05-Interface
HomeSupportReference GuidesMIB CompanionH3C S5590-EI S5130S-G FS5500-EI FS5500V2-EI S6530X Switch Series MIB Reference-6W10105-Interface
04-HH3C-IF-EXT-MIB
04-HH3C-IF-EXT-MIB 305.39 KB
HH3C-IF-EXT-MIB
About this MIB
Use this MIB to manage and describe interfaces.
MIB file name
hh3c-if-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIfExt(40)
Scalar objects
hh3cIfStatGlobalFlowInterval
Object (OID)
Access
Value range
Implementation
hh3cIfStatGlobalFlowInterval (1.3.6.1.4.1.25506.2.40.1.1)
read-write
Integer32
Integer32(0..2147483647)
Global statistics polling interval. 0 indicates the traffic statistics collection feature is disabled.
Not supported
hh3cIfShutDownInterval
Object (OID)
Access
Value range
Implementation
hh3cIfShutDownInterval (1.3.6.1.4.1.25506.2.40.1.2)
read-write
Integer32
Integer32(1..2147483647)
Port status detection timer.
0..300
hh3cIfPhysicalNumber
Object (OID)
Access
Value range
Implementation
hh3cIfPhysicalNumber (1.3.6.1.4.1.25506.2.40.2.3.1)
read-only
Integer32
Number of physical interfaces on the device.
As per the MIB.
Tabular objects
hh3cIfFlowStatTable
About this table
Use this table to obtain the interface traffic information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfStatFlowInterval.
Object (OID)
Access
Value range
Implementation
hh3cIfStatFlowInterval (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.1)
read-write
Integer32
Traffic statistics polling interval.
Supported.
hh3cIfStatFlowInBits (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.2)
read-only
Unsigned32
Unsigned32 (0..4294967295)
Incoming traffic in bits.
As per the MIB.
hh3cIfStatFlowOutBits (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.3)
read-only
Unsigned32
Outgoing traffic in bits.
As per the MIB.
hh3cIfStatFlowInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.4)
read-only
Unsigned32
Incoming traffic in packets.
As per the MIB.
hh3cIfStatFlowOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.5)
read-only
Unsigned32
Outgoing traffic in packets.
As per the MIB.
hh3cIfStatFlowInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.6)
read-only
Unsigned32
Incoming traffic in bytes.
As per the MIB.
hh3cIfStatFlowOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.1.1.7)
read-only
Unsigned32
Outgoing traffic in bytes.
As per the MIB.
hh3cIfSpeedStatTable
About this table
Use this table to obtain the interface traffic speed statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfSpeedStatInterval.
Object (OID)
Access
Value range
Implementation
hh3cIfSpeedStatInterval (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.1)
read-only
Integer32
Interface traffic speed statistics polling interval. 0 indicates the interface traffic speed statistics collection feature is disabled.
Supported.
hh3cIfSpeedStatInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.2)
read-only
Unsigned32
Average incoming traffic speed (in pps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval.
As per the MIB.
hh3cIfSpeedStatOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.3)
read-only
Unsigned32
Average outgoing traffic speed (in pps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval.
As per the MIB.
hh3cIfSpeedStatInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.4)
read-only
Unsigned32
Average incoming traffic speed (in Bps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval.
As per the MIB.
hh3cIfSpeedStatOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.2.1.5)
read-only
Unsigned32
Average outgoing traffic speed (in Bps) of the interface within the specified interval before the latest sampling point. The interval is specified by h3cIfSpeedStatInterval.
As per the MIB.
hh3cIfSpeedStatInBits
(1.3.6.1.4.1.25506.2.40.2.1.2.2.1.6)
read-only
Unsigned32
Average of input bits per second (32-bit).
As per the MIB.
hh3cIfSpeedStatOutBits
(1.3.6.1.4.1.25506.2.40.2.1.2.2.1.7)
read-only
Unsigned32
Average of output bits per second (32-bit).
As per the MIB.
hh3cIfHCFlowStatTable
About this table
Use this table to obtain the 64-bit traffic information of interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfStatFlowHCInBits.
Object (OID)
Access
Value range
Implementation
hh3cIfStatFlowHCInBits (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.1)
read-only
CounterBasedGauge64
Counter64 (0..18446744073709551615)
Incoming traffic in bits (64-bit version).
As per the MIB.
hh3cIfStatFlowHCOutBits (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.2)
read-only
CounterBasedGauge64
Outgoing traffic in bits (64-bit version).
As per the MIB.
hh3cIfStatFlowHCInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.3)
read-only
CounterBasedGauge64
Incoming traffic in packets (64-bit version).
As per the MIB.
hh3cIfStatFlowHCOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.4)
read-only
CounterBasedGauge64
Outgoing traffic in packets (64-bit version).
As per the MIB.
hh3cIfStatFlowHCInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.5)
read-only
CounterBasedGauge64
Incoming traffic in bytes (64-bit version).
As per the MIB.
hh3cIfStatFlowHCOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.3.1.6)
read-only
CounterBasedGauge64
Outgoing traffic in bytes (64-bit version).
As per the MIB.
hh3cRTParentIfTable
About this table
Use this table to obtain main interface information of subinterfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cRTParentIfIndex.
Object (OID)
Access
Value range
Implementation
hh3cRTParentIfIndex (1.3.6.1.4.1.25506.2.40.2.2.1.1.1)
not-accessible
Integer32
Main interface index. Index of the interface for which you can create subinterfaces.
