MSR610-CMW710-R6728P26
Release time:2023-07-05
HomeSupportRoutersMSR600 SeriesSoftware DownloadMSR610
H3C MSR2600_MSR3600_MSR5600_MSR8XX-CMW710-R6728P26 Release Notes
Introduction· 1
Version information· 1
Version number 1
Version history· 1
Hardware and software compatibility matrix· 9
Upgrade advice· 18
Upgrade restrictions and guidelines· 18
Hardware feature updates· 18
CMW710-R6728P26· 18
CMW710-R6728P25· 18
CMW710-R6728P23· 19
CMW710-R6728P19· 19
CMW710-R6728P17· 19
CMW710-R6728P16· 19
CMW710-R6728P15· 19
CMW710-R6728P14· 19
CMW710-R6728P12· 19
CMW710-R0821P15· 19
CMW710-R0821P14· 19
CMW710-R0821P13· 20
CMW710-R0821P11· 20
CMW710-R0821P10· 20
CMW710-R0809P33· 20
CMW710-R0809P32· 20
CMW710-R0809P28· 20
Software feature and command updates· 20
MIB updates· 21
Operation changes· 23
Restrictions and cautions· 23
Restrictions· 23
Cautions· 23
Licensing· 23
About licensing· 23
Registering and installing licenses· 24
Obtaining license server software and documentation· 24
Open problems and workarounds· 24
List of resolved problems· 25
Resolved problems in CMW710-R6728P26· 25
Resolved problems in CMW710-R6728P25· 27
Resolved problems in CMW710-R6728P23· 28
Resolved problems in CMW710-R6728P20· 29
Resolved problems in CMW710-R6728P19· 30
Resolved problems in CMW710-R6728P18· 31
Resolved problems in CMW710-R6728P17· 31
Resolved problems in CMW710-R6728P1601· 33
Resolved problems in CMW710-R6728P16· 33
Resolved problems in CMW710-R6728P15· 34
Resolved problems in CMW710-R6728P14· 34
Resolved problems in CMW710-R6728P12· 34
Resolved problems in CMW710-R0821P16· 35
Resolved problems in CMW710-R0821P15· 35
Resolved problems in CMW710-R0821P14· 35
Resolved problems in CMW710-R0821P13· 36
Resolved problems in CMW710-R0821P11· 36
Resolved problems in CMW710-R0821P10· 36
Resolved problems in CMW710-R0809P33· 37
Resolved problems in CMW710-R0809P32· 37
Resolved problems in CMW710-R0809P28· 37
Resolved problems in CMW710-R0809P27· 38
Resolved problems in CMW710-R0809P25· 38
Resolved problems in CMW710-R0809P22· 39
Resolved problems in CMW710-R0707P24· 39
Resolved problems in CMW710-R0707P21· 41
Resolved problems in CMW710-R0707P19· 41
Resolved problems in CMW710-R0707P16· 42
Troubleshooting resources· 45
Related documentation· 46
Documentation set 46
Obtaining documentation· 46
Technical support 46
Appendix A Feature list 47
Hardware features· 47
Software features· 66
Appendix B Upgrading software· 70
Software types· 70
Upgrade methods· 70
Preparing for the upgrade· 71
Centralized devices upgrading from the CLI 72
Saving the running configuration and verifying the storage space· 72
Downloading the image file to the router 73
Specifying the startup image file· 73
Rebooting and completing the upgrade· 74
Distributed devices upgrading from the CLI 76
Displaying the slot number of the active MPU·· 76
Saving the running configuration and verifying the storage space· 76
Downloading the image file to the router 77
Specifying the startup image file· 77
Rebooting and completing the upgrade· 79
Upgrading from the BootWare menu· 80
Accessing the BootWare menu· 80
Using TFTP/FTP to upgrade software through an Ethernet port 82
Using XMODEM to upgrade software through the console port 85
Managing files from the BootWare menu· 90
Displaying all files· 91
Changing the type of a system software image· 91
Deleting files· 92
Handling software upgrade failures· 93
Appendix C Handling console login password loss· 93
Disabling password recovery capability· 93
Handling console login password loss· 94
Examining the password recovery capability setting· 95
Using the Skip Current System Configuration option· 96
Using the Skip Authentication for Console Login option· 97
Using the Restore to Factory Default Configuration option· 98
List of tables
Table 1 Version history· 1
Table 2 Hardware and software compatibility matrix· 9
Table 3 MSR610 and fit AP compatibility matrix· 12
Table 4 MSR810-W/MSR810-W-DB/MSR810-LM/MSR810-LM-HK/MSR810-LM-CNDE-SJK/MSR810-CNDE-SJK/MSR810-W-LM/MSR810-W-LM-HK/MSR810-LME/MSR810-LM-EIMSR2600-10-X1/MSR26-30/MSR3600-28/MSR3600-28-X1/MSR3600-28-X1-DP/MSR3600-51/MSR3600-51-X1/MSR3600-51-X1-DP/MSR36-10/MSR36-20/SR36-40/MSR36-60 and fit AP compatibility matrix· 13
Table 5 MSR2600-6-X1/MSR2600-15-X1/MSR3610-X1-DP/MSR3610-X1-DC/MSR3610-X1-DP-DC and fit AP compatibility matrix· 14
Table 6 MSR3610-I-DP/MSR3610-I-DP+DDR4-16GB/MSR3610-I-DP+DDR4-32GB/MSR3610-IE-DP/MSR3610-IE-DP+DDR4-8GB/MSR3610-IE-DP+DDR4-32GB/ MSR3610-IE-EAD/MSR-EAD-770 and fit AP compatibility matrix· 14
Table 7 MSR810/MSR810-10-PoE/MSR3620-DP and fit AP compatibility matrix· 15
Table 8 MSR3610-X1 and fit AP compatibility matrix· 15
Table 9 MSR3610-I-DP+DDR4-8GB/MSR3610-IE-DP+DDR4-16GB and fit AP compatibility matrix· 16
Table 10 MSR810-LM-GL/MSR810-W-LM-GL/MSR830-6EI-GL/MSR830-10EI-GL/MSR830-6HI-GL/MSR830-10HI-GL/MSR2600-6-X1-GL/MSR1004S-5G and fit AP compatibility matrix· 17
Table 11 MSR860-6EI-XS/MSR860-6HI-XS/MSR3600-28-XS/MSR3620-XS and fit AP compatibility matrix· 17
Table 12 MSR2630-XS/MSR3610-XS/MSR3610-I-XS/MSR3610-IE-XS and fit AP compatibility matrix· 17
Table 13 MIB updates· 21
Table 14 MSR 26-30 specifications· 47
Table 15 MSR 3600 specifications· 47
Table 16 MSR 5600 specifications· 49
Table 17 MSR 56 MPU-100 Specification· 49
Table 18 MSR 56 SPU Specification· 49
Table 19 MSR 36-40/36-60/56-60/56-80 AC power module specifications· 50
Table 20 MSR 36-40/36-60/56-60/56-80 DC power module specifications· 50
Table 21 MSR3600-51 AC power module specifications· 50
Table 22 MSR3600-51 DC power module specifications· 50
Table 23 MSR 36-40/36-60/56-60/56-80 PoE power module specifications· 50
Table 24 MSR 3620-DP specifications· 50
Table 25 MSR 5620 specifications· 51
Table 26 MSR 56 MPU-60 Specification· 52
Table 27 MSR 3620-DP AC power module specifications· 52
Table 28 MSR 5620 AC power module specifications· 52
Table 29 MSR 3620-DP DC power module specifications· 52
Table 30 MSR 5620 DC power module specifications· 52
Table 31 MSR 5620 PoE power module specifications· 52
Table 32 MSR2600 specifications· 53
Table 33 MSR2600-10-X1 router specifications· 53
Table 34 MSR810-10-PoE specifications· 54
Table 35 MSR810-EI_ MSR810-LM-EA· 54
Table 36 MSR810 specifications· 55
Table 37 MSR810-LME specifications· 56
Table 38 MSR810-GL specifications· 56
Table 39 MSR830 specifications· 57
Table 40 MSR2600-6-X1-GL specifications· 58
Table 41 MSR3600-28-SI-GL specifications· 58
Table 42 MSR3610-X1 specifications· 59
Table 43 MSR3610-I specifications· 60
Table 44 MSR1000 router series specifications· 61
Table 45 MSR610 router series specifications· 61
Table 46 MSR series routes Module List 62
Table 47 MSR Series routers software features· 66
Table 48 Storage media· 71
Table 49 BootWare menu options· 81
Table 50 Ethernet submenu options· 82
Table 51 Network parameter fields and shortcut keys· 83
Table 52 Serial submenu options· 85
Table 53 File Control submenu options· 91
Table 54 BootWare options and password recovery capability compatibility matrix· 93
Introduction
This document describes the features, restrictions and guidelines, open problems, and workarounds for version R6728P26. Before you use this version on a live network, back up the configuration and test the version to avoid software upgrade affecting your live network.
Use this document in conjunction with H3C MSR2600_MSR3600_MSR5600_MSR8XX-CMW710-R6728P26 Release Notes (Software Feature Changes) and the documents listed in "Related documentation."
Version information
Version number
H3C Comware Software, Version 7.1.064, Release 6728P26
To identify the version number (see Note), execute the display version command in any view.
Version history
IMPORTANT
IMPORTANT:
The software feature changes listed in the version history table for each version are not complete. To obtain complete information about all software feature changes in each version, see the Software Feature Changes document for this release notes.
For information about version R0809P22 and earlier for different device models, see the following documents:
·         MSR810_MSR810P10_MSR810SE series routersH3C MSR810_MSR810P10_MSR810SE-CMW710-R0809P22 Release Notes
·         MSR2600-6-X1-GL_MSR3600-28-SI-GL series routersH3C MSR2600_MSR3600-CMW710-R0809P22 Release Notes
·         MSR830EI-GL_MSR830HI-GL_MSR810-GL series routersH3C MSR810_MSR830-CMW710-R0809P22 Release Notes
Version number
Last version
Release date
Release type
Remarks
CMW710-R6728P26
CMW710-R6728P25
2023-03-29
Release version
Support MSR 2600_3600_5600_MSR8XX series.
Fixes bugs.
CMW710-R6728P25
CMW710-R6728P23
2022-12-08
Release version
·        Fixes bugs.
CMW710-R6728P23
CMW710-R6728P20
2022-09-15
Release version
·        New feature:
1.Configuring BFD parameters for the specified BGP peer or peer group
·        Fixes bugs.
 CMW710-R6728P22
First releases
2022-08-24
Release version
MSR610 first releases
CMW710-R6728P20
CMW710-R6728P19
2022-06-23
Release version
·        Fixes bugs.
CMW710-R6728P19
CMW710-R6728P17
2022-06-16
Release version
·        New hardware feature
Add new hardware:
HMIM-4SAE-V2
HMIM-8SAE-V2
·        Fixes bugs.
CMW710-R6728P18
CMW710-R6728P1601
2022-05-16
Release version
Support MSR1004S-5G
Fixes bugs
CMW710-R6728P17
CMW710-R6728P16
2022-04-02
Release version
·        New feature:
1.Transparent transmission of RIR data packets on an interface
2.New feature: WAAS packet duplication
3.Binding a smart token to the device
4.Configuring a title for a PKI entity
5.Support for AAA private protocol
·        Modified feature:
1.Matching the return packets after NAT is performed
2.Changing the link mode for GE0 and SFP5 interfaces on the front panel of an MSR810-W-LM-GL or MSR2600-6-X1-GL
3.Configuring the initiator to use dynamic source UDP ports for IKE negotiations
4.Support of IKE profiles for obtaining user information from AAA servers for client authentication
·        Fixes bugs.
CMW710-R6728P1601
CMW710-R6728P15
2022-03-18
Release version
Support MSR1004S-5G
Fixes bugs
CMW710-R6728P16
CMW710-R6728P14
2022-03-02
Release version
·        Modified feature:
1. Encapsulating mirrored packets with parameter such as destination IP and source IP for flow-mirroring traffic to an interface
·        Fixes bugs.
CMW710-R6728P15
CMW710-E6728P13
2022-01-25
Release version
Support MSR1004S-5G
Fixes bugs
CMW710-R6728P14
CMW710-R6728P12
2021-12-29
Release version
·        New feature:
1. Applying the export routing policy to VPNv4 routes before RT filtering
CMW710-E6728P13
First release
2021-11-19
Release version
MSR1004S-5G first release
CMW710-R6728P12
CMW710-R0821P16
2021-11-01
Release version
·        New feature:
1. Configuring the FEP host name and port number for a POS application template
2. Configuring flow priority-based traffic scheduling
3. Configuring the link load balancing mode
4. Enabling the device to drop service flows upon failure to find an optimal link
5. Configuring RIR collaboration
6. Specifying a VXLAN tunnel as a dedicated link for a flow template
7. Configuring domain name delimiters
8. Configuring BGP-EPE
9. Public network IP over SRv6
10. Link state change statistics of Ethernet interfaces
11. Route exchange between the BGP EVPN address family and the BGP VPNv4 address family
12. Redistributing MAC/IP advertisement routes of EVPN into BGP unicast routing tables
13. Changing the style of Web management pages to the new style
14 Specifying a label allocation mode
15 Remote address switchback for IPsec backup
16 Displaying global IPsec information
17 Displaying global IKE information
18 Enabling logging for creations and deletions of P2MP IPsec tunnel entries
19 Adding management IPs, IP ranges, and excluded IPs for Telnet
20 Configuring EoGRE tunnels and monitoring EoGRE information
21 WLAN optimization
22 Specifying file extensions of webpage files to be cached
23 Configuring traffic direction channels for Web cache dual gateways
24 Enabling the route reflector to change the attributes of routes to be reflected
25 NetStream for an SRv6-TE policy
26 NetStream sampling for an SRv6-TE policy
27 IPv6 NetStream for an SRv6-TE policy
28 Configuring an MPLS load sharing mode
29 Excluding a host name from an address object
30 Configuring URL deployment
·        Modified feature:
1 Configuring fast log output with VNI information for NAT modules
2 Settings the maximum number of consecutive keepalive packets that the local device can send to the cloud server
3 Specifying the port number, VPN instance, and source IPv4 address when connecting a device to a cloud server
4 Support of iNQA for binding a VSI interface or VSI subinterface to the MP
5 Specifying the output interface for NQA probe packets
6 Configuring SRv6 TE policy forwarding statistics
7 Configuring the green channel in bandwidth management from the Web interface
8 Displaying binding information about assigned IP addresses
9 Adding multiple static IP address bindings in bulk
10 Displaying information about a cellular interface
11 Editing the MAC addresses imported to MAC address filter
12 Specifying a remote address for an IPsec tunnel
13 Displaying IKE SA information
14 Configuring a peer ID for IKE profile matching
15 Displaying IPsec policy information
16 Configuring a TCP match criterion in a WAAS class
17 Applying IPsec policy entries to an interface
18 Using the original cost of redistributed routes
19 ALG support for processing IP fragments and TCP segments of SIP
20 Setting port numbers for Web caching to listen for HTTP or HTTPS packets
21 Specifying an IP address object group used to filter Web content to be cached
22 Configuring an optimization action for an RTP WAAS class
23 Configuring the link bandwidth of a VXLAN tunnel interface
24 Enabling RIR link selection based on remaining bandwidth of physical interfaces
25 Login IP address for Web login
26 Web configuration for IPsec VPN establishment
27 Configuring a NAT one-to-one mapping from the Web interface
·        Fixes bugs.
