- 06-ACL and QoS Configuration Examples
- 01-ACL Configuration Examples
- 02-Traffic Filtering Configuration Examples
- 03-Traffic Policing Configuration Examples
- 04-GTS and Rate Limiting Configuration Examples
- 05-Congestion Avoidance and Queue Scheduling Configuration Examples
- 06-Priority Mapping and Queue Scheduling Configuration Examples
- 07-Priority Marking and Queue Scheduling Configuration Examples
- 08-Control Plane-Based QoS Policy Configuration Examples
05-Congestion Avoidance and Queue Scheduling Configuration Examples | 102.51 KB |
Example: Configuring congestion avoidance and queue scheduling
Introduction
This document provides examples for configuring congestion avoidance and queue scheduling profiles.
This document assumes that you have basic knowledge of congestion avoidance and queue scheduling profiles.
As shown in Figure 1, three types of traffic come from the Internet to the device through the gateway.
· Voice traffic—Transmitted in VLAN 6 and carries 802.1p priority 6.
· Video traffic—Transmitted in VLAN 4 and carries 802.1p priority 4.
· Data traffic—Transmitted in VLAN 2 and carries 802.1p priority 2.
Configure congestion avoidance and queue scheduling on the device to meet the following requirements:
· The voice traffic, video traffic, and data traffic are scheduled in the ratio of 1:2:2 when congestion occurs.
· WRED drop is used when serious congestion occurs.
Analysis
To configure congestion avoidance and queue scheduling, you must perform the following tasks:
· To assign different types of traffic to different queues, configure the inbound interface to trust the 802.1p priority in packets.
· To schedule the three types of traffic in the ratio of 1:2:2, assign their queues to one WRR group and configure weights for these queues.
· To minimize performance degradation for different types of traffic, use the drop parameters in Table 1.
Traffic type |
Packet color |
Lower limit |
Upper limit |
Drop probability |
Voice |
Yellow |
1000 |
1500 |
3% |
Red |
500 |
1000 |
30% |
Video |
Yellow |
1000 |
1500 |
2% |
Red |
500 |
1000 |
20% |
Data |
Yellow |
1000 |
1500 |
1% |
Red |
500 |
1000 |
10% |
Hardware |
Software version |
S6550X-HI switch series |
Release 1116 and later, Release 1213P51 and later |
S6880 switch series |
S9820-8M switch |
S5580X-HI switch series |
Release 1213P50 and later |
S5580X-EI switch series |
S5580S-EI switch series |
Procedures
1. Allow VLANs for different types of traffic to pass through:
# Create three VLANs .
[Device] vlan 2
[Device-vlan2] quit
[Device] vlan 4
[Device-vlan4] quit
[Device] vlan 6
[Device-vlan6] quit
# Assign interfaces to VLANs.
[Device] interface hundredgige 2/0/1
[Device-HundredGigE2/0/1] port link-type trunk
[Device-HundredGigE2/0/1] port trunk permit vlan 2 4 6
[Device-HundredGigE2/0/1] quit
[Device] interface twenty-fivegige 1/0/1
[Device-Twenty-FiveGigE1/0/1] port link-type trunk
[Device-Twenty-FiveGigE1/0/1] port trunk permit vlan 2 4 6
[Device-Twenty-FiveGigE1/0/1] quit
[Device] interface twenty-fivegige 1/0/2
[Device-Twenty-FiveGigE1/0/2] port link-type trunk
[Device-Twenty-FiveGigE1/0/2] port trunk permit vlan 2 4 6
[Device-Twenty-FiveGigE1/0/2] quit
2. Configure interface HundredGigE 2/0/1 to trust the 802.1p priority in packets.
[Device-HundredGigE2/0/1] qos trust dot1p
[Device- interface hundredgige 2/0/1] qos trust auto
3. Configure WRR on Twenty-FiveGigE 1/0//1 and Twenty-FiveGigE 1/0//2:
# Display the 802.1p-to-local precedence map to determine the local precedence for each type of traffic.
[Device] display qos map-table inbound dot1p-lp
MAP-TABLE NAME: dot1p-lp TYPE: pre-define
IMPORT : EXPORT
0 : 2
1 : 0
2 : 1
3 : 3
4 : 4
5 : 5
6 : 6
7 : 7
# Enable weight-based WRR on Twenty-FiveGigE 1/0/1.
[Device-Twenty-FiveGigE1/0/1] qos wrr weight
# Configure the weights of queue 1 (for data traffic), queue 4 (for video traffic), and queue 6 (for voice traffic) as 2, 2, and 1, respectively.
