01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S5580X-EI[HI] & S5580S-EI Switch Series Command References-R1213P50-6W10001-Fundamentals Command Reference
06-Configuration file management commands
06-Configuration file management commands 251.86 KB
archive configuration
Use archive configuration to manually archive the running configuration to the configuration archive directory.
This command saves the running configuration to the specified configuration archive directory with file names generated from the specified name prefix.
Before executing this command, you must use one of the following methods to specify a directory and a name prefix for the configuration archives:
·     For local archiving, use the archive configuration location command to specify a local configuration archive directory and a name prefix.
·     For remote archiving, use the archive configuration server command to specify a configuration archive directory and a name prefix on a remote SCP server. In addition, you must use the archive configuration server user and archive configuration server password commands to configure a username and password for accessing the server.
# Archive the running configuration.
<Sysname> archive configuration
Save the running configuration to an archive file. Continue? [Y/N]: Y
The running configuration was saved to myarchive_1.cfg.
archive configuration interval
archive configuration max
display archive configuration
Use archive configuration interval to enable automatic running-configuration archiving and set the archiving interval.
Use undo archive configuration interval to disable automatic running-configuration archiving.
archive configuration interval interval
The automatic running-configuration archiving feature is disabled.
interval: Specifies the interval for automatically saving the running configuration. The value range is 10 to 525600, in minutes.
Automatic configuration archiving enables the system to periodically save the running configuration to the archive directory. After the system finishes an automatic archive, it resets the archiving interval timer.
Before enabling automatic configuration archiving, you must use one of the following methods to specify a directory and a name prefix for the configuration archives:
# Set the system to archive the running configuration every 60 minutes.
[Sysname] archive configuration interval 60
Archive file will be saved every 60 minutes.
Use archive configuration location to specify a local directory and file name prefix for archiving the running configuration.
Use undo archive configuration location to restore the default.
archive configuration location directory filename-prefix filename-prefix
No local directory or file name prefix is specified on the device for archiving the running configuration.
directory: Specifies the archive directory, a string of 1 to 63 characters. The value for this argument must take the format of storage-medium-name:/folder-name. The directory must already exist on the device.
filename-prefix: Specifies a file name prefix for configuration archives, a case-insensitive string of 1 to 30 characters. Valid characters are letters, digits, underscores (_), and hyphens (-).
Before archiving the running configuration to the device, either manually or automatically, you must specify a local directory and file name prefix for configuration archives.
The local configuration archives on the device are named in the format of prefix_serial number.cfg, for example, archive_1.cfg and archive_2.cfg. The serial number is automatically assigned from 1 to 1000, increasing by 1. After the serial number reaches 1000, it restarts from 1.
If you change the file directory or file name prefix on the device, the following events occur:
·     The old configuration archives change to common configuration files.
·     The configuration archive counter is reset. The serial number for new configuration archives starts at 1.
·     The display archive configuration command no longer displays the old configuration archives.
The configuration archive counter does not restart when you delete configuration archives from the archive directory. However, if the device reboots after all configuration archives have been deleted, the configuration archive counter restarts. The serial number for new configuration archives starts at 1.
The undo archive configuration location command removes the local configuration archive directory and file name prefix settings. The command also performs the following operations:
·     Disables the configuration archive feature (both manual and automatic methods).
·     Restores the default settings of the archive configuration interval and archive configuration max commands.
·     Clears the configuration archive information displayed by using the display archive configuration command.
# Set the configuration archive directory as flash:/archive and the archive file name prefix as my_archive.
<Sysname> mkdir flash:/archive
Creating directory flash:/archive... Done.
[Sysname] archive configuration location flash:/archive filename-prefix my_archive
Use archive configuration max to set the maximum number of configuration archives that can be saved on the device.
Use undo archive configuration max to restore the default.
archive configuration max file-number
The maximum number is 5.
file-number: Specifies the maximum number of configuration archives that can be saved on the device. The value range for this argument is 1 to 10. Adjust the setting depending on the amount of storage space available.
Before you execute this command, use the archive configuration location command to specify a configuration archive directory and archive file name prefix on the device.
After the maximum number of configuration archives is reached, the system deletes the oldest archive for the new archive.
Changing the limit setting to a lower value does not cause immediate deletion of excess archives. Instead, the configuration archive feature deletes the oldest n files when a new archive is manually or automatically saved, where n = current archive count – new archive limit + 1. For example, seven configuration archives have been saved before the archive limit is set to four. When saving a new configuration archive, the system first deletes the oldest four (7 – 4 + 1) archives.
If you execute the undo archive configuration location command, the default archive limit is restored.
# Set the maximum number of configuration archives to 10.
[Sysname] archive configuration max 10
Use archive configuration server to configure the parameters for archiving the running configuration to a remote server.
