07-Layer 3 - IP Routing
HomeSupportRoutersCR16000-M SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-M Routers Alarm Reference-R838x-6W10007-Layer 3 - IP Routing
12-OSPFV3-MIB
12-OSPFV3-MIB 116.30 KB
OSPFV3-MIB
About this MIB
Use this MIB to obtain OSPFv3 information.
MIB file name
rfc5643-ospfv3.mib
Notifications
ospfv3VirtIfStateChange
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.191.0.1
Virtual interface state changes.
Informational
Informational
N/A (N/A)
ON
Notification triggers
This notification is generated when the state of a virtual interface changes to Point-to-Point or changes from Point-to-Point to another state. To reduce unnecessary notifications caused by virtual interface up events, no virtual interface state change notification will be sent within 2 times the dead interval since the virtual interface state changes to a value other than DOWN.
This issue occurs when one of the following conditions exists:
The state of a virtual interface changes from P2P to Down, or from Down to P2P.
The router ID of a virtual link neighbor changes.
System impact
If the state of a virtual interface changes from Down to P2P, it has no negative impact on services.
If the state of a virtual interface changes from P2P to Down, the virtual interface will be disconnected and OSPFV3 route calculation will fail. Services might be interrupted.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtif-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtif-state-change command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.191.1.1.1
 (ospfv3RouterId)
Unique identifier of a router in an AS.
N/A
Ospfv3RouterIdTC
Unsigned32 (1..'FFFFFFFF'h)
1.3.6.1.2.1.191.1.8.1.9 (ospfv3VirtIfState)
Virtual interface state.
ospfv3VirtIfAreaId
ospfv3VirtIfNeighbor
INTEGER
down(1), pointToPoint(4)
Recommended action
To resolve this issue:
1.Use the display ospfv3 vlink command to view the state of the virtual interface.
  - If the state of the virtual interface changes from Down to P2P, no action is required.
  - If the state of the virtual interface changes from P2P to Down, proceed to step 2.
2.Use the display ospfv3 spf-tree command to identify whether the flags of the SPF node corresponding to the neighbor router ID of the virtual interface include the S flag. This flag indicates that the neighbor is reachable.
  - If yes, check whether the virtual interface settings are configured correctly on both the local end and the remote end.
  - If no, check for the cause of the unreachability.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfv3NbrStateChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.2
Neighbor state changes.
Informational
Informational
N/A (N/A)
ON
For DR and BDR, this notification is generated when the state of a neighbor changes to FULL or changes from FULL to another state. For DRother, this notification is sent when the state of a neighbor changes to 2-way or changes from 2-way to another state.
To reduce unnecessary notifications caused by interface up events, no neighbor state change notification will be sent within 2 times the dead interval since the interface state changes to a value other than DOWN.
The state of a neighbor changes from Attempt or any other state to 1-Way or Down, or from Down or any other state to 2-Way or Full.
The local and remote ends have different interface settings (such as the hello timer, dead timer, and authentication settings).
OSPFv3 is restarted by the reset ospfv3 process command.
The state of a neighbor in an NBMA or broadcast network changes from Full to another state or changes from another state to Full.
System impact
The process of OSPFv3 neighbor establishment involves a series of neighbor state changes, including Down, Attempt, Init, 2-Way, ExStart, Exchange, Loading, and Full.
If the state of a neighbor progresses, it has no negative impact on services.
If the state of a neighbor regresses, services might be interrupted.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 neighbor-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 neighbor-state-change command.
Object
OID (object name)
Index
Value range
 (ospfv3RouterId)
N/A
Ospfv3RouterIdTC
1.3.6.1.2.1.191.1.9.1.8 (ospfv3NbrState)
Neighbor state.
ospfv3NbrIfIndex
ospfv3NbrIfInstId
ospfv3NbrRtrId
INTEGER
down(1), attempt(2), init(3), twoWay(4), exchangeStart(5), exchange(6), loading(7), full(8)
Recommended action
1.Use the display ospfv3 peer command to view the state of the neighbor. You can view the State field in the command output.
  - If the neighbor state is Full, no action is required.
