04-Interface
HomeSupportRoutersH3C SR8800-F Router SeriesDiagnose & MaintainAlarms ReferencesH3C SR8800-F Routers Alarm Reference-R838x-6W10004-Interface
01-HH3C-IF-EXT-MIB
01-HH3C-IF-EXT-MIB 365.11 KB
HH3C-IF-EXT-MIB· 1
About this MIB· 1
MIB file name· 1
Notifications· 1
hh3cIfPortUp· 1
hh3cIfPortDown· 2
hh3cIfMonInputUsageRising· 3
hh3cIfMonOutputUsageRising· 4
hh3cIfMonInputUsageResume· 5
hh3cIfMonOutputUsageResume· 6
hh3cIfMonInputErrorAlarmRising· 7
hh3cIfMonInputErrorAlarmResume· 8
hh3cIfMonOutputErrorAlarmRising· 9
hh3cIfMonOutputErrorAlarmResume· 10
hh3cIfMonSdhErrorRising· 11
hh3cIfMonSdhErrorResume· 13
hh3cIfMonSdhB1ErrorRising· 14
hh3cIfMonSdhB1ErrorResume· 15
hh3cIfMonSdhB2ErrorRising· 16
hh3cIfMonSdhB2ErrorResume· 17
hh3cIfMonCRCErrorRising· 18
hh3cIfMonRxPauseFrameRising· 21
hh3cIfMonRxPauseFrameResume· 22
hh3cIfMonTxPauseFrameRising· 23
hh3cIfMonTxPauseFrameResume· 25
hh3cIfMonGiantRising· 26
hh3cIfMonGiantResume· 27
hh3cIfMonRuntRising· 28
hh3cIfMonRuntResume· 29
hh3cIfMonInputBufferDropRising· 30
hh3cIfMonInputBufferDropResume· 31
hh3cIfMonOutputBufferDropRising· 32
hh3cIfMonOutputBufferDropResume· 33
hh3cIfMonInputUFlowRising· 34
hh3cIfMonInputUFlowFalling· 36
hh3cIfMonBip8SdError 37
hh3cIfMonBip8SdErrorResume· 38
hh3cIfLofAlarm·· 39
hh3cIfLofAlarmResume· 40
hh3cIfOofAlarm·· 41
hh3cIfOofAlarmResume· 42
hh3cIfMonCRCBitErrorRising· 43
hh3cIfMonCRCBitErrorResume· 44
hh3cIfFlowControlDLAlarm·· 45
hh3cIfFlowControlDLAlarmResume· 46
hh3cIfOutputErrorAlarm·· 47
hh3cIfOutputErrorAlarmResume· 48
hh3cIfCableSnrAbnormal 48
hh3cIfCableSnrNormal 49
hh3cIfCableSnrDetectNotSupport 50
hh3cIfSfpNotSupportSingleFiber 51
hh3cIfLRMStateAbnormal 51
hh3cIfSfpWorkOnlyNonNego· 52
hh3cIfPfcDeadLockAlarm·· 53
hh3cIfPfcDeadLockResume· 54
hh3cIfPfcTurnOffAlarm·· 55
hh3cIfPfcTurnOffResume· 56
hh3cIfQueueAlarm·· 56
hh3cIfQueueResume· 57
hh3cIfQueueStatDiscardAlarm·· 58
hh3cIfQueueStatDiscardResume· 59
HH3C-IF-EXT-MIB
About this MIB
Use this MIB to manage and describe interfaces.
MIB file name
hh3c-if-ext.mib
Notifications
hh3cIfPortUp
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.40.3.0.5
Link-up alarm
Recovery
Warning
ON
Notification triggers
This notification is generated when physical state of the interface changes to up.
Possible reasons are:
The undo shutdown command is executed on the interface.
The interface or link failure is resolved.
The physical state of the interface comes up.
System impact
The interface can normally forward packets.
Status control
ON
CLI: snmp-agent trap enable standard linkup
OFF
CLI: undo snmp-agent trap enable standard linkup
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.2.2.1.1 (ifIndex)
Interface index.
ifIndex
Integer32
Standard MIB values.
1.3.6.1.2.1.2.2.1.2 (ifDescr)
Interface description.
ifIndex
OCTET STRING
OCTET STRING(0..255)
Recommended action
No action is required.
hh3cIfPortDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.6
Link-down alarm.
Error
Major
1.3.6.1.4.1.25506.2.40.3.0.5 (hh3cIfPortUp)
ON
This notification is generated when physical state of the interface changes to down.
The physical link of the interface is down, and the link is disconnected.
The interface is shut down.
System impact
The interface cannot normally forward packets.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
To resolve this issue:
1.Execute the display this command in interface view to identify whether the interfaces on both end are shut down. If the interfaces are shut down, execute the undo shutdown command in interface view to bring them up.
2.Identify whether the physical connection is normal (for example, whether the network cables or transceiver modules are firmly connected). If the physical connection is abnormal, correctly connect the interfaces.
