- 04-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-Policy-based routing commands
- 06-IPv6 static routing commands
- 07-RIPng commands
- 08-OSPFv3 commands
- 09-IPv6 policy-based routing commands
- 10-Routing policy commands
| 00-Preface | 100.54 KB |
Preface
· This command reference describes the routing configuration commands.
· CLI.
· RBAC, device login, and device access control.
· Management of the device, file systems, and configuration files.
· FTP and TFTP.
· Software upgrade.
· Tcl and Python.
· Automatic configuration.
· Audience
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