Use undo archive configuration server to restore the default.
archive configuration server { ftp | tftp | scp } { ipv4-address | ipv6 ipv6-address } [ port port-number ] [ vpn-instance vpn-instance-name ] [ directory directory ] filename-prefix filename-prefix [ interval interval ]
No parameters are set for archiving the running configuration to a remote server.
ftp: Specifies a remote FTP server.
tftp: Specifies a remote TFTP server.
scp: Specifies a remote SCP server.
ipv4-address: Specifies the SCP server by its IPv4 address.
ipv6 ipv6-address: Specifies the SCP server by its IPv6 address.
port port-number: Specifies the TCP port number of the SCP server. The value range for the port-number argument is 1 to 65535, and the default port number is 22.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the SCP server is on the public network, do not specify this option.
directory directory: Specifies the archive directory, a case-insensitive string. If you do not specify this option, the archive directory is the root directory of the SCP server.
filename-prefix filename-prefix: Specifies a file name prefix for configuration archives, a case-insensitive string of 1 to 30 characters. Valid characters are letters, digits, underscores (_), and hyphens (-).
interval interval: Enables automatic running-configuration remote archiving and sets the archiving interval. The value range for the interval argument is 10 to 525600, in minutes.
If you use a remote FTP or SCP server, make sure the device is consistent with that server in FTP or SCP settings. If a login username and password is configured on the server, you must use the archive configuration server user and archive configuration server password commands to specify that login username and password on the device.
Before archiving the running configuration to a remote SCP server, you must perform the following tasks:
·     Use this command to specify a configuration archive directory and a name prefix on the remote SCP server.
·     Use the archive configuration server user and archive configuration server password commands to configure a username and password for accessing the server.
To manually archive the running configuration, use the archive configuration command. To periodically archive the running configuration, use the archive configuration interval command.
On the specified remote SCP server, configuration archives are named in the format of filename-prefix_YYYYMMDD_HHMMSS.cfg, for example, archive_20170526_203430.cfg.
Local archiving (the archive configuration location command) and remote archiving (the archive configuration server command) are mutually exclusive. You cannot use the two features at the same time.
The maximum number of configuration archives on a remote SCP server depends on the SCP server setting and is not restricted by the archive configuration max command.
The undo archive configuration server command removes the configuration archive directory and file name prefix settings, but it does not delete the configuration archives saved on the server. The command also performs the following operations:
·     Restores the default setting for the archive configuration interval command.
# Set the configuration archive directory as archive/ on the SCP server at 192.168.1.1 and set the archive file name prefix as my_archive.
[Sysname] archive configuration server scp 192.168.1.1 port 22 directory /archive/ filename-prefix my_archive
Use archive configuration server password to configure the password for accessing the FTP or SCP server that stores the configuration archives.
Use undo archive configuration server password to restore the default.
archive configuration server password { cipher | simple } string
No password is configured for accessing the FTP or SCP server that stores the configuration archives.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 33 to 117 characters.
# Set the password to admin in plaintext form for accessing the SCP server that saves configuration archives.
[Sysname] archive configuration server password simple admin
Use archive configuration server user to configure the username for accessing the FTP or SCP server that stores the configuration archives.
Use undo archive configuration server user to restore the default.
archive configuration server user user-name
No username is configured for accessing the FTP or SCP server that stores the configuration archives.
user-name: Specifies the username, a case-sensitive string of 1 to 63 characters.
# Set the username to admin for accessing the SCP server that saves configuration archives.
[Sysname] archive configuration server user admin
backup startup-configuration
Use backup startup-configuration to back up the main next-startup configuration file to a TFTP server.
backup startup-configuration to { ipv4-server | ipv6 ipv6-server } [ dest-filename ] [ vpn-instance vpn-instance-name ]
ipv4-server: Specifies a TFTP server by its IPv4 address or host name. The host name is a case-insensitive string of 1 to 253 characters. Valid characters include letters, digits, hyphens (-), underscores (_), and dots (.).
ipv6 ipv6-server: Specifies a TFTP server by its IPv6 address or host name. The host name is a case-insensitive string of 1 to 253 characters. Valid characters include letters, digits, hyphens (-), underscores (_), and dots (.).
dest-filename: Specifies the name of the target file used for saving the file on the server. The file must be a .cfg file. The file name is a case-insensitive string of up to 255 characters. If you do not specify a target file name, the source file name is used.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the TFTP server is on the public network, do not specify this option.
# Back up the main next-startup configuration file to the IPv4 TFTP server at 2.2.2.2 in the public network, and set the target file name to 192-168-1-26.cfg.
<Sysname> backup startup-configuration to 2.2.2.2 192-168-1-26.cfg
Backing up the main startup configuration file to 2.2.2.2...
Done.
# Back up the main next-startup configuration file to the IPv4 TFTP server at 2.2.2.2 in MPLS L3VPN instance VPN1, and set the target file name to 192-168-1-26.cfg.
<Sysname> backup startup-configuration to 2.2.2.2 192-168-1-26.cfg vpn-instance VPN1
Backing up the main startup configuration file to 2.2.2.2 in VPN VPN1...
Done.
# Back up the main next-startup configuration file to the IPv6 TFTP server at 2001::2 in the public network, and set the target file name to 192-168-1-26.cfg.