3.If the issue persists, contact H3C Support.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.1
Inbound bandwidth usage rising alarm.
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.2 (hh3cIfMonInputUsageResume)
ON
This notification is generated when the inbound bandwidth usage exceeds the upper threshold.
System impact
When the inbound bandwidth usage reaches about 100%, the service traffic might be delayed or dropped.
Status control
ON
CLI: snmp-agent trap enable ifmonitor input-usage
OFF
CLI: undo snmp-agent trap enable ifmonitor input-usage
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.1 (hh3cIfMonInputUsageLowThres)
Lower threshold for the inbound bandwidth usage.
Unsigned32
0-100
1.3.6.1.4.1.25506.2.40.5.2.1.1.2 (hh3cIfMonInputUsageHighThres)
Upper threshold for the inbound bandwidth usage.
Unsigned32
0-100
1.3.6.1.4.1.25506.2.40.5.1.1.1.1 (hh3cIfMonInputUsageStatistics)
Inbound bandwidth usage statistics.
hh3cIfMonInputRateStatistics
Counter64
Recommended action
1.Identify whether the upper threshold set on the interface is too low.
  - If the threshold is too low, execute the port ifmonitor input-usage command to modify the threshold.
  - If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.3
Outbound bandwidth usage rising alarm.
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.4 (hh3cIfMonOutputUsageResume)
ON
This notification is generated when the outbound bandwidth usage exceeds the upper threshold.
System impact
When the outbound bandwidth usage reaches about 100%, the service traffic might be delayed or dropped.
Status control
ON
CLI: snmp-agent trap enable ifmonitor output-usage
OFF
CLI: undo snmp-agent trap enable ifmonitor output-usage
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.3 (hh3cIfMonOutputUsageLowThres)
Lower threshold for the outbound bandwidth usage.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.4 (hh3cIfMonOutputUsageHighThres)
Upper threshold for the outbound bandwidth usage.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.2 (hh3cIfMonOutputUsageStatistics)
Outbound bandwidth usage statistics.
Counter64
Recommended action
  - If the threshold is too low, execute the port ifmonitor output-usage command to modify the threshold.
Basic information
OID
Event
Severity
Default status
Inbound bandwidth usage recovery alarm
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the inbound bandwidth usage drops from above the upper threshold to below the lower threshold.
System impact
The service restores.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
0-100
Unsigned32
0-100
Counter64
Recommended action
Basic information
OID
Event
Severity
Default status
Outbound bandwidth usage recovery alarm
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the outbound bandwidth usage drops from above the upper threshold to below the lower threshold.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
0-100
Unsigned32
0-100
Counter64
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.5
Inbound error packet rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.6 (hh3cIfMonInputErrorAlarmResume)
ON
This notification is generated when the number of inbound error packets exceeds the upper threshold within the specified interval.
The optical transceiver module fails.
The optical fiber or link fails.
System impact
Service traffic might be dropped.
Status control
ON
CLI: snmp-agent trap enable ifmonitor input-error
OFF
CLI: undo snmp-agent trap enable ifmonitor input-error
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.6 (hh3cIfMonInputErrorAlarmHighThres)
Upper threshold for the number of inbound error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.5 (hh3cIfMonInputErrorAlarmLowThres)
Lower threshold for the number of inbound error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.3 (hh3cIfMonInputErrorAlarmStatistics)
Inbound error alarm statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.7 (hh3cIfMonInputErrorAlarmInterval)
Inbound error alarm statistics collection interval.
Unsigned32
0-65535
Recommended action
1.Replace the transceiver module. Identify whether the alarm is cleared.
2.Replace the optical fiber or link. Identify whether the alarm is cleared.
3.Identify whether the upper threshold set on the interface is too low.
  - If the threshold is too low, execute the port ifmonitor input-error command to modify the threshold.
Basic information
OID
Event
Severity
Default status
Inbound error packet recovery alarm
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the number of inbound error packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
CLI: undo snmp-agent trap enable ifmonitor input -error
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.7
Outbound error packet rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.8 (hh3cIfMonOutputErrorAlarmResume)
ON
This notification is generated when the number of outbound error packets exceeds the upper threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor output-error
OFF
CLI: undo snmp-agent trap enable ifmonitor output-error
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.9 (hh3cIfMonOutputErrorAlarmHighThres)
Upper threshold for the number of outbound error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.8 (hh3cIfMonOutputErrorAlarmLowThres)
Lower threshold for the number of outbound error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.4 (hh3cIfMonOutputErrorAlarmStatistics)
Outbound error alarm statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.10 (hh3cIfMonOutputErrorAlarmInterval)
Outbound error alarm statistics collection interval.
Unsigned32
0-65535
Recommended action
1.Verify that the optical fiber is firmly installed. Identify whether the alarm is cleared.
2.Verify that the physical link is normal.
3.Execute the display interface command to identify whether the Tx power of the transceiver module of the interface that fails is within the normal range. Identify whether the negotiation mode, clock mode, and scrambling mode (link protocol, clock, and scramble) are the same on both ends. If they are different, modify the negotiation mode configuration on both ends to make them consistent. Identify whether the alarm is cleared.
