06-Layer 3—IP Routing Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9825 & S9855 Switch Series Command References-R9126Pxx-6W10006-Layer 3—IP Routing Command Reference
01-Basic IP routing commands
01-Basic IP routing commands 490.25 KB
Basic IP routing commands· 1
address-family ipv4· 1
address-family ipv6· 1
bandwidth-based-sharing· 2
display ecmp mode· 2
display hardware-resource routing-mode· 3
display ip load-sharing mode· 4
display ip load-sharing path· 5
display ip routing-table· 7
display ip routing-table acl 16
display ip routing-table ip-address· 20
display ip routing-table prefix-list 23
display ip routing-table protocol 25
display ip routing-table record· 28
display ip routing-table statistics· 35
display ip routing-table summary· 38
display ipv6 rib attribute· 39
display ipv6 rib graceful-restart 40
display ipv6 rib nib· 40
display ipv6 rib nib record· 43
display ipv6 route-direct nib· 46
display ipv6 routing-table· 48
display ipv6 routing-table acl 56
display ipv6 routing-table ipv6-address· 59
display ipv6 routing-table prefix-list 62
display ipv6 routing-table protocol 64
display ipv6 routing-table record· 67
display ipv6 routing-table statistics· 70
display ipv6 routing-table summary· 72
display rib attribute· 73
display rib graceful-restart 75
display rib nib· 76
display rib nib record· 82
display route-direct nib· 89
ecmp mode enhanced· 94
fib lifetime· 94
flush route-attribute· 95
hardware-resource routing-mode· 95
inter-protocol fast-reroute· 96
ip load-sharing mode· 97
ip load-sharing symmetric enable· 98
ipv6 route fast-switchover enable· 99
nexthop recursive-lookup restrain clear-interval 99
nexthop recursive-lookup restrain disable· 100
primary-path-detect bfd· 101
protocol lifetime· 103
protocol nexthop recursive-lookup· 103
record-limit 104
reset ip routing-table record· 106
reset ip routing-table statistics protocol 106
reset ipv6 rib nib record· 107
reset ipv6 routing-table record· 107
reset ipv6 routing-table statistics protocol 108
reset rib nib record· 108
rib· 109
routing-table limit 109
address-family ipv4
Use address-family ipv4 to create the RIB IPv4 address family and enter its view, or enter the view of the existing RIB IPv4 address family.
Use undo address-family ipv4 to delete the RIB IPv4 address family and all configurations in the view.
address-family ipv4
No RIB IPv4 address family exists.
RIB view
# Create the RIB IPv4 address family and enter its view.
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4]
address-family ipv6
Use address-family ipv6 to create the RIB IPv6 address family and enter its view, or enter the view of the existing RIB IPv6 address family.
Use undo address-family ipv6 to delete the RIB IPv6 address family and all configurations in the view.
address-family ipv6
No RIB IPv6 address family exists.
RIB view
# Create the RIB IPv6 address family and enter its view.
[Sysname] rib
[Sysname-rib] address-family ipv6
[Sysname-rib-ipv6]
Use bandwidth-based-sharing to enable IPv4 load sharing based on bandwidth.
Use undo bandwidth-based-sharing to disable IPv4 load sharing based on bandwidth.
This command cannot take effect when IPv4 or IPv6 enhanced ECMP mode is enabled.
The IPv4 load sharing based on bandwidth is disabled.
This feature load shares flow traffic among multiple output interfaces based on their load percentages. The device calculates the load percentage for each output interface in terms of their expected bandwidths.
Devices that run load sharing protocols implement load sharing based on the ratios defined by these protocols.
# Enable IPv4 load sharing based on bandwidth.
[Sysname] bandwidth-based-sharing
display ecmp mode
Use display ecmp mode to display the IPv4 and IPv6 ECMP mode.
display ecmp mode
# Display the IPv4 and IPv6 ECMP mode.
<Sysname> display ecmp mode
  ECMP-Mode in use: Default
  ECMP-Mode at the next reboot: Enhanced
ECMP-Mode in use
The current ECMP mode:
·     Default—Normal mode.
·     Enhanced—Enhanced mode.
ECMP mode used at the next startup:
ecmp mode enhanced
Use display hardware-resource routing-mode to display the routing-mode hardware resource mode.
display hardware-resource [routing-mode]
If you do not specify the routing-mode keyword, this command displays all hardware resource modes.
# Display the routing-mode hardware resource mode.
<Sysname> display hardware-resource routing-mode
Routing-mode resource(routing-mode), all supported modes:
  ipv6-128          IPv6-128 supported
  Default         Current         Next
  ipv6-128        ipv6-128        ipv6-128
Routing-mode hardware resource mode supported by the device:
ipv6-128—IPv6 routes with more than 64 bits.
Default routing-mode hardware resource mode.
Current
Current routing-mode hardware resource mode.
Next
Most recently configured routing-mode hardware resource mode.
Use display ip load-sharing mode to display the load sharing mode in use.
display ip load-sharing mode slot slot-number
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the load sharing mode for all member devices.
# Display the load sharing mode in use.
<Sysname> display ip load-sharing mode slot 1
Load-sharing mode: per-flow
Load-sharing options: dest-ip | src-ip | ip-pro | dest-port | src-port | ingress-port
Load-sharing algorithm: 0
Algorithm level: 2
Load-sharing algorithm: 1
Algorithm level: 3
Load-sharing algorithm: 2
Load-sharing mode
The load sharing mode in use. The value is per-flow, which represents per-flow load sharing.
Options configured for load sharing:
·     dest-ip—Identifies flows by destination IP address in packets.
·     src-ip—Identifies flows by source IP address in packets.
·     ip-pro—Identifies flows by IP protocol in packets.
·     dest-port—Identifies flows by destination port number in packets.
·     src-port—Identifies flows by source port number in packets.
·     ingress-port—Identifies flows by ingress port in packets.
Algorithm used by load sharing.
Algorithm level
Load sharing algorithm level.
Use display ip load-sharing path to display the load sharing path selected for a flow.
This command takes effect only on the S9825 switch series.
display ip load-sharing path ingress-port interface-type interface-number packet-format { ipv4oe dest-ip ip-address [ src-ip ip-address ] | ipv6oe dest-ipv6 ipv6-address [ flow-label flow-label | src-ipv6 ipv6-address ] * } [ dest-port port-id | ip-pro protocol-id | src-port port-id | vpn-instance vpn-instance-name ] *
ingress-port interface-type interface-number: Specifies an ingress port by its type and number.
packet-format { ipv4oe dest-ip ip-address [src-ip ip-address ] | ipv6oe dest-ipv6 ipv6-address [ src-ipv6 ipv6-address ] }: Specifies the packet encapsulation format.
ipv4oe: Specifies the format of IPv4 over Ethernet.
dest-ip ip-address: Specifies the destination IPv4 address in dotted decimal notation. If you do not specify this argument, the calculation uses 0.0.0.0 for path selection.
src-ip ip-address: Specifies the source IPv4 address in dotted decimal notation. If you do not specify this argument, the calculation uses 1.1.1.1 for path selection.
ipv6oe: Specifies the format of IPv6 over Ethernet.
dest-ipv6 ipv6-address: Specifies the destination IPv6 address. If you do not specify this option, the calculation uses 0:0:0:0:0:0:0:0 for path selection.
flow-label flow-label: Specifies the flow label in IPv6 packets. The value range for the flow-label argument is 0 to 1048575. If you do not specify a flow label, the device uses flow label 0 when it calculates ECMP route selection information.
src-ipv6 ipv6-address: Specifies the source IPv6 address. If you do not specify this option, the calculation uses 2000::1 for path selection.
dest-port port-id: Specifies a destination port number in the range of 1 to 65535. If you do not specify this option, the calculation uses 0 for path selection.
ip-pro protocol-id: Specifies an IP protocol by its number in the range of 1 to 255. If you do not specify this option, the calculation uses 0 for path selection if the destination address is an IPv4 address and uses 17 for path selection if the destination address is an IPv6 address.
source-port port-id: Specifies a source port number in the range of 1 to 65535. If you do not specify this option, the calculation uses 0 for path selection.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display the path on the public network, do not specify this option.
The option settings in this command must match both the options displayed in the display ip load-sharing mode command and the field values in load shared packets. If the option settings do not meet the requirement, the path displayed by this command might be different from the real path for load sharing.
For tunnel packets forwarded by the device, the display ip load-sharing path command obtains path information only from the outermost layer of the packets.
The display ip load-sharing path command applies to only TCP and UDP packets if the packets contain source and destination port numbers.
For ECMP routes formed through PBR, the display ip load-sharing path command does not support obtaining load sharing path information.
# Display the load sharing path selected for the flow with the following attributes: ingress port HundredGigE 1/0/3, destination IP address 10.110.0.2, source IP address 10.100.0.2, IP protocol number 153, destination port number 2000, source port number 2000.
<Sysname> display ip load-sharing path ingress-port hundredgige 1/0/3 packet-format ipv4oe dest-ip 10.110.0.2 src-ip 10.100.0.2 ip-pro 153 dest-port 2000 src-port 2000
Load-sharing parameters:
  Missing configured are set to 0.
  ingress-port: HundredGigE1/0/3
  packet-format: IPv4oE
  dest-ip: 10.110.0.2
  src-ip: 10.100.0.2
  ip-pro: 153
  dest-port: 2000
  src-port: 2000
Path selected: 20.0.0.2(interface HundredGigE1/0/3)
Load sharing algorithm ID.
Load sharing options specified by the ip load-sharing mode command.
Load sharing parameters that you specify for the display ip load-sharing path command.
Values of the unconfigured parameters are set to 0.
ingress-port
Ingress port of the packet.
packet-format
Packet encapsulation format.
dest-ip
Destination IP address of the packet.
src-ip
Source IP address of the packet.
ip-pro
IP protocol number.
dest-port
Destination port number.
src-port:
Source port number.
flow-label
IPv6 packet flow label.
Path selected
Selected path information, including the IPv4 or IPv6 address of the next hop and the egress port.
Use display ip routing-table to display routing table information.
display ip routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ verbose ]
display ip routing-table all-routes
all-vpn-instance: Specifies all VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays routing table information for the public network.
all-routes: Displays routing table information for the public network and all VPN instances.
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays only brief information about active routes.
# Display brief information about active routes in the routing table.
<Sysname> display ip routing-table
Destinations : 12        Routes : 12
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
1.1.1.0/24          Static 60   0            192.168.47.4    Vlan12
                    Static 60   0            192.168.47.4    Vlan13
192.168.1.0/24      Direct 0    0            192.168.1.40    Vlan11
192.168.1.0/32      Direct 0    0            192.168.1.40    Vlan11
192.168.1.40/32     Direct 0    0            127.0.0.1       InLoop0
192.168.1.255/32    Direct 0    0            192.168.1.40    Vlan11
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
# Display brief information about active routes in the routing table for the public network and all VPN instances.
<Sysname> display ip routing-table all-routes
VPN instance: public instance
Destinations : 8        Routes : 8
1.1.1.0/24          Static 60   0            192.168.47.4    Vlan11
VPN instance: vpn1
1.1.2.0/24          Static 60   0            2.2.1.1         Vlan11
3.3.1.0/24          BGP    255  0            55.1.1.2        Vlan12
# Display information about IPv4 routes for all VPN instances.
<Sysname> display ip routing-table all-vpn-instance
VPN instance: vpn1
VPN instance: vpn2
Destinations : 7        Routes : 7
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
1.1.3.0/24          Static 60   0            3.3.1.1         Vlan13
Table 5 Command output
Destinations
Number of destination addresses.
Routes
Number of routes.
Destination/Mask
Destination address/mask length.
Proto
Route type or protocol that installed the route:
·     Direct—Direct route.
·     Static—Static route.
·     OSPF—OSPF route.
·     ISIS—IS-IS route.
·     BGP—BGP route.
·     OpenR—Open Routing (OpenR) route.
·     O_INTRA—OSPF intra-area route.
·     O_INTER—OSPF inter-area route.
·     O_ASE1—OSPF Type-1 external route.
·     O_ASE2—OSPF Type-2 external route.
·     O_SUM—OSPF summary route.
·     IS_L1—IS-IS Level-1 route.
·     IS_L2—IS-IS Level-2 route.
·     IS_SUM—IS-IS summary route.
Pre
Preference of the route.
Cost
Cost of the route.
NextHop
Next hop address of the route.
Output interface for packets to be forwarded along the route.
Summary count
Number of routes.
