02-Device Management
HomeSupportRoutersH3C SR8800-X Router SeriesDiagnose & MaintainAlarms ReferencesH3C SR8800-X Routers Alarm Reference-R838x-6W10002-Device Management
07-SYSLOG-MSG-MIB
07-SYSLOG-MSG-MIB 39.03 KB
SYSLOG-MSG-MIB
About this MIB
Use this MIB to manage syslog messages as SNMP objects and enable and view syslog message notifications.
MIB file name
rfc5676-syslog-msg.mib
Notifications
syslogMsgNotification
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.192.0.1
A syslog message generated
Informational
Warning
N/A (N/A)
OFF
Notification triggers
This notification is generated when a new syslog message is received.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable syslog command.
MIB: Set syslogMsgEnableNotifications to true(1).
OFF
CLI: Use the undo snmp-agent trap enable syslog command.
MIB: Set syslogMsgEnableNotifications to false(2).
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.192.1.2.1.2 (syslogMsgFacility)
Facility of the syslog message.
syslogMsgIndex
SyslogFacility
kern(0), user(1), mail(2), daemon(3), auth(4), syslog(5), lpr(6), news(7), uucp(8), cron(9), authpriv(10), ftp(11), ntp(12), audit(13), console(14), cron2(15), local0(16), local1(17), local2(18), local3(19), local4(20), local5(21), local6(22), local7(23)
1.3.6.1.2.1.192.1.2.1.3 (syslogMsgSeverity)
Severity of the syslog message.
syslogMsgIndex
SyslogSeverity
emerg(0), alert(1), crit(2), err(3), warning(4), notice(5), info(6), debug(7)
1.3.6.1.2.1.192.1.2.1.4 (syslogMsgVersion)
Version of the syslog message.
syslogMsgIndex
Unsigned32
0..999
1.3.6.1.2.1.192.1.2.1.5 (syslogMsgTimeStamp)
Timestamp of the syslog message.
syslogMsgIndex
SyslogTimeStamp
OCTET STRING (SIZE (0|10|13))
1.3.6.1.2.1.192.1.2.1.6 (syslogMsgHostName)
Host name of the syslog message.
syslogMsgIndex
DisplayString
OCTET STRING (SIZE (0..255))
1.3.6.1.2.1.192.1.2.1.7 (syslogMsgAppName)
Application name of the syslog message.
syslogMsgIndex
DisplayString
OCTET STRING (SIZE (0..48))
1.3.6.1.2.1.192.1.2.1.8 (syslogMsgProcID)
Process ID of the syslog message.
syslogMsgIndex
DisplayString
OCTET STRING (SIZE (0..128))
1.3.6.1.2.1.192.1.2.1.9 (syslogMsgMsgID)
Message ID of the syslog message.
syslogMsgIndex
DisplayString
OCTET STRING (SIZE (0..32))
1.3.6.1.2.1.192.1.2.1.10 (syslogMsgSDParams)
Number of structured data element parameters carried in the syslog message.
syslogMsgIndex
Unsigned32
Standard MIB values.
1.3.6.1.2.1.192.1.2.1.11 (syslogMsgMsg)
Message part of the syslog message.
syslogMsgIndex
OCTET STRING
Recommended action
No action is required.