  - If the neighbor state is not Full, proceed to step 2.
2.Use the display interface interface-type interface-number command to view the state of the neighbor-facing interface on the local end.
  - If the interface is up, proceed to step 3.
  - If the neighbor interface is down, check whether the shutdown command is executed on the interface.
If yes, execute the undo shutdown command on the interface, and then proceed to step 3.
If no, proceed to step 3.
3.Use the ping command to identify whether the IPv6 address of the remote interface is reachable.
  - If yes, proceed to step 4.
  - If no, proceed to step 6.
4.Use the display ospfv3 interface command to view the state of the OSPFv3 interface. You can view the State field in the command output.
  - If the neighbor-facing interface is down, proceed to step 6.
  - If the neighbor-facing interface is not down, proceed to step 5.
5.Use the display ospfv3 interface verbose command to check whether the local and remote ends use the same interface settings, including the hello timer, dead timer, poll timer, OSPFv3 network type, and authentication settings.
  - If yes, proceed to step 6.
  - If no, use the following commands to modify inconsistent interface settings and make sure that the local and remote ends use the same interface settings.
ospfv3 timer hello
ospfv3 timer dead
ospfv3 timer poll
ospfv3 network-type
ospfv3 authentication-mode
6.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfv3VirtNbrStateChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.3
Virtual neighbor state changes.
Informational
Informational
N/A (N/A)
ON
This notification is generated when the state of a virtual neighbor changes to FULL or changes from FULL to another state. To reduce unnecessary notifications caused by virtual interface up events, no virtual neighbor state change notification will be sent within 2 times the dead interval since the virtual interface state changes to a value other than DOWN.
The state of a virtual neighbor regresses (for example, changing from Full to 1-Way or Down) or progresses to the final state (for example, Full).
The state of the physical interface on which the virtual link is established changes.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtneighbor-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtneighbor-state-change command.
Object
OID (object name)
Index
Value range
 (ospfv3RouterId)
N/A
Ospfv3RouterIdTC
1.3.6.1.2.1.191.1.11.1.8 (ospfv3VirtNbrState)
Virtual neighbor state.
ospfv3VirtNbrArea
ospfv3VirtNbrRtrId
INTEGER
Recommended action
1.Use the display ospfv3 interface and display ipv6 interface brief commands to view the state of the physical interface on which the virtual link is established.
  - If the physical state of the interface is Down, check whether the interface has been shut down.
If yes, execute the undo shutdown command on the interface, and then proceed to step 2.
If no, proceed to step 2.
  - If the link layer protocol state of the interface is Up, proceed to step 2.
2.Use the display ospfv3 peer command to view the state of the neighbor.
  - If the State field displays Full, proceed to step 3.
  - If the State field does not display Full, proceed to step 5.
3.Use the display ospfv3 spf-tree command to identify whether the flags of the SPF node corresponding to the neighbor router ID of the virtual interface include the S flag. This flag indicates that the neighbor is reachable.
  - If no, proceed to step 5.
4.Use the display ospfv3 vlink and display current-configuration configuration ospfv3 commands to identify whether the local and remote ends use the same settings, such as the hello timer, dead timer, and poll timer.
  - If yes, proceed to step 5.
  - If no, use the vlink-peer command to configure the same settings for both the local and remote ends, and then check whether the notification is cleared.
If yes, the troubleshooting is complete.
5.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfv3IfConfigError
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.4
Interface configuration error.
Informational
Informational
N/A (N/A)
ON
This notification is generated when a non-virtual interface receives a packet from another router with mismatched configuration. This issue occurs when one of the following conditions exists:
The local interface and the remote interface use different interface settings.
The link layer protocol changes.
System impact
This issue typically has no negative impact as long as the local interface and the remote interface use the same settings after configuration correction.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 if-cfg-error command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 if-cfg-error command.