[Device-Twenty-FiveGigE1/0/1] qos wrr 1 group 1 weight 2
[Device-Twenty-FiveGigE1/0/1] qos wrr 4 group 1 weight 2
[Device-Twenty-FiveGigE1/0/1] qos wrr 6 group 1 weight 1
# Enable weight-based WRR on Twenty-FiveGigE 1/0/2.
[Device-Twenty-FiveGigE1/0/2] qos wrr weight
[Device-Twenty-FiveGigE1/0/2] qos wrr 1 group 1 weight 2
[Device-Twenty-FiveGigE1/0/2] qos wrr 4 group 1 weight 2
[Device-Twenty-FiveGigE1/0/2] qos wrr 6 group 1 weight 1
4. Configure congestion avoidance:
# Configure a WRED table.
[Device] qos wred queue table droppolicy
[Device-wred-table-droppolicy] queue 6 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 3
[Device-wred-table-droppolicy] queue 6 drop-level 2 low-limit 500 high-limit 1000 discard-probability 30
[Device-wred-table-droppolicy] queue 4 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 2
[Device-wred-table-droppolicy] queue 4 drop-level 2 low-limit 500 high-limit 1000 discard-probability 20
[Device-wred-table-droppolicy] queue 1 drop-level 1 low-limit 1000 high-limit 1500 discard-probability 1
[Device-wred-table-droppolicy] queue 1 drop-level 2 low-limit 500 high-limit 1000 discard-probability 10
[Device-wred-table-droppolicy] quit
# Apply the WRED table to interfaces Twenty-FiveGigE 1/0/1 and Twenty-FiveGigE 1/0/2.
[Device-Twenty-FiveGigE1/0/1] qos wred apply droppolicy
[Device-Twenty-FiveGigE1/0/2] qos wred apply droppolicy
# Verify the WRR configuration on interfaces Twenty-FiveGigE 1/0/1 and Twenty-FiveGigE 1/0/2.
[Device] display qos queue wrr interface
Interface: Twenty-FiveGigE1/0/1
Output queue: Weighted Round Robin queuing
Queue ID Queue name Group Byte count
0 be 1 1
1 af1 1 2
2 af2 1 3
3 af3 1 4
4 af4 1 2
5 ef 1 9
6 cs6 1 1
7 cs7 1 15
Interface: Twenty-FiveGigE1/0/2
0 be 1 1
1 af1 1 2
2 af2 1 3
3 af3 1 4
4 af4 1 2
5 ef 1 9
6 cs6 1 1
7 cs7 1 15
# Display the WRED table configuration.
Table name: droppolicy
Table type: Queue based WRED
QID gmin gmax gprob ymin ymax yprob rmin rmax rprob exponent ECN
0 100 1000 10 100 1000 10 100 1000 10 9 N
1 100 1000 10 1000 1500 1 500 1000 10 9 N
2 100 1000 10 100 1000 10 100 1000 10 9 N
3 100 1000 10 100 1000 10 100 1000 10 9 N
4 100 1000 10 1000 1500 2 500 1000 20 9 N
5 100 1000 10 100 1000 10 100 1000 10 9 N
6 100 1000 10 1000 1500 3 500 1000 30 9 N
7 100 1000 10 100 1000 10 100 1000 10 9 N
Configuration files
vlan 1
vlan 2
vlan 4
vlan 6
interface Twenty-FiveGigE1/0/1
port link-mode bridge
port trunk permit vlan 1 to 2 4 6
qos byte-count
qos wrr af1 group 1 byte-count 2
qos wrr af4 group 1 byte-count 2
qos wrr cs6 group 1 byte-count 1
interface Twenty-FiveGigE1/0/2
qos wrr byte-count
interface HundredGigE2/0/1
return