<Sysname> backup startup-configuration to ipv6 2001::2 192-168-1-26.cfg
Backing up the main startup configuration file to 2001::2...
Done.
restore startup-configuration
configuration commit
Use configuration commit to commit the settings configured after the configuration commit delay timer was set.
You must execute the configuration commit delay command to set the configuration delay timer before executing this command.
The settings you made during the commit delay interval are automatically removed if you have not manually committed them before the configuration commit delay timer expires.
As a best practice, configure the information center to output logs to the console. Use the logs to determine whether you want to commit the settings. For more information about the information center, see System Management Configuration Guide.
# Set the configuration commit delay timer to 10 minutes.
[Sysname] configuration commit delay 10
# Commit the settings configured after the configuration commit delay timer was set and before the delay timer expires.
Use configuration commit delay to enable the configuration commit delay feature and start the configuration commit delay timer.
configuration commit delay delay-time
delay-time: Sets the configuration commit delay interval. The value range is 1 to 65535 minutes.
The system creates a rollback point to record the configuration status when you execute this command to start the configuration commit delay timer. The settings you made during the commit delay interval takes effect immediately. However, these settings will be removed automatically if you have not manually committed them before the configuration commit delay timer expires. Then, the system returns to the configuration status when the commit delay timer started.
This feature prevents a misconfiguration from causing the inability to access the device and is especially useful when you configure the device remotely.
When you use this feature, follow these restrictions and guidelines:
·     In a multi-user context, make sure no one else is configuring the device.
·     To avoid unexpected errors, do not perform any operations during the configuration rollback.
·     You can reconfigure the configuration commit delay timer before it expires to shorten or extend the commit delay interval. However, the rollback point will not change.
·     The configuration commit delay feature is a one-time setting. The feature is disabled with the rollback point removed when the commit delay timer expires or after a manual commit operation is performed. To use this feature again, you must re-execute this command.
# Change the configuration commit delay timer to 60 minutes before the old delay timer expires.
[Sysname] configuration commit delay 60
The commit delay already set 10 minutes, overwrite it? [Y/N]:y
configuration encrypt
Use configuration encrypt to enable configuration encryption.
Use undo configuration encrypt to disable configuration encryption.
configuration encrypt { private-key | public-key }
Configuration encryption is disabled.
private-key: Encrypts configuration with a private key. All devices running Comware 9 software use the same private key.
public-key: Encrypts configuration with a public key. All devices running Comware 9 software use the same public key.
Configuration encryption enables the device to automatically encrypt a configuration file when saving the running configuration to the file.
Any devices running Comware 9 software can decrypt the encrypted configuration file. To prevent an encrypted file from being decoded by unauthorized users, make sure the file is accessible only to authorized users.
# Enable the public-key method for configuration encryption.
[Sysname] configuration encrypt public-key
configuration exclusive by-user-name
Use configuration exclusive by-user-name to assign a user exclusive write access to the configuration.
Use undo configuration exclusive by-user-name to restore the default.
configuration exclusive by-user-name user-name
undo configuration exclusive by-user-name user-name
The configuration is not locked. No users have exclusive write access to the configuration.
user-name: Specifies a username, a case-sensitive string of 1 to 80 characters.
In a multiuser environment, configuration conflicts or service exceptions might occur if multiple users are configuring the device.
To make sure only one user can change the running configuration, assign that user exclusive write access to the configuration. This setting locks the configuration. Then, all other users will have only read access to the configuration until the configuration is unlocked.
This command is available only for users that log in to the device through scheme authentication. Scheme authentication requires a username and password.
Only one user can lock the configuration at a time.
To unlock the configuration, use the undo configuration exclusive by-user-name user-name command. The user-name argument must be the username that locked the configuration. To obtain this username, use the display configuration exclusive by-user-name command.
The configuration exclusive by-user-name command no longer takes effect after the device reboots. To use this command, you must reconfigure it.
# Assign user aaa exclusive write access to the configuration.
[Sysname] configuration exclusive by-user-name aaa
configuration replace file
Use configuration replace file to perform configuration rollback.
filename: Specifies the path of the replacement configuration file, a string of up to 255 characters. The file must be a .cfg file. The file and file path must be valid and on the local system.
CAUTION
CAUTION:
The configuration rollback feature replaces the running configuration with the configuration in a configuration file without rebooting the device. This operation will cause settings not in the replacement configuration file to be lost, which might cause service interruption. When you perform configuration rollback, make sure you fully understand its impact on your network.
The configuration rollback feature helps you revert to a previous configuration state or adapt the running configuration to different network environments.
To ensure a successful rollback, follow these guidelines:
·     Make sure the replacement configuration file is created by using the configuration archive feature or the save command on the device.
·     If the configuration file is not created on the device, make sure the command lines in the configuration file are fully compatible with the device.
·     Make sure the replacement configuration file is not encrypted.
# Replace the running configuration with the configuration in the my_archive_1.cfg configuration file.
[Sysname] configuration replace file my_archive_1.cfg
Current configuration will be lost, save current configuration? [Y/N]:n
Now replacing the current configuration. Please wait...
