15-VXLAN Command Reference
HomeSupportSwitchesS12500X-AF SeriesReference GuidesCommand ReferencesH3C S12500X-AF Switch Series Command References(R28xx)-6W10115-VXLAN Command Reference
Table of Contents
Related Documents
01-VXLAN commands
01-VXLAN commands 409.63 KB
VXLAN commands· 1
Basic VXLAN commands· 1
ac statistics enable· 1
arp suppression enable· 1
bandwidth (Ethernet service instance view) 2
bandwidth (VSI view) 3
description· 4
display arp suppression vsi 4
display hardware-resource source-udp-port 6
display hardware-resource vxlan· 6
display igmp host group· 8
display ipv6 nd suppression vsi 9
display l2vpn mac-address· 11
display l2vpn mac-address mac-move· 13
display l2vpn service-instance· 14
display l2vpn vsi 16
display statistic mode· 20
display vxlan tunnel 20
emulate-ping vxlan· 21
encapsulation· 23
flooding disable (Ethernet service instance view) 25
flooding disable (VSI view) 26
forwarding mode· 27
group· 28
hardware-resource source-udp-port 29
hardware-resource vxlan· 30
igmp host enable· 31
ipv6 nd suppression enable· 32
l2vpn enable· 32
l2vpn statistics interval 33
learning mode· 33
mac-address static vsi 35
reserved vxlan· 36
reset arp suppression vsi 37
reset ipv6 nd suppression vsi 37
reset l2vpn mac-address· 38
reset l2vpn mac-address mac-move· 38
reset l2vpn statistics ac· 39
reset l2vpn statistics vsi 39
restrain· 40
rewrite inbound tag· 41
rewrite outbound tag· 42
selective-flooding mac-address· 43
service-instance· 44
shutdown· 45
statistic mode· 45
statistics enable (Ethernet service instance view) 46
statistics enable (VSI view) 47
tunnel 47
tunnel bfd enable· 49
tunnel global source-address· 50
vlan-forwarding static· 51
vsi 51
vxlan· 52
vxlan default-decapsulation· 53
vxlan invalid-udp-checksum discard· 54
vxlan invalid-vlan-tag discard· 54
vxlan ip-forwarding· 55
vxlan local-mac report 56
vxlan tunnel mac-learning disable· 57
vxlan udp-port 57
vxlan vlan-based· 58
vxlan vni 59
xconnect vsi 60
VXLAN IP gateway commands· 61
arp distributed-gateway dynamic-entry synchronize· 61
arp send-rate· 62
bandwidth· 63
default 63
description· 64
display interface vsi-interface· 64
distributed-gateway local 67
gateway subnet 68
gateway vsi-interface· 69
interface vsi-interface· 70
ipv6 nd distributed-gateway dynamic-entry synchronize· 70
mac-address· 71
mtu· 72
reset counters interface vsi-interface· 72
shutdown· 73
vtep group member local 74
vtep group member remote· 74
vxlan tunnel arp-learning disable· 75
vxlan tunnel nd-learning disable· 76
OVSDB commands· 76
ovsdb server bootstrap ca-certificate· 76
ovsdb server enable· 77
ovsdb server pki domain· 78
ovsdb server pssl 78
ovsdb server ptcp· 79
ovsdb server ssl 80
ovsdb server tcp· 81
vtep access port 82
vtep acl disable· 83
vtep enable· 83
vxlan tunnel flooding-proxy· 84
VXLAN commands
Use ac statistics enable to enable packet statistics for Ethernet service instances of a VLAN.
Use undo ac statistics enable to disable packet statistics for Ethernet service instances of a VLAN.
The packet statistics feature is disabled for Ethernet service instances of a VLAN.
VLAN view
This command enables packet statistics for the Ethernet service instances automatically created for VLAN-based VXLAN assignment.
Before you enable this feature, you must use the vxlan vlan-based command to enable VLAN-based VXLAN assignment.
# Map VLAN 10 to VXLAN 100, and enable packet statistics for Ethernet service instances of VLAN 10.
[Sysname] vxlan vlan-based
[Sysname] vlan 10
[Sysname-vlan10] vxlan vni 100
[Sysname-vlan10] ac statistics enable
vxlan vlan-based
Use arp suppression enable to enable ARP flood suppression.
Use undo arp suppression enable to disable ARP flood suppression.
ARP flood suppression is disabled.
VSI view
ARP flood suppression reduces ARP request broadcasts by enabling the VTEP to reply to ARP requests on behalf of VMs.
This feature snoops ARP packets to populate the ARP flood suppression table with local and remote MAC addresses. If an ARP request has a matching entry, the VTEP replies to the request on behalf of the VM. If no match is found, the VTEP floods the request to both local and remote sites.
# Enable ARP flood suppression for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] arp suppression enable
Use bandwidth to set the bandwidth limit for an Ethernet service instance.
bandwidth bandwidth
undo bandwidth
No bandwidth limit is set for an Ethernet service instance.
bandwidth: Specifies a bandwidth limit in kbps. The value range for this argument is 64 to 4194303.
The bandwidth limit takes effect only on incoming traffic. An Ethernet service instance drops excess incoming traffic when its bandwidth limit is reached.
If you use the bandwidth command for both an Ethernet service instance and its mapped VSI, the Ethernet service instance bandwidth is limited exclusively from the VSI bandwidth. For example, VSI vsi1 has AC 1, AC 2, AC 3, and Tunnel 1. The bandwidth limit of VSI vsi1 is 500 kbps, and the bandwidth limit of AC 1 is 120 kbps. The total bandwidth of AC 2, AC 3, and Tunnel 1 is limited to 500 kbps.
# Set the bandwidth limit to 10240 kbps for Ethernet service instance 200.
[Sysname] interface fortygige 1/0/1
[Sysname-FortyGigE1/0/1] service-instance 200
[Sysname-FortyGigE1/0/1-srv200] encapsulation s-vid 200
[Sysname-FortyGigE1/0/1-srv200] bandwidth 10240
Use bandwidth to set the bandwidth limit for a VSI.
bandwidth bandwidth
undo bandwidth
No bandwidth limit is set for a VSI.
VSI view
bandwidth: Specifies a bandwidth limit in kbps. The value range for the bandwidth argument is 64 to 4194303.
This command limits the total bandwidth of the incoming traffic on all ACs and VXLAN tunnels mapped to a VSI. A VSI drops excess incoming traffic when its bandwidth limit is reached.
If you use both the restrain and bandwidth commands on a VSI, the restrain command does not take effect. The bandwidth command limits the total incoming bandwidth of the VSI.
# Set the bandwidth limit to 10240 kbps for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] bandwidth 10240
display l2vpn vsi
description
Use description to configure a description for a VSI.
A VSI does not have a description.
VSI view
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
# Configure a description for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
display l2vpn vsi
Use display arp suppression vsi to display ARP flood suppression entries.
In standalone mode:
display arp suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
In IRF mode:
display arp suppression vsi [ name vsi-name ] [ chassis chassis-number slot slot-number ] [ count ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays entries for all VSIs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays entries on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays entries on the global active MPU. (In IRF mode.)
count: Displays the number of ARP flood suppression entries that match the command.
# Display ARP flood suppression entries.
<Sysname> display arp suppression vsi
IP address      MAC address    VSI name                    Link ID    Aging(min)
1.1.1.2         000f-e201-0101 vsi1                        0x70000    14
1.1.1.3         000f-e201-0202 vsi1                        0x80000    18
1.1.1.4         000f-e201-0203 vsi2                        0x90000    10
# Display the number of ARP flood suppression entries.
<Sysname> display arp suppression vsi count
Total entries: 3
Link ID
Link ID that uniquely identifies an AC or a VXLAN tunnel on a VSI.
Aging(min)
Remaining lifetime (in minutes) of the ARP flood suppression entry. When the timer expires, the entry is deleted.
Use display hardware-resource source-udp-port to display the hardware resource mode for the outer source UDP port number in outgoing VXLAN packets.
# Display the hardware resource mode for the outer source UDP port number in outgoing VXLAN packets.
<Sysname> display hardware-resource source-udp-port
Source-udp-port resource(source-udp-port), all supported modes:
  8bit              The default mode
  16bit             The enhance mode
  Default         Current         Next
  8bit            8bit            8bit
VXLAN source-udp-port resource
Supported hardware resource modes for the outer source UDP port number in outgoing VXLAN packets:
·     8bit—8bit mode. In this mode, the most significant 8 bits of the outer source UDP port number is fixed to 00000000 for outgoing VXLAN packets. The other 8 bits are not fixed.
·     16bit—16bit mode. In this mode, no bit is fixed for the outer source UDP port number in outgoing VXLAN packets.
The default hardware resource mode for the outer source UDP port number in outgoing VXLAN packets.
Current
The current hardware resource mode for the outer source UDP port number in outgoing VXLAN packets.
Next
The hardware resource mode for the outer source UDP port number in outgoing VXLAN packets that will take effect at the next system startup.
Use display hardware-resource vxlan to display the VXLAN hardware resource mode.
display hardware-resource [ vxlan ]
vxlan: Specifies the VXLAN hardware resource mode. If you do not specify this keyword, the command displays all hardware resource modes.
# Display the VXLAN hardware resource mode.
<Sysname> display hardware-resource vxlan
Vxlan resource(vxlan), all supported modes:
  normal            The normal mode
  mac               The mac mode
  stag              The stag mode
  ctag              The ctag mode
  normal          normal          normal
VXLAN hardware resource modes supported by the device.
·     normal—Normal mode. In this mode, more hardware resources are assigned to VXLAN tunnels than MAC address entries. In normal mode, a VXLAN tunnel interface can be the outgoing interface of a network route.
·     mac—MAC address mode. In this mode, more hardware resources are assigned to MAC address entries than VXLAN tunnels.
·     ctag—Ctag mode. In this mode, more hardware resources are assigned to VXLAN tunnels than MAC address entries. The device in Layer 3 forwarding mode processes packets to be forwarded through VXLAN tunnels as follows:
¡     Adds the tag of the CVLAN ID in the ARP entry used for forwarding to packets before VXLAN encapsulation.
¡     Does not add VLAN tags to packets if the ARP entry does not contain a CVLAN ID.
·     stag—Stag mode. In this mode, more hardware resources are assigned to VXLAN tunnels than MAC address entries. The device in Layer 3 forwarding mode processes packets to be forwarded through VXLAN tunnels as follows:
¡     Adds the tag of the SVLAN ID in the ARP entry used for forwarding to packets before VXLAN encapsulation.
¡     Does not add VLAN tags to packets if the ARP entry does not contain an SVLAN ID.
The default VXLAN hardware resource mode.
Current
The current VXLAN hardware resource mode.
Next
The VXLAN hardware resource mode for the next startup.
Use display igmp host group to display information about the multicast groups that contain IGMP host-enabled interfaces.
display igmp [ vpn-instance vpn-instance-name ] host group [ group-address | interface interface-type interface-number ] [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about the multicast groups that contain IGMP host-enabled interfaces for the public network.
group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, this command displays information about all multicast groups.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays multicast group information for all interfaces.
verbose: Displays detailed multicast group information. If you do not specify this keyword, the command displays brief multicast group information.
For the VXLAN multicast source interface of a multicast-mode VXLAN to join its VXLAN multicast group, enable the IGMP host feature on the interface. The VXLAN multicast source interface provides the source IP address for multicast VXLAN packets.
Use this command to verify the following information:
·     Multicast group information for VXLANs.
·     Group membership status of VXLAN multicast source interfaces.
# Display brief information about all multicast groups that contain IGMP host-enabled interfaces.
<Sysname> display igmp host group
IGMP host groups in total: 2
 Vlan-interface10(1.1.1.20):
   Group address      Member state      Expires
   225.1.1.1          Idle              Off
   225.1.1.2          Idle              Off
# Display detailed information about all multicast groups that contain IGMP host-enabled interfaces.
<Sysname> display igmp host group verbose
   Group: 225.1.1.1
     Group mode: Exclude
     Member state: Idle
     Expires: Off
     Source list (sources in total: 0):
   Group: 225.1.1.2
     Group mode: Exclude
     Member state: Idle
     Expires: Off
Total number of multicast groups that contain IGMP host-enabled interfaces.
Name and IP address of the IGMP host-enabled interface.
Total number of multicast groups on the interface.
Group address/Group
Address of the multicast group.
Member state
Member state:
·     Delay—The interface has joined the multicast group, and it has started the delay timer for sending IGMP reports.
·     Idle—The interface has joined the multicast group, but it has not started the delay timer for sending IGMP reports.
The delay timer is not user configurable.
Expires
Remaining delay time for the interface to send an IGMP report.
This field displays Off if the delay timer is disabled.
Group mode
Multicast source filtering mode:
·     Include.
·     Exclude.
Source list
Multicast sources of the multicast group.
sources in total
Total number of multicast sources.
For more information about the command output, see IGMP in IP Multicast Configuration Guide.
igmp host enable
Use display ipv6 nd suppression vsi to display ND flood suppression entries.
In standalone mode:
display ipv6 nd suppression vsi [ name vsi-name ] [ slot slot-number ] [ count ]
In IRF mode:
display ipv6 nd suppression vsi [ name vsi-name ] [ chassis chassis-number slot slot-number ] [ count ]
count: Displays the number of ND flood suppression entries that match the command.
