- 07-Multicast Configuration Guide
- 01-Multicast overview
- 02-IGMP snooping configuration
- 03-PIM snooping configuration
- 04-Multicast VLAN configuration
- 05-Multicast routing and forwarding configuration
- 06-IGMP configuration
- 07-PIM configuration
- 08-MSDP configuration
- 09-MLD snooping configuration
- 10-IPv6 PIM snooping configuration
- 11-IPv6 multicast VLAN configuration
- 12-IPv6 multicast routing and forwarding configuration
- 13-MLD configuration
- 14-IPv6 PIM configuration
| 11-IPv6 multicast VLAN configuration | 161.44 KB |
Configuring IPv6 multicast VLANs
Sub-VLAN-based IPv6 multicast VLAN
Port-based IPv6 multicast VLAN
Restrictions and guidelines: IPv6 multicast VLAN configuration
Configuring a sub-VLAN-based IPv6 multicast VLAN
Configuring a port-based IPv6 multicast VLAN
Setting the maximum number of IPv6 multicast VLAN forwarding entries
Verifying and maintaining IPv6 multicast VLAN
Verifying IPv6 multicast VLAN configuration and running status
Displaying and clearing IPv6 multicast groups in IPv6 multicast VLANs
IPv6 multicast VLAN configuration examples
Example: Configuring sub-VLAN-based IPv6 multicast VLAN
Example: Configuring port-based IPv6 multicast VLAN
IPv6 multicast VLAN feature
As shown in Figure 1, Host A, Host B, and Host C are in different VLANs and the same IPv6 multicast group. When Switch A (Layer 3 device) receives IPv6 multicast data for that group, it forwards three copies of the data to Switch B (Layer 2 device). This occupies a large amount of bandwidth and increases the burden on the Layer 3 device.
Figure 1 Multicast transmission without the IPv6 multicast VLAN feature
After an IPv6 multicast VLAN is configured on Switch B, Switch A sends one copy of the IPv6 multicast data to the IPv6 multicast VLAN on Switch B. This saves network bandwidth and lessens the burden on the Layer 3 device.
IPv6 multicast VLAN methods
IPv6 multicast VLANs support sub-VLAN-based IPv6 multicast VLANs and port-based IPv6 multicast VLANs.
As shown in Figure 2:
· Host A, Host B, and Host C are in VLAN 2 through VLAN 4, respectively.
· On Switch B, VLAN 10 is an IPv6 multicast VLAN. VLAN 2 through VLAN 4 are sub-VLANs of VLAN 10.
· MLD snooping is enabled for the multicast VLAN and its sub-VLANs.
Figure 2 Sub-VLAN-based multicast VLAN
MLD snooping manages router ports in the IPv6 multicast VLAN and member ports in each sub-VLAN. When Switch A receives IPv6 multicast data from the IPv6 multicast source, it sends only one copy of the IPv6 multicast data to the IPv6 multicast VLAN on Switch B. Then, Switch B sends a separate copy to each sub-VLAN of the IPv6 multicast VLAN.
As shown in Figure 3:
· Host A, Host B, and Host C are in VLAN 2 through VLAN 4, respectively. All the user ports (ports with attached hosts) on Switch B are hybrid ports.
· On Switch B, VLAN 10 is an IPv6 multicast VLAN. All the user ports are assigned to VLAN 10.
· MLD snooping is enabled for the IPv6 multicast VLAN and its sub-VLANs.
Figure 3 Port-based IPv6 multicast VLAN
MLD snooping manages the router ports and member ports in the IPv6 multicast VLAN. When Switch A receives IPv6 multicast data from the IPv6 multicast source, it sends only one copy of the IPv6 multicast data to the IPv6 multicast VLAN on Switch B. Then, Switch B sends a separate copy to each user port in the IPv6 multicast VLAN.
The VLAN to be configured as an IPv6 multicast VLAN must exist.
If you have configured both a sub-VLAN-based IPv6 multicast VLAN and a port-based IPv6 multicast VLAN on a device, the port-based IPv6 multicast VLAN configuration takes effect.
Do not configure an IPv6 multicast VLAN on a device that is enabled with IPv6 multicast routing. Otherwise, the system displays errors. Do not enable IPv6 multicast routing on a device that is configured with IPv6 multicast VLANs. Otherwise, IPv6 multicast forwarding exceptions occur.
