H3C?Servers Whitley & Cedar Island Platform Scenario-Based BIOS Configuration Guide-6W101
HomeSupportConfigure & DeployUser ManualsH3C?Servers Whitley & Cedar Island Platform Scenario-Based BIOS Configuration Guide-6W101
01-Text
01-Text 393.53 KB
Overview·· 1
About the BIOS· 1
Applicable products· 1
Applicable versions· 1
Using this document 1
Recommended BIOS settings· 3
About recommended BIOS settings· 3
BIOS parameters for different workload modes· 3
Introduction to workload modes· 7
Fixed Turbo Frequency· 7
Application scenarios· 7
Configuration instructions· 7
General Peak Frequency Compute· 7
Low Latency· 7
High Performance Compute· 8
Application scenarios· 8
Configuration instructions· 8
General Power Efficient Compute· 8
Virtualization-Power Efficient 8
Virtualization-Performance· 8
Configuration instructions· 9
Advanced Reliability Mode· 9
Application scenarios· 9
Transactional Application Processing· 9
General Throughput Compute· 9
Graphic Processing· 9
Configuration instructions· 10
IO Throughput 10
Application scenarios· 10
Custom·· 10
Configuring a workload profile· 11
Entering the BIOS setup utility· 11
Accessing the Miscellaneous Configuration submenu· 13
Selecting a workload profile· 14
Restarting the server 15
Overview
To meet the diverse needs of users in different workload modes, this document describes the configuration guide for setting BIOS parameters based on the services running on the server. It also describes the application scenarios and configuration instructions for the related workload modes."
About the BIOS
The Basic Input and Output System (BIOS) is a non-volatile firmware stored in the system ROM of a server. It is used to perform hardware initialization during server booting and provide runtime services for the operating systems. As shown in Figure 1, the BIOS interacts between the server hardware and the operating system (OS).
Figure 1 Layered architecture of a server system
Applicable products
This document is applicable to the following products:
·     H3C UniServer B5700 G5
·     H3C UniServer R4300 G5
·     H3C UniServer R4700 G5
·     H3C UniServer R4900 G5
·     H3C UniServer R4900LC G5
·     H3C UniServer R5300 G5
·     H3C UniServer R5500 G5 Intel
·     H3C UniServer R6900 G5
Applicable versions
The BIOS version applicable to this document is BIOS-5.XX.
Using this document
The information in this document is subject to change over time. You can access the H3C website to obtain the most recent version of the BIOS.
The information in this document might differ from your product if it contains custom configuration options or features.
A workload profile is a set of configuration options to deploy BIOS settings for server applications. The BIOS provides several profiles to match the selected workload. You can find the Workload Profile Configuration item from the Advanced > Miscellaneous Configuration screen. The pre-configured parameter values in a profile are recommended values applicable to the corresponding scenario.
The BIOS parameter configurations recommended for different workload modes are shown in Table 1 and Table 2, which are the workload profile dependencies matrixes. An "X" means that the option setting has no requirement for the profile and can be modified. By default, "X" uses the default value of the corresponding device model and the default value varies by device model. When you apply a new profile to the device, the value of "X" will be restored to the default.
Not all the options listed are shown on the BIOS. However, the options of profiles default to the values shown here.
For information about application scenarios and configuration of different workload modes, see "Introduction to workload modes."