# Display ND flood suppression entries.
<Sysname> display ipv6 nd suppression vsi
IPv6 address            MAC address     VSI name         Link ID    Aging (min)
1000::2                 000f-e201-0101  vsi1             0x70000    5
1000::3                 000f-e201-0202  vsi1             0x80000    5
1000::4                 000f-e201-0203  vsi2             0x90000    5
# Display the number of ND flood suppression entries.
<Sysname> display ipv6 nd suppression vsi count
Total entries: 3
Table 5 Command output
Link ID
Aging (min)
Remaining lifetime (in minutes) of the ND flood suppression entry. When the timer expires, the entry is deleted.
Use display l2vpn mac-address to display MAC address entries for VSIs.
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count | verbose ]
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC address entries for all VSIs.
dynamic: Specifies dynamic MAC address entries learned in the data plane. If you do not specify this keyword, the command displays all MAC address entries, including:
·     Dynamic remote- and local-MAC entries.
·     Remote-MAC entries advertised through BGP EVPN.
·     Manually added static remote- and local-MAC entries.
·     Remote-MAC entries issued through OpenFlow.
·     Remote-MAC entries issued through OVSDB.
count: Displays the number of MAC address entries.
verbose: Displays detailed information about MAC address entries.
If you do not specify the count or verbose keyword, this command displays brief information about MAC address entries.
# Display brief information about MAC address entries for all VSIs.
<Sysname> display l2vpn mac-address
MAC Address    State     VSI Name                        Link ID/Name   Aging
0000-0000-000b Static    vpn1                            Tunnel10       NotAging
0000-0000-000c Dynamic   vpn1                            Tunnel60       Aging
0000-0000-000d Dynamic   vpn1                            Tunnel99       Aging
00e0-fc09-9993 EVPN      vpna                            Tunnel0        NotAging
0001-0001-0003 EVPN      vpna                            Tunnel0        NotAging
                                                         Tunnel1        NotAging
0002-0003-0004 Multiport vpna                            FGE1/0/2       NotAging
                                                         Tunnel8        NotAging
                                                         Tunnel9        NotAging
0100-5e00-0003 Multicast vpnb                            FGE1/0/3       NotAging
                                                         Tunnel12       NotAging
--- 8 mac address(es) found  ---
# Display the total number of MAC address entries in all VSIs.
<Sysname> display l2vpn mac-address count
Table 6 Command output
Entry state:
·     Dynamic—Local- or remote-MAC entry dynamically learned in the data plane.
·     Static—Static local- and remote-MAC entry.
·     EVPN—Remote-MAC entry advertised through BGP EVPN.
·     OpenFlow—Remote-MAC entry issued by a remote controller through OpenFlow.
·     OVSDB—Remote-MAC entry issued by a remote controller through OVSDB.
·     Multiport—Local or remote multiport unicast MAC entry.
·     Multicast—Local or remote multicast MAC entry.
Link ID/Name
For a local MAC address, this field displays the name of the interface that hosts the Ethernet service instance for the MAC address.
For a remote MAC address, this field displays the tunnel interface name.
Aging
Entry aging state:
·     Aging.
·     NotAging.
# Display detailed information about MAC address entries for all VSIs.
<Sysname> display l2vpn mac-address verbose
MAC Address : 0000-0000-000b
VSI Name    : vpn1
VXLAN ID    : 123
Interface   : FGE1/0/1
Link ID     : 1
State       : Dynamic
Aging       : Aging
MAC Address : 0002-0003-0004
VSI Name    : vpna
VXLAN ID    : 10
State       : Multiport
Aging       : NotAging
Interface       Link ID
FGE1/0/2         0x0
Tunnel8         0x5000002
Tunnel9         0x5000003
MAC Address : 0100-5e00-0003
VSI Name    : vpnb
VXLAN ID    : 20
State       : Multicast
Aging       : NotAging
Interface       Link ID
FGE1/0/3         0x0
Tunnel12        0x5000004
Table 7 Command output
Link ID
Entry state:
·     Static—Static local- or remote-MAC entry.
Aging
Entry aging state:
·     Aging.
·     NotAging.
Use display l2vpn mac-address mac-move to display the MAC address move records after the device is started for all VSIs.
In standalone mode:
display l2vpn mac-address mac-move [ slot slot-number ]
In IRF mode:
display l2vpn mac-address mac-move [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command displays MAC address move records for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, the command displays MAC address move records for all cards. (In IRF mode.)
When a MAC address frequently moves between the specified two interfaces, Layer 2 loops might occur in the network. To discover and locate loops, you can view the MAC address move records.
In the MAC address move records, records with the same MAC address, VLAN, source port, and current port are considered to be one record.
(In standalone mode.) A card can generate a maximum of 200 MAC address move records.
(In IRF mode.) Each card of an IRF member device can generate a maximum of 200 MAC move records.
# Display the MAC address move records for all VSIs.
<Sysname> display l2vpn mac-address mac-move
MAC address : 0000-4900-03e7      VSI name   : 3
Current port: FFGE1/0/1 srv2       Source port: FGE1/0/2 srv3
Last time   : 2019-02-19 20:44:15 Move count : 1
---  1 MAC address moving records found  ---
Table 8 Command output
Current port
Interface to which the MAC address was moved.
Source port
Interface from which the MAC address was moved.
Last time
Last time when the MAC address was moved.
Move count
Number of MAC address moves after the device is started.
Use display l2vpn service-instance to display information about Ethernet service instances.
interface interface-type interface-number: Specifies a Layer 2 Ethernet interface or Layer 2 aggregate interface by its interface type and number. If you do not specify an interface, this command displays Ethernet service instance information for all Layer 2 Ethernet interfaces and Layer 2 aggregate interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command displays information about all Ethernet service instances on the specified Layer 2 Ethernet interface or Layer 2 aggregate interface.
verbose: Displays detailed information about Ethernet service instances. If you do not specify this keyword, the command displays brief information about Ethernet service instances.
# Display brief information about all Ethernet service instances.
<Sysname> display l2vpn service-instance
Total number of service-instances: 4, 4 up, 0 down
Total number of ACs: 2, 2 up, 0 down
Interface                SrvID Owner                           LinkID State Type
FGE1/0/1                 3     vsi12                           1      Up    VSI
FGE1/0/1                 4     vsi13                           1      Up    VSI
Table 9 Command output
Total number of ACs
Total number of attachment circuits (ACs) and the number of ACs in each state (up or down).
Name of a Layer 2 Ethernet interface or Layer 2 aggregate interface.
SrvID
Ethernet service instance ID.
Owner
VSI name. This field is empty if an Ethernet service instance is not mapped to any VSI.
LinkID
Ethernet service instance's link ID on the VSI.
Ethernet service instance state:
·     Up.
·     Down.
L2VPN type of the Ethernet service instance:
·     VSI.
·     VPWS.
# Display detailed information about all Ethernet service instances on FortyGigE 1/0/1.
<Sysname> display l2vpn service-instance interface fortygige 1/0/1 verbose
Interface: FGE1/0/1
  Service Instance: 1
    Type          : Manual
    Encapsulation : s-vid 16
    Bandwidth     : Unlimited
    VSI Name      : vsi10
    Link ID       : 1
    State         : Up
    DF state      : BDF
    Statistics    : Enabled
    Input Statistics:
      Octets   :0
      Packets  :0
    Output Statistics:
      Octets   :0
      Packets  :0
Table 10 Command output
Service Instance
Type and traffic match mode of the Ethernet service instance:
Manual—Static Ethernet service instance in VLAN-based traffic match mode.
Encapsulation
Frame match criterion of the Ethernet service instance. If the Ethernet service instance does not contain a frame match criterion, the command does not display this field.
Bandwidth
Bandwidth limit in kbps. If no bandwidth limit is set for the Ethernet service instance, Unlimited is displayed.
Link ID
·     Up.
·     Down.
DF state
Whether the device is the designated forwarder for the AC at a multihomed EVPN site:
·     BDF—The device is a backup designated forwarder.
·     DF—The device is the designated forwarder.
This field is not displayed if no Ethernet segment identifier is configured on the interface.
Statistics
Packet statistics state:
·     Enabled—The packet statistics feature is enabled for the Ethernet service instance.
·     Disabled—The packet statistics feature is disabled for the Ethernet service instance.
Input Statistics
Incoming traffic statistics:
·     Octets—Number of incoming bytes.
·     Packets—Number of incoming packets.
Output Statistics
Outgoing traffic statistics:
·     Octets—Number of outgoing bytes.
·     Packets—Number of outgoing packets.
service-instance
display l2vpn vsi
Use display l2vpn vsi to display information about VSIs.
display l2vpn vsi [ name vsi-name ] [ verbose ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays information about all VSIs.
verbose: Displays detailed information about VSIs. If you do not specify this keyword, the command displays brief information about VSIs.
# Display brief information about all VSIs.
<Sysname> display l2vpn vsi
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
VSI Name                        VSI Index       MTU    State
vpna                            0               1500   Up
Table 11 Command output
MTU
MTU on the VSI.
VSI state:
·     Up—The VSI is up.
·     Down—The VSI is down.
·     Admin down—The VSI has been manually shut down by using the shutdown command.
# Display detailed information about all VSIs.
<Sysname> display l2vpn vsi verbose
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Broadcast Restrain      : Unlimited
  Multicast Restrain      : Unlimited
  Unknown Unicast Restrain: Unlimited
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            : -
  Input statistics:
    Octets   : 0
    Packets  : 0
    Errors   : 0
    Discards : 0
  Output statistics:
    Octets   : 0
    Packets  : 0
    Errors   : 0
    Discards : 0
  Gateway Interface       : VSI-interface 100
  VXLAN ID                : 10
  Tunnels:
    Tunnel Name          Link ID    State  Type      Flood proxy
    Tunnel1              0x5000001  Up     Manual    Disabled
    Tunnel2              0x5000002  Up     Manual    Disabled
    MTunnel0             0x6002710  Up     Auto      Disabled
  ACs:
    AC                               Link ID    State    Type
    FGE1/0/1 srv1000                 0          Up       Manual
Table 12 Command output
VSI Description
Description of the VSI. If the VSI does not have a description, the command does not display this field.
VSI State
VSI state:
·     Up—The VSI is up.
·     Administratively down—The VSI has been manually shut down by using the shutdown command.
MTU
MTU on the VSI.
Bandwidth
If no bandwidth limit is set for the VSI, Unlimited is displayed.
Broadcast Restrain
Broadcast restraint bandwidth (in kbps).
If the broadcast restraint bandwidth is not set, Unlimited is displayed.
Multicast Restrain
Multicast restraint bandwidth (in kbps).
If the multicast restraint bandwidth is not set, Unlimited is displayed.
Unknown unicast restraint bandwidth (in kbps).
If the unknown unicast restraint bandwidth is not set, Unlimited is displayed.
MAC Learning
State of the MAC learning feature.
MAC Table Limit
Maximum number of MAC address entries on the VSI.
MAC Learning rate
MAC address entry learning rate of the VSI.
Drop Unknown
Action on source MAC-unknown frames received after the maximum number of MAC entries is reached.
Flooding
State of the VSI's flooding feature:
·     Enabled—Flooding is enabled on the VSI.
·     Disabled—Flooding is disabled on the VSI.
Statistics
·     Enabled—The packet statistics feature is enabled for the VSI.
·     Disabled—The packet statistics feature is disabled for the VSI.
Input statistics
·     Errors—Number of error packets.
·     Discards—Number of discarded packets.
Output statistics
Gateway Interface
VSI interface name.
Tunnel state:
·     Up—The tunnel is operating correctly.
·     Blocked—The tunnel is a backup tunnel. Its tunnel interface is up, but the tunnel is blocked because the primary tunnel is operating correctly.
·     Defect—The tunnel interface is up, but BFD cannot detect the remote VTEP.
·     Down—The tunnel interface is down.
Tunnel assignment method:
·     Auto—The tunnel was automatically assigned to the VXLAN:
¡     For an EVPN network, VXLAN tunnels are automatically assigned to VXLANs.
¡     For a multicast-mode VXLAN, the tunnel (MTunnel) was automatically created and assigned to the VXLAN to transmit flood traffic.
·     Manual—The tunnel was manually assigned to the VXLAN.
Flood proxy
Flood proxy state:
·     Enabled—Flood proxy is enabled. The VTEP sends broadcast, multicast, and unknown unicast traffic to a flood proxy server through the tunnel. The flood proxy server replicates and forwards flood traffic to remote VTEPs.
·     Disabled—Flood proxy is disabled.
ACs
ACs that are bound to the VSI.
Link ID
AC's link ID on the VSI.
AC state:
·     Up.
·     Down.
·     Dynamic (M-LAG)—Dynamic Ethernet service instance created on the peer link, in VLAN-based traffic match mode.
·     Manual—Static Ethernet service instance in VLAN-based traffic match mode.
Use display statistic mode to display the current packet statistic collection mode.
# Display the current packet statistic collection mode.
<Sysname> display statistic mode
The packet statistic mode is vsi.
statistic mode vsi
Use display vxlan tunnel to display VXLAN tunnel information for VXLANs.
display vxlan tunnel [ vxlan-id vxlan-id ]
vxlan-id: Specifies a VXLAN ID. The value range for this argument is 0 to 16777215. If you do not specify a VXLAN, this command displays VXLAN tunnel information for all VXLANs.