Succeeded in replacing current configuration with the file my_archive_1.cfg.
configuration replace server
Use configuration replace server to roll the running configuration back by using a configuration file on a remote server.
Use undo configuration replace server to restore the default.
configuration replace server { ftp | tftp } { ipv4-address | ipv6 ipv6-address } [ port port-number ] [ vpn-instance vpn-instance-name ] [ directory directory ] file filename
No parameters are configured for remote configuration rollback.
ipv4-address: Specifies the IPv4 address of the remote server.
ipv6 ipv6-address: Specifies the IPv6 address of the remote server.
port port-number: Specifies the TCP port number of the remote server, in the range of 1 to 65535. By default, the FTP port number is 21 and the TFTP port number is 69.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the remote server is on the public network, do not specify this option.
directory directory: Specifies the remote rollback directory. The directory argument is a case-insensitive string. If you do not specify this option, the rollback directory is the root directory of the remote server.
file filename: Specifies the default replacement configuration file for running-configuration remote rollback. The filename argument is a case-insensitive string. The file must be a .cfg file.
If you use a remote FTP server, make sure the device is consistent with that FTP server in FTP settings. If a login username and password is configured on the FTP server, you must use the configuration replace server user and configuration replace server password commands to specify that login username and password on the device.
# Replace the running configuration with the configuration in the archive/ directory of the FTP server at 192.168.1.1.
[Sysname] configuration replace server ftp 192.168.1.1 port 22 directory /archive/ file my_archive_2017-05-09.cfg
configuration replace server file
display configuration replace server
Use configuration replace server file to enable remote configuration rollback.
Use undo configuration replace server file to disable remote configuration rollback.
configuration replace server file [ filename ] [ at time [ date ] ]
Remote configuration rollback is disabled.
filename: Specifies a replacement configuration file by its name, a string of up to 255 characters. The file must be a .cfg file. If you do not specify a replacement configuration file, this command uses the default replacement configuration file specified by using the configuration replace server command for a rollback.
at time: Specifies the time at which the system downloads the replacement configuration file and performs configuration rollback. The time argument is in the format of HH:MM. HH represents the hours, in the range of 0 to 23. MM represents the minutes, in the range of 0 to 59.
date: Specifies the date on which the system downloads the replacement configuration file and performs configuration rollback. This argument is in the format of MM/DD/YYYY or YYYY/MM/DD. YYYY represents the year, in the range of 2000 to 2035. MM represents the month, in the range of 1 to 12. DD represents the day, in the range of 1 to N. The value for N depends on the month.
CAUTION
CAUTION:
The remote configuration rollback feature replaces the running configuration with the configuration in a remote configuration file without rebooting the device. This operation will cause settings not in the replacement configuration file to be lost, which might cause service interruption. When you perform configuration rollback, make sure you fully understand its impact on your network.
This command enables the device to perform the following operations:
1.     Downloads the replacement configuration file from the remote rollback server.
2.     Saves the downloaded file as a temporary file.
3.     Replaces the running configuration with the configuration in the temporary file.
4.     Deletes the temporary file after the configuration rollback finishes.
To perform an immediate configuration rollback, do not specify a rollback time or date. An immediate configuration rollback cannot be canceled.
To schedule a configuration rollback, specify a rollback time and optionally a date. A configuration rollback schedule can be canceled before the specified rollback time. When you schedule a rollback, follow these restrictions and guidelines:
·     If you specify a rollback date with the rollback time, the specified date must be the same or later than the current system date. If the specified date is the same as the current system date, the specified time must be later than the current system time. After you create the rollback schedule, be careful with changing the system clock backward. The rollback schedule will be canceled automatically if it expires before it could be executed because the system date or time is changed backward.
·     If you do not specify a rollback date with the rollback time, the device compares the specified rollback time with the current system time.
¡     If the specified rollback time is later than the current system time, the device performs a rollback at the specified time on the current day.
¡     If the specified rollback time is earlier than the current system time, the device performs a rollback at the specified time on the next day.
# Roll back the running configuration immediately with the specified replacement configuration file on the remote server for configuration rollback.
[Sysname] configuration replace server file my_archive_2017-05-09.cfg
The running configuration will be lost. Do you want to save the running configuration? [Y/N]: N
Now replacing the running configuration...
Successfully replaced running configuration with file my_archive_2017-05-09.cfg.
Use configuration replace server password to configure the password for accessing the remote FTP server for configuration rollback.
Use undo configuration replace server password to restore the default.
configuration replace server password { cipher | simple } string
No password is configured for accessing the remote FTP server for remote configuration rollback.
# Set the password to admin in plaintext form for accessing the remote FTP server for configuration rollback.
[Sysname] configuration replace server password simple admin
Use configuration replace server user to specify the username for accessing the remote FTP server for configuration rollback.
Use undo configuration replace server user to restore the default.
configuration replace server user user-name
No username is configured for accessing the remote FTP server for configuration rollback.
