13-Network Management and Monitoring Command Reference
HomeSupportSwitchesH3C S12500G-AF Switch SeriesReference GuidesCommand ReferencesH3C S12500G-AF Switch Series Command References-Release7634Pxx-6W10013-Network Management and Monitoring Command Reference
12-Mirroring commands
12-Mirroring commands 118.06 KB
Port mirroring commands
display mirroring-group
Use display mirroring-group to display mirroring group information.
display mirroring-group { group-id | all | local | remote-destination | remote-source }
group-id: Specifies a mirroring group by its ID. The value range for this argument is 1 to 16.
all: Specifies all mirroring groups.
local: Specifies local mirroring groups.
remote-destination: Specifies remote destination groups.
remote-source: Specifies remote source groups.
Mirroring group information includes the type, status, and content of a mirroring group. It is sorted by mirroring group number.
# Display information about all mirroring groups.
<Sysname> display mirroring-group all
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring port:
        HundredGigE3/0/1  Inbound
    Monitor port: HundredGigE3/0/2
Mirroring group
Number of the mirroring group.
Type of the mirroring group:
·     Local.
·     Remote source.
·     Remote destination.
Status
Status of the mirroring group:
·     Active—The mirroring group has taken effect.
·     Incomplete—The mirroring group configuration is not complete and does not take effect.
Mirroring port
Source port.
Mirroring CPU
Source CPU.
Monitor port
Destination port.
mirroring-group
Use mirroring-group to create a mirroring group.
Use undo mirroring-group to delete mirroring groups.
mirroring-group group-id { local | remote-destination | remote-source }
undo mirroring-group { group-id | all | local | remote-destination | remote-source }
No mirroring groups exist.
group-id: Specifies a mirroring group ID. The value range for this argument is 1 to 16.
# Create local mirroring group 1.
[Sysname] mirroring-group 1 local
mirroring-group mirroring-cpu
Use mirroring-group mirroring-cpu to configure source CPUs for a mirroring group.
Use undo mirroring-group mirroring-cpu to remove source CPUs from a mirroring group.
In standalone mode:
mirroring-group group-id mirroring-cpu slot slot-number-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-cpu slot slot-number-list
In IRF mode:
mirroring-group group-id mirroring-cpu chassis chassis-number slot slot-number-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-cpu chassis chassis-number slot slot-number-list
No source CPU is configured for a mirroring group.
group-id: Specifies a mirroring group by its number. The specified mirroring group must already exist. The value range for this argument is 1 to 16.
slot slot-number-list: Specifies a space-separated list of up to eight slot number items. An item specifies a card by its slot number or specifies a range of cards in the form of start-slot-number to end-slot-number. The end slot number must be equal to or greater than the start slot number. (In standalone mode.)
chassis chassis-number slot slot-number-list: Specifies cards on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number-list argument specifies a space-separated list of up to eight slot number items. An item specifies a card by its slot number or specifies a range of cards in the form of start-slot-number to end-slot-number. The end slot number must be equal to or greater than the start slot number. (In IRF mode.)
both: Mirrors both received and sent packets.
inbound: Mirrors only received packets.
outbound: Mirrors only sent packets.
You can configure source CPUs only for local mirroring groups and remote source groups.
# (In standalone mode.) Create local mirroring group 1 to monitor the inbound traffic of the CPU on the specified slot.
[Sysname] mirroring-group 1 mirroring-cpu slot 1 inbound
mirroring-group
mirroring-group mirroring-port (interface view)
Use mirroring-group mirroring-port to configure a port as a source port for a mirroring group.
Use undo mirroring-group mirroring-port to restore the default.
mirroring-group group-id mirroring-port { both | inbound | outbound }
undo mirroring-group group-id mirroring-port
A port does not act as a source port for any mirroring groups.
Interface view
You can configure source ports only for local mirroring groups and remote source groups.
A Layer 2 or Layer 3 aggregate interface cannot be configured as a source port for a mirroring group.
Do not assign a source port of a mirroring group to the remote probe VLAN of the mirroring group.
