| 04-Data buffer commands | 110.12 KB |
buffer packet-drop alarm enable
buffer packet-drop alarm interval
buffer queue guaranteed (interface view)
buffer queue map-to service-pool
buffer queue shared (interface view)
buffer threshold alarm interval
buffer usage threshold all-queue
buffer usage threshold headroom
buffer usage threshold headroom queue
buffer usage threshold queue (interface view)
buffer usage threshold queue (system view)
display buffer usage interface
Inappropriate data buffer changes can cause system problems. Before manually changing data buffer settings, make sure you understand its impact on your device. As a best practice, use the burst-mode enable command if the system requires large buffer spaces. The burst-mode enable command and the buffer apply command are mutually exclusive. If you have configured the data buffer by using one command, you must execute the undo form of the command before using the other command.
buffer apply
Use buffer apply to apply manually configured data buffer settings.
Use undo buffer apply to restore the default.
buffer apply
undo buffer apply
For data buffer settings to take effect, you must execute this command after configuring data buffer settings.
After applying manually configured data buffer settings, you cannot directly modify the applied settings. To modify them, you must cancel the application, reconfigure data buffer settings, and reapply the new settings.
# Apply manually configured data buffer settings.
[Sysname] buffer apply
Use buffer packet-drop alarm enable to enable packet-drop alarms.
Use undo buffer packet-drop alarm enable to disable packet-drop alarms.
Packet-drop alarms are disabled.
The device generates and reports packet-drop alarms to a network management system (such as IMC) for displaying the data buffer usage.
This command does not take effect only on the Headroom buffer.
# Enable packet-drop alarms.
[Sysname] buffer packet-drop alarm enable
Use buffer packet-drop alarm interval to set the interval for sending packet-drop alarms.
Use undo buffer packet-drop alarm interval to restore the default.
buffer packet-drop alarm interval interval
The interval for sending packet-drop alarms is 5 seconds.
interval: Specifies the interval for sending packet-drop alarms, in the range of 0 to 60 seconds. The value of 0 indicates that packet-drop alarms are sent immediately after they are generated.
This command takes effect only when packet-drop alarms are enabled.
# Set the interval for sending packet-drop alarms to 20 seconds.
[Sysname] buffer packet-drop alarm interval 20
Use buffer queue guaranteed to set the fixed-area ratio or size for a queue.
Use undo buffer queue guaranteed to delete the fixed-area ratio or size setting of a queue.
buffer egress cell queue queue-id guaranteed ratio ratio
undo buffer egress cell queue queue-id guaranteed
The fixed-area ratio for a queue is 13%.
Interface view
egress: Specifies the egress buffer.
cell: Specifies cell resources.
queue-id: Specifies a queue by its ID in the range of 0 to 7.
ratio ratio: Specifies the fixed-area space ratio, in percentage. The value range for ratio is 0 to 100.
By default, all queues have an equal share of the fixed area. You can set the fixed-area ratio for a queue. The other queues equally share the remaining part.
The fixed-area space for a queue cannot be used by other queues. Therefore, it is also called the minimum guaranteed buffer for the queue. The sum of the fixed-area ratios configured for all queues cannot exceed 100%. The queue that causes the sum of the fixed-area ratios to exceed 100% fails to be configured and still uses the default setting.
# Configure queue 0 on Ten-GigabitEthernet 1/0/1 to use 20% fixed-area space of cell resources in the egress buffer.
[Sysname-Ten-GigabitEthernet1/0/1] buffer egress cell queue 0 guaranteed ratio 20
Use buffer queue map-to service-pool to map a queue to a service pool.
Use undo buffer queue map-to service-pool to restore the default.
buffer ingress queue queue-id map-to service-pool sp-id
undo buffer ingress queue queue-id map-to
All queues are mapped to service pool 0.
Interface view
service-pool sp-id: Specifies a service pool by its ID. The value range for the sp-id argument is 1 to 3.
Before configuring this command, use the buffer service-pool shared command to set the maximum shared-area ratio for the service pool.
For the ingress buffer, the queue ID specified represents the 802.1p priority. The actual queue ID mapped to the service pool is determined by the dot1p-lp priority map.