4.Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor output-error command to modify the threshold.
5.If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
Outbound error packet recovery alarm
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the number of outbound error packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.9
SDH error packet rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.10 (hh3cIfMonSdhErrorResume)
ON
This notification is generated when the number of SDH error packets exceeds the upper threshold within the specified interval.
The optical fiber fails.
System impact
Status control
ON
Syntax: snmp-agent trap enable ifmonitor sdh-error
OFF
CLI: undo snmp-agent trap enable ifmonitor sdh-error
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.11 (hh3cIfMonSdhErrorLowThres)
Lower threshold for the number of SDH error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.12 (hh3cIfMonSdhErrorHighThres)
Upper threshold for the number of SDH error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.5 (hh3cIfMonSdhErrorStatistics)
SDH error statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.13 (hh3cIfMonSdhErrorInterval)
SDH error statistics collection interval.
Unsigned32
0-65535
Recommended action
To resolve the issue:
2.Replace the optical fiber. Identify whether the alarm is cleared.
3.Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor sdh-error command to modify the threshold.
4.Collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
SDH error packet recovery alarm
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the number of SDH error packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor sdh-error
OFF
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.11
SDH B1 error packet rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.12 (hh3cIfMonSdhB1ErrorResume)
ON
This notification is generated when the number of SDH B1 error packets exceeds the upper threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor sdh-b1-error
OFF
CLI: undo snmp-agent trap enable ifmonitor sdh-b1-error
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.14 (hh3cIfMonSdhB1ErrorLowThres)
Lower threshold for the number of SDH B1 error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.15 (hh3cIfMonSdhB1ErrorHighThres)
Upper threshold for the number of SDH B1 error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.6 (hh3cIfMonSdhB1ErrorStatistics)
SDH B1 error packet statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.16 (hh3cIfMonSdhB1ErrorInterval)
SDH B1 error statistics collection interval.
Unsigned32
0-65535
Recommended action
1.Identify whether the link (including optical fiber, transceiver module, transmission device, jumper, and so on) fails. Replace the faulty components (if any), and verify that the link is connected correctly. Identify whether the alarm is cleared.
2.Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor sdh-b1-error command to modify the threshold.
3.Collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
SDH B1 error packet recovery alarm
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the number of SDH B1 error packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.13
SDH B2 error packet rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.14 (hh3cIfMonSdhB2ErrorResume)
ON
This notification is generated when the number of SDH B2 error packets exceeds the upper threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor sdh-b2-error
OFF
CLI: undo snmp-agent trap enable ifmonitor sdh-b2-error
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.17 (hh3cIfMonSdhB2ErrorLowThres)
Lower threshold for the number of SDH B2 error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.18 (hh3cIfMonSdhB2ErrorHighThres)
Upper threshold for the number of SDH B2 error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.7 (hh3cIfMonSdhB2ErrorStatistics)
SDH B2 error packet statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.19 (hh3cIfMonSdhB2ErrorInterval)
SDH B2 error statistics collection interval.
Unsigned32
0-65535
Recommended action
2.Replace the faulty components (if any), and verify that the link is connected correctly. Identify whether the alarm is cleared.
3.Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor sdh-b2-error command to modify the threshold. If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the number of SDH B2 error packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
SDH B2 error statistics.
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.15
CRC error packet rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.16 (hh3cIfMonCRCErrorResume)
ON
This notification is generated when the number of CRC error packets exceeds the upper threshold within the specified interval.
Status control
ON
CLI: snmp-agent trap enable ifmonitor crc-error
OFF
CLI: undo snmp-agent trap enable ifmonitor crc-error
Objects
OID (object name)
Index nodes
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.21(hh3cIfMonCRCErrorHighThres)
Upper threshold for the number of CRC error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.20(hh3cIfMonCRCErrorLowThres)
Lower threshold for the number of CRC error packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.8(hh3cIfMonCRCErrorStatistics)
CRC error statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.22(hh3cIfMonCRCErrorInterval)
CRC error statistics collection interval.
Unsigned32
0-65535
1.3.6.1.4.1.25506.2.40.5.2.1.1.23(hh3cIfMonCRCErrType)
INTEGER
1-2
Recommended action
Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor crc-error command to modify the threshold. If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
CRC error packet recovery alarm
Recovery
Informational
N/A
ON
This notification is generated when the number of CRC error packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.21 (hh3cIfMonCRCErrorHighThres)
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.20 (hh3cIfMonCRCErrorLowThres)
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.8 (hh3cIfMonCRCErrorStatistics)
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.22 (hh3cIfMonCRCErrorInterval)
Unsigned32
0-65535
1.3.6.1.4.1.25506.2.40.5.2.1.1.23 (hh3cIfMonCRCErrType)
INTEGER
1-2
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.17
Received pause frame rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.18 (hh3cIfMonRxPauseFrameResume)
ON
This notification is generated when the number of received pause frames exceeds the upper threshold within the specified interval.