Table 1 Workload profile dependencies matrix
Dependency
Low Latency
Hyper-Threading [ALL]
Enabled
Enabled
Disabled
X
Enabled
Enabled
Hardware Prefetcher
Disabled
Enabled
Enabled
X
Enabled
Enabled
Adjacent Cache Prefetch
Disabled
Enabled
Enabled
X
Enabled
Enabled
DCU Streamer Prefetcher
Disabled
Enabled
Enabled
X
Enabled
Enabled
DCU IP Prefetcher
Disabled
Enabled
Enabled
X
Enabled
Enabled
LLC Prefetch
Enabled
Enabled
Enabled
X
Enabled
Disabled
XPT Prefetcher
Enabled
Enabled
Enabled
X
Enabled
Disabled
EIST (P-States)
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Energy Efficient Turbo
Enabled
Disabled
Disabled
Disabled
Disabled
Disabled
Turbo Mode
Disabled
Enabled
Enabled
Enabled
Enabled
Disabled
Hardware P-States
Native Mode
Disabled
Disabled
Out of Band Mode
Disabled
Disabled
EPP profile
X
X
X
Performance
X
X
Enable Monitor MWAIT
Enabled
Disabled
Disabled
Disabled
Disabled
Disabled
CPU C6 Report/report
Enabled
Disabled
Disabled
Disabled
Disabled
Disabled
Enhanced Halt State (C1E)
Enabled
Disabled
Disabled
Disabled
Disabled
Disabled
Package C State
C6(non Retention) state
C0/C1 state
C0/C1 state
X
C0/C1 state
C0/C1 state
Power Performance Tuning
BIOS Controls EPB
OS Controls EPB
OS Controls EPB
X
OS Controls EPB
OS Controls EPB
ENERGY_PERF_BIAS_CFG mode
Power
X
X
X
X
X
VMX
Enabled
Enabled
Disabled
X
Disabled
X
Intel VT for Directed I/O
Enabled
Enabled
Disabled
X
Disabled
X
SR-IOV Support
Enabled
Enabled
Disabled
X
Disabled
X
Numa
Enabled
Enabled
Enabled
X
Enabled
Enabled
SNC (Sub NUMA)
Disabled
Enable SNC2 (2-clusters) - G5 2P
Enabled - G5 4P
Enabled - G5 4P
X
Enabled - G5 4P
Disabled
ADDDC Sparing
X
X
X
X
X
X
Patrol Scrub
X
X
X
X
X
X
Note: The Virtualization-Performance profile requires Enable Monitor MWAIT option to be set to Enabled when using it in a VMware EVC mode scenario.
Table 2 Workload profile dependencies matrix (2)
Dependency
Graphic Processing
IO Throughput
Enabled
Enabled
Disabled
Enabled
Enabled
Disabled
Hardware Prefetcher
Disabled
Enabled
Disabled
Enabled
Enabled
Disabled
Disabled
Enabled
Disabled
Enabled
Enabled
Disabled
Disabled
Enabled
Disabled
Enabled
Enabled
Disabled
DCU IP Prefetcher
Disabled
Enabled
Disabled
Enabled
Enabled
Disabled
LLC Prefetch
Enabled
Enabled
Enabled
Disabled
Enabled
Enabled
XPT Prefetcher
Enabled
Enabled
Enabled
Disabled
Enabled
Enabled
EIST (P-States)
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
Disabled
Enabled
X
Disabled
Enabled
Turbo Mode
Disabled
Enabled
Disabled
Enabled
Enabled
Disabled
Hardware P-States
Native Mode
Disabled
Disabled
Disabled
Disabled
Disabled
EPP profile
X
X
X
X
X
X
Enabled
Disabled
Disabled
Disabled
Disabled
Disabled
Enabled
Disabled
Disabled
Disabled
Disabled
Enabled
Enabled
Disabled
Disabled
Disabled
Disabled
Enabled
Package C State
C0/C1 state
C0/C1 state
C0/C1 state
C0/C1 state
C0/C1 state
BIOS Controls EPB
OS Controls EPB
OS Controls EPB
OS Controls EPB
OS Controls EPB
OS Controls EPB
Power
X
X
X
X
X
VMX
Disabled
Disabled
Enabled
X
Disabled
Enabled
Disabled
Disabled
Enabled
X
Disabled
Enabled
SR-IOV Support
Disabled
Disabled
Enabled
X
Disabled
Enabled
Numa
Enabled
Enabled
Enabled
Enabled
Enabled
Enabled
SNC (Sub NUMA)
Disabled
Enabled - G5 4P
Enabled - G5 4P
Disabled
Enabled - G5 4P
Enabled - G5 4P
ADDDC Sparing
X
X
X
Enabled
X
X
Patrol Scrub
X
X
X
Enabled
X
X
The following information describes the application scenarios and configuration instructions of workload profile for different workload modes.
The BIOS configuration schemes for different application scenarios are for general use. You configure the settings as needed.
The Fixed Turbo Frequency profile enables all present processors to operate at the Turbo frequency through out-of-band management.
The operating system does not participate in frequency adjustment.
The General Peak Frequency Compute profile is intended for scenarios that do not require high overall system performance.