# Map queue 1 on Ten-GigabitEthernet 1/0/1 to service pool 1.
[Sysname-Ten-GigabitEthernet1/0/1] buffer egress queue 1 map-to service-pool 1
Use buffer queue shared to set the maximum shared-area ratio or size for a queue.
Use undo buffer queue shared to delete the maximum shared-area ratio or size setting of a queue.
buffer egress cell queue queue-id shared ratio ratio
undo buffer egress cell queue queue-id shared
The maximum shared-area ratio for a queue is 20%.
Interface view
ratio ratio: Specifies the maximum shared-area ratio, in percentage. The value range for ratio is 0 to 100.
By default, all queues have an equal share of the shared area. You can set the shared-area ratio for a queue. The unconfigured queues use the default setting. The shared-area space for each queue is finally determined by the chip based on your configuration and the number of packets to be received and sent.
# Configure queue 0 on Ten-GigabitEthernet 1/0/1 to use 20% shared-area space of cell resources in the egress buffer.
[Sysname-Ten-GigabitEthernet1/0/1] buffer egress cell queue 0 shared ratio 20
Use buffer service-pool shared to set the maximum shared-area ratio or size for a service pool.
Use undo buffer service-pool shared to delete the maximum shared-area ratio or size setting of a service pool.
buffer ingress [ slot slot-number ] cell service-pool sp-id shared ratio ratio
undo buffer ingress [ slot slot-number ] cell service-pool sp-id shared
All of the shared area is reserved for service pool 0.
ingress: Specifies the ingress buffer.
slot slot-number: Specifies an IRF member device by its member ID (slot number).
ratio ratio: Specifies the maximum shared-area ratio, in percentage. The value range for ratio is 0 to 99.
This command takes effect after you executed the buffer apply command.
If you specify the slot slot-number option, this commmand applies to the specified slot. If you do not specify the option, this commmand applies to all slots. The configuration for a slot have higher priority over the configuration for all slots.
# Configure service pool 1 to use up to 50% shared-area space of cell resources in the egress buffer.
[Sysname] buffer egress cell service-pool 1 shared ratio 50
buffer apply
buffer threshold alarm enable
Use buffer threshold alarm enable to enable threshold-crossing alarms.
Use undo buffer threshold alarm enable to disable threshold-crossing alarms.
buffer threshold alarm { egress | headroom | ingress } enable
undo buffer threshold alarm { egress | headroom | ingress } enable
Threshold-crossing alarms are disabled.
headroom: Specifies the Headroom buffer.
The device generates and reports threshold-crossing alarms to a network management system (such as IMC) for displaying the data buffer usage.
# Enable threshold-crossing alarms.
[Sysname] buffer threshold alarm ingress enable
Use buffer threshold alarm interval to set the interval for sending threshold-crossing alarms.
Use undo buffer threshold alarm interval to restore the default.
buffer threshold alarm { egress | headroom | ingress } interval interval
undo buffer threshold alarm { egress | headroom | ingress } interval
The interval for sending threshold-crossing alarms is 5 seconds.
interval: Specifies the interval for sending threshold-crossing alarms, in the range of 0 to 60 seconds. 0 indicates that threshold-crossing alarms are sent immediately after they are generated.
This command takes effect only when threshold-crossing alarms are enabled.
# Set the interval for sending threshold-crossing alarms to 20 seconds.
[Sysname] buffer threshold alarm ingress interval 20
Use buffer usage threshold to set a per-interface buffer usage threshold.
Use undo buffer usage threshold to restore the default.
buffer usage threshold slot slot-number ratio ratio
undo buffer usage threshold slot slot-number
The per-interface buffer usage threshold is 100%.
slot slot-number: Specifies an IRF member device by its member ID.
ratio ratio: Specifies the buffer usage threshold in percentage, in the range of 1 to 100.
This command takes effect only when the packet statistics collection mode is queue (configured by using the statistic mode queue command).
After you configure this command, the switch automatically records buffer usage for each interface. When a queue on an interface uses more buffer space than the set threshold, the system counts one threshold violation for the queue.
To display the buffer usage statistics for interfaces, use the display buffer usage interface command.
# Set the per-interface buffer usage threshold to 50% for IRF member device 1.
[Sysname] buffer usage threshold slot 1 ratio 50
Use buffer usage threshold all-queue to set the alarm threshold for all queues.
