05-Layer 3—IP Services Command Reference
HomeSupportSwitchesS10500X-G SeriesReference GuidesCommand ReferencesH3C S10500X-G Switch Series Command References-R7753Pxx-6W10005-Layer 3—IP Services Command Reference
05-IP forwarding basics commands
05-IP forwarding basics commands 96.83 KB
Basic IP forwarding commands
MDC is supported only when the device operates in standalone mode. For more information about MDC, see Virtual Technologies Configuration Guide.
display fib
Use display fib to display FIB entries.
display fib [vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display the FIB entries for the public network, do not specify any VPN instance.
ip-address: Displays the FIB entry that matches the specified destination IP address.
mask: Specifies the mask for the IP address.
mask-length: Specifies the mask length for the IP address. The value range is 0 to 32.
If you specify an IP address without a mask or mask length, this command displays the longest matching FIB entry.
If you specify an IP address and a mask or mask length, this command displays the exactly matching FIB entry.
# Display all FIB entries of the public network.
<Sysname> display fib
Destination count: 5 FIB entry count: 5
Flag:
  R:Relay     F:FRR
Destination/Mask   Nexthop         Flag     OutInterface/Token       Label
0.0.0.0/32         127.0.0.1       UH       InLoop0                  Null
1.1.1.0/24         192.168.126.1   USGF     M-GE0/0/0                Null
127.0.0.0/8        127.0.0.1       U        InLoop0                  Null
127.0.0.0/32       127.0.0.1       UH       InLoop0                  Null
127.0.0.1/32       127.0.0.1       UH       InLoop0                  Null
# Display the FIB entries for VPN vpn1.
<Sysname> display fib vpn-instance vpn1
Destination count: 6 FIB entry count: 6
Flag:
  R:Relay     F:FRR
20.20.20.0/24      20.20.20.25     U        M-GE0/0/0                Null
20.20.20.0/32      20.20.20.25     UBH      M-GE0/0/0                Null
20.20.20.25/32     127.0.0.1       UH       InLoop0                  Null
20.20.20.25/32     20.20.20.25     H        M-GE0/0/0                Null
20.20.20.255/32    20.20.20.25     UBH      M-GE0/0/0                Null
# Display the FIB entries matching the destination IP address 10.2.1.1.
<Sysname> display fib 10.2.1.1
Flag:
  R:Relay     F:FRR
10.2.1.1/32        127.0.0.1       UH       InLoop0                  Null
Destination count
Total number of destination addresses.
FIB entry count
Total number of FIB entries.
Destination/Mask
Destination address and the mask length.
Nexthop
Next hop address.
Flag
Flags of routes:
·     U—Usable route.
·     G—Gateway route.
·     H—Host route.
·     B—Blackhole route.
·     D—Dynamic route.
·     S—Static route.
·     R—Relay route.
·     F—Fast reroute.
OutInterface/Token
Output interface/LSP index number.
Label
Inner label.
forwarding split-horizon
Use forwarding split-horizon to enable split horizon forwarding.
Use undo forwarding split-horizon to disable split horizon forwarding.
Split horizon forwarding is disabled.
Layer 2 interface view
Layer 3 interface view
This feature prevents IPv4, IPv6, and MPLS packets from being forwarded out of the physical interface on which they were received, avoiding network loops.
You can enable this feature globally in system view or enable this feature for a specific interface in interface view. This feature takes effect on an interface if it is enabled for the interface or enabled globally.
To disable this feature, you must disable it in both system view and interface view.
# Enable split horizon forwarding globally.
[Sysname] forwarding split-horizon
forwarding vxlan-packet inner-protocol
Use forwarding vxlan-packet inner-protocol to enable hardware forwarding for specific packets received from VXLAN tunnels.
Use undo forwarding vxlan-packet inner-protocol to restore the default.
forwarding vxlan-packet inner-protocol { ipv4 | ipv6 } *
undo forwarding vxlan-packet inner-protocol [ ipv4 | ipv6 ]
Packets received from VXLAN tunnels are delivered to the CPU for processing.
ipv4: Specifies IPv4 packets.
ipv6: Specifies IPv6 packets.
