09-Layer 3 - IP Routing
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesMIB CompanionH3C SR8800-F Routers MIB Reference-R838x-6W10009-Layer 3 - IP Routing
14-RIPv2-MIB
14-RIPv2-MIB 75.23 KB
RIPv2-MIB
About this MIB
Use this table to obtain RIPv2 interface statistics information, interface configuration information, and neighbor information.
MIB file name
rfc1724-rip.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).rip2(23)
Scalar objects
rip2GlobalRouteChanges (1.3.6.1.2.1.23.1.1)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
INTEGER(0..4294967295)
Number of route changes.
As per the MIB.
rip2GlobalQueries (1.3.6.1.2.1.23.1.2)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Number of RIP responses.
As per the MIB.
Tabular objects
rip2IfStatTable
About this table
This table contains interface statistics information.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table index is rip2IfStatAddress.
Object (OID)
Access
Value range
Implementation
rip2IfStatAddress (1.3.6.1.2.1.23.2.1.1)
read-only
IpAddress
OCTET STRING (4)
Interface IP address.
As per the MIB.
rip2IfStatRcvBadPackets (1.3.6.1.2.1.23.2.1.2)
read-only
Counter32
Number of received bad packets.
As per the MIB.
rip2IfStatRcvBadRoutes (1.3.6.1.2.1.23.2.1.3)
read-only
Counter32
Number of received bad routes.
As per the MIB.
rip2IfStatSentUpdates (1.3.6.1.2.1.23.2.1.4)
read-only
Counter32
Number of triggered updates sent.
As per the MIB.
rip2IfStatStatus (1.3.6.1.2.1.23.2.1.5)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Interface state.
Supports only the read operation.
rip2IfConfTable
About this table
This table contains interface configuration information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is rip2IfConfAddress.
Object (OID)
Access
Value range
Implementation
rip2IfConfAddress (1.3.6.1.2.1.23.3.1.1)
read-only
IpAddress
OCTET STRING (4)
As per the MIB.
rip2IfConfDomain (1.3.6.1.2.1.23.3.1.2)
read-create
RouteTag
OCTET STRING (2)
Route tag in the packet.
rip2IfConfAuthType (1.3.6.1.2.1.23.3.1.3)
read-create
INTEGER
noAuthentication (1),         simplePassword (2),         md5 (3)
Authentication mode.
rip2IfConfAuthKey (1.3.6.1.2.1.23.3.1.4)
read-create
OCTET STRING
OCTET STRING (0..16)
Authentication key.
rip2IfConfSend (1.3.6.1.2.1.23.3.1.5)
read-create
INTEGER
doNotSend (1),
ripVersion1 (2),
rip1Compatible (3),
ripVersion2 (4),
ripV1Demand (5),
ripV2Demand (6)
Version of sent packets.
rip2IfConfReceive (1.3.6.1.2.1.23.3.1.6)
read-create
INTEGER
rip1 (1),
rip2 (2),
rip1OrRip2 (3),
doNotRecieve (4)
Version of received packets.
rip2IfConfDefaultMetric (1.3.6.1.2.1.23.3.1.7)
read-create
INTEGER
INTEGER( 0..15 )
Default cost of redistributed routes.
rip2IfConfStatus (1.3.6.1.2.1.23.3.1.8)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Interface state.
rip2IfConfSrcAddress (1.3.6.1.2.1.23.3.1.9)
read-create
IpAddress
OCTET STRING (4)
Packet source IP address.
rip2PeerTable
About this table
This table contains neighbor information.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are rip2PeerAddress and rip2PeerDomain.
Object (OID)
Access
Value range
Implementation
rip2PeerAddress (1.3.6.1.2.1.23.4.1.1)
read-only
IpAddress
OCTET STRING (4)
Neighbor IP address.
As per the MIB.
rip2PeerDomain (1.3.6.1.2.1.23.4.1.2)
read-only
RouteTag
OCTET STRING (2)
As per the MIB.
rip2PeerLastUpdate (1.3.6.1.2.1.23.4.1.3)
read-only
TimeTicks
Standard MIB values.
Time when the most recent update was received from the neighbor.
As per the MIB.
rip2PeerVersion (1.3.6.1.2.1.23.4.1.4)
read-only
INTEGER
INTEGER( 0..255 )
Version of the most recent packet received from the neighbor.
As per the MIB.
rip2PeerRcvBadPackets (1.3.6.1.2.1.23.4.1.5)
read-only
Counter32
As per the MIB.
rip2PeerRcvBadRoutes (1.3.6.1.2.1.23.4.1.6)
read-only
Counter32
As per the MIB.
