FiveGigE1/0/2
 port access vlan 12
interface Twenty-FiveGigE1/0/3
 port access vlan 13
multicast routing
pim
 bidir-pim enable
 c-bsr 10.12.1.1
·     Switch B:
ospf 1
 area 0.0.0.0
vlan 12
Vlan 23
vlan 101
 ip address 10.12.1.2 255.255.255.0
 pim sm
interface Vlan-interface23
 ip address 10.23.1.2 255.255.255.0
 pim sm
interface Vlan-interface101
 ip address 10.101.1.1 255.255.255.0
 igmp enable
 port access vlan 101
 port access vlan 12
 port access vlan 23
multicast routing
pim
 bidir-pim enable
·     Switch C:
ospf 1
 area 0.0.0.0
vlan 13
vlan 23
vlan 33
vlan 102
 ip address 10.13.1.3 255.255.255.0
 pim sm
 ip address 10.23.1.3 255.255.255.0
 pim sm
interface Vlan-interface33
 ip address 10.33.1.3 255.255.255.0
 pim sm
interface Vlan-interface102
 ip address 10.102.1.1 255.255.255.0
 igmp enable
 port access vlan 102
 port access vlan 23
 port access vlan 13
interface Twenty-FiveGigE1/0/4
 port access vlan 33
multicast routing
pim
 bidir-pim enable