If no username is configured, the username will be anonymous.
# Set the username to admin for accessing the remote FTP server for configuration rollback.
[Sysname] configuration replace server user admin
Use display archive configuration to display configuration archive information.
# Display information about the configuration archives saved on the device.
<Sysname> display archive configuration
Filename prefix: my_archive
Archive interval in minutes: 120
Maximum number of archive files: 10
Archive history:
  No.  TimeStamp                FileName
  1    Jan 05 2020 20:24:54     my_archive_1.cfg
  2    Jan 05 2020 20:34:54     my_archive_2.cfg
# 3    Jan 05 2020 20:44:54     my_archive_3.cfg
The pound sign (#) indicates the most recent archive file.
Next archive file to be saved: my_archive_4.cfg
# Display information about the configuration archives saved on a remote SCP server.
Username: test
Archive history:
 1     Wed Jan 15 14:20:18 2020   my_archive_20170509_142018.cfg
!2     Wed Jan 15 14:33:10 2020   my_archive_20170509_143018.cfg
#!3    Wed Jan 15 14:49:37 2020   my_archive_20170509_144018.cfg
The exclamation mark (!) indicates that the remote archiving attempt failed.
Username
Username for accessing the remote FTP or SCP server that stores the configuration archives.
If the remote server is a TFTP server, this field is not available.
Location
Absolute path of the directory for saving running-configuration archives.
Filename prefix
File name prefix for configuration archives.
Interval (in minutes) for the system to automatically archive the running configuration.
If automatic configuration saving is disabled, this field is not available.
Maximum number of configuration archives that can be saved on the device.
Archive history
History configuration archive information.
No.
Number of a configuration archive.
TimeStamp
Time when the configuration archive was created.
Use display configuration exclusive by-user-name to display information about user-based configuration locking.
# Display information about configuration locking after the system configuration was locked.
<Sysname> display configuration exclusive by-user-name
User-name: aaa
Locked at: 2018-03-07T20:13:31
# Display information about configuration locking after the configuration was unlocked.
User-name: aaa
Unlocked at: 2018-03-07T20:14:09
Use display configuration replace server to display information about remote configuration rollback.
The device stores only the most recent 10 remote rollback records.
# Display information about remote configuration rollback.
<Sysname> display configuration replace server
Username: test
VPN instance: VPN1
Next replacement file: my_archive_20180509_143018.cfg
Next replacement time: 22:00 2018/6/12
Replacement history:
  No. Time                     FileName
 ! 1  20:21:09 2018/10/18      my_archive_20180509_142018.cfg
 ! 2  20:25:00 2018/10/18      my_archive_20180509_143018.cfg
#! 3  22:52:23 2018/10/20      my_archive_20180509_144018.cfg
The exclamation mark (!) indicates that the remote replacing attempt failed.
The pound sign (#) indicates the most recent replacement file.
Username
Username for accessing the remote server to download a configuration file for configuration rollback.
Location
Absolute path of the replacement configuration file.
VPN instance
VPN instance to which the remote server belongs.
Configuration file for the next remote configuration rollback.
If no remote configuration rollback schedule is waiting for execution, this field is not available.
Time and date for the next remote configuration rollback.
Replacement history
Remote configuration rollback history.
No.
Number of a configuration rollback.
Time
Time and date when the configuration rollback was performed.
Filename
Name of the replacement configuration file.
display current-configuration
Use display current-configuration to display the running configuration.
display current-configuration [ [ configuration [ module-name ] | exclude-provision | interface [ interface-type [ interface-number ] ] ] [ all ] | slot slot-number ]
configuration [ module-name ]: Displays the feature configuration. The module-name argument specifies a feature module. If you do not specify a feature module, the command displays all feature settings you have made.
exclude-provision: Excludes preprovisioned settings from the running configuration.
interface [ interface-type [ interface-number ] ]: Displays interface configuration, where the interface-type argument represents the interface type and the interface-number argument represents the interface number. If you do not specify the interface-type interface-number arguments, the command displays the running configuration for all interfaces. If you specify only the interface-type argument, the command displays the running configuration for all interfaces of this type.
all: Displays all settings in the running configuration, including the default settings. If you do not specify this keyword, the command displays only non-default settings in the running configuration.
slot slot-number: Specifies the slot number of the device, which is fixed at 1.
Use this command to verify the configuration you have made.
If the system has automatically changed the setting you have made for a parameter, this command displays the effective setting instead of the configured one. An automatic change typically occurs because of system restrictions. This command does not display parameters that are using the default settings if you do not specify the all keyword.
