| 02-Device hardening commands | 35.33 KB |
password-recovery enable
Use password-recovery enable to enable password recovery capability.
Use undo password-recovery enable to disable password recovery capability.
Password recovery capability is enabled.
Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure new passwords.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
Availability of BootWare menu options depends on the password recovery capability setting. For more information, see the release notes.
# Disable password recovery capability.
[Sysname] undo password-recovery enable
The command will disable the password recovery function. Continue? [Y/N]:
usb disable
Use usb disable to disable USB interfaces.
Use undo usb disable to enable USB interfaces.
usb disable
undo usb disable
All USB interfaces are enabled.
You can use USB interfaces to upload or download files. By default, all USB interfaces are enabled.
Before executing this command, use the umount command to unmount all USB file systems.
# Enable USB interfaces.
[Sysname] undo usb disable