As per the MIB.
hh3cRTMinSubIfOrdinal (1.3.6.1.4.1.25506.2.40.2.2.1.1.2)
read-only
Integer32
Minimum number of the subinterface that can be created.
As per the MIB.
hh3cRTMaxSubIfOrdinal (1.3.6.1.4.1.25506.2.40.2.2.1.1.3)
read-only
Integer32
Maximum number of the subinterface that can be created.
As per the MIB.
hh3cRTSubIfTable
About this table
Use this table to obtain information about subinterface information of main interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cRTSubIfParentIfIndex.
Object (OID)
Access
Value range
Implementation
hh3cRTSubIfParentIfIndex (1.3.6.1.4.1.25506.2.40.2.2.2.1.1)
not-accessible
Integer32
As per the MIB.
hh3cRTSubIfOrdinal (1.3.6.1.4.1.25506.2.40.2.2.2.1.2)
not-accessible
Integer32
Subinterface number.
As per the MIB.
hh3cRTSubIfSubIfIndex (1.3.6.1.4.1.25506.2.40.2.2.2.1.3)
read-only
Integer32
Subinterface index.
As per the MIB.
hh3cRTSubIfSubIfDesc (1.3.6.1.4.1.25506.2.40.2.2.2.1.4)
read-only
DisplayString
OCTET STRING(0..255)
Subinterface description.
As per the MIB.
hh3cRTSubIfRowStatus (1.3.6.1.4.1.25506.2.40.2.2.2.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Subinterface state.
Available values are active(1), createAndGo(4), and destroy(6).
hh3cIfLinkModeTable
About this table
Use this table to obtain the interface link mode.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfLinkModeIndex.
Object (OID)
Access
Value range
Implementation
hh3cIfLinkModeIndex (1.3.6.1.4.1.25506.2.40.2.2.3.1.1)
not-accessible
Integer32
1..2147483647
Link mode index.
As per the MIB.
hh3cIfLinkMode (1.3.6.1.4.1.25506.2.40.2.2.3.1.2)
read-write
INTEGER
bridgeMode(1),
routeMode(2)
Current link mode of the interface.
As per the MIB.
hh3cIfLinkModeSwitchSupport (1.3.6.1.4.1.25506.2.40.2.2.3.1.3)
read-only
TruthValue
true(1),
false(2)
Whether the link mode of the interface can be switched.
As per the MIB.
hh3cIfPortTypeTable
About this table
Use this table to obtain the port type of an interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfPortTypeIndex.
Object (OID)
Access
Value range
Implementation
hh3cIfPortTypeIndex (1.3.6.1.4.1.25506.2.40.2.2.4.1.1)
not-accessible
Integer32
Interface index, which is the same as ifIndex in ifTable.
As per the MIB.
hh3cIfPortType (1.3.6.1.4.1.25506.2.40.2.2.4.1.2)
read-write
INTEGER
other(1),ethernet(2),fc(3)
Ethernet/ FC mode of an interface.
As per the MIB.
hh3cIfTable
About this table
Use this table to obtain interface-related information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfUpDownTimes.
Object (OID)
Access
Value range
Implementation
hh3cIfUpDownTimes (1.3.6.1.4.1.25506.2.40.2.3.2.1.1)
read-only
Integer32
Number of interface up/down events.
As per the MIB.
hh3cIfMtu (1.3.6.1.4.1.25506.2.40.2.3.2.1.2)
read-write
Integer32
Interface MTU.
As per the MIB.
hh3cIfBandwidthRate (1.3.6.1.4.1.25506.2.40.2.3.2.1.3)
accessible-for-notify
Integer32
Interface bandwidth.
Not supported
hh3cIfDiscardPktRate (1.3.6.1.4.1.25506.2.40.2.3.2.1.4)
Integer32
Packet loss rate of an interface.
Not supported
hh3cIfStatusKeepTime (1.3.6.1.4.1.25506.2.40.2.3.2.1.5)
read-only
TimeTicks
TimeTicks (0..4294967295)
Duration of the current interface state.
As per the MIB.
hh3cIfInNUcastPkts (1.3.6.1.4.1.25506.2.40.2.3.2.1.6)
read-only
Integer32
Number of incoming non-unicast packets.
Not supported
hh3cIfOutNUcastPkts (1.3.6.1.4.1.25506.2.40.2.3.2.1.7)
read-only
Integer32
Number of outgoing non-unicast packets.
Not supported
hh3cIfIsPoe (1.3.6.1.4.1.25506.2.40.2.3.2.1.8)
read-only
TruthValue
true(1),
false(2)
Support for PoE on an interface.
Not supported
hh3cIfOperStatus (1.3.6.1.4.1.25506.2.40.2.3.2.1.9)
read-only
INTEGER
up(1),
down(2),
testing(3),
admindown(4)
Operational state of an interface.
Not supported
hh3cIfDownTimes (1.3.6.1.4.1.25506.2.40.2.3.2.1.10)
read-only
Integer32
Number of link-down events.
Not supported
hh3cIfPfcStatus (1.3.6.1.4.1.25506.2.40.2.3.2.1.11)
read-write
INTEGER
enable(1),
disable(2),
auto(3)
PFC mode of an interface.
Supported.
hh3cIfPfcDot1pNoDrop (1.3.6.1.4.1.25506.2.40.2.3.2.1.12)
read-write
BITS
pri0(0), pri1(1), pri2(2), pri3(3), pri4(4), pri5(5), pri6(6), pri7(7)
802.1p priority list for PFC on an interface.
