12-Network Management and Monitoring Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S9825 & S9855 Switch Series Configuration Guides-R9126Pxx-6W10012-Network Management and Monitoring Configuration Guide
06-Sampler configuration
06-Sampler configuration 35.68 KB
Configuring samplers
About sampler
A sampler selects a packet from sequential packets and sends the packet to other service modules for processing. Sampling is useful when you want to limit the volume of traffic to be analyzed. The sampled data is statistically accurate and sampling decreases the impact on the forwarding capacity of the device. The random sampling mode is supported, which might select any packet from sequential packets in each sampling.
Creating a sampler
2.     Create a sampler.
sampler sampler-name mode random packet-interval [ n-power ] rate
By default, no samplers exist.
Verifying and maintaining a sampler
To display configuration information about the sampler, execute the following command in any view:
display sampler [ sampler-name ] [ slot slot-number ]