# Display VXLAN tunnel information for all VXLANs.
<Sysname> display vxlan tunnel
Total number of VXLANs: 1
VXLAN ID: 10, VSI name: vpna, Total tunnels: 3 (3 up, 0 down, 0 defect, 0 blocked)
Tunnel name          Link ID    State  Type         Flood proxy
# Display VXLAN tunnel information for VXLAN 10.
<Sysname> display vxlan tunnel vxlan-id 10
Table 13 Command output
Link ID
Tunnel's link ID in the VXLAN.
Tunnel state:
Flood proxy
Flood proxy state:
tunnel
vxlan
emulate-ping vxlan
Use emulate-ping vxlan to test the reachability of a remote VM.
emulate-ping vxlan [ -c count | -m interval | -s packet-size | -t time-out ] * vxlan-id vxlan-id source-mac mac-address destination-mac mac-address
-c count: Specifies the number of ICMP echo requests to be sent. The value range is 1 to 4294967295, and the default value is 5.
-m interval: Specifies the interval for sending ICMP echo requests. The value range is 1 to 65535 milliseconds, and the default value is 200 milliseconds.
-s packet-size: Specifies the length of ICMP echo quests (IP and ICMP headers not included). The value range is 20 to 8100 bytes, and the default value is 56 bytes.
-t time-out: Specifies the ICMP echo reply timeout period. The value range is 0 to 65535 milliseconds, and the default value is 2000 milliseconds. If the device does not receive an ICMP echo reply within the timeout period after sending an ICMP echo request, the device determines that the ICMP echo reply times out.
vxlan-id vxlan-id: Specifies a VXLAN ID. The value range for the vxlan-id argument is 0 to 16777215.
source-mac mac-address: Specifies the source MAC address of ICMP echo requests. The MAC address must be a local VM address in the MAC address table of the specified VXLAN.
destination-mac mac-address: Specifies the destination MAC address of ICMP echo requests. The MAC address must be a remote VM address in the MAC address table of the specified VXLAN.
The emulate-ping vxlan command enables the device to test the reachability of a remote VM by simulating a local VM to send ICMP echo requests. The requests are encapsulated in Layer 2 data frames and then sent to the remote VM in the specified VXLAN. The device determines the reachability of the remote VM based on the response time and number of received ICMP echo replies. You can view the packet transmission statistics in the command output.
The emulate-ping vxlan command is not supported if EVPN M-LAG is configured on the device. For more information about EVPN M-LAG, see EVPN Configuration Guide.
# Simulate local VM 1ea3-c0be-0206 to test the reachability of remote VM 1ea3-b77b-0106 in VXLAN 100.
<Sysname> emulate-ping vxlan vxlan-id 100 source-mac 1ea3-c0be-0206 destination-mac 1ea3-b77b-0106
Emulate ping in VXLAN 100: source MAC 1ea3-c0be-0206, destination MAC 1ea3-b77b-0106, 56 data bytes.
Press CTRL_C to break.
56 bytes from 100.1.2.1: ICMP_seq=0 time=1.114 ms
56 bytes from 100.1.2.1: ICMP_seq=1 time=1.073 ms
56 bytes from 100.1.2.1: ICMP_seq=2 time=1.123 ms
56 bytes from 100.1.2.1: ICMP_seq=3 time=1.781 ms
56 bytes from 100.1.2.1: ICMP_seq=4 time=0.933 ms
--- Ping statistics for VXLAN 100 ---
round-trip min/avg/max/std-dev = 0.000/0.200/1.000/0.400 ms
Table 14 Command output
Statistics about the received ICMP echo reply from the VM at 100.1.2.1. If no reply is received within the timeout period, nothing is displayed.
·     bytes—Number of bytes in the ICMP echo reply.
·     ICMP_seq—Sequence number, used to determine whether a request is lost, disordered, or repeated.
·     time—Response time.
5 packet(s) transmitted
Number of transmitted ICMP echo requests.
5 packet(s) received
Number of received ICMP echo replies.
0.0% packet loss
Percentage of unacknowledged requests.
round-trip min/avg/max/std-dev=0.933/1.205/1.781/0.296 ms
Minimum/average/maximum/standard deviation response time in milliseconds.
encapsulation
Use encapsulation to configure a frame match criterion for an Ethernet service instance.
Use undo encapsulation to restore the default.
encapsulation s-vid vlan-id-list [ c-vid vlan-id | only-tagged ]
encapsulation { default | untagged }
undo encapsulation [ s-vid vlan-id-list ]
An Ethernet service instance does not contain a frame match criterion.
s-vid: Matches frames that are tagged with the specified outer 802.1Q VLAN IDs.
c-vid: Matches frames that are tagged with the specified inner 802.1Q VLAN IDs.
vlan-id-list: Specifies one inner VLAN item or a space-separated list of up to eight outer VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the format of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094.
only-tagged: Matches tagged frames. If the outer 802.1Q VLAN is not the PVID, the matching result does not differ, whether or not you specify the only-tagged keyword. If the outer 802.1Q VLAN is the PVID, the matching result depends on whether or not the only-tagged keyword is specified.
·     To match only PVID-tagged frames, specify the only-tagged keyword.
·     To match both untagged frames and PVID-tagged frames, do not specify the only-tagged keyword.
default: Specifies the default match criterion. On an interface, you can configure this criterion only in one Ethernet service instance. The default match criterion matches frames that do not match any other Ethernet service instance on the interface. The Ethernet service instance that uses the default match criterion matches any frames if it is the only instance on the interface.
untagged: Matches any frames that do not have an 802.1Q VLAN tag.
For packets to be correctly forwarded, make sure the interface where an Ethernet service instance resides permits the matching inner and outer VLANs of the Ethernet service instance.
Follow these restrictions and guidelines when you create multiple Ethernet service instances on an interface:
·     If the Ethernet service instances match only the outer VLAN IDs, the VLAN IDs cannot overlap.
·     If the Ethernet service instances match both inner and outer VLAN IDs, the following rules apply:
¡     Two Ethernet service instances can match the same outer VLAN IDs if their matching inner VLAN IDs do not overlap. In other cases, the outer VLAN IDs matched by Ethernet service instances cannot overlap.
¡     Two Ethernet service instances can match the same inner VLAN IDs if their matching outer VLAN IDs do not overlap. In other cases, the inner VLAN IDs matched by Ethernet service instances cannot overlap.
An Ethernet service instance can contain only one frame match criterion. In the following cases, you can execute the encapsulation command multiple times to modify the frame match criterion of an Ethernet service instance:
·     You have configured the frame match criterion by using the encapsulation s-vid command.
¡     You can repeat the encapsulation s-vid command to add matching outer VLAN IDs to the criterion. For example, if you execute the encapsulation s-vid 100 and encapsulation s-vid 200 commands, the Ethernet service instance matches frames tagged with outer VLAN IDs 100 and 200.
¡     You can repeat the undo encapsulation s-vid command to remove matching outer VLAN IDs from the criterion. If all matching outer VLAN IDs are removed, the mapping between the Ethernet service instance and the VSI is removed automatically.
·     You have configured the frame match criterion by using the encapsulation s-vid c-vid command.
You can repeat the encapsulation s-vid command to add matching outer VLAN IDs to the criterion. All the specified outer VLAN IDs take effect. You cannot remove matching outer VLAN IDs by using the undo encapsulation s-vid command.
For example, an Ethernet service instance matches frames tagged with outer VLAN IDs 100 and 200, and inner VLAN ID 100 if you execute the following commands:
¡     encapsulation s-vid 100 c-vid 100
¡     encapsulation s-vid 200
You cannot repeat the encapsulation command to modify the frame match criterion of an Ethernet service instance if you have configured the frame match criterion by using the following commands:
·     encapsulation s-vid { vlan-id | vlan-id-list } only-tagged.
·     encapsulation untagged.
·     encapsulation default.
To change the frame match criterion, first execute the undo encapsulation command without any parameters to remove the original frame match criterion. The command also automatically removes the mapping between the Ethernet service instance and the VSI.
# Configure Ethernet service instance 1 on FortyGigE 1/0/1 to match frames that have an outer 802.1Q VLAN ID of 111.
[Sysname-FortyGigE1/0/1] service-instance 1
[Sysname-FortyGigE1/0/1-srv1] encapsulation s-vid 111
Use flooding disable to confine the flood traffic of an Ethernet service instance.
Use undo flooding disable to restore the default.
flooding disable { all-port | source-port }
An Ethernet service instance sends flood traffic to the other Ethernet service instances of the same VSI.
all-port: Disables flooding to all the other Ethernet service instances of the same VSI.
source-port: Disables flooding to the other Ethernet service instances of the same VSI on the local port.
To prevent broadcast storms, use this command to confine the flood traffic of Ethernet service instances.
# Disable Ethernet service instance 10 from flooding traffic to the other Ethernet service instances of the same VSI on FortyGigE 1/0/1.
[Sysname-FortyGigE1/0/1] service-instance 10
[Sysname-FortyGigE1/0/1-srv10] flooding disable source-port
Use flooding disable to disable flooding for a VSI.
Use undo flooding disable to enable flooding for a VSI.
flooding disable { all | { broadcast | unknown-multicast | unknown-unicast } * } [ all-direction | dci ]
Flooding is enabled for a VSI.
VSI view
all: Specifies broadcast, unknown unicast, and unknown multicast traffic.
broadcast: Specifies broadcast traffic.
unknown-multicast: Specifies unknown multicast traffic.
unknown-unicast: Specifies unknown unicast traffic.
all-direction: Disables flooding traffic received from an AC or VXLAN tunnel interface to any other ACs and VXLAN tunnel interfaces of the same VSI. If you do not specify this keyword, the command only disables flooding traffic received from ACs to VXLAN tunnel interfaces of the VSI.
dci: Disables flooding only to VXLAN-DCI tunnel interfaces. If you do not specify this keyword, the command disables flooding to both VXLAN tunnel interfaces and VXLAN-DCI tunnel interfaces.
By default, the device floods broadcast, unknown unicast, and unknown multicast frames received from the local site to the following interfaces in the frame's VXLAN:
·     All site-facing interfaces except for the incoming interface.
·     All VXLAN tunnel interfaces.
When receiving broadcast, unknown unicast, and unknown multicast frames on VXLAN tunnel interfaces, the device floods the frames to all site-facing interfaces in the frames' VXLAN.
To confine a kind of flood traffic, use this command to disable flooding for that kind of flood traffic on the VSI bound to the VXLAN.
The unknown-multicast or unknown-unicast keyword cannot be used alone. You must specify both of them.
If VXLAN-DCI is configured, flood traffic is also sent out of VXLAN-DCI tunnel interfaces. To confine flood traffic to the site-facing interfaces and VXLAN tunnels within a data center, you can specify the dci keyword to disable flooding only to VXLAN-DCI tunnel interfaces.
The all-direction keyword disables flooding traffic received from an AC or VXLAN tunnel interface to any other ACs and VXLAN tunnel interfaces of the same VSI. If VXLAN-DCI is configured, this keyword also disables flooding between VXLAN tunnel interfaces and VXLAN-DCI tunnel interfaces.
# Disable flooding of local broadcast traffic to remote sites for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] flooding disable broadcast
forwarding mode
Use forwarding mode to set the VXLAN or VXLAN-DCI Layer 2 forwarding mode.
Use undo forwarding mode to restore the default.
forwarding mode { double-vid | mac | svid-only }
MAC forwarding mode is used.
VXLAN tunnel interface view
VXLAN-DCI tunnel interface view
double-vid: Specifies double-VID forwarding mode, in which the device performs MAC address table lookup based on both the inner and outer VLAN IDs.
mac: Specifies MAC forwarding mode, in which the device performs MAC address table lookup based on the destination MAC address.
svid-only: Specifies SVID-only forwarding mode, in which the device performs MAC address lookup based on the outer VLAN ID.
If double-VID or SVID-only forwarding mode is used, make sure the VSI's MAC address table contains VLAN-based MAC address entries. The entries can be manually created or dynamically learned.
# Configure Tunnel 10 to use double-VID forwarding mode for VXLAN Layer 2 traffic.
[Sysname] interface tunnel 10
[Sysname-Tunnel10] forwarding mode double-vid
learning mode
group
Use group to assign a VXLAN a multicast group address for flood traffic, and specify a source IP address for multicast VXLAN packets.
Use undo group to restore the default.
group group-address source source-address
undo group group-address source source-address
A VXLAN uses unicast mode (head-end replication) for flood traffic. No multicast group address or source IP address is specified for multicast VXLAN packets.
VXLAN view
group-address: Specifies a multicast address in the range of 224.0.1.0 to 239.255.255.255.
source source-address: Specifies a source IP address for multicast VXLAN packets.
To reduce traffic sent to the transport network, use multicast mode if the network has dense flood traffic or many VTEPs.
The multicast mode supports the following multicast methods:
·     PIM—VTEPs and transport network devices run PIM to generate multicast forwarding entries. On a VTEP, you can use the IP address of a loopback interface as the source IP address for multicast VXLAN packets. If the VTEP has multiple transport-facing interfaces, PIM dynamically selects the outgoing interfaces for multicast VXLAN packets.
