04-Layer 2—LAN Switching Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5580X-EI[HI] & S5580S-EI Switch Series Command References-R1213P50-6W10004-Layer 2—LAN Switching Command Reference
14-Service loopback group commands
14-Service loopback group commands 56.56 KB
display service-loopback group
Use display service-loopback group to display service loopback group information.
display service-loopback group [ group-id ]
group-id: Specifies a service loopback group ID. The value range for the group-id argument is 1 to 1024. If you do not specify a service loopback group, this command displays information about all service loopback groups.
# Display information about service loopback group 5.
<Sysname> display service-loopback group 5
Group ID: 5                  Service type: Tunnel
  Member                              Status
  GigabitEthernet1/0/1                Selected
  GigabitEthernet1/0/2                Unselected
Group ID
Service loopback group ID.
Service type
Service type of the service loopback group:
Tunnel—Supports unicast tunnel traffic.
Member
Member ports of the service loopback group.
Status
Status of each member port in the service loopback group:
·     Selected—The port is in Selected state and can forward service packets.
·     Unselected—The port is in Unselected state. It cannot forward service packets.
port service-loopback group
Use port service-loopback group to assign a port to a service loopback group.
Use undo port service-loopback group to remove a port from a service loopback group.
port service-loopback group group-id
A port does not belong to a service loopback group.
CAUTION
CAUTION:
·     When you assign a port to a service loopback group, the system removes the configuration on the port. Make sure you are fully aware of the impact of this command before using it on a live network.
·     For correct traffic processing, make sure a service loopback group has a minimum of one member port when it is being used by a feature.
# Assign GigabitEthernet 1/0/1 to service loopback group 5.
[Sysname-GigabitEthernet1/0/1] port service-loopback group 5
Use service-loopback group to create a service loopback group and specify its service type.
Use undo service-loopback group to delete a service loopback group.
service-loopback group group-id type tunnel
undo service-loopback group group-id
No service loopback groups exist.
type: Specifies the service type of the service loopback group.
tunnel: Specifies the unicast tunnel service.
Service loopback groups must work with other features, such as GRE. A service loopback group can be used by multiple features.
You must create a service loopback group before you can use it with a feature.
To ensure correct traffic processing, do not delete a service loopback group that is being used by a feature.
# Create service loopback group 5 and specify the unicast tunnel service for the group.
[Sysname] service-loopback group 5 type tunnel