Supported.
hh3cIfDescription (1.3.6.1.4.1.25506.2.40.2.3.2.1.13)
read-write
DisplayString
Description of an interface.
As per the MIB.
hh3cIfFwdErrDiscards
(1.3.6.1.4.1.25506.2.40.2.3.2.1.14)
read-only
Unsigned32
Number of packets dropped because of forwarding entry errors on an interface.
Supported.
hh3cIfUsingTable
About this table
Use this table to obtain information about breakout interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfUsingIndex.
Object (OID)
Access
Value range
Implementation
hh3cIfUsingIndex (1.3.6.1.4.1.25506.2.40.2.3.4.1)
not-accessible
Integer32
Index of an interface that can be split or combined.
As per the MIB.
hh3cIfUsingSupportType (1.3.6.1.4.1.25506.2.40.2.3.4.2)
read-only
Integer32
Interface type that an interface can be split or combined into.
As per the MIB.
hh3cIfUsingType (1.3.6.1.4.1.25506.2.40.2.3.4.3)
read-write
INTEGER
noUsing(0),
using10GE(1),
using20GE(2),
using40GE(3),
using100GE(4),
using25GE(5),
using50GE(6)
Interface type that an interface will be split or combined into.
As per the MIB.
hh3cIfUsingStatus (1.3.6.1.4.1.25506.2.40.2.3.4.4)
read-only
INTEGER
noUsing(0),
needReboot(1)
State of the splitting or combining operation.
As per the MIB.
hh3cIfQueBufferTable
About this table
Use this table to obtain the interface buffer information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfQueId.
Object (OID)
Access
Value range
Implementation
hh3cIfQueId
(1.3.6.1.4.1.25506.2.40.2.2.6.1.1)
read-only
INTEGER
que0(1),
que1(2),
que2(3),
que3(4),
que4(5),
que5(6),
que6(7),
que7(8)
ID of an interface buffer queue.
As per the MIB.
hh3cIfQueOutUcastTotal
(1.3.6.1.4.1.25506.2.40.2.2.6.1.2)
read-only
Unsigned32
Total buffer of an outbound unicast queue.
As per the MIB.
hh3cIfQueOutUcastFree
(1.3.6.1.4.1.25506.2.40.2.2.6.1.3)
read-only
Unsigned32
Available buffer of an outbound unicast queue.
As per the MIB.
hh3cIfQueOutUcastUsedRatio
(1.3.6.1.4.1.25506.2.40.2.2.6.1.4)
read-only
Unsigned32
Buffer usage of an outbound unicast queue.
As per the MIB.
hh3cIfQueOutUcastUsedPeak
(1.3.6.1.4.1.25506.2.40.2.2.6.1.5)
read-only
Unsigned32
Peak buffer usage of an outbound unicast queue.
As per the MIB.
hh3cIfQueOutUcastThreshold
(1.3.6.1.4.1.25506.2.40.2.2.6.1.6)
read-only
Unsigned32
Buffer alarm threshold of an outbound unicast queue.
As per the MIB.
hh3cIfQueOutUcastOverThres
(1.3.6.1.4.1.25506.2.40.2.2.6.1.7)
read-only
Unsigned32
Number of buffer usage alarms of an outbound unicast queue.
As per the MIB.
hh3cIfQueInTotal
(1.3.6.1.4.1.25506.2.40.2.2.6.1.8)
read-only
Unsigned32
Total buffer of an inbound unicast queue.
As per the MIB.
hh3cIfQueInFree
(1.3.6.1.4.1.25506.2.40.2.2.6.1.9)
read-only
Unsigned32
Available buffer of an inbound unicast queue.
As per the MIB.
hh3cIfQueInUsedRatio
(1.3.6.1.4.1.25506.2.40.2.2.6.1.10)
read-only
Unsigned32
Buffer usage of an inbound unicast queue.
As per the MIB.
hh3cIfQueInUsedPeak
(1.3.6.1.4.1.25506.2.40.2.2.6.1.11)
read-only
Unsigned32
Peak buffer usage of an inbound unicast queue.
As per the MIB.
hh3cIfQueInThreshold
(1.3.6.1.4.1.25506.2.40.2.2.6.1.12)
read-only
Unsigned32
Buffer alarm threshold of an inbound unicast queue.
As per the MIB.
hh3cIfQueInOverThres
(1.3.6.1.4.1.25506.2.40.2.2.6.1.13)
read-only
Unsigned32
Number of buffer usage alarms of an inbound unicast queue.
As per the MIB.
hh3cIfQueInHeadRoomTotal
(1.3.6.1.4.1.25506.2.40.2.2.6.1.14)
read-only
Unsigned32
Total headroom of an inbound queue.
As per the MIB.
hh3cIfQueInHeadRoomFree
(1.3.6.1.4.1.25506.2.40.2.2.6.1.15)
read-only
Unsigned32
Available headroom of an inbound queue.
As per the MIB.
hh3cIfQueInHeadRoomUsedRatio
(1.3.6.1.4.1.25506.2.40.2.2.6.1.16)
read-only
Unsigned32
Headroom usage of an inbound queue.
As per the MIB.
hh3cIfQueInHeadRoomUsedPeak
(1.3.6.1.4.1.25506.2.40.2.2.6.1.17)
read-only
Unsigned32
Peak headroom usage of an inbound unicast queue.