A source port cannot be used as a reflector port, monitor port, or egress port.
# Create local mirroring group 1 to monitor the bidirectional traffic of the port HundredGigE 3/0/1.
[Sysname] interface hundredgige 3/0/1
[Sysname-HundredGigE3/0/1] mirroring-group 1 mirroring-port both
# Create remote source group 2 to monitor the bidirectional traffic of the port HundredGigE 3/0/2.
[Sysname] mirroring-group 2 remote-source
[Sysname] interface hundredgige 3/0/2
[Sysname-HundredGigE3/0/2] mirroring-group 2 mirroring-port both
mirroring-group
mirroring-group mirroring-port (system view)
Use mirroring-group mirroring-port to configure source ports for a mirroring group.
Use undo mirroring-group mirroring-port to remove source ports from a mirroring group.
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-port interface-list
No source port is configured for a mirroring group.
interface-list: Specifies a space-separated list of up to eight interface items. Each item specifies an interface by its type and number or specifies a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. When you specify a range of interfaces, the interfaces must be of the same type and on the same slot. The start interface number must be identical to or lower than the end interface number.
# Create local mirroring group 1 to monitor the bidirectional traffic of HundredGigE 3/0/1.
[Sysname] mirroring-group 1 mirroring-port hundredgige 3/0/1 both
# Create remote source group 2 to monitor the bidirectional traffic of HundredGigE 3/0/2.
[Sysname] mirroring-group 2 mirroring-port hundredgige 3/0/2 both
mirroring-group
mirroring-group monitor-egress
Use mirroring-group monitor-egress to configure the egress port for a remote source group.
Use undo mirroring-group monitor-egress to restore the default.
In system view:
mirroring-group group-id monitor-egress interface-type interface-number
undo mirroring-group group-id monitor-egress interface-type interface-number
In interface view:
No egress port is configured for a remote source group.
Interface view
interface-type interface-number: Specifies a port by its type and number.
You can configure egress ports only for remote source groups.
For port mirroring to work correctly, disable the following features on the egress port of a mirroring group:
·     Spanning tree.
·     802.1X.
·     IGMP snooping.
·     Static ARP.
·     MAC address learning.
The member port of an existing mirroring group cannot be configured as an egress port.
The member port of an aggregate interface cannot be configured as an egress port.
# Create remote source group 1. Configure HundredGigE 3/0/1 as its egress port in system view.
[Sysname] mirroring-group 1 remote-source
[Sysname] mirroring-group 1 monitor-egress hundredgige 3/0/1
# Create remote source group 2. Configure HundredGigE 3/0/2 as its egress port in interface view.
[Sysname-HundredGigE3/0/2] mirroring-group 2 monitor-egress
mirroring-group
mirroring-group monitor-port (interface view)
Use mirroring-group monitor-port to configure a port as the monitor port for a mirroring group.
Use undo mirroring-group monitor-port to restore the default.
mirroring-group group-id monitor-port
undo mirroring-group group-id monitor-port
A port does not act as the monitor port for any mirroring groups.
Interface view
You can configure monitor ports only for local mirroring groups and remote destination groups.
Do not enable the spanning tree feature on the monitor port of a mirroring group.
For a Layer 2 aggregate interface configured as the monitor port of a mirroring group, do not perform either of the following tasks:
·     Configure its member ports as source ports of the mirroring group.
Use a monitor port only for port mirroring, so the data monitoring device receives and analyzes only the mirrored traffic.
The member port of an existing mirroring group cannot be configured as a monitor port.
The member port of an aggregate interface cannot be configured as a monitor port.
Only one monitor port can be configured for one mirroring group.
# Create local mirroring group 1 and configure HundredGigE 3/0/1 as its monitor port.
[Sysname-HundredGigE3/0/1] mirroring-group 1 monitor-port
# Create remote destination group 2 and configure HundredGigE 3/0/2 as its monitor port.
[Sysname] mirroring-group 2 remote-destination
[Sysname-HundredGigE3/0/2] mirroring-group 2 monitor-port
mirroring-group
mirroring-group monitor-port (system view)
Use mirroring-group monitor-port to configure the monitor ports for a mirroring group.