·     IGMP host—VTEPs and transport network devices run PIM and IGMP to generate multicast forwarding entries.
¡     Transport-facing interfaces of VTEPs act as IGMP hosts.
¡     Transport network devices connected to a VTEP run IGMP.
¡     All transport network devices run PIM.
On a VTEP, you must use the IP address of the transport-facing interface as the source IP address for multicast VXLAN packets. If the VTEP has multiple transport-facing interfaces, multicast VXLAN packets are sent to the transport network through the interface that provides the source IP address for multicast VXLAN packets.
VTEPs in a multicast-mode VXLAN can use different multicast methods.
To forward multicast traffic correctly, you must use the source IP address of an up VXLAN tunnel as the source IP address for multicast VXLAN packets.
For multicast-mode VXLANs, transport network devices must maintain multicast group and forwarding information. To reduce the multicast forwarding entries maintained by transport network devices, assign a multicast group address to multiple VXLANs. The VTEP separates traffic between VXLANs by VXLAN IDs.
For VXLANs that use the same multicast group address, you must configure the same source IP address for their multicast VXLAN packets.
If you execute the group command multiple times for a VXLAN, the most recent configuration takes effect.
# Set the multicast group address to 233.1.1.1 for flood traffic in VXLAN 100. Set the source IP address to 2.1.1.1 for multicast VXLAN packets.
[Sysname] vsi aaa
[Sysname-vsi-aaa] vxlan 100
[Sysname-vsi-aaa-vxlan-100] group 233.1.1.1 source 2.1.1.1
igmp host enable
pim dm (IP Multicast Command Reference)
pim sm (IP Multicast Command Reference)
Use hardware-resource source-udp-port to set the hardware resource mode for the outer source UDP port number in outgoing VXLAN packets.
Use undo hardware-resource source-udp-port to restore the default.
hardware-resource source-udp-port { 8bit | 16bit }
The hardware resource mode is 8bit.
8bit: Sets the hardware resource mode to 8bit mode. In this mode, the most significant 8 bits of the outer source UDP port number is fixed to 01010000 for outgoing VXLAN packets. The other 8 bits are not fixed.
16bit: Sets the hardware resource mode to 16bit. In this mode, no bit is fixed for the outer source UDP port number in outgoing VXLAN packets.
For a hardware resource mode change to take effect, you must reboot the device.
# Set the hardware resource mode to 8bit for the outer source UDP port number in outgoing VXLAN packets.
[Sysname] hardware-resource source-udp-port 8bit
Use hardware-resource vxlan to set the VXLAN hardware resource mode.
Use undo hardware-resource vxlan to restore the default.
hardware-resource vxlan { ctag | mac | normal | stag }
The VXLAN hardware resource mode is normal.
ctag: Specifies the Ctag mode.
mac: Specifies the MAC address mode.
normal: Specifies the normal mode.
stag: Specifies the Stag mode.
Creation of VXLAN tunnels and MAC address entries requires hardware resources, which are limited. You can selected a VXLAN hardware resource mode to distribute hardware resources between VXLAN tunnels and MAC address entries depending on your network requirements..
·     MAC address mode—Assigns more hardware resources to MAC address entries.
·     Normal mode—Assigns more hardware resources to VXLAN tunnels. In this mode, a VXLAN tunnel interface can be the outgoing interface of a network route.
·     Ctag mode—Assigns more hardware resources to VXLAN tunnels, and enables the device in Layer 3 forwarding mode to process packets to be forwarded through VXLAN tunnels as follows:
·     Stag mode—Assigns more hardware resources to VXLAN tunnels, and enables the device in Layer 3 forwarding mode to process packets to be forwarded through VXLAN tunnels as follows:
# Set the VXLAN hardware resource mode to MAC address.
[Sysname] hardware-resource vxlan mac
igmp host enable
Use igmp host enable to enable the IGMP host feature on an interface.
Use undo igmp host enable to disable the IGMP host feature on an interface.
igmp host enable
The IGMP host feature is disabled on an interface.
Interface view
You must configure an interface as an IGMP host if its IP address is the source IP address of multicast VXLAN packets. The IGMP host feature enables the interface to send IGMP reports in response to IGMP queries before it can receive traffic from a multicast group.
For this command to take effect, you must use the multicast routing command to enable IP multicast routing.
# Enable IP multicast routing, and then enable the IGMP host feature on VLAN-interface 10.
[Sysname] multicast routing
[Sysname-mrib] quit
[Sysname-Vlan-interface10] igmp host enable
group
multicast routing (IP Multicast Command Reference)
Use ipv6 nd suppression enable to enable ND flood suppression.
Use undo ipv6 nd suppression enable to disable ND flood suppression.
ND flood suppression is disabled.
VSI view
ND flood suppression reduces ND request multicasts by enabling the VTEP to reply to ND requests on behalf of user terminals.
This feature snoops ND packets to populate the ND flood suppression table with local and remote MAC addresses. If an ND request has a matching entry, the VTEP replies to the request on behalf of the user terminal. If no match is found, the VTEP floods the request to both local and remote sites.
# Enable ND flood suppression for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] ipv6 nd suppression enable
l2vpn enable
Use l2vpn enable to enable L2VPN.
Use undo l2vpn enable to disable L2VPN.
l2vpn enable
undo l2vpn enable
L2VPN is disabled.
You must enable L2VPN before you can configure L2VPN settings.
# Enable L2VPN.
[Sysname] l2vpn enable
Use l2vpn statistics interval to set the VXLAN statistics collection interval.
Use undo l2vpn statistics interval to restore the default.
l2vpn statistics interval interval
The VXLAN statistics collection interval is 15 minutes.
interval: Specifies an interval value in the range of 30 to 65535 seconds.
# Set the VXLAN statistics collection interval to 30 seconds.
[Sysname] l2vpn statistics interval 30
learning mode
Use learning mode to set the MAC learning mode.
Use undo learning mode to restore the default.
learning mode { disable | double-vid | mac | svid-only }
undo learning mode
Source MAC learning mode is enabled.
disable: Disables MAC learning. In this situation, only static MAC address entries are available.
double-vid: Specifies double-VID learning mode, in which the device generates MAC address entries based on the inner and outer VLAN IDs (CVLAN and SVLAN tags) of data frames. The MAC address in a MAC address entry uses the 0-SVLAN tag-CVLAN tag format.
mac: Specifies source MAC learning mode, in which the device generates MAC address entries based on the source MAC addresses of data frames.
svid-only: Specifies SVID-only learning mode, in which the device generates MAC address entries based on the outer VLAN IDs (SVLAN tags) of data frames. The MAC address in a MAC address entry uses the 0-SVLAN tag-0 format.
The outgoing interface in a MAC address entry is the Ethernet service instance or VXLAN tunnel interface where the entry is learned.
When you use this command to set the MAC learning mode for VXLAN, follow these restrictions and guidelines:
·     To ensure correct forwarding, the tunnels and Ethernet service instances of a VSI must use matching MAC learning modes and VXLAN Layer 2 forwarding modes. For example, a VSI has an Ethernet service instance and a VXLAN tunnel. If the Ethernet service instance uses MAC forwarding mode, the VXLAN tunnel must use source MAC learning mode.
·     If an Ethernet service instance on a Layer 2 Ethernet interface uses source MAC, double-VID, or SVID-only learning mode, MAC address learning must be enabled on the interface.
·     If a VXLAN tunnel uses source MAC, double-VID, or SVID-only learning mode, remote-MAC address learning must be enabled on the tunnel.
When you use this command to set the MAC learning mode for VXLAN-DCI, follow these restrictions and guidelines:
·     To ensure correct forwarding, the VXLAN tunnels and VXLAN-DCI tunnels of a VSI must use matching MAC learning modes and Layer 2 forwarding modes. For example, a VSI has a VXLAN tunnel and a VXLAN-DCI tunnel. If the VXLAN tunnel uses MAC forwarding mode, the VXLAN-DCI tunnel must use source MAC learning mode. If the VXLAN-DCI tunnel uses MAC forwarding mode, the VXLAN tunnel must use source MAC learning mode.
·     If a VXLAN or VXLAN-DCI tunnel uses source MAC, double-VID, or SVID-only learning mode, remote-MAC address learning must be enabled on the tunnel.
# Enable double-VID learning mode on Tunnel 10.
[Sysname-Tunnel10] learning mode double-vid
forwarding mode
mac-address mac-learning enable
Use mac-address static vsi to add a static MAC address entry for a VXLAN VSI.
Use undo mac-address static vsi to remove a static MAC address entry for a VXLAN VSI.
mac-address static mac-address { interface interface-type interface-number service-instance instance-id | interface tunnel tunnel-number } vsi vsi-name
undo mac-address static [ mac-address ] [ interface interface-type interface-number service-instance instance-id | interface tunnel tunnel-number ] vsi vsi-name
VXLAN VSIs do not have static MAC address entries.
mac-address: Specifies a MAC address in H-H-H format. Do not specify a multicast MAC address or an all-zeros MAC address. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001. For static VLAN-based MAC address entries, the value for this argument must use the 0-SVLAN tag-0 or 0-SVLAN tag-CVLAN tag format.
interface interface-type interface-number service-instance instance-id: Specifies an Ethernet service instance on an interface. The interface-type interface-number argument specifies the interface by its type and number. The instance-id argument specifies the Ethernet service instance by its ID in the range of 1 to 4096. This option applies to local MAC addresses.
interface tunnel tunnel-number: Specifies a VXLAN or VXLAN-DCI tunnel interface by its tunnel interface number. The tunnel interface must already exist. This option applies to remote MAC addresses.
A local MAC address is the MAC address of a VM in the local site. Local MAC entries include manually added entries and dynamically learned entries.
A remote MAC address is the MAC address of a VM in a remote site. Remote MAC entries include manually added MAC entries, dynamically learned MAC entries, and MAC entries advertised through BGP EVPN.
When you add a local MAC address entry, make sure the specified Ethernet service instance has been mapped to the VSI. When you add a remote MAC address entry, make sure the VSI's VXLAN has been specified on the VXLAN or VXLAN-DCI tunnel.
Do not configure static remote-MAC entries for tunnels that are automatically established by using EVPN.
·     EVPN re-establishes tunnels if the transport-facing interface goes down and then comes up. If you have configured static remote-MAC entries, the entries are deleted when the tunnels are re-established.
·     EVPN re-establishes tunnels if you perform configuration rollback. If the tunnel IDs change during tunnel re-establishment, configuration rollback fails, and static remote-MAC entries on the tunnels cannot be restored.
The undo mac-address static vsi vsi-name command removes all static MAC address entries for a VSI.
# Add MAC address 000f-e201-0101 to VSI vsi1. Specify Tunnel-interface 1 as the outgoing interface.
[Sysname] mac-address static 000f-e201-0101 interface tunnel 1 vsi vsi1
# Add MAC address 000f-e201-0102 of Ethernet service instance 1 to VSI vsi1. Specify FortyGigE 1/0/1 as the outgoing interface.
[Sysname] mac-address static 000f-e201-0102 interface fortygige 1/0/1 service-instance 1 vsi vsi1
reserved vxlan
Use reserved vxlan to specify a reserved VXLAN.
Use undo reserved vxlan to restore the default.
reserved vxlan vxlan-id
undo reserved vxlan
No VXLAN has been reserved.
You can specify only one reserved VXLAN on the VTEP. The reserved VXLAN cannot be the VXLAN created on any VSI.
The reserved VXLAN ID cannot be the same as the remote VXLAN ID specified by using the mapping vni command.
# Specify VXLAN 10000 as the reserved VXLAN.
[Sysname] reserved vxlan 10000
mapping vni (EVPN Command Reference)
Use reset arp suppression vsi to clear ARP flood suppression entries on VSIs.
reset arp suppression vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears ARP flood suppression entries on all VSIs.
# Clear ARP flood suppression entries on all VSIs.
<Sysname> reset arp suppression vsi
This command will delete all entries. Continue? [Y/N]:y
Use reset ipv6 nd suppression vsi to clear ND flood suppression entries on VSIs.
reset ipv6 nd suppression vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears ND flood suppression entries on all VSIs.
# Clear ND flood suppression entries on all VSIs.
<Sysname> reset ipv6 nd suppression vsi
Use reset l2vpn mac-address to clear dynamic MAC address entries on VSIs.
reset l2vpn mac-address [ vsi vsi-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears all dynamic MAC address entries on all VSIs.
Use this command when the number of dynamic MAC address entries reaches the limit or the device learns incorrect MAC addresses.
# Clear the dynamic MAC address entries on VSI vpn1.
<Sysname> reset l2vpn mac-address vsi vpn1
display l2vpn mac-address vsi
Use reset l2vpn mac-address mac-move to clear the MAC address move records after the device is started for all VSIs.
# Clear the MAC address move records after the device is started for all VSIs.
<Sysname> reset l2vpn mac-address mac-move
Use reset l2vpn statistics ac to clear packet statistics on ACs.
reset l2vpn statistics ac [ interface interface-type interface-number service-instance instance-id]
service-instance instance-id: Specifies an Ethernet service instance ID in the range of 1 to 4096.
If you do not specify any parameters, this command clears packet statistics on all ACs.