The rate of received pause frames exceeds the threshold.
Pause frames are received continuously for a long period of time.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor rx-pause
OFF
CLI: undo snmp-agent trap enable ifmonitor rx-pause
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.25 (hh3cIfMonRxPauseFrameHighThres)
Upper threshold for received pause frames.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.24 (hh3cIfMonRxPauseFrameLowThres)
Lower threshold for received pause frames.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.9 (hh3cIfMonRxPauseFrameStatistics)
Received pause frame statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.26 (hh3cIfMonRxPauseFrameInterval)
Received pause frame statistics collection interval.
Unsigned32
0-65535
Recommended action
1.Decrease the service traffic received on the peer interface. Identify whether the alarm is cleared.
2.Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor rx-pause command to modify the threshold. If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
Received pause frame recovery alarm
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the number of received pause frames drops from above the upper threshold to below the lower-threshold within the specified interval.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.19
Transmitted pause frame rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.20 (hh3cIfMonTxPauseFrameResume)
ON
This notification is generated when the number of transmitted pause frames exceeds the upper threshold within the specified interval.
The rate of sent pause frames exceeds the threshold.
Pause frames are sent continuously for a long period of time.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor tx-pause
OFF
CLI: undo snmp-agent trap enable ifmonitor tx-pause
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.28 (hh3cIfMonTxPauseFrameHighThres)
Upper threshold for transmitted pause frames.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.27 (hh3cIfMonTxPauseFrameLowThres)
Lower threshold for transmitted pause frames.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.10 (hh3cIfMonTxPauseFrameStatistics)
Transmitted pause frame statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.29 (hh3cIfMonTxPauseFrameInterval)
Transmitted pause frame statistics collection interval.
Unsigned32
0-65535
Recommended action
1.Decrease the service traffic sent on the peer interface. Identify whether the alarm is cleared.
2.Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the port ifmonitor tx-pause command to modify the threshold. If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
Transmitted pause frame recovery alarm
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the number of transmitted pause frames drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.21
Giant packet rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.22 (hh3cIfMonGiantResume)
ON
This notification is generated when the number of giant packets exceeds the upper threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor giant
OFF
CLI: undo snmp-agent trap enable ifmonitor giant
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.30 (hh3cIfMonGiantLowThres)
Lower threshold for giant packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.31 (hh3cIfMonGiantHighThres)
Upper threshold for giant packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.11 (hh3cIfMonGiantStatistics)
Giant packet statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.32 (hh3cIfMonGiantInterval)
Giant packet statistics collection interval.
Unsigned32
0-65535
Recommended action
1.Verify that the source traffic is normal.
2.Execute the jumboframe enable command to adjust the maximum size of a packet that can be transmitted on the interface.
Basic information
OID
Event
Severity
Default status
Giant packet recovery alarm
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the number of giant packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
hh3cIfMonRuntRising
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.23
Runt packet rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.24 (hh3cIfMonRuntResume)
ON
This notification is generated when the number of runt packets exceeds the upper threshold within the specified interval.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor runt
OFF
CLI: undo snmp-agent trap enable ifmonitor runt
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.33 (hh3cIfMonRuntLowThres)
Lower threshold for runt packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.34 (hh3cIfMonRuntHighThres)
Upper threshold for runt packets.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.12 (hh3cIfMonRuntStatistics)
Runt packet statistics.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.35 (hh3cIfMonRuntInterval)
Runt packet statistics collection interval.
Unsigned32
0-65535
Recommended action
hh3cIfMonRuntResume
Basic information
OID
Event
Severity
Default status
Runt packet recovery alarm
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the number of runt packets drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.25
The number of incoming packets dropped in the buffer exceeds the upper threshold
Error
Major
1.3.6.1.4.1.25506.2.40.6.0.26 (hh3cIfMonInputBufferDropResume)
ON
This notification is generated when the number of incoming packets dropped in the buffer exceeds the upper threshold within the specified interval.
The transmission rate on the peer end is too fast.
The processing rate on the local end is too slow.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor input-buffer-drop
OFF
CLI: undo snmp-agent trap enable ifmonitor input-buffer-drop
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.36 (hh3cIfMonInputBufferDropLowThres)
Lower threshold for the number of incoming packets dropped in the buffer.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.37 (hh3cIfMonInputBufferDropHighThres)
Upper threshold for the number of incoming packets dropped in the buffer.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.13 (hh3cIfMonInputBufferDropStatistics)
Statistics of the number of incoming packets dropped in the buffer.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.38 (hh3cIfMonInputBufferDropInterval)
Statistics collection interval for the number of incoming packets dropped in the buffer.
Unsigned32
0-65535
Recommended action
1.Decrease the service traffic sending rate on the peer end, such as limiting the rate by quality of service (QoS). Identify whether the alarm is cleared.
3.If it is set reasonably, collect related information and contact H3C Support.