# Display detailed information about all routes in the routing table.
<Sysname> display ip routing-table verbose
Destinations : 13        Routes : 13
Destination: 0.0.0.0/32
   Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                        Age: 08h34m37s
        Cost: 0                   Preference: 0
       IpPre: N/A                 QosLocalID: N/A
         Tag: 0                        State: Active NoAdv
   OrigTblID: 0x0                    OrigVrf: default-vrf
     TableID: 0x2                     OrigAs: 0
       NibID: 0x10000000              LastAs: 0
      AttrID: 0xffffffff            Neighbor: 0.0.0.0
       Flags: 0x1000c            OrigNextHop: 127.0.0.1
       Label: NULL               RealNextHop: 127.0.0.1
     BkLabel: NULL                 BkNextHop: N/A
     SRLabel: NULL                 Interface: InLoopBack0
   BkSRLabel: NULL               BkInterface: N/A
   Tunnel ID: Invalid            IPInterface: InLoopBack0
 BkTunnel ID: Invalid          BKIPInterface: N/A
     InLabel: NULL            ColorInterface: N/A
    SIDIndex: NULL          BKColorInterface: N/A
    FtnIndex: 0x0            TunnelInterface: N/A
TrafficIndex: N/A          BKTunnelInterface: N/A
   Connector: N/A                     PathID: 0x0
  SRTunnelID: Invalid
    SID Type: N/A                        NID: Invalid
    FlushNID: Invalid                  BkNID: Invalid
  BkFlushNID: Invalid              StatFlags: 0x0
         Exp: N/A
   VpnPeerId: N/A                       Dscp: N/A
         SID: N/A                 OrigLinkID: 0x0
       BkSID: N/A                 RealLinkID: 0x0
CommBlockLen: 0
Destination: 1.1.1.0/24
   Protocol: Static
  Process ID: 0
   SubProtID: 0x0                        Age: 04h20m37s
        Cost: 0                   Preference: 60
         Tag: 0                        State: Active Adv
       NibID: 0x10000003              LastAs: 0
       Flags: 0x1008c            OrigNextHop: 192.168.47.4
       Label: NULL               RealNextHop: 192.168.47.4
     SRLabel: NULL                 Interface: Vlan-interface12
   Tunnel ID: Invalid            IPInterface: Vlan-interface12
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Destination: 1.2.3.4/32
   Protocol: BGP instance default
  Process ID: 0
   SubProtID: 0x1                        Age: 02h38m34s
        Cost: 0                   Preference: 255
     TableID: 0x2                     OrigAs: 200
       NibID: 0x16000000              LastAs: 200
      AttrID: 0x2                   Neighbor: 2.2.3.4
       Flags: 0x10060            OrigNextHop: 2.2.3.4
       Label: NULL               RealNextHop: 2.2.3.4
     SRLabel: NULL                 Interface: Vlan-interface11
   Tunnel ID: Invalid            IPInterface: Vlan-interface11
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
# Display detailed information about all routes in the routing table for all VPN instances.
<Sysname> display ip routing-table all-vpn-instance verbose
VPN instance: vpn1
Destinations : 1        Routes : 1
   Protocol: Direct
  Process ID: 0
   OrigTblID: 0x0                    OrigVrf: vpn1
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
VPN instance: vpn2
   Protocol: Static
  Process ID: 0
   OrigTblID: 0x0                    OrigVrf: vpn2
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Table 6 Command output
Destinations
Routes
Number of routes.
Destination
Protocol
·     OSPF—OSPF route.
·     ISIS—IS-IS route.
·     BGP—BGP route.
SubProtID
ID of the subprotocol for routing.
Age
Time for which the route has been in the routing table.
Cost
Cost of the route.
Preference
IpPre
IP precedence.
QosLocalID
Local QoS ID.
N/A represents an invalid value.
Tag
Route tag.
Route status:
·     Active—Active unicast route.
·     Adv—Route that can be advertised.
·     Inactive—Inactive route.
·     NoAdv—Route that the router must not advertise.
·     Derived—Derived route. If a route recurses to multiple related routes, all related routes except the first one are derived routes. The number of derived routes is not included in the total number of routes.
OrigTblID
Original routing table ID.
OrigVrf
Original VPN instance to which the route belongs. This field displays default-vrf if the route is on the public network.
TableID
ID of the routing table.
OrigAs
Original AS number.
NibID
ID of the next hop.
LastAs
Last AS number.
AttrID
Attribute ID.
Neighbor
Address of the neighbor determined by the routing protocol.
Flags
Flags of the route.
OrigNextHop
Label
Label.
RealNextHop
Real next hop of the route.
BkLabel
Backup label.
BkNexthop
Backup next hop.
SRLabel
Segment routing (SR) label.
BkSRLabel
Backup SR label.
SIDIndex
SID index value.
InLabel
Incoming label of the route.
Tunnel ID
Tunnel ID.
BkTunnel ID
Backup tunnel ID. If the command output contains three dots (…), multiple backup tunnels exist but only the first backup tunnel takes effect.
BkInterface
Backup output interface. If the command output contains three dots (…), multiple backup output interfaces exist but only the first backup output interface takes effect.
IPInterface
IP output interface.
BkIPInterface
Backup IP output interface.
ColorInterface
Color output interface obtained through SR-MPLS TE policy-based or SRv6 TE policy-based recursion.
BkColorInterface
Backup color output interface.
FtnIndex
Index of the FTN entry.
TunnelInterface
Tunnel output interface.
TrafficIndex
Traffic index in the range of 1 to 64. This field displays N/A when the value is invalid.
BkTunnelInterface
Backup tunnel output interface.
Connector
BGP connector attribute exchanged between BGP peers along with a VPN IPv4 route. The value of the attribute is the IP address of the remote PE device. The BGP connector attribute is used for MD VPN. This field displays N/A if the BGP connector attribute is not supported.
Summary count
Number of routes.
PathID
Path ID.
SRTunnelID
SR tunnel ID.
SID Type
SID type. If the route does not have an SID, this field displays N/A.
NID
Index of the Next Hop Label Forwarding Entry (NHLFE) issued by the routing protocol.
FlushNID
Actual NHLFE index issued to the FIB.
BkNID
Backup NHLFE index issued by the routing protocol.
BkFlushNID
Actual backup NHLFE index issued to the FIB.
VpnPeerId
ID of the VPN peer to which the route belongs, in the range of 1 to 134217727. This field displays N/A when the value is invalid.
Dscp
DSCP value of the route, in the range of 0 to 63. This field displays N/A when the value is invalid.
Exp
MPLS EXP value of the route, which is supported only by BGP. This field displays N/A when the value is invalid.
SID
Primary SID. N/A indicates that the attribute is not available.
BkSID
Backup SID. N/A indicates that the attribute is not available.
CommBlockLen
Common prefix length in the locator.
OrigLinkID
Original link ID of the SDWAN TTE connection.
RealLinkID
Real link ID of the SDWAN TTE connection.
Use display ip routing-table acl to display information about routes permitted by a basic ACL.
display ip routing-table [ vpn-instance vpn-instance-name ] acl ipv4-acl-number [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays routing information for the public network.
ipv4-acl-number: Specifies a basic ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes permitted by the basic ACL. If you do not specify this keyword, the command displays only brief information about active routes permitted by the basic ACL.
If the specified ACL does not exist or has no rules configured, the command displays information about all routes.
If a rule in the specified ACL has the VPN instance match criterion configured, the rule will not take effect.
# Define basic ACL 2000 and set the route filtering rules.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-ipv4-basic-2000] rule deny source any
# Display brief information about active routes permitted by basic ACL 2000.
[Sysname-acl-ipv4-basic-2000] display ip routing-table acl 2000
Summary count : 4
192.168.1.0/24      Direct 0    0            192.168.1.111   Vlan11
192.168.1.0/32      Direct 0    0            192.168.1.111   Vlan11
192.168.1.111/32    Direct 0    0            127.0.0.1       InLoop0
192.168.1.255/32    Direct 0    0            192.168.1.111   Vlan11
For command output, see Table 5.
# Display detailed information about all routes permitted by basic ACL 2000.
<Sysname> display ip routing-table acl 2000 verbose
Summary count : 4
Destination: 192.168.1.0/24
   Protocol: Direct
  Process ID: 0
   SubProtID: 0x1                        Age: 04h20m37s
       Flags: 0x10080            OrigNextHop: 192.168.1.111
       Label: NULL               RealNextHop: 192.168.1.111
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Destination: 192.168.1.0/32
   Protocol: Direct
  Process ID: 0
       Flags: 0x1008c            OrigNextHop: 192.168.1.111
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Destination: 192.168.1.111/32
   Protocol: Direct
  Process ID: 0
       Flags: 0x10004            OrigNextHop: 127.0.0.1
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Destination: 192.168.1.255/32
   Protocol: Direct
  Process ID: 0
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
For command output, see Table 6.
Use display ip routing-table ip-address to display information about routes to a specific destination address.
Use display ip routing-table ip-address1 to ip-address2 to display information about routes to a range of destination addresses.
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask-length | mask ] [ longer-match ] [ verbose ]
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address1 to ip-address2 [ verbose ]
ip-address: Specifies a destination IP address in dotted decimal notation.
mask-length: Specifies the mask length, an integer in the range of 0 to 32.
mask: Specifies the IP address mask in dotted decimal notation.
longer-match: Displays the route entries that meet the matching rules as described in the usage guidelines.
ip-address1 to ip-address2: Specifies a destination IP address range.
verbose: Displays detailed routing table information, including information about both active and inactive routes. If you do not specify this keyword, the command displays brief information about active routes.
Executing the command with different parameters yields different outputs.
·     display ip routing-table ip-address
¡     The system ANDs the entered destination IP address with the subnet mask in each active route entry.
¡     The system ANDs the destination IP address in each active route entry with its own subnet mask.
If the two operations yield the same result for an entry, the entry is displayed.
·     display ip routing-table ip-address mask
¡     The system ANDs the entered destination IP address with the entered subnet mask.
¡     The system ANDs the destination IP address in each active route entry with the entered subnet mask.
If the two operations yield the same result for an entry with a subnet mask not greater than the entered subnet mask, the entry is displayed.
·     display ip routing-table ip-address longer-match
¡     The system ANDs the entered destination IP address with the subnet mask in the following way:
-     If the entered IP address belongs to class A, B, or C, the system ANDs it with the default subnet mask of the corresponding class.
-     If the entered IP address is 0.0.0.0, the system ANDs it with the subnet mask 0.0.0.0.
-     Except the previous cases, for example, if the entered IP address is a loopback address, the system ANDs it with the subnet mask 255.255.255.255.
¡     The system ANDs the destination IP address in each active route entry with the subnet mask of the entered IP address.
If the two operations yield the same result for multiple entries, all the entries are displayed.
·     display ip routing-table ip-address mask longer-match
·     display ip routing-table ip-address1 to ip-address2
The system displays active route entries with destinations in the range of ip-address1/32 to ip-address2/32.
# Display brief information about the routes to the destination IP address 11.0.0.1.
<Sysname> display ip routing-table 11.0.0.1
Summary count : 3
11.0.0.0/8          Static 60   0            0.0.0.0         NULL0
11.0.0.0/16         Static 60   0            0.0.0.0         NULL0
11.0.0.0/24         Static 60   0            0.0.0.0         NULL0
# Display brief information about the routes to the destination IP address 11.0.0.1 with mask length 20.
<Sysname> display ip routing-table 11.0.0.1 20
Summary count : 2
# Display brief information about the routes to the destination IP address 11.0.0.1 with the default mask length for class A networks.
<Sysname> display ip routing-table 11.0.0.1 longer-match
Summary count : 3
<Sysname> display ip routing-table 11.0.0.1 20 longer-match
Summary count : 3
# Display brief information about the routes to destination addresses in the range of 1.1.1.0 to 5.5.5.0.
<Sysname> display ip routing-table 1.1.1.0 to 5.5.5.0
Summary count : 4
1.1.1.1/32          Direct 0    0            127.0.0.1       InLoop0
2.2.2.0/24          Direct 0    0            2.2.2.1         Vlan2
3.3.3.1/32          Direct 0    0            127.0.0.1       InLoop0
4.4.4.1/32          Direct 0    0            127.0.0.1       InLoop0
# Display detailed information about the routes to the destination IP address 1.2.3.4.
<Sysname> display ip routing-table 1.2.3.4 verbose
Summary count : 1
   Protocol: Static
  Process ID: 0
   SubProtID: 0x1                        Age: 00h00m37s
       NibID: 0x15000000              LastAs: 0
      AttrID: 0x0                   Neighbor: 0.0.0.0
       Flags: 0x10060            OrigNextHop: 192.168.47.2
       Label: NULL               RealNextHop: 192.168.47.2
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Use display ip routing-table prefix-list to display routes permitted by an IP prefix list.
display ip routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters.
verbose: Displays detailed information about all routes permitted by the IP prefix list. If you do not specify this keyword, the command displays brief information about active routes permitted by the IP prefix list.
If the specified IP prefix list does not exist, the command displays information about all routes.