Use undo mirroring-group monitor-port to remove the monitor ports from a mirroring group.
mirroring-group group-id monitor-port interface-type interface-number
undo mirroring-group group-id monitor-port interface-type interface-number
No monitor port is configured for a mirroring group.
For a Layer 2 aggregate interface configured as the monitor port of a mirroring group, do not perform any of the following tasks:
Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
[Sysname] mirroring-group 1 monitor-port hundredgige 3/0/1
[Sysname] mirroring-group 2 monitor-port hundredgige 3/0/2
mirroring-group
mirroring-group reflector-port
Use mirroring-group reflector-port to configure the reflector port for a remote source group.
Use undo mirroring-group reflector-port to restore the default.
In system view:
mirroring-group group-id reflector-port interface-type interface-number
undo mirroring-group group-id reflector-port interface-type interface-number
In interface view:
No reflector port is configured for a mirroring group.
Interface view
WARNING
WARNING!
·     The port to be configured as a reflector port must be a port not in use. Do not connect a network cable to a reflector port.
·     When a port is configured as a reflector port, the port restores to the factory default settings. You cannot configure other features on a reflector port.
·     If an IRF port is bound to only one physical interface, do not configure the physical interface as a reflector port. Otherwise, the IRF might split.
You can configure reflector ports only for remote source groups.
You can configure a port as a reflector port only when the port is operating with the default setting of the following parameters:
·     Duplex mode.
·     Speed.
·     MDI settings.
You cannot change the duplex mode, MDI settings, or speed for a reflector port.
The member port of an aggregate interface cannot be configured as a reflector port.
# Create remote source group 1. Configure HundredGigE 3/0/1 as its reflector port in system view.
[Sysname] mirroring-group 1 reflector-port hundredgige 3/0/1
# Create remote source group 2. Configure HundredGigE 3/0/2 as its reflector port in interface view.
[Sysname-HundredGigE3/0/2] mirroring-group 2 reflector-port
mirroring-group
mirroring-group remote-probe vlan
Use mirroring-group remote-probe vlan to specify a VLAN as the remote probe VLAN for a mirroring group.
Use undo mirroring-group remote-probe vlan to restore the default.
mirroring-group group-id remote-probe vlan vlan-id
undo mirroring-group group-id remote-probe vlan vlan-id
No remote probe VLAN is configured for a mirroring group.
vlan-id: Specifies a VLAN by its ID.
You can configure remote probe VLANs only for remote source groups and remote destination groups.
When a VLAN is configured as a remote probe VLAN, use the VLAN for port mirroring exclusively.
The remote mirroring groups on the source device and destination device must use the same remote probe VLAN.
Only a static VLAN that already exists can be configured as a remote probe VLAN. A VLAN can be configured as the remote probe VLAN for only one mirroring group.
To delete a VLAN that is configured as a remote probe VLAN, remove the remote probe VLAN configuration first.
Only one remote probe VLAN can be configured for a mirroring group.
# Create remote source group 1 and configure VLAN 10 as its remote probe VLAN.
[Sysname] mirroring-group 1 remote-probe vlan 10
# Create remote destination group 2 and configure VLAN 20 as its remote probe VLAN.
[Sysname] mirroring-group 2 remote-probe vlan 20
mirroring-group
Flow mirroring commands
mirror-to cpu
Use mirror-to cpu to configure a mirroring action that mirrors traffic to the CPU.
Use undo mirror-to cpu to delete the mirroring action that mirrors traffic to the CPU.
mirror-to cpu
undo mirror-to cpu
No mirroring action exists to mirror traffic to the CPU.
Traffic behavior view
# Create traffic behavior 1 and configure the action of mirroring traffic to the CPU for the traffic behavior.
[Sysname] traffic behavior 1
[Sysname-behavior-1] mirror-to cpu
mirror-to ifa-processor
Use mirror-to ifa-processor to configure a mirroring action that mirrors traffic to the in-band network telemetry (INT) processor.
