01-Text | 1.43 MB |
Hardware requirements (deployment on physical server)
Hardware requirements (deployment on VM)
Check the installation environment
Convergence deployment process on Matrix
Deployment process on Unified Platform
Deployment on Unified Platform
Install licenses on the license server
Obtain the license authorization
Upgrade and uninstall software
Uninstallation on Unified Platform
Overview
Virtual Network Function (VNF) Manager for Virtual Broadband Remote Access Server (vBRAS) (VNFM-vBRAS) is a containerized software product for vBRAS lifecycle management. It must work with the VNF-Manager component to accomplish virtual machine (VM) image management, VM VNF package management, and VM lifecycle management. vBRAS lifecycle management provides carriers with fast deployment, initialization, and lifecycle management of vBRASs, providing more agile deployment capabilities.
Server requirements
VNFM-vBRAS can be deployed on Unified Platform in either single-host mode or three-host mode.
CAUTION: · As a best practice to decrease the possibility of system failure due to abnormal power outages, make sure the RAID controllers used in servers support power fail protection with supercapacitors installed. · For VNFM-vBRAS of a version earlier than E6302, the compatible Unified Platform version is earlier than E0706 (including E06xx), and the ETCD partition must use a separate physical hard disk. · For VNFM-vBRAS of version E6302 or later, the compatible Unified Platform version is E0711 and later. The ETCD partition can share a physical hard disk with other partitions. For better performance, use a separate physical hard disk for the ETCD partition as a best practice. |
The hardware requirements for running VNFM-vBRAS on Unified Platform are as shown in Table 1.
CPU |
Memory |
Disk |
NIC |
x86-64 (Intel64/AMD64), 10 cores, 2.0 GHz or above |
108 GB or above |
RAID configuration is required, and the RAID level can be RAID1 or RAID10. Select one of the following configuration options: · Disk configuration option 1: ¡ System disk: 2 × 960 GB SSDs in RAID1 or 4 × 480 GB SSDs in RAID10 (the total disk capacity after RAID configuration must be greater than or equal to 960 GB) ¡ ETCD disk: 2 × 480 GB SSDs in RAID1 (the total disk capacity after RAID configuration must be greater than or equal to 50 GB), installation path: /var/lib/etcd · Disk configuration option 2: ¡ System disk: 2 × 1200 GB HDDs in RAID1 or 4 × 600 GB HDDs in RAID10 (the total disk capacity after RAID configuration must be greater than or equal to 960 GB), 7.2K RPM or higher HDDs ¡ ETCD disk: 2 × 600 GB HDDs in RAID1 (the total disk capacity after RAID configuration must be greater than or equal to 50 GB), 7.2K RPM or higher HDDs, installation path: /var/lib/etcd ¡ RAID controller: 1 GB cache, power fail protection supported with a supercapacitor installed |
· Non-bonding mode: 1 × 1Gbps or 1 × 10Gbps · Bonding mode: 2 × 1Gbps Linux bonding interfaces or 2 × 10Gbps Linux bonding interfaces |
NOTE: Make sure the server supports operating system CentOS 7.6 or later. |
VNFM-vBRAS supports VM-based deployment and can be installed in a VM environment. The virtualization environment provides necessary resources such as CPU, memory, and disks. Supported virtualization platforms and versions:
· VMware ESXi: 6.7.0
· CAS: H3C_CAS-E0706
For VM-based deployment, if the virtualization platform server has the hyper-threading mode enabled, the number of vCPUs must be twice the number of CPU cores required by physical server-based deployment. If the hyper-threading mode is not enabled, the number of vCPUs must be the same as that required by physical server-based deployment, and the memory and disk configuration can follow the requirements by physical server-based deployment. This section takes enabling hyper-threading as an example.
CAUTION: · The CPU, memory, and disk resources allocated to a VM must meet the recommended capacity requirements. Make sure physical resources of the corresponding capacities exist. Do not enable the overcommitment mode, which allocates resources more than resources available. Additionally, you must reserve resources for the VNFM-vBRAS VM. If you do not do that, the system environment will be unstable. · To deploy VNFM-vBRAS on a VM managed by VMware, you must enable the promiscuous mode and forged transmits on the host where the VM resides. · As a best practice to ensure high availability, configure the three VM nodes of the VNFM-vBRAS cluster on three different physical hosts. |
The hardware requirements for running VNFM-vBRAS on Unified Platform are as shown in Table 2.