# Create an IP prefix list named test to permit the route 1.1.1.0/24.
[Sysname] ip prefix-list test permit 1.1.1.0 24
# Display brief information about the active route permitted by the IP prefix list.
[Sysname] display ip routing-table prefix-list test
Summary count : 1
1.1.1.0/24          Direct 0    0            1.1.1.2         Vlan11
# Display detailed information about all routes permitted by the IP prefix list.
[Sysname] display ip routing-table prefix-list test verbose
Summary count : 1
   Protocol: Direct
  Process ID: 0
       Flags: 0x1008c            OrigNextHop: 1.1.1.2
       Label: NULL               RealNextHop: 1.1.1.2
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Use display ip routing-table protocol to display information about routes installed by a protocol.
display ip routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ]
protocol: Specifies a routing protocol.
inactive: Displays information about inactive routes. If you do not specify this keyword, the command displays information about both active and inactive routes.
verbose: Displays detailed routing table information. If you do not specify this keyword, the command displays brief routing information.
# Display brief information about direct routes.
<Sysname> display ip routing-table protocol direct
Summary count : 9
Direct Routing table status : <Active>
Summary count : 9
2.2.2.0/32          Direct 0    0            2.2.2.1         Vlan2
2.2.2.2/32          Direct 0    0            127.0.0.1       InLoop0
2.2.2.255/32        Direct 0    0            2.2.2.1         Vlan2
Direct Routing table status : <Inactive>
Summary count : 0
# Display brief information about static routes.
<Sysname> display ip routing-table protocol static
Summary count : 1
Static Routing table status : <Active>
Summary count : 0
Static Routing table status : <Inactive>
Summary count : 1
1.2.3.0/24          Static 60   0            1.2.4.5        Vlan10
# Display brief information about OpenR routes.
<Sysname> display ip routing-table protocol openr
Summary count : 1
OpenR Routing table status : <Active>
Summary count : 1
192.11.3.0/24       OpenR  30   0            12.13.3.12     Vlan10
Summary count : 0
# Display detailed information about BGP routes.
<Sysname> display ip routing-table protocol bgp verbose
Summary count : 1
Destination: 1.1.1.2/32
  Process ID: 0
   SubProtID: 0x6                        Age: 00h03m54s
      AttrID: 0x0                   Neighbor: 192.168.47.2
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
# Display detailed information about OpenR routes.
<Sysname> display ip routing-table protocol openr verbose
Summary count : 1
Destination: 192.11.3.0/24
   Protocol: OpenR
  Process ID: 0
   SubProtID: 0xfe                       Age: 01h13m48s
        Cost: 0                   Preference: 30
       NibID: 0x19000000              LastAs: 0
       Flags: 0x10040            OrigNextHop: 12.13.3.12
       Label: NULL               RealNextHop: 12.13.3.12
     SRLabel: NULL                 Interface: Vlan-interface10
   Tunnel ID: Invalid            IPInterface: Vlan-interface10
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Use display ip routing-table record to display IPv4 route entry records.
display ip routing-table record flush [ delete | update ] [ verbose ]
display ip routing-table record notify [ delete | update ] [ verbose ]
display ip routing-table record receive [ add | delete | update ] [ verbose ]
flush: Displays the records for the route entries issued by the RIB to the FIB.
notify: Displays the records for the route entries notified by the RIB to the routing protocol.
receive: Displays the records for the route entries received by the RIB from the routing protocol.
add: Displays the records for the added route entries.
delete: Displays the records for the deleted route entries.
update: Displays the records for the updated route entries. If you specify the flush or notify keyword, the system takes added route entries as updated route entries when displaying the associated records.
verbose: Displays detailed information about IPv4 route entry records. If you do not specify this keyword, the command displays only brief information about IPv4 route entry records.
If you do not specify the add, delete, or update keyword, the command displays records for the added, deleted, and updated route entries.
When the system enters the level-1 memory threshold alarm status, it stops recording new route entry information. When the system enters the level-3 memory threshold alarm status, it clears existing route entry records. When the system exits the level-1 memory threshold alarm status, it starts recording new route entry information again.
# Display brief information about the records for the route entries issued by the RIB to the FIB.
<Sysname> display ip routing-table record flush
Total number of records: 2
Date   Time         Action Destination/Mask/VNID/Vrf
210907 15:38:50:961 update 200.0.0.0/24/0x111000000/default-vrf
210907 15:40:13:331 delete 200.0.0.0/24/0x0/default-vrf
Table 7 Command output
Total number of route entry records.
Date
Date when a record was generated.
Time
Time when the record was generated.
Action
Action on the route entry in the record:
·     update.
·     delete.
Destination
Destination address.
Mask
Mask length.
VNID
VN entry ID.
Vrf
Name of the VPN instance to which the route belongs. If the route belongs to the public network, this field displays default-vrf.
# Display detailed information about the records for the updated route entries issued by the RIB to the FIB.
<Sysname> display ip routing-table record flush update verbose
Total number of records: 1
Limit of records: 1000
        Time: 210907 15:38:50:961    Action: update
 Destination: 200.0.0.0/24
    VrfIndex: 0                     VrfName: default-vrf
    PriNibID: 0x0
      OrigAs: 0                      LastAs: 0
        VNID: 0x111000000            AttrId: 0xffffffff
       Flags: 0x10020000
       Label: 0xffffffff            BkLabel: 0xffffffff
   LabelType: None               InstanceId: 0
IpPrecedence: 255              QosLocalId: 65535
TrafficIndex: 65535                     Exp: N/A
Table 8 Command output
Limit of records
Maximum number of route entry records.
Time
Date and time when a record was generated.
Action
·     update.
·     delete.
Destination
Destination address and mask length.
VrfIndex
VPN instance index.
VrfName
PriNibID
SRv6 forwarding entry index.
OrigAs
Original AS number.
LastAs
Last AS number.
VNID
VN entry ID.
AttrId
Route attribute ID.
Flags
Flags of the route.
Label
Label.
BkLabel
Backup label.
LabelType
Protocol generated the labels. Values include:
·     None—No label.
·     BGP—BGP protocol.
·     SLSP—SLSP protocol.
·     OSPF—OSPF protocol.
·     ISIS—IS-IS protocol.
·     UNR—User network route.
·     Unknown—Unknown protocol.
InstanceId
ID of the multi-instance process.
IpPre
IP preference.
QosLocalID
Local QoS ID.
TrafficIndex
Traffic index. This field displays N/A when the value is invalid.
SID Type
SID type.
VsiIndex
Index of the VSI to which the EVPN SRv6 SID belongs.
LinkId
Link ID of the L2VPN End.DX2 SID.
ArgLen
Arguments field length.
Exp
VpnPeerId
Dscp
FlowIndex
Flow index.
SID Type
SID type. This field displays N/A if the attribute is not available.
LinkId
Link ID of the SDWAN TTE connection.
# Display brief information about the records for the route entries notified by the RIB to the routing protocol.
<Sysname> display ip routing-table record notify
Total number of records: 3
Date   Time         Action Destination/Mask/NibID/Vrf
210907 15:38:50:961 update 200.0.0.0/24/0x11000000/default-vrf
210907 15:39:46:496 update 200.0.0.0/24/0x11000000/default-vrf
210907 15:39:51:825 update 200.0.0.0/24/0x11000000/default-vrf
Table 9 Command output
Date
Time
Action
·     update.
·     delete.
Destination
Mask
Mask length.
NibID
ID of the next hop.
Vrf
# Display detailed information about the records for the deleted route entries notified by the RIB to the routing protocol.
<Sysname> display ip routing-table record notify delete verbose
        Time: 210908 09:22:11:460    Action: delete
 Destination: 200.0.0.0/8
     TableID: 0x2                     NibID: 0x0
      ActCnt: 0                  InactNibID: 0x0
 OldProtocol: STATIC            NewProtocol: UnSpec
       Flags: 0xc00                ExtFlags: 0x22
Table 10 Command output
Limit of records
Time
Action
·     add.
·     update.
·     delete.
Destination
TableID
ID of the routing table for the route.
NibID
Next hop ID.
ActCnt
Number of active routes using the route prefix.
InactNibID
Next hop ID of the inactive route reported to MPLS.
VrfIndex
VPN instance index.
VrfName
OldProtocol
Routing protocol reported by the route the previous time.
NewProtocol
Routing protocol reported by the route the current time.
Flags
Flags of the route.
ExtFlags
Extended flags of the route.
# Display brief information about the records for the route entries received by the RIB from the routing protocol.
<Sysname> display ip routing-table record receive
Date   Time         Action Proto      Destination/Mask/NibID/Vrf
210907 15:38:50:957 add    STATIC     200.0.0.0/24/0x11000000/default-vrf
210907 15:39:51:825 update STATIC     200.0.0.0/24/0x11000000/default-vrf
210907 15:40:13:329 delete STATIC     200.0.0.0/24/0x11000000/default-vrf
Table 11 Command output
Date
Time
Action
Action on the route entry:
·     add.
·     update.
·     delete.
Protocol
Routing protocol discovered the route.
Destination
Mask
Mask length.
PrefixLength
IPv6 address prefix length.
NibID
ID of the next hop.
Vrf
# Display detailed information about the records for the added route entries received by the RIB from the routing protocol.
<Sysname> display ip routing-table record receive add verbose
        Time: 210907 15:38:50:957    Action: add
     TableID: 0x2                 ProcessID: 0
    Protocol: STATIC              SubProtID: 0x1
       NibID: 0x11000000           NewNibID: N/A
      AttrID: 0xffffffff           ModFlags: 0x0
       Flags: 0x60               ResetFlags: 0x0
     SRLabel: 0xffffffff          BkSRLabel: 0xffffffff
     InLabel: 0xffffffff           SIDIndex: 0xffffffff
      CommID: 0x8000000                 Tag: 0
    SID Type: N/A
         SID: N/A
       BkSID: N/A
         Exp: N/A
Table 12 Command output
Limit of records
Time
Action
·     add.
·     update.
·     delete.
Destination
TableID
Routing table ID of the route entry.
ProcessID
Process ID.
VrfIndex
VPN instance index.
VrfName
Protocol
SubProtID
Routing subprotocol ID.
NibID
Next hop ID.
NewNibID
ID of the updated next hop.
AttrID
Route attribute ID.
Flags
Flags of the route.
ResetFlags
Reset flags of the route upon an update.
This field displays 1 if any bit in the Flags field is changed.
ModFlags
Modified flags of the route.
Label
Label.
BkLabel
Backup label.
SRLabel
SR label.
BkSRLabel
Backup SR label.
InLabel
SIDIndex
SID index value.
CommID
Common informatin entry ID of the route.
Tag
Route tag.
Cost
Cost of the route.
Preference
IpPre
IP precedence.
QosLocalID
Local QoS ID.
Connector
BGP Connector attribute.
PathID
Path ID.
SID Type
SID
Primary SID. If no primary SID is available, this field displays N/A.
BkSID
Backup SID. If no backup SID is available, this field displays N/A.
Exp
VpnPeerId
Dscp
Use display ip routing-table statistics to display IPv4 route or route prefix statistics.
display ip routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] [ prefix ] statistics
all-routes: Specifies the public network and all VPN instances.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays IPv4 route statistics for the public network.
prefix: Displays statistics about IPv4 route prefixes. If you do not specify this keyword, the command displays statistics about IPv4 routes.
If you do not specify any parameters, this command displays statistics about IPv4 routes in the public network.
# Display IPv4 route statistics for the public network.
<Sysname> display ip routing-table statistics
Total prefixes: 15        Active prefixes: 15
Proto      Routes      Active      Added       Deleted
DIRECT     12          12          30          18
STATIC     3           3           5           2
UNR        0           0           0           0
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
OpenR      0           0           0           0
Total      15          15          35          20
# Display IPv4 route statistics for the public network and all VPN instances.
<Sysname> display ip routing-table all-routes statistics
Total prefixes: 11        Active prefixes: 11
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
OpenR      0           0           0           0
Total      11          11          13          2
# Display IPv4 route statistics for VPN instance vpn1.
<Sysname> display ip routing-table vpn-instance vpn1 statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
OpenR      0           0           0           0
Total      11          11          13          2
# Display IPv4 route statistics for all VPN instances.
<Sysname> display ip routing-table all-vpn-instance statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
OpenR      0           0           0           0
Total      11          11          13          2
# Display IPv4 route prefix statistics for the public network.
<Sysname> display ip routing-table prefix statistics
Proto      Prefixes    Active      Added       Deleted
DIRECT     7           7           7           0
STATIC     0           0           0           0
UNR        0           0           0           0
RIP        1           0           1           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
LISP       0           0           0           0
EIGRP      0           0           0           0
BGP        0           0           0           0
OpenR      0           0           0           0
Total      8           7           8           0
Table 13 Command output
Proto
Protocol that installed the route.
Routes
Number of routes installed by the protocol.
Prefixes
Number of IPv4 route prefixes.
Active
Number of active routes.
Added
Number of routes added to the routing table after the router started up or the routing table was cleared most recently.
Deleted
Number of routes marked as deleted, which will be cleared after a period.
Total
Total number of routes.
Use display ip routing-table summary to display brief routing table information, including maximum number of ECMP routes, maximum number of active routes, and number of remaining active routes.
display ip routing-table [ vpn-instance vpn-instance-name ] summary
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays brief routing table information for the public network.