Use undo mirror-to ifa-processor to delete the mirroring action that mirrors traffic to the INT processor.
mirror-to ifa-processor [ sampler sampler-name ]  [ vxlan ]
No mirroring action exists to mirror traffic to the INT processor.
sampler sampler-name: Specifies a sampler by its name. The sampler-name argument is a case-insensitive string of 1 to 31 characters. If you do not specify this option, packets are not sampled, and all matching packets are mirrored.
vxlan: Performs VXLAN encapsulation before performing INT encapsulation for packets to be mirrored to the INT processor. For more information about VXLAN, see VXLAN Configuration Guide or EVPN Configuration Guide.
A sampler selects a packet from sequential packets. Flow mirroring uses the sampler to limit the volume of traffic to be mirrored. Flow mirroring supports using a sampler that has not been created. If you configure multiple samplers for a mirroring action, the most recent configuration takes effect. For more information about samplers, see Network Management and Monitoring Configuration Guide.
To enable INT in a VXLAN or EVPN network, you must configure the VTEP as an INT entry node and specify the vxlan keyword when configuring the action of mirroring traffic to the INT processor.
Example
# Create traffic behavior 1 and configure the action of mirroring traffic to the INT processor. Specify sampler samp for the mirroring action.
[Sysname-behavior-1] mirror-to ifa-processor sampler samp
sampler
mirror-to interface
Use mirror-to interface to configure a mirroring action that mirrors traffic to an interface.
Use undo mirror-to interface to delete a mirroring action that mirrors traffic to an interface.
Syntax 1:
mirror-to interface interface-type interface-number [ backup-interface interface-type interface-number ] [ sampler sampler-name ] [ truncation ]  [ { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address } [ vxlan vxlan-id [ destination-port destination-port-value | source-port source-port-value ] * ] [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * ] [ destination-mac mac-address ]
undo mirror-to interface interface-type interface-number
Syntax 2:
mirror-to interface { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address } [ vxlan vxlan-id [ destination-port destination-port-value | source-port source-port-value ] * ] [ sampler sampler-name ] [ truncation ] [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name ] * [ destination-mac mac-address ]
undo mirror-to interface { destination-ip destination-ip-address source-ip source-ip-address| destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address }
Syntax 3:
mirror-to interface interface-type interface-number reflector-port interface-type interface-number strip-vlan vlan-id
No mirroring actions exist to mirror traffic to interfaces.
backup-interface interface-type interface-number: Specifies a backup interface by its type and number. When the card hosting the primary interface specified by using the interface interface-type interface-number option is unplugged or rebooted, traffic can be mirrored to the backup interface. When the card hosting the primary interface recovers, traffic is switched back to the primary interface.
truncation: Truncates the mirrored packets to retain only the first 192 bytes of each packet.
destination-ip destination-ip-address: Specifies the destination IP address for the mirrored packets.
source-ip source-ip-address: Specifies the source IP address for the mirrored packets.
vxlan vxlan-id: Specifies a VXLAN by its ID in the range of 1 to 16777215 for the mirrored packets. For more information about VXLAN, see VXLAN Configuration Guide.
destination-ipv6 destination-ipv6-address: Specifies the destination IPv6 address for the mirrored packets.
source-ipv6 source-ipv6-address: Specifies the source IPv6 address for the mirrored packets.
The destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address option must be deployed together with the vxlan vxlan-id [ destination-port destination-port-value | source-port source-port-value ] * option to take effect.
destination-port destination-port-value: Specifies the destination port number for mirrored packets encapsulated by using VXLAN. The default is 4789.
source-port source-port-value: Specifies the source port number for mirrored packets encapsulated by using VXLAN. The default varies by device model.
dscp dscp-value: Specifies the DSCP value for the mirrored packets. The dscp-value argument can be a number in the range of 0 to 63 or a keyword in Table 2.