CPU |
Memory |
Disk |
20 cores, 2.0GHz frequency |
108 GB or higher |
· Disk: ¡ System disk: 1.92 TB ¡ ETCD disk: 50 GB · NIC: 1 × 10Gbps |
Disk partitions
Table 3 Disk partition configuration
Mount point |
Partition configuration for hard disk capacity of 2400 GB |
Partition configuration for hard disk capacity of 1920 GB |
Partition configuration for hard disk capacity of 960 GB |
/var/lib/docker |
500 GiB |
450 GiB |
/boot |
1024 MiB |
1024 MiB |
1024 MiB |
swap |
1024 MiB |
1024 MiB |
1024 MiB |
/var/lib/ssdata |
550 GiB |
500 GiB |
800 GiB |
500 GiB |
692 GiB |
/boot/efi |
200 MiB |
200 MiB |
150 MiB |
/var/lib/etcd |
48 GiB |
48 GiB |
48 GiB |
GFS partition |
300 GiB |
220 GiB |
200 GiB |
Software requirements
VNFM-vBRAS runs as a component on Unified Platform. Before deploying VNFM-vBRAS, you must first install Unified Platform.
Client requirements
You can access Unified Platform directly through a browser and do not need to install a client. Google Chrome 70 or later are recommended.
Table 4 describes the installation environment check items. Make sure all requirements for installing Unified Platform are met.
Table 4 Checking the installation environment
Check item |
Check criteria |
Server |
Hardware check |
Make sure all hardware components (including CPU, memory, hard disks, and NICs) meet the requirements Identify whether operating system CentOS 7.6 and later are supported. |
Software check |
Make sure the system time has been configured. As a best practice, configure NTP for time synchronization and make sure the whole network uses the same clock source for time synchronization. |
Client |
Make sure the browser version meets the requirements |
Installation workflow
VNFM-vBRAS is the core component of vBRAS lifecycle management. When deploying the VNFM-vBRAS component, you must also deploy the VNF-Manager component or make sure the VNF-Manager component has been deployed.
VNFM-vBRAS supports the following deployment methods:
· Deployment on Matrix.
· Deployment on Unified Platform.
Table 5 Convergence deployment process on Matrix
Step |
Operation |
Remarks |
1. Prepare servers |
According to the network requirements, prepare one or three servers. |
Required. See "Server requirements" for hardware and software requirements. |
2. Deploy Matrix |
Install the H3Linux operating system and deploy Matrix on the servers. |
Required. For more information, see H3C Unified Platform Deployment Guide. |
3. Deploy the VNFM-vBRAS component |
Required. |
Required. |
Required. |
Required. |
Required. |
Table 6 VNFM-vBRAS installation process
Step |
Operation |
Remarks |
2. Deploy Matrix |
3. Deploy Unified Platform |
Versions earlier than E0713 |
Deploy Unified Platform and applications in the following order: · common_PLAT_GlusterFS_2.0 · general_PLAT_portal_2.0 · general_PLAT_kernel_2.0 · general_PLAT_kernel-base_2.0 |
Required. For more information, see H3C Unified Platform Deployment Guide. general_PLAT_kernel-base_2.0 does not require manual deployment after upload, because it can be automatically deployed when the VNFM-vBRAS component is deployed. |
E0713 and later |
Deploy Unified Platform and applications in the following order: · UDTP_Middle · UDTP_GlusterFS · UDTP_Core · UDTP_Imonitor · BMP_Report · BMP_Alarm · BMP_Subscription · BMP_Template |
4. Deploy the VNFM-vBRAS component |
Required. |
Required. |
Required. |
Required. |
Required. |
Required. |
Required. |
Required. |
Install VNFM-vBRAS
CAUTION: VNFM-vBRAS runs as a component on Unified Platform. Operations such as deployment, upgrade, and uninstallation of the component must be performed on Matrix or Unified Platform. |
When deploying the VNFM-vBRAS component, you must also deploy the VNF-Manager component or make sure the VNF-Manager component has been deployed. In this example, the VNF Manager component has been deployed. If the VNF-Manager component has not been deployed, deploy it as described in H3C VNF Manager Installation and Deployment Guide (Unified Platform).
Directly deploy the VNFM-vBRAS component and its dependent Unified Platform application installation packages on Matrix.
Log in to Matrix
1. In the address bar of the browser, enter https://ip_address:8443/matrix/ui to log in to Matrix.
The ip_address parameter specifies the northbound service VIP.
2. On the top navigation bar, click Deploy.
3. From the navigation pane, select Convergence Deployment.
4. Click Install.
The component deployment guide page opens.
Upload installation packages
1. Click the Upload button to upload the component installation packages and the dependent Unified Platform application installation packages to the system.
For the component installation packages and their dependent Unified Platform application installation packages, see Table 7 and Table 8.
