15-Network Management and Monitoring
HomeSupportRoutersCR16000-F SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-F Routers Alarm Reference-R838x-6W10015-Network Management and Monitoring
05-HH3C-NETCONF-MIB
05-HH3C-NETCONF-MIB 67.34 KB
HH3C-NETCONF-MIB
About this MIB
Use this MIB to notify SNMP NMSs of NETCONF session establishment and disconnection events.
MIB file name
hh3c-netconf.mib
Notifications
hh3cNetconfServerSessionStart
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.206.2.0.1
NETCONF server established a session.
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification is generated when the NETCONF server establishes a session with a NETCONF client.
System impact
No negative impact on the system.
Status control
No action is required.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.206.1.1.1
 (hh3cNetconfSessionId)
NETCONF session ID.
N/A
Integer32
Integer32 , (1..2147483647)
1.3.6.1.4.1.25506.2.206.1.1.2
 (hh3cNetconfSessionUserName)
NETCONF session username.
N/A
DisplayString
OCTET STRING (1..80)
1.3.6.1.4.1.25506.2.206.1.1.3
 (hh3cNetconfSessionPeerIPAddressType)
Type of the remote IP address that established the NETCONF session with the device.
N/A
InetAddressType
Standard MIB values.
1.3.6.1.4.1.25506.2.206.1.1.4 (hh3cNetconfSessionPeerIPAddress)
Remote IP address that established the NETCONF session with the device.
N/A
InetAddress
Recommended action
hh3cNetconfServerSessionEnd
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.206.2.0.2
NETCONF server ended a session
Informational
Warning
N/A (N/A)
ON
This notification might be generated when the following events occur:
The NETCONF server receives a session termination request.
A persistent session is disconnected because of a network error.
A temporary session is disconnected because the session timeout time expires.
System impact
NETCONF server terminates a session.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
NETCONF session ID.
N/A
Integer32
N/A
DisplayString
N/A
InetAddressType
N/A
InetAddress
1.3.6.1.4.1.25506.2.206.1.1.5 (hh3cNetconfSessionTerminationReason)
Reasons for the session to be disconnected by the NETCONF client:
N/A
INTEGER
Options:, other(1)—Any other reason than those listed below., closed(2)—Session was closed., timeout(3)—Session exception occurred., idleTimeout(4)—Session timed out.
Recommended action
If the session was closed normally, no action is required.
If the session was closed abnormally, check the physical link.