Object
OID (object name)
Index
Value range
 (ospfv3RouterId)
N/A
Ospfv3RouterIdTC
1.3.6.1.2.1.191.1.7.1.12
 (ospfv3IfState)
Interface state.
ospfv3IfIndex
ospfv3IfInstId
INTEGER
down(1), loopback(2), waiting(3), pointToPoint(4), designatedRouter(5), backupDesignatedRouter(6), otherDesignatedRouter(7), standby(8)
1.3.6.1.2.1.191.1.14.3
 (ospfv3PacketSrc)
IPv6 packet that cannot be identified by a neighbor.
N/A
InetAddressIPv6
OCTET STRING (16)
1.3.6.1.2.1.191.1.14.1
 (ospfv3ConfigErrorType)
OSPFv3 configuration error type.
N/A
INTEGER
badVersion(1), areaMismatch(2), unknownNbmaNbr(3), unknownVirtualNbr(4), helloIntervalMismatch(5), deadIntervalMismatch(6), optionMismatch(7), mtuMismatch(8), duplicateRouterId(9), noError(10)
1.3.6.1.2.1.191.1.14.2 (ospfv3PacketType)
OSPFv3 data packet type.
N/A
INTEGER
hello(1), dbDescript(2), lsReq(3), lsUpdate(4), lsAck(5), nullPacket(6)
Recommended action
1.Use the display ospfv3 interface interface-type interface-number command to identify whether the local OSPFv3 interface and the remote OSPFv3 interface use the same settings.
  - If yes, proceed to step 3.
  - If no, proceed to step 2.
2.Perform the following tasks to clear the notification:
Use the following commands to reconfigure the local or remote OSPFv3 interface, ensuring that the two interfaces use the same settings:
ospfv3 timer hello
ospfv3 timer dead
ospfv3 timer poll
Identify whether the notification is cleared:
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
ospfv3VirtIfConfigError
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.5
Virtual interface configuration error.
Informational
Warning
N/A (N/A)
ON
This notification is generated when an OSPFv3 virtual interface on a router receives a packet from another router with mismatched configuration. This issue occurs when the interface settings on the ends of a virtual link are not the same.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtif-cfg-error command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtif-cfg-error command.
Object
OID (object name)
Index
Value range
 (ospfv3RouterId)
N/A
Ospfv3RouterIdTC
 (ospfv3VirtIfState)
ospfv3VirtIfAreaId
INTEGER
N/A
INTEGER
N/A
INTEGER
Recommended action
1.Use the display ospfv3 vlink and display current-configuration configuration ospfv3 commands to identify whether the two ends of the virtual link use the same interface settings.
2.Use the vlink-peer command to reconfigure an end of the virtual link, ensuring that the two ends of the virtual link use the same settings. Then, identify whether the notification is cleared:
  - If yes, the troubleshooting is complete.
  - If no, proceed to step 3.
ospfv3IfRxBadPacket
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.6
A non-virtual interface receives an error packet.
Informational
Warning
N/A (N/A)
ON
This notification is generated when a non-virtual interface receives an OSPFv3 packet that cannot be parsed. This issue occurs when one of the following conditions exists:
The length of the OSPFv3 packet is incorrect.
The OSPFv3 packet has content errors.
System impact
When a non-virtual interface receives an OSPFv3 packet that cannot be parsed, it discards the packet. If the packet is a hello packet, the neighbor that sends the packet might go down.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 if-bad-pkt command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 if-bad-pkt command.
Object
OID (object name)
Index
Value range
 (ospfv3RouterId)
N/A
Ospfv3RouterIdTC
 (ospfv3IfState)
Interface state.
ospfv3IfIndex
ospfv3IfInstId
INTEGER
 (ospfv3PacketSrc)
IPv6 packet that cannot be identified by the neighbor.
N/A
InetAddressIPv6
OCTET STRING (16)
N/A
INTEGER
Recommended action
Collect alarm information and configuration data, and then contact H3C Support for help.
ospfv3VirtIfRxBadPacket
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.7
A virtual interface receives an error packet.
Informational
Informational
N/A (N/A)
ON
This notification is generated when a virtual interface receives an OSPFv3 packet that cannot be parsed. This issue occurs when one of the following conditions exists:
System impact
When a virtual interface receives an OSPFv3 packet that cannot be parsed, it discards the packet. If the packet is a hello packet, the neighbor that sends the packet might go down.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtif-bad-pkt command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtif-bad-pkt command.
