- 09-Security Command Reference
- 01-AAA commands
- 02-802.1X commands
- 03-MAC authentication commands
- 04-Portal commands
- 05-Web authentication commands
- 06-Port security commands
- 07-Password control commands
- 08-Keychain commands
- 09-Public key management commands
- 10-PKI commands
- 11-IPsec commands
- 12-SSH commands
- 13-SSL commands
- 14-Attack detection and prevention commands
- 15-TCP attack prevention commands
- 16-IP source guard commands
- 17-ARP attack protection commands
- 18-ND attack defense commands
- 19-uRPF commands
- 20-MFF commands
- 21-FIPS commands
- 22-MACsec commands
- 23-802.1X client commands
20-MFF commands | 61.19 KB |
display mac-forced-forwarding interface
display mac-forced-forwarding vlan
mac-forced-forwarding gateway probe
mac-forced-forwarding network-port
MFF commands
Use display mac-forced-forwarding interface to display MFF port configuration.
# Display MFF port configuration.
<Sysname> display mac-forced-forwarding interface
Network Port:
GE1/0/1 GE1/0/2
User Port:
GE1/0/3 GE1/0/4 GE1/0/5
Network Port |
List of network ports. |
User Port |
List of user ports. |
Use display mac-forced-forwarding vlan to display the MFF configuration for a VLAN.
display mac-forced-forwarding vlan vlan-id
vlan-id: Specifies a VLAN by its ID.
# Display the MFF configuration for VLAN 2.
<Sysname> display mac-forced-forwarding vlan 2
VLAN 2
Gateway:
192.168.1.42 000f-e200-8046
Server:
192.168.1.48 192.168.1.49
VLAN 2 |
ID of the VLAN to which the gateways belong. |
Gateway |
IP and MAC addresses of gateways. If no address is learned, this field displays N/A. |
Server |
Server IP addresses. |
mac-forced-forwarding server
Use mac-forced-forwarding to enable MFF and specify the default gateway.
Use undo mac-forced-forwarding to disable MFF.
mac-forced-forwarding default-gateway gateway-ip
MFF is disabled.
VLAN view
default-gateway gateway-ip: Specifies the IP address of the default gateway.
For MFF to take effect, make sure ARP snooping is enabled on the VLAN where MFF is enabled.
For a network (or VLAN) with IP addresses manually configured, the gateway IP address must be manually configured. MFF checks for and denies only all-zero and all-one gateway IP addresses.
# Enable MFF for VLAN 2 and specify the IP address of the default gateway.
[Sysname] vlan 2
[Sysname-vlan2] mac-forced-forwarding default-gateway 1.1.1.1
Use mac-forced-forwarding gateway probe to enable periodic gateway probe.
Use undo mac-forced-forwarding gateway probe to disable periodic gateway probe.
Periodic gateway probe is disabled.
VLAN view
Make sure you have enabled MFF before enabling periodic gateway probe. The probe interval is 30 seconds.
# Enable periodic gateway probe.
[Sysname] vlan 2
[Sysname-vlan2] mac-forced-forwarding gateway probe
Use mac-forced-forwarding network-port to configure the Ethernet port as a network port.
Use undo mac-forced-forwarding network-port to restore the default.
The Ethernet port is a user port.
You should configure the following ports as network ports:
· Upstream ports connected to a gateway.
· Ports connected to the MFF devices in a cascaded network (a network with multiple MFF devices connected to one another).
· Ports between devices in a ring network.
You can configure multiple ports as network ports.
You can configure a port as a network port regardless of whether MFF is enabled for the VLAN of the port. However, the configuration takes effect only after MFF is enabled.
Link aggregation is supported by network ports in an MFF-enabled VLAN, but is not supported by user ports in the VLAN. To cancel the network port configuration of a link aggregation member port in a MFF-enabled VLAN, remove the network port from the link aggregation group first. For more information about link aggregation, see Layer 2—LAN Switching Configuration Guide.
# Configure GigabitEthernet 1/0/1 as a network port.
[Sysname-GigabitEthernet1/0/1] mac-forced-forwarding network-port
Use mac-forced-forwarding server to specify the IP addresses of servers.
Use undo mac-forced-forwarding server to remove server IP addresses.
mac-forced-forwarding server server-ip&<1-10>
undo mac-forced-forwarding server server-ip&<1-10>
No server IP address is specified.
VLAN view
server-ip&<1-10>: Specifies a space-separated list of up to 10 server IP addresses.
You need to maintain a server list on the MFF device to ensure communication between the servers and clients.
Server IP addresses can be those of the interfaces on a router in a VRRP group and those of the servers collaborating with MFF, such as a RADIUS server.
When the MFF device receives an ARP request from a server, it searches the IP-to-MAC address entries it has stored. Then the device replies with the requested MAC address to the server.
In this way, packets from the server to a host are not forwarded by the gateway. However, packets from a host to the server are forwarded by the gateway.
MFF does not check whether the IP address of a server is on the same network segment as that of a gateway. Instead, it checks whether the IP address of a server is all-zero or all-one. An all-zero or all-one server IP address is invalid.
Make sure MFF is enabled before you execute the mac-forced-forwarding server command.
# Specify the server at 192.168.1.100.
[Sysname] vlan 2
[Sysname-vlan2] mac-forced-forwarding server 192.168.1.100