Do not configure a VLAN as an IPv6 multicast VLAN or an IPv6 sub-VLAN if the VLAN interface is enabled with IPv6 PIM or MLD. Otherwise, the system displays errors. Do not enable IPv6 PIM or MLD on a VLAN interface if the VLAN interface belongs to an IPv6 multicast VLAN or an IPv6 multicast sub-VLAN. Otherwise, IPv6 multicast forwarding exceptions occur.
The IPv6 multicast VLAN feature does not take effect on secondary VLANs. As a best practice, do not configure the IPv6 multicast VLAN feature for secondary VLANs. For more information about secondary VLAN, see Layer 2—LAN Switching Configuration Guide.
The VLANs to be configured as sub-VLANs of an IPv6 multicast VLAN must exist and cannot be IPv6 multicast VLANs or sub-VLANs of any other IPv6 multicast VLANs.
Before you configure a sub-VLAN-based IPv6 multicast VLAN, you must complete the following tasks:
· Create VLANs as required.
· Enable MLD snooping for the VLAN to be configured as the IPv6 multicast VLAN, and for the VLANs to be configured as sub-VLANs.
1. Enter system view.
2. Configure a VLAN as an IPv6 multicast VLAN and enter IPv6 multicast VLAN view.
ipv6 multicast-vlan vlan-id
By default, a VLAN is not an IPv6 multicast VLAN.
3. Assign VLANs to the IPv6 multicast VLAN as sub-VLANs.
subvlan vlan-list
By default, an IPv6 multicast VLAN does not have any sub-VLANs.
You can assign user ports to an IPv6 multicast VLAN in IPv6 multicast VLAN view or assign a user port to an IPv6 multicast VLAN in interface view.
A user port can belong to only one IPv6 multicast VLAN.
Before you configure a port-based IPv6 multicast VLAN, you must complete the following tasks:
· Enable MLD snooping for the VLAN to be configured as the IPv6 multicast VLAN.
· Enable MLD snooping for all the VLANs that contain the multicast receivers.
· Configure the attributes of user ports. Make sure the ports can forward packets from the VLAN to be configured as the IPv6 multicast VLAN and send the packets with the VLAN tag removed. For more information about configuring port attributes, see VLAN configuration in Layer 2—LAN Switching Configuration Guide.
Assigning user ports to an IPv6 multicast VLAN in IPv6 multicast VLAN view
2. Configure an IPv6 VLAN as an IPv6 multicast VLAN and enter IPv6 multicast VLAN view.
3. Assign ports to the IPv6 multicast VLAN as user ports.
port interface-list
Assigning user ports to an IPv6 multicast VLAN in interface view
3. Return to system view.
4. Enter Layer 2 interface view.
5. Assign the port to the IPv6 multicast VLAN as a user port.
ipv6 port multicast-vlan vlan-id
By default, a port does not belong to any IPv6 multicast VLAN.
About setting the maximum number of IPv6 multicast VLAN forwarding entries
You can set the maximum number of IPv6 multicast VLAN forwarding entries on the device. When the upper limit is reached, the device does not create IPv6 multicast VLAN forwarding entries until some entries age out or are manually removed.
2. Set the maximum number of IPv6 multicast VLAN forwarding entries.
ipv6 multicast-vlan entry-limit limit
The default setting is 4000.
· Display information about IPv6 multicast VLANs.
display ipv6 multicast-vlan [ vlan-id ]
· Display information about IPv6 multicast VLAN forwarding entries.
display ipv6 multicast-vlan forwarding-table [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | slot slot-number | subvlan vlan-id | vlan vlan-id ] *
To display information about IPv6 multicast groups in IPv6 multicast VLANs, execute the following command in any view:
display ipv6 multicast-vlan group [ ipv6-source-address | ipv6-group-address | slot slot-number | verbose | vlan vlan-id ] *
To clear IPv6 multicast groups in IPv6 multicast VLANs, execute the following command in user view:
reset ipv6 multicast-vlan group [ ipv6-group-address [ prefix-length ] | ipv6-source-address [ prefix-length ] | vlan vlan-id ] *
As shown in Figure 4:
· Layer 3 device Switch A runs MLD and acts as the MLD querier. Layer 2 device Switch B runs MLDv1 snooping.
