03-Interface
HomeSupportSwitchesS12500R SeriesReference GuidesMIB CompanionH3C S12500R Switch Router Series MIB Companion(52xx)-6W10103-Interface
03-IF-MIB
03-IF-MIB 113.82 KB
IF-MIB
About this MIB
This MIB describes generic attributes for network interfaces.
MIB file name
rfc2863-if.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ifMIB(31)
Scalar objects
ifNumber
Object (OID)
Access
Value range
Implementation
ifNumber(1.3.6.1.2.1.2.1)
read-only
Integer32
Integer32(1..2147483647)
Number of interfaces.
As per the MIB.
ifTableLastChange
Object (OID)
Access
Value range
Implementation
ifTableLastChange (1.3.6.1.2.1.31.1.5)
read-only
TimeTicks
TimeTicks (0..4294967295)
Value of sysUpTime at the time of the last creation or deletion of an entry in the IfTable.
Not supported
ifStackLastChange
Object (OID)
Access
Value range
Implementation
ifStackLastChange (1.3.6.1.2.1.31.1.6)
read-only
TimeTicks
Value of sysUpTime at the time of the last creation or deletion of the whole interface stack.
Not supported
Tabular objects
ifTable
About this table
Use this table to obtain information about an interface by interface index.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
ifIndex (1.3.6.1.2.1.2.2.1.1)
read-only
Integer32
Integer32 (1..2147483647)
Index of an interface.
As per the MIB.
ifDescr (1.3.6.1.2.1.2.2.1.2)
read-only
DisplayString
OCTET STRING(0..255)
Description of the interface.
A string that contains information about the interface, null0, Vlan-interface2, Gigabitethernet1/0/1, Ten-Gigabitethernet2/0/1, for example.
ifType (1.3.6.1.2.1.2.2.1.3)
read-only
IANAifType
INTEGER {
other(1),
regular1822(2),
hdh1822(3),
ddnX25(4),
rfc877x25(5),
ethernetCsmacd(6), iso88023Csmacd(7), iso88024TokenBus(8), iso88025TokenRing(9), iso88026Man(10),
starLan(11),
proteon10Mbit(12), proteon80Mbit(13), hyperchannel(14),
fddi(15),
lapb(16),
sdlc(17),
ds1(18),
e1(19),
basicISDN(20),
primaryISDN(21), propPointToPointSerial(22), ppp(23),
softwareLoopback(24),
eon(25),
ethernet3Mbit(26),
nsip(27),
slip(28),
ultra(29),
ds3(30),
sip(31),
frameRelay(32),
rs232(33),
para(34),
arcnet(35),
arcnetPlus(36),
atm(37),
miox25(38),
sonet(39),
x25ple(40),
iso88022llc(41),
localTalk(42),
smdsDxi(43), frameRelayService(44),
v35(45),
hssi(46),
hippi(47),
modem(48),
aal5(49),
sonetPath(50),
sonetVT(51),
smdsIcip(52),
propVirtual(53), propMultiplexor(54), ieee80212(55),
fibreChannel(56), hippiInterface(57), frameRelayInterconnect(58), aflane8023(59),
aflane8025(60),
cctEmul(61),
fastEther(62), isdn(63), v11(64), v36(65), g703at64k(66), g703at2mb(67), qllc(68), fastEtherFX(69), channel(70), ieee80211(71), ibm370parChan(72), escon(73), dlsw(74), isdns(75), isdnu(76), lapd(77), ipSwitch(78), rsrb(79), atmLogical(80), ds0(81), ds0Bundle(82), bsc(83), async(84), cnr(85), iso88025Dtr(86), eplrs(87), arap(88), propCnls(89), hostPad(90), termPad(91), frameRelayMPI(92), x213(93), adsl(94), radsl(95), sdsl(96), vdsl(97), iso88025CRFPInt(98), myrinet(99), voiceEM(100), voiceFXO(101), voiceFXS(102), voiceEncap(103), voiceOverIp(104), atmDxi(105), atmFuni(106), atmIma(107), pppMultilinkBundle(108), ipOverCdlc(109), ipOverClaw(110), stackToStack(111), virtualIpAddress(112), mpc(113), ipOverAtm(114), iso88025Fiber(115), tdlc(116), gigabitEthernet(117), hdlc(118), lapf(119), v37(120), x25mlp(121), x25huntGroup(122), transpHdlc(123),