By default, the device forwards packets received from VXLAN tunnels to the CPU for processing when acting as a VTEP in a distributed EVPN gateway network. If a large number of packets are received, packet loss might occur because of software rate limit, which might cause service exceptions on downlink devices.
To resolve this issue, you can enable the device to forward specific packets received from VXLAN tunnels in hardware without delivering them to the CPU.
# Enable hardware forwarding for IPv4 packets received from VXLAN tunnels.
[Sysname] forwarding vxlan-packet inner-protocol ipv4
ip forwarding
Use ip forwarding to enable IPv4 packet forwarding on an interface that has no IPv4 address configured.
Use undo ip forwarding to disable IPv4 packet forwarding on an interface that has no IPv4 address configured.
ip forwarding
undo ip forwarding
If an interface has no IPv4 address configured, the IPv4 packet forwarding is disabled on the interface.
Interface view
On a device that supports both IPv4 and IPv6, the next hop of an IPv4 packet might be an IPv4 address or an IPv6 address. If the output interface has no IPv4 address configured, the interface cannot forward the IPv4 packet. To solve this problem, execute this command on the interface. This feature allows the interface to forward IPv4 packets even though the interface has no IPv4 address configured.
# Enable IPv4 packet forwarding on VLAN-interface 1 that has no IPv4 address configured.
[Sysname-Vlan-interface1] ip forwarding
ip forwarding-table save
Use ip forwarding-table save to save the IP forwarding entries to a file.
ip forwarding-table save filename filename
filename filename: Specifies the name of a file, a string of 1 to 255 characters. For information about the filename argument, see file system management in Fundamentals Configuration Guide.
The command automatically creates the file if you specify a nonexistent file. If the file already exists, this command overwrites the file content.
To automatically save the IP forwarding entries periodically, configure a schedule for the device to automatically run the ip forwarding-table save command. For information about scheduling a task, see Fundamentals Configuration Guide.
# Save the IP forwarding entries to the fib.txt file.
<Sysname> ip forwarding-table save filename fib.txt
snmp-agent trap enable fib
Use snmp-agent trap enable fib to enable SNMP notifications for FIB events.
Use undo snmp-agent trap enable fib to disable SNMP notifications for FIB events.
SNMP notifications for FIB events are enabled.
This feature enables the FIB module to generate SNMP notifications for critical FIB events. The SNMP notifications are sent to the SNMP module. For the SNMP notifications to be sent correctly, you must also configure SNMP. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Disable SNMP notifications for FIB events.
[Sysname] undo snmp-agent trap enable fib
Load sharing commands
display ip load-sharing mode
Use display ip load-sharing mode to display the load sharing mode in use.
In standalone mode:
display ip load-sharing mode slot slot-number
In IRF mode:
display ip load-sharing mode chassis chassis-number slot slot-number
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the load sharing mode for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays the load sharing mode for all cards. (In IRF mode.)
# Display the load sharing mode in use.
<Sysname> display ip load-sharing mode slot 1
Load-sharing mode: per-flow
Load-sharing options: dest-ip | src-ip | ip-pro | dest-port | src-port | ingress-port
Load-sharing algorithm: 1
IP tunnel load-sharing mode: outer
Load-sharing mode
The load sharing mode in use:
·     per-packet—Per-packet load sharing.
·     per-flow—Per-flow load sharing.
Options configured for load sharing:
·     dest-ip—Identifies flows by packet's destination IP address.
·     src-ip—Identifies flows by packet's source IP address.
·     ip-pro—Identifies flows by packet's IP protocol.
·     dest-port—Identifies flows by packet's destination port number.
·     src-port—Identifies flows by packet's source port number.
·     ingress-port—Identifies flows by packet's ingress port.
·     flow-label—Identifies flows by IPv6 packet's flow label.
Algorithm used by load sharing.
Load sharing for IP tunnel packets:
·     inner—Identifies flows by inner IP header information.