CMW710-R0821P16
CMW710-R0821P15
2021-08-30
Release version
Support MSR 2600_3600_5600_MSR8XX series.For more information, see Table 2
·        Fixes bugs.
CMW710-R0821P15
CMW710-R0821P14
2021-07-29
Release version
·        Fixes bugs.
CMW710-R0821P14
CMW710-R0821P13
2021-07-12
Release version
·        Fixes bugs.
CMW710-R0821P13
CMW710-R0821P11
2021-05-21
Release version
·        Fixes bugs.
CMW710-R0821P11
CMW710-R0821P10
2021-03-19
Release version
·        Fixes bugs.
CMW710-R0821P10
CMW710-R0809P33
2021-02-08
Release version
·        New feature
1Layer 3 connection keepalive
2Session synchronization
3gRPC
4HTTP proxy
5CAR-list-based dynamic traffic policing
6Error code detection
·        Modified feature
1Local FPGA mirroring group
2Configuring a match criterion for QoS
3Support for keychain authentication with the HMAC-SM3 or SM3 algorithm
4Configuring a static route
5Redistributing replicated BGP routes to IGPs
6Configuring dynamic port block mapping for NAT444
·        Fixes bugs.
CMW710-R0809P33
CMW710-R0809P32
2020-12-15
Release version
·        Fixes bugs.
CMW710-R0809P32
CMW710-R0809P28
2020-11-12
Release version
·        Fixes bugs.
CMW710-R0809P28
CMW710-R0809P27
2020-07-28
Release version
·        Fixes bugs.
CMW710-R0809P27
CMW710-R0809P25
2020-06-29
Release version
·        New feature:
1.Configuring the DHCP-designated default router as the next hop of a static route
2.Applying an SSL server policy to the RESTful access over HTTPS service
3.Applying an SSL server policy to the NETCONF over SOAP over HTTPS service
·        Fixes bugs.
CMW710-R0809P25
CMW710-R0809P22
2020-05-20
Release version
·        New feature:
1. Backup H3C Oasis servers
2. Enabling forced forwarding for an MPLS TE tunnel
3. EPS agent
·        Modified feature
1. Login password control
·        Fixes bugs.
CMW710-R0809P22
CMW710-R0707P24
2020-04-26
Release version
Support MSR 2600_3600_5600 series
·        New feature:
1.Setting the maximum number of ECMP routes
2.Support for last hop backup
3.Session synchronization
4.Support for dynamic port block mapping synchronization
·        5.Support for NPTv6
·        6.VXLAN support for IPv6 underlay networks
7.Portal support for NAT444
·        Modified feature
·        1.Configuring portal authentication pages
·        Fixes bugs.
CMW710-R0707P24
CMW710-R0707P21
2020-03-25
Release version
·        Modified feature:
1. Processing for user IP conflicts on an LNS
2. Login password control
·        Fixes bugs.
CMW710-R0707P21
CMW710-R0707P19
2019-11-07
Release version
·        Fixes bugs.
CMW710-R0707P19
CMW710-R0707P16
2019-09-20
Release version
·        Fixes bugs.
CMW710-R0707P16
CMW710-R0605P13
2019-06-20
Release version
·        New feature:
1. mGRE
2. Public key management support for Suite B
3.PKI support for Suite B
4.IPsec support for Suite B
5.SSL support for Suite B
6.FIPS support for Suit B
7.SSH support for Suite B
8. Support for collaboration with the Oasis platform on the MSR3610-I-DP[IE-DP]
·         Modified feature:
1. Ethernet interface
·        Fixes bugs.
CAUTION
CAUTION:
To avoid an upgrade failure, use Table 2 to verify the hardware and software compatibility before performing an upgrade.
Item
Specifications
Product family
MSR2600_MSR 3600_MSR 5600_MSR8XX
Hardware platform
MSR 26-30
MSR 2600-10-X1
MSR 36-10_MSR 36-20_MSR 36-40_MSR 36-60_MSR 3600-28_MSR 3600-51
MSR 56-60_MSR 56-80
MSR 3620-DP
MSR 5620
MSR3610-X1_MSR3610-X1-DP_MSR3610-X1-DC_MSR3610-X1-DP-DC
MSR3600-28-SI_ MSR3600-51-SI
MSR 2600-6-X1
MSR3600-28-X1/MSR3600-28-X1-DP/MSR3600-51-X1/MSR3600-51-X1-DP
MSR3610-G/MSR3620-G
MSR3610-I-DP/MSR3610-IE-DP/MSR3610-IE-ES/MSR3610-IE-EAD/MSR3610-I-IG/MSR3610-IE-IG
MSR810-CNDE-SJK
MSR810_MSR810-W_MSR810-W-DB_MSR810-LM_MSR810-W-LM_MSR810-LM-EA
MSR810-LMS_ MSR810-LUS
MSR810-LME
MSR2600-15-X1
MSR3660-XS_MSR3640-X1-HI
MSR1004S-5G
MSR610
Boot ROM version
MSR 26-30: 183 or higher
MSR 3600-28_MSR 3600-51: 183 or higher
MSR 36-10_MSR 36-20_MSR 36-40_MSR 36-60182 or higher
MSR 56-60_MSR 56-80:
 MPU-100: 171 or higher
                     SPU-100/200150 or higher
MPU-100-X1: 240 or higher
SPU-100-X1/SPU-200-X1/SPU-400-X1/ SPE-S1220 or higher
SPE-S3: 101 or higher
MSR 2600-10-X1:273 or higher
MSR 3620-DP131 or higher
MSR 5620 MPU-60242 or higher
                      SPU220 or higher
MSR3610-X1_MSR3610-X1-DP_MSR3610-X1-DC_MSR3610-X1-DP-DC132 or higher
MSR3600-28-SI_ MSR3600-51-SI121 or higher
MSR2600-6-X1113 or higher
MSR3600X1: 104 or higher
MSR3620G4: 122 or higher
MSR3620G16: 122 or higher
MSR36I: 113 or higher
MSR810_MSR810-CNDE-SJK_MSR810-LM-EA_MSR810-EI: 167 or higher
MSR810-LMS_ MSR810-LUS: 111 or higher
MSR810-LME: 111 or higher
MSR830EI: 167 or higher
MSR830HI:123 or higher
MSR830S: 111 or higher
MSR3600-28/51-X1:104 or higher
MSR2600-15-X1: 102 or higher
MSR3660-XS_MSR3640-X1-HI:103 or higher
MSR1004S-5G102 or higher
MSR 610167 or higher
(Note: Perform the command display version command in any view to view the version information. Please see Note)
Software images and their MD5 checksums
Hardware
software
MD5 Check Sum
MSR 26-30
MSR26-CMW710-R6728P26.ipe
6621eca4df82986768872a4b1688a622
MSR 2600-6-X1
MSR26X1A-CMW710-R6728P26.ipe
0c017d6095dd99d8a40af5b7619bee78
MSR36-10_MSR36-20_MSR36-40_MSR36-60_MSR3620-DP
MSR36-CMW710-R6728P26.ipe
be05c80b80bd8a1005323d98d7d2af49
MSR3610-I-DP_MSR3610-IE-DP/MSR3610-IE-EAD
MSR36I-CMW710-R6728P26.ipe
e2c7975377e4e7d159eb42082ba5c0f8
MSR3610-X1
MSR36X1-CMW710-R6728P26.ipe
bce53c3332ae58350b7bf92c7c8f353a
MSR810_MSR810-W_MSR810-W-DB_MSR810-LM_MSR810-W-LM_MSR810-LM-EA_ MSR810-EI
MSR810-CMW710-R6728P26.ipe
e3c4694db527773365efdd0cbd2f2858
MSR810-LME
MSR810SE-CMW710-R6728P26.ipe
365b2b537c2db5c082e57009e3ec6070
MSR830-10EI-GL_MSR830-6EI-GL
MSR830EI-CMW710-R6728P26.ipe
b271dbe131ff1a2f203cf8c803507b10
MSR830-10HI-GL_MSR830-6HI-GL
MSR830HI-CMW710-R6728P26.ipe
3281592688b1cb62819781b80feba7af
MSR 2600-10-X1
MSR2600X1-CMW710-R6728P26.ipe
e1e4990129247b8cfc441334db459af0
MSR3600-28_MSR3600-51
MSR3600-CMW710-R6728P26.ipe
97ef3708ad3e8ccbf6114d5f81ee478e
MSR3600-28-X1_MSR3600-28-X1-DP_MSR3600-51-X1_MSR3600-51-X1-DP
MSR3600X1-CMW710-R6728P26.ipe
8de89c680d469463605d730764973bd7
MSR3610-G_MSR3620-G
MSR36G-CMW710-R6728P26.ipe
c255f409ab97b8ca1634cd2a7c1a5d31
MSR 56-60_MSR 56-80_MSR 5620
MSR56-CMW710-R6728P26.ipe
ed8170db18166e62d9451f1a5a79eae7
MSR810S-CMW710-R6728P26.ipe
9727e4083811eae50faab5df7d905065
MSR3600SI-CMW710-R6728P26.ipe
2c47b17473d3fa3b42309f8364c635e2
MSR36X1HI-CMW710-R6728P26.ipe
da9a76ed66c5dfe1888b430ec0ffc3b4
MSR1004S-5G
MSR1004S-CMW710-R6728P26.ipe
c94a469610327991ae3da0293a13a8b1
MSR 610
MSR610-CMW710-R6728P26.ipe
c75ba6335c5fc91ebc5465817b9ee76b
iMC version
iMC FCAPS(E0709)
iMC AOM(E0706P01)
iMC ACLM (E0706P12)
iMC BIMS 7.3 (E0509)
iMC DM 7.3(E0706P12)
iMC EAD 7.3 (E0627)
iMC EIA 7.3 (E0627)
iMC EIA 7.3 (E0627)
iMC iCC 7.3(E0706P12)
iMC IVM 7.3 (E0508)
iMC MVM 7.3 (E0511)
iMC NTA 7.3 (E0507)
iMC PLAT 7.3 (E0706P12)
iMC QoSM 7.3 (E0506P01)
iMC SHM 7.3 (E0511)
iMC WSM 7.3 (E0609)
UCenter E0709
iMC VLAN 7.3 (E0706P12)
iNode version
iNode PC 7.3 (E0585)
Cards version
Cards Name
CPLD or FPGA version
SIC-4G-LTE-V
100 or higher
SIC-4G-LTE-A
100 or higher
SIC-4G-LTE-G
100 or higher
SampSample: To display the host software and Boot ROM version of the MSR 810, perform the following:
<Sysname> display version
H3C Comware Software, Version 7.1.064, Release 6728P26                ------- Note
Copyright (c) 2004-2022 New H3C Technologies Co., Ltd. All rights reserved.
H3C MSR810 uptime is 0 weeks, 0 days, 0 hours, 3 minutes
Last reboot reason : User reboot
Boot image: flash:/msr810-cmw710-boot-r6728p26.bin
Boot image version: 7.1.064P80, Release 6728P26
  Compiled Jun 16 2022 15:00:00
System image: flash:/msr810-cmw710-system-r6728p26.bin
System image version: 7.1.064, Release 6728P26
Feature image(s) list:
  flash:/msr810-cmw710-wifidog-r6728p26.bin, version: 7.1.064
  flash:/msr810-cmw710-wwd-r6728p26.bin, version: 7.1.064
  flash:/msr810-cmw710-security-r6728p26.bin, version: 7.1.064
  flash:/msr810-cmw710-voice-r6728p26.bin, version: 7.1.064
  flash:/msr810-cmw710-data-r6728p26.bin, version: 7.1.064
CPU ID: 0xa
1G bytes DDR3 SDRAM Memory
256M bytes Flash Memory
PCB               Version:Ver.A
CPLD              Version:  0.0
Basic    BootWare Version:  1.67                                ------Note
Extended BootWare Version:  1.67
[SLOT  0]CON                       (Hardware)Ver.A, (Driver)1.0,   (CPLD)0.0
[SLOT  0]GE0/0                     (Hardware)Ver.A, (Driver)1.0,   (CPLD)0.0
[SLOT  0]4GSW                      (Hardware)Ver.A, (Driver)1.0,   (CPLD)0.0
[SLOT  0]SFP0/5                    (Hardware)Ver.A, (Driver)1.0,   (CPLD)0.0
[SLOT  0]CELLULAR0/0               (Hardware)Ver.A, (Driver)1.0,   (CPLD)0.0
AP
File Name
Remarks
WA4320i-ACN
WA4320H-ACN
WA4320-ACN
WA4320X
WA4330-ACN
WA4320-ACN-B
WA4320H-ACN-HI
wa4300.ipe
WA4320-ACN-SI
wa4300s.ipe
WA4320H
WA4320H-EI
WA510H-WW
wa4300h.ipe
WA5620i-ACN
WA5620
WA560-WW
wa5600.ipe
WA5320H
WA5320
WA5320E
WA5320i
WA5320-SI
WA5530-SI
WA5530
WA530-WW
WA530X-WW
WA536-WW
WA538-WW
wa5300.ipe
Table 4 MSR810-W/MSR810-W-DB/MSR810-LM/MSR810-LM-HK/MSR810-LM-CNDE-SJK/MSR810-CNDE-SJK/MSR810-W-LM/MSR810-W-LM-HK/MSR810-LME/MSR810-LM-EIMSR2600-10-X1/MSR26-30/MSR3600-28/MSR3600-28-X1/MSR3600-28-X1-DP/MSR3600-51/MSR3600-51-X1/MSR3600-51-X1-DP/MSR36-10/MSR36-20/MSR36-40/MSR36-60 and fit AP compatibility matrix
AP型号
文件名
备注
WA4320i-ACN
WA4320H-ACN
WA4320-ACN
WA4320X
WA4330-ACN
WA4320-ACN-B
WA4320H-ACN-HI
wa4300.ipe
WA4320-ACN-SI
wa4300s.ipe
WA4320H
WA4320H-EI
wa4300h.ipe
WA5620i-ACN
WA5620
wa5600.ipe
WA5320H
WA5320
WA5320E
WA5320i
WA5320-SI
WA5530-SI
WA5530
wa5300.ipe
AP型号
文件名
备注
WA4320i-ACN
WA4320H-ACN
WA4320-ACN
WA4320X
WA4330-ACN
WA4320-ACN-B
WA4320H-ACN-HI
wa4300.ipe
WA4320-ACN-SI
wa4300s.ipe
WA4320H
WA4320H-EI
SIC-AP320
wa4300h.ipe
WA5620i-ACN
WA5620
wa5600.ipe
WA5320H
WA5320
WA5320E
WA5320i
WA5320-SI
WA5530-SI
WA5530
wa5300.ipe
AP型号
文件名
备注
WA4320i-ACN
WA4320H-ACN
WA4320-ACN
WA4320X
WA4330-ACN
WA4320-ACN-B
WA4320H-ACN-HI
wa4300.ipe
WA4320-ACN-SI
SIC-AP220
wa4300s.ipe
WA4320H
WA4320H-EI
SIC-AP320
wa4300h.ipe
WA5620i-ACN
WA5620
wa5600.ipe
WA5320H
WA5320
WA5320E
WA5320i
WA5320-SI
WA5530-SI
WA5530
wa5300.ipe
AP型号
文件名
备注
WA4320i-ACN
WA4320H-ACN
WA4320-ACN
WA4320X
WA4330-ACN
WA4320-ACN-B
WA4320H-ACN-HI
wa4300.ipe
WA4320-ACN-SI
wa4300s.ipe
WA4320H
WA4320H-EI
WA510H-WW
wa4300h.ipe
WA5620i-ACN
WA5620
WA560-WW
wa5600.ipe
WA5320H
WA5320
WA5320E
WA5320i
WA5320-SI
WA5530-SI
WA5530
WA530-WW
WA530X-WW
WA536-WW
WA538-WW
wa5300.ipe
AP型号
文件名
备注
WA4320i-ACN
WA4320H-ACN
WA4320-ACN
WA4320X
WA4330-ACN
WA4320-ACN-B
WA4320H-ACN-HI
wa4300.ipe
WA4320-ACN-SI
wa4300s.ipe
WA4320H
WA4320H-EI
WA510H-WW
SIC-AP320
wa4300h.ipe
WA5620i-ACN
WA5620
WA560-WW
wa5600.ipe
WA5320H
WA5320
WA5320E
WA5320i
WA5320-SI
WA5530-SI
WA5530
WA530-WW
WA530X-WW
WA536-WW
WA538-WW
wa5300.ipe
AP型号
文件名
备注
WA4320i-ACN
WA4320H-ACN
WA4320-ACN
WA4320X
WA4330-ACN
WA4320-ACN-B
WA4320H-ACN-HI
wa4300.ipe
WA4320-ACN-SI
SIC-AP220
wa4300s.ipe
WA4320H
WA4320H-EI
WA510H-WW
SIC-AP320
wa4300h.ipe
WA5620i-ACN
WA5620
WA560-WW
wa5600.ipe
WA5320H
WA5320
WA5320E
WA5320i
WA5320-SI
WA5530-SI
WA5530
WA530-WW
WA530X-WW
WA536-WW
WA538-WW
wa5300.ipe
AP型号
文件名
备注
WA510H-WW
wa4300h.ipe
WA560-WW
wa5600.ipe
WA530-WW
WA530X-WW
WA536-WW
WA538-WW
wa5300.ipe
AP型号
文件名
备注
WA4320i-X
wa4300.ipe
WA2610H
WA2610H-LI
WA4320H-SI
WA4320-ACN-E
WA4320-ACN-D
WA4320-ACN-C
wa4300s.ipe
WA4320H
WA5320H-LI
WA5320-D
wa4300h.ipe
WA5320-C
WA5320-C-IOT
WA5320
WA5320i-LI
WA5320H
WA5320-C-EI
WA5320X-E
WA5320X-SI
WA5320X
WA5320X-LI
WA5530S
WA5530-LI
WA5530
wa5300.ipe
AP型号
文件名
备注
WA4320i-X
wa4300.ipe
WA2610H
WA2610H-LI
WA4320H-SI
WA4320-ACN-E
WA4320-ACN-D
WA4320-ACN-C
wa4300s.ipe
WA4320H
WA5320H-LI
WA5320-D
SIC-AP320
wa4300h.ipe
WA5320-C
WA5320-C-IOT
WA5320
WA5320i-LI
WA5320H
WA5320-C-EI
WA5320X-E
WA5320X-SI
WA5320X
WA5320X-LI
WA5530S
WA5530-LI
WA5530
wa5300.ipe
Upgrade advice
As a best practice, upgrade to this version as long as possible.