· The IPv6 multicast source sends IPv6 multicast data to IPv6 multicast group FF1E::101. Receivers Host A, Host B, and Host C belong to VLAN 2, VLAN 3, and VLAN 4, respectively.
Configure a sub-VLAN-based IPv6 multicast VLAN on Switch B to meet the following requirements:
· Switch A sends the IPv6 multicast data to Switch B through the IPv6 multicast VLAN.
· Switch B forwards the IPv6 multicast data to the receivers in different user VLANs.
1. Configure Switch A:
# Enable IPv6 multicast routing.
[SwitchA-mrib6] quit
# Create VLAN 20, and assign GigabitEthernet 1/0/2 to the VLAN.
[SwitchA] vlan 20
[SwitchA-vlan20] port gigabitethernet 1/0/2
[SwitchA-vlan20] quit
# Assign an IPv6 address to VLAN-interface 20, and enable IPv6 PIM-DM on the interface.
[SwitchA-Vlan-interface20] ipv6 address 1::2 64
[SwitchA-Vlan-interface20] ipv6 pim dm
# Create VLAN 10.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
# Configure GigabitEthernet 1/0/1 as a hybrid port, and assign the port to VLAN 10 as a tagged VLAN member.
[SwitchA-GigabitEthernet1/0/1] port link-type hybrid
[SwitchA-GigabitEthernet1/0/1] port hybrid vlan 10 tagged
[SwitchA-GigabitEthernet1/0/1] quit
# Assign an IPv6 address to VLAN-interface 10, and enable MLD on the interface.
[SwitchA-Vlan-interface10] ipv6 address 2001::1 64
[SwitchA-Vlan-interface10] mld enable
2. Configure Switch B:
# Enable the MLD snooping feature.
[SwitchB] mld-snooping
[SwitchB-mld-snooping] quit
# Create VLAN 2, assign GigabitEthernet 1/0/2 to the VLAN, and enable MLD snooping for the VLAN.
[SwitchB] vlan 2
[SwitchB-vlan2] port gigabitethernet 1/0/2
[SwitchB-vlan2] mld-snooping enable
[SwitchB-vlan2] quit
# Create VLAN 3, assign GigabitEthernet 1/0/3 to the VLAN, and enable MLD snooping for the VLAN.
[SwitchB] vlan 3
[SwitchB-vlan3] port gigabitethernet 1/0/3
[SwitchB-vlan3] mld-snooping enable
[SwitchB-vlan3] quit
# Create VLAN 4, assign GigabitEthernet 1/0/4 to the VLAN, and enable MLD snooping for the VLAN.
[SwitchB] vlan 4
[SwitchB-vlan4] port gigabitethernet 1/0/4
[SwitchB-vlan4] mld-snooping enable
[SwitchB-vlan4] quit
# Create VLAN 10, and enable MLD snooping for the VLAN.
[SwitchB] vlan 10
[SwitchB-vlan10] mld-snooping enable
[SwitchB-vlan10] quit
[SwitchB-GigabitEthernet1/0/1] port link-type hybrid
[SwitchB-GigabitEthernet1/0/1] port hybrid vlan 10 tagged
# Configure VLAN 10 as an IPv6 multicast VLAN, and assign VLAN 2 through VLAN 4 as sub-VLANs to multicast VLAN 10.
[SwitchB] ipv6 multicast-vlan 10
[SwitchB-ipv6-mvlan-10] subvlan 2 to 4
[SwitchB-ipv6-mvlan-10] quit
# Display information about all IPv6 multicast VLANs on Switch B.
[SwitchB] display ipv6 multicast-vlan
Total 1 IPv6 multicast VLANs.
IPv6 multicast VLAN 10:
Sub-VLAN list(3 in total):
2-4
Port list(0 in total):
# Display information about IPv6 multicast groups in IPv6 multicast VLANs on Switch B.
[SwitchB] display ipv6 multicast-vlan group
Total 1 entries.
IPv6 multicast VLAN 10: Total 1 entries.
(::, FF1E::101)
Sub-VLANs (3 in total):
VLAN 2
VLAN 3
VLAN 4
The output shows that IPv6 multicast group FF1E::101 belongs to IPv6 multicast VLAN 10. IPv6 multicast VLAN 10 contains sub-VLANs VLAN 2 through VLAN 4. Switch B will replicate the IPv6 multicast data of VLAN 10 to VLAN 2 through VLAN 4.