·     outer—Identifies flows by outer IP header information.
display ip load-sharing path
Use display ip load-sharing path to display the load sharing path selected for a flow.
display ip load-sharing path ingress-port interface-type interface-number packet-format { ipv4oe dest-ip ip-address [ src-ip ip-address ] | ipv6oe dest-ipv6 ipv6-address [ src-ipv6 ipv6-address | flow-label flow-label ] } [ dest-port port-id | ip-pro protocol-id | src-port port-id | vpn-instance vpn-instance-name ] *
ingress-port interface-type interface-number: Specifies an ingress port by its type and number.
packet-format { ipv4oe dest-ip ip-address [src-ip ip-address ] | ipv6oe dest-ipv6 ipv6-address [ src-ipv6 ipv6-address ] }: Specifies the packet encapsulation format.
ipv4oe: Specifies the format of IPv4 over Ethernet.
dest-ip ip-address: Specifies the destination IPv4 address in dotted decimal notation. If you do not specify this argument, the calculation uses 0.0.0.0 for path selection.
src-ip ip-address: Specifies the source IPv4 address in dotted decimal notation. If you do not specify this argument, the calculation uses 0.0.0.0 for path selection.
ipv6oe: Specifies the format of IPv6 over Ethernet.
dest-ipv6 ipv6-address: Specifies the destination IPv6 address. If you do not specify this option, the calculation uses 0:0:0:0:0:0:0:0 for path selection.
src-ipv6 ipv6-address: Specifies the source IPv6 address. If you do not specify this option, the calculation uses 0:0:0:0:0:0:0:0 for path selection.
flow-label flow-label: Specifies the IPv6 flow label in the range of 0 to 1048575. If you do not specify an IPv6 flow label, the device uses 0 for ECMP route selection.
dest-port port-id: Specifies a destination port number in the range of 1 to 65535. If you do not specify this option, the calculation uses 0 for path selection.
ip-pro protocol-id: Specifies an IP protocol by its number in the range of 1 to 65535. If you do not specify this option, the calculation uses 0 for path selection.
source-port port-id: Specifies a source port number in the range of 1 to 65535. If you do not specify this option, the calculation uses 0 for path selection.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display the path on the public network, do not specify this option.
The option settings in this command must match both the options displayed in the display ip load-sharing mode command and the field values in load shared packets. If the option settings do not meet the requirement, the path displayed by this command might be different from the real path for load sharing.
The command cannot display egress interface information or tunnel encapsulation packet information for non-known unicast packets.
# Display the load sharing path selected for the flow with the following attributes: ingress port Ten-GigabitEthernet 3/0/3, destination IP address 10.110.0.2, source IP address 10.100.0.2, IP protocol number 153, destination port number 2000, source port number 2000.
<Sysname> display ip load-sharing path ingress-port ten-gigabitethernet 3/0/3 packet-format ipv4oe dest-ip 10.110.0.2 src-ip 10.100.0.2 ip-pro 153 dest-port 2000 src-port 2000
Load-sharing algorithm: 0
Load-sharing parameters:
  Missing configured are set to 0.
  ingress-port: Ten-GigabitEthernet3/0/3
  packet-format: IPv4oE
  dest-ip: 10.110.0.2
  src-ip: 10.100.0.2
  ip-pro: 153
  dest-port: 2000
  src-port: 2000
Path selected: 20.0.0.2(interface Ten-GigabitEthernet3/0/3)
Load sharing algorithm ID.
Load sharing options specified by the ip load-sharing mode command.
Load sharing parameters that you specify for the display ip load-sharing path command.
Values of the unconfigured parameters are set to 0.
ingress-port
Ingress port of the packet.
packet-format
Packet encapsulation format.
dest-ip
Destination IP address of the packet.
src-ip
Source IP address of the packet.
ip-pro
IP protocol number.
dest-port
Destination port number.
src-port:
Source port number.
flow-label
Flow label.
Path selected
Selected path information, including the IPv4 or IPv6 address of the next hop and the egress port.
ip load-sharing local-first enable
Use ip load-sharing local-first enable to enable local-first load sharing.
Use undo ip load-sharing local-first enable to disable local-first load sharing.
Local-first load sharing is enabled.
Local-first load sharing takes effect only on an IRF fabric.
# Enable local-first load sharing.
[Sysname] ip load-sharing local-first enable
Use ip load-sharing mode to configure the load sharing mode.