Before performing a software upgrade, it is important to refer to the H3C MSR2600_MSR3600_MSR5600_MSR8XX-CMW710-R6728P26 Release Notes (Software Feature Changes) document for any feature changes in the new version. Also check the most recent version of the related documents (see "Related documentation") available on the H3C website for more information about feature configuration and commands.
CMW710-R6728P26
None.
CMW710-R6728P25
None.
CMW710-R6728P23
None.
CMW710-R6728P19
Add new hardware:
HMIM-4SAE-V2
HMIM-8SAE-V2.
CMW710-R6728P17
Add new hardware:
RT-SIC-4G-CAT6
CMW710-R6728P16
None.
CMW710-R6728P15
Add  new hardware:
MSR1004S-5G
MSR1004S-5G-GL
CMW710-R6728P14
None.
CMW710-R6728P12
None.
CMW710-R0821P15
None.
CMW710-R0821P14
None.
CMW710-R0821P13
Add  new hardware:
2-Port OC-3c/STM-1c POS HMIM Module
4-Port Asynchronous Serial Interface (4*RS232/RS422/RS485,2*DI) SIC Module
H3C MSR3610-IG ICT Industrial Converged Gateway with 8GE (2Combo) Ports,HD Supported,PoE Supported,Dual AC Power Supplies
H3C MSR3610-IG Enhanced ICT Industrial Converged Gateway with 8GE (2Combo) Ports,HD Supported,PoE Supported,Dual AC Power Supplies
CMW710-R0821P11
None.
CMW710-R0821P10
None.
CMW710-R0809P33
None.
CMW710-R0809P32
None.
CMW710-R0809P28
None.
For software feature changes in version R0809P22 and earlier for different device models, see the following documents:
·         MSR810_MSR810P10_MSR810SE series routersH3C MSR810_MSR810P10_MSR810SE-CMW710-R0809P22 Release Notes (Software Feature Changes)
·         MSR2600-6-X1-GL_MSR3600-28-SI-GL series routersH3C MSR2600_MSR3600-CMW710-R0809P22 Release Notes (Software Feature Changes)
·         MSR830EI-GL_MSR830HI-GL_MSR810-GL series routersH3C MSR810_MSR830-CMW710-R0809P22 Release Notes (Software Feature Changes)
For more information about the software feature and command update history, see H3C MSR2600_MSR3600_MSR5600-CMW710-R6728P26 Release Notes (Software Feature Changes).
MIB updates
Item
MIB file
Module
CMW710-R6728P26
New
None
None
None
Modified
None
None
None
CMW710-R6728P25
New
None
None
None
Modified
None
None
None
CMW710-R6728P23
New
None
None
None
Modified
None
None
None
CMW710-R6728P19
New
None
None
None
Modified
None
None
None
CMW710-R6728P17
New
None
None
None
Modified
None
None
None
CMW710-R6728P16
New
None
None
None
Modified
None
None
None
CMW710-R6728P15
New
None
None
None
Modified
None
None
None
CMW710-R6728P14
New
None
None
None
Modified
None
None
None
CMW710-R6728P12
New
None
None
None
Modified
None
None
None
CMW710-R0821P15
New
None
None
None
Modified
None
None
None
CMW710-R0821P14
New
None
None
None
Modified
None
None
None
CMW710-R0821P13
New
None
None
None
Modified
None
None
None
CMW710-R0821P11
New
None
None
None
Modified
None
None
None
CMW710-R0821P10
New
None
None
None
Modified
None
None
None
CMW710-R0821P09
New
None
None
None
Modified
None
None
None
CMW710-R0809P33
New
None
None
None
Modified
None
None
None
CMW710-R0809P32
New
None
None
None
Modified
None
None
None
CMW710-R0809P28
New
None
None
None
Modified
None
None
None
CMW710-R0809P27
New
None
None
None
Modified
None
None
None
CMW710-R0809P25
New
None
None
None
Modified
None
None
None
CMW710-R0707P24
New
None
None
None
Modified
None
None
None
CMW710-R0707P21
New
None
None
None
Modified
None
None
None
CMW710-R0707P19
New
None
None
None
Modified
None
None
None
CMW710-R0707P16
New
hh3c-entity-vendortype-oid.
mib
hh3c-product-id.mib
RFC1213-MIB
Added  RFC1213-MIB
Modified
None
None
None
Operation changes
None.
When you use this version of software, make sure you fully understand the restrictions and cautions described in this section.
Restrictions
Software Feature
1.       The mGRE and Suite B features are not available in the current software version R04XX.
Others
2.       After the version is graded to R0809P27, the password of a local user must contain a minimum of 10 characters, and the password complexity settings must be compliant with the requirements. For more information about the password complexity requirements, see the password control commands in the software feature change.
3.       Preprovisioning is not supported on all devices and cards. For more information about support for previsioning, contact Technical Support.
Cautions
None.
Licensing
About licensing
H3C offers licensing options for you to deploy features and expand resource capacity on an as needed basis. To use license-based features, purchase licenses from H3C and install the licenses. For more information about the license-based features and licenses available for them, see H3C MSR & SR6600 Series Routers License Matrixes.
To register and transfer licenses, access H3C license services at http://www.h3c.com/en/License.
For information about registering licenses, installing activation files, and transferring licenses, see H3C Switches & Routers Licensing Guide
To perform remote licensing, first download and install the H3C license server software.
·         To obtain the H3C license server software package, click
·         To obtain H3C license server documentation, click
202112211799
·         Symptom: After IPsec is configured for the device, the device cannot defend against DDoS attacks of UDP packets from port 4500. The device CPU usage reaches 100% if 20M such UDP packets are injected. The device CPU operates normally if IPsec settings are removed or other types of packets (packets from ports other than port 4500) are injected.
·         Condition: This symptom occurs if you configure IPsec for the device and then inject 20M UDP packets with source port 4500.
·         Workaround: Use a filtering method, such as packet filter, to filter the attack packets.
202203150527
·         Symptom: If full gigabit traffic is injected to interfaces G0/1 to G0/2 on MSR3600G for forwarding, BFD sessions flap on the interfaces that are not forwarding traffic.
·         Condition: This symptom occurs if the FPGA backend does not have the order preserving function, and protocol packets are not received or sent in time on the interfaces without traffic when the FPGA interfaces are forwarding a large number of service traffic.
·         Workaround: This issue does not occur in non-pressured scenarios.
202110120447
·         Symptom: The ADWAN controller deploys SR-TE settings and redirects traffic to a tunnel. The traffic is forwarded along the scheduled the tunnel. However, the route shows that the traffic is forwarded through the default tunnel and the FIB entry has multiple outgoing tunnel interfaces.
·         Condition: This symptom occurs after the ADWAN controller deploys SR-TE settings and traffic is redirected to a specific tunnel as scheduled by SR-TE.
·         Workaround: This is a route display issue and does not affect traffic engineering.
202205121131
·         Symptom: IPv6 NetStream for an SRv6 TE policy collects only one ping packet.
·         Condition: This symptom occurs if ping packets are forwarded through an SRv6 TE policy tunnel and IPv6 NetStream is enabled for SRv6 TE policies.
·         Workaround: This issue only affects NetStream statistics in SRv6 TE scenario. Avoid enabling NetStream statistics for SRv6 TE policies.
202204260470
·         Symptom: XGE interfaces are used for IRF fabric setup. If you insert 1000-Mbps transceiver modules into the interfaces and change the speed to 1000 Mbps and then use them for IRF fabric setup, IRF fabric setup fails after the devices are rebooted.
·         Condition: This symptom occurs if the following operations are performed:
¡  IRF fabric setup is supported.
¡  XGE interfaces support autonegotiation, and 1000-Mbps transceiver modules are inserted into the interfaces.
¡  The speed is changed to 1000 Mbps for these interfaces, and then these interfaces are bound to IRF ports.
·         Workaround: Use GE interfaces for IRF setup, or configure the XGE interfaces for IRF fabric setup to operate at 10000 Mbps.
202303230501
·         Symptom: An EMMC error occurs on the USB chip of an MSR3600G device and the device fails to save the configuration.
·         Condition: This symptom might occur if the device is powered on and powered off repeatedly.
·         Workaround: Power cycle the device.
202302161095
·         Symptom: The IS-IS neighbors of a Layer 3 Ethernet subinterface do not come up.
·         Condition: This symptom might occur if you perform the following tasks on a distributed device:
a.    Configure a MAC address for an interface.
b.    Remove the MAC address configuration from the interface.
·         Workaround: Do not change the MAC address of an interface if the interface has a Layer 3 Ethernet subinterface that runs IS-IS.
For resolved problem lists of version R0809P22 and earlier for different device models, see the following documents:
202209211027
·         Symptom: The browser prompts that the website cannot provide a secure connection when you log in to the SSL VPN gateway.
·         Condition: This symptom occurs if you perform the following operations:
¡  Roll back the certificate configuration of the SSL VPN gateway to the initial configuration.
¡  Save the running configuration and restart the SSL VPN gateway.
¡  Roll back to the original certificate configuration.
¡  Enable an SSL VPN context for the SSL VPN gateway.
¡  Log in to the SSL VPN gateway.
202110120447
202209091543
·         Symptom: Failed to install a patch through the controller because the xmlcfgd process is locked.
·         Condition: This symptom occurs when you install a patch through the controller.
202211150166
·         Symptom: The svpnlang value in the cookie that is returned from https://218.61.255.153:2000/wnm/login/login.json has an XSS injection vulnerability of CVE-2022-35416 vulnerability.
·         Condition: None.
202302240115
·         Symptom: The peak traffic statistics are inaccurate for fixed interfaces on SPU300-G modules.
·         Condition: This symptom occurs if the fixed interfaces on SPU300-G modules receive and send traffic and you view the statistics.
202302160660
·         Symptom: An interface module on an MSR56G router cannot start up.
·         Condition: This symptom occurs if you save the configuration (including NAT) and restart the router.
202302270304
·         Symptom: After MSR3640X1, MSR3620X1, MSR3640X1HI, or MSR56 router starts up with the initial configuration, the BFD process occupies a large amount of memory.
·         Condition: This symptom occurs if the router is upgraded to R6728P24 and restarted with the initial configuration.
202301120184
·         Symptom: The IKED process is abnormal and the forwarding card restarts unexpectedly.
·         Condition: This symptom occurs occasionally if the device runs for a long period of time with IPsec and DPD configured.
202303150164
·         Symptom: Some interfaces on an SPU300G module fail to send packets.
·         Condition: This symptom might occur if you configure a QoS rate limit on an interface on the SPU300G module and the interface receives excess traffic.
202303281759
·         Symptom: The memory resources used by OSPF are increasing, because OSPF has been running for a long time and some interfaces flap frequently.
·         Condition: This symptom might occur if the device runs OSPF for a long time and some interfaces flap frequently.
202207281593
·         Symptom: The device repeatedly prints “Deadloop detected on cpu 0 core 1” and the traffic is interrupted.
·         Condition: Directly configure the NAT server with NO-PAT.
202207040294
·         Symptom: The Web and Cloud-Net interfaces are stuck, and the Web interface times out and exits after a period of time.
·         Condition: Obtain the device logs at the CLI.
202208300351
·         Symptom: The CPU usage of the device will become high irregularly.
·         Condition: When SNMP reads the device CPU usage, replace the real-time MIB node with the MIB node at the five minutes interval.
202209220712
·         Symptom: The SSLVPN certificate authentication failed.
·         Condition: Restart the SSLVPN process to resolve this issue.
202211171839
·         Symptom: The MSR3600G reports a temperature alarm when its temperature is in the normal range.
·         Condition: This symptom occurs with a low probability when the device is operating correctly.
202208191102
·         Symptom: The virtual IP address of the VRRP group is not reachable if the aggregate interface on the MSR3620-X1 has multiple member ports.
·         Condition: This symptom occurs if the Layer 3 aggregate interface has multiple member ports, and is enabled with VRRP.
202210110714
·         Symptom: Removal of a SIC-5G subcard is not reported to the controller. Normal event will not be reported to the controller for subcard removal.
·         Condition: This symptom occurs if the device is incorporated by the controller and a SIC-5G subcard is hot swapped.
202211100976
·         Symptom: An MSR 5600 router fails to forward NAT traffic because the primary traffic processing slot of a subinterface is incorrect.