# Display local user configuration.
<Sysname> display current-configuration configuration local-user
local-user ftp class manage
 password hash $h$6$D5A6pqcGpnZXxFUO$OJqnqffG7m1wTH3C6v+FBCjZZBzqgJjTZlbATl1dnKNlYwFMJcWDMbDn8HD1j4XzuKggDp2LrP40kGIOvQGYhQ==
 service-type ftp
local-user root class manage
 password hash $h$6$GcTZyXO04qmom21z$GjeAeDMjP/xtknMLf9NHUNIvebNYR3tkd5aWS6sKbkFh/ECFJZOjh2FVUI0GW7u44fNK6Ke7ANE7dhhAFcytUQ==
return
# Display VLAN interface configuration.
<Sysname> display current-configuration interface Vlan-interface
interface Vlan-interface1
 ip address 192.168.1.84 255.255.255
Return
display current-configuration diff
Use display current-configuration diff to display the differences that the running configuration has as compared with the next-startup configuration.
This command searches for the next-startup configuration in the following order:
1.     The .cfg main next-startup configuration file.
2.     The .cfg backup next-startup configuration file if the .cfg main next-startup configuration file is unavailable.
If both configuration files are unavailable, the system displays a message indicating that no next-startup configuration files exist.
# Display the differences that the running configuration has as compared with the next-startup configuration.
<Sysname> display current-configuration diff
--- Startup configuration
+++ Current configuration
@@ -5,7 +5,7 @@
  sysname Sysname
-alias dhc display history-command
+alias dh display hotkey
<Sysname>
- - - A
+++ B
·     A represents the source configuration for comparison, which can be Startup configuration, Current configuration, or the name of the source configuration file with its directory information.
·     B represents the target configuration for comparison, which can be Current configuration, Startup configuration, or the name of the target configuration file with its directory information.
In this example, the startup configuration and the current configuration are the source and target, respectively.
@@ -linenumber1,number1 +linenumber2,number2 @@
Location information for identifying the command line differences:
·     -linenumber1,number1—Source configuration section that contains differences. The linenumber1 argument represents the start line of the section. The number1 argument represents the number of lines between the start line and the end line of the section.
·     +linenumber2,number2—Target configuration section that contains differences. The linenumber2 argument represents the start line of the section. The number2 argument represents the number of lines between the start line and the end line of the section.
cmd1
- cmd2
+ cmd3
cmd4
Displays command differences.
·     cmd1 and cmd4—Command lines are contained in both source and target configurations if they are not prefixed with a minus (-) or plus (+) sign. They provide a context for locating command line differences.
·     - cmd2—Command lines are prefixed with a minus sign if they are contained in the source configuration but not in the target configuration.
·     + cmd3—Command lines are prefixed with a plus sign if they are contained in the target configuration but not in the source configuration.
In this example, the sample output shows that the alias dhc display history-command command is contained only in the source configuration, and the alias dh display hotkey command is contained only in the target configuration.
display diff
display saved-configuration
display default-configuration
Use display default-configuration to display the factory defaults.
Factory defaults are custom basic settings that came with the device. Factory defaults vary by device models and might differ from the initial default settings for the commands.
If no factory defaults came with the device, the output of the display default-configuration command is empty.
The device starts up with the factory defaults if no next-startup configuration files are available.
# Display the factory defaults.
<Sysname> display default-configuration
display diff
Use display diff to display differences between configurations.
display diff configfile file-name-s { configfile file-name-d | current-configuration | startup-configuration }
display diff current-configuration { configfile file-name-d | startup-configuration }
display diff startup-configuration { configfile file-name-d | current-configuration }
configfile file-name-s: Specifies the source configuration file for comparison.
configfile file-name-d: Specifies the target configuration file for comparison.
current-configuration: Specifies the running configuration. In the display diff current-configuration command, this keyword specifies the source configuration for comparison. In the display diff configfile file-name-s and display diff startup-configuration commands, this keyword specifies the target configuration.
startup-configuration: Specifies the next-startup configuration. In the display diff startup-configuration command, this keyword specifies the source configuration for comparison. In the display diff configfile file-name-s and display diff current-configuration commands, this keyword specifies the target configuration.
If you specify the startup-configuration keyword, the system searches for the next-startup configuration in the following order:
# Display the differences between startup.cfg and test.cfg.
<Sysname> display diff configfile startup.cfg configfile test.cfg
--- flash:/startup.cfg
+++ flash:/test.cfg
@@ -5,7 +5,7 @@
  sysname Sysname
<Sysname>
The output shows that the alias dhc display history-command command is contained only in startup.cfg, and the alias dh display hotkey command is contained only in test.cfg.
# Display the differences between the running configuration and the next-startup configuration.
<Sysname> display diff current-configuration startup-configuration
--- Current configuration
+++ Startup configuration
@@ -5,7 +5,7 @@
  sysname Sysname
<Sysname>
The output shows that the alias dhc display history-command command is contained only in the running configuration, and the alias dh display hotkey command is contained only in the next-startup configuration.
For the command output description, see Table 3.
Use display saved-configuration to display the contents of the configuration file for the next system startup.
Use this command to verify that important settings have been saved to the configuration file for the next system startup.
This command selects the configuration file to display in the following order:
1.     If the main startup configuration file is available, this command displays the content of the main startup configuration file.
2.     If only the backup startup configuration file is available, this command displays the content of the backup file.
3.     If both the main and backup startup configuration files are not available, this command does not display anything.