Basic information
OID
Event
Severity
Default status
The number of incoming packets dropped in the buffer recovers.
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the number of incoming packets dropped in the buffer drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.27
The number of outgoing packets dropped in the buffer exceeds the upper threshold
Error
Major
1.3.6.1.4.1.25506.2.40.6.0.28 (hh3cIfMonOutputBufferDropResume)
ON
This notification is generated when the number of outgoing packets dropped in the buffer exceeds the upper threshold within the specified interval.
The possible reason is the transmission rate at the local end is too fast.
System impact
Status control
ON
CLI: snmp-agent trap enable ifmonitor output-buffer-drop
OFF
CLI: undo snmp-agent trap enable ifmonitor output-buffer-drop
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.5.2.1.1.39 (hh3cIfMonOutputBufferDropLowThres)
Lower threshold for the number of outgoing packets dropped in the buffer.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.40 (hh3cIfMonOutputBufferDropHighThres)
Upper threshold for the number of outgoing packets dropped in the buffer.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.5.1.1.1.14 (hh3cIfMonOutputBufferDropStatistics)
Statistics of the number of outgoing packets dropped in the buffer.
Counter64
1-4294967295
1.3.6.1.4.1.25506.2.40.5.2.1.1.41 (hh3cIfMonOutputBufferDropInterval)
Statistics collection interval for the number of outgoing packets dropped in the buffer.
Unsigned32
0-65535
Recommended action
1.Decrease the service traffic sent on the local end, such as limiting the speed by qos. Identify whether the alarm is cleared.
2.If it is not cleared, collect related information and contact H3C Support.
Basic information
OID
Event
Severity
Default status
The number of outgoing packets dropped in the buffer recovers.
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the number of outgoing packets dropped in the buffer drops from above the upper threshold to below the lower threshold within the specified interval.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Unsigned32
1-4294967295
Unsigned32
1-4294967295
Counter64
1-4294967295
Unsigned32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.29
The unknown unicast traffic on the input interface exceeds the set alarm threshold
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.30 (hh3cIfMonInputUFlowFalling)
ON
Device traffic is abnormal or the device is under network attack, resulting in unknown unicast traffic on the input interface exceeds the set alarm threshold.
System impact
The uplink bandwidth of normal protocol packets might be preempted, resulting in protocol disruption and data loss.
Status control
This notification cannot be turned off.
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.1.18.0
 (hh3cIfUNUCPortRealFlow)
Ratio of unknown unicast traffic to the total traffic
N/A
Integer32
Integer32(0..100)
1.3.6.1.4.1.25506.2.40.1.19.0 (hh3cIfUNUCPortAlarmThreshold)
Threshold
N/A
Integer32
Integer32(1..2147483647)
Recommended action
1.Execute the display this command in interface view to check the VLAN or VSI configuration of the current interface.
2.Enter the corresponding VLAN or VSI view in system view, and execute the display this command to identify whether MAC address learning is enabled.
  - If MAC address learning is disabled, proceed to step 3.
  - If MAC address learning enabled, proceed to step 4.
3.Execute the mac-address mac-learning enable command to enable MAC address learning, and then identify whether the alarm is cleared.
If the alarm is not cleared, proceed to step 4.
4.Collect alarm information, log information, and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
The unknown unicast traffic on the input interface drops below the set alarm threshold
Recovery
Warning
N/A (N/A)
ON
The unknown unicast traffic on the input interface drops below the set alarm threshold.
System impact
The system is not impacted.
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
N/A
Integer32
Integer32(0..100)
Threshold
N/A
Integer32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.31
This notification is generated when the BIP8 error code rate exceeds the threshold
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.32 (hh3cIfMonBip8SdErrorResume)
ON
The BIP8 error code traffic on the input interface exceeds the set alarm threshold.
System impact
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.1.20.0
hh3cIfBip8SdErrThreshold (1.3.6.1.4.1.25506.2.40.1.20.0
hh3cIfBip8SdErrThreshold)
BIP8 error code rate alarm threshold
N/A
Integer32
Recommended action
Basic information
OID
Event
Severity
Default status
This notification is generated when the BIP8 error code rate drops below the threshold
Recovery
ON
This notification is generated when the outbound PFC frame rate exceeds the early warning threshold.
System impact
Outbound PFC frames might be lost.
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.2.2.5.1.1 (hh3cIfPfcDot1pValue)
Interface queue priority.
INTEGER
0-7
1.3.6.1.4.1.25506.2.40.2.2.5.1.3 (hh3cIfPfcDot1pOutPps)
Outbound rate for a priority.
Unsigned32
1-4294967295
1.3.6.1.4.1.25506.2.40.2.2.5.1.5 (hh3cIfPfcDot1pOutPpsThreshold)
Outbound rate threshold for a priority.
Unsigned32
1-4294967295
Recommended action
1.To resolve the issue:
  - Verify that the upper threshold is set reasonably.
  - If the inbound PFC frame rate exceeds the threshold, verify that the peer device is operating properly.