·         Condition: This symptom occurs if both IRF and outbound NAT are configured.
202209291164
·         Symptom: When IPCP NAK packets with the IPv4 option as all-zeros are received, the pppd process gets stuck in an infinite loop.
·         Condition: This symptom occurs if the device receives invalid IPCP NAK packets (with the IPv4 option as all-zeros).
202210241602
·         Symptom: The packets processed by RIR on the VSI inbound interface are encrypted and then processed in one core, the aging is slow in the RIR forwarding cache. When a large amount of traffic exists for a long period of time, the memory usage is high.
·         Condition: This symptom occurs if packets processed by RIR on the VSI inbound interface.
202211140193
·         Symptom: After a branch site is added to the network of the ADWAN solution, RIR link selection from the headquarters to the site is incorrect. Link selection is as expected after you configure the tunnel out-interface command again.
·         Condition: This symptom occurs if you add a new site to the network of the ADWAN solution configured with RIR link selection.
202208191342
·         Symptom: The memory is exhausted after a GM card is removed while IPsec traffic is present.
·         Condition: This symptom occurs if the IPsec tunnel uses the SM4+SM3 algorithm combination.
202208101089
·         Symptom: The CPU usage is 100% for a long time.
·         Condition: This symptom occurs if you obtain the device configuration through the controller or through NETCONF.
202207211628
·         Symptom: The APR feature cannot work correctly.
·         Condition: This symptom occurs if one of the following operations is performed:
¡  Automatic update for the APR signature library.
¡  Manual update for the APR signature library.
¡  Rolling back the APR signature library.
202207210949
·         Symptom: The device reboots after an HMIM-8GSWF card is removed or rebooted while traffic is present.
·         Condition: This symptom occurs if an HMIM-8GSWF card is removed or rebooted while traffic is present.
202207130227
·         Symptom: BGP neighbors flap frequently.
·         Condition: This symptom occurs if BGP establishes a large number of neighbors by using ADVPN tunnel addresses in a spine-leaf network.
202208231254
·         Symptom: When acting as a Telnet server, the device reports the Failed to connect to the remote host error message during a redirection operation.
·         Condition: This symptom occurs if you execute the telnet server acl command before enabling redirection.
202205121202
·         Symptom: The configuration fails to be saved on an MSR5680 router.
·         Condition: This symptom occurs if you log in to the router through SSH and execute the fixdisk command.
202208181743
·         Symptom: The serial number of the new subcard obtained through NETCONF is the serial number of the old subcard before replacement.
·         Condition: This symptom occurs after you replace a subcard with another subcard on an MSR router.
202207190168
·         Symptom: The MSR3600X devices report the MBUF block alarm after they form an IRF fabric.
·         Condition: This symptom might occur if the MSR3600X devices use Layer 2 interfaces with IDs larger than G0/3 as IRF physical interfaces and they receive packets of a fixed length.
202206291293
·         Symptom: A primary private FIB route becomes a blackhole route.
·         Condition: This symptom might occur if the ingress node in an L3VPN over SRv6 BE network has TI-LFA backup configured.
202209020121
·         Symptom: In SDWAN mode, SNMPv3 connection failed.
·         Condition: This symptom might occur if two IRF member devices have different snmpboots values after a master/subordinate switchover.
202206240760
·         Symptom: A TTY loses shell settings after an asynchronous serial port switches from flow mode to protocol mode and then to flow mode again.
·         Condition: This symptom might occur if an asynchronous serial port switches from flow mode to protocol mode and then to flow mode again.
202206281099
·         Symptom: An IRF member device reports the RBAC registration alarm after startup.
·         Condition: This symptom might occur if an IRF member device starts up.
202206090402
·         Symptom: An internal error occurs after a Chinese operator library file is imported on the Web interface.
·         Condition: This symptom might occur if a Chinese operator library file is imported on the multi-WAN configuration page.
202205311764
·         Symptom: The CVE-1999-0524 vulnerability exists.
·         Condition: This symptom occurs when you scan the system for vulnerabilities.
202205190739
·         Symptom: Establishment of RIR NQA detection fails.
·         Condition: This symptom might occur if IRF member devices reboot and the traffic outgoing interface for a tunnel is on the subordinate device.
202205201580
·         Symptom: An IRF master reboots unexpectedly.
·         Condition: This symptom might occur if the device is in an ADWAN environment and traffic is scheduled by RIR after the device is powered on.
202204270732
·         Symptom: IRF member devices reboot unexpectedly.
·         Condition: This symptom might occur if last hop holding is enabled on the devices and FTP traffic is forwarded across the IRF master and subordinate devices.
202205181795
·         Symptom: BGP connections are disrupted because of memory exhaustion.
·         Condition: This symptom might occur if BGP routs are recurve to FRR routes and BGP route flapping occurs frequently.
202205121082
·         Symptom: The GE0/0 and GE0/5 interfaces operate in Layer 2 mode by default on the MSR1002X 4 device.
·         Condition: This symptom might occur if the device boots with initial configuration or the default command has been executed on the interfaces.
202106111031
·         Symptom: Aggregation member ports become Selected slowly, and the Selected states of aggregation member ports are different on both ends of an aggregate link. As a result, VRRP advertisements are dropped during a period of time, and the VRRP state becomes abnormal.
·         Condition: This symptom occurs if you frequently add member ports to and remove member ports from an aggregate interface.
202205300240
·         Symptom: When a cable is repeatedly plugged/unplugged for a port, the LED for the port is always on, and the port is physically down.
·         Condition: This symptom occurs if a cable is repeatedly plugged/unplugged for a port.
202205191789
·         Symptom: Both the RTA client and server are configured with multiple VTY virtual terminals. The minimum VTY virtual terminal number on the server is not applied to the interface on the client, another VTY virtual terminal number on the server is applied to the client interface, and a connection is triggered. The server will generate a core file.
·         The minimum VTY virtual terminal number on the server is not applied to the interface on the client, another VTY virtual terminal number on the server is applied to the client interface, and a connection is triggered.
202205190464
·         Symptom: The whole MSR56 router is rebooted repeatedly. After the cards are started, the Remove button might not take effect.
·         Condition: This symptom occurs if the cards are not initialized within 120 seconds and the function of shielding the button is not enabled.
202205181709
·         Symptom: In synchronous serial port mode, when NRZI is configured on serial ports of both ends, the serial ports cannot ping each other.
·         Condition: This symptom occurs if you configure NRZI in synchronous serial port mode.
202203050553
·         Symptom: When IPsec, NAT, and IPsec No NAT are all enabled on an outgoing interface on the device, a tunnel can be established normally. However, NAT translation is not first performed for the backward IPSec traffic, and the backward traffic cannot be forwarded.
·         Condition: This symptom occurs if IPsec, NAT, and IPsec No NAT are all enabled on an outgoing interface on the device and bidirectional traffic is injected.
202203231723
·         Symptom: The per-IP, per-TCP port number, and per-UDP port number connection count limit settings configured from the Web interface do not take effect.
·         Condition: This symptom occurs after you configure per-IP, per-TCP port number, and per-UDP port number connection limit settings from the Web interface.
202204281309
·         Symptom: An MSR 1004S-5G router fails to load the new configuration file but restores to the factory-default settings.
·         Condition: This symptom might occur after you perform the following operations:
a.    Press the reset button on the router to restore factory-default settings.
b.    Save new configuration and reboot the router.
202204121481
·         Symptom: The GNSS LED on an MSR 1004S-5G router might not turn on after the router starts up. and the display cellular command might not display GNSS latitude and longitude information.
·         Condition: This symptom might occur after an MSR 1004S-5G router starts up.
202202110203
·         Symptom: Failed to log in to the device through Telnet or SSH.
·         Condition: This symptom occurs if the following conditions exist:
¡  You have logged in to the device through a VTY line.
¡  A large number of abnormal exits occur to the processes in the preceding login. As a result, the line in the dbm cannot be released.
202203170154
·         Symptom: A interface module reboots when the display hardware internal dump Ten-GigabitEthernet 2/2/0 chip 2 global is executed in probe view.
·         Condition: This symptom occurs on an MSR 56-60 router installed with an HMIM-4XP module.
202202240545
·         Symptom: Entering any command in SSL VPN policy group view causes the CLI to return to the system view.
·         Condition: This symptom occurs on devices that use the IPE files 36x1.ipe or 36hi.ipe.
202203281236
·         Symptom: The device reboots after it receives traffic
·         Condition: This symptom occurs if EoGRE over IPsec is configured and the output interface of the traffic is a 5G wireless interface.
202202250466
·         Symptom: On a basic multicast network, configure ambiguous VLAN termination on IGMP-enabled subinterfaces on the multicast group side. The captured packets carry only one layer of VLAN tags, which should carry two layers of VLAN tags.
·         Condition: This symptom occurs if ambiguous VLAN termination is configured on IGMP-enabled subinterfaces on the multicast group side of a basic multicast network.
202111301472
·         Symptom: On an ADWAN hub-spoke network, an incoming LAN interface is a cross-card aggregate interface. When you switch the traffic processing slot for the aggregate interface, the controller deletes the application group configuration (flow ID-related configuration). If you view the RIR sessions of the flow ID when traffic is not stopped, the sessions still exist, and session statistics exist in the display tunnel flow-statistics command output.
·         Condition: This symptom occurs if the following conditions exist on an ADWAN hub-spoke network:
¡  An incoming LAN interface is a cross-card aggregate interface.
¡  When you switch the traffic processing slot for the aggregate interface, the controller deletes the application group configuration (flow ID-related configuration).
¡  View the RIR sessions of the flow ID when traffic is not stopped.
202201120647
·         Symptom: The device cannot perform per-packet load sharing for fragments of large packets.
·         Condition: This symptom occurs if you enable RIR per-packet load sharing in an ADWAN dual-gateway scenario.
202202240385
·         Symptom: More than 50 L2TP tunnels based on VLAN subinterfaces are configured on the device, and traffic is injected. After a period of time, the traffic statistics of VLAN interfaces read from MIBs are larger than the actual statistics.
·         Condition: This symptom occurs if more than 50 L2TP tunnels based on VLAN subinterfaces are configured on the device and traffic is injected for a period of time.
202202110645
·         Symptom: In the ADVPN environment, the actual outgoing interface of packets is a public network interface not bound to a VPN instance, and the ADVPN tunnel interface is bound to a VPN instance. IKE negotiation fails in phase 2, and IPsec SAs cannot be negotiated.
¡  In the ADVPN environment, the actual outgoing interface of packets is a public network interface not bound to a VPN instance.
¡  The ADVPN tunnel interface is bound to a VPN instance.
202111090191
·         Symptom: Integrity is not checked for an IPsec policy template. Nodes with smaller serial numbers are preferentially matched. If the configuration of a policy template with a small serial number is empty, IPsec SA negotiation fails.
·         Condition: This symptom occurs if the configuration of an IPsec policy template with a small serial number is empty.
202203110956
·         Symptom: The built-in RM500QGL module on the MSR1004S-5G router has a 5% probability of being not recognized when the router is operating correctly.
·         Condition: This symptom occurs with a probability when the MSR1004S-5G router is operating correctly.
202201200280
·         Symptom: The NQA process might reboot unexpectedly with an extremely low probability.
a.          An NQA operation with the saving of history records enabled has started and is running.
b.         For the NQA operation, use the NMS to frequently deploy the following get operations (including get, get-next, and get-bulk):
-      pingProbeHistoryTable for an ICMP echo operation.
-      traceRouteProbeHistoryTable/traceRouteHopsTable for a UDP tracert operation.
202112240749
·         Symptom: The traffic rate statistics cannot be collected.
·         Condition: This symptom occurs if you view the traffic rate statistics of PPPoE users on the user traffic ranking page.
202112240315
·         Symptom: The CPU usage of the MPU is high. As a result, the IPsec and BGP services cannot be established for a long period of time.
¡  The device uses an MPU100-X1 MPU and is deployed on an ADWAN branch network.
¡  The hubs are upgraded when a large number of branches exist.
202112220555
·         Symptom: The pppd process is abnormal and generates a core file.
·         Condition: This symptom occurs if the static VA pool is repeatedly created and deleted when a large number of L2TP users repeatedly come online and go offline.
202112160087
·         Symptom: Traffic fails to be forwarded.
·         Condition: This symptom occurs if IP source guard is enabled on interfaces of an MSR3600-28-X1/3600-51-X1 device.
202111261458
·         Symptom: After the connection state of an SRv6 policy changes, the gRPC server does not obtain related state change information.
·         Condition: This symptom occurs if the device is connected to a gRPC server and the connection state of an SRv6 policy is changed on the device.
202202240545
·         Symptom: When you enter SSL VPN policy group view and execute a command available in this view, the system automatically returns to the system view and the command fails to be executed.
·         Condition: This symptom occurs if you enter SSL VPN policy group view and execute a command available in this view.
202201101361
·         Symptom: When a GE 0/5 interface on the MSR1004 device connects to a 10-GE interface on the MSR56 device, the local interface on the MSR1004 device is up and the peer is down.
·         Condition: This symptom occurs if a GE 0/5 interface on the MSR1004 device connects to a 10-GE interface on the MSR56 device.
202110190485
·         Symptom: Traffic not matching an IPsec SA is encrypted by IPsec.
·         Condition: This symptom occurs if you configure an IPsec tunnel in SVTI mode, specify an ACL at one end of the tunnel, and do not specify an ACL at the other end of the tunnel, and then inject traffic to the end that does not specify an ACL.
202110221173
·         Symptom: The CPU usage is high after mLDP-based MVPN is configured.
·         Condition: This symptom occurs if mLDP-based MVPN is configured.
202108110448
·         Symptom: An SVTI tunnel interface that references an ACL cannot be up.
·         Condition: This symptom occurs if you configure an SVTI tunnel and specify an ACL for it.
202108171536
·         Symptom: After you configure traffic-directing settings in SR-MPLS TE policy and then roll back a configuration file without these settings, the traffic-directing settings are still effective.
·         Condition: This symptom might occur when configure traffic-directing settings in SR-MPLS TE policy and then roll back a configuration file without these settings.
202108171791
·         Symptom: Traffic is still forwarded through the original SRv6-TE policy tunnel even after you use the remark service-class command to remark the service class for the traffic tunnel in a QoS policy.
·         Condition: This symptom might occur if the traffic is forwarded through SRv6-TE policy CBTS, and then you use the remark service-class command to remark the service class for the traffic tunnel in a QoS policy.
202108200478
·         Symptom: After you configure an IPv6 IPsec policy with the policy name the same as that of an IPsec policy, the subsequent IPv6 IPsec policy settings can take effect but not build run, and the settings are lost after a device reboot even if they are saved before the reboot.
·         Condition: This symptom occurs if you configure an IPv6 IPsec policy whose name contains the name of an IPsec policy, then configure other settings for the IPv6 IPsec policy, save the settings, and then reboot the device.
202107290522
·    Symptom: Interfaces on both ends of a PPP link repeatedly flap.
·    Condition: This symptom occurs if an MP bundle is configured through an MP-group interface on an E1 or POS card and the MP-group interface on one end is shut down or deleted.
202107080664
·    Symptom: There is residual IKE SA configuration on the hub after the spoke is restarted.
·    Condition: This symptom occurs if you restart a spoke device in an ADVPN that uses the full-mesh networking mode.
202106070526
·         Symptom: The device requests a PKI certificate from a server after it synchronizes the system time by using NTP. The server returns an error because it has issued a certificate to the device.