# Clear packet statistics for Ethernet service instance 1 on FortyGigE 1/0/1.
<Sysname> reset l2vpn statistics ac interface fortygige 1/0/1 service-instance 1
display l2vpn service-instance verbose
Use reset l2vpn statistics vsi to clear packet statistics on VSIs.
reset l2vpn statistics vsi [ name vsi-name ]
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears packet statistics on all VSIs.
# Clear packet statistics on all VSIs.
<Sysname> reset l2vpn statistics vsi
restrain
Use restrain to set broadcast, multicast, or unknown unicast restraint bandwidth for a VSI.
Use undo restrain to restore the default.
restrain { broadcast | multicast | unknown-unicast } bandwidth
undo restrain { broadcast | multicast | unknown-unicast }
A VSI's broadcast restraint bandwidth, unknown multicast restraint bandwidth, and unknown unicast restraint bandwidth are not set.
VSI view
broadcast: Specifies the broadcast restraint bandwidth.
multicast: Specifies the multicast restraint bandwidth.
unknown-unicast: Specifies the unknown unicast restraint bandwidth. Unknown unicast packets refer to the unicast packets whose destination MAC addresses are not in the MAC address table of the VSI.
bandwidth: Specifies the broadcast, multicast, or unknown unicast restraint bandwidth in kbps. The value for this argument can be 0 or in the range of 64 to 4194303. If you set this argument to 0, the command disables the specified kind of flood traffic.
When the bandwidth of incoming broadcast, multicast, or unknown unicast traffic on VXLAN tunnels of a VSI exceeds the configured restraint bandwidth, the VSI drops the exceeding traffic.
# Set the broadcast restraint bandwidth, multicast restraint bandwidth, and unknown unicast restraint bandwidth to 100 kbps for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] restrain broadcast 100
[Sysname-vsi-vpn1] restrain multicast 100
[Sysname-vsi-vpn1] restrain unknown-unicast 100
display l2vpn vsi
rewrite inbound tag
Use rewrite inbound tag to configure the VLAN tag processing rule for incoming traffic.
Use undo rewrite inbound tag to restore the default.
rewrite inbound tag { nest { c-vid vlan-id | s-vid vlan-id [ c-vid vlan-id ] } | remark { { 1-to-1 | 2-to-1 } { c-vid vlan-id | s-vid vlan-id } | { 1-to-2 | 2-to-2 } s-vid vlan-id c-vid vlan-id } | strip { c-vid | s-vid [ c-vid ] } } [ symmetric ]
VLAN tags of incoming traffic are not processed.
Ethernet service instance view
nest: Adds VLAN tags.
c-vid: Specifies an inner VLAN tag.
s-vid: Specifies an outer VLAN tag.
vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
remark: Maps VLAN tags.
1-to-1: Performs one-to-one mapping to replace one VLAN tag of packets with the specified VLAN tag.
2-to-1: Performs two-to-one mapping to replace the outer and inner VLAN tags of double tagged packets with the specified VLAN tag.
1-to-2: Performs one-to-two mapping to replace the VLAN tag of single tagged packets with the specified outer and inner VLAN tags.
2-to-2: Performs two-to-two mapping to replace the outer and inner VLAN tags of double tagged packets with the specified outer and inner VLAN tags.
strip: Removes VLAN tags.
symmetric: Applies the reverse VLAN tag processing rule to outgoing traffic.
To modify the VLAN tag processing rule for incoming traffic, you must first delete the existing rule by using the undo rewrite inbound tag command.
When you use this command on an Ethernet service instance, follow these restrictions:
·     You must execute this command before you map the Ethernet service instance to a VSI.
·     The Ethernet service instance does not support this command if its matching outer VLAN ID is the PVID of the interface that hosts the Ethernet service instance.
·     The Ethernet service instance must use Ethernet access mode.
·     Do not use the encapsulation { default | tagged | untagged } command on the Ethernet service instance.
·     Do not specify a VLAN ID as both the matching outer and inner VLAN IDs of the Ethernet service instance.
·     On the device, you cannot execute both the rewrite inbound tag and rewrite outbound tag commands on the Ethernet service instances of a VSI.
# Configure Ethernet service instance 1 on FortyGigE 1/0/1 to replace outer VLAN tag 10 with outer VLAN tag 100 for incoming traffic.
[Sysname-FortyGigE1/0/1-srv1] encapsulation s-vid 10
[Sysname-FortyGigE1/0/1-srv1] rewrite inbound tag remark 1-to-1 s-vid 100
Use rewrite outbound tag to configure the VLAN tag processing rule for outgoing traffic.
Use undo rewrite outbound tag to restore the default.
rewrite outbound tag { nest { c-vid vlan-id | s-vid vlan-id [ c-vid vlan-id ] } | remark { { 1-to-1 | 2-to-1 } { c-vid vlan-id | s-vid vlan-id } | { 1-to-2 | 2-to-2 } s-vid vlan-id c-vid vlan-id } | strip { c-vid | s-vid [ c-vid ] } }
VLAN tags of outgoing traffic are not processed.
To modify the VLAN tag processing rule for outgoing traffic, you must first delete the existing rule by using the undo rewrite outbound tag command.
·     This command adds the specified VLAN tag to an untagged packet and replaces the outmost VLAN tag of a tagged packet with the specified VLAN tag.
# Configure Ethernet service instance 1 on FortyGigE 1/0/1 to replace outer VLAN tag 10 with outer VLAN tag 100 for incoming traffic and to remove the outer VLAN tags for outgoing traffic.
[Sysname] interface fortygige 1/0/1
[Sysname-FortyGigE1/0/1-srv1] rewrite outbound tag strip s-vid
selective-flooding mac-address
Use selective-flooding mac-address to enable selective flood for a MAC address.
Use undo selective-flooding mac-address to disable selective flood for a MAC address.
selective-flooding mac-address mac-address
undo selective-flooding mac-address mac-address
Selective flood is disabled for all MAC addresses.
VSI view
mac-address: Specifies a MAC address. The MAC address cannot be all Fs.
This command excludes a remote unicast or multicast MAC address from the remote flood suppression done by using the flooding disable command. The VTEP will flood the frames destined for the specified MAC address to remote sites when floods are confined to the local site.
# Enable selective flood for 000f-e201-0101 on VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] selective-flooding mac-address 000f-e201-0101
flooding disable (VSI view)
service-instance
Use service-instance to create an Ethernet service instance and enter its view, or enter the view of an existing Ethernet service instance.
Use undo service-instance to delete an Ethernet service instance.
undo service-instance instance-id
No Ethernet service instances exist.
# On Layer 2 Ethernet interface FortyGigE 1/0/1, create Ethernet service instance 1 and enter Ethernet service instance view.
shutdown
Use shutdown to shut down a VSI.
Use undo shutdown to bring up a VSI.
shutdown
VSIs are up.
VSI view
Use this command to temporarily disable a VSI to provide Layer 2 switching services. The shutdown action does not change settings on the VSI. You can continue to configure the VSI. After you bring up the VSI again, the VSI provides services based on the latest settings.
# Shut down VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
display l2vpn vsi
statistic mode
Use statistic mode to set the packet statistic collection mode.
Use undo statistic mode to restore the default.
statistic mode { ac | vsi }
undo statistic mode
The default packet statistic collection mode is VSI.
ac: Specifies the AC mode.
vsi: Specifies the VSI mode.
To enable packet statistics for an Ethernet service instance, set the packet statistic collection mode to AC and execute the statistics enable command in Ethernet service instance view.
To enable packet statistics for a VSI and its associated VSI interface, set the packet statistic collection mode to VSI and execute the statistics enable command in VSI view.
The statistic mode vsi command takes effect only if the VSI interface is associated with only one VSI.
You can use the statistic mode ac, statistic mode queue, or statistic mode vsi command to set the packet statistic collection mode. If you execute the statistic mode command multiple times, the most recent configuration takes effect.
# Set the packet statistic collection mode to VSI.
[Sysname] statistic mode vsi
Do you want to change the packet statistic mode? [Y/N]:y
statistic mode queue (ACL and QoS Command Reference)
statistics enable (Ethernet service instance view)
Use statistics enable to enable packet statistics for an Ethernet service instance.
Use undo statistics enable to disable packet statistics for an Ethernet service instance.
statistics enable
The packet statistics feature is disabled for an Ethernet service instance.
For this command to take effect, you must configure a frame match criterion for the Ethernet service instance and map it to a VSI. If you modify the frame match criterion or VSI mapping, packet statistics of the instance is cleared.
# Enable packet statistics for Ethernet service instance 200 on FortyGigE 1/0/1.
[Sysname-FortyGigE1/0/1] service-instance 200
[Sysname-FortyGigE1/0/1-srv200] statistics enable
Related command
statistics enable (VSI view)
Use statistics enable to enable packet statistics for a VSI.
Use undo statistics enable to disable packet statistics for a VSI.
statistics enable
The packet statistics feature is disabled for a VSI.
VSI view
# Enable packet statistics for VSI vsi1.
[Sysname] vsi vsi1
[Sysname-vsi-vsi1] statistics enable
tunnel
Use tunnel to assign VXLAN tunnels to a VXLAN.
Use undo tunnel to remove VXLAN tunnels from a VXLAN.
tunnel { tunnel-number [ backup-tunnel tunnel-number | flooding-proxy | relay-agent { ipoe | pppoe } *] | all }
undo tunnel { tunnel-number | all }
A VXLAN does not contain VXLAN tunnels.
VXLAN view
tunnel-number: Specifies a tunnel interface number. The tunnel must be an existing VXLAN tunnel.
backup-tunnel tunnel-number: Specifies a backup tunnel by its tunnel interface number. The tunnel must be an existing VXLAN tunnel.
flooding-proxy: Enables flood proxy on the tunnel for the VTEP to send flood traffic to the flood proxy server. The flood proxy server replicates and forwards flood traffic to remote VTEPs. If you do not specify this keyword, flood proxy is disabled on the tunnel.
relay-agent: Enables relay agent for the tunnel to transmit PPPoE or IPoE packets to the remote VTEP. If you do not specify this keyword, relay agent is disabled on the tunnel.
·     ipoe: Enables IPoE relay agent.
·     pppoe: Enables PPPoE relay agent.
all: Specifies all VXLAN tunnels.
This command assigns a VXLAN tunnel to a VXLAN to provide Layer 2 connectivity for the VXLAN between two sites. In unicast mode, the system floods unknown unicast, multicast, and broadcast traffic to each tunnel in the VXLAN.
You can assign multiple VXLAN tunnels to a VXLAN, and configure a VXLAN tunnel to trunk multiple VXLANs.
To assign a pair of primary and backup VXLAN tunnels to the VXLAN, specify the backup-tunnel tunnel-number option. When the primary VXLAN tunnel is operating correctly, the backup VXLAN tunnel does not forward traffic. When the primary VXLAN tunnel goes down, traffic is switched to the backup VXLAN tunnel.
If you enable PPPoE or IPoE relay agent on a VXLAN tunnel, the device uses this tunnel to send PPPoE or IPoE packets received from the associated VXLAN to the remote VTEP. Typically, relay agent is used on DPs in the forwarding-control separation solution. For a DP to send control traffic (PPPoE or IPoE packets) to a CP, you must enable PPPoE or IPoE relay agent on the VXLAN tunnel between the DP and the CP.
If you enable relay agent multiple times on a VXLAN tunnel, the most recent configuration takes effect. For example, if you execute the tunnel 1 relay-agent pppoe and tunnel 1 relay-agent ipoe commands in sequence, only IPoE relay agent is enabled on the tunnel.
If you assign VXLAN tunnels to a VXLAN one by one, you cannot remove all the VXLAN tunnels by using the undo tunnel all command.
If you assign all VXLAN tunnels to a VXLAN by using the tunnel all command, you cannot remove the VXLAN tunnels one by one. You can only use the undo tunnel all command to remove all the VXLAN tunnels.
As a best practice, use the tunnel all command only when batch VXLAN tunnel assignment is necessary.
# Assign VXLAN tunnels 1 and 2 to VXLAN 10000.
[Sysname] vsi vpna
[Sysname-vsi-vpna] vxlan 10000
[Sysname-vsi-vpna-vxlan-10000] tunnel 1
[Sysname-vsi-vpna-vxlan-10000] tunnel 2
tunnel bfd enable
Use tunnel bfd enable to enable BFD on a VXLAN tunnel interface.
Use undo tunnel bfd enable to disable BFD on a VXLAN tunnel interface.
tunnel bfd enable destination-mac mac-address
BFD is disabled on a VXLAN tunnel interface.
destination-mac mac-address: Specifies a destination MAC address in H-H-H format for BFD control packets. The MAC address must be a remote VTEP address or a multicast address. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001.
Enable BFD on both ends of a VXLAN tunnel for quick link connectivity detection. The VTEPs periodically send BFD single-hop control packets to each other through the VXLAN tunnel. A VTEP sets the tunnel state to Defect if it has not received control packets from the remote end for 5 seconds. In this situation, the tunnel interface state is still Up. The tunnel state will change from Defect to Up if the VTEP can receive BFD control packets again.
For BFD sessions to come up, you must reserve a VXLAN by using the reserved vxlan command.
# Enable BFD on VXLAN tunnel interface Tunnel 9, and specify 1-1-1 as the destination MAC address for BFD control packets.