By disabling Turbo boost, this profile allows the operating system to control frequency adjustment for the system to operate at the CPU base frequency.
Low Latency
The Low Latency profile is intended to be used in latency-sensitive environments, such as a system featuring a large data volume, real-time service monitoring, and extensive message spreading.
This type of systems requires quick responses to maximize the real-time value of data. By disabling power saving and hyper-threading that might introduce computational latency, this profile allows the operating system to control frequency so that the system can operate at the Turbo frequency.
The High Performance Compute profile is intended for intensive computing scenarios.
This profile is similar to the low latency profile but is mostly used to process concurrent tasks. As a best practice, enable hyper-threading. By disabling power saving, this profile enables the operating system to control frequency adjustment for the system to operate at the Turbo frequency.
The General Power Efficient Compute profile is intended for scenarios that have high power consumption.
This profile is similar to the virtualization-power efficient profile but virtualization-related options are disabled. In this profile, power saving is enabled and CPU cores can enter sleep mode, which increases latency and causes performance degrade in case of processor mode change.
The Virtualization-Power Efficient profile is intended to be used for virtualization environments and scenarios that have strict power consumption requirements.
The profile enables all virtualization-related options. By enabling power saving, the profile manages to maintain the system power consumption to a low level in idle state at the cost of high speed.
The Virtualization-Performance profile is intended to be used in virtualization environments that require high performance.
The profile enables all virtualization-related options. By disabling power saving, the profile allows the system to operate at a high speed and a high frequency.
The Advanced Reliability Mode profile is intended for scenarios that require high system stability and maintainability.
By enabling advanced RAS features and disabling power saving, this profile shortens the response time for system errors. As a best practice, use x4 memory chips.
The Transactional Application Processing profile is intended to be used for upper-layer service application scenarios such as database systems.
The profile configuration is the same as the HPC profile settings, which is applicable to most scenarios. If the service data are random and the data set has a large volume, disable prefetch options and NUMA to facilitate application service execution as a best practice.
The General Throughput Compute profile is intended to be used for workloads where the total maximum sustained workload throughput is needed.
By disabling prefetch options and Turbo boost, this profile reduces the processor idle cycles caused by waiting, balances peak frequency management and throughput, and improves I/O throughput.
Graphic Processing
The Graphic Processing profile is intended for workloads that are run on servers installed with GPUs.
The profile configuration is similar to the HPC profile settings, which is applicable to most scenarios. By disabling virtualization, this profile improves the processor core frequency, which enhances data processing ability and improves system performance.
IO Throughput
The IO Throughput profile is intended for workloads that require improved IO and memory throughput.
This is achieved by disabling prefetch options, turning off turbo boost, enabling some power-saving options, reducing the number of stalled cycles caused by CPU waiting, balancing peak frequency management, and throughput requirements. The end result is improved IO and memory throughput.
Custom
The Custom profile uses the default BIOS settings.
If you select this profile, the system loads the default BIOS settings and you can modify the settings as needed. For information about the default settings, see the BIOS user guide.
1.     Connect a keyboard, a mouse, and a monitor to the server or enable the remote console from the HDM Web interface.
For information about enabling the remote console, see H3C Servers HDM User Guide.
2.     Start or restart the server.
3.     Press Del or Esc when the BIOS startup screen opens, as shown in Figure 2.
Figure 2 BIOS setup screen
4.     Enter the BIOS password if required during boot-up, as shown in Figure 3.
Figure 3 Entering the power on password
5.     (Optional.) If you have set a BIOS administrator password and a user password, select the role before entering BIOS setup, as shown in Figure 4.
Figure 4 Selecting a role to enter setup
6.     Enter the password of the selected role, as shown in Figure 5.
Figure 5 Entering the BIOS password
As shown in Figure 6, the BIOS setup utility screen opens.
Figure 6 BIOS setup utility screen
On the BIOS setup utility, click the Advanced tab, select Miscellaneous Configuration, and then press Enter, as shown in Figure 7.
Figure 7 Miscellaneous Configuration submenu screen
As shown in Figure 8, select a workload profile from the Workload Profile Configuration drop-down list.
Figure 8 Selecting a workload profile
After the configuration, press F4. In the dialog box that opens, select Ok to save the configuration and exit the BIOS. The configuration will take effect after the server restarts.