  - If the outbound PFC frame rate exceeds the threshold, verify that the local device is operating properly.
  - If both the inbound PFC frame rate and outbound PFC frame rate exceed the thresholds, verify that the local device and peer device are operating properly.
2.Identify whether the upper threshold set on the interface is too low. If the threshold is too low, execute the priority-flow-control early-warning dot1p dot1p-list outpps pps-value command to modify the threshold. If the threshold is set reasonably, collect alarm information and configuration data, and then contact H3C Support.
hh3cIfLofAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.26
The OOF state stays continuously for 3 ms (the Rx line does not receive correct A1A2 bytes for 24 continuous frames).
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.27 (hh3cIfLofAlarmResume)
ON
This notification is generated when the OOF state stays continuously for 3 ms (the Rx line does not receive correct A1A2 bytes for 24 continuous frames).
The attenuation of the Rx signals is high.
The Tx signals from the remote end do not have a frame structure.
The Rx direction of the local end fails.
System impact
Services might be interrupted. The following impacts might occur:
Impact 1: After this alarm is generated, the services are interrupted, and AIS signals are inserted to the downstream devices.
Impact 2: After this alarm is generated, the system will automatically return MS_RDI alarms to the upstream devices, and the upstream devices generate MS_RDI alarms.
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
0-65535
ifIndex
OCTET STRING
Recommended action
1.If a fiber port fails:
  - Identify whether the fibers are connected incorrectly (for example, two ports at different speeds are connected), and correct the incorrect connections, if any. Identify whether the alarm is cleared.
  - Identify whether the Rx optical power of the local end is normal on NMS.
If the Rx optical power is too low, clean the optical fiber pigtail and the Rx optical interface on the line card of the local end, identify whether the flange and optical attenuator of the local end are connected correctly, and identify whether the attenuation value of the optical attenuator is too great. Connect the flange and optical attenuator correctly, and identify whether the alarm is cleared.
If the Rx optical power is too high, add an optical attenuator. Adjust the Rx optical power to the normal range. Identify whether the alarm is cleared.
  - Identify whether the Tx optical power of the remote end is normal. If the Tx optical power is normal, perform an optical fiber loopback for the line card of the local end. If the alarm is cleared on the local end, it means that the Tx signals from the remote end do not have a frame structure.
2.If a copper port fails:
  - Identify whether the cable is connected incorrectly (for example, two ports at different speeds are connected), and correct the incorrect connections, if any. Identify whether the alarm is cleared.
  - Verify that the frame format of the remote end is the same as that of the local end. Identify the alarm is cleared.
Basic information
OID
Event
Severity
Default status
This recovery notification is generated when the OOF state recovers.
Recovery
Informational
N/A (N/A)
ON
System impact
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
0-65535
ifIndex
OCTET STRING
Recommended action
hh3cIfOofAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.32
When the frame alignment signal byte cannot be determined in the input bit stream, the STM-N signal is considered as in the loss of frame alignment state.
If the frame header cannot be determined for five continuous frames, the OOF alarm is generated.
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.33 (hh3cIfOofAlarmResume)
ON
System impact
Service switchover or interruption might occur.
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
0-65535
ifIndex
OCTET STRING
Recommended action
1.Identify whether the fibers are connected incorrectly (for example, two ports at different speeds are connected), and correct the incorrect connections, if any.
2.Identify whether the Rx optical power of the local end is normal on NMS.
  - If the Rx optical power is too low, clean the optical fiber pigtail and the Rx optical interface on the line card of the local end, identify whether the flange and optical attenuator of the local end are connected correctly, and identify whether the attenuation value of the optical attenuator is too great. Connect the flange and optical attenuator correctly, and identify whether the alarm is cleared.
  - If the Rx optical power is too high, add an optical attenuator. Adjust the Rx optical power to the normal range. Identify whether the alarm is cleared.
3.Identify whether the Tx optical power of the remote end is normal. If the Tx optical power is normal, perform an optical fiber loopback for the line card of the local end. If the alarm is cleared on the local end, it means that the Tx signals from the remote end do not have a frame structure.
Basic information
OID
Event
Severity
Default status
Recovery
Informational
ON
System impact
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
0-65535
ifIndex
OCTET STRING
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.6.0.33
CRC error packet rate rising alarm
Error
Warning
1.3.6.1.4.1.25506.2.40.6.0.34 (hh3cIfMonCRCBitErrorResume)
ON
This notification is generated when the CRC error packet rate exceeds the upper threshold within the default interval.
System impact
If the shutdown keyword is specified when you set the CRC error packet rate threshold on a physical interface, the interface will be shut down and stop forwarding packets when the received CRC error packets exceed the upper threshold. The interface that is shut down due to CRC errors will not restore automatically. To restore it, execute the undo shutdown command.