[Sysname] interface tunnel 9 mode vxlan
[Sysname-Tunnel9] tunnel bfd enable destination-mac 1-1-1
tunnel global source-address
Use tunnel global source-address to specify a global source address for VXLAN tunnels.
Use undo tunnel global source-address to restore the default.
tunnel global source-address { ipv4-address | ipv6 ipv6-address }
undo tunnel global source-address [ ipv6 ]
No global source address is specified for VXLAN tunnels.
ipv4-address: Specifies an IPv4 address.
ipv6 ipv6-address: Specifies an IPv6 address. If you do not specify the ipv6 keyword when executing the undo tunnel global source-address command, the command deletes the global source IPv4 address for VXLAN tunnels.
IMPORTANT
IMPORTANT:
For correct VXLAN deployment and VTEP management, do not manually specify tunnel-specific source addresses for VXLAN tunnels if OVSDB is used.
A VXLAN tunnel uses the global source address if you do not specify a source interface or source address for the tunnel.
The global source address takes effect only on VXLAN tunnels (VXLAN-DCI tunnels not included).
IPv4 VXLAN tunnels use the global source IPv4 address and IPv6 VXLAN tunnels use the global source IPv6 addresses. The device does not support VXLAN over IPv6 tunnels.
# Specify 1.1.1.1 as the global source address for VXLAN tunnels.
[Sysname] tunnel global source-address 1.1.1.1
vlan-forwarding static
Use vlan-forwarding static to configure a static VLAN-based MAC address entry on an Ethernet service instance.
Use undo vlan-forwarding static to restore the default.
vlan-forwarding static s-vid vlan-id [ c-vid vlan-id ]
No static VLAN-based MAC address entries exist.
s-vid vlan-id: Specifies an outer VLAN ID in the range of 1 to 4094.
c-vid vlan-id: Specifies an inner VLAN ID in the range of 1 to 4094. To configure an entry that contains both inner and outer VLAN IDs, you must specify this option. The MAC address in the entry uses the 0-SVLAN tag-CVLAN tag format. To configure an entry that contains only the outer VLAN ID, do not specify this option. The MAC address in the entry uses the 0-SVLAN tag-0 format.
To forward traffic to the local site when MAC learning is disabled on an Ethernet service instance, you must configure static VLAN-based MAC address entries. The outgoing interface in the entries is the Ethernet service instance.
# Configure a static VLAN-based MAC address entry on Ethernet service instance 5.
[Sysname-FortyGigE1/0/1] service-instance 5
[Sysname-FortyGigE1/0/1-srv5] encapsulation s-vid 5
[Sysname-FortyGigE1/0/1-srv5] vlan-forwarding static s-vid 5
forwarding mode
learning mode
vsi
Use vsi to create a VSI and enter its view, or enter the view of an existing VSI.
Use undo vsi to delete a VSI.
vsi vsi-name
undo vsi vsi-name
No VSIs exist.
vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters.
A VSI acts as a virtual switch to provide Layer 2 switching services for a VXLAN on a VTEP. A VSI has all functions of a physical Ethernet switch, including source MAC address learning, MAC address aging, and flooding.
A VSI can provide services only for one VXLAN.
# Create VSI vxlan10 and enter VSI view.
[Sysname] vsi vxlan10
[Sysname-vsi-vxlan10]
display l2vpn vsi
vxlan
Use vxlan to create a VXLAN and enter its view, or enter the view of an existing VXLAN.
Use undo vxlan to restore the default.
vxlan vxlan-id
undo vxlan
No VXLANs exist.
VSI view
You can create only one VXLAN for a VSI. The VXLAN ID for each VSI must be unique.
Do not create a VXLAN whose ID is identical to one of the following VXLAN IDs:
·     Remote VXLAN ID for VXLAN mapping, configurable with the mapping vni command.
·     Reserved VXLAN ID, configurable with the reserved vxlan command.
·     L3 VXLAN ID, configurable with the l3-vni command.
# Create VXLAN 10000 for VSI vpna and enter VXLAN view.
[Sysname] vsi vpna
vsi
vxlan default-decapsulation
Use vxlan default-decapsulation to enable default VXLAN decapsulation.
Use undo vxlan default-decapsulation to restore the default.
vxlan default-decapsulation source interface interface-type interface-number
undo vxlan default-decapsulation source interface
Default VXLAN decapsulation is disabled.
source interface interface-type interface-number: Specifies an interface by its type and number.
If a VXLAN tunnel is configured on only one VTEP of a pair of VTEPs, the VXLAN tunnel is a unidirectional tunnel to the VTEP not configured with the tunnel. In this situation, that VTEP drops the VXLAN packets received from the unidirectional VXLAN tunnel. For a VTEP to receive VXLAN packets from a unidirectional VXLAN tunnel, enable default VXLAN decapsulation on the interface whose IP address is the tunnel destination address. The VTEP will decapsulate all the VXLAN packets destined for the IP address of that interface.
This command takes effect only when the specified interface has an IP address.
Default VXLAN decapsulation does not take effect on bidirectional VXLAN tunnels. If you remove the one-way communication issue for a VXLAN tunnel by configuring the tunnel on both the local and remote VTEPs, this feature no longer takes effect on that tunnel.
# Enable default VXLAN decapsulation.
[Sysname] vxlan default-decapsulation source interface fortygige 1/0/1
vxlan invalid-udp-checksum discard
Use vxlan invalid-udp-checksum discard to enable the device to drop the VXLAN packets that fail UDP checksum check.
Use undo vxlan invalid-udp-checksum discard to restore the default.
The device does not check the UDP checksum of VXLAN packets.
This command enables the device to check the UDP checksum of VXLAN packets.
The device always sets the UDP checksum of VXLAN packets to 0. For compatibility with third-party devices, a VXLAN packet can pass the check if its UDP checksum is 0 or correct. If its UDP checksum is incorrect, the VXLAN packet fails the check and is dropped.
# Enable the device to drop the VXLAN packets that fail UDP checksum check.
[Sysname] vxlan invalid-udp-checksum discard
vxlan invalid-vlan-tag discard
Use vxlan invalid-vlan-tag discard to enable the device to drop the VXLAN packets that have 802.1Q VLAN tags in the inner Ethernet header.
Use undo vxlan invalid-vlan-tag discard to restore the default.
The device does not check whether a VXLAN packet has 802.1Q VLAN tags in the inner Ethernet header.
If a remote VTEP uses the Ethernet access mode, its VXLAN packets might contain 802.1Q VLAN tags. To prevent the local VTEP from dropping the VXLAN packets, do not execute the vxlan invalid-vlan-tag discard command on the local VTEP.
To configure the access mode, use the xconnect vsi command.
# Enable the device to drop VXLAN packets that have 802.1Q VLAN tags.
[Sysname] vxlan invalid-vlan-tag discard
xconnect vsi
vxlan ip-forwarding
Use vxlan ip-forwarding to enable Layer 3 forwarding for all VXLANs.
Use undo vxlan ip-forwarding to enable Layer 2 forwarding for all VXLANs.
vxlan ip-forwarding [ tagged | untagged ]
Layer 3 forwarding is enabled for all VXLANs, and VXLAN packets do not carry VLAN tags.
Views.
tagged: Specifies the tagged mode. In this mode, the VTEP adds a VLAN tag to a VXLAN packet.
untagged: Specifies the untagged mode. In this mode, the VTEP does not add a VLAN tag to a VXLAN packet.
If the device is a VTEP, enable Layer 2 forwarding for VXLANs. If the device is a VXLAN IP gateway, enable Layer 3 forwarding for VXLANs.
In Layer 3 forwarding mode, the VTEP uses the ARP table (IPv4 network) or ND table (IPv6 network) to forward traffic for VXLANs. In Layer 2 forwarding mode, the VTEP uses the MAC address table to forward traffic for VXLANs.
You must delete all VSIs, VSI interfaces, and VXLAN tunnel interfaces before you can change the forwarding mode.
If you enable Layer 3 forwarding for VXLANs, the tagging status of VXLAN packets is not determined by the link type of the outgoing interface. You must use this command to set the tagging mode of VXLAN packets.
·     Set the tagging mode to untagged if the following requirements are met:
¡     The link type of the outgoing interface is access, trunk, or hybrid.
¡     VXLAN packets are transmitted to the next hop through the PVID of the outgoing interface.
·     Set the tagging mode to tagged if the following requirements are met:
¡     The link type of the outgoing interface is trunk or hybrid.
¡     VXLAN packets are transmitted to the next hop through a VLAN other than the PVID of the outgoing interface.
If you do not set the tagging mode when you execute this command, the untagged mode is used.
You must delete all VXLAN tunnel interfaces before you can change the tagging mode of VXLAN packets.
# Enable Layer 3 forwarding for all VXLANs, and use the default tagging mode (untagged) for VXLAN packets.
<Sysname>system-view
[Sysname] vxlan ip-forwarding
vxlan local-mac report
Use vxlan local-mac report to enable local-MAC logging.
Use undo vxlan local-mac report to disable local-MAC logging.
Local-MAC logging is disabled.
When the local-MAC logging feature is enabled, the VXLAN module immediately sends a log message with its local MAC addresses to the information center. When a local MAC address is added or removed, a log message is also sent to the information center to report the local-MAC change.
With the information center, you can set log message filtering and output rules, including output destinations. For more information about configuring the information center, see Network Management and Monitoring Configuration Guide.
# Enable local-MAC logging.
[Sysname] vxlan local-mac report
Use vxlan tunnel mac-learning disable to disable remote-MAC address learning.
Use undo vxlan tunnel mac-learning disable to enable remote-MAC address learning.
Remote-MAC address learning is enabled.
When network attacks occur, use this command to prevent the device from learning incorrect remote MAC addresses in the data plane.
# Disable remote-MAC address learning.
[Sysname] vxlan tunnel mac-learning disable
vxlan udp-port
Use vxlan udp-port to set the destination UDP port number for VXLAN packets.
Use undo vxlan udp-port to restore the default.
vxlan udp-port port-number
undo vxlan udp-port
The destination UDP port number is 4789 for VXLAN packets.
port-number: Specifies a UDP port number in the range of 1 to 65535. As a best practice, specify a port number in the range of 1024 to 65535 to avoid conflict with well-known ports.
You must configure the same destination UDP port number on all VTEPs in a VXLAN.
# Set the destination UDP port number to 6666 for VXLAN packets.
[Sysname] vxlan udp-port 6666
vxlan vlan-based
Use vxlan vlan-based to enable VLAN-based VXLAN assignment.
Use undo vxlan vlan-based to disable VLAN-based VXLAN assignment.
vxlan vlan-based
VLAN-based VXLAN assignment is disabled.
If you use Ethernet service instances as ACs, you can assign customer traffic to a VXLAN by using one of the following methods:
·     Ethernet service instance-to-VSI mapping—This method uses the frame match criterion of an Ethernet service instance to match a list of VLANs on a site-facing Layer 2 interface. The VTEP assigns customer traffic to a VXLAN by mapping the Ethernet service instance to a VSI.
·     VLAN-based VXLAN assignment—This method maps a VLAN to a VXLAN. When a VLAN is mapped to a VXLAN and VLAN-based VXLAN assignment is enabled, the device automatically performs the following operations:
a.     Creates an Ethernet service instance that uses the VLAN ID as its instance ID on each interface in the VLAN.
b.     Maps the Ethernet service instances to the VSI of the VXLAN.
On an interface, the frame match criterion of the Ethernet service instance is set as follows:
¡     If the VLAN ID is the PVID of the interface, the Ethernet service instance matches untagged frames.
¡     If the VLAN ID is not the PVID of the interface, the Ethernet service instance matches frames tagged with an outer VLAN ID that is same as that VLAN ID.
Do not configure both Ethernet service instance-to-VSI mapping and VLAN-based VXLAN assignment.
VLAN-based VXLAN assignment takes effect only on access and trunk ports. It does not take effect on hybrid ports.
# Enable VLAN-based VXLAN assignment.
[Sysname] vxlan vlan-based
vxlan vni
Use vxlan vni to map a VLAN to a VXLAN.
Use undo vxlan vni to remove the VXLAN mapping for a VLAN.
vxlan vni vxlan-id
undo vxlan vni
A VLAN is not mapped to a VXLAN.
VLAN view
Before you map VLANs to VXLANs, enable VLAN-based VXLAN assignment by using the vxlan vlan-based command.
You cannot map VLAN 1 to any VXLAN.
Do not map a VLAN to the L3 VXLAN ID of EVPN.
If you map a VLAN to a nonexistent VXLAN, the configuration takes effect after the VXLAN is created.
# Map VLAN 10 to VXLAN 100.
[Sysname] vlan 10
[Sysname-vlan10] vxlan vni 100
vxlan vlan-based
xconnect vsi
Use xconnect vsi to map an AC to a VSI.
Use undo xconnect vsi to restore the default.
xconnect vsi vsi-name [ access-mode { ethernet | vlan } ] [ track track-entry-number&<1-3> ]
undo xconnect vsi
An AC is not mapped to any VSI.
vsi-name: Specifies the VSI name, a case-sensitive string of 1 to 31 characters.
access-mode: Specifies an access mode. The default access mode is VLAN.
ethernet: Specifies the Ethernet access mode.
vlan: Specifies the VLAN access mode.
track track-entry-number&<1-3>: Specifies a space-separated list of up to three track entry numbers in the range of 1 to 1024. The AC is up only if a minimum of one associated track entry is in positive state.
