Title | Size | Downloads |
RS3M2C10S02004.zip | 67.72 KB | |
H3C UniServer R4900 G6 System Board SCPLD V004 Release Notes.xlsx.zip | 7.14 KB | |
H3C UniServer R4900 G6 System Board SCPLD V004 Release Notes.pdf | 700.38 KB |
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Version information
Version number
Supported languages
Supported hardware platforms
Hardware and software compatibility matrix
(Optional) Version compatibility with ISSU
Update recommendation
Update restrictions and guidelines
Hardware feature updates
Software feature and command updates
V004
MIB updates
Operation changes
Open problems and workarounds
List of resolved problems
Resolved problems in V004
Troubleshooting
Related documentation
Documentation set
Obtaining documentation
Technical support
List of tables
Table 1 Version history
Table 2 Hardware and software compatibility matrix for H3C UniServer R4900 G6
Table 3 Hardware features
This document describes the features, restrictions and guidelines, open problems, and workarounds for version V004. Before you use this version on a live network, back up the configuration and test the version to avoid software update affecting your live network.
Use this document in conjunction with the documents listed in "Related documentation."
Version information
Version number
CPLD version: V004
| NOTE: To view the CPLD version of a drive backplane, access the HDM Web interface of the server, navigate to System > Summary > Others page, as shown in Figure 1 The figure is for illustration only. |
Version number | Last version | Release date | Version type | Remarks |
V004 | First release | 2023-07-30 |
| N/A |
Supported languages
English.
Chinese.
CAUTION: To avoid an update failure, use the following table to verify the hardware and software compatibility before performing an update. |
Table 3 Hardware and software compatibility matrix for H3C UniServer R4900 G6
Item | Specifications |
Product family | H3C UniServer R4900 G6 |
Ultra system board MCPLD | V004 or later |
Ultra system board SCPLD | V004 or later |
Ultra system board VR | V002 or later |
HDM | 1.54 or later |
BIOS | 6.00.23 or later |
Image file name and MD5 value | RS3M2C10S02004.bin:ef0097d966b1cab42587cc12077ce296 (Subject to change according to the latest naming conventions) |
Remarks | N/A |
None.
This version is required for update.
Make sure the server and the HDM client (such as a PC) can reach each other.
For a successful bulk update, make sure you can update one server successfully before you update the remaining servers.
During the update, make sure the network connection is available and do not refresh the webpage.
Do not refresh the page during the update.
To avoid CPLD or operating system errors, do not power on or power off the server during the firmware update.
After the firmware is updated, clear the browser cache before you re-log in to HDM.
None.
V004
None.
MIB updates
N/A.
Operation changes
None.
Make sure the HDM version is 1.54 or later.
None.
202306250162
Symptom: If PMIC DIMMs of the TI manufacturer are used, BIOS initialization gets stuck.
Condition: This symptom might occur if the CPLD version is V003 and PMIC DIMMs of the TI manufacturer are used together with PMIC DIMMs of other manufacturers.
202306250486
Symptom: The health LED on the chassis ear flashes red when no HDM alarm is present.
Condition: This symptom might occur if a PSU with specific errors are installed.
202304010586
Symptom: HDM displays N/A for hot swapped OCP network adapters of specific models.
Condition: This symptom might occur if you hot swap OCP network adapters of specific models.
Troubleshooting
To obtain troubleshooting information, access the H3C official website at https://www.h3c.com/en/Support/Resource_Center/EN/Home/Severs/00-Public/Diagnose___Maintain/Troubleshooting/H3C_Servers_TG/.
Documentation set
H3C Servers Firmware Update Guide
H3C Servers HDM User Guide
Access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com:
1.Click https://www.h3c.com/en/Support/Resource_Center/Technical_Documents/.
2.Select a product category and model to obtain the documentation of the product.
Technical support
Email: [email protected]
Telephone: 400-810-0504
Website: http://www.h3c.com
Item | Description |
Module name | 2U rack server system board with two processor sockets |
Module version | RS36M2C10S VC |
Module number | 0302A6UB |
Max rate | 32 GT/s |
Operating temperature | 5°C to 45°C (41°F to 113°F) |
Operating humidity | 8 to 90% RH, non-condensing |
N/A
Use this section to update CPLD when you can access HDM for the server from the RJ-45 port.
Hardware and software requirements
The following hardware and software requirements must be met:
A CP with an RJ-45 port.
A browser is installed.
None.
Before uploading the version file for update, first verify that the MD5 checksum is correct.
Screenshots in this section are for illustration only.
Updating the CPLD firmware online
1.Connect the RJ-45 port on the local PC to the network port on the server for HDM access.
2.Configure local area connection properties to specify a local IP address that is on the same network segment as the management address of HDM.
Entering the username and password
Enter the management address of HDM, for example, 192.168.1.2, in the browser, and enter the username and password.
The default settings are as follows:
Username: admin
Password: Password@_
1.On the HDM Web interface, select Firmware & Software > Update Firmware. Then, click Browse to select and upload an image file in BIN format.
2.Click Next. Select the firmware to be updated and then click Next. Update the firmware as instructed.
3.Confirm the update operation.
Figure 2 Update progress
Figure 3 Update completed
4.Use either method to make the new firmware version take effect:
Remove the AC power from the device for 30 seconds and then power on the device.
Access the Firmware & Software > Restart Firmware page on HDM, and restart CPLD.
Handling firmware update failures
If a firmware update fails, the system starts up with the original firmware version. To resolve the firmware update failure issue:
1.Verify that the physical interfaces are connected correctly.
2.Verify that the firmware image file is correct.
3.Verify that the server is not powered off during the update.
4.For the firmware update to take effect, restart the server.