2. After the upload is completed, click Next to parse the installation packages and access the application selection page.
Table 7 List of installation packages
Component name |
Component installation package name |
VNFM-vBRAS |
VNFM-vBRAS-version-MATRIX.zip |
Table 8 Dependent Unified Platform application installation packages
Installation package name |
Dependencies |
UDTP_Middle_version_x86.zip |
Middleware image repository |
UDTP_GlusterFS_version_x86.zip |
Provides local shared storage functionalities |
Middle |
UDTP_Core_version_x86.zip |
Provides portal, unified authentication, user management, service gateway, help center, permission, resource identity, license, configuration center, resource group, and logging functions |
Middle, GlusterFS |
UDTP_IMonitor_version_x86.zip |
Provides the self-monitoring service |
Middle, GlusterFS, Core |
BMP_Report_version_x86.zip |
Report |
BMP_Alarm_version_x86.zip |
Provides the alarm service |
Report |
Figure 1 Uploading installation packages
Select applications
1. Select VNFM-vBRAS.
The VNF-Manager component and the dependent Unified Platform application packages will be automatically selected by default.
2. Click Next.
Figure 2 Selecting applications (1)
Figure 3 Selecting applications (2)
Select installation packages
Select the version number of each installation package. Click Next.
Figure 4 Selecting installation packages
Configure parameters
The VNFM-vBRAS application does not require any parameter configuration. Click Deploy, confirm the applications to be deployed, and start deployment. The deployment progress will be displayed on the page.
Figure 5 Configuring parameters
Figure 6 Application deployment in progress
Before deploying VNFM-vBRAS, you must first deploy the application package for Unified Platform. Then, deploy the VNFM-vBRAS component on Unified Platform.
Install Unified Platform
For information about installing Unified Platform, see H3C Unified Platform Deployment Guide.
Table 9 Dependent Unified Platform application installation packages (earlier than E0713)
Application installation package name |
common_PLAT_GlusterFS_2.0_version_x86.zip |
general_PLAT_portal_2.0_version_x86.zip |
Provides the portal, unified authentication, user management, service gateway, and help center functions |
general_PLAT_kernel_2.0_version_x86.zip |
Provides the permission, resource identity, license, configuration center, resource group, and logging functions |
general_PLAT_kernel-base_2.0_version_x86.zip |
Provides the alarm, access parameter template, monitor template, report, and forwarding via mail or SMS functions |
Table 10 Dependent Unified Platform application installation package (E0713 and later versions)
Dependencies |
Middle |
Middle, GlusterFS |
Report |
Report |
BMP_Subscription_version_x86.zip |
Subscription service |
Report, Alarm |
BMP_Template_version_x86.zip |
Access parameter templates and monitor templates |
Log in to Unified Platform
1. In the address bar of the browser, enter the login address (the default is http://ip_address:30000/central/index.html) of Unified Platform to access the login page.
¡ The ip_address parameter specifies the northbound service VIP of the Unified Platform cluster.
¡ 30000 is the port number.
2. On the top navigation bar, click System.
3. From the navigation pane, select Deployment to access the component deployment guide page.
Click Upload to upload the component installation packages to the system. After the installation packages required for deploying this scenario are uploaded, click Next to parse the installation packages and access the component selection page.
Table 11 List of installation packages
Component name |
VNFM-vBRAS |
VNFM_VBRAS-version-MATRIX.zip |
Figure 7 Uploading installation packages
Select components
Expand the controller item, and select the VNF lifecycle management and VNFM-vBRAS options. Select the package names and versions to use, and click Next to access the parameter configuration page.
Figure 8 Selecting components
VNFM-vBRAS does not need parameter configuration. Click Next to access the network configuration page.
Configure networks
VNFM-vBRAS does not require network configuration. Click Next to access the node binding page.
Bind nodes
VNFM-vBRAS does not require node binding. Click Next to access the network binding page.
Bind networks
VNFM-vBRAS does not require network binding. Click Next to proceed to the parameter confirmation page.
Confirm parameters
You do not need to confirm parameters for VNFM-vBRAS. Click Deploy to start deploying VNFM-vBRAS. The deployment progress will be displayed on the page.
Figure 9 Component deployment in progress
Log in to VNFM-vBRAS
VNFM-vBRAS runs on Unified Platform. To access the VNFM-vBRAS component page, you must first log in to Unified Platform.
The Unified Platform provides a friendly UI. To log in to Unified Platform:
1. In the address bar of the browser, enter the login address (the default is http://ucenter_ip_address: 30000/central/index.html) of Unified Platform to access the login page as shown in Figure 10.