# Display brief routing table information for the public network.
<Sysname> display ip routing-table summary
Max ECMP: 32
Max Active Route: 262144
Remain Active Route: 262126
# Display brief routing table information for the MPLS L3VPN instance vpn1.
<Sysname> display ip routing-table vpn-instance vpn1 summary
Max ECMP: 32
Remain Active Route: 262134
Threshold value percentage of max active routes: 100%
Table 14 Command output
Max ECMP
Maximum number of ECMP routes supported by the system.
Max Active Route
Maximum number of supported routes.
Remain Active Route
Number of the remaining inactive routes.
Threshold value xxx
Alarm threshold of active routes specified by using the routing-table limit command in a VPN instance:
·     Threshold value of active routes alert—This field is displayed when the alarm threshold is specified by using the routing-table limit number simply-alert command. When the number of active routes exceeds the alarm threshold, the system logs the event and sends traps but still accepts active routes.
·     Threshold value percentage of max active routes—This field is displayed when the routing-table limit number simply-alert command is not configured or when the alarm threshold is specified by using the routing-table limit number warn-threshold command. The value range for the alarm threshold is 1 to 100 in percentage. When the percentage of active routes exceeds the alarm threshold, the system logs the event and sends traps but still accepts active routes. If the number of active routes reaches the maximum number, no more routes can be added. The percentage of active routes equals the number of active routes divided by the maximum number of active routes supported in a VPN instance, and multiplied by 100.
Use display ipv6 rib attribute to display route attribute information in the IPv6 RIB.
attribute-id: Specifies a route attribute by its ID, a hexadecimal string in the range of 0 to ffffffff.
# Display route attribute information in the IPv6 RIB.
<Sysname> display ipv6 rib attribute
Total number of attribute(s): 1
Detailed information of attribute 0x9:
                  Flag: 0x0
              Protocol: BGP4+ instance default
        Address family: IPv6
       Reference count: 0
      Local preference: 0
Ext-communities number: 0
 Ext-communities value: N/A
    Communities number: 0
     Communities value: N/A
        AS-path number: 0
         AS-path value: N/A
For command output, see Table 18.
Use display ipv6 rib graceful-restart to display IPv6 RIB GR state information.
# Display IPv6 RIB GR state information.
<Sysname> display ipv6 rib graceful-restart
RIB GR state     : Phase2-calculation end
RCOM GR state    : Flush end
Protocol GR state:
 No.  Protocol   Lifetime FD   State    Start/End
 1    DIRECT6    480      29   End      No/No
 2    STATIC6    480      32   End      No/No
 3    ISISV6     480      30   End      No/No
 4    BGP4+ instance default
                 480      31   End      No/No
 5    OpenR6     480      83   End      No/No
For command output, see Table 19.
Use display ipv6 rib nib to display next hop information in the IPv6 RIB.
display ipv6 rib nib [ sub-nib nib-id ] [ verbose ]
self-originated: Displays information about next hops of self-originated routes in the IPv6 RIB.
sub-nib nib-id: Specifies a sub-NIB by its ID to display information about its parent NIB.
nib-id: Specifies a NIB by its ID, a hexadecimal string in the range of 1 to ffffffff.
verbose: Displays detailed next hop information in the IPv6 RIB. If you do not specify this keyword, the command displays brief next hop information in the IPv6 RIB.
protocol protocol: Specifies a protocol by its name.
# Display brief next hop information in the IPv6 RIB.
<Sysname> display ipv6 rib nib
Total number of nexthop(s): 151
      NibID: 0x20000000        Sequence: 0
       Type: 0x1                Flushed: Yes
        Age: 00h01m50s
   UserKey0: 0x0                VrfNthp: 0
   UserKey1: 0x0                Nexthop: ::
   UserKey2: 0x0                IFIndex: 0x111
   UserKey3: 0x0              LocalAddr: ::
   TopoNthp: Invalid            ExtType: 0x0
      Color: 0                   COFlag: 0x0
     LinkID: 0x0
   SIDIndex: 0x0                SRPName:
 OriNexthop: ::
      NibID: 0x20000001        Sequence: 1
        Age: 00h01m50s
   UserKey1: 0x0                Nexthop: ::1
   UserKey2: 0x0                IFIndex: 0x112
   UserKey3: 0x0              LocalAddr: ::1
     LinkID: 0x0
 OriNexthop: ::
# Display detailed next hop information in the IPv6 RIB.
<Sysname> display ipv6 rib nib verbose
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: ::
     RefCnt: 4              FlushRefCnt: 1
       Flag: 0x84               Version: 1
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: ::
  RelyDepth: 0              RealNexthop: ::
  Interface: NULL0            LocalAddr: ::
  TunnelCnt: 0                      Vrf: default-vrf
   TunnelID: N/A               Topology:
     Weight: 0                    Flags: 0x0
SRPolicyNID: 4294967295     SRInterface:
ColorWeight: 0                  Locator: N/A
 OrigLinkID: 0x0             RealLinkID: 0x0
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: ::
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: ::1
  RelyDepth: 0              RealNexthop: ::1
  Interface: InLoop0          LocalAddr: ::1
      NibID: 0x26000002        Sequence: 1
        Age: 00h01m50s
   UserKey1: 0x0                Nexthop: 122::2
   UserKey3: 0x0              LocalAddr: 122::2
     LinkID: 0x0
 OriNexthop: ::
   Instance: abc
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 122::2
  RelyDepth: 0              RealNexthop: 122::2
For command output, see Table 20 and Table 21.
Use display ipv6 rib nib record to display next hop records in the IPv6 RIB.
display ipv6 rib nib record flush [ delete | update ] [ verbose ]
display ipv6 rib nib record receive [ add | delete | update ] [ verbose ]
flush: Displays the records for the next hops issued by the IPv6 RIB to the FIB.
receive: Displays the records for the next hops received by the IPv6 RIB from the routing protocol.
add: Displays the records for the added next hops.
delete: Displays the records for the deleted next hops.
update: Displays the records for the updated next hops. If you specify the flush keyword, the system takes added next hops as updated next hops when displaying the associated records.
verbose: Displays detailed information about next hop records. If you do not specify this keyword, the command displays only brief information about next hop records.
If you do not specify the add, delete, or update keyword, the command displays records for the added, deleted, and updated next hops.
When the system enters the level-1 memory threshold alarm status, it stops recording new next hop information. When the system enters the level-3 memory threshold alarm status, it clears existing next hop records. When the system exits the level-1 memory threshold alarm status, it starts recording new next hop information again.
# Display brief information about the records for the next hops issued by the IPv6 RIB to the FIB.
<Sysname> display ipv6 rib nib record flush
Date   Time         Action VNID
210908 15:31:55:364 update 0x20000000
210908 15:31:55:364 update 0x120000001
For descriptions about the command output, see Table 22.
# Display detailed information about the records for the updated next hops issued by the IPv6 RIB to the FIB.
<Sysname> display ipv6 rib nib record flush update verbose
        Time: 210908 15:31:55:364    Action: update
       NibID: 0x20000000               VNID: 0x20000000
    Sequence: 0                     Version: 1
        Flag: 0x80                     Type: 0xd
    VrfIndex: 0                     Nexthop: ::
     IfIndex: 1410                LocalAddr: ::
     ExtType: 0x0               NibInstance: IFM
    UserKey0: 0x0                  UserKey1: 0x0
    SIDIndex: 0x0              SrPolicyName:
       Color: 0                  OriNexthop: ::
      COFlag: 0x0                   Locator: N/A
      LinkID: 0x0                PolicyName:
 1 nexthop(s):
   Interface: 258                 LocalAddr: ::
    VrfIndex: 0                    Topology:
      Weight: 0                       Flags: 0x800
 SRPolicyNID: 4294967295        SRInterface: 0
 TELoadShare: 0
       NibID: 0x20000001               VNID: 0x120000001
    Sequence: 1                     Version: 1
        Flag: 0x80                     Type: 0x1
    VrfIndex: 0                     Nexthop: ::1
     IfIndex: 1410                LocalAddr: ::1
 1 nexthop(s):
 TELoadShare: 0
For descriptions about the command output, see Table 23.
# Display brief information about the records for the next hops received by the IPv6 RIB from the routing protocol.
<Sysname> display ipv6 rib nib record receive
Date   Time         Action NibID      NibInstance
210908 10:45:35:211 add    0x21000000 USR
210908 10:45:35:215 update 0x21000000 USR
210908 10:49:47:785 delete 0x21000000 USR
For descriptions about the command output, see Table 24.
# Display detailed information about the records for the added next hops received by the IPv6 RIB from the routing protocol.
<Sysname> display ipv6 rib nib record receive add verbose
        Time: 210928 14:39:14:147    Action: add
 NibInstance: IFM                   Version: 1
        Flag: 0x0                   UsrData: 0xffffffffffffffff
        Type: 0x1                   ExtType: 0x0
  InstanceId: 0                     Nexthop: ::1
   BandWidth: 0                      Weight: 0
   ProtNibID: 0xffffffff           NibFlags: 0x0
 1 nexthop(s):
   Interface: 1410                LocalAddr: ::1
 TELoadShare: 0
For descriptions about the command output, see Table 25.
Use display ipv6 route-direct nib to display next hop information for IPv6 direct routes.
verbose: Displays detailed next hop information for IPv6 direct routes. If you do not specify this keyword, the command displays brief next hop information for IPv6 direct routes.
# Display brief next hop information for IPv6 direct routes.
<Sysname> display ipv6 route-direct nib
Total number of nexthop(s): 115
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: ::
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: ::
# Display detailed next hop information for IPv6 direct routes.
<Sysname> display ipv6 route-direct nib verbose
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: ::
     RefCnt: 1              FlushRefCnt: 0
       Flag: 0x2                Version: 1
 1 nexthop(s):
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: ::
 1 nexthop(s):
For command output, see Table 26 and Table 27.
Use display ipv6 routing-table to display IPv6 routing table information.
display ipv6 routing-table [ all-vpn-instance | vpn-instance vpn-instance-name ] [ verbose ]
display ipv6 routing-table all-routes
all-vpn-instance: Displays IPv6 routing table information for all VPN instances.
all-routes: Displays IPv6 routing table information for the public network and all VPN instances.
# Display brief information about active routes in the IPv6 routing table.
<Sysname> display ipv6 routing-table
Destinations : 3 Routes : 3
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: 6::/64                                      Protocol  : Static
NextHop    : 5::2                                        Preference: 60
Interface  : HGE1/0/1                                     Cost      : 0
Interface  : HGE1/0/2                                     Cost      : 0
Table 15 Command output
Destinations
Routes
Number of routes.
Destination
IPv6 address and prefix of the destination network or host.
NextHop
Preference
Protocol
·     OSPFv3—OSPFv3 route.
·     ISISv6—IPv6 IS-IS route.
·     BGP4+—IPv6 BGP route.
·     OpenR6—IPv6 Open Routing (IPv6 OpenR) route.
Cost
Cost of the route.
Summary count
Number of routes.
<Sysname> display ipv6 routing-table verbose
Destinations : 6 Routes : 6
   Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                        Age: 19h23m02s
     TableID: 0xa                     OrigAs: 0
       NibID: 0x20000000              LastAs: 0
      AttrID: 0xffffffff            Neighbor: ::
       Flags: 0x10004            OrigNextHop: ::1
       Label: NULL               RealNextHop: ::1
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Destination: 6::/64
   Protocol: Static
  Process ID: 0
   SubProtID: 0x0                        Age: 00h01m47s
       NibID: 0x21000000              LastAs: 0
       Flags: 0x10080            OrigNextHop: 5::2
       Label: NULL               RealNextHop: 3::3
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Destination: 12::/96
   Protocol: Direct
  Process ID: 0
       NibID: 0x20000003              LastAs: 0
       Flags: 0x10080            OrigNextHop: ::
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Destination: 12::1/128
   Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                        Age: 00h01m45s
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Destination: FF::11/128
  Process ID: 0
   SubProtID: 0x6                        Age: 00h00m33s
     TableID: 0xa                     OrigAs: 200
       NibID: 0x26000000              LastAs: 200
      AttrID: 0x1                   Neighbor: 12::2
       Flags: 0x10060            OrigNextHop: 12::2
       Label: NULL               RealNextHop: 12::2
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Table 16 Command output
Destination
Protocol
SubProtID
Age
Cost
Cost of the route.
Preference
IpPre
IP precedence.
QosLocalID
Local QoS ID.
Tag
Tag of the route.
Route status:
OrigTblID
OrigVrf
TableID
OrigAs
Original AS number.
NibID
ID of the next hop.
LastAs
Last AS number.
AttrID
Attribute ID.
Neighbor
Flags
Flags of the route.
OrigNextHop
Label
Label.
RealNextHop
BkLabel
Backup label.
BkNexthop
Backup next hop.
SRLabel
BkSRLabel
Backup SR label.
SIDIndex
SID index value.
InLabel
Tunnel ID
Tunnel ID.