Use undo ip load-sharing mode to restore the default.
In standalone mode:
ip load-sharing mode per-flow [ algorithm algorithm-number [ seed seed-number ] [ shift shift-number ] | [ dest-ip | dest-port | ingress-port | ip-pro | src-ip | src-port ] * | tunnel { inner | outer } ] { global | slot slot-number }
undo ip load-sharing mode [ per-flow { algorithm | tunnel } ] { global | slot slot-number }
In IRF mode:
ip load-sharing mode { per-flow [ algorithm algorithm-number [ seed seed-number ] [ shift shift-number ] | [ algorithm-switch ] | [ dest-ip | dest-port | flow-label | ingress-port | ip-pro | src-ip | src-port ] * | tunnel { all | inner | outer } ] | per-packet } { chassis chassis-number slot slot-number | global }
undo ip load-sharing mode [ per-flow { algorithm | tunnel } ] { chassis chassis-number slot slot-number | global }
The device performs per-flow load sharing based on the following criteria: source IP address, destination IP address, source port number, destination port number, and IP protocol number.
algorithm algorithm-number: Specifies an algorithm for per-flow load sharing. The value range for the algorithm-number argument is 0 to 1.If you specify an algorithm, and then execute the undo ip load-sharing mode command, the algorithm value is set to 0.
seed seed-number: Specifies the seed value for the algorithm. The value range is 0 to ffffffff.
shift shift-number: Specifies the shift value for the hash algorithm result. The value range is 0 to 31.
per-flow: Implements per-flow load sharing. If you specify none of the dest-ip, dest-port, ingress-port, ip-pro, src-ip, and src-port keywords, the device performs per-flow load sharing based on the destination IP addresses and source IP addresses of packets.
dest-ip: Identifies flows by destination IP address.
dest-port: Identifies flows by destination port.
flow-label: Identifies flows by flow label. This keyword takes effect only on IPv6 packets.
ingress-port: Identifies flows by ingress port.
ip-pro: Identifies flows by protocol number.
src-ip: Identifies flows by source IP address.
src-port: Identifies flows by source port.
tunnel { inner | outer }: Performs per-flow load sharing for IP tunnel packets. The inner keyword identifies flows by inner IP header information. The outer keyword identifies flows by outer IP header information. If you do not specify this option, the device identifies IP tunnel packet flows by outer IP header information to implement load sharing.
global: Configures the load sharing mode globally.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command configures the load sharing mode for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command configures the load sharing mode for all cards. (In IRF mode.)
If traffic is not shared equally, you can use the seed seed-number option and the shift shift-number option to adjust the algorithm result.
Load sharing hash seed does not take effect on non-known unicast packets.
Load sharing for IP tunnel packets does not take effect on non-known unicast packets.
For MPLS packets, the device only supports per-flow load sharing based on their source IP addresses or destination IP addresses.
The load-sharing mode configured for a slot takes precedence over the global load-sharing mode. The global mode takes effect only on slots not configured with a load-sharing mode.
# (In standalone mode.) Configure per-flow load sharing for slot 1.
[Sysname] ip load-sharing mode per-flow slot 1
# (In standalone mode.) Configure per-flow load sharing based on the destination IP addresses and source IP addresses of packets for slot 1.
[Sysname] ip load-sharing mode per-flow dest-ip src-ip slot 1
# (In standalone mode.) Configure per-flow load sharing based on the inner IP header information of IP tunnel packets for slot 1.
[Sysname] ip load-sharing mode per-flow tunnel inner slot 1
# (In standalone mode.) Configure per-flow load sharing based on algorithm 1 for slot 1.
[Sysname] ip load-sharing mode per-flow algorithm 1 slot 1
ip load-sharing symmetric enable
Use ip load-sharing symmetric enable to enable symmetric load sharing.
Use undo ip load-sharing symmetric enable to disable symmetric load sharing.
Symmetric load sharing is disabled.
Symmetric load sharing ensures that bidirectional traffic specific to a particular source and destination address pair flow along the same path.
Symmetric load sharing takes effect only on known unicast packets.
# Enable symmetric load sharing.
[Sysname] ip load-sharing symmetric enable