To monitor the status of an AC, associate it with track entries.
To configure this command for an Ethernet service instance, you must first use the encapsulation command to add a frame match criterion to the service instance.
For traffic that matches the Ethernet service instance, the system uses the VSI's MAC address table to make a forwarding decision.
The access mode determines how a VTEP processes the 802.1Q VLAN tags in the inner Ethernet frames assigned to the VSI.
·     VLAN access mode—Ethernet frames received from or sent to the local site must contain 802.1Q VLAN tags.
¡     For an Ethernet frame received from the local site, the VTEP removes all its 802.1Q VLAN tags before forwarding the frame.
¡     For an Ethernet frame destined for the local site, the VTEP adds 802.1Q VLAN tags to the frame before forwarding the frame.
In VLAN access mode, VXLAN packets sent between VXLAN sites do not contain 802.1Q VLAN tags. VXLAN can provide Layer 2 connectivity for different 802.1Q VLANs between sites. You can use different 802.1Q VLANs to provide the same service in different sites.
·     Ethernet access mode—The VTEP does not process the 802.1Q VLAN tags of Ethernet frames received from or sent to the local site.
¡     For an Ethernet frame received from the local site, the VTEP forwards the frame with the 802.1Q VLAN tags intact.
¡     For an Ethernet frame destined for the local site, the VTEP forwards the frame without adding 802.1Q VLAN tags.
In Ethernet access mode, VXLAN packets sent between VXLAN sites contain 802.1Q VLAN tags. VXLAN cannot provide Layer 2 connectivity for different 802.1Q VLANs between sites. You must use the same 802.1Q VLAN to provide the same service between sites.
# On FortyGigE 1/0/1, configure Ethernet service instance 200 to match frames with an outer 802.1Q VLAN tag of 200, and map the instance to VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] quit
[Sysname-FortyGigE1/0/1-srv200] encapsulation s-vid 200
[Sysname-FortyGigE1/0/1-srv200] xconnect vsi vpn1
encapsulation
vsi
VXLAN IP gateway commands
arp distributed-gateway dynamic-entry synchronize
Use arp distributed-gateway dynamic-entry synchronize to enable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
Use undo arp distributed-gateway dynamic-entry synchronize to disable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
Dynamic ARP entry synchronization is disabled for distributed VXLAN IP gateways.
When local proxy ARP is enabled on distributed VXLAN IP gateways, each gateway learns ARP information independently. A gateway does not forward ARP packets destined for its local VSI interfaces to other gateways. For distributed VXLAN IP gateways to have the same ARP entries, you must enable dynamic ARP entry synchronization.
A controller or the EVPN feature can also synchronize ARP entries among distributed VXLAN IP gateways. When you use a controller or the EVPN feature, do not enable dynamic ARP entry synchronization.
# Enable dynamic ARP entry synchronization for distributed VXLAN IP gateways.
[Sysname] arp distributed-gateway dynamic-entry synchronize
distributed-gateway local
local-proxy-arp enable (Layer 3—IP Services Command Reference)
arp send-rate
Use arp send-rate to set an ARP packet sending rate limit for a VSI interface.
Use undo arp send-rate to remove the ARP packet sending rate limit for a VSI interface.
arp send-rate pps
undo arp send-rate
The ARP packet sending rate is not limited for a VSI interface.
VSI interface view
pps: Specifies a rate limit in the range of 1 to 500 pps.
VMs have limited capacity to process packets. To prevent packet processing from degrading VM performance, limit the ARP packet sending rate of the VSI interface for VMs. The VTEP will drop excess ARP packets if the rate limit is exceeded.
# Set the ARP packet sending rate limit to 50 pps for VSI-interface 1.
<Sysname> system
[Sysname] interface vsi-interface 1
[Sysname-Vsi-interface1] arp send-rate 50
bandwidth
Use bandwidth to set the expected bandwidth for a VSI interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth (in kbps) of a VSI interface equals the interface baud rate divided by 1000.
VSI interface view
# Set the expected bandwidth to 10000 kbps for VSI-interface 100.
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] bandwidth 10000
default
Use default to restore the default settings for a VSI interface.
default
VSI interface view
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions.
To resolve this problem:
1.     Use the display this command in interface view to identify these commands.
2.     Use their undo forms or follow the command reference to restore their default settings.
3.     If the restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for VSI-interface 100.
[Sysname-Vsi-interface100] default
This command will restore the default settings. Continue? [Y/N]:y
description
Use description to configure the description of a VSI interface.
The description of a VSI interface is interface-name plus Interface (for example, Vsi-interface100 Interface).
VSI interface view
# Configure the description as gateway for VXLAN 10 for VSI-interface 100.
[Sysname-Vsi-interface100] description gateway for VXLAN 10
display interface vsi-interface
Use display interface vsi-interface to display information about VSI interfaces.
display interface [ vsi-interface [ vsi-interface-id ] ] [ brief [ description | down ] ]
vsi-interface [ vsi-interface-id ]: Specifies VSI interfaces. If you specify a VSI interface, this command displays information about the specified interface. If you specify only the vsi-interface keyword, this command displays information about all VSI interfaces. If you do not specify the vsi-interface [ vsi-interface-id ] option, this command displays information about all interfaces. Make sure the specified VSI interfaces have been created on the device.
brief: Display brief interface information. If you do not specify this keyword, the command displays detailed interface information.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays interfaces that are physically down as well as the down reason. If you do not specify this keyword, the command does not filter output by physical interface state.
# Display information about VSI-interface 100.
<Sysname> display interface vsi-interface 100
Vsi-interface100
Current state: UP
Line protocol state: UP
Description: Vsi-interface100 Interface
Bandwidth: 1000000 kbps
IP packet frame type: Ethernet II, hardware address: 0011-2200-0102
IPv6 packet frame type: Ethernet II, hardware address: 0011-2200-0102
Table 15 Command output
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down.
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface:
·     UP(spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist.
Description of the interface.
Bandwidth
Expected bandwidth of the interface.
MTU of the interface.
The interface is not assigned an IP address and cannot process IP packets.
Internet address
IP address of the interface. The primary attribute indicates that the address is the primary IP address.
IPv4 packet framing format.
hardware address
MAC address.
IPv6 packet framing format.
Physical
Physical type of the interface, which is fixed at Unknown.
baudrate
Interface baudrate in kbps.
Last time when the reset counters interface vsi-interface command was used to clear interface statistics.
This field displays Never if the reset counters interface vsi-interface command has never been used on the interface since the device startup.
Average input rate for the last 300 seconds.
Average output rate for the last 300 seconds.
Incoming traffic statistics on the interface:
·     Number of incoming packets.
·     Number of incoming bytes.
·     Number of dropped incoming packets.
Outgoing traffic statistics on the interface:
·     Number of outgoing packets.
·     Number of outgoing bytes.
·     Number of dropped outgoing packets.
# Display brief information about all VSI interfaces.
<Sysname> display interface vsi-interface brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
Vsi100               DOWN DOWN     --
# Display brief information and complete description for VSI-interface 100.
<Sysname> display interface vsi-interface 100 brief description
Vsi100               UP    UP      1.1.1.1         VSI-interface100
# Displays interfaces that are physically down and the down reason.
Interface            Link   Cause
Vsi100               DOWN   Administratively
Vsi200               DOWN   Administratively
Table 16 Command output
Abbreviated interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     UP (s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag.
·     DOWN—The data link layer protocol of the interface is down.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Not connected—The interface is not mapped to any VSI, or the mapped VSI does not have any AC or VXLAN tunnel.
Use distributed-gateway local to specify a VSI interface as a distributed gateway to provide services for the local site.
Use undo distributed-gateway local to restore the default.
A VSI interface is not a distributed gateway.
VSI interface view
If a VXLAN uses distributed gateway services, you must assign the same IP address to the VXLAN's VSI interfaces on different VTEPs. To avoid IP address conflicts, you must specify the VSI interface on each VTEP as a distributed gateway.
# Specify VSI-interface 100 as a distributed gateway.
[Sysname-Vsi-interface100] distributed-gateway local
gateway subnet
Use gateway subnet to assign a subnet to a VSI.
Use undo gateway subnet to remove a subnet from a VSI.
gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
undo gateway subnet { ipv4-address wildcard-mask | ipv6-address prefix-length }
No subnet is assigned to a VSI.
VSI view
ipv4-address: Specifies an IPv4 subnet address in dotted-decimal notation.
wildcard-mask: Specifies a wildcard mask in dotted decimal notation. In contrast to a network mask, the 0 bits in a wildcard mask represent "do care" bits, and the 1 bits represent "don't care" bits. If the "do care" bits in a packet's IP address are identical to the "do care" bits in the specified subnet address, the packet is assigned to the VSI. All "don't care" bits are ignored. The 0s and 1s in a wildcard mask can be noncontiguous. For example, 0.255.0.255 is a valid wildcard mask.
ipv6-address prefix-length: Specifies an IPv6 subnet address and the address prefix length in the range of 1 to 128.
You must configure this command on VSIs that share a gateway interface. This command enables the VSI interface to identify the VSI of a packet.
You can assign a maximum of eight IPv4 and IPv6 subnets to a VSI.
You must specify a gateway interface for a VSI before you can assign subnets to the VSI. If you remove the gateway interface from the VSI, the VSI's subnet settings are automatically deleted.
For VSIs that share a gateway interface, the subnets must be unique.
# Assign subnet 100.0.10.0/24 to VSI vxlan.
[Sysname] vsi vxlan
[Sysname-vsi-vxlan] gateway subnet 100.0.10.0 0.0.0.255
gateway vsi-interface
Use gateway vsi-interface to specify a gateway interface for a VSI.
Use undo gateway vsi-interface to restore the default.
gateway vsi-interface vsi-interface-id
No gateway interface is specified for a VSI.
VSI view
vsi-interface-id: Specifies a VSI interface by its number. The VSI interface must already exist.
When you delete a VSI interface by using the undo interface vsi-interface command, the gateway interface setting of the VSI interface is also deleted.
A VSI can have only one gateway interface. Multiple VSIs can share a gateway interface.
# Specify VSI-interface 100 as the gateway interface for VSI vpna.
[Sysname] vsi vpna
[Sysname-vsi-vpna] gateway vsi-interface 100
Use interface vsi-interface to create a VSI interface and enter its view, or enter the view of an existing VSI interface.
Use undo interface vsi-interface to delete a VSI interface.
interface vsi-interface vsi-interface-id
undo interface vsi-interface vsi-interface-id
No VSI interfaces exist.
vsi-interface-id: Specifies a VSI interface number. The value range for this argument is 0 to 16777215.
# Create VSI-interface 100 and enter VSI interface view.
ipv6 nd distributed-gateway dynamic-entry synchronize
Use ipv6 nd distributed-gateway dynamic-entry synchronize to enable dynamic ND entry synchronization for distributed VXLAN IP gateways.
Use undo ipv6 nd distributed-gateway dynamic-entry synchronize to disable dynamic ND entry synchronization for distributed VXLAN IP gateways.
Dynamic ND entry synchronization is disabled for distributed VXLAN IP gateways.
When local ND proxy is enabled on distributed VXLAN IP gateways, each gateway learns ND information independently. A gateway does not forward ND packets destined for its local VSI interfaces to other gateways. For distributed VXLAN IP gateways to have the same ND entries, you must enable dynamic ND entry synchronization.
A controller or the EVPN feature can also synchronize ND entries among distributed VXLAN IP gateways. When you use a controller or the EVPN feature, do not enable dynamic ND entry synchronization.
# Enable dynamic ND entry synchronization for distributed VXLAN IP gateways.
[Sysname] ipv6 nd distributed-gateway dynamic-entry synchronize
local-proxy-nd enable (Layer 3—IP Services Command Reference)
mac-address
Use mac-address to assign a MAC address to a VSI interface.
Use undo mac-address to restore the default.
undo mac-address
VSI interfaces use the MAC address of VLAN-interface 4094 on the device.
VSI interface view
The source MAC address of packets sent by a VSI interface depends on the 36 most significant bits of the VSI interface's MAC address:
·     The MAC address of VLAN-interface 4094 is used if the MAC address of the VSI interface and the bridge MAC address of the device have different values in the 36 most significant bits.
·     The MAC address of the VSI interface is used if that MAC address has the same value in the 36 most significant bits as the bridge MAC address of the device.
# Assign MAC address 0001-0001-0001 to VSI-interface 100.
[Sysname-Vsi-interface100] mac-address 1-1-1
mtu
Use mtu to set the MTU for a VSI interface.
mtu size
undo mtu
The default MTU of a VSI interface is 1444 bytes.
VSI interface view
size: Specifies an MTU value in the range of 46 to 9008 bytes.