interleave(124),
fast(125),
ip(126),
docsCableMaclayer(127), docsCableDownstream(128), docsCableUpstream(129), a12MppSwitch(130),
tunnel(131),
coffee(132),
ces(133),
atmSubInterface(134),
l2vlan(135),
l3ipvlan(136),
l3ipxvlan(137), digitalPowerline(138), mediaMailOverIp(139),
dtm(140),
dcn(141),
ipForward(142),
msdsl(143),
ieee1394(144),
if-gsn(145),
dvbRccMacLayer(146), dvbRccDownstream(147), dvbRccUpstream(148), atmVirtual(149),
mplsTunnel(150),
srp(151),
voiceOverAtm(152), voiceOverFrameRelay(153), idsl(154),
compositeLink(155), ss7SigLink(156), propWirelessP2P(157), frForward(158),
rfc1483(159),
usb(160),
ieee8023adLag(161), bgppolicyaccounting(162), frf16MfrBundle(163), h323Gatekeeper(164), h323Proxy(165),
mpls(166),
mfSigLink(167),
hdsl2(168),
shdsl(169),
ds1FDL(170),
pos(171),
dvbAsiIn(172),
dvbAsiOut(173),
plc(174),
nfas(175),
tr008(176),
gr303RDT(177),
gr303IDT(178),
isup(179), propDocsWirelessMaclayer(180), propDocsWirelessDownstream(181), propDocsWirelessUpstream(182), hiperlan2(183),
propBWAp2Mp(184), sonetOverheadChannel(185), digitalWrapperOverheadChannel(186), aal2(187), radioMAC(188), atmRadio(189),
imt(190),
mvl(191),
reachDSL(192),
frDlciEndPt(193), atmVciEndPt(194), opticalChannel(195), opticalTransport(196), propAtm(197),
voiceOverCable(198), infiniband(199),
teLink(200), q2931(201),
virtualTg(202), sipTg(203),
sipSig(204), docsCableUpstreamChannel(205), econet(206),
pon155(207), pon622(208),
bridge(209),
linegroup(210),
voiceEMFGD(211), voiceFGDEANA(212),
voiceDID(213),
mpegTransport(214), sixToFour(215),
gtp(216), pdnEtherLoop1(217), pdnEtherLoop2(218), opticalChannelGroup(219), homepna(220), gfp(221), ciscoISLvlan(222), actelisMetaLOOP(223), fcipLink(224),
rpr(225),
qam(226),
lmp(227),
cblVectaStar(228), docsCableMCmtsDownstream(229), adsl2(230), macSecControlledIF(231), macSecUncontrolledIF(232), aviciOpticalEther(233), atmbond(234),
voiceFGDOS(235), mocaVersion1(236), ieee80216WMAN(237), adsl2plus(238), dvbRcsMacLayer(239),
dvbTdm(240),
dvbRcsTdma(241),
x86Laps(242),
wwanPP(243),
wwanPP2(244),
voiceEBS(245),
ifPwType(246),
ilan(247),
pip(248),
aluELP(249),
gpon(250),
vdsl2(251), capwapDot11Profile(252), capwapDot11Bss(253), capwapWtpVirtualRadio(254), bits(255), docsCableUpstreamRfPort(256), cableDownstreamRfPort(257), switchstack(65534)
Type of the interface.
Implementation varies by product.
ifMtu (1.3.6.1.2.1.2.2.1.4)
read-only
Integer32
MTU of the interface.
Size of the largest packet that can be received or forwarded on the interface.
This object is inapplicable to aggregate interfaces.
ifSpeed (1.3.6.1.2.1.2.2.1.5)
read-only
Gauge32
Gauge32 (0..4294967295)
Speed of the interface.
Estimated bandwidth of the interface.
ifPhysAddress (1.3.6.1.2.1.2.2.1.6)
read-only
PhysAddress
OCTET STRING
MAC address of the interface.
For a switch, only the following types of interfaces have a MAC address:
·     M-Ethernet port.
·     Vlan interface.
·     Ethernet port.
·     GigabitEthernet port.
·     XGigabitEthernet port.
·     Forty-GigabitEthernet port.
·     Hundred-GigabitEthernet port.
ifAdminStatus (1.3.6.1.2.1.2.2.1.7)
read- write
OCTET STRING
up(1),
down(2),
testing(3)
Default status of the interface.