As per the MIB.
hh3cIfHCSpeedStatTable
About this table
Use this table to obtain the 64-bit packet statistics of an interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfSpeedStatHCInPkts.
Object (OID)
Access
Value range
Implementation
hh3cIfSpeedStatHCInPkts (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.1)
read-only
CounterBasedGauge64
Average incoming traffic speed (in packets) of the interface within the specified interval before the latest sampling point.
As per the MIB.
hh3cIfSpeedStatHCOutPkts (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.2)
read-only
CounterBasedGauge64
Average outgoing traffic speed (in packets) of the interface within the specified interval before the latest sampling point.
As per the MIB.
hh3cIfSpeedStatHCInBytes (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.3)
read-only
CounterBasedGauge64
Average incoming traffic speed (in bytes) of the interface within the specified interval before the latest sampling point.
As per the MIB.
hh3cIfSpeedStatHCOutBytes (1.3.6.1.4.1.25506.2.40.2.1.2.4.1.4)
read-only
CounterBasedGauge64
Average outgoing traffic speed (in bytes) of the interface within the specified interval before the latest sampling point.
As per the MIB.
hh3cIfSpeedStatHCInBits
(1.3.6.1.4.1.25506.2.40.2.1.2.4.1.5)
read-only
CounterBasedGauge64
Average incoming traffic speed (in bits) of the interface within the specified interval before the latest sampling point.
As per the MIB.
hh3cIfSpeedStatHCOutBits
(1.3.6.1.4.1.25506.2.40.2.1.2.4.1.6)
read-only
CounterBasedGauge64
Average outgoing traffic speed (in bits) of the interface within the specified interval before the latest sampling point.
As per the MIB.
hh3cIfExtTrapCfgTable
About this table
Use this table to obtain information about the interface bandwidth and packet loss rate.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfBandwidthUpperLimit.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.40.3.1.1.1.1)
read-write
Integer32
Upper limit of the interface bandwidth.
Not supported
hh3cIfDiscardPktRateUpperLimit
(1.3.6.1.4.1.25506.2.40.3.1.1.1.2)
read-write
Integer32
Upper limit of the interface packet loss rate.
Not supported
hh3cIfMonStatTable
About this table
Use this table to obtain the interface bandwidth usage statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfMonInputRateStatistics.
Object (OID)
Access
Value range
Implementation
hh3cIfMonInputUsageStatistics (1.3.6.1.4.1.25506.2.40.5.1.1.1)
read-only
Unsigned32
Inbound bandwidth usage statistics.
This object can only be reported.
hh3cIfMonOutputUsageStatistics (1.3.6.1.4.1.25506.2.40.5.1.1.2)
read-only
Unsigned32
Outbound bandwidth usage statistics.
hh3cIfMonInputErrorAlarmStatistics
(1.3.6.1.4.1.25506.2.40.5.1.1.3)
read-only
Counter64
Inbound error alarm statistics.
hh3cIfMonOutputErrorAlarmStatistics
(1.3.6.1.4.1.25506.2.40.5.1.1.4)
read-only
Counter64
Outbound error alarm statistics.
hh3cIfMonSdhErrorStatistics
(1.3.6.1.4.1.25506.2.40.5.1.1.5)
read-only
Counter64
SDH error statistics.
hh3cIfMonSdhB1ErrorStatistics
(1.3.6.1.4.1.25506.2.40.5.1.1.6)
read-only
Counter64
SDH-B1 error statistics.
hh3cIfMonSdhB2ErrorStatistics
(1.3.6.1.4.1.25506.2.40.5.1.1.7)
read-only
Counter64
SDH-B2 error statistics.
hh3cIfMonCRCErrorStatistics
(1.3.6.1.4.1.25506.2.40.5.1.1.8)
read-only
Counter64
CRC error statistics.
hh3cIfMonRxPauseFrameStatistics
(1.3.6.1.4.1.25506.2.40.5.1.1.9)
read-only
Counter64
Received pause frame statistics.
hh3cIfMonTxPauseFrameStatistics
(1.3.6.1.4.1.25506.2.40.5.1.1.10)
read-only
Counter64
Transmitted pause frame statistics.
hh3cIfMonThresholdTable
About this table
Use this table to obtain the interface statistics of an interface.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfMonInputUsageLowThres.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.40.5.2.1.1.1)
read-write
Unsigned32
Lower threshold for the inbound bandwidth usage.
This object can only be reported and modified.
hh3cIfMonInputUsageHighThres
(1.3.6.1.4.1.25506.2.40.5.2.1.2)
read-write
Unsigned32
Upper threshold for the inbound bandwidth usage.
hh3cIfMonOutputUsageLowThres
(1.3.6.1.4.1.25506.2.40.5.2.1.3)
read-write
Unsigned32
Lower threshold for the outbound bandwidth usage.
hh3cIfMonOutputUsageHighThres
 (1.3.6.1.4.1.25506.2.40.5.2.1.4)
read-write
Unsigned32
Upper threshold for the outbound bandwidth usage.
hh3cIfMonInputErrorAlarmLowThres
(1.3.6.1.4.1.25506.2.40.5.2.1.5)
read-write
Unsigned32
Lower threshold for the number of inbound error packets.
hh3cIfMonInputErrorAlarmHighThres
(1.3.6.1.4.1.25506.2.40.5.2.1.6)
read-write
Unsigned32
Upper threshold for the number of inbound error packets.