Object
OID (object name)
Index
Value range
 (ospfv3RouterId)
N/A
Ospfv3RouterIdTC
 (ospfv3VirtIfState)
ospfv3VirtIfAreaId
INTEGER
N/A
INTEGER
Recommended action
ospfv3IfStateChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.10
Interface state changes.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the state of a non-virtual interface changes from DR to Down or changes to the Point-to-Point, DR, BDR, or DRother state. This issue occurs when one of the following conditions exists:
The physical interface comes up or goes down.
The router priority for the interface changes and DR/BDR election is performed.
System impact
This issue might affect the state of neighbors. If the state of an OSPFv3 interface regresses (for example, changing to Down), it will be disconnected from its neighbors.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 if-state-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 if-state-change command.
Object
OID (object name)
Index
Value range
 (ospfv3RouterId)
N/A
Ospfv3RouterIdTC
1.3.6.1.2.1.191.1.7.1.12 (ospfv3IfState)
Interface state.
ospfv3IfIndex
ospfv3IfInstId
INTEGER
Recommended action
1.Use the display ospfv3 interface command to view the interface state.
  - If the interface state is Down, proceed to step 2.
  - If the interface state is not Down, no action is required.
2.Use the display interface interface-type interface-number command to view the state of the interface.
  - If the interface is in up, proceed to step 3.
  - If the interface is not up, check whether the interface has been shut down.
If yes, execute the undo shutdown command on the interface.
ospfv3NssaTranslatorStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.11
A router's ability to translate type-7 LSAs into type-5 LSAs changes.
Informational
Warning
N/A (N/A)
ON
This notification is generated when a router's ability to translate OSPFv3 type-7 LSAs into OSPFv3 type-5 LSAs changes. This issue occurs when one of the following conditions exists:
The translate-always keyword of the nssa command is configured or canceled on an NSSA ABR.
An NSSA ABR has been configured with a new router ID and the change is already in effect.
The device becomes an ABR or its role changes from ABR to another.
System impact
When the translator in an NSSA area changes, the former translator must flush the Type-5 LSAs translated from Type-7 LSAs and the new translator translates new OSPFv3 type-7 LSAs into OSPFv3 type-5 LSAs. This might cause temporary AES route flapping.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 nssatranslator-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 nssatranslator-status-change command.
Object
OID (object name)
Index
Value range
 (ospfv3RouterId)
N/A
Ospfv3RouterIdTC
1.3.6.1.2.1.191.1.2.1.12 (ospfv3AreaNssaTranslatorState)
Method for the NSSA ABR to become capable of translating Type-7 LSAs into Type-5 LSAs.
ospfv3AreaId
INTEGER
enabled(1), elected(2), disabled(3)
Recommended action
1.If the nssa translate-always command is configured on the local device, use the display ospfv3 command to identify whether the 7/5 translator state field displays Enabled.
  - If yes, no action is required.
  - If no, proceed to step 7.
If the nssa translate-always command is canceled on the local device, use the display ospfv3 command to identify whether the 7/5 translator state field displays Disabled.
  - If the 7/5 translator state field displays Disabled, proceed to step 2.
  - If the 7/5 translator state field displays Elected, no action is required.
2.Use the display ospfv3 lsdb router command to identify whether the Options field in the router LSAs of an NSSA ABR contains the Nt bit.
3.If the local device has been configured with a new router ID and the change is already in effect, identify whether the NSSA translator role is correct after the network topology is stable.
  - If no, proceed to step 4.
4.Identify whether other NSSA ABRs have been configured with new router IDs. After the network topology is stable, identify whether one of the new router IDs is larger than the local router ID.
5.If a new NSSA ABR has been added in the area, identify whether the router ID of the new NSSA ABR is larger than the local router ID after the network topology is stable.
If the new device is not an ABR, proceed to step 6.
6.Check whether the ospfv3NbrStateChange or ospfv3IfStateChange notification is generated on the local and neighbor devices.
  - If yes, perform the recommended actions to clear the notification.