BkTunnel ID
BkInterface
IPInterface
BkIPInterface
ColorInterface
BkColorInterface
TunnelInterface
BkTunnelInterface
FtnIndex
TrafficIndex
Connector
BGP connector attribute exchanged between BGP peers along with a VPN IPv4 route. The value of the attribute is the IP address of the remote PE device. The BGP connector attribute is used for MD VPN. This field displays N/A if BGP connector attribute is not supported.
PathID
Path ID.
SRTunnelID
SR tunnel ID.
SID Type
NID
FlushNID
BkNID
BkFlushNID
VpnPeerId
Dscp
Exp
SID
BkSID
CommBlockLen
OrigLinkID
RealLinkID
Use display ipv6 routing-table acl to display routing information permitted by an IPv6 basic ACL.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] acl ipv6-acl-number [ verbose ]
ipv6-acl-number: Specifies a basic IPv6 ACL by its number in the range of 2000 to 2999.
verbose: Displays detailed information about all routes permitted by the basic IPv6 ACL. If you do not specify this keyword, the command displays only brief information about active routes permitted by the basic IPv6 ACL.
If the specified IPv6 ACL does not exist or has no rules configured, the command displays information about all IPv6 routes.
If a rule in the specified IPv6 ACL has the VPN instance match criterion configured, the rule will not take effect.
# Display brief information about active routes permitted by IPv6 ACL 2000.
<Sysname> display ipv6 routing-table acl 2000
Summary count : 5
Destination : ::1/128                                    Protocol  : Direct
Destination: 12::/96                                     Protocol  : Direct
NextHop    : ::                                          Preference: 0
Interface  : Vlan11                                      Cost      : 0
Destination: 12::1/128                                   Protocol  : Direct
Destination: FF::11/128                                  Protocol  : BGP4+
NextHop    : 12::2                                       Preference: 255
Destination: FE80::/10                                   Protocol  : Direct
For command output, see Table 15.
# Display detailed information about all routes permitted by IPv6 ACL 2000.
<Sysname> display ipv6 routing-table acl 2000 verbose
Summary count : 6
   Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                        Age: 19h29m12s
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
   Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                        Age: 00h07m57s
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
For command output, see Table 16.
Use display ipv6 routing-table ipv6-address to display information about routes to an IPv6 destination address.
Use display ipv6 routing-table ipv6-address1 to ipv6-address2 to display information about routes to a range of IPv6 destination addresses.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ longer-match ] [ verbose ]
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address1 to ipv6-address2 [ verbose ]
ipv6-address: Specifies a destination IPv6 address.
prefix-length: Specifies the prefix length in the range of 0 to 128.
ipv6-address1 to ipv6-address2: Specifies a destination IPv6 address range.
Executing the command with different parameters yields different output.
·     display ipv6 routing-table ipv6-address
¡     The system ANDs the entered destination IPv6 address with the prefix length in each active route entry.
¡     The system ANDs the destination IPv6 address in each active route entry with the prefix length in the entry.
·     display ipv6 routing-table ipv6-address prefix-length
¡     The system ANDs the entered destination IPv6 address with the entered prefix length.
¡     The system ANDs the destination IPv6 address in each active route entry with the entered prefix length.
If the two operations yield the same result for an entry with a prefix length not greater than the entered prefix length, the entry is displayed.
·     display ipv6 routing-table ipv6-address longer-match
If you do not specify the prefix-length argument, the command yields the same result as the display ipv6 routing-table command.
·     display ipv6 routing-table ipv6-address prefix-length longer-match
·     display ipv6 routing-table ipv6-address1 to ipv6-address2
The system displays route entries with destinations in the range of ipv6-address1/128 to ipv6-address2/128.
# Display brief information about the routes to the destination IPv6 address 10::1 127.
<Sysname> display ipv6 routing-table 10::1 127
Summary count: 3
Destination: 10::/64                                     Protocol  : Static
NextHop    : ::                                          Preference: 60
Interface  : NULL0                                       Cost      : 0
Destination: 10::/68                                     Protocol  : Static
Destination: 10::/120                                    Protocol  : Static
# Display brief information about the routes to the destination IPv6 address 10::1 with prefix length 127.
<Sysname> display ipv6 routing-table 10::1 127 longer-match
Summary count : 3
# Display brief information about the routes to destination addresses in the range of 100:: to 300::.
<Sysname> display ipv6 routing-table 100:: to 300::
Summary count : 3
Destination: 100::/64                                    Protocol  : Static
Destination: 200::/64                                    Protocol  : Static
Destination: 300::/64                                    Protocol  : Static
# Display detailed information about the routes to destination IPv6 addresses 1:2::3:4/128.
<Sysname> display ipv6 routing-table 1:2::3:4 128 verbose
Summary count : 1
Destination: 1:2::3:4/128
   Protocol: BGP4+ instance abc
  Process ID: 0
   SubProtID: 0x1                        Age: 00h01m14s
     TableID: 0x1                     OrigAs: 200
      AttrID: 0x0                   Neighbor: 2:2::3:4
       Flags: 0x10060            OrigNextHop: 2:2::3:4
       Label: NULL               RealNextHop: 2:2::3:4
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Use display ipv6 routing-table prefix-list to display information about IPv6 routes permitted by an IPv6 prefix list.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
verbose: Displays detailed information about all IPv6 routes permitted by the IPv6 prefix list. If you do not specify this keyword, the command displays brief information about active IPv6 routes permitted by the IPv6 prefix list.
If the specified IPv6 prefix list does not exist, the command displays information about all routes.
# Create an IPv6 prefix list named test to permit the prefix ::1/128.
[Sysname] ipv6 prefix-list test permit ::1 128
# Display brief information about the active IPv6 route permitted by the IPv6 prefix list.
[Sysname] display ipv6 routing-table prefix-list test
Summary count : 1
# Display detailed information about all routes permitted by the IPv6 prefix list.
[Sysname] display ipv6 routing-table prefix-list test verbose
Summary count : 1
   Protocol: Direct
  Process ID: 0
   SubProtID: 0x0                        Age: 08h57m19s
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Use display ipv6 routing-table protocol to display information about IPv6 routes installed by a protocol.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ]
# Display brief information about IPv6 direct routes.
<Sysname> display ipv6 routing-table protocol direct
Summary count : 2
Summary count : 2
Summary count : 0
# Display brief information about IPv6 static routes.
<Sysname> display ipv6 routing-table protocol static
Summary count : 3
Summary count : 3
Destination: 2::2/128                                    Protocol  : Static
NextHop    : fe80::2                                     Preference: 60
Interface  : Vlan12                                      Cost      : 0
NextHop    : fe80::3                                     Preference: 60
Destination: 3::3/128                                    Protocol  : Static
NextHop    : 2::2                                        Preference: 60
Summary count : 0
# Display brief information about IPv6 OpenR routes.
<Sysname> display ipv6 routing-table protocol openr
Summary count : 1
OpenR6 Routing table status : <Active>
Summary count : 1
Destination: 2::2/128                                    Protocol  : OpenR6
NextHop    : fe80::2                                     Preference: 30
OpenR6 Routing table status : <Inactive>
Summary count : 0
# Display detailed information about IPv6 BGP routes.
<Sysname> display ipv6  routing-table protocol bgp4+ verbose
Summary count : 1
Destination: 22::22/128
  Process ID: 0
   SubProtID: 0x6                        Age: 00h04m15s
       NibID: 0x25000001              LastAs: 200
      AttrID: 0x3                   Neighbor: 121::2
       Flags: 0x10060            OrigNextHop: 121::2
       Label: NULL               RealNextHop: 121::2
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
# Display detailed information about IPv6 OpenR routes.
<Sysname> display ipv6 routing-table protocol openr verbose
Summary count : 1
   Protocol: OpenR6
  Process ID: 0
   SubProtID: 0x1                        Age: 01h28m12s
       Flags: 0x10060            OrigNextHop: 200::6
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
display ipv6 routing-table record
Use display ipv6 routing-table record to display IPv6 routing entry records.
display ipv6 routing-table record flush [ delete | update ] [ verbose ]
display ipv6 routing-table record notify [ delete | update ] [ verbose ]
display ipv6 routing-table record receive [ add | delete | update ] [ verbose ]
flush: Displays the records for the route entries issued by the IPv6 RIB to the FIB.
notify: Displays the records for the route entries notified by the IPv6 RIB to the routing protocol.
receive: Displays the records for the route entries received by the IPv6 RIB from the routing protocol.
verbose: Displays detailed information about IPv6 route entry records. If you do not specify this keyword, the command displays only brief information about IPv6 route entry records.
# Display brief information about the records for the route entries issued by the IPv6 RIB to the FIB.
<Sysname> display ipv6 routing-table record flush
Date   Time         Action Destination/PrefixLength/VNID/Vrf
210908 09:33:21:996 update 1001::/64/0x520000004/default-vrf
210908 09:33:23:386 update 1001::1/128/0x120000001/default-vrf
For descriptions about the command output, see Table 7.
# Display detailed information about the records for the updated route entries issued by the IPv6 RIB to the FIB.
<Sysname> display ipv6 routing-table record flush update verbose
        Time: 210908 09:33:21:996    Action: update
 Destination: 1001::/64
    PriNibID: 0x0
      OrigAs: 0                      LastAs: 0
        VNID: 0x520000004
       Flags: 0x10040000          FlowIndex: 65535
    SID Type: 0                    VsiIndex: 0xffffffff
      LinkId: 0xffffffff             ArgLen: 0
  InstanceId: 0                      AttrId: 0xffffffff
        Time: 210908 09:33:23:386    Action: update
 Destination: 1001::1/128
    PriNibID: 0x0
      OrigAs: 0                      LastAs: 0
        VNID: 0x120000001
For descriptions about the command output, see Table 8.
# Display brief information about the records for the route entries notified by the IPv6 RIB to the routing protocol.
<Sysname> display ipv6 routing-table record notify
Date   Time         Action Destination/PrefixLength/NibID/Vrf
210908 10:47:03:698 update 2000::/64/0x21000000/default-vrf
For descriptions about the command output, see Table 9.
# Display detailed information about the records for the deleted route entries notified by the IPv6 RIB to the routing protocol.
<Sysname> display ipv6 routing-table record notify delete verbose
        Time: 210908 10:49:47:787    Action: delete
 Destination: 2000::/64
     TableID: 0xa                     NibID: 0x0
     RtFlags: 0xc00              ExtRtFlags: 0x22
For descriptions about the command output, see Table 10.
# Display brief information about the records for the route entries received by the IPv6 RIB from the routing protocol.
<Sysname> display ipv6 routing-table record receive
Date   Time         Action Proto      Destination/PrefixLength/NibID/Vrf
210908 09:33:23:385 add    DIRECT     1001::1/128/0x20000001/default-vrf
For descriptions about the command output, see Table 11.
# Display detailed information about the records for the added route entries received by the IPv6 RIB from the routing protocol.
<Sysname> display ipv6 routing-table record receive add verbose
        Time: 210908 09:33:23:385    Action: add
     TableID: 0xa                 ProcessID: 0
    Protocol: DIRECT              SubProtID: 0x0
       NibID: 0x20000001           NewNibID: N/A
       Flags: 0x4                ResetFlags: 0x0
      CommID: 0x5000001                 Tag: 0
    SID Type: N/A
         SID: N/A
       BkSID: N/A
         Exp: N/A
For descriptions about the command output, see Table 12.
display ipv6 routing-table statistics
Use display ipv6 routing-table statistics to display IPv6 route and route prefix statistics.
display ipv6 routing-table [ all-routes | all-vpn-instance | vpn-instance vpn-instance-name ] [ prefix ] statistics
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays route statistics for the public network.
prefix: Displays statistics about IPv6 route prefixes. If you do not specify this keyword, the command displays statistics about IPv6 routes.
If you do not specify any parameters, this command displays statistics about IPv6 routes in the public network.
# Display IPv6 route statistics for the public network.
<Sysname> display ipv6 routing-table statistics
Total prefixes: 8        Active prefixes: 8
DIRECT     5           5           5           0
STATIC     3           3           3           0
UNR        0           0           0           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
SRv6       0           0           0           0
BGP4+      0           0           0           0
OpenR6     0           0           0           0
Total      8           8           8           0
# Display IPv6 route statistics for the public network and all VPN instances.
<Sysname> display ipv6 routing-table all-routes statistics
Total prefixes: 6        Active prefixes: 6
DIRECT     3           3           3           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
SRv6       0           0           0           0
BGP4+      0           0           0           0
OpenR6     0           0           0           0
Total      6           6           8           2
# Display IPv6 route statistics for VPN instance vpn1.
<Sysname> display ipv6 routing-table vpn-instance vpn1 statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
SRv6       0           0           0           0
BGP4+      0           0           0           0
OpenR6     0           0           0           0
Total      11          11          13          2
# Display IPv6 route statistics for all VPN instances.
<Sysname> display ipv6 routing-table all-vpn-instance statistics
DIRECT     8           8           8           0
STATIC     3           3           5           2
UNR        0           0           0           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
LISP       0           0           0           0
SRv6       0           0           0           0
BGP4+      0           0           0           0
OpenR6     0           0           0           0
Total      11          11          13          2
# Display IPv6 route prefix statistics for the public network.
<Sysname> display ipv6 routing-table prefix statistics
DIRECT     5             5           5           0
STATIC     1             1           1           0
UNR        0             0           0           0
RIPng      0             0           0           0
OSPFv3     0             0           0           0
IS-ISv6    0             0           0           0
LISP       0             0           0           0
SRv6       0             0           0           0
BGP4+      0             0           0           0
OpenR6     0             0           0           0
Total      6             6           6           0
Table 17 Command output
Proto
Routes
Prefixes
Number of IPv6 route prefixes.