¡  The device does not have an RTC device and restores its system time to year 2011 upon each startup.
¡  The device requests a PKI certificate from the server after a startup.
¡  Because the device has not synchronized its time by using NTP, it has an incorrect system time and determines that the certificate issued from the server is not in the validity period and drops the certificate.
202104090941
·         Symptom: mGRE does not support IKEv2.
·         Condition: None.
202103310929
·         Symptom: Memory leaks occur after IPv6 NetStream is configured.
·         Condition: This symptom might occur if the device receives traffic after IPv6 NetStream is configured.
202102021358
·         Symptom: Traffic loss occurs when the router selects an output interface different from the one configured by using the tunnel out-interface command for the traffic forwarded over a VXLAN over TE tunnel.
·         Condition: This symptom might occur if the router selects an output interface different from the one configured by using the tunnel out-interface command for the traffic forwarded over a VXLAN over TE tunnel.
202102071217
·         Symptom: On the MSR3600-28 router, when a port range is assigned to a Layer 2 aggregation group, only the lowest numbered port is successfully assigned.
·         Condition: This symptom might occur if a port range is assigned to a Layer 2 aggregation group.
202102021242
·         Symptom: The HTTP/HTTPS remote login feature does not take effect when it is issued from the Web interface.
·         Condition: This symptom might occur if remote login is configured on the Web interface.
202101251358
·         Symptom: Users cannot access webpages on the Internet after outbound NAT is configured on the WAN interface.
·         Condition: This symptom occurs if WAAS is also configured in SD-WAN B04 version.
202101111482
·         Symptom: Device memory exhausts on the ingress of an MPLS TE tunnel.
·         Condition: This symptom occurs in an SDWAN industry B06 scenario where OSPF is used to direct traffic to the MPLS TE tunnel and OSPF route flapping occurs repeatedly.
202101071839
·         Symptom: In the SD-WAN branch B04 solution scenario, RIR settings such as link types and sequence numbers fail to be issued.
·         Condition: This symptom might occur when you issue RIR settings upon a link switchover after you delete the configured RIR settings.
202101151300
·         Symptom: In the SD-WAN branch B04 solution scenario, the RIR flow priority-based traffic scheduling settings are lost.
·         Condition: This symptom might occur upon a link switchover after the controller issues the RIR flow priority-based traffic scheduling settings.
202101070004
·         Symptom: L2TP negotiation fails.
·         Condition: This symptom might occur if the offset bit is set in L2TP IPCP packets.
202012081289
·         Symptom: The device reboots after running for a long time because of memory exhaustion.
·         Condition: This symptom occurs if the SNMP module is configured to send trap messages to multiple servers with the address of the first server reachable but the address of the second server unreachable.
202009300258
·         Symptom: The IKE process is stuck and tunnel negotiations fail.
·         Condition: This symptom might occur in the following situation:
¡  IKE uses digital certificate authentication, and the certificate revocation checking method is configured as revocation-check method crl none.
¡  There are many IKE negotiations and the device cannot connect to the CRL repository server.
202009300258
·         Symptom: The IKE process is stuck and tunnel negotiation fails.
·         Condition: This symptom might occur if the following conditions exist:
202010100134
·         Symptom: Deadloops and unexpected forwarding module reboots might occur after session statistics collection is enabled.
·         Condition: This symptom might occur if DPI and session statistics collection are enabled and a large number of applications have application layer traffic.
202006290650
·         Symptom: The device reboots repeatedly because of memory exhaustion.
·         Condition: This symptom occurs if a large number of packets are sent to port 6633.
202006100361
·         Symptom: An interface might fail to receive or send packets with a low probability, which will cause traffic forwarding failure.
·         Condition: This symptom occurs if a device with an HMIM-4GEE or HMIM-4GEF card is upgraded to version R0809 and the peer device is not restarted.
202005190442
·         Symptom: The username checking feature cannot be disabled by the undo password-control complexity user-name check command.
·         Condition: This symptom occurs if you execute the undo password-control complexity user-name check command in local user view or user group view.
201912131149
·         Symptom: Ping failure or service exception exists for ping or service packets (for example, Telnet or DDNS) sourced from the local device.
·         Condition: This symptom might occur if dual WAN links are available for the packets.
202005061081
·         Symptom: The IKE process cannot be started because of failure to bind default port 500 to IKE.
·         Condition: This symptom occurs if you configure IKE when port 500 is occupied by using the nqa server udp-echo x.x.x.x 500 command.
202004130473
·         Symptom: IPsec negotiation failed.
·         Condition: This symptom occurs if the SM4 encryption algorithm is specified for phase 2 IPsec negotiation and the initiator carries the key length of 128 bits for the phase 2 negotiation.
201911060873
·         Symptom: The interface bandwidth usage in the display interface command output is incorrect.
·         Condition: This symptom occurs if the following devices forward a large amount of traffic:
¡  Devices and cards with Layer 2 interfaces.
¡  Devices using 32-bit CPU, including MSR8XX series, MSR9XX series, ICG2000D/MSR2600 series, MSR3600 series, MSR100X series, and MSR2630.
¡  GE 0/6 through GE 0/9 on an SPU100-X1 card.
¡  GE 0/1 through GE 0/9 on an SPU200/400-X1 card.
201911290115
·         Condition: This symptom occurs if the following interfaces forward a large amount of traffic:
¡  Interfaces on devices and cards with Layer 2 interfaces.
¡  Interfaces on devices using 32-bit CPU, including MSR8XX series, MSR9XX series, ICG2000D, MSR2600 series, MSR3600 series, MSR100X series, and MSR2630.
¡  GE 0/6 through GE 0/9 on SPU100-X1.
¡  GE 0/1 through GE 0/9 on SPU200/400-X1.
202001100481
·         Symptom: IKE negotiation failed.
Condition: This symptom occurs when IKE uses the digital certificate for identity authentication and uses DN in the certificate as the local identity, and the subject field in the certificate exceeds 256 characters.
202003041116
·         Symptom: A QoS policy containing a traffic policing action does not take effect on an aggregate interface.
·         Condition: This symptom occurs if there is traffic on the aggregate subinterfaces instead of the aggregate interface and you apply the QoS policy to the aggregate interface.
202003190408
·         Symptom: Cannot create an IPsec policy in the Web interface. An error message prompts that the configuration object does not exist.
·         Condition: This symptom occurs after the device is restored to factory defaults.
202003130974
·         Symptom: The renegotiation initiated by the local device failed.
·         Condition: This symptom occurs when an IPsec tunnel is established between two IPsec gateways and you modify different IPsec policy entries of the same IPsec policy.
202003191478
·         Symptom: The IKE process exited exceptionally, and memory overlap occurs.
·         Condition: This symptom occurs if you execute the reset advpn session command or the reset vam client fsm command when CRL checking is enabled.
Resolved problems in CMW710-R0707P24
201911060979
·         Symptom: The source IP address or destination network segment address configuration is displayed as a host address in the Web interface.
·         Condition: This symptom occurs if the following operations are performed on the authentication-free IP address page in the Web interface:
a.    Configure a description.
b.    Set the source IP address or destination network segment address.
201910310870
·         Symptom: The server IP address cannot be modified.
·         Condition: This symptom might occur if you select both the check box for modifying server address and the check box for modifying the service provider on the advanced options page.
201910250289
·         Symptom: Configuration import operation might fail.
·         Condition: This symptom might occur if the device has multiple storage media and you use the Web interface to import the configuration file.
201910241082
·         Symptom: The Delete button to the right of a user group member does not take effect.
·         Condition: This symptom might occur when you add or edit a user group on the Network Behaviors > User Group Configuration page.
201910240455
·         Symptom: The IP address information is not displayed on the interface speed page or WAN configuration page.
·         Condition: This symptom occurs if a Layer 3 WAN interface is configured to obtain an IP address through DHCP or PPPoE in the Web interface.
201910230726
·         Symptom: The network behavior management feature is disabled.
·         Condition: This symptom might occur if you specify the same string in different cases as the names for policies on the Web application control page.
201910230699
·         Symptom: Cannot create a policy on the URL filtering page.
·         Condition: This symptom might occur if you specify a policy name that starts with an upper-case letter.
201910150870
·         Symptom: The later added IKE keychain will overwrite the previously added IKE keychain. As a result, only one IKE keychain exists on the device, and the IPsec tunnel might fail to be established.
·         Condition: This symptom occurs if IPsec policies with the same letters of different cases in their names are added in order.
201910141007
·         Symptom: The system fails to read the user information during user information modification.
·         Condition: This symptom might occur when you modify a user on the Web user management page.
201910211052
·         Symptom: Some configurations for AP templates of models WA2620-WiNet and WA2620E-WiNet get lost after you upgrade the AC from R0615PXX to R0707P21 because templates of the two models do not support the vlan1 command.
·         Condition: This symptom might occur if you upgrade the AC from R0615PXX to R0707P21 and the vlan1 command has been executed for AP templates of the two models.
202002130717
·         Symptom: A device reboots unexpectedly.
·         Condition: This symptom occurs with a low probability if a multi-core device forwards multiple flows in a VXLAN/EVI environment.
201912020343
·         Symptom: Before a user passes 802.1X authentication, the user cannot ping the configured EAD free IP.
·         Condition: This symptom occurs if you configure the EAD free IP function and then enable 802.1X authentication.
201912190196
·         Symptom: The SSH connection to the device is disconnected and core files are generated.
·         Condition: This symptom occurs if the password control function is enabled, an SSH user logs in to the device for the first time, and the user enters incorrect passwords multiple times.
201912260565
·         Symptom: LSAs remain in an OSPF NSSA area because of time sequence problems.
·         Condition: This symptom occurs with a low probability if the device and its neighbor repeatedly enable and disable redistribution for the same routes.
201911291010
·         Symptom: The memory of the device is lost.
·         Condition: This symptom occurs if DPI is enabled on the device, two PCs share and access files across slots or chassis, and the device forwards SMB2 packets.
Resolved problems in CMW710-R0707P21
201911060528
·         Symptom: The switch reboots because of memory exhaustion.
·         Condition: This symptom occurs if the switch forwards traffic for a long time when application statistics collection or session statistics collection is enabled.
201908300153
·         Symptom: A server returned an HTTPS authentication failure report during TACACS authentication.
·         Condition: This symptom might occur when the rem_addr field of the authentication request does not carry the terminal IP address but a server identifies the processing policy based on the field.
201907190401
·         Symptom: CFD does not take effect.
·         Condition: This symptom occurs if CFD is configured on the device and then the device is rebooted.
201907300197
·         Symptom: An error is reported during the operating system installation on VMs.
·         Condition: This symptom occurs if the operating system is installed in the same disk on two VMs.
201909240203
·         Symptom: The IP addresses are not displayed on the IP address list page.
·         Condition: This symptom occurs if multiple WAN interfaces obtain IP addresses through DHCP and PPPoE links.
Resolved problems in CMW710-R0707P19
201907040419
·         Symptom: Traffic from some addresses might be switched to the backup link when the primary link works correctly.
·         Condition: This symptom might occur in an MPLS L3VPN FRR scenario.
201905300255
·         Symptom: Cannot add IPsec protected data flows in the ACL for an IPsec policy. The Add button does not take effect.
·         Condition: This symptom occurs when you configure an ACL to add IPsec protected data flows on the New IPsec Policy page for IPsec VPN.
201906240172
·    Symptom: The memory leaks.
·    Condition: This symptom occurs if the info-center syslog trap buffersize 65535 command is executed and the device runs for a long period of time.
201906120398
·    Symptom: ADVPNs fail to be established.
·    Condition: This symptom occurs if multiple spokes use different addresses and ports to register ADVPN negotiation.
Resolved problems in CMW710-R0707P16
201705120372
·    Symptom: Tracert fails for failure to respond to ICMP error messages if the ip unreachables enable or ip ttl-expires enable command was executed 50 days ago.
·    Condition: This symptom occurs if the ip unreachables enable or ip ttl-expires enable command was executed 50 days ago.
201902260252
·    Symptom: After the cable type is set to 75 ohm for interfaces on some E1 interface cards, the configuration cannot be cancelled.
·    Condition: This symptom occurs if the undo form of the command is executed.
201906100675
·    Symptom: The hardware resources are insufficient when a QoS policy is applied.
·    Condition: This symptom occurs if a QoS policy is applied to an interface.
201905230062
·    Symptom: The TACACS server cannot recover from the Block status.
·    Condition: This symptom occurs if active/standby switchover occurs on the device.
201905220166
·    Symptom: Static route configuration is lost.
·    Condition: This symptom occurs if the route configuration contains interfaces and descriptions, and the IRF mode is switched.
201905230358
·    Symptom: Errors occur to LLDP initialization.
·    Condition: This symptom occurs if the subordinate member device of an IRF fabric is rebooted.
201905230130
·    Symptom: The link aggregation module operates abnormally.
·    Condition: This symptom occurs if links flap.
201905280875
·    Symptom: The VSI names cannot be obtained from MIB nodes.
·    Condition: This symptom occurs if the device is configured with both cross-connect groups and VSIs, and cross-connect groups are configured with AC interfaces.
201905230155
·    Symptom: Telnet users remain.
·    Condition: This symptom occurs if users repeatedly Telnet to the device through different terminals.
201905200886
·    Symptom: The device cannot properly forward packets.
·    Condition: This symptom occurs if the device is configured with the vpn popgo command.
201906050532
·         Symptom: After a Telnet user locks the user line and disconnects the connection, the Comsh process remains and the CPU usage gets very high.
·         Condition: This symptom occurs if a user Telnets to the device and then press Ctrl+C (specified as the user line locking key) to lock the user line.
201906270092
·         Symptom: The CLI gets stuck after the display port-security command is executed and you have to press Ctrl+C to abort the command execution.
·         Condition: This symptom occurs if the following operations are performed on the device:
a.          Enable port security, configure secure MAC addresses, set the port security's limit on the number of MAC addresses to 1, and set the intrusion protection mode to disableport-temporarily.
b.         Log in to the device from another PC and execute the display port-security command to display port security configuration, operation information, and statistics.
201812070155
·         Symptom: Some UDP packets get lost.
·         Condition: This symptom occurs if the UDP packets are fragmented and the third and fourth bytes following the IP header of a fragment are 0D AF (3503).
201809300368
·         Symptom: The memory allocated to some service modules (such as NetStream and QoS) leaks.
·         Condition: This symptom occurs with a low probability if the service modules use fast forwarding entries for service processing.
201808080160
·         Symptom: The device cannot calculate IS-IS routes correctly.
·         Condition: This symptom occurs if IS-IS PIC is enabled on the device, NSF IETF is enabled on the peer device, and the peer device reboots or a port on the device flaps.
201811230277
·         Symptom: The configuration modified in the Web interface gets lost after the device reboots.
·         Condition: This symptom occurs if the configuration is modified in the Web interface and the configuration is not saved before the device reboots.
201812070175
·         Symptom: The device fails to restart up from a .cfg configuration file.
·         Condition: This symptom occurs if the .cfg configuration file includes an ACL which is specified with ten thousands of object groups and each of the object groups contains an IP address object with a host name.
201810250059
·         Symptom: IMC generates a configuration failure message after it deploys a duplicated configuration to the device.
·         Condition: This symptom occurs if IMC deploys a duplicated configuration to the device.
201808070708
·         Symptom: An MSR router becomes abnormal.
·         Condition: This symptom occurs if both NAT and object groups are configured on the MSR router.