# Display the contents of the configuration file for the next system startup.
<Sysname> display saved-configuration
 version 7.1.070, Release 1201
 sysname Sysname
 ftp server enable
 telnet server enable
 domain default enable system
vlan 1
domain system
  ---- More ----
reset saved-configuration
save
display startup
Use display startup to display the names of all startup configuration files, including the file that the device started up with and the files for next startup.
display startup
# Display names of the startup configuration files.
<Sysname> display startup
MainBoard:
 Current startup saved-configuration file: flash:/startup.cfg
 Next main startup saved-configuration file: flash:/startup.cfg
 Next backup startup saved-configuration file: NULL
MainBoard
Displays the startup configuration files on the device.
Configuration file that the device has started up with.
If the field is suffixed with an asterisk (*), the startup configuration file is a binary file.
Primary configuration file to be used at the next startup.
Backup configuration file to be used at the next startup.
display this
Use display this to display the running configuration in the current view.
display this [ all ]
all: Displays all settings in the running configuration in the current view, including the default settings. If you do not specify this keyword, the command displays only non-default settings in the running configuration.
Use this command to verify the configuration you have made in a certain view.
Some parameters can be successfully set even if their dependent features are not enabled. For these parameters, this command displays their settings after the dependent features are enabled.
This command can be executed in any user line view to display the running configuration of all user lines.
# Display the running configuration on VLAN-interface 1.
[Sysname-Vlan-interface1] display this
return
Use reset saved-configuration to delete a next-startup configuration file.
backup: Specifies the backup next-startup configuration file.
main: Specifies the main next-startup configuration file.
CAUTION
CAUTION:
This command permanently deletes the specified next-startup configuration file from the device.
You can delete the main file, the backup file, or both.
To delete a file that is set as both main and backup next-startup configuration files, you must execute both the reset saved-configuration backup command and the reset saved-configuration main command. Using only one of the commands sets the target file attribute to NULL instead of deleting the file.
If you do not specify a configuration file attribute, the reset saved-configuration command deletes the main next-startup configuration file.
# Delete the main next-startup configuration file.
<Sysname> reset saved-configuration
The saved configuration file will be erased. Are you sure? [Y/N]:y
Configuration file in flash: is being cleared.
Please wait ...........
Configuration file is cleared.
Use restore startup-configuration to download a configuration file from a TFTP server and specify it as the main next-startup configuration file.
restore startup-configuration from { ipv4-server | ipv6 ipv6-server } src-filename [ vpn-instance vpn-instance-name ]
src-filename: Specifies the name of the configuration file to be downloaded. The file must be a .cfg file. The file name is a case-insensitive string of up to 255 characters.
Before restoring the configuration file for the next startup, make sure the following requirements are met:
·     The server is reachable.
·     The server is enabled with TFTP service.
·     You have read and write permissions to the server.
This command is not available if you have used the tftp client ipv6 source interface command to specify a management Ethernet interface as the source interface.
# Download test.cfg from the IPv4 TFTP server at 2.2.2.2 in the public network, and specify the file as the main next-startup configuration file.
<Sysname> restore startup-configuration from 2.2.2.2 test.cfg
Restoring the next startup-configuration file from 2.2.2.2. Please wait...finished.
# Download test.cfg from the IPv4 TFTP server at 2.2.2.2 in MPLS L3VPN instance VPN1, and specify the file as the main next-startup configuration file.
<Sysname> restore startup-configuration from 2.2.2.2 test.cfg vpn-instance VPN1
# Download test.cfg from the IPv6 TFTP server at 2001::2 in the public network, and specify the file as the main next-startup configuration file.
<Sysname> restore startup-configuration from ipv6 2001::2 test.cfg
Restoring the next startup-configuration file from 2001::2. Please wait...finished.
save
Use save file-url [ all | slot slot-number ] to save the running configuration to a configuration file, without specifying the file as a next-startup configuration file.
Use save [ safely ] [ backup | main ] [ force ] [ changed ] to save the running configuration as a next-startup configuration file in the root directory of the storage medium.
file-url: Specifies a file path, a string of up to 255 characters. The file must be a .cfg file.
all: Saves the running configuration to the device.
safely: Saves the configuration file in safe mode. If you do not specify this keyword, the device saves the configuration file in fast mode.
backup: Saves the running configuration to a configuration file, and specifies the file as the backup next-startup configuration file. If you do not specify this keyword or the main keyword, the command specifies the saved file as the main next-startup configuration file.
main: Saves the running configuration to a configuration file, and specifies the file as the main next-startup configuration file. If you do not specify this keyword or the backup keyword, the command specifies the saved file as the main next-startup configuration file.
force: Saves the running configuration to the existing next-startup configuration file without prompting for confirmation. If you do not specify this keyword, the system prompts you to confirm the operation. If you do not confirm the operation within 30 seconds, the system automatically aborts the operation. If you enter Y within the time limit, you can continue the save process and change the target file name during the process.
changed: Overwrites the target configuration file with the running configuration if an inconsistency is detected between the settings in the configuration file and the running configuration. The save command does not take effect if no inconsistency is detected. If you do not specify this keyword, the save command always overwrites the target configuration file with the running configuration.
