05-HH3C-MAC-INFORMATION-MIB | 72.32 KB |
About this MIB
Use this MIB to configure MAC Information.
MIB file name
hh3c-mac-information.mib
Notifications
hh3cMACInformationChangedTrapExt
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.87.1.4.0.1 |
MAC changes. |
Informational |
Warning |
ON |
Notification triggers
This notification is generated when MAC addresses change.
System impact
Status control
This notification cannot be disabled.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.87.1.4.2.1 (hh3cMACInfoTrapVerExt) |
SNMP version. |
N/A |
Unsigned32 |
Standard MIB values. |
1.3.6.1.4.1.25506.2.87.1.4.2.2 (hh3cMACInfoTrapIndexExt) |
Notification index. |
N/A |
Unsigned32 |
Unsigned32 (1..2147483647) |
1.3.6.1.4.1.25506.2.87.1.4.2.3 (hh3cMACInfoTrapCountExt) |
Notification count. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.87.1.4.2.4 (hh3cMACInfoTrapMsgExt) |
Notification contents. |
N/A |
OCTET STRING |
OCTET STRING (1..254) |
Recommended action
No action is required.
hh3cMACInformationMovedTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.87.1.4.0.2 |
A MAC address moves. |
Error |
Minor |
1.3.6.1.4.1.25506.2.87.1.4.0.3 (hh3cMACInformationMovedRsmTrap) |
OFF |
This notification is generated when a MAC address moves.
System impact
The MAC address move might cause transient interruption of traffic.
Status control
ON
CLI: Use the snmp-agent trap enable mac-address [ mac-move ] command.
OFF
CLI: Use the undo snmp-agent trap enable mac-address [ mac-move ] command.
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.87.1.4.2.5.0 (hh3cMACInfoTrapMsgMovedAddress) |
MAC address. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.87.1.4.2.6.0 (hh3cMACInfoTrapMsgMovedVlan) |
VLAN ID. |
N/A |
Unsigned32 |
Unsigned32 (1..4094) |
1.3.6.1.4.1.25506.2.87.1.4.2.7.0 (hh3cMACInfoTrapMsgMovedFromIf) |
Source port for the MAC address move. |
N/A |
Unsigned32 |
Unsigned32(1..2147483647) |
1.3.6.1.4.1.25506.2.87.1.4.2.8.0 (hh3cMACInfoTrapMsgMovedToIf) |
Destination port for the MAC address move. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.87.1.4.2.9.0 (hh3cMACInfoTrapMsgMovedCount) |
MAC address move count. |
N/A |
Counter32 |
1.3.6.1.4.1.25506.2.87.1.4.2.13.0 (hh3cMACInfoTrapMsgChassis) |
Chassis ID. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.87.1.4.2.14.0 (hh3cMACInfoTrapMsgSlot) |
Slot ID. |
N/A |
Unsigned32 |
Recommended action
To resolve this issue:
1.Execute the display mac-address mac-move command to view the MAC address move records, and check whether physical Layer 2 loops exist on interfaces.
- If physical Layer 2 loops exist, remove these loops. If MAC address moves occur frequently after you remove the loops, perform step 2.
- If no Layer 2 loop exists, perform step 2.
2.Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.87.1.4.0.3 |
MAC address moves stop. |
Recovery |
Warning |
N/A (N/A) |
ON |
This notification is generated when MAC address moves stop in a VLAN within a specific time period.
System impact
No impact on services.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.87.1.4.2.6 (hh3cMACInfoTrapMsgMovedVlan) |
VLAN ID. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.87.1.4.2.13 (hh3cMACInfoTrapMsgChassis) |
Chassis ID. |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.87.1.4.2.14 (hh3cMACInfoTrapMsgSlot) |
Slot ID. |
N/A |
Unsigned32 |
Recommended action
hh3cMACInfoVsiMovedTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.87.1.4.0.4 |
A MAC address moves on a VSI. |
Error |
Minor |
1.3.6.1.4.1.25506.2.87.1.4.0.5 (hh3cMACInfoVsiMovedRsmTrap) |
ON |
This notification is generated when a MAC address moves on a VSI.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.87.1.4.2.5 (hh3cMACInfoTrapMsgMovedAddress) |
MAC address. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.87.1.4.2.10 (hh3cMACInfoTrapMsgMovedVsi) |
VSI name. |
N/A |
OCTET STRING |
OCTET STRING (1..31) |
1.3.6.1.4.1.25506.2.87.1.4.2.11 (hh3cMACInfoTrapMsgMovedFmIfName) |
Source interface name for the MAC address move or interface + service instance or link identifier |
N/A |
OCTET STRING |
OCTET STRING (0..255) |
1.3.6.1.4.1.25506.2.87.1.4.2.12 (hh3cMACInfoTrapMsgMovedToIfName) |
Destination interface name for the MAC address move or interface + service instance or link identifier |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.87.1.4.2.9 (hh3cMACInfoTrapMsgMovedCount) |
N/A |
Counter32 |
Chassis ID. |
N/A |
Unsigned32 |
Slot ID. |
N/A |
Unsigned32 |
Recommended action
1.Execute the display l2vpn mac-address mac-move command to view the MAC address move records, and check whether physical Layer 2 loops exist on the VSI.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.87.1.4.0.5 |
MAC address moves stop on a VSI. |
Recovery |
Warning |
N/A (N/A) |
ON |
This notification is generated when MAC address moves stop on a VSI within a specific time period.
System impact
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
VSI name. |
N/A |
OCTET STRING |
Chassis ID. |
N/A |
Unsigned32 |
Slot ID. |
N/A |
Unsigned32 |
Recommended action
hh3cMACInfoMovedIfBlockTrap
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.87.1.4.0.6 |
MAC address move suppression is triggered on an interface due to frequent MAC address moves. |
Error |
Critical |
1.3.6.1.4.1.25506.2.87.1.4.0.7 (hh3cMACInfoMovedIfResumeTrap) |
ON |
This notification is generated when MAC address move suppression is triggered on an interface due to frequent MAC address moves, and this interface will be shut down for a suppression interval.
System impact
MAC address move suppression might cause service interruption on the shutdown interface.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.87.1.4.2.15 (hh3cMACInfoTrapMsgBlockIfName) |
Interface name. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.87.1.4.2.16 (hh3cMACInfoTrapMsgBlockTime) |
Suppression interval (seconds). |
N/A |
Unsigned32 |
Unsigned32(30..86400) |
MAC address. |
N/A |
OCTET STRING |
VLAN ID. |
N/A |
Unsigned32 |
Recommended action
1.Check whether physical Layer 2 loops exist in the VLAN.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.87.1.4.0.7 |
An interface recovers from MAC address move suppression. |
Recovery |
Warning |
N/A (N/A) |
ON |
This notification is generated when an interface goes up after a suppression interval elapses.
System impact
Services interrupted due to MAC address move suppression are restored.
Status control
ON
OFF
Object
OID (object name) |
Index |
Type |
Value range |
Interface name. |
N/A |
OCTET STRING |
N/A |
Unsigned32 |
VLAN ID. |
N/A |
Unsigned32 |
Recommended action