201806120670
·         Symptom: When you modify the route preference of a 4G interface in the Web interface, the system prompts that the next hop is invalid.
·          Condition: None.
201805230764
·         Symptom: NetStream entry statistics are incorrect.
·         Condition: This symptom occurs if both NetStream and NAT are enabled on an interface.
201805300014
·         Symptom: CVE-2016-9586
·         Condition: Haxx curl and libcurl of versions 7.1 through 7.51.0 are vulnerable to a buffer overflow. The vulnerability happens because the program does not well perform the boundary checks for data input by users. An attacker can exploit this vulnerability to execute arbitrary codes in the context of the affected program.
201803130414
·         Symptom: The device reboots unexpectedly.
·         Condition: This symptom occurs if NAT ALG is enabled on the device, and abnormal SIP packets pass through the device, which causes the memory access exceptions.
201804091102
·         Symptom: A VRF route does not exist on the device.
·         Condition: This symptom occurs if a VRF route of a BGP entity is inserted into another VPN through matching an IRT in the VPN. The system prompts that the VRF route is successfully inserted. In fact, the VRF route does not exist.
201802020849
·         Symptom: IPsec SA negotiation fails. The system prompts that the number of IKE SA being negotiated reaches the threshold.
·         Condition: This symptom might occur when a large number of IPsec SAs are negotiated.
201801090571
·         Symptom: The SSH session is not released correctly.
a.          Enable password aging.
b.         Log in to the device through SSH, and modify the password.
c.          Log in to the device again. The system prompts that the password is to expire and prompts the user to modify the password. Perform no operation in this case.
201711300317
·         Symptom: The LDP process exits unexpectedly.
·         Condition: This symptom occurs if the device is connected to a Cisco device, and the TLVs received from the Cisco device cannot be recognized.
201906120398
·         Workaround: None. To be resolved in the later version.
201905230062
201905220166
201905230130
201905230155
201905200886
201809060320
·         Symptom: MPLS traffic forwarding fails when frequent MPLS LDP flapping occurs.
·         Condition: This symptom might occur if frequent MPLS LDP flapping occurs.
201808080157
·         Symptom: The router is connected to a Cisco device configured with NSF IETF, and IS-IS PIC is enabled on the router. After the Cisco device is rebooted, route errors occur because the outgoing interface and next hop of some routes are not updated.
·         Condition: This symptom might occur if the IS-IS PIC-enabled router is connected to a Cisco device configured with NSF IETF, and the Cisco device is rebooted.
Troubleshooting resources
To obtain troubleshooting resources for the product:
1.       Select the device category and model.
2.       Select the Maintain or Maintenance menu.
Documentation set
·         H3C MSR 2600 Router Installation Quick Start(For MSR 26-30)
·         H3C MSR 3600 Routers Installation Quick Start(For MSR 36-10[20][40][60])
·         H3C MSR 3600 Routers Installation Quick Start(For MSR3600-28[28-SI][51][51-SI])
·         H3C MSR 3600 Routers Installation Quick Start(For MSR3620-DP)
·         H3C MSR3610-X1 Gigabit Ethernet Integrated Service Gateway Installation Quick Start
·         H3C MSR 5600 Routers Installation Quick Start(For MSR5620)
·         H3C MSR 5600 Routers Installation Quick Start (For MSR 56-60[80])
·         H3C MSR 2600 Routers Installation Guide
·         H3C MSR 3600 Routers Installation Guide
·         H3C MSR3610-I-DP[I-XS][IE-DP][IE-ES][IE-XS][IE-EAD] ICT Converged Gateway Installation Guide
·         H3C MSR 5600 Routers Installation Guide
·         H3C MSR810 Routers Installation Quick Start
·         H3C MSR810 Routers Installation Guide
·         H3C MSR830 Router Series Installation Guide
·         H3C MSR2600-6-X1-GL Gigabit Router Installation Guide
·         H3C MSR Router Series Comware 7 Interface Module Guide
·         H3C MSR810 2600 3600 Routers Configuration Guides(V7)
·         H3C MSR810 2600 3600 Routers Command References(V7)
·         H3C MSR 5600 Routers Configuration Guides(V7)
·         H3C MSR 5600 Routers Command References(V7)
·         H3C MSR600 Router Series Quick Start
·         H3C MSR600 Router Series Installation Guide
·         H3C MSR600 Router Series Hardware Information and Specifications
Obtaining documentation
Take the following steps to get related documents from the H3C website at www.h3c.com.
1.       Go to  https://www.h3c.com/
2.       Choose the desired product category and model.
Technical support
[email protected]
http://www.h3c.com
Appendix A Feature list
Hardware features
Table 14 MSR 26-30 specifications
Item
Console/AUX port
1
USB console port
1
USB port
1
Gigabit Ethernet port
2
Memory
1 GB DDR3
Internal CF card
256 MB
SIC/DSIC slot
3 SIC slots
(Slots 1 and 2 can be used for a DSIC interface module by removing the slot divider.)
Dimensions (H × W × D)
(excluding rubber feet and mounting brackets)
44.2 × 360 × 305.3 mm
AC power supply
Rated voltage range: 100 VAC to 240 VAC @ 50 Hz/60 Hz
Maximum power for AC power supply
54 W
Operating temperature
0°C to 45°C (32°F to 113°F)
Relative humidity
(noncondensing)
5% to 90%
Table 15 MSR 3600 specifications
Item
MSR 36-10
MSR 36-20
MSR 36-40
MSR 36-60
MSR3600-28
MSR3600-51
CON/AUX ports
1
1
1
1
1
1
USB console ports
1
1
1
1
N/A
N/A
USB ports
2
2
2
2
1
1
Gigabit Ethernet WAN ports
3
3
3
3
3
3
Gigabit Ethernet LAN ports
N/A
N/A
N/A
N/A
24
48
SFP port
1 (fiber port of the combo interface)
2 (fiber port of the combo interface)
1
N/A
SIC/DSIC slots
2 SIC slots
4 SIC slots/2 DSIC slots
4 (2 DSIC slots)
4 SIC slots
4 SIC slots
HMIM slots
1
2
4
6
N/A
N/A
VPM slots
1
1
2
2
N/A
N/A
Memory
2 GB DDR3
DDR3
·        2 GB (default)
·        4 GB (maximum)
DDR3
·        2 GB (default)
·        4 GB (maximum)
DDR3
·        2 GB (default)
·        4 GB (maximum)
1 GB DDR3
1 GB DDR3
Built-in CF card memory
256 MB
256 MB
256 MB
256 MB
256 MB
256 MB
External CF card memory
N/A
4 GB (maximum)
4 GB (maximum)
4 GB (maximum)
N/A
N/A
CF card slot
N/A
1
1
1
N/A
N/A
Dimensions (H × W × D) (excluding rubber feet and mounting brackets)
44.2 × 440 × 480 mm (1.74 × 17.32 × 18.90 in)
88.1 × 440 × 480 mm (3.47 × 17.32 × 18.90 in)
135 × 440 × 480 mm (5.32 × 17.32 × 18.90 in)
44.2 x 440 × 360 mm (1.74 x 17.32 x 14.17 in)
44.2 x 440 × 400 mm (1.74 x 17.32 x 15.75 in)
Power module slot
N/A
N/A
2 (Slot PWR1 can hold a PoE module.)
2 (Both the slots can hold a PoE module.)
N/A
2
AC power supply
DC power supply
Rated voltage range: 48 VDC to 60 VDC
N/A
Rated power for AC/DC power supply
125 W
125 W
AC: 300 W
AC: 300 W
54 W
150 W
Rated power for PoE power supply
Not supported
275 W
750 W
750 W
N/A
N/A
Rated power for each PoE port
15.4 W
15.4 W
15.4 W
15.4 W
N/A
N/A
RPS power
800 W
800 W
N/A
N/A
N/A
N/A
Relative humidity
(noncondensing)
5% RH to 95% RH
Table 16 MSR 5600 specifications
Item
MSR 56-60
MSR 56-80
MPU slot
2
SPU slot
1
HMIM slot
6
8
Dimensions (H × W × D), excluding rubber feet and mounting brackets
175.1 × 440 × 480 mm
219.5 × 440 × 480 mm
Power pluggable and buckup
N+1
N+1
Operating humidity (noncondensing)
5% RH to 95% RH
Table 17 MSR 56 MPU-100 Specification
Item
Specification
Console port
1
AUX port
1
GE management port
1
USB console port
1
USB port
1
Memory
·        2 GB DDR3 (default)
·        4 GB DDR3 (maximum)
CF card
·        512 MB (default)
·        4 GB (maximum)
CF card slot
1
Flash
8 MB
Table 18 MSR 56 SPU Specification
Item
SPU-100
SPU-200SPU-300
USB port
2
VPM slot
2
Combo
4
SFP+ port
0
1
Applicable router model
MSR 56-60/56-80
Applicable MPU
MPU-100
Table 19 MSR 36-40/36-60/56-60/56-80 AC power module specifications
Item
Specification
Model
PSR300-12A2
Rated input voltage range
100 VAC to 240 VAC @ 50 Hz or 60 Hz
Rated power
300 W
Table 20 MSR 36-40/36-60/56-60/56-80 DC power module specifications
Item
Specification
Model
PSR300-12D2
48 VDC to 60 VDC
Rated power
300 W
Table 21 MSR3600-51 AC power module specifications
Item
Specification
Rated power
150 W
Table 22 MSR3600-51 DC power module specifications
Item
Specification
48 VDC to 60 VDC
Rated power
150 W
Table 23 MSR 36-40/36-60/56-60/56-80 PoE power module specifications
Item
Specification
Model
PSR750-A
Rated power
·        300 W to the system
·        450 W to PDs
Table 24 MSR 3620-DP specifications
Item
MSR 3620-DP
CON/AUX ports
N/A
USB ports
1
4(Combo)
SFP ports
6 (four are fiber ports of the combo interfaces)
SIC/DSIC slots
4 SIC slots
HMIM slots
2
Memory
2GB DDR3
Flash
512MB
Micro SD
8GB
Micro SD slot
1
44.2 × 440 × 470 mm (1.74 × 17.32 × 18.50 in)
Power module slot
2
AC power supply
DC power supply
150W
Relative humidity
(noncondensing)
5% RH to 95% RH
Table 25 MSR 5620 specifications
Item
MSR 5620
MPU slot
2
SIC/DSIC slots
4 SIC slots
HMIM slot
2
USB ports
2
Combo ports
3
SFP+ ports
2
N+1
5% RH to 95% RH
Table 26 MSR 56 MPU-60 Specification
Item
Specification
Console port
1
GE management port
1
USB port
1
Memory
2GB DDR3
Micro SD
8 GB
Micro SD slot
1
Flash
512 MB
Table 27 MSR 3620-DP AC power module specifications
Item
Specification
Rated power
150 W
Table 28 MSR 5620 AC power module specifications
Item
Specification
Model
PSR300-12A2
Rated power
300 W
Table 29 MSR 3620-DP DC power module specifications
Item
Specification
48 VDC to 60 VDC
Rated power
150 W
Table 30 MSR 5620 DC power module specifications
Item
Specification
Model
PSR300-12D2
48 VDC to 60 VDC
Rated power
300 W
Table 31 MSR 5620 PoE power module specifications
Item
Specification
Model
PSR750-A
Rated power
·        450 W to PDs
Table 32 MSR2600 specifications
Item
MSR2600-6-X1/MSR2630-XS
MSR2600-10-X1
MSR2600-15-X1
Console/AUX port
N/A
1
N/A
Console port
1
N/A
1
USB port
1
1
1
GE copper port
5
10
13
GE fiber port
1
N/A
2
USB Bluetooth adapter
Supported only by the MSR2600-6-X1
Supported
Not supported
Reset button
1
1
1
Memory
1GB DDR3
1GB DDR3
1GB DDR3
Flash
256 MB
256 MB
512 MB
SIC slot
2
3
2
44.2 × 360 × 300 mm (1.74 × 14.17 × 11.81 in)
44.2 × 360 × 303.5 mm (1.74 × 14.17 × 11.95 in)
Rated AC voltage
100 to 240 VAC @ 50/60 Hz
Max power consumption
30 W
30 W
36 W
Storage temperature
40°C to +70°C (40°F to +158°F)
Humidity
5% RH to 95% RH, non-condensing
Table 33 MSR2600-10-X1 router specifications
Item
MSR2600-10-X1
Console/AUX port
1
USB port
1
GE WAN port
10
Reset button
1
Memory
1GB DDR3
Flash
256 MB
SIC slot
3 SIC slots
44.2×360×303.5mm (1.74 × 14.17 × 11.95 in)
AC power supply
Rated voltage range: 100 VAC to 240 VAC@50 to 60Hz
Rated power for AC power supply
30W
Relative humidity (non-condensing)
5% RH to 95% RH
Table 34 MSR810-10-PoE specifications
Item
MSR810-10-PoE
Console port
1
USB port
1
GE WAN port/GE SFP port
1GE+1Combo
GE LAN port
8
Memory
1 GB DDR3
Flash
256MB
44.2 × 330 × 230 mm (1.74 × 12.99 × 9.06 in)
AC power adapter
100 VAC to 240 VAC @ 50 to 60Hz
Max. AC power
20W+65W(PoE)
0°C to 40°C (32°F to 104°F)
5% RH to 90% RH
Table 35 MSR810-EI_ MSR810-LM-EA
Item
RT-MSR810-EI
RT-MSR810-LM-EA
Console port
1
1
USB port
1
1
GE WAN port
1
1
GE SFP port
1
1
Combo interface
N/A
N/A
GE LAN port
4
4
FE port
N/A
N/A
N/A
N/A
Micro SD card slot
N/A
N/A
Built-in 3G/4G module
N/A
TDD-LTE, FDD-LTE, WCDMA, HSPA+, GSM, EDGE
4G LET antenna port
N/A
2
WLAN antenna port
N/A
N/A
GPS antenna port
N/A
N/A
Memory
1 GB DDR3
1 GB DDR3
Flash
256 MB
256 MB
44 × 210 × 140 mm (1.73 × 8.27 × 5.51 in)
Input voltage
Power rating
8 W
10 W
PoE power
N/A
N/A
Operating humidity
5% RH to 90% RH, non-condensing
Table 36 MSR810 specifications
Item
MSR810
MSR810-W
MSR810-W-DB
MSR810-LM
MSR810-W-LM
Console port
1
USB port
2
2
2
1
1
GE WAN port
1
GE SFP port
1
GE LAN port
4
Memory
1 GB DDR3
Flash
256MB
43.6 × 266 × 161 mm (1.72 × 10.47 × 6.34 in)
AC power adapter
12V
Max. AC power
24W
5% RH to 90% RH
Table 37 MSR810-LME specifications
Item
MSR810-LME
Console port
1
USB port
1
FE port
4
4G LET antenna port
1
TDD-LTE, FDD-LTE, TD-SCDMA, UMTS, GSM, EVDO, CDMA1x, TDD-LTE, FDD-LTE, TD-SCDMA, UMTS, and GSM
Memory
1 GB DDR3
Flash
256MB
35 × 115 × 100 mm (1.38 × 4.53 × 3.94 in)
AC power adapter
Max. AC power
10W
0% RH to 95% RH
Table 38 MSR810-GL specifications
Item
MSR810-LM-GL
MSR810-W-LM-GL
Console port
1
1
USB port
1
1
GE WAN port
1
1
GE SFP port
1
1
GE LAN port
4
4
FE port
N/A
N/A
LTE, UMTS(WCDMA), HSDPA, HSUPA, HSPA+, DC-HSPA+, GSM, GPRS, EDGE, and GNSS
Memory
1 GB DDR3
1 GB DDR3
Flash
256 MB
256 MB
Input voltage
Max. input power
24 W
24 W
Operating humidity
Table 39 MSR830 specifications
Item
MSR830-6EI-GL
MSR830-10EI-GL
MSR830-6HI-GL
MSR830-10HI-GL
Console ports
1
1
1
1
USB ports
N/A
1
1
1
GE copper ports
6
10
6
10
SFP ports
N/A
N/A
1
1
Micro SD slots
N/A
N/A
1
1
Reset button
1
1
1
1
Memory
1GB DDR3
1GB DDR3
1GB DDR3
1GB DDR3
Flash
256 MB
256 MB
256 MB
256 MB
44 × 440 × 225 mm (1.73 × 17.32 × 8.86 in)
AC power adapter
Humidity
5% RH to 95% RH (noncondensing)
Table 40 MSR2600-6-X1-GL specifications
Item
MSR2600-6-X1-GL
Console port
1
USB port
1
GE copper port
5
GE fiber port
1
Reset button
1
Memory
1GB DDR3
Flash
256 MB
SIC slots
2
Rated AC voltage
30 W
Storage temperature
Humidity
Table 41 MSR3600-28-SI-GL specifications
Item
MSR3600-28-SI-GL
Console ports
1
USB ports
1
3
24
SFP ports
1
SIC/DSIC slots
4 SIC slots
Memory