Use undo buffer usage threshold all-queue to restore the default.
buffer egress usage threshold all-queue slot slot-number ratio ratio
undo buffer egress usage threshold all-queue slot slot-number ratio
The alarm threshold is 100% for all queues.
ratio ratio: Specifies the alarm threshold in percentage, in the range of 1 to 100.
When a queue causes the total buffer usage on the interface to exceed the alarm threshold, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the alarm threshold to 50% for all queues in slot 1.
[Sysname] buffer egress usage threshold all-queue slot 1 ratio 50
buffer queue shared (system view)
Use buffer usage threshold headroom to set the global per-queue alarm threshold for the Headroom buffer.
Use undo buffer usage threshold headroom to restore the default.
buffer usage threshold headroom slot slot-number ratio ratio
undo buffer usage threshold headroom slot slot-number ratio
The global per-queue alarm threshold for the Headroom buffer is 100%.
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the global alarm threshold for the Headroom buffer, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the global per-queue alarm threshold to 50% for slot 1.
[Sysname] buffer usage threshold headroom slot 1 ratio 50
Use buffer usage threshold headroom queue to set the Headroom buffer alarm threshold for a queue on an interface.
Use undo buffer usage threshold headroom queue to restore the default.
buffer usage threshold headroom queue queue-id ratio ratio
undo buffer usage threshold headroom queue queue-id ratio
The global per-queue alarm threshold for the Headroom buffer is used.
Interface view
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the alarm threshold, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the Headroom buffer alarm threshold to 50% for queue 1 on Ten-GigabitEthernet 1/0/1.
[Sysname–Ten-GigabitEthernet1/0/1] buffer usage threshold headroom queue 1 ratio 50
Use buffer usage threshold queue to set the ingress or egress buffer alarm threshold for a queue on an interface.
Use undo buffer usage threshold queue to restore the default.
buffer { egress | ingress } usage threshold queue queue-id ratio ratio
undo buffer { egress | ingress } usage threshold queue queue-id ratio
The global per-queue alarm threshold for the ingress or egress buffer is used.
Interface view
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the alarm threshold for the ingress or egress buffer, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the ingress buffer alarm threshold to 50% for queue 1 on Ten-GigabitEthernet 1/0/1.
[Sysname–Ten-GigabitEthernet1/0/1] buffer ingress usage threshold queue 1 ratio 50
Use buffer usage threshold queue to set the global ingress or egress buffer alarm threshold for a queue.
buffer { egress | ingress } usage threshold slot slot-number queue queue-id ratio ratio
undo buffer { egress | ingress } usage threshold slot slot-number queue queue-id ratio
The global ingress or egress buffer alarm threshold for a queue is 100%.
This command takes effect only when threshold-crossing alarms are enabled. When a queue exceeds the global ingress or egress alarm threshold, the device generates and reports a threshold-crossing alarm to a network management system (such as IMC).
# Set the global ingress alarm threshold to 50% for queue 1 in slot 1.
[Sysname] buffer ingress usage threshold slot 1 queue 1 ratio 50
burst-mode enable
Use burst-mode enable to enable the Burst feature.
Use undo burst-mode enable to disable the Burst feature.
burst-mode enable
The Burst feature is disabled.
The Burst feature is especially useful for reducing packet losses under the following circumstances:
· Traffic enters a device from a high-speed interface and goes out of a low-speed interface.
· Traffic enters a device from multiple same-rate interfaces and goes out of an interface with the same rate.
The Burst feature takes effect only on known unicast packets.
# Enable the Burst feature.
[Sysname] burst-mode enable
Use display buffer usage to display buffer usage.
display buffer usage [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID (slot number). If you do not specify an IRF member device, this command displays buffer usage for all IRF member devices.