Supports only the values up(1) and down(2).
ifOperStatus (1.3.6.1.2.1.2.2.1.8)
read-only
OCTET STRING
up(1),
down(2),
testing(3),
unknown(4),
dormant(5),
notPresent(6),
lowerLayerDown(7)
Operational status of the interface.
Current operational status of the interface.
ifLastChange (1.3.6.1.2.1.2.2.1.9)
read-only
TimeTicks
Duration of the interface.
Time elapsed since the interface entered in the current status.
ifInOctets (1.3.6.1.2.1.2.2.1.10)
read-only
Counter32
Counter32 (0..4294967295)
Number of octets in incoming packets.
As per the MIB.
ifInUcastPkts (1.3.6.1.2.1.2.2.1.11)
read-only
Counter32
Number of incoming unicast packets.
As per the MIB.
ifInNUcastPkts (1.3.6.1.2.1.2.2.1.12)
read-only
Counter32
Number of incoming non-unicast packets.
As per the MIB.
ifInDiscards (1.3.6.1.2.1.2.2.1.13)
read-only
Counter32
Number of incoming packets that were dropped.
Not supported by switches.
ifInErrors (1.3.6.1.2.1.2.2.1.14)
read-only
Counter32
Number of incoming packets that contain errors.
As per the MIB.
ifInUnknownProtos (1.3.6.1.2.1.2.2.1.15)
read-only
Counter32
Number of incoming protocol-unknown packets.
As per the MIB.
ifOutOctets (1.3.6.1.2.1.2.2.1.16)
read-only
Counter32
Number of octets in outgoing packets.
As per the MIB.
ifOutUcastPkts (1.3.6.1.2.1.2.2.1.17)
read-only
Counter32
Number of outgoing unicast packets.
As per the MIB.
ifOutNUcastPkts (1.3.6.1.2.1.2.2.1.18)
read-only
Counter32
Number of outgoing non-unicast packets.
As per the MIB.
ifOutDiscards (1.3.6.1.2.1.2.2.1.19)
read-only
Counter32
Number of outgoing packets that were dropped.
As per the MIB.
ifOutErrors (1.3.6.1.2.1.2.2.1.20)
read-only
Counter32
Number of outgoing packets that contain errors.
As per the MIB.
ifOutQLen (1.3.6.1.2.1.2.2.1.21)
read-only
Gauge32
Length of the outgoing packet queue.
ifSpecific (1.3.6.1.2.1.2.2.1.22)
read-only
OCTET IDENTIFIER
OCTET IDENTIFIER
Interface for realize specific definitions.
Not supported
ifXTable
About this table
Use this table to obtain information about an interface by interface name.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is ifName.
Object (OID)
Access
Value range
Implementation
ifName (1.3.6.1.2.1.31.1.1.1.1)
read-only
DisplayString
Name of an interface.
Interface name.
ifInMulticastPkts (1.3.6.1.2.1.31.1.1.1.2)
read-only
Counter32
Number of incoming multicast packets.
As per the MIB.
ifInBroadcastPkts (1.3.6.1.2.1.31.1.1.1.3)
read-only
Counter32
Number of incoming broadcast packets.
As per the MIB.
ifOutMulticastPkts (1.3.6.1.2.1.31.1.1.1.4)
read-only
Counter32
Number of outgoing multicast packets.
As per the MIB.
ifOutBroadcastPkts (1.3.6.1.2.1.31.1.1.1.5)
read-only
Counter32
Number of outgoing broadcast packets.
As per the MIB.
ifHCInOctets (1.3.6.1.2.1.31.1.1.1.6)
read-only
Counter64
Counter64 (0..18446744073709551615)
As per the MIB.
ifHCInUcastPkts (1.3.6.1.2.1.31.1.1.1.7)
read-only
Counter64
As per the MIB.
ifHCInMulticastPkts (1.3.6.1.2.1.31.1.1.1.8)
read-only
Counter64
As per the MIB.
ifHCInBroadcastPkts (1.3.6.1.2.1.31.1.1.1.9)
read-only
Counter64
As per the MIB.
ifHCOutOctets (1.3.6.1.2.1.31.1.1.1.10)
read-only
Counter64
Number of octets in outgoing multicast packets.