Active
Added
Deleted
Total
display ipv6 routing-table summary
Use display ipv6 routing-table summary to display brief IPv6 routing table information, including maximum number of ECMP routes, maximum number of active routes, and number of remaining active routes.
display ipv6 routing-table [ vpn-instance vpn-instance-name ] summary
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays brief IPv6 routing table information for the public network.
# Display brief IPv6 routing table information for the public network.
<Sysname> display ipv6 routing-table summary
Max ECMP: 32
# Display brief IPv6 routing table information for the MPLS L3VPN instance vpn1.
<Sysname> display ipv6 routing-table vpn-instance vpn1 summary
Max ECMP: 32
Threshold value of active routes alert: 65100
For command output, see Table 14.
display rib attribute
Use display rib attribute to display route attribute information in the RIB.
# Display route attribute information in the RIB.
<Sysname> display rib attribute
Total number of attribute(s): 10
Detailed information of attribute 0x0:
                  Flag: 0x0
        Address family: IPv4
       Reference count: 0
Act-RT reference count: 0
            Flush flag: 0
      Local preference: 0
Ext-communities number: 26
 Ext-communities value: <RT: 1:1> <RT: 2:2> <RT: 3:3> <RT: 123.123.123.123:65535
                        > <RT: 1234567890:65535> <RT: 123.123.123.123:65534> <RT
                        : 4:4> <RT: 5:5> <RT: 6:6> <RT: 7:7> <RT: 8:8> <RT: 9:9>
                         <RT: 10:10> <RT: 10:1> <RT: 10:11> <RT: 10:12> <RT: 10:
                        13> <RT: 10:14> <RT: 10:15> <RT: 10:16> ...
        AS-path number: 0
         AS-path value: N/A
  SFlow AS-path length: 0
   SFlow AS-path value: N/A
Detailed information of attribute 0x1:
                  Flag: 0x0
              Protocol: BGP
       Reference count: 0
            Flush flag: 0
      Local preference: 0
Ext-communities number: 1
 Ext-communities value: <RT: 1:2>
        AS-path number: 0
         AS-path value: N/A
Table 18 Command output
Protocol
Protocol that generates the attribute.
Reference count of active routes.
Flush flag
Flag of flushing route attribute information to the FIB:
·     0—The route attribute information is not flushed to the FIB.
·     1—The route attribute information is flushed to the FIB.
Number of the extended community attribute values.
Values of the extended community attribute. This field displays N/A when no values exist, and it can display a maximum of 20 values.
Communities number
Number of the COMMUNITY attribute values.
Communities value
Values of the COMMUNITY attribute. This field displays N/A when no values exist, and it can display a maximum of 20 values.
AS-path number
Number of ASs in the AS_PATH attribute.
AS-path value
Values of the AS_PATH attribute, including AS_SET, AS_SEQUENCE, confederation AS_SET, and confederation AS_SEQUENCE. This field displays N/A when no values exist, and it can display a maximum of 20 values.
Length of the sFlow AS-path attribute.
SFlow AS-path value
Value of the sFlow AS-path attribute. This field displays N/A if the length of the sFlow AS-path attribute is 0. This field can display a maximum of 80 characters.
display rib graceful-restart
Use display rib graceful-restart to display RIB GR state information.
# Display RIB GR state information.
<Sysname> display rib graceful-restart
Protocol GR state:
 1    DIRECT     100      30   End      No/No
 2    STATIC     480      34   End      No/No
 3    OSPF       480      36   End      No/No
 4    ISIS       480      32   End      No/No
 5    BGP instance default
                 480      25   End      No/No
 6    OpenR      480      85   End      No/No
Table 19 Command output
RIB GR state
RIB GR status:
·     Start—GR starts.
·     IGP end—All IGP protocols complete GR.
·     VPN-triggering end—Optimal route selection triggered by VPN routes completes.
·     VPN-calculation end—Optimal VPN route selection completes.
·     Routing protocol end—All routing protocols complete GR.
·     Triggering start—All triggered optimal route selection starts.
·     Triggering end—All triggered optimal route selection completes.
·     Phase1-calculation end—Optimal route selection phase 1 completes.
·     All end—All protocols complete GR.
·     Phase2-calculation end—Optimal route selection phase 2 completes.
RCOM GR state
RCOM GR status:
·     Start—GR starts.
·     VPN-notification end—VPN routes have been delivered to the route management module.
·     Notification end—All routes have been delivered to the route management module.
·     Flush start—Starts to flush routes to the FIB.
·     Flush end—Completes flushing routes to the FIB.
No.
Protocol number.
Lifetime
Lifetime (in seconds) of routes in the RIB during GR.
FD
Handle between the protocol and the RIB.
Protocol GR state:
·     Init—Initialization state.
·     Listen—Listening state.
·     Idle.
·     Active.
·     Start—GR starts.
·     End—GR completes.
Start/End
Message sending state:
·     No—The message has not been sent.
·     Yes—The message has been sent.
display rib nib
Use display rib nib to display next hop information in the RIB.
display rib nib [ sub-nib nib-id ] [ verbose ]
self-originated: Displays information about next hops of self-originated routes in the RIB.
verbose: Displays detailed next hop information in the RIB. If you do not specify this keyword, the command displays brief next hop information in the RIB.
# Display brief next hop information in the RIB.
<Sysname> display rib nib
Total number of nexthop(s): 176
      NibID: 0x10000000        Sequence: 0
        Age: 00h01m50s
   UserKey1: 0x0                Nexthop: 0.0.0.0
   UserKey3: 0x0              LocalAddr: 0.0.0.0
   TopoNthp: 0                  ExtType: 0x0
     LinkID: 0x0
 OriNexthop: 0.0.0.0
      NibID: 0x10000001        Sequence: 1
        Age: 00h01m50s
   UserKey1: 0x0                Nexthop: 127.0.0.1
   UserKey3: 0x0              LocalAddr: 127.0.0.1
     LinkID: 0x0
 OriNexthop: 0.0.0.0
      NibID: 0x10000002        Sequence: 2
       Type: 0x5                Flushed: Yes
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: 0.0.0.0
      NibID: 0x16000000        Sequence: 3
       Type: 0x21               Flushed: No
   UserKey1: 0x0                Nexthop: 12.1.1.2
   UserKey2: 0x0                IFIndex: 0x0
     LinkID: 0x0
 OriNexthop: 0.0.0.0
   Instance: abc
Table 20 Command output
NibID
ID of the next hop.
Sequence
Sequence number of the next hop.
Type of the next hop.
Flushed
Indicates whether the route with the next hop has been flushed to the FIB.
Age
Elapsed time since the next hop information was last updated.
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
UserKey2
Reserved data 3.
UserKey3
Reserved data 4.
VrfNthp
Index of the VPN instance to which the next hop belongs. This field displays 0 if the next hop is on the public network.
Nexthop
Next hop address.
IFIndex
Interface index.
LocalAddr
Local interface address.
TopoNthp
(Non-base topologies are not supported in the current software version.) Index of the topology that contains the next hop. For IPv4 routes, this field displays 0 if the next hop is on the public network. For IPv6 routes, this field displays Invalid.
ExtType
NIB extension type.
Color
Color extended community attribute.
COFlag
Flag of the color extended community attribute.
LinkID
SIDIndex
SID index value.
Instance
BGP instance name.
SubNibID
ID of the sub-next hop.
SubSeq
Sequence number of the sub-next hop.
NthpCnt
Number of sub-next hops.
Samed
Number of the same sub-next hops.
NthpType
Type of the sub-next hop. The value is IP, which represents IP forwarding.
SRPName
SR-MPLS TE policy name.
OriNexthop
Original next hop of the route. If the route is obtained from a BGP update message, this field displays the next hop IP address in the received message.
# Display detailed next hop information in the RIB.
<Sysname> display rib nib verbose
        Age: 00h01m50s
   UserKey2: 0x0                IFIndex: 0x10002
     LinkID: 0x0
 OriNexthop: 0.0.0.0
     RefCnt: 6              FlushRefCnt: 2
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 0.0.0.0
  RelyDepth: 0              RealNexthop: 0.0.0.0
  Interface: NULL0            LocalAddr: 0.0.0.0
   TunnelID: N/A               Topology: base
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: 0.0.0.0
     RefCnt: 11             FlushRefCnt: 5
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 127.0.0.1
  RelyDepth: 0              RealNexthop: 127.0.0.1
  Interface: InLoop0          LocalAddr: 127.0.0.1
      NibID: 0x15000003        Sequence: 3
       Type: 0x43               Flushed: Yes
        Age: 00h01m50s
   UserKey0: 0x100010000        VrfNthp: 0
   UserKey1: 0x0                Nexthop: 22.22.22.22
     LinkID: 0x0
 OriNexthop: 0.0.0.0
   Instance: default
     RefCnt: 9              FlushRefCnt: 3
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 22.22.22.22
  RelyDepth: 1              RealNexthop: 13.1.1.2
  Interface: Vlan11           LocalAddr: 13.1.1.1
  TunnelCnt: 1                      Vrf: default-vrf
   TunnelID: 1025              Topology: base
Table 21 Command output
x nexthop (s)
Number of next hops.
PrefixIndex
Prefix index of the next hop for an ECMP route.
Vrf
VPN instance name. For the public network, this field displays default-vrf.
OrigNexthop
Original next hop.
RealNexthop
Real next hop.
Output interface.
LocalAddr
IFIndex
Interface index.
TopoNthp
ExtType
NIB extension type.
Color
COFlag
LinkID
SIDIndex
SID index value.
SRPName
OriNexthop
RelyDepth
Recursion depth.
TunnelCnt
Number of tunnels after route recursion.
TunnelID
ID of the tunnel after route recursion.
Topology
Topology name. For IPv4 routes, this field displays base for the topology on the public network. For IPv6 routes, this field is blank.
Weight
ECMP route weight. This field displays 0 for non-ECMP routes.
Instance
BGP instance name.
RefCnt
Reference count of the next hop.
FlushRefCnt
Reference count of the next hop that is flushed to the FIB.
Flag
Flag of the next hop.
Version
Version of the next hop.
Flags
Flags of the detailed next hop.
SRPolicyNID
NIB ID of the route obtained from an SR-MPLS TE policy through route recursion.
SRInterface
Output interface of the route obtained from the SR-MPLS TE policy through route recursion.
ColorWeight
Weight value of the color attribute in the SR-MPLS TE policy.
Locator
IPv6 prefix of the locator to which the SID belongs. N/A indicates that the attribute is not available.
OrigLinkID
RealLinkID
display rib nib record
Use display rib nib record to display next hop records in the RIB.
display rib nib record flush [ delete | update ] [ verbose ]
display rib nib record receive [ add | delete | update ] [ verbose ]
flush: Displays the records for the next hops issued by the RIB to the FIB.
receive: Displays the records for the next hops received by the RIB from the routing protocol.
# Display brief information about the records for the next hops issued by the RIB to the FIB.
<Sysname> display rib nib record flush
210908 15:31:58:753 update 0x10000000
210908 15:31:58:755 update 0x110000001
Table 22 Command output
Total number of next hop records.
Date
Time
Action
Action on the next hop in the record:
·     add.
·     update.
·     delete.
VNID
VN entry ID.
# Display detailed information about the records for the updated next hops issued by the RIB to the FIB.
<Sysname> display rib nib record flush update verbose
        Time: 210928 14:39:14:162    Action: update
       NibID: 0x10000000               VNID: 0x10000000
      RefCnt: 5                 FlushRefCnt: 1
    VrfIndex: 0x0                   Nexthop: 127.0.0.1
     IfIndex: 1410                LocalAddr: 127.0.0.1
       Color: 0                  OriNexthop: 0.0.0.0
 1 nexthop(s):
   Interface: 1410                LocalAddr: 127.0.0.1
    VrfIndex: 0                    Topology: base
 TELoadShare: 0
Table 23 Command output
Limit of records
Maximum number of next hop records.
Time
Action
·     update.
·     delete.
NibID
ID of the next hop.
VNID
VN entry ID.
Sequence
Version
Flag
RefCnt
FlushRefCnt
Next hop type.
VrfIndex
VPN instance index.
Nexthop
Next hop address.
IfIndex
Output interface index.
LocalAddr
ExtType
Extended type of the next hop.
NibInstance
Instance or protocol generated the next hop information:
·     IFM—Interface management instance.