hh3cIfMonInputErrorAlarmInterval (1.3.6.1.4.1.25506.2.40.5.2.1.7)
read-write
Unsigned32
Inspection interval for the number of inbound error packets.
hh3cIfMonOutputErrorAlarmLowThres
(1.3.6.1.4.1.25506.2.40.5.2.1.8)
read-write
Unsigned32
Inspection interval for the number of outbound error packets.
hh3cIfMonOutputErrorAlarmHighThres
(1.3.6.1.4.1.25506.2.40.5.2.1.9)
read-write
Unsigned32
Upper threshold for the number of outbound error packets.
hh3cIfMonOutputErrorAlarmInterval
(1.3.6.1.4.1.25506.2.40.5.2.1.10)
read-write
Unsigned32
hh3cIfMonSdhErrorLowThres
(1.3.6.1.4.1.25506.2.40.5.2.1.11)
read-write
Unsigned32
Lower threshold for the number of SDH error packets.
hh3cIfMonSdhErrorHighThres
(1.3.6.1.4.1.25506.2.40.5.2.1.12)
read-write
Unsigned32
Upper threshold for the number of SDH error packets.
hh3cIfMonSdhErrorInterval
(1.3.6.1.4.1.25506.2.40.5.2.1.13)
read-write
Unsigned32
Inspection interval for the number of SDH error packets.
hh3cIfMonSdhB1ErrorLowThres
(1.3.6.1.4.1.25506.2.40.5.2.1.14)
read-write
Unsigned32
Lower threshold for the number of SDH B1 error packets.
hh3cIfMonSdhB1ErrorHighThres
(1.3.6.1.4.1.25506.2.40.5.2.1.15)
read-write
Unsigned32
Upper threshold for the number of SDH B1 error packets.
hh3cIfMonSdhB1ErrorInterval
(1.3.6.1.4.1.25506.2.40.5.2.1.16)
read-write
Unsigned32
Inspection interval for the number of SDH B1 error packets.
hh3cIfMonSdhB2ErrorLowThres
(1.3.6.1.4.1.25506.2.40.5.2.1.17)
read-write
Unsigned32
Lower threshold for the number of SDH B2 error packets.
hh3cIfMonSdhB2ErrorHighThres
(1.3.6.1.4.1.25506.2.40.5.2.1.18)
read-write
Unsigned32
Upper threshold for the number of SDH B2 error packets.
hh3cIfMonSdhB2ErrorInterval
(1.3.6.1.4.1.25506.2.40.5.2.1.19)
read-write
Unsigned32
Inspection interval for the number of SDH B2 error packets.
hh3cIfMonCRCErrorLowThres
(1.3.6.1.4.1.25506.2.40.5.2.1.20)
read-write
Unsigned32
Lower threshold for the number of CRC error packets.
hh3cIfMonCRCErrorHighThres
(1.3.6.1.4.1.25506.2.40.5.2.1.21)
read-write
Unsigned32
Upper threshold for the number of CRC error packets.
hh3cIfMonCRCErrorInterval
(1.3.6.1.4.1.25506.2.40.5.2.1.22)
read-write
Unsigned32
Inspection interval for the number of CRC error packets.
hh3cIfMonCRCErrType
(1.3.6.1.4.1.25506.2.40.5.2.1.23)
read-write
Unsigned32
Inspection type for the CRC error packets.
hh3cIfMonRxPauseFrameLowThres
(1.3.6.1.4.1.25506.2.40.5.2.1.24)
read-write
Unsigned32
Lower threshold for the number of received pause frames.
hh3cIfMonRxPauseFrameHighThres
(1.3.6.1.4.1.25506.2.40.5.2.1.25)
read-write
Unsigned32
Upper threshold for the number of received pause frames.
hh3cIfMonRxPauseFrameInterval
(1.3.6.1.4.1.25506.2.40.5.2.1.26)
read-write
Unsigned32
Inspection interval for the number of received pause frames.
hh3cIfMonTxPauseFrameLowThres
(1.3.6.1.4.1.25506.2.40.5.2.1.27)
read-write
Unsigned32
Lower threshold for the number of transmitted pause frames.
hh3cIfMonTxPauseFrameHighThres
(1.3.6.1.4.1.25506.2.40.5.2.1.28)
read-write
Unsigned32
Upper threshold for the number of transmitted pause frames.
hh3cIfMonTxPauseFrameInterval
(1.3.6.1.4.1.25506.2.40.5.2.1.29)
read-write
Unsigned32
Inspection interval for the number of transmitted pause frames.
hh3cifMonAlarmDownEnableTable
About this table
Use this table to set or get whether to enable the interface down function.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cIfMonInputErrorAlarmEnableDown.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.40.5.2.2.1.1)
read-write
TruthValue
true(1),
false(2)
Whether to shut down the physical interface when the number of inbound error packets exceeds the upper threshold.
hh3cIfMonOutputErrorAlarmEnableDown
(1.3.6.1.4.1.25506.2.40.5.2.2.1.2)
read-write
TruthValue
true(1),
false(2)
Whether to the shut down the physical interface when the number of outbound error packets exceeds the upper threshold.
hh3cIfMonSdhErrorEnableDown
read-write
TruthValue
true(1),
false(2)
Whether to the shut down the physical interface when the number of SDH error packets exceeds the upper threshold.
hh3cIfMonSdhB1ErrorEnableDown
read-write
TruthValue
true(1),
false(2)
Whether to the shut down the physical interface when the number of SDH B1 error packets exceeds the upper threshold.
hh3cIfMonSdhB2ErrorEnableDown
read-write
TruthValue
true(1),
false(2)
Whether to the shut down the physical interface when the number of SDH B2 error packets exceeds the upper threshold.
hh3cIfMonCRCErrorEnableDown
read-write
TruthValue
true(1),
false(2)
Whether to the shut down the physical interface when the number of CRC error packets exceeds the upper threshold.