# Display buffer usage.
<Sysname> display buffer usage
Egress buffer usage on chassis 1 slot 3 :
Chip0
core0:
Total: 761856 BD
Used: 0 BD
Free: 761856 BD
core1:
Total:1048576 BD
Used: 0 BD
Free:1048576 BD
Ingress buffer usage on slot |
Usage of cell resources in the shared area on a slot. A buffer descriptor (BD) is a cell resource. |
Chip |
Chip number. |
core |
Type of the data buffer. |
Total |
Total size of the data buffer. |
Used |
Size of used data buffer. |
Free |
Size of free data buffer. |
Use display buffer usage interface to display buffer usage statistics for interfaces.
display buffer usage interface [ interface-type [ interface-number ] ] [ verbose ]
interface-type [ interface-number ]: Specifies an interface by its type and number. If you do not specify the interface-type argument, this command displays buffer usage statistics for all Ethernet interfaces. If you specify the interface-type argument without the interface-number argument, this command displays buffer usage statistics for all Ethernet interfaces of the specified type.
verbose: Displays detailed buffer usage statistics. If you do not specify this keyword, the command displays brief buffer usage statistics.
# Display brief buffer usage statistics for Ten-GigabitEthernet 1/0/1.
<Sysname> display buffer usage interface ten-gigabitethernet 1/0/1
Interface QueueID Total Used Threshold(%) Violations
XGE1/0/1 0 761856 0 100 0
1 761856 0 100 0
2 761856 0 100 0
3 761856 0 100 0
4 761856 0 100 0
5 761856 0 100 0
6 761856 0 100 0
7 761856 0 100 0
Total |
Data buffer size in bytes allowed for a queue. |
Used |
Data buffer size in bytes that has been used by a queue. |
Threshold(%) |
Buffer usage threshold for a queue. The threshold value is the same as the per-interface threshold value. |
Violations |
Number of threshold violations for a queue. The value of this field is reset upon a switch reboot. |
# Display detailed buffer usage statistics for Ten-GigabitEthernet 1/0/1.
[Sysname] display buffer usage interface ten-gigabitethernet 1/0/1 verbose
XGE1/0/1
Ingress:
QueueID: 0
Total: -- Used: 2 Threshold(%): 3
Violations: 4 Shared: 5 Headroom: 6
XoffThres: 7 IsDynamic: 1
Used(%): 6 Free: 15 UsedPeak: 17
HeadroomUsed(%): 3 HeadroomFree: 19 HeadroomPeak: 20
QueueID: 1
Total: -- Used: 4 Threshold(%): 6
Violations: 8 Shared: 10 Headroom: 12
XoffThres: 14 IsDynamic: 1
Used(%): 12 Free: 30 UsedPeak: 34
HeadroomUsed(%): 6 HeadroomFree: 38 HeadroomPeak: 40
QueueID: 2
Total: -- Used: 6 Threshold(%): 9
Violations: 12 Shared: 15 Headroom: 18
XoffThres: 21 IsDynamic: 1
Used(%): 18 Free: 45 UsedPeak: 51
HeadroomUsed(%): 9 HeadroomFree: 57 HeadroomPeak: 60
QueueID: 3
Total: -- Used: 8 Threshold(%): 12
Violations: 16 Shared: 20 Headroom: 24
XoffThres: 28 IsDynamic: 1
Used(%): 24 Free: 60 UsedPeak: 68
HeadroomUsed(%): 12 HeadroomFree: 76 HeadroomPeak: 80
QueueID: 4
Total: -- Used: 10 Threshold(%): 15
Violations: 20 Shared: 25 Headroom: 30
XoffThres: 35 IsDynamic: 1
Used(%): 30 Free: 75 UsedPeak: 85
HeadroomUsed(%): 15 HeadroomFree: 95 HeadroomPeak: 100
QueueID: 5
Total: -- Used: 12 Threshold(%): 18
Violations: 24 Shared: 30 Headroom: 36
XoffThres: 42 IsDynamic: 1
Used(%): 36 Free: 90 UsedPeak: 102
HeadroomUsed(%): 18 HeadroomFree: 114 HeadroomPeak: 120
QueueID: 6
Total: -- Used: 14 Threshold(%): 21
Violations: 28 Shared: 35 Headroom: 42
XoffThres: 49 IsDynamic: 1
Used(%): 42 Free: 105 UsedPeak: 119
HeadroomUsed(%): 21 HeadroomFree: 133 HeadroomPeak: 140
QueueID: 7
Total: -- Used: 16 Threshold(%): 24
Violations: 32 Shared: 40 Headroom: 48
XoffThres: 56 IsDynamic: 1
Used(%): 48 Free: 120 UsedPeak: 136