512 MB DDR3
Flash memory
256 MB
43.6 × 440 × 360 mm (1.72 × 17.32 × 14.17 in)
AC power supply
Rated voltage range: 100 VAC to 240 VAC @ 50 Hz/60 Hz; 1.5A
30 W
Humidity
Table 42 MSR3610-X1 specifications
Item
MSR3610-X1
MSR3610-X1-DP
MSR3610-X1-DC
MSR3610-X1-DP-DC
Console port
1
1
1
1
USB port
1
1
1
1
GE port
4, including two copper combo ports
SFP port
2
2
2
2
Memory
2GB DDR3
2GB DDR3
2GB DDR3
2GB DDR3
Flash
512 MB
512 MB
512 MB
512 MB
Hard disk
1 (2.5 inch, SATA connectors)
N/A
N/A
Micro SD card slot
1
1
1
1
SIC slot
4
4
4
4
43.6 × 440× 360 mm (1.72 × 17.32 × 14.17 in)
AC power input
Single AC input
Dual AC inputs
N/A
N/A
DC power input
N/A
N/A
Single DC input
Dual DC inputs
Rated AC/DC voltage
100 VAC to 240 VAC @ 50 to 60 Hz
48 VDC to 60 VDC
48 VDC to 60 VDC
Rated AC/DC power
54 W
54 W
66 W
66 W
·        Without a hard disk: 0°C to 45°C (32°F to 113°F)
·        With a hard disk: 5°C to 40°C (41°F to 104°F)
5% to 95%
5% to 95%
5% to 95%
5% to 95%
Table 43 MSR3610-I specifications
Item
MSR3610-I-DP/3610-I-XS
MSR3610-IE-DP/3610-IE-ES/3610-IE-XS
MSR3610-IE-EAD
MSR3610-I-IG/3610-IE-IG
Console port
1
1
1
1
GE copper ports
2 (combo interfaces) + 6
GE fiber ports
USB port
1
1
1
1
Drive slot
1 (support for a 2.5-inch SATA drive)
SIC interface module slots
4
4
4
4
AC power receptacles
2
2
2
2
Memory
8/16/32 GB DDR4
8/16/32 GB DDR4
32 GB DDR4
·        MSR3610-I-IG: 8 GB
·        MSR3610-IE-IG: 16 GB
Built-in storage
4 GB EMMC
4 GB (64 GB in total) EMMC
·        MSR3610-I-IG: 4 GB EMMC
·        MSR3610-IE-IG: 4 GB (64 GB in total) EMMC
Dimensions (H × W × D) (excluding mounting brackets and rubber feet)
Rated AC voltage
100 VAC to 240 VAC @ 50 or 60 Hz
Maximum power consumption
54 W
54 W
54 W
54 W
·        Without a drive: 0°C to 45°C (32°F to 113°F)
·        With a drive: 5°C to 40°C (41°F to 104°F)
·        Without a drive: 20°C to +55°C (4°F to +131°F)
·        Without a drive: 5% RH to 95% RH, noncondensing
·        With a drive: 10% RH to 80% RH, noncondensing
Table 44 MSR1000 router series specifications
Item
MSR1004S-5G/MSR1004S-5G-GL
Console port
1
USB port
1
WAN port
3
LAN port
4
LAN/WAN port
N/A
Built-in 5G module
5G NSA/SA, LTE, UMTS WCDMA
5G LTE antenna port
4
GPS antenna port
1
Memory
1 GB DDR3
Flash
512 MB
52.4 × 150 × 127 mm (2.06 × 5.91 × 5 in)
Input voltage
100 to 240 VAC @ 50 to 60 Hz
19.25 W
Operating ambient temperature
0°C to 55°C (32°F to 131°F)
Operating ambient humidity
Table 45 MSR610 router series specifications
Item
MSR610
Console port
1
USB port
1
GE WAN port
1
GE SFP port
1
GE LAN port
4
Memory
1 GB DDR3
Flash
256 MB
Input voltage
Rated power
8 W
Operating humidity
Table 46 MSR series routes Module List
For hardware compatibility with the interface modules, see the interface module manual.
Module
SIC
Ethernet interface modules:
·        4-port 10/100 Mbps Ethernet L2 switching module (RJ45) (SIC-4FSW)
·        1-port 10/100 Mbps Ethernet electrical SIC interface module (RJ45) (SIC-1FEA)
·        1-port 100 Mbps Ethernet electrical SIC interface module-SIC-1FEF
·        4-port 10/100 Mbps Ethernet L2 switching module-PoE card(SIC-4FSWP)
·        1-port 10/100/1000BASE-T(RJ45) and 100BASE-FX/1000BASE-X(SFP,Combo) Ethernet interface card- RT-SIC-1GEC-V2
·        4-port 10/100/1000BASE-T Switch electrical interface SIC Module -RT-SIC-4GSW
·        4-port 100BASE-FX/1000BASE-X(SFP) Ethernet L2/L3 SIC Module-RT-SIC-4GSWF
WAN interface modules:
·        1-port enhanced synchronous/asynchronous serial SIC interface module (SIC-1SAE)
·        1-port fractional E1 SIC interface module (SIC-1E1-F-V3)
·        1-port E1/CE1/PRI SIC interface module (SIC-1EPRI)
·        1-port analog modem SIC interface module (SIC-1AM)
·        8-port asynchronous serial interface card (SIC-8AS)
·        16-port asynchronous serial interface card (SIC-16AS)
·        1-port ISDN BRI S/T interface card (SIC-1BS)
·        1-port ISDN BRI S/T interface card (SIC-2BS)
·        2-port fractional E1 interface module (SIC-2E1-F)
·        1-port Fractional T1 interface card (SIC-T1-F)
·        1-port ADSL over POTS SIC interface module (SIC-1ADSL)
·        1-port ADSL over ISDN interface module (SIC-1ADSL-I)
·        1 port E1/CE1/PRI SIC interface module(SIC-1EPRI-V3)
·        2-port enhanced synchronous/asynchronous serial SIC interface module RT-SIC-2SAE
·        4-port enhanced synchronous/asynchronous serial SIC interface module RT-SIC-4SAE
·        4-Port Asynchronous Serial Interface (4*RS232/RS422/RS485,2*DI) SIC Module
WLAN interface modules:
·        External Antennas 3 Streams Dual Radio 802.11ac/n Wireless Access Point,FIT (SIC-AP220)
·        External Antennas 3 Streams Dual Radio 802.11ac/n Wave 2 Wireless Access Point,FIT (SIC-AP320)
3G interface modules:
·        3G access module ( RT-SIC-3G-HSPA)
·        CDMA 2000 1x RTT/1x EV-DO Rev.0/1x EV-DO Rev.A 3G access module ( RT-SIC-3G-CDMA)
·        GPRS/EDGE/TD-SCDMA/HSDPA 3G access module ( RT-SIC-3G-TD)
4G interface modules:
·        4G LTE(TDD/FDD LTE,TD-SCDMA,WCDMA,Full Frequency EVDO)SIC Module (SIC-4G-LTE-M)
·        4G WLAN access module (SIC-4G-CNDE)
·        4G WLAN access module (SIC-D4G-CNDE)
Network data encryption modules:
·        4G WLAN access module (SIC-CNDE)
·        China OSCCA Data Encryption SIC Module (SIC-CNDE-SJK)
·        4G LTE(TDD/FDD LTE,TD-SCDMA,WCDMA,Full Frequency EVDO,Dual SIM) and China OSCCA Data Encryption SIC Module (SIC-4G-CNDE-SJK)
·        Dual 4G LTE(TDD/FDD LTE,TD-SCDMA,WCDMA,Full Frequency EVDO,Dual SIM) and China OSCCA Data Encryption SIC Module (SIC-D4G-CNDE-SJK)
M.2 riser SIC module:
·        M.2 SSD riser SIC module (RT-SIC-M2-SATA)
Voice interface modules:
·        1-port voice module subscriber circuit SIC interface module (SIC-1FXS)
·        2-port voice module subscriber circuit SIC interface module (SIC-2FXS)
·        1-port voice module FXO SIC interface module (SIC-1FXO)
·        2-port voice module FXO SIC interface module (SIC-2FXO)
·        1-channel E1 voice SIC interface module (SIC-1VE1)
·        1-channel T1 voice SIC interface module (SIC-1VT1)
·        1-port ISDN BRI S/T voice interface card (SIC-1BSV)
·        2-port ISDN BRI S/T voice interface card (SIC-2BSV)
·        2-port voice subscriber circuit & 1-port voice AT0 analog trunk interface card-SIC-2FXS1FXO
·        1-port E1/T1 Voice SIC Module(DSP On Board)-SIC-1VE1T1
DSIC
·        9-port 10/100 Mbps Ethernet L2 switching module (RJ45) (DSIC-9FSW)
·        4-port voice subscriber circuit & 1-port voice AT0 analog trunk interface card (DSIC-4FXS1FXO)
·        9-port 10/100 Mbps Ethernet L2 switching module -PoE card (DSIC-9FSWP)
HMIM
·        2-port 10M/100/1000M Ethernet electrical HMIM interface module (RJ45) (HMIM-2GEE)
·        4-port 10M/100/1000M Ethernet electrical HMIM interface module (RJ45) (HMIM-4GEE)
·        8-port 10M/100/1000M Ethernet electrical HMIM interface module (RJ45) (HMIM-8GEE)
·     2-port 1000BASE-X HMIM Module (HMIM-2GEF)
·     4-port 1000BASE-X HMIM Module (HMIM-4GEF)
·     8-port 1000BASE-X HMIM Module (HMIM-8GEF)
·     24-port Gig-T Switch HMIM Module (HMIM-24GSW)
·     24-port Gig-T PoE Switch HMIM Module (HMIM-24GSW-POE)
·        8-port 10/100/1000BASE-T(RJ45)+2-port100BASE-FX/1000BASE-X(SFP,Combo) Switch HMIM Module (HMIM-8GSW)
·        8-port 100/1000 Ethernet(4SFP+4SFP/RJ45 Combo)L2/L3 HMIM Module (HMIM-8GSWF)
·        4-Port 10GBASE-R HMIM Module (HMIM-4XP)
·        1 port CE1/PRI interface module (HMIM-1E1)
·        2 port CE1/PRI interface module (HMIM-2E1)
·        4 port CE1/PRI interface module (HMIM-4E1)
·        8 port CE1/PRI interface module (HMIM-8E1)
·        1-port fractional E1 interface module (HMIM-1E1-F)
·        2-port fractional E1 interface module (HMIM-2E1-F)
·        4-port fractional E1 interface module (HMIM-4E1-F)
·        8-port fractional E1 interface module (HMIM-8E1-F)
·        2 port CT1/PRI interface module (HMIM-2T1)
·        4-port fractional T1 interface module HMIM-4T1-F)
·        1-port T3/CT3 compatible interface module (HMIM-1CE3)
·        2 channel enhanced synchronous/asynchronous interface module (HMIM-2SAE)
·        4 channel enhanced synchronous/asynchronous interface module (HMIM-4SAE)
·        8 channel enhanced synchronous/asynchronous interface module (HMIM-8SAE)
·        8 port asynchronous serial interface panel (RJ45) (HMIM-8ASE)
·        16 port asynchronous serial interface panel (RJ45) (HMIM-16ASE)
·        6-port analog modem HMIM interface module (HMIM-6AM)
·        6-port fast connect modem interface module (HMIM-6FCM)
·        SCA SM Encryption HMIM Module(HMIM-CNDE-SJK)
·        1-port OC-3 / STM-1 CPOS HMIM Module (HMM-1CPOS)
·        2-port OC-3 / STM-1 CPOS HMIM Module (HMIM-2CPOS)
·        1-port OC-3c / STM-1c ATM SFP HMIM Module (HMIM-ATMOC3)
·        1-port SDH/SONET interface module (HMIM-1POS)
·        2-Port OC-3c/STM-1c POS HMIM Module
·        4-port SDH/SONET interface module (HMIM-4POS-STM1/4)
·        1-Port E1 POS or DM DHMIM Module (DHMIM-1E1POS1DM)
·        1-Port E1 POS HMIM Module (HMIM-1E1POS)
·        1-Port E1 DM DHMIM Module (DHMIM-1DM)
·        8-port E1/CE1/T1/CT1/PRI HMIM Module (HMIM-8E1T1)
·        4-port E1/CE1/T1/CT1/PRI HMIM Module (HMIM-4E1T1)
·        2-port E1/CE1/T1/CT1/PRI HMIM Module (HMIM-2E1T1)
·        8-port E1/T1/Fractional E1/T1 HMIM Module (HMIM-8E1T1-F)
·        4-port E1/T1/Fractional E1/T1 HMIM Module (HMIM-4E1T1-F)
·        2-port E1/T1/Fractional E1/T1 HMIM Module (HMIM-2E1T1-F)
·        16-port voice module subscriber circuit interface board(HMIM-16FXS)
·        8-port voice module FXS-FXO interface module (HMIM-8FXS-8FXO)
·        1 channel E1 voice HMIM interface module (HMIM-1VE1)
·        2 channel E1 voice HMIM interface module (HMIM-2VE1)
·        1 channel T1 voice HMIM interface module (HMIM-1VT1)
·        2 channel T1 voice HMIM interface module (HMIM-2VT1)
·        4-port voice module subscriber circuit interface board (HMIM-4FXS)
·        4-port voice module FXO interface module (HMIM-4FXO)
·        4 channel voice processing board E&M trunk interface module (HMIM-4E&M)
·        8-port voice E&M analog trunk interface module (HMIM-8E&M)
VPM
·        128-channel voice processing module (RT-VPM2-128)
·        256-channel voice processing module (RT-VPM2-256)
·        512-channel voice processing module (RT-VPM2-512)
HMIM Adapter
·        0.5U MIM to HMIM adapter (HMIM Adapter)
·        1U MIM to HMIM adapter (HMIM Adapter-H)
MIM(need to config the HMIM-Adapter)
·        1-port 10M100M Ethernet electrical MIM interface module (RJ45) (MIM-1FE)
·        2-port 10M/100M Ethernet electrical MIM interface module (RJ45) (MIM-2FE)
·        4-port 10M/100M Ethernet electrical MIM interface module (RJ45) (MIM-4FE)
·        1-port 1000M Ethernet electrical MIM interface module (RJ45) (MIM-1GBE)
·        2-port 1000M Ethernet electrical MIM interface module (RJ45) (MIM-2GBE)
·        1-port 1000M Ethernet electrical MIM interface module (RJ45) (MIM-1GEF)
·        2-port 1000M Ethernet electrical MIM interface module (RJ45) (MIM-2GEF)
·        1-port ATM (Asynchronous Transfer Mode) 155 Mbps optical interface module (HMIM-1ATM-OC3)
·        2 channel enhanced synchronous/asynchronous interface module (MIM-2SAE)
·        4 channel enhanced synchronous/asynchronous interface module (MIM-4SAE)
·        8 channel enhanced synchronous/asynchronous interface module (MIM-8SAE)
·        8 port asynchronous serial interface panel (RJ45) (MIM-8ASE)
·        16 port asynchronous serial interface panel (RJ45) (MIM-16ASE)
·        1 port CE1/PRI interface module (MIM-1E1)
·        2 port CE1/PRI interface module (MIM-2E1)
·        4 port CE1/PRI interface module (MIM-4E1)
·        8 port E1 interface module (75ohm) (MIM-8E1 (75))
·        1-port fractional E1 interface module (MIM-1E1-F)
·        2-port fractional E1 interface module (MIM-2E1-F)
·        4-port fractional E1 interface module (MIM-4E1-F)
·        8 port E1 interface module (75ohm) (MIM-8E1 (75)-F)
·        2 port CT1/PRI interface module (MIM-2T1)
·        8 port T1 interface module (MIM-8T1)
·        4-port fractional T1 interface module MIM-4T1-F)
·        1-port T3/CT3 compatible interface module (MIM-1CE3-V2)
·        1-port  SDH/SONET interface module (MIM-1POS-V2)
·        6-port analog modem MIM interface module (MIM-6AM)
·        1-port dual-pair G.SHDSL interface module (MIM-1SHL-4W)
·        1 channel E1 voice MIM interface module (MIM-1VE1)
·        1 channel T1 voice MIM interface module (MIM-1VT1)
·        2 channel E1 voice MIM interface module (MIM-2VE1)
·        2 channel T1 voice MIM interface module (MIM-2VT1)
·        4-port voice module subscriber circuit interface board (MIM-4FXS)
·        4-port voice module FXO interface module (MIM-4FXO)
·        8-port voice module FXS-FXO interface module (MIM-8FXS-8FXO)
·        4 channel voice processing board E&M trunk interface module (MIM-4EM)
·        4-port ISDN BRI S/T voice interface card (MIM-4BSV)
·        16-port voice module subscriber circuit interface board (MIM-16FXS)
·        6-port fast connect modem interface module (MIM-6FCM)
3G Modem
WCDMA 3G Modem
Huawei E173E261E303CE3131E303E303SE352E303HE3533
CDMA2000 3G Modem
Huawei EC1261
CAUTION
CAUTION:
The support and restriction of modules on MSR please refer to H3C MSR Series Routers Interface Module Guide, Appendix A Interface Card and Interface Module Purchase Guide.