Notifications
The following information describes the notifications included in the HH3C-IF-EXT-MIB module.
hh3cIfPortUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.40.3.0.5
Link-up alarm
Informational
ON
The notification is generated when physical state of the interface changes to up.
Status control
ON
CLI: snmp-agent trap enable standard linkup
OFF
CLI: undo snmp-agent trap enable standard linkup
Objects
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Interface index.
Yes
Integer32
Standard MIB values.
1.3.6.1.2.1.2.2.1.1 (ifDescr)
Interface description.
No
OCTET STRING
Unsigned32 (0..255)
Recommended action
No action is required.
hh3cIfPortDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.6
Link-down alarm.
Informational
ON
The notification is generated when physical state of the interface changes to down.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
Recommended action
hh3cIfMonInputUsageRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.1
Inbound bandwidth usage rising alarm.
Informational
ON
The notification is generated when the inbound bandwidth usage exceeds the upper threshold.
Status control
ON
CLI: snmp-agent trap enable ifmonitor input-usage
OFF
CLI: undo snmp-agent trap enable ifmonitor input-usage
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
1.3.6.1.2.1.2.2.1.2 (ifDescr)
No
OCTET STRING
Unsigned32 (0..255)
1.3.6.1.4.1.25506.2.40.5.2.1.1.1(hh3cIfMonInputUsageLowThres)
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.2(hh3cIfMonInputUsageHighThres)
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.1(hh3cIfMonInputUsageStatistics)
No
Counter64
Recommended action
To resolve the issue:
1.     Verify that the upper threshold is set reasonably.
2.     If the issue persists, contact H3C Support.
hh3cIfMonInputUsageResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.2
Inbound bandwidth usage recovery alarm
Informational
ON
The notification is generated when the inbound bandwidth usage drops from above the upper threshold to below the lower threshold.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
No
Unsigned32
1-4294967295
No
Unsigned32
1-4294967295
No
Counter64
Recommended action
hh3cIfMonOutputUsageRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.3
Outbound bandwidth usage rising alarm
Informational
ON
The notification is generated when the outbound bandwidth usage exceeds the upper threshold.
Status control
ON
CLI: snmp-agent trap enable ifmonitor output-usage
OFF
CLI: undo snmp-agent trap enable ifmonitor output-usage
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
1.3.6.1.4.1.25506.2.40.5.2.1.1.3(hh3cIfMonOutputUsageLowThres)
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.4(hh3cIfMonOutputUsageHighThres)
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.2(hh3cIfMonOutputUsageStatistics)
No
Counter64
Recommended action
hh3cIfMonOutputUsageResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.4
Outbound bandwidth usage recovery alarm
Informational
ON
The notification is generated when the outbound bandwidth usage drops from above the upper threshold to below the lower threshold.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
No
Unsigned32
1-4294967295
No
Unsigned32
1-4294967295
No
Counter64
Recommended action
hh3cIfMonInputErrorAlarmRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.5
Inbound error packet rising alarm
Informational
ON
The notification is generated when the number of inbound error packets exceeds the upper threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor input-error
OFF
CLI: undo snmp-agent trap enable ifmonitor input-error
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
1.3.6.1.4.1.25506.2.40.5.2.1.1.6(hh3cIfMonInputErrorAlarmHighThres)
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.5(hh3cIfMonInputErrorAlarmLowThres)
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.3(hh3cIfMonInputErrorAlarmStatistics)
No
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.7(hh3cIfMonInputErrorAlarmInterval)
Inbound error alarm statistics collection interval.
No
Unsigned32
1-65535
Recommended action
hh3cIfMonInputErrorAlarmResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.6
Inbound error packet recovery alarm
Informational
ON
The notification is generated when the number of inbound error packets drops from above the upper threshold to below the lower threshold within the specified interval.
Status control
ON
OFF
CLI: undo snmp-agent trap enable ifmonitor input -error
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
No
Unsigned32
1-4294967295
No
Unsigned32
1-4294967295
No
Counter64
1-4294967295
No
Unsigned32
1-65535
Recommended action
hh3cIfMonOutputErrorAlarmRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.7
Outbound error packet rising alarm
Informational
ON
The notification is generated when the number of outbound error packets exceeds the upper threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor output-error
OFF
CLI: undo snmp-agent trap enable ifmonitor output-error
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
1.3.6.1.4.1.25506.2.40.5.2.1.1.9(hh3cIfMonOutputErrorAlarmHighThres)
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.8(hh3cIfMonOutputErrorAlarmLowThres)
Lower threshold for the number of outbound error packets.
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.4(hh3cIfMonOutputErrorAlarmStatistics)
No
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.10(hh3cIfMonOutputErrorAlarmInterval)
Outbound error alarm statistics collection interval.
No
Unsigned32
1-65535
Recommended action
hh3cIfMonOutputErrorAlarmResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.8
Outbound error packet recovery alarm
Informational
ON
The notification is generated when the number of outbound error packets drops from above the upper threshold to below the lower threshold within the specified interval.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
No
Unsigned32
1-4294967295
No
Unsigned32
1-4294967295
No
Counter64
1-4294967295
No
Unsigned32
1-65535
Recommended action
hh3cIfMonSdhErrorRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.9
SDH error packet rising alarm
Informational
ON
The notification is generated when the number of SDH error packets exceeds the upper threshold within the specified interval.
