| 02-HH3C-SRV6-MIB | 42.55 KB |
HH3C-SRV6-MIB
About this MIB
Use this MIB to configure SRv6 settings.
MIB file name
hh3c-srv6.mib
Notifications
hh3cSrv6SidRouteConflict
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.197.0.1 |
A route conflict occurred. |
Error |
Warning |
1.3.6.1.4.1.25506.2.197.0.2 (hh3cSrv6SidRouteConflictClear) |
OFF |
Notification triggers
This notification is generated when a locally configured SRv6 SID conflicts with an IPv6 route learned from the remote device.
System impact
The conflicted SRv6 local SID forwarding entry or IPv6 route entry might be deleted, resulting in traffic forwarding failure.
Status control
ON
CLI: Use the snmp-agent trap enable srv6 command.
OFF
CLI: Use the undo snmp-agent trap enable srv6 command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.197.1.1.1 (hh3cSrv6NotificationSid) |
SRv6 address of the SID. |
hh3cSrv6NotificationSid hh3cSrv6NotificationSidPrefixLen |
InetAddressIPv6 |
OCTET STRING (16) |
1.3.6.1.4.1.25506.2.197.1.1.2 (hh3cSrv6NotificationSidPrefixLen) |
SRv6 prefix length of the SID. |
Unsigned32 |
Unsigned32 (1..128) |
Recommended action
1.Use the display ipv6 routing-table command to view the IPv6 routing table information. Then, use the display segment-routing ipv6 local-sid command to view the local SID forwarding table information for SRv6.
2.Compare the entries in the two previous tables and identify the conflicting entries. You can delete the conflicting SRv6 SID on the local end as needed.
3.If the issue persists after the SRv6 SID is deleted, collect alarm information and configuration data, and then contact Technical Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.197.0.2 |
The route conflict was cleared. |
Recovery |
Informational |
N/A (N/A) |
OFF |
This notification is generated when the conflict between a locally configured SRv6 SID and a remotely learned IPv6 route is removed.
System impact
No impact on services.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
InetAddressIPv6 |
OCTET STRING (16) |
Unsigned32 |
Recommended action
No action is required.
