- 06-Layer 3—IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-Static routing configuration
- 03-OSPF configuration
- 04-IS-IS configuration
- 05-Basic BGP configuration
- 06-Advanced BGP configuration
- 07-Policy-based routing configuration
- 08-IPv6 static routing configuration
- 09-OSPFv3 configuration
- 10-IPv6 policy-based routing configuration
- 11-Routing policy configuration
- 12-DCN configuration
| 00-Preface | 100.24 KB |
Preface
This configuration guide covers the routing technologies for IPv4 and IPv6 networks of different sizes, route filtering, route control, and policy based routing.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S10500X-G switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