CAUTION
CAUTION:
Use the save command with caution. This command will overwrite the settings in the target configuration file. When you execute this command, carefully read the messages displayed by the system and make sure you fully understand the impact of this command on services.
If the file specified for this command does not exist, the system creates the file before saving the configuration. If the file already exists, the system prompts you to confirm whether to overwrite the file. If you choose to not overwrite the file, the system cancels the save operation.
This command saves the running configuration to an .mdb binary file as well as a .cfg text file. The two files use the same file name. An .mdb file takes less time to load than a .cfg file.
When you use the save [ safely ] [ backup | main ] [ force ] [ changed ] command, follow these guidelines:
·     In safe mode, the system saves configuration in a temporary file and starts overwriting the target next-startup configuration file after the save operation is complete. If a reboot, power failure, or out of memory or storage space event occurs during the save operation, the next-startup configuration file is retained.
·     In fast mode, the device directly overwrites the target next-startup configuration file. If a reboot, power failure, or out of memory or storage space event occurs during this process, all settings in the next-startup configuration file are lost.
Safe mode is slower than fast mode, but more secure. As a best practice, specify the safely keyword for reliable configuration saving.
If containers have been created on the device, follow these guidelines when you use the save command to save the running configuration:
·     If you do not specify the force keyword, the system prompts you to confirm whether to save the settings of the containers.
¡     If you enter Y at the prompt, the system saves the settings of the containers for the settings to survive a reboot. Saving the container settings will take some time.
¡     If you enter N at the prompt or do not confirm the prompt in 30 seconds, the system continues the saving process without saving the container settings.
·     If you specify the force keyword, the system saves the container settings without any confirmation required.
# Save the running configuration to backup.cfg, without specifying the file as a next-startup configuration file.
<Sysname> save backup.cfg
The current configuration will be saved to flash:/backup.cfg. Continue? [Y/N]:y
Now saving current configuration to the device.
Saving configuration flash:/backup.cfg. Please wait...
Configuration is saved to device successfully.
# Save the running configuration to the main next-startup configuration file without any confirmation required.
<Sysname> save force
Validating file. Please wait....
# When containers exist on the device, save the running configuration to the main next-startup configuration file without any confirmation required.
Saving docker files need some time.
Saving docker files............
Done.
# Save the running configuration to a file in the root directory of the default storage medium, and specify the file as the main next-startup configuration file.
<Sysname> save
Please input the file name(*.cfg)[flash:/backup.cfg]
(To leave the existing filename unchanged, press the enter key):test.cfg
Validating file. Please wait............
# When containers exist on the device, save the running configuration to a file in the root directory of the default storage medium, and specify the file as the main next-startup configuration file.
<Sysname> save
Saving docker files need some time. Do you want to save docker files in this process? [Y/N]:y
Done.
save current-configuration interval
Use save current-configuration interval to enable the automatic configuration saving feature and set the automatic saving interval.
Use undo save current-configuration interval to restore the default.
save current-configuration interval interval
The automatic configuration saving feature is disabled.
interval: Sets the automatic saving interval, in minutes. The value range is 10 to 525600.
This feature enables the device to automatically save the running configuration to both the .cfg and .mdb main next-startup configuration files at intervals. At each interval, the device performs an automatic saving operation only if the running configuration contains different settings than the main next-startup configuration files.
If no main next-startup configuration files exist, this feature automatically creates configuration files startup.cfg and startup.mdb to save the running configuration and specifies the files as the main next-startup configuration files.
# Enable the device to automatically save the running configuration to the .cfg and .mdb main next-startup configuration files every 60 minutes.
[Sysname] save current-configuration interval 60
Use startup saved-configuration to specify a file as a next-startup configuration file.
Use undo startup saved-configuration to configure the system to start up with the factory defaults at the next startup.
No next-startup configuration files are specified.
cfgfile: Specifies the path of a configuration file, a string of up to 255 characters. The file must be a .cfg file. The file path can include only the file name, or the storage medium information and file name. If the file is not on the default storage medium, you must specify the file name with storage medium information.
backup: Specifies the configuration file as the backup next-startup configuration file.
main: Specifies the configuration file as the main next-startup configuration file. This is the primary configuration file that the device attempts to load at startup. If the loading attempt fails, the device tries the backup next-startup configuration file.
If you do not specify the backup or main keyword, the startup saved-configuration command specifies the main next-startup configuration file.
As a best practice, specify different files as the main and backup next-startup configuration files.
The undo startup saved-configuration command changes the file attribute of the main and backup next-startup configuration files to NULL. However, the command does not delete the two configuration files.
You can also specify a configuration file as a next startup file when you use the save command to save the running configuration.
# Specify the main next-startup configuration file.
<Sysname> startup saved-configuration testcfg.cfg
Please wait ....... Done.
display startup