·     USR—Static routing.
·     RIP—RIP or RIPng.
·     OSPF—OSPF or OSPFv3.
·     ISIS—IS-IS or IPv6 IS-IS.
·     BGP—BGP or BGP4+.
·     RIB—IP routing table instance.
·     UNR—User network routing instance.
·     None—Unknown or invalid instance.
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
SIDIndex
SID index value.
SrPolicyName
Name of an SR-MPLS TE policy.
Color
OriNexthop
Original next hop address of the route.
If the route is obtained from a BGP UPDATE message, the address is the next hop IP address in the BGP UPDATE message.
COFlag
Locator
If no locator is available, this field displays N/A.
PolicyName
Name of the SR-MPLS TE policy.
TELoadShare
LoadShare setting of the TE interface.
SubType
Subtype of the parent NIB.
SubNibID
SubSeq
NthpCnt
Samed
NthpType
Type of the sub-next hop:
·     IP—IP forwarding.
x nexthop (s)
PrefixIndex
OrigNexthop
Original next hop.
RelyDepth
Recursion depth.
RealNexthop
Real next hop.
Output interface.
Topology
Topology name. The topology name for the IPv4 public network is base. This field is blank for IPv6, because IPv6 does not support non-base topologies.
Weight
Flags
Flags of the current next hop.
SRPolicyNID
SRInterface
ColorWeight
Locator
LinkID
link ID of the SDWAN TTE connection.
OrigLinkID
Original link ID of the SDWAN TTE connection.
RealLinkID
Real link ID of the SDWAN TTE connection.
# Display brief information about the records for the next hops received by the RIB from the routing protocol.
<Sysname> display rib nib record receive
210907 14:42:09:471 add    0x10000003 IFM
210907 15:35:45:190 delete 0x10000003 IFM
Table 24 Command output
Date
Time
Action
·     add.
·     update.
·     delete.
NibID
ID of the next hop.
NibInstance
·     RIP—RIP or RIPng.
·     BGP—BGP or BGP4+.
# Display detailed information about the records for the added next hops received by the RIB from the routing protocol.
<Sysname> display rib nib record receive add verbose
        Time: 210928 14:39:14:148    Action: add
  InstanceId: 0                     Nexthop: 127.0.0.1
 1 nexthop(s):
 TELoadShare: 0
Table 25 Command output
Limit of records
Time
Action
·     add.
·     update.
·     delete.
NibID
Next hop ID.
Sequence
Next hop sequence number.
NibInstance
·     RIP—RIP or RIPng.
·     BGP—BGP or BGP4+.
Version
Flag
UsrData
Protocol private data.
VrfIndex
VPN instance index.
VrfName
Next hop type.
Nexthop
Next hop address.
ExtType
LocalAddr
InstanceId
IfIndex
Interface index.
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
Color
COFlag
BandWidth
Bandwidth of the link associated with the next hop.
Weight
ProtNibID
Next hop ID carried by the protocol.
NibFlags
Flags of the next hop.
SIDIndex
SID index value.
SrPolicyName
LinkID
PolicyName
SubType
SubNibID
SubSeq
NthpCnt
Samed
NthpType
·     IP—IP forwarding.
x nexthop (s)
PrefixIndex
OrigNexthop
Original next hop.
RelyDepth
Recursion depth.
RealNexthop
Real next hop.
Output interface.
Topology
Flags
SRPolicyNID
SRInterface
ColorWeight
Locator
TELoadShare
OrigLinkID
RealLinkID
display route-direct nib
Use display route-direct nib to display next hop information for direct routes.
verbose: Displays detailed next hop information for direct routes. If you do not specify this keyword, the command displays brief next hop information for direct routes.
# Display brief next hop information for direct routes.
<Sysname> display route-direct nib
Total number of nexthop(s): 116
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: 0.0.0.0
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: 0.0.0.0
Table 26 Command output
NibID
ID of the NIB.
Sequence
Sequence number of the NIB.
Type of the NIB.
Flushed
Indicates whether the route with the NIB has been flushed to the FIB.
Age
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
UserKey2
Reserved data 3.
UserKey3
Reserved data 4.
Color
COFlag
LinkID
SIDIndex
SID index value.
VrfNthp
Nexthop
Next hop address.
IFIndex
Interface index.
LocalAddr
Local interface IP address.
TopoNthp
ExtType
NIB extension type.
SRPName
OriNexthop
# Display detailed next hop information for direct routes.
<Sysname> display route-direct nib verbose
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: 0.0.0.0
     RefCnt: 2              FlushRefCnt: 0
 1 nexthop(s):
        Age: 00h01m50s
     LinkID: 0x0
 OriNexthop: 0.0.0.0
     RefCnt: 5              FlushRefCnt: 0
 1 nexthop(s):
Table 27 Command output
x nexthop(s)
PrefixIndex
Vrf
OrigNexthop
Original next hop.
RealNexthop
Real next hop.
Output interface.
localAddr
RelyDepth
Recursion depth.
TunnelCnt
TunnelID
Topology
Weight
RefCnt
FlushRefCnt
Flag
Version
IFIndex
Interface index.
TopoNthp
ExtType
NIB extension type.
Color
COFlag
Flag of the extended community attribute.
LinkID
SIDIndex
SID index value.
SRPName
OriNexthop
Flags
SRPolicyNID
SRInterface
ColorWeight
Locator
OrigLinkID
RealLinkID
ecmp mode enhanced
Use ecmp mode enhanced to enable the IPv4 and IPv6 enhanced ECMP mode.
Use undo ecmp mode to disable the IPv4 and IPv6 enhanced ECMP mode.
ecmp mode enhanced
undo ecmp mode
The IPv4 and IPv6 enhanced ECMP mode is disabled.
When one or multiple ECMP routes fail, the default ECMP mode enables the device to reallocate all traffic to the remaining routes.
The enhanced ECMP mode enables the device to reallocate only the traffic of the failed routes to the remaining routes.
This command takes effect after a device reboot. Before you reboot the device, make sure you understand the potential impact on the network.
# Enable the IPv4 and IPv6 enhanced ECMP mode.
[Sysname] ecmp mode enhanced
The configuration will take effect at the next reboot. Continue? [Y/N]:y
Reboot device to make the configuration take effect.
display ecmp mode
fib lifetime
Use fib lifetime to set the maximum lifetime for IPv4 or IPv6 routes in the FIB.
Use undo fib lifetime to restore the default.
fib lifetime seconds
undo fib lifetime
The maximum lifetime for IPv4 or IPv6 routes in the FIB is 600 seconds.
RIB IPv4 address family view
RIB IPv6 address family view
seconds: Specifies the maximum lifetime for routes in the FIB, in the range of 0 to 6000 seconds. When this argument is set to 0, FIB entries immediately age out after a protocol or RIB process switchover.
When a protocol or RIB process switchover occurs and GR is not configured, FIB entries age out after the time specified in this command.
# Set the maximum lifetime for IPv4 routes in the FIB to 60 seconds.
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4] fib lifetime 60
flush route-attribute
Use flush route-attribute to enable the RIB to flush route attribute information to the FIB.
Use undo flush route-attribute remove the configuration.
flush route-attribute protocol
undo flush route-attribute protocol
The RIB does not flush route attribute information to the FIB.
protocol: Specifies a routing protocol. In the current software version, only BGP is supported.
# Enable the RIB to flush BGP route attribute information to the FIB.
[Sysname] rib
[Sysname-rib-ipv4] flush route-attribute bgp
hardware-resource routing-mode
Use hardware-resource routing-mode to set the routing-mode hardware resource mode.
Use undo hardware-resource routing-mode to restore the default.
hardware-resource routing-mode ipv6-128
The routing-mode hardware resource mode is IPv6-128.
ipv6-128: Specifies the IPv6-128 mode.
This command takes effect upon device reboot. Before you reboot the device, make sure you understand the potential impact on the network.
The default routing-mode hardware resource mode is IPv6-128. In this mode, the device supports IPv6 routes with more than 64 bits.
# Set the routing-mode hardware resource mode to IPv6-128.
[Sysname] hardware-resource routing-mode ipv6-128
display hardware-resource routing-mode
inter-protocol fast-reroute
Use inter-protocol fast-reroute to enable IPv4 or IPv6 RIB inter-protocol FRR.
Use undo inter-protocol fast-reroute to disable IPv4 or IPv6 RIB inter-protocol FRR.
inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
undo inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
Inter-protocol FRR is disabled.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command enables inter-protocol FRR for the public network.
This command allows a device to perform fast rerouting between routes of different protocols. A backup next hop is automatically selected to reduce the service interruption time caused by unreachable next hops. When the next hop of the primary link fails, the traffic is redirected to the backup next hop.
This command uses the next hop of a route from a different protocol as the backup next hop for the faulty route, which might cause loops.
Inter-protocol FRR cannot select a backup next hop from routes in the RIB that have the same next hop, output interface, and destination as those of the faulty route.
# Enable IPv4 RIB inter-protocol FRR for the public network.
[Sysname] rib
[Sysname-rib-ipv4] inter-protocol fast-reroute
ip load-sharing mode
Use ip load-sharing mode to configure the load sharing mode.
Use undo ip load-sharing mode to restore the default.
ip load-sharing mode per-flow [ algorithm algorithm-number [ seed seed-number ] [ shift shift-number ] | [ dest-ip | dest-port | ingress-port | ip-pro | src-ip | src-port ] * ] { global | slot slot-number }
undo ip load-sharing mode [ per-flow [ algorithm algorithm-number [ seed seed-number ] [ shift shift-number ] | [ dest-ip | dest-port | ingress-port | ip-pro | src-ip | src-port ] * ] ] { global | slot slot-number }
The device performs per-flow load sharing based on the following criteria: source IP address, destination IP address, source port number, destination port number, IP protocol number, and ingress port.
per-flow: Implements per-flow load sharing.
algorithm algorithm-number: Specifies an algorithm by its number for per-flow load sharing.The value range and the default value for the algorithm-number argument is 0 to 13.
seed seed-number: Specifies the seed value for the algorithm. The value range for the seed-number argument is 0 to ffff.
dest-ip: Identifies flows by destination IP address.
dest-port: Identifies flows by destination port.
ingress-port: Identifies flows by ingress port.
ip-pro: Identifies flows by protocol number.
src-ip: Identifies flows by source IP address.
src-port: Identifies flows by source port.
global: Configures the load sharing mode globally.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command configures the load sharing mode for all member devices.
The dest-ip and src-ip keywords are specified in pairs.
·     If you specify the dest-ip keyword, this command automatically adds the src-ip keyword.
·     If you specify the src-ip keyword, this command automatically adds the dest-ip keyword.
The src-port and dest-port keywords are specified in pairs.
·     If you specify the dest-port keyword, this command automatically adds the src-port keyword.
·     If you specify the src-port keyword, this command automatically adds the dest-port keyword.
If you execute this command multiple times for the same algorithm level, the most recent configuration takes effect.
If traffic is not load shared well among interfaces, you can use the seed seed-number option and the shift shift-number option to adjust the algorithm result.
# Configure per-flow load sharing.
[Sysname] ip load-sharing mode per-flow slot 1
# Configure per-flow load sharing for slot 1 and specify algorithm 1 at level 2.
[Sysname] ip load-sharing mode per-flow level 2 algorithm 1 slot 1
ip load-sharing symmetric enable
Use ip load-sharing symmetric enable to enable symmetric load sharing.
Use undo ip load-sharing symmetric enable to disable symmetric load sharing.
Symmetric load sharing is disabled.
Symmetric load sharing ensures that bidirectional traffic specific to a particular source and destination address pair flow along the same path.
# Enable symmetric load sharing.
[Sysname] ip load-sharing symmetric enable
ipv6 route fast-switchover enable
Use ipv6 route fast-switchover enable to enable IPv6 route fast switchover.
Use undo ipv6 route fast-switchover enable to disable IPv6 route fast switchover.
IPv6 route fast switchover is disabled.
Use this command if a physical interface is the output interface for a large number of routes, including ECMP routes and primary/secondary routes. When a link failure occurs on an interface, the device typically performs the following operations before switching the traffic to a valid route:
1.     Deletes all ND entries for the link.
2.     Instructs the FIB to delete the associated FIB entries.
This process is time-consuming and interruptive if a large number of routes traverse the interface. Route fast switchover minimizes traffic interruption by instructing the FIB to delete the affected FIB entries immediately without having to wait for the ND entries to be deleted.
# Enable IPv6 route fast switchover.
[Sysname] ipv6 route fast-switchover enable
nexthop recursive-lookup restrain clear-interval
Use nexthop recursive-lookup restrain clear-interval to set the interval for clearing the recursion loop counter.
Use undo nexthop recursive-lookup restrain clear-interval to restore the default.
nexthop recursive-lookup restrain clear-interval interval
The interval for clearing the recursion loop counter is 600 seconds.
clear-interval interval: Specifies the interval for clearing the recursion loop counter, in the range of 1 to 65535 seconds.