If the shutdown keyword is not specified, the interface will generate an alarm exceeding the upper threshold and enter the alarm status when the received CRC error packets exceed the upper threshold.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.6.1.1 (hh3cIfMonCRCBitErrorHighThresStr)
N/A
OCTET STRING
OCTET STRING(1..255)
1.3.6.1.4.1.25506.2.40.6.1.2 (hh3cIfMonCRCBitErrorLowThresStr)
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.40.6.1.3 (hh3cIfMonCRCBitErrorRatioStr)
N/A
OCTET STRING
Recommended action
1.Verify that the fibers are connected correctly. Execute the display interface command to identify whether the specified interface is up.
  - If the interface is up, proceed to step 2.
  - If the interface is down, proceed to step 5.
2.Execute the display interface command to identify whether the Rx optical power of the local end is normal.
  - If it is normal, proceed to step 3.
  - If it is not normal, proceed to step 6.
3.Execute the display interface command to identify whether the negotiation mode, clock mode, and scrambling mode (link protocol, clock, and scramble) are the same on both ends.
  - If the configuration is the same on both ends, proceed to step 6.
  - If the configuration is different on both ends, proceed to step 4.
4.Modify the negotiation mode, clock mode, and scrambling mode (link protocol, clock, and scramble) on both ends to make them consistent. Identify whether the alarm is cleared.
If the alarm is not cleared, proceed to step 6.
5.Verify that the physical link is normal and collect the results.
6.Collect alarm information, log information, and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
CRC error packet rate recovery alarm
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the number of CRC error packets drops from above the upper threshold to below the lower threshold within the default interval.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
N/A
OCTET STRING
N/A
OCTET STRING
N/A
OCTET STRING
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.63
The port does not forward packets but receives pause frames, or the port sends pause frames but does not receive packets
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.64 (hh3cIfFlowControlDLAlarmResume)
ON
This notification is generated in either of the following conditions:
The port does not forward packets, but receives a large number of pause frames.
The port continuously sends a large number of pause frames, but does not receive packets.
System impact
An interface cannot forward packets.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
To resolve this issue, collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
The port does not forward packets or receive pause frames, or the port sends pause frames and receives packets
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the port sends pause frames and receives packets or the port does not forward packets or receive pause frames.
System impact
Status control
The interface is unable to forward the packets.
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.65
Some service data on the port is dropped
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.66 (hh3cIfOutputErrorAlarmResume)
ON
This notification is generated if the optical transceiver module or optical fiber fails.
System impact
Some service data on the port is dropped.
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.1.7 (hh3cIfSlotIndex)
Card index.
N/A
Integer32
0-65535
1.3.6.1.4.1.25506.2.40.1.8 (hh3cIfSubSlotIndex)
Subcard index.
N/A
Integer32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
No service data is dropped on the port.
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the optical transceiver module or optical fiber recovers and the service data on the port restores.
System impact
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Card index.
N/A
Integer32
0-65535
Subcard index.
N/A
Integer32
0-65535
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.67
The network cable quality is poor or signal interference occurs
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.68 (hh3cIfCableSnrNormal)
ON
This notification is generated when a multiGE copper port operates at 2.5 Gbps or higher and the network cable quality is poor or signal interference occurs.
System impact
Packet loss might occur.
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
1.Replace the current cable with a higher-quality cable, for example, category 6A cable or shielded cable.
2.Execute the speed { 100 | 1000 } or auto speed { 100 | 1000 } command to set a lower speed for the multiGE interface.
Basic information
OID
Event
Severity
Default status
The network cable quality is good and no signal interference occurs
Recovery
Informational
N/A (N/A)
ON
This notification is generated when a multiGE copper port operates at 2.5 Gbps or higher, the network cable quality is good, and no signal interference occurs.
System impact
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.69
A multiGE interface in up state goes down
Informational
Warning
N/A (N/A)
ON
This notification is generated when the network cable quality cannot be detected and a multiGE interface in up state goes down.
System impact
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
1.The network cable quality cannot be detected. Replace the network cable.
2.Collect alarm information and configuration data, and then contact H3C Support.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.70
A transceiver module inserted into an interface does not support single fiber communication
Informational
Warning
N/A (N/A)
ON
This notification is generated when a transceiver module inserted into an interface does not support single fiber communication.
System impact
The single fiber communication function cannot be used on the interface because of the transceiver module inserted into the interface.
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
To resolve this issue, replace the transceiver module with a transceiver module that supports single fiber communication.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.71
The interface does not support LRM transceiver modules
Informational
Warning
N/A (N/A)
ON
This notification is generated when the transceiver module inserted into an interface does not support LRM transceiver modules.
System impact
The transceiver module is not available, and the service of the interface is interrupted.
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
1.Execute the display transceiver command to view the type of the transceiver module installed in the interface.
2.Replace the transceiver module with a non-LRM transceiver module.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.72
A GE transceiver module installed in an XGE interface can operate only at non-autonegotiated 1000 Mbps
Informational
Warning
N/A (N/A)
ON
This notification is generated when a GE transceiver module installed in an XGE interface can operate only at non-autonegotiated 1000 Mbps and the interconnect interface is manually configured to operate at 1000 Mbps.