Status control
ON
Syntax: snmp-agent trap enable ifmonitor sdh-error
OFF
CLI: undo snmp-agent trap enable ifmonitor sdh-error
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
1.3.6.1.4.1.25506.2.40.5.2.1.1.11(hh3cIfMonSdhErrorLowThres)
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.12(hh3cIfMonSdhErrorHighThres)
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.5(hh3cIfMonSdhErrorStatistics)
No
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.13(hh3cIfMonSdhErrorInterval)
SDH error statistics collection interval.
No
Unsigned32
1-65535
Recommended action
hh3cIfMonSdhErrorResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.10
SDH error packet recovery alarm
Informational
ON
The notification is generated when the number of SDH error packets drops from above the upper threshold to below the lower threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor sdh-error
OFF
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
No
Unsigned32
1-4294967295
No
Unsigned32
1-4294967295
No
Counter64
1-4294967295
No
Unsigned32
1-65535
Recommended action
hh3cIfMonSdhB1ErrorRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.11
SDH B1 error packet rising alarm
Informational
ON
The notification is generated when the number of SDH B1 error packets exceeds the upper threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor sdh-b1-error
OFF
CLI: undo snmp-agent trap enable ifmonitor sdh-b1-error
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
1.3.6.1.4.1.25506.2.40.5.2.1.1.14(hh3cIfMonSdhB1ErrorLowThres)
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.15(hh3cIfMonSdhB1ErrorHighThres)
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.6(hh3cIfMonSdhB1ErrorStatistics)
SDH B1 error packet statistics.
No
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.16(hh3cIfMonSdhB1ErrorInterval)
SDH B1 error statistics collection interval.
No
Unsigned32
1-65535
Recommended action
hh3cIfMonSdhB1ErrorResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.12
SDH B1 error packet recovery alarm
Informational
ON
The notification is generated when the number of SDH B1 error packets drops from above the upper threshold to below the lower threshold within the specified interval.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
No
Unsigned32
1-4294967295
No
Unsigned32
1-4294967295
No
Counter64
1-4294967295
No
Unsigned32
1-65535
Recommended action
hh3cIfMonSdhB2ErrorRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.13
SDH B2 error packet rising alarm
Informational
ON
The notification is generated when the number of SDH B2 error packets exceeds the upper threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor sdh-b2-error
OFF
CLI: undo snmp-agent trap enable ifmonitor sdh-b2-error
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
1.3.6.1.4.1.25506.2.40.5.2.1.1.17(hh3cIfMonSdhB2ErrorLowThres)
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.18(hh3cIfMonSdhB2ErrorHighThres)
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.7(hh3cIfMonSdhB2ErrorStatistics)
SDH B2 error packet statistics.
No
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.19(hh3cIfMonSdhB2ErrorInterval)
SDH B2 error statistics collection interval.
No
Unsigned32
1-65535
Recommended action
hh3cIfMonSdhB2ErrorResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.14
Informational
ON
The notification is generated when the number of SDH B2 error packets drops from above the upper threshold to below the lower threshold within the specified interval.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
No
Unsigned32
1-4294967295
No
Unsigned32
1-4294967295
SDH B2 error statistics.
No
Counter64
1-4294967295
No
Unsigned32
1-65535
Recommended action
hh3cIfMonCRCErrorRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.15
CRC error packet rising alarm
Informational
ON
The notification is generated when the number of CRC error packets exceeds the upper threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor crc-error
OFF
CLI: undo snmp-agent trap enable ifmonitor crc-error
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
1.3.6.1.4.1.25506.2.40.5.2.1.1.21(hh3cIfMonCRCErrorHighThres)
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.20(hh3cIfMonCRCErrorLowThres)
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.8(hh3cIfMonCRCErrorStatistics)
No
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.22(hh3cIfMonCRCErrorInterval)
CRC error statistics collection interval.
No
Unsigned32
1-65535
1.3.6.1.4.1.25506.2.40.5.2.1.1.23(hh3cIfMonCRCErrType)
No
INTEGER
1-2
Recommended action
hh3cIfMonCRCErrorResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.16
CRC error packet recovery alarm
Informational
ON
The notification is generated when the number of CRC error packets drops from above the upper threshold to below the lower threshold within the specified interval.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
No
Unsigned32
1-4294967295
No
Unsigned32
1-4294967295
No
Counter64
1-4294967295
No
Unsigned32
1-65535
No
INTEGER
1-2
Recommended action
hh3cIfMonRxPauseFrameRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.17
Received pause frame rising alarm
Informational
ON
The notification is generated when the number of received pause frames exceeds the upper threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor rx-pause
OFF
CLI: undo snmp-agent trap enable ifmonitor rx-pause
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
1.3.6.1.4.1.25506.2.40.5.2.1.1.25(hh3cIfMonRxPauseFrameHighThres)
Upper threshold for received pause frames.
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.24(hh3cIfMonRxPauseFrameLowThres)
Lower threshold for received pause frames.
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.9(hh3cIfMonRxPauseFrameStatistics)
No
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.26(hh3cIfMonRxPauseFrameInterval)
Received pause frame statistics collection interval.