HeadroomUsed(%): 24 HeadroomFree: 152 HeadroomPeak: 160
Egress:
QueueID: 0
Total: 9 Used: 10 Threshold(%): 11
Violations: 12 TailDropThres: 13 IsDynamic: 1
DeadlockCount: 21 DeadlockRecover: 22
Used(%): 2 Free: 23 UsedPeak: 25
QueueID: 1
Total: 18 Used: 20 Threshold(%): 22
Violations: 24 TailDropThres: 26 IsDynamic: 1
DeadlockCount: 42 DeadlockRecover: 44
Used(%): 4 Free: 46 UsedPeak: 50
QueueID: 2
Total: 27 Used: 30 Threshold(%): 33
Violations: 36 TailDropThres: 39 IsDynamic: 1
DeadlockCount: 63 DeadlockRecover: 66
Used(%): 6 Free: 69 UsedPeak: 75
QueueID: 3
Total: 36 Used: 40 Threshold(%): 44
Violations: 48 TailDropThres: 52 IsDynamic: 1
DeadlockCount: 84 DeadlockRecover: 88
Used(%): 8 Free: 92 UsedPeak: 100
QueueID: 4
Total: 45 Used: 50 Threshold(%): 55
Violations: 60 TailDropThres: 65 IsDynamic: 1
DeadlockCount: 105 DeadlockRecover: 110
Used(%): 10 Free: 115 UsedPeak: 125
QueueID: 5
Total: 54 Used: 60 Threshold(%): 66
Violations: 72 TailDropThres: 78 IsDynamic: 1
DeadlockCount: 126 DeadlockRecover: 132
Used(%): 12 Free: 138 UsedPeak: 150
QueueID: 6
Total: 63 Used: 70 Threshold(%): 77
Violations: 84 TailDropThres: 91 IsDynamic: 1
DeadlockCount: 147 DeadlockRecover: 154
Used(%): 14 Free: 161 UsedPeak: 175
QueueID: 7
Total: 72 Used: 80 Threshold(%): 88
Violations: 96 TailDropThres: 104 IsDynamic: 1
DeadlockCount: 168 DeadlockRecover: 176
Used(%): 16 Free: 184 UsedPeak: 200
Ingress |
Usage statistics for the ingress buffer. |
Egress |
Usage statistics for the egress buffer. |
Total |
Data buffer size allowed for a queue, in bytes. |
Used |
Data buffer size that has been used by a queue, in bytes. |
Threshold(%) |
Violations |
Shared |
Number of cell resources in the shared area used by a queue. |
Headroom |
Number of cell resources in the Headroom area used by a queue. When a queue on an interface enabled with PFC enters PFC XOFF state, the interface sends XOFF frames to notify the peer interface to stop sending packets to that queue. Packets sent by the peer interface before it receives XOFF frames are stored in the Headroom area. |
XoffThres |
Back pressure frame triggering threshold. If a dynamic back pressure frame triggering threshold is configured, this field displays a percentage value. If a static back pressure frame triggering threshold is configured, this field displays an absolute value. |
TailDropThres |
Tail drop threshold, in the number of cell resources calculated according to the ratio value set in the buffer queue shared command. |
IsDynamic |
For the inbound direction, this field can be one of the following values: · 0—Indicates a static back pressure frame triggering threshold. · 1—Indicates a dynamic back pressure frame triggering threshold. For the outbound direction, this field can only be 1, which indicates a dynamic tail drop threshold. |
Used(%) |
Buffer usage in percentage. |
Free |
Free buffer in bytes. |
UsedPeak |
Peak used buffer in bytes during the time between two executions of the display buffer usage interface command. |
HeadroomUsed(%) |
Headroom area usage in percentage for the ingress buffer. |
HeadroomFree |
Free Headroom area in bytes for the ingress buffer. |
HeadroomPeak |
Peak used Headroom area in bytes during the time between two executions of the display buffer usage interface command. |
DeadlockCount |
Number of times the device entered the PFC deadlock state in the egress buffer. |
DeadlockRecover |
Number of times the device released the PFC deadlock state in the egress buffer. |
NOTE: For more information about back pressure frame triggering thresholds and PFC deadlock, see Ethernet interface configuration in Layer 2—LAN Switching Configuration Guide. |
