01-HH3C-RADIUS-MIB | 104.46 KB |
HH3C-RADIUS-MIB
About this MIB
Use this MIB to obtain and configure RADIUS server settings.
MIB file name
hh3c-radius.mib
Notifications
hh3cRadiusAuthServerUpTrap
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.13.3.0.1 |
Authentication server up |
Informational |
Warning |
N/A (N/A) |
OFF |
Notification triggers
Notification Triggers
System impact
OID
Event
Severity
Default status
Informational
Warning
N/A
OFF
This notification is generated when the state of an authentication server changes from blocked to active.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable radius authentication-server-up command.
OFF
CLI: Use the undo snmp-agent trap enable radius authentication-server-up command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.67.1.2.1.1.3.1.2 (radiusAuthServerAddress) |
IP address of an authentication server. |
Yes |
IP Address |
Standard MIB values. |
1.3.6.1.2.1.67.1.2.1.1.3.1.3 (radiusAuthClientServerPortNumber) |
Port number of the authentication server. |
Yes |
INTEGER |
1.. 65535 |
Recommended action
No action is required.
hh3cRadiusAccServerUpTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.13.3.0.2 |
Accounting server up |
Informational |
Warning |
N/A (N/A) |
OFF |
System impact
OID
Event
Severity
Default status
Informational
Warning
N/A
OFF
This notification is generated when the state of an accounting server changes from blocked to active.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable radius accounting-server-up command.
OFF
CLI: Use the undo snmp-agent trap enable radius accounting-server-up command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.67.2.2.1.1.3.1.2 (radiusAccServerAddress) |
IP address of an accounting server. |
Yes |
IP Address |
1.3.6.1.2.1.67.2.2.1.1.3.1.3 (radiusAccClientServerPortNumber) |
Port number of the accounting server. |
Yes |
INTEGER |
1.. 65535 |
Recommended action
hh3cRadiusAuthErrTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.13.3.0.3 |
Authentication failure alarm threshold crossing. |
Informational |
Major |
N/A (N/A) |
OFF |
System impact
OID
Event
Severity
Default status
Informational
Major
N/A
OFF
This notification is generated when the authentication failure ratio reaches the authentication failure alarm threshold.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable radius authentication-error-threshold command.
OFF
CLI: Use the undo snmp-agent trap enable radius authentication-error-threshold command.
Object
OID (object name) |
Index |
Type |
Value range |
Yes |
IP Address |
Yes |
INTEGER |
1.. 65535 |
Recommended action
hh3cRadiusAuthServerDownTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.13.3.1 |
Authentication server down |
Informational |
Major |
N/A (N/A) |
OFF |
System impact
OID
Event
Severity
Default status
Informational
Major
N/A
OFF
This notification is generated when the state of an authentication server changes from active to blocked.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable radius authentication-server-down command.
OFF
CLI: Use the undo snmp-agent trap enable radius authentication-server-down command.
Object
OID (object name) |
Index |
Type |
Value range |
Yes |
IP Address |
Yes |
INTEGER |
1.. 65535 |
Recommended action
hh3cRadiusAccServerDownTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.13.3.2 |
Accounting server down |
Informational |
Major |
N/A (N/A) |
OFF |
System impact
OID
Event
Severity
Default status
Informational
Major
N/A
OFF
This notification is generated when the state of an accounting server changes from active to blocked.
【System impact】
Status control
ON
CLI: Use the snmp-agent trap enable radius accounting-server-down command.
OFF
CLI: Use the undo snmp-agent trap enable radius accounting-server-down command.
Object
OID (object name) |
Index |
Type |
Value range |
Yes |
IP Address |
Port number of an accounting server. |
Yes |
INTEGER |
1.. 65535 |
Recommended action