Table 2 DSCP keywords and values
Keyword
DSCP value in binary
DSCP value in decimal
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094 for the mirrored packets.
vrf-instance vrf-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. The mirrored packets will be forwarded based on the routing table of the specified VPN instance.
destination-mac mac-address: Specifies the destination MAC address for mirrored packets sent to the interface. The mac-address argument is in the format of H-H-H. If you do not specify this option, the device uses the destination IP address to dynamically get the destination MAC address for the mirrored packets.
reflector-port interface-type interface-number: Specifies a reflector port by its type and number.
strip-vlan vlan-id: Specifies a VLAN where mirrored packets are broadcast by its ID in the range of 1 to 4094.
You can execute the mirror-to interface interface-type interface-number command multiple times for a traffic behavior to mirror traffic to different interfaces.
To mirror traffic to the specified interface, use the mirror-to interface interface-type interface-number command.
To mirror traffic to interfaces based on routes matching the specified destination IP address, use the mirror-to interface destination-ip destination-ip-address source-ip source-ip-address command. When receiving packets that meet the flow mirroring criteria, the device performs the following tasks:
1.     Encapsulates the packets based on the configured encapsulation parameters, including the source and destination IP addresses.
2.     Searches the routing table for routes matching the configured destination IP address.
If ECMP load-balancing is configured, multiple matching ECMP routes might be found for the specified destination IP address.
3.     Sends the mirrored packets out of the output interfaces in the matching routes to the final destination.
If a selected output interface goes down, the device will send the mirrored packets out of another interface based on the routing metric recalculations.
If you do not specify a VLAN for the mirrored packets destined to a VLAN interface, the device encapsulates the packets as follows:
¡     The device determines whether to encapsulate a VLAN ID for the packets based on the VLAN settings for the Layer 2 Ethernet interface associated with the VLAN interface.
¡     To encapsulate a VLAN ID, the device uses the VLAN ID of the VLAN interface to encapsulate the packets.
When you use syntax 3 to mirror traffic to an interface, the device copies packets received on the mirroring sources to the destination interface. Then, the destination interface sends the mirrored packets to the specified reflector port, and the reflector port broadcasts the mirrored packets within the specified VLAN. This syntax is applicable only when the mirrored packets are VLAN-tagged and these packets must be sent out of the device untagged.
When you use syntax 3, the specified mirroring destination interface and reflector port must be assigned to a mirroring-type service loopback group. For more information about service loopback groups, see service loopback group configuration in Layer 2—LAN Switching Configuration Guide.
When you specify the vxlan parameter, you must also set the destination-port destination-port-value parameter to the default value 4789 for the VXLAN encapsulation to take effect.
When the outgoing interface corresponding to the destination IP encapsulated for mirrored packets is a Layer 3 Ethernet subinterface, the VLAN to which the Layer 3 Ethernet subinterface belongs must be the same as the VLAN of mirrored packets.
# Create traffic behavior 1 and configure the action of mirroring traffic to HundredGigE 3/0/1 for the traffic behavior.
[Sysname-behavior-1] mirror-to interface hundredgige 3/0/1
# Create traffic behavior 1, and configure the action of mirroring traffic to HundredGigE 3/0/1 for the traffic behavior. Specify the following parameters for the mirrored packets sent to HundredGigE 3/0/1:
·     Specify 1.1.1.1 and 2.2.2.2 as the destination address and source address, respectively.
·     Specify 20, 100, and vrf1 as the DSCP value, VLAN, and the VPN instance name, respectively.
[Sysname-behavior-1] mirror-to interface hundredgige 3/0/1 destination-ip 1.1.1.1 source-ip 2.2.2.2 dscp 20 vlan 100 vrf-instance vrf1
# Configure traffic behavior 1 to encapsulate mirrored packets with source address 2.2.2.2 and destination address 1.1.1.1 and send out the packets.
[Sysname-behavior-1] mirror-to interface destination-ip 1.1.1.1 source-ip 2.2.2
# Configure traffic behavior 1 to mirror packets to HundredGigE 3/0/1 with the reflector port as HundredGigE 3/0/2 and broadcast the mirrored packets with VLAN 100.
[Sysname-behavior-1] mirror-to interface hundredgige 3/0/1 reflector-port hundredgige 3/0/2 strip-vlan 100