¡ The ucenter_ip_address parameter is the northbound service VIP of the Unified Platform cluster.
Figure 10 Login page of Unified Platform
2. Enter the username and password to log in to Unified Platform.
The default username is admin, and the default password is Pwd@12345. After successful login, the main page of Unified Platform opens.
3. On the top navigation bar, click Automation.
4. From the navigation pane, select VNF Manager > vBRAS Management to access the VNFM-vBRAS component page.
Register the software
Register Unified Platform
For information about registering Unified Platform, see H3C Unified Platform Deployment Guide.
Register VNFM-vBRAS
After VNFM-vBRAS is installed, all functions can be tried within 180 days. To continue using the software beyond this trial period, you must obtain the license authorization.
For more information about requesting and installing the license, see H3C Software Product Remote Licensing Guide.
After installing the license for the product on the license server, you only need to connect to the license server from the license management page to obtain the license authorization. To do that, perform the following tasks:
1. Log in to Unified Platform.
3. From the navigation pane, select License Management > License Information.
4. Configure the license server parameters on the page.
Table 12 describes each parameter.
Parameter |
IP Address |
IP address of the server for installing the license server. |
Port Number |
The default is 5555, which is the same as the port number of the license server authorization service. |
Client Name |
Client name set on the license server. |
Client Password |
Password for the client set on the license server. |
5. After configuration, click Connect to establish a connection to the license server.
After the connection is established successfully, VNFM-vBRAS can automatically obtain license authorization.
CAUTION: · Before upgrading or uninstalling the software, back up both VNFM-vBRAS and VNF-Manager on Unified Platform. When restoring data, you must use backup files from the same time. · To upgrade Unified Platform compatible with VNFM-vBRAS from E0711 or earlier to E0713 or later, first upgrade Unified Platform and then upgrade VNFM-vBRAS. |
This chapter describes the upgrade and uninstallation procedures of the VNFM-vBRAS component. For information about the upgrade and uninstallation procedures of Unified Platform, see H3C Unified Platform Deployment Guide.
Upgrade VNFM-vBRAS
Upgrade on Matrix
On Matrix, you can upgrade a component with its configuration retained. Upgrading components might cause service interruption. Please perform this operation with caution.
1. Log in to Matrix.
2. Access the Deployment > Convergence Deployment page.
Figure 11 Deployment page
3. Click the button on the
left of the datacenter scenario to expand component information. Then, click
the
button in the Actions column for the
VNFM-vBRAS application to access the upgrade page.
4. Upload the installation packages, select the installation packages to be upgraded, and click Upgrade to start the component upgrade.
Figure 12 Upgrading applications
Upgrade on Unified Platform
On Unified Platform, you can upgrade a component with its configuration retained. Upgrading components might cause service interruption. Please perform this operation with caution.
1. Log in to the Unified Platform.
2. Navigate to the System > Deployment page.
Figure 13 Deployment page
left of the component to expand component information. Then, click the
button
4. Upload the installation packages, select the installation packages to be upgraded, and click Upgrade to upgrade the components.
Figure 14 Upgrading components
5. If the component upgrade fails, click Roll Back to roll back the components to the versions before the upgrade.
Uninstall VNFM-vBRAS
Uninstallation on Matrix
3. Select the checkboxes on the left of the components to be uninstalled, and click Uninstall to uninstall the specified components.
Figure 15 Uninstalling components
2. Access the System > Deployment page.
Figure 16 Uninstalling components
Scale out VNFM-vBRAS
You can scale out VNFM-vBRAS from single-host mode to cluster mode. VNFM-vBRAS can be scaled out on Matrix or Unified Platform.
In this mode, you must add two more master nodes to Matrix to form a three-host cluster with the original master node. Then, scale out Unified Platform, VNF Manager, and VNFM-vBRAS in sequence.
Scale-out on Matrix
Scale out Matrix
Scale out Unified Platform
Scale out VNF-Manager
For more information, see H3C VNF Manager Installation and Deployment Guide (Unified Platform).
Figure 17 Deployment page
the
icon in the Actions column for the
VNFM-vBRAS component to access the scale-out page.
Figure 18 Scale-out page
4. Click Scale Out to start scale-out.
The scale-out progress will be displayed on the page.
Figure 19 Scaling out applications
Scale-out on Unified Platform
Scale out Matrix
1. Access the System > Deployment page.
Figure 20 Deployment page
2. Select VNFM-vBRAS to be scaled out, click
the icon in the Actions column to access
the scale-out page.
Figure 21 Scale-out page
3. Click Scale Out.