7.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfv3RestartStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.12
GR restarter state changes.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the state of the GR restarter changes. This issue occurs when one of the following conditions exists:
The device stops GR.
The device starts GR.
System impact
If the state of the GR restarter changes due to a GR failure, this issue will affect services.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 grrestarter-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 grrestarter-status-change command.
Object
OID (object name)
Index
Value range
 (ospfv3RouterId)
N/A
Ospfv3RouterIdTC
1.3.6.1.2.1.191.1.1.18
 (ospfv3RestartStatus)
GR restarter state.
N/A
INTEGER
notRestarting(1), plannedRestart(2), unplannedRestart(3)
1.3.6.1.2.1.191.1.1.16
 (ospfv3RestartInterval)
GR timeout interval.
N/A
Ospfv3UpToRefreshIntervalTC
Unsigned32 (40..1800)
1.3.6.1.2.1.191.1.1.20 (ospfv3RestartExitReason)
Reason why the device exited GR restarter state.
N/A
INTEGER
none(1), inProgress(2), completed(3), timedOut(4), topologyChanged(5)
Recommended action
1.If you are manually performing an active/standby switchover or restarting the OSPFv3 process with GR, no action is required. Otherwise, proceed to step 2.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
ospfv3NbrRestartHelperStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.13
The GR helper state of a neighbor changes.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the GR helper state of a neighbor changes. This issue occurs when one of the following conditions exists:
The neighbor becomes the GR helper.
The neighbor stops being the GR helper.
System impact
If the GR helper state of a neighbor changes due to a GR failure, this issue will affect services.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 grhelper-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 grhelper-status-change command.
Object
OID (object name)
Index
Value range
 (ospfv3RouterId)
N/A
Ospfv3RouterIdTC
1.3.6.1.2.1.191.1.9.1.13
 (ospfv3NbrRestartHelperStatus)
GR helper state of the neighbor.
ospfv3NbrIfIndex
ospfv3NbrIfInstId
ospfv3NbrRtrId
INTEGER
notHelping(1), helping(2)
1.3.6.1.2.1.191.1.9.1.14
 (ospfv3NbrRestartHelperAge)
GR helper aging timer.
ospfv3NbrIfIndex
ospfv3NbrIfInstId
ospfv3NbrRtrId
Unsigned32 (1..1800)
1.3.6.1.2.1.191.1.9.1.15 (ospfv3NbrRestartHelperExitReason)
Reason why the neighbor exited GR helper state.
ospfv3NbrIfIndex
ospfv3NbrIfInstId
ospfv3NbrRtrId
INTEGER
Recommended action
ospfv3VirtNbrRestartHelperStatusChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.191.0.14
The GR helper state of a virtual neighbor changes.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the GR helper state of a virtual neighbor changes. This issue occurs when one of the following conditions exists:
The virtual neighbor becomes the GR helper.
The virtual neighbor stops being the GR helper.
System impact
If the GR helper state of a virtual neighbor changes due to a GR failure, this issue will affect services.
Status control
ON
CLI: Use the snmp-agent trap enable ospfv3 virtgrhelper-status-change command.
OFF
CLI: Use the undo snmp-agent trap enable ospfv3 virtgrhelper-status-change command.
Object
OID (object name)
Index
Value range
 (ospfv3RouterId)
N/A
Ospfv3RouterIdTC
1.3.6.1.2.1.191.1.11.1.13
 (ospfv3VirtNbrRestartHelperStatus)
GR helper state of the virtual neighbor.
ospfv3VirtNbrArea
ospfv3VirtNbrRtrId
INTEGER
1.3.6.1.2.1.191.1.11.1.14
 (ospfv3VirtNbrRestartHelperAge)
Remaining time of the GR interval when the router is acting as a GR helper for the virtual neighbor.
ospfv3VirtNbrArea
ospfv3VirtNbrRtrId
1.3.6.1.2.1.191.1.11.1.15 (ospfv3VirtNbrRestartHelperExitReason)
Reason why the virtual neighbor exited GR helper state.
ospfv3VirtNbrArea
ospfv3VirtNbrRtrId
INTEGER
Recommended action