No
Unsigned32
1-65535
Recommended action
hh3cIfMonRxPauseFrameResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.18
Received pause frame recovery alarm
Informational
ON
The notification is generated when the number of received pause frames drops from above the upper threshold to below the lower-threshold within the specified interval.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
No
Unsigned32
1-4294967295
No
Unsigned32
1-4294967295
No
Counter64
1-4294967295
No
Unsigned32
1-65535
Recommended action
hh3cIfMonTxPauseFrameRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.19
Transmitted pause frame rising alarm
Informational
ON
The notification is generated when the number of transmitted pause frames exceeds the upper threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor tx-pause
OFF
CLI: undo snmp-agent trap enable ifmonitor tx-pause
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
1.3.6.1.4.1.25506.2.40.5.2.1.1.28(hh3cIfMonTxPauseFrameHighThres)
Upper threshold for transmitted pause frames.
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.27(hh3cIfMonTxPauseFrameLowThres)
Lower threshold for transmitted pause frames.
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.10(hh3cIfMonTxPauseFrameStatistics)
No
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.29(hh3cIfMonTxPauseFrameInterval)
Transmitted pause frame statistics collection interval.
No
Unsigned32
1-65535
Recommended action
hh3cIfMonTxPauseFrameResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.20
Transmitted pause frame recovery alarm
Informational
ON
The notification is generated when the number of transmitted pause frames drops from above the upper threshold to below the lower threshold within the specified interval.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
No
Unsigned32
1-4294967295
No
Unsigned32
1-4294967295
No
Counter64
1-4294967295
No
Unsigned32
1-65535
Recommended action
hh3cIfMonGiantRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.21
Giant packet rising alarm
Informational
ON
The notification is generated when the number of giant packets exceeds the upper threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor giant
OFF
CLI: undo snmp-agent trap enable ifmonitor giant
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
1.3.6.1.4.1.25506.2.40.5.2.1.1.30(hh3cIfMonGiantLowThres)
Lower threshold for giant packets.
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.31(hh3cIfMonGiantHighThres)
Upper threshold for giant packets.
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.11(hh3cIfMonGiantStatistics)
Giant packet statistics.
No
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.32(hh3cIfMonGiantInterval)
Giant packet statistics collection interval.
No
Unsigned32
1-65535
Recommended action
hh3cIfMonGiantResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.22
Giant packet recovery alarm
Informational
ON
The notification is generated when the number of giant packets drops from above the upper threshold to below the lower threshold within the specified interval.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
No
Unsigned32
1-4294967295
No
Unsigned32
1-4294967295
No
Counter64
1-4294967295
No
Unsigned32
1-65535
Recommended action
hh3cIfMonRuntRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.23
Runt packet rising alarm
Informational
ON
The notification is generated when the number of runt packets exceeds the upper threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor runt
OFF
CLI: undo snmp-agent trap enable ifmonitor runt
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
1.3.6.1.4.1.25506.2.40.5.2.1.1.33(hh3cIfMonRuntLowThres)
Lower threshold for runt packets.
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.34(hh3cIfMonRuntHighThres)
Upper threshold for runt packets.
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.12(hh3cIfMonRuntStatistics)
Runt packet statistics.
No
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.35(hh3cIfMonRuntInterval)
Runt packet statistics collection interval.
No
Unsigned32
1-65535
Recommended action
hh3cIfMonRuntResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.24
Runt packet recovery alarm
Informational
ON
The notification is generated when the number of runt packets drops from above the upper threshold to below the lower threshold within the specified interval.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
No
Unsigned32
1-4294967295
No
Unsigned32
1-4294967295
No
Counter64
1-4294967295
No
Unsigned32
1-65535
Recommended action
hh3cIfPfcOutRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.7
Outbound PFC frame rate rising alarm
Informational
ON
The notification is generated when the outbound PFC frame rate exceeds the early warning threshold.
Status control
This notification cannot be turned off.
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
1.3.6.1.4.1.25506.2.40.2.2.5.1.1(hh3cIfPfcDot1pValue)
Interface queue priority.
No
INTEGER
0-7
1.3.6.1.4.1.25506.2.40.2.2.5.1.3(hh3cIfPfcDot1pOutPps)
Outbound rate for a priority.
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.2.2.5.1.5(hh3cIfPfcDot1pOutPpsThreshold)
Outbound rate threshold for a priority.
No
Unsigned32
1-4294967295
Recommended action
2.     If the inbound PFC frame rate exceeds the threshold, verify that the peer device is operating properly.
3.     If the outbound PFC frame rate exceeds the threshold, verify that the local device is operating properly.
4.     If both the inbound PFC frame rate and outbound PFC frame rate exceed the thresholds, verify that the local device and peer device are operating properly.
5.     If the issue persists, contact H3C Support.
hh3cIfInPfcRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.8
Inbound PFC frame rate rising alarm
Informational
ON
The notification is generated when the inbound PFC frame rate exceeds the early warning threshold.
Status control
Objects
OID (object name)
Index
Value range
Interface index.
Yes
Integer32
No
OCTET STRING
Unsigned32 (0..255)
No
INTEGER
0-7
1.3.6.1.4.1.25506.2.40.2.2.5.1.2(hh3cIfPfcDot1pInPps)
Inbound rate for a priority.
No
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.2.2.5.1.4(hh3cIfPfcDot1pInPpsThreshold)
Inbound rate threshold for a priority.
No
Unsigned32
1-4294967295
Recommended action