As shown in Figure 5:
· Layer 3 device Switch A runs MLDv1 and acts as the MLD querier. Layer 2 device Switch B runs MLDv1 snooping.
Configure a port-based IPv6 multicast VLAN on Switch B to meet the following requirements:
· Switch A sends IPv6 multicast data to Switch B through the IPv6 multicast VLAN.
[SwitchA] vlan 20
# Create VLAN 10, and assign GigabitEthernet 1/0/1 to the VLAN.
[SwitchA] vlan 10
[SwitchA-vlan10] port gigabitethernet 1/0/1
# Create VLAN 10, assign GigabitEthernet 1/0/1 to the VLAN, and enable MLD snooping for the VLAN.
[SwitchB] vlan 10
[SwitchB-vlan10] port gigabitethernet 1/0/1
# Create VLAN 2, and enable MLD snooping for the VLAN.
[SwitchB] vlan 2
# Create VLAN 3, and enable MLD snooping for the VLAN.
[SwitchB] vlan 3
# Create VLAN 4, and enable MLD snooping for the VLAN.
[SwitchB] vlan 4
# Configure GigabitEthernet 1/0/2 as a hybrid port, and configure VLAN 2 as the PVID of the hybrid port.
[SwitchB] interface gigabitethernet 1/0/2
[SwitchB-GigabitEthernet1/0/2] port link-type hybrid
[SwitchB-GigabitEthernet1/0/2] port hybrid pvid vlan 2
# Assign GigabitEthernet 1/0/2 to VLAN 2 and VLAN 10 as an untagged VLAN member.
[SwitchB-GigabitEthernet1/0/2] port hybrid vlan 2 untagged
[SwitchB-GigabitEthernet1/0/2] port hybrid vlan 10 untagged
# Configure GigabitEthernet 1/0/3 as a hybrid port, and configure VLAN 3 as the PVID of the hybrid port.
[SwitchB] interface gigabitethernet 1/0/3
[SwitchB-GigabitEthernet1/0/3] port link-type hybrid
[SwitchB-GigabitEthernet1/0/3] port hybrid pvid vlan 3
# Assign GigabitEthernet 1/0/3 to VLAN 3 and VLAN 10 as an untagged VLAN member.
[SwitchB-GigabitEthernet1/0/3] port hybrid vlan 3 untagged
[SwitchB-GigabitEthernet1/0/3] port hybrid vlan 10 untagged
[SwitchB-GigabitEthernet1/0/3] quit
# Configure GigabitEthernet 1/0/4 as a hybrid port, and configure VLAN 4 as the PVID of the hybrid port.
[SwitchB] interface gigabitethernet 1/0/4
[SwitchB-GigabitEthernet1/0/4] port link-type hybrid
[SwitchB-GigabitEthernet1/0/4] port hybrid pvid vlan 4
# Assign GigabitEthernet 1/0/4 to VLAN 4 and VLAN 10 as an untagged VLAN member.
[SwitchB-GigabitEthernet1/0/4] port hybrid vlan 4 untagged
[SwitchB-GigabitEthernet1/0/4] port hybrid vlan 10 untagged
[SwitchB-GigabitEthernet1/0/4] quit
# Configure VLAN 10 as an IPv6 multicast VLAN.
# Assign GigabitEthernet 1/0/2 and GigabitEthernet 1/0/3 to VLAN 10.
[SwitchB-ipv6-mvlan-10] port gigabitethernet 1/0/2 to gigabitethernet 1/0/3
# Assign GigabitEthernet 1/0/4 to VLAN 10.
[SwitchB-GigabitEthernet1/0/4] ipv6 port multicast-vlan 10
# Display information about IPv6 multicast VLANs on Switch B.
Sub-VLAN list(0 in total):
Port list(3 in total):
GE1/0/2
GE1/0/3
GE1/0/4
# Display dynamic MLD snooping forwarding entries on Switch B.
[SwitchB] display mld-snooping group
Total 1 entries.
(::, FF1E::101)
Host slots (0 in total):
Host ports (3 in total):
GE1/0/2 (00:03:23)
GE1/0/3 (00:04:07)
GE1/0/4 (00:04:16)
The output shows that MLD snooping maintains the user ports in the multicast VLAN (VLAN 10). Switch B will forward the IPv6 multicast data of VLAN 10 through these user ports.