# Set the MTU to 1430 bytes for VSI-interface 100.
[Sysname-Vsi-interface100] mtu 1430
Use reset counters interface vsi-interface to clear packet statistics on VSI interfaces.
reset counters interface [ vsi-interface [ vsi-interface-id ] ]
vsi-interface [ vsi-interface-id ]: Specifies VSI interfaces. If you specify a VSI interface, this command clears packet statistics on the specified interface. If you specify only the vsi-interface keyword, this command clears packet statistics on all VSI interfaces. If you do not specify the vsi-interface [ vsi-interface-id ] option, this command clears packet statistics on all interfaces. Make sure the specified VSI interfaces have been created on the device.
Use this command to clear history statistics before you collect traffic statistics for a time period.
# Clear packet statistics on VSI-interface 100.
<Sysname> reset counters interface vsi-interface 100
shutdown
Use shutdown to shut down a VSI interface.
Use undo shutdown to bring up a VSI interface.
shutdown
A VSI interface is up.
VSI interface view
sage guidelines
CAUTION
CAUTION:
If you shut down a VSI interface, the VXLAN network using this VSI interface as the gateway will be unable to communicate with other networks at Layer 3. Make sure you are fully aware of the impact of this command when you use it on a live network.
# Shut down VSI-interface 100.
[Sysname-Vsi-interface100] shutdown
vtep group member local
Use vtep group member local to assign the local VTEP to a VTEP group.
Use undo vtep group member local to remove the local VTEP from a VTEP group.
vtep group group-ip member local member-ip
undo vtep group group-ip member local
A VTEP is not assigned to any VTEP group.
group-ip: Specifies a VTEP group by its group IP address. The IP address must already exist on the local VTEP.
member-ip: Specifies the member VTEP IP address for the local VTEP. The IP address must already exist on the local VTEP.
Member VTEPs in a VTEP group cannot use the group IP address or share an IP address.
# Assign the local VTEP to VTEP group 1.1.1.1, and specify 2.2.2.2 as the member VTEP IP address of the local VTEP.
[Sysname] vtep group 1.1.1.1 member local 2.2.2.2
vtep group member remote
Use vtep group member remote to specify a VTEP group and its member VTEPs.
Use undo vtep group member remote to remove a VTEP group and its member VTEPs.
vtep group group-ip member remote member-ip&<1-8>
undo vtep group group-ip member remote
No VTEP group is specified.
member-ip&<1-8>: Specifies a space-separated list of up to eight member VTEP IP addresses.
# Specify VTEP group 1.1.1.1 and its member VTEPs at 2.2.2.2, 3.3.3.3, and 4.4.4.4.
[Sysname] vtep group 1.1.1.1 member remote 2.2.2.2 3.3.3.3 4.4.4.4
vxlan tunnel arp-learning disable
Use vxlan tunnel arp-learning disable to disable remote ARP learning for VXLANs.
Use undo vxlan tunnel arp-learning disable to enable remote ARP learning for VXLANs.
Remote ARP learning is enabled for VXLANs.
By default, the device learns ARP information of remote VMs from packets received on VXLAN tunnel interfaces. To save resources on VTEPs in an SDN transport network, you can temporarily disable remote ARP learning when the controller and VTEPs are synchronizing entries. After the entry synchronization is completed, use the undo vxlan tunnel arp-learning disable command to enable remote ARP learning.
As a best practice, disable remote ARP learning for VXLANs only when the controller and VTEPs are synchronizing entries.
# Disable remote ARP learning for VXLANs.
<Sysname> system
[Sysname] vxlan tunnel arp-learning disable
vxlan tunnel nd-learning disable
Use vxlan tunnel nd-learning disable to disable remote ND learning for VXLANs.
Use undo vxlan tunnel nd-learning disable to enable remote ND learning for VXLANs.
Remote ND learning is enabled for VXLANs.
By default, the device learns ND information of remote VMs from packets received on VXLAN tunnel interfaces. To save resources on VTEPs in an SDN transport network, you can temporarily disable remote ND learning when the controller and VTEPs are synchronizing entries. After the entry synchronization is completed, use the undo vxlan tunnel nd-learning disable command to enable remote ND learning.
As a best practice, disable remote ND learning for VXLANs only when the controller and VTEPs are synchronizing entries.
# Disable remote ND learning for VXLANs.
<Sysname> system
[Sysname] vxlan tunnel nd-learning disable
OVSDB commands
ovsdb server bootstrap ca-certificate
Use ovsdb server bootstrap ca-certificate to specify a CA certificate file for establishing OVSDB SSL connections.
Use undo ovsdb server bootstrap ca-certificate to restore the default.
ovsdb server bootstrap ca-certificate ca-filename
SSL uses the CA certificate file in the PKI domain.
ca-filename: Specifies the CA certificate file name, a case-insensitive string. The file name cannot contain the slot string, and the file must be stored on the active MPU.
For the specified certificate to take effect, you must execute the ovsdb server enable command to enable the OVSDB server. You must disable and then re-enable the OVSDB server if it has been enabled.
If the specified CA certificate file does not exist, the device obtains a self-signed certificate from the controller. The obtained file uses the name specified for the ca-filename argument.
# Specify CA certificate file ca-new for establishing OVSDB SSL connections.
[Sysname] ovsdb server bootstrap ca-certificate ca-new
ovsdb server enable
ovsdb server pki domain
ovsdb server pssl
ovsdb server ssl
ovsdb server enable
Use ovsdb server enable to enable the OVSDB server.
Use undo ovsdb server enable to disable the OVSDB server.
ovsdb server enable
The OVSDB server is disabled.
To obtain configuration data from controllers, you must enable the OVSDB server.
Before you enable the OVSDB server, you must establish an OVSDB SSL or TCP connection with a minimum of one controller.
# Enable the OVSDB server.
[Sysname] ovsdb server enable
Use ovsdb server pki domain to specify a PKI domain for establishing OVSDB SSL connections.
Use undo ovsdb bootstrap server pki domain to restore the default.
ovsdb server pki domain domain-name
undo ovsdb server pki domain
No PKI domain is specified for establishing OVSDB SSL connections.
domain-name: Specifies a PKI domain name, a case-sensitive string of 1 to 31 characters. The PKI domain must already exist and contain a complete certificate and key.
To communicate with controllers through SSL, you must specify a PKI domain.
For the specified PKI domain to take effect, you must execute the ovsdb server enable command to enable the OVSDB server. You must disable and then re-enable the OVSDB server if it has been enabled.
For more information about PKI domains, see PKI in Security Configuration Guide.
# Specify PKI domain ovsdb_test for establishing OVSDB SSL connections.
[Sysname] ovsdb server pki domain ovsdb_test
ovsdb server enable
ovsdb server pssl
ovsdb server ssl
ovsdb server pssl
Use ovsdb server pssl to enable the device to listen for OVSDB SSL connection requests.
Use undo ovsdb server pssl to restore the default.
ovsdb server pssl [ port port-number ]
The device does not listen for OVSDB SSL connection requests.
port port-number: Specifies a port to listen for OVSDB SSL connection requests. The value range for the port-number argument is 1 to 65535. If you do not specify a port, the device uses the port number 6640.
Before you use this command, you must specify a PKI domain for SSL.
You can specify only one port to listen for OVSDB SSL connection requests. If you execute this command multiple times, the most recent configuration takes effect.
For the specified port setting to take effect, you must execute the ovsdb server enable command to enable the OVSDB server. You must disable and then re-enable the OVSDB server if it has been enabled.
# Enable the device to listen for OVSDB SSL connection requests on port 6640.
[Sysname] ovsdb server pssl
ovsdb server enable
ovsdb server ssl
ovsdb server ptcp
Use ovsdb server ptcp to enable the device to listen for OVSDB TCP connection requests.
Use undo ovsdb server ptcp to restore the default.
ovsdb server ptcp [ port port-number ] [ acl acl-number ]
The device does not listen for OVSDB TCP connection requests.
port-number: Specifies a port to listen for OVSDB TCP connection requests. The value range for the port-number argument is 1 to 65535. If you do not specify a port, the device uses the port number 6640.
acl acl-number: Specifies a basic IPv4 ACL by its ACL number to filter OVSDB TCP connection requests. The value range for the acl-number argument is 2000 to 2999.
You can specify only one port to listen for OVSDB TCP connection requests. If you execute this command multiple times, the most recent configuration takes effect.
If you specify a basic IPv4 ACL for this command, the OVSDB server accepts only the OVSDB TCP connection requests that are permitted by the ACL. The OVSDB server rejects any OVSDB TCP connection requests that do not match the ACL or that are denied by the ACL.
The OVSDB server does not filter OVSDB TCP connection requests in any of the following situations:
·     No IPv4 ACL is specified for this command.
·     The specified IPv4 ACL does not exist.
·     The specified IPv4 ACL does not have rules.
You can specify only one IPv4 ACL to filter OVSDB TCP connection requests. If you execute this command multiple times, the most recent configuration takes effect.
Modification to rules in the specified IPv4 ACL takes effect only on OVSDB TCP connection requests that are received after the modification. If you specify another IPv4 ACL, the IPv4 ACL also takes effect only on OVSDB TCP connection requests that are received after the modification.
# Enable the device to listen for OVSDB TCP connection requests on port 6640.
[Sysname] ovsdb server ptcp
ovsdb server enable
ovsdb server tcp
ovsdb server ssl
Use ovsdb server ssl to set up an active OVSDB SSL connection to a controller.
Use undo ovsdb server ssl to remove an OVSDB SSL connection from a controller.
ovsdb server ssl ip ip-address port port-number
undo ovsdb server ssl ip ip-address port port-number
The device does not have active OVSDB SSL connections to a controller.
ip ip-address: Specifies the destination IP address for the SSL connection.
port port-number: Specifies the destination port for the SSL connection. The value range for the port-number argument is 1 to 65535.
The device can have a maximum of eight active SSL connections.
To establish the connection, you must execute the ovsdb server enable command. You must disable and then re-enable the OVSDB server if it has been enabled.
# Set up an active SSL connection to port 6632 at 192.168.12.2.
[Sysname] ovsdb server ssl ip 192.168.12.2 port 6632
ovsdb server enable
ovsdb server pssl
ovsdb server tcp
Use ovsdb server tcp to set up an active OVSDB TCP connection to a controller.
Use undo ovsdb server tcp to remove an OVSDB TCP connection.
ovsdb server tcp ip ip-address port port-number
undo ovsdb server tcp ip ip-address port port-number
The device does not have active OVSDB TCP connections.
ip ip-address: Specifies the destination IP address for the TCP connection.
port port-number: Specifies the destination port for the TCP connection. The value range for the port-number argument is 1 to 65535.
The device can have a maximum of eight active OVSDB TCP connections.
# Set up an active OVSDB TCP connection to port 6632 at 192.168.12.2.
[Sysname] ovsdb server tcp ip 192.168.12.2 port 6632
ovsdb server enable
ovsdb server ptcp
vtep access port
Use vtep access port to specify a site-facing interface as a VTEP access port.
Use undo vtep access port to restore the default.
vtep access port
An interface is not a VTEP access port.
Layer 3 interface view
For controllers to manage a site-facing interface, you must specify the interface as a VTEP access port.
# Specify FortyGigE 1/0/1 as a VTEP access port.
[Sysname-FortyGigE1/0/1] vtep access port
vtep acl disable
Use vtep acl disable to disable the ACLs issued by the OVSDB controller.
Use undo vtep acl disable to enable the ACLs issued by the OVSDB controller.
vtep acl disable
The ACLs issued by the OVSDB controller are enabled on the device.
Before you use this command, you must use the vtep enable command to enable the OVSDB VTEP service.
Use the vtep acl disable command on a VTEP to disable all the ACLs issued by the OVSDB controller in order to save ACL resources on the VTEP.
# Disable the ACLs issued by the OVSDB controller.
[Sysname] vtep enable
[sysname] vtep acl disable
vtep enable
vtep enable
Use vtep enable to enable the OVSDB VTEP service.
Use undo vtep enable to disable the OVSDB VTEP service.
vtep enable
undo vtep enable
The OVSDB VTEP service is disabled.
# Enable the OVSDB VTEP service.
vxlan tunnel flooding-proxy
Use vxlan tunnel flooding-proxy to enable flood proxy on multicast VXLAN tunnels.
Use undo vxlan tunnel flooding-proxy to disable flood proxy on multicast VXLAN tunnels.
Flood proxy is disabled on multicast VXLAN tunnels.
Flood proxy is supported on multicast VXLAN tunnels only when the OVSDB controller is a NSX controller from VMware.
If you use a flood proxy server, you must enable flood proxy globally on multicast tunnels. Then the multicast tunnels are converted into flood proxy tunnels. The VTEP sends broadcast, multicast, and unknown unicast traffic for a VXLAN to the flood proxy server through the tunnels. The flood proxy server then replicates and forwards flood traffic to remote VTEPs.
After you enable flood proxy on multicast VXLAN tunnels, if the controller issues VSI configuration, the system automatically disables ARP flood suppression on all VSIs issued by the controller. If the controller does not issue VSI configuration, the system does not automatically change the state of ARP flood suppression.
If you do not enable flood proxy on multicast VXLAN tunnels, the system does not automatically change the state of ARP flood suppression regardless of whether the controller issues VSI configuration.
The vxlan tunnel flooding-proxy command and its undo form affect only VXLAN tunnels that are issued after the vxlan tunnel flooding-proxy command.
# Enable flood proxy on all multicast VXLAN tunnels.
<Sysname> system
[Sysname] vxlan tunnel flooding-proxy