As per the MIB.
ifHCOutUcastPkts (1.3.6.1.2.1.31.1.1.1.11)
read-only
Counter64
As per the MIB.
ifHCOutMulticastPkts (1.3.6.1.2.1.31.1.1.1.12)
read-only
Counter64
As per the MIB.
ifHCOutBroadcastPkts (1.3.6.1.2.1.31.1.1.1.13)
read-only
Counter64
As per the MIB.
ifLinkUpDownTrapEnable (1.3.6.1.2.1.31.1.1.1.14)
read-write
INTEGER
enabled(1),
disabled(2)
Whether to enable link-up or link-down traps on the interface.
As per the MIB.
ifHighSpeed (1.3.6.1.2.1.31.1.1.1.15)
read-only
Gauge32
Bandwidth of the interface.
As per the MIB.
ifPromiscuousMode (1.3.6.1.2.1.31.1.1.1.16)
read-write
TruthValue
true(1),
false(2)
Enabling status of promiscuous mode.
ifConnectorPresent (1.3.6.1.2.1.31.1.1.1.17)
read-only
TruthValue
true(1),
false(2)
Whether the interface sublayer has a physical connector.
As per the MIB.
ifAlias (1.3.6.1.2.1.31.1.1.1.18)
read-write
DisplayStringOCTET STRING
OCTET STRING(0..64)
Alias of the interface.
As per the MIB.
ifCounterDiscontinuityTime (1.3.6.1.2.1.31.1.1.1.19)
read-only
TimeTicks
Time when the interface's counters suffered discontinuity.
ifRcvAddressTable
About this table
Use this table to configure the address of an interface to receive packets.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Supported
Supported
Columns
The table index is ifRcvAddressAddress.
Object (OID)
Access
Value range
Implementation
ifRcvAddressAddress (1.3.6.1.2.1.31.1.4.1.1)
not-accessible
PhysAddress
OCTET STRING (4)
Address of an interface to receive packets.
ifRcvAddressStatus (1.3.6.1.2.1.31.1.4.1.2)
read-create
INTEGER
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Status of the receiving address.
ifRcvAddressType (1.3.6.1.2.1.31.1.4.1.3)
read-create
INTEGER
other(1),
volatile(2),
nonVolatile(3)
Type of the receiving address.
Notifications
This section contains the IF-MIB notifications.
linkDown
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.6.3.1.1.5.3
Link down.
Error
Major
1.3.6.1.6.3.1.1.5.4 (linkUp)
ON
This notification is generated when the SNMPv2 entity, acting in an agent role, has detected that the ifOperStatus object for one of its communication links is about to enter the down state from some other state (but not from the notPresent state.  Other states refer to the values of the ifOperStatus variable.
Status control
ON
CLI: Use the snmp-agent trap enable standard linkdown command.
OFF
CLI: Use the undo snmp-agent trap enable standard linkdown command.
Objects
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Yes
InterfaceIndex
1.3.6.1.2.1.2.2.1.7 (ifAdminStatus)
Administrative status of the interface.
No
INTEGER
up(1)
down(2)
testing(3)
1.3.6.1.2.1.2.2.1.8 (ifOperStatus)
No
INTEGER
up(1)
down(2)
testing(3)
unknown(4)
dormant(5)
notPresent(6)
lowerLayerDown(7)
Recommended action
To resolve the issue:
1.     Verify that the interface is connected and configured correctly.
2.     If the issue persists, contact H3C Support.
linkUp
Basic information
OID
Event
Severity
Default status
1.3.6.1.6.3.1.1.5.4
Link up.
Recovery
Warning
N/A
ON
This notification is generated when that the SNMPv2 entity, acting in an  agent role, has detected that the ifOperStatus object for one of its communication links left the down state and transitioned into some other state (but not into the notPresent state).  Other states refer to the values of the ifOperStatus variable.
Status control
ON
CLI: Use the snmp-agent trap enable standard linkup command.
OFF
CLI: Use the undo snmp-agent trap enable standard linkup command.
Objects
OID (object name)
Index
Value range
Yes
InterfaceIndex
No
INTEGER
up(1)
down(2)
testing(3)
No
INTEGER
up(1)
down(2)
testing(3)
unknown(4)
dormant(5)
notPresent(6)
lowerLayerDown(7)
Recommended action
No action is required.