System impact
After an XGE interface has a GE transceiver module installed, the autonegotiation function of the interface is unavailable.
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
Recommended action
To resolve this issue, manually configure the interconnect interface to operate at 1000 Mbps.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.73
PFC deadlock might cause traffic interruption on the network
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.74 (hh3cIfPfcDeadLockResume)
ON
This notification is generated when PFC deadlock occurs.
System impact
Traffic interruption might occur on the network.
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
1.3.6.1.4.1.25506.2.40.2.2.6.1.1 (hh3cIfQueId)
ID of an interface's buffer queue.
hh3cIfQueId
INTEGER
que0(1),, que1(2),, que2(3),, que3(4),, que4(5),, que5(6),, que6(7),, que7(8)
Recommended action
1.Execute the display priority-flow-control command to identify the PFC deadlock reasons on the network and optimize the network. If this issue persists on the network, proceed with step 2.
2.Execute the priority-flow-control deadlock cos cos-value interval interval command to adjust the PFC deadlock detection interval to meet the actual network requirements.
Basic information
OID
Event
Severity
Default status
PFC deadlock recovers, and traffic is forwarded
Recovery
Informational
N/A (N/A)
ON
This notification is generated when PFC deadlock recovers and traffic can be normally forwarded.
System impact
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
hh3cIfQueId
INTEGER
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.75
The number of PFC deadlock times exceeds the threshold for automatically disabling PFC
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.76 (hh3cIfPfcTurnOffResume)
ON
This notification is generated when the number of PFC deadlock times within a detection period exceeds the threshold for automatically disabling PFC.
System impact
PFC is automatically disabled.
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
hh3cIfQueId
INTEGER
Recommended action
2.Execute the priority-flow-control deadlock cos cos-value interval interval command to adjust the PFC deadlock detection interval and execute the priority-flow-control deadlock threshold cos cos-value period period count count command to adjust the number of PFC deadlock times for automatically disabling PFC to meet the actual network requirements.
3.If the PFC deadlock has been removed from the network, first execute the undo priority-flow-control enable command to disable PFC and then execute the priority-flow-control enable command to enable PFC on the interface, so that PFC is applied again.
Basic information
OID
Event
Severity
Default status
The number of PFC deadlock times is lower than the threshold for automatically disabling PFC
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the number of PFC deadlock times within a detection period is lower than the threshold for automatically disabling PFC.
System impact
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
hh3cIfQueId
INTEGER
Recommended action
hh3cIfQueueAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.77
The usage of a queue on an interface exceeds the threshold configured on the interface
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.78 (hh3cIfQueueResume)
ON
This notification is generated when the usage of a queue on an interface exceeds the threshold configured on the interface.
System impact
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
hh3cIfQueId
INTEGER
1.3.6.1.4.1.25506.2.40.30.0 (hh3cIfCurrentUsedRatio)
Current queue usage
N/A
Unsigned32
Unsigned32 (0..4294967295)
1.3.6.1.4.1.25506.2.40.31.0 (hh3cIfUsedRatioThershold)
Queue usage threshold
N/A
Unsigned32
Recommended action
hh3cIfQueueResume
Basic information
OID
Event
Severity
Default status
The usage of a queue on an interface drops below the threshold configured on the interface
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the usage of a queue on an interface drops below the threshold configured on the interface.
System impact
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
hh3cIfQueId
INTEGER
Current queue usage
N/A
Unsigned32
N/A
Unsigned32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.40.3.0.79
The number of dropped packets, the number of dropped bytes, or the packet loss ratio of a port queue exceeds the alarm threshold
Error
Warning
1.3.6.1.4.1.25506.2.40.3.0.80 (hh3cIfQueueStatDiscardResume)
ON
This notification is generated when the number of dropped packets, the number of dropped bytes, or the packet loss ratio of a port queue exceeds the alarm threshold.
System impact
Packet loss occurs, and services on the interface might be impacted.
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
hh3cIfQueId
INTEGER
1.3.6.1.4.1.25506.2.40.31.0 (hh3cIfDiscardType)
Packet loss type
N/A
INTEGER
discardstat(1), discardByte(2), discardrate(3)
1.3.6.1.4.1.25506.2.40.31.0 (hh3cIfDiscardThreshold)
Packet loss threshold
N/A
Counter64
Counter64, (0..18446744073709551615)
Recommended action
Basic information
OID
Event
Severity
Default status
The number of dropped packets, the number of dropped bytes, or the packet loss ratio of a port queue drops below the alarm threshold
Recovery
Informational
N/A (N/A)
ON
This notification is generated when the number of dropped packets, the number of dropped bytes, or the packet loss ratio of a port queue drops below the alarm threshold.
System impact
Status control
Object
OID (object name)
Index
Value range
Interface index.
ifIndex
Integer32
ifIndex
OCTET STRING
hh3cIfQueId
INTEGER
Packet loss type
N/A
INTEGER
N/A
Counter64
Recommended action