Recursion loop suppression enables the system to use a counter to record the number of route recursion failures. When the counter reaches 20, the system suppresses route recursion for a specified period of time. When the suppression time expires, the system resets the counter and disables route recursion suppression.
# Set the interval for clearing the recursion loop counter to 100 seconds.
[Sysname] rib
[Sysname-rib-ipv4] nexthop recursive-lookup restrain clear-interval 100
nexthop recursive-lookup restrain disable
Use nexthop recursive-lookup restrain disable to disable the suppression for next hop recursion loop.
Use undo nexthop recursive-lookup restrain disable to enable the suppression for next hop recursion loop.
Suppression for next hop recursion loop is enabled.
A recursion loop occurs when a route recurses to a related route that recurses back to the route. It causes a route recursion failure and further lookup for a related route. If recursion loop persists, continuous route flapping will cause high system resource consumption and CPU utilization.
This command enables the system to use a counter to record the number of route recursion failures. When the counter reaches 20, the system suppresses route recursion for a specified period of time to save system resources on the device.
# Disable the suppression for next hop recursion loop.
[Sysname] rib
[Sysname-rib-ipv4] nexthop recursive-lookup restrain disable
primary-path-detect bfd
Use primary-path-detect bfd to enable BFD for primary route next hop detection of inter-protocol FRR or ECMP routes.
Use undo primary-path-detect bfd to disable BFD for primary route next hop detection of inter-protocol FRR or ECMP routes.
primary-path-detect bfd { ctrl | echo } [ inter-protocol-frr | protocol-ecmp protocol ]
undo primary-path-detect bfd [ inter-protocol-frr | protocol-ecmp protocol ]
BFD is disabled for primary route next hop detection of inter-protocol FRR or ECMP routes.
ctrl: Specifies the BFD control packet mode.
echo: Specifies the BFD echo packet mode.
inter-protocol-frr: Enables primary route next hop detection for inter-protocol FRR.
protocol-ecmp protocol: Enables primary route next hop detection for ECMP routes of a routing protocol.
·     In RIB IPv4 address family view, the value for the protocol argument can be bgp, isis, ospf, or static.
·     In RIB IPv6 address family view, the value for the protocol argument depends on the BFD mode.
¡     In BFD control packet mode, the value can be bgp4+, isisv6, ospfv3, or static.
¡     In BFD echo packet mode, the value can be bgp4+ or static.
After you configure this command, device automatically creates an IP FRR BFD session to detect the next hop availability of the primary route. Upon primary route next hop failure, traffic can be immediately switched to the backup route next hop for fast convergence.
·     For inter-protocol FRR, the primary route is the route with the highest preference among the routes to the same destination.
·     For ECMP routes of a routing protocol, the primary route is each ECMP route. If you specify the ecmp-shared keyword when configuring FRR for a routing protocol, the device will use the LFA algorithm to calculate backup next hops for each ECMP route. The routes destined for the backup next hops are also added to the routing table as ECMP routes and the state of these routes is backup. BFD does not detect these backup ECMP routes.
This command takes effect and automatically creates a BFD session only when the primary route exists and a backup next hop is generated for it.
You can execute this command multiple times to change the BFD mode (echo packet mode or control packet mode).
If you do not specify the inter-protocol-frr or protocol-ecmp keyword, the command applies to both inter-protocol FRR and ECMP routes. The command without the inter-protocol-frr and protocol-ecmp keywords takes precedence over that with the inter-protocol-frr or protocol-ecmp keyword. For example, if you have used the primary-path-detect bfd ctrl command, you can use only the following commands to modify or cancel the command configuration:
·     primary-path-detect bfd echo.
·     undo primary-path-detect bfd.
A control-packet-mode BFD session can be successfully established through negotiation between the two ends. To use a control-packet-mode BFD session to detect the primary route next hop availability, you must create a static BFD session that meets the following requirements on the next hop device:
·     Create a single-hop BFD session in control packet mode.
·     The source IP address of the BFD session is the destination IP address of the BFD session automatically created by the local end.
·     The destination IP address of the BFD session is the source IP address of the BFD session automatically created by the local end.
·     The remote discriminator of the BFD session is the local discriminator of the BFD session automatically created by the local end.
The local device can use a control-packet-mode BFD session to detect the primary route next hop only after you create the static BFD session on the primary route next hop device. For more information about creating static BFD sessions, see BFD configuration in High Availability Configuration Guide.
When another protocol (for example, BGP, OSPF, and IS-IS) uses BFD to detect the primary route next hop, it also automatically create a BFD session. If the next hop to be detected is the same as the next hop of the RIB primary route, the device does not repeatedly create the same type of BFD sessions. Instead, the device reuses the BFD session of other protocols.
# Enable control-mode BFD for primary route next hop detection of IS-IS ECMP routes.
[Sysname] rib
[Sysname-rib-ipv4] primary-path-detect bfd ctrl protocol-ecmp isis
fast-reroute
protocol lifetime
Use protocol lifetime to set the maximum lifetime for IPv4 or IPv6 routes in the RIB.
Use undo protocol lifetime to restore the default.
undo protocol protocol [ instance instance-name ] lifetime
The maximum lifetime for IPv4 or IPv6 routes in the RIB is 900 seconds.
seconds: Specifies the maximum lifetime for routes and labels in the RIB, in the range of 1 to 6000 seconds.
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. This argument applies only to the BGP protocol. If you do not specify a BGP instance, this command sets the maximum lifetime for all BGP routes and labels in the RIB.
When GR is enabled, make sure the protocol can complete GR and install all route entries to the RIB within the lifetime configured in this command.
# Set the maximum lifetime for static routes in the RIB to 60 seconds.
[Sysname] rib
[Sysname-rib-ipv4] protocol static lifetime 60
protocol nexthop recursive-lookup
Use protocol nexthop recursive-lookup to configure routing policy-based recursive lookup.
Use undo protocol nexthop recursive-lookup to remove the configuration.
protocol protocol nexthop recursive-lookup route-policy route-policy-name
undo protocol protocol nexthop recursive-lookup route-policy
Routing policy-based recursive lookup is not configured.
protocol: Specifies a routing protocol, which can be bgp or static in RIB IPv4 address family view or bgp4+ in RIB IPv6 address family view.
route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
Configure routing policy-based recursive lookup to control route recursion results. For example, when a route changes, the routing protocol has to perform a route recursion if the next hop is indirectly connected. The routing protocol might select an incorrect path, which can cause traffic loss. To prevent this problem, you can use a routing policy to filter out incorrect routes. The routes that pass the filtering of the routing policy will be used for route recursion.
The apply clauses in the specified routing policy cannot take effect.
Make sure a minimum of one related route can match the routing policy for correct traffic forwarding.
# Configure recursive lookup based on routing policy policy1 for static routes.
[Sysname] rib
[Sysname-rib-ipv4] protocol static nexthop recursive-lookup route-policy policy1
record-limit
Use record-limit to set the maximum number of RIB next hop records or route entry records.
Use undo record-limit to restore the default.
record-limit limit [ rib nib [ flush [ delete | update ] | receive [ add | delete | update ] ] ]
undo record-limit [ rib nib [ flush [ delete | update ] | receive [ add | delete | update ] ] ]
record-limit limit [ routing-table [ flush [ delete | update ] | notify [ delete | update ] | receive [ add | delete | update ] ] ]
undo record-limit [ routing-table [ flush [ delete | update ] | notify [ delete | update ] | receive [ add | delete | update ] ] ]
The maximum number of RIB next hop records or route entry records is 1000.
limit: Sets the maximum number of RIB next hop records or route entry records. The value range is 0 to 10000. To disable recording for RIB next hops or route entries, set the value to 0. When the number of records reaches the maximum number, the system can record new next hops or route entries. However, the new next hop or route entry records overwrite the oldest next hop or route entry records.
rib nib: Sets the maximum number of RIB next hop records.
routing-table: Sets the maximum number of route entry records.
flush: Sets the maximum number of records flushed from RIB to FIB.
notify: Sets the maximum number of records reported by RIB to routing protocols.
receive: Sets the maximum number of records received by RIB from routing protocols.
add: Sets the maximum number of records that contain the add action.
update: Sets the maximum number of records that contain the update action. If you specify the flush or notify keyword, records that contain the add action are also counted into the update category.
delete: Sets the maximum number of records that contain the delete action.
Repeat the command to set the maximum number for different types of records.
If you do not specify the rib nib or routing-table keywords, the command sets the maximum number for all types of RIB next hop and route entry records.
If you do not specify the add, delete, or update keyword, the command sets the maximum number for records that contain the add, delete, and update actions.
# Set the maximum number of next hop records and route entry records to 100 in the IPv4 RIB.
[Sysname] rib
[Sysname-rib-ipv4] record-limit 100
# Set the maximum number of IPv4 route entry records to 200.
[Sysname] rib
[Sysname-rib-ipv4] record-limit 200 routing-table
# Set the maximum number of next hop records that contain the add action to 300. The records are received by IPv4 RIB from routing protocols.
[Sysname] rib
[Sysname-rib-ipv4] record-limit 300 nib receive
# Set the maximum number of route entry records that contain the update action to 400. The records are reported by IPv6 RIB to routing protocols.
[Sysname] rib
[Sysname-rib] address-family ipv6
[Sysname-rib-ipv6] record-limit 400 routing-table notify update
# Set the maximum number of next hop records that contain the delete action to 500. The records are flushed from IPv6 RIB to FIB.
[Sysname] rib
[Sysname-rib-ipv6] record-limit 500 nib flush delete
reset ip routing-table record
Use reset ip routing-table record to clear IPv4 routing entry records.
# Clear IPv4 routing entry records.
<Sysname> reset ip routing-table record
reset ip routing-table statistics protocol
Use reset ip routing-table statistics protocol to clear IPv4 route statistics.
reset ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ip routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command clears IPv4 route statistics for the public network.
all-routes: Clears route statistics for the public network and all VPN instances.
all-vpn-instance: Clears route statistics for all VPN instances.
protocol: Clears route statistics for a routing protocol.
all: Clears route statistics for all IPv4 routing protocols.
This command clears IPv4 route statistics for the public network if you do not specify the all-routes, vpn-instance, or all-vpn-instance keyword.
# Clear all IPv4 route statistics for the public network.
<Sysname> reset ip routing-table statistics protocol all
reset ipv6 rib nib record
Use reset ipv6 rib nib record to clear next hop records in the IPv6 RIB.
# Clear next hop records in the IPv6 RIB.
<Sysname> reset ipv6 rib nib record
reset ipv6 routing-table record
Use reset ipv6 routing-table record to clear IPv6 routing entry records.
# Clear IPv6 routing entry records.
<Sysname> reset ipv6 routing-table record
reset ipv6 routing-table statistics protocol
Use reset ipv6 routing-table statistics protocol to clear IPv6 route statistics.
reset ipv6 routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
reset ipv6 routing-table [ all-routes | all-vpn-instance ] statistics protocol { protocol | all }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command clears the IPv6 route statistics for the public network.
protocol: Clears route statistics for an IPv6 routing protocol.
all: Clears route statistics for all IPv6 routing protocols.
This command clears IPv6 route statistics for the public network if you do not specify the all-routes, vpn-instance, or all-vpn-instance keyword.
# Clear all IPv6 route statistics for the public network.
<Sysname> reset ipv6 routing-table statistics protocol all
reset rib nib record
Use reset rib nib record to clear next hop records in the IPv4 RIB.
# Clear next hop records in the IPv4 RIB.
<Sysname> reset rib nib record
rib
Use rib to enter RIB view.
Use undo rib to remove all configurations in RIB view.
rib
undo rib
# Enter RIB view.
[Sysname] rib
[Sysname-rib]
routing-table limit
Use routing-table limit to set the maximum number of active IPv4/IPv6 routes supported by the device.
Use undo routing-table limit to restore the default.
The maximum number of active IPv4/IPv6 routes is not set for the device.
number: Specifies the maximum number of active IPv4/IPv6 routes supported by the device, in the range of 1 to 4294967295.
warn-threshold: Specifies an alarm threshold in the range of 1 to 100, in percentage. When the percentage of active routes exceeds the alarm threshold, the system generates a system log message but still accepts active routes. You can take relevant actions based on the message to save system resources. If the number of active routes reaches the maximum number, no more routes can be added and new routes are discarded.
simply-alert: Enables the device to still accept active routes but generate a log message when the number of active IPv4/IPv6 routes exceeds the maximum number.
Configuration in RIB IPv4 address family view limits the number of active IPv4 routes for the public network and all VPN instances.
Configuration in RIB IPv6 address family view limits the number of active IPv6 routes for the public network and all VPN instances.
If you execute this command multiple times in the same view, the most recent configuration takes effect.
# In RIB IPv4 address family view, set the maximum number of active IPv4 routes to 1000 for the public network and all VPN instances. The device still accepts new active routes but generates a system log message when the maximum number of active routes is exceeded.
[Sysname] rib
[Sysname-rib-ipv4] routing-table limit 1000 simply-alert
