01-Fundamentals Command Reference
HomeSupportSwitchesS5590-EI SeriesReference GuidesCommand ReferencesH3C S5590-HI[S5590-EI][S5500V3-HI] Switch Series Command References-R8108Pxx-6W10001-Fundamentals Command Reference
10-Automatic configuration commands
10-Automatic configuration commands 32.37 KB
autodeploy udisk enable
Use autodeploy udisk enable to enable USB-based automatic configuration.
Use undo autodeploy udisk enable to disable USB-based automatic configuration.
USB-based automatic configuration is enabled.
This command is supported only if the device has a USB interface.
# Disable USB-based automatic configuration.
[Sysname] undo autodeploy udisk enable