Software features
Table 47 lists the widest feature set supported. Support for features in the feature set depends on the device model. For more information, see the configuration guide and command reference for the device.
Table 47 MSR Series routers software features
Category
Features
LAN protocol:
ARP (proxy ARP, free ARP, authorization ARP)
Ethernet_II
Ethernet_SNAP
VLAN (PORT-BASED VLAN/MAC-BASED VLAN/VLAN-BASED PORT ISOLATE/VLAN VPN/ VOICE VLAN)
802.3x
LACP(802.3ad)
802.1p
802.1Q
802.1x
QinQ
RSTP(802.1w)
MSTP(802.1s)
GVRP
Vxlan
PORT MUTILCAST suppression
WAN protocols:
PPP
PPPoE Client
DCCDialer Watch
ISDN
Modem
3G Modem
IP services
Fast forwarding (unicast/multicast)
TCP
UDP
IP Option
IP unnumber
Policy routing (unicast/multicast)
Non-IP services:
Netstream
IP application
Ping and Trace
DHCP Server
DHCP Client
DNS client
DNS Static
NQA
INQA
IP Accounting
NTP
Telnet
TFTP Client
FTP Client
FTP Server
IP route
Static routing management
Dynamic routing protocols:
·        RIP
·        OSPF
·        BGP
·        IS-IS
Multicast routing protocols:
·        IGMP
·        PIM-DM
·        PIM-SM
·        MBGP
·        MSDP
Routing policy
MPLS
LDP
LSPM
MPLS TE
MPLS FW
MPLS/BGP VPN
IPv6
IPv6 basic functions
IPv6 ND
IPv6 PMTU
IPv6 FIB
IPv6 ACL
IPv6 transition technologies
NAT-PT
IPv6 tunneling
6PE, 6VPE
IPv6 routing
IPv6 static routing management
IPv6 Vxlan,
NPTv6
SRv6
·        MLD
·        PIM-DM
·        PIM-SM
·        PIM-SSM
AAA
Local authentication
Radius
HWTacacs
LDAP
Firewall
ASPF
ACL
FILTER
Security
Port security
IPSec
PORTAL
L2TP
NAT/NAPT
PKI
RSA
SSH V1.5/2.0
URPF
GRE
Reliability
VRRP
Backup center
BFD
L2 QoS
LR
Flow-base QOS Policy
Port-Based Mirroring
Packet Remarking
Priority Mapping
Port Trust Mode
Port Priority
Flow Filter
FlowControl
ACL
Traffic supervision
CAR (Committed Access Rate)
LR (Line Rate)
Congestion management
FIFOPQCQWFQCBQRTPQ
Congestion avoidance
WRED/RED
Traffic shaping
GTSGeneric Traffic Shaping
Other QOS technologies
MPLS QOS
IPHC
Sub-interface QOS
Voice Interfaces
FXS
FXO
E&M
E1VI/T1VI
Voice Signaling
R2
DSS1
SIP
SIP
SIP Operation
Codec
G.711A law
G.711U law
G.723R53
G.723R63
G.729a
G.729R8
G.729bR8
Media Process
RTP
Network management
SNMP V1/V2c/V3
MIB
SYSLOG
RMON
NETCONF
Local management
Command line management
License management
File system management
Auto-configure
Dual Image
User access management
Console interface login
AUX interface login
TTY interface login
Telnet (VTY) login
SSH login
FTP login
XMODEM
Appendix B Upgrading software
This section describes how to upgrade system software while the router is operating normally or when the router cannot correctly start up.
Software types
The following software types are available:
·         Boot ROM image—A .bin file that comprises a basic section and an extended section. The basic section is the minimum code that bootstraps the system. The extended section enables hardware initialization and provides system management menus. You can use these menus to load application software and the startup configuration file or manage files when the device cannot correctly start up.
·         Comware image—Includes the following image subcategories:
¡  Boot image—A .bin file that contains the Linux operating system kernel. It provides process management, memory management, file system management, and the emergency shell.
¡  System image—A .bin file that contains the minimum feature modules required for device operation and some basic features, including device management, interface management, configuration management, and routing. To have advanced features, you must purchase feature packages.
¡  Feature package—Includes a set of advanced software features. Users purchase feature packages as needed.
¡  Patch packages—Irregularly released packages for fixing bugs without rebooting the device. A patch package does not add new features or functions.
Comware software images that have been loaded are called "current software images." Comware images specified to load at the next startup are called "startup software images."
Boot ROM image, boot image, and system image are required for the system to work. These images might be released separately or as a whole in one .ipe package file. If an .ipe file is used, the system automatically decompresses the file, loads the .bin boot and system images and sets them as startup software images.
Upgrade methods
You can upgrade system software by using one of the following methods:
Upgrade method
Remarks
Centralized devices upgrading from the CLI
You must reboot the router to complete the upgrade.
This method can interrupt ongoing network services.
Distributed devices upgrading from the CLI
Upgrading from the BootWare menu
Use this method when the router cannot correctly start up.
Preparing for the upgrade
Before you upgrade system software, complete the following tasks:
·         Set up the upgrade environment as shown in Table 49.
·         Configure routes to make sure that the router and the file server can reach each other.
·         Run a TFTP or FTP server on the file server.
·         Log in to the CLI of the router through the console port.
·         Copy the upgrade file to the file server and correctly set the working directory on the TFTP or FTP server.
·         Make sure the upgrade has minimal impact on the network services. During the upgrade, the router cannot provide any services.
IMPORTANT
IMPORTANT:
In the BootWare menu, if you choose to download files over Ethernet, the Ethernet port must be GE0 on an MSR 26-30, MSR 36-10, MSR 36-20, MSR 36-40, MSR 36-60, MSR3600-28, or MSR3600-51 router, and must be M-GE0 on an MSR 56-60 or MSR 56-80 router.
Table 48 Storage media
Model
Storage medium
Path
Router Types
MSR2600-6-X1-GL
Flash
flash:/
Centralized devices
MSR3600-28-SI-GL
Flash
flash:/
Centralized devices
MSR 36-20
CF card
cfa0:/
Centralized devices
MSR 36-40
CF card
cfa0:/
Centralized devices
MSR 36-60
CF card
cfa0:/
Centralized devices
MSR3600-28
Flash
flash:/
Centralized devices
MSR3600-51
Flash
flash:/
Centralized devices
MSR 56-60
CF card
cfa0:/
Centralized devices
MSR 56-80
CF card
cfa0:/
Distributed devices
MSR810-10-PoE
Flash
flash:/
Centralized devices
MSR810
Flash
flash:/
Centralized devices
MSR830
Flash
flash:/
Centralized devices
Figure 1 Set up the upgrade environment
You can use the TFTP or FTP commands on the router to access the TFTP or FTP server to back up or download files.
Saving the running configuration and verifying the storage space
1.       Save the running configuration.
<Sysname>save
Configuration is saved to device successfully.
<Sysname>
2.       Identify the system software image and configuration file names and verify that the flash has sufficient space for the new system software image.
<Sysname>dir
Directory of flash:
   0 drw-           - Aug 15 2012 12:03:13   diagfile
   1 -rw-          84 Aug 15 2012 12:17:59   ifindex.dat
   2 drw-           - Aug 15 2012 12:03:14   license
   3 drw-           - Aug 15 2012 12:03:13   logfile
   4 -rw-    11418624 Dec 15 2011 09:00:00   msr26-cmw710-boot-a0005.bin
   5 -rw-     1006592 Dec 15 2011 09:00:00   msr26-cmw710-data-a0005.bin
   6 -rw-       10240 Dec 15 2011 09:00:00   msr26-cmw710-security-a0005.bin
   7 -rw-    24067072 Dec 15 2011 09:00:00   msr26-cmw710-system-a0005.bin
   8 -rw-     1180672 Dec 15 2011 09:00:00   msr26-cmw710-voice-a0005.bin
   9 drw-           - Aug 15 2012 12:03:13   seclog
  10 -rw-        1632 Aug 15 2012 12:18:00   startup.cfg
  11 -rw-       25992 Aug 15 2012 12:18:00   startup.mdb
262144 KB total (223992 KB free)
<Sysname>
Downloading the image file to the router
Using TFTP
Download the system software image file (for example, msr26.ipe) to the flash on the router.
<Sysname>tftp 192.168.1.100 get msr26.ipe
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 35.9M  100 35.9M    0     0   559k      0  0:01:05  0:01:05 --:--:--  546k
<Sysname>
Using FTP
1.       From FTP client view, download the system software image file (for example, msr26.ipe) to the CF card on the router.
ftp> get msr26.ipe
msr26.ipe already exists. Overwrite it? [Y/N]:y
227 Entering passive mode (192,168,1,100,5,20)
125 Using existing data connection
226 Closing data connection; File transfer successful.
37691392 bytes received in 17.7 seconds (2.03 Mbyte/s)
[ftp]
2.       Return to user view.
[ftp]quit
221 Service closing control connection
<Sysname>
Specifying the startup image file
1.       Specify the msr26.ipe file as the main image file at the next reboot.
<Sysname>boot-loader file flash:/msr26.ipe main
Images in IPE:
This command will set the main startup software images. Continue? [Y/N]:y
Add images to the device.
Successfully copied flash:/msr26-cmw710-boot-a0005.bin to flash:/msr26-cmw710-boot-a0005.bin.
Successfully copied flash:/msr26-cmw710-system-a0005.bin to flash:/msr26-cmw710-system-a0005.bin.
Successfully copied flash:/msr26-cmw710-security-a0005.bin to flash:/msr26-cmw710-security-a0005.bin.
Successfully copied flash:/msr26-cmw710-voice-a0005.bin to flash:/msr26-cmw710-voice-a0005.bin.
Successfully copied flash:/msr26-cmw710-data-a0005.bin to flash:/msr26-cmw710-data-a0005.bin.
The images that have passed all examinations will be used as the main startup software images at the next reboot on the device.
<Sysname>
2.       Verify that the file has been loaded.
<Sysname> display boot-loader
Software images on the device:
Current software images:
Main startup software images:
Backup startup software images:
  None
<Sysname>
Rebooting and completing the upgrade
1.       Reboot the router.
<Sysname>reboot
Now rebooting, please wait...
<Sysname>
System is starting...
2.       After the reboot is complete, verify that the system software image is correct.
<Sysname> display version
H3C Comware Software, Version 7.1.042, Release 000701
Copyright (c) 2004-2013 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C MSR56-60 uptime is 0 weeks, 0 days, 11 hours, 49 minutes
Last reboot reason : Power on
Boot image: cfa0:/MSR56-cmw710-boot-a0005.bin
Boot image version: 7.1.040, Alpha 0005
System image: cfa0:/MSR56-cmw710-system-a0005.bin
System image version: 7.1.040, Alpha 0005
Feature image(s) list:
  cfa0:/MSR56-cmw710-security-a0005.bin, version: 7.1.040
  cfa0:/MSR56-cmw710-voice-a0005.bin, version: 7.1.040
  cfa0:/MSR56-cmw710-data-a0005.bin, version: 7.1.040
Slot 0: MPU-100 uptime is 0 week, 0 day, 1 hour, 20 minutes
CPU ID: 0x3
2G bytes DDR3 SDRAM Memory
8M bytes Flash Memory
PCB               Version:  2.0
CPLD              Version:  1.0
Basic    BootWare Version:  1.04
Extended BootWare Version:  1.04
[SUBSLOT  0]CON                    (Hardware)2.0    (Driver)1.0,   (Cpld)1.0
[SUBSLOT  0]AUX                    (Hardware)2.0    (Driver)1.0,   (Cpld)1.0
[SUBSLOT  0]MGE0                   (Hardware)2.0    (Driver)1.0,   (Cpld)1.0
Slot 1: MPU-100 uptime is 0 week, 0 day, 1 hour, 8 minutes
Last reboot reason : User reboot
CPU ID: 0x3
PCB               Version:  2.0
CPLD              Version:  1.0
Basic    BootWare Version:  1.05
Extended BootWare Version:  1.05
Slot 2: SPU-100 uptime is 0 week, 0 day, 1 hour, 19 minutes
CPU ID: 0x5
PCB               Version:  2.0
CPLD              Version:  1.0
Basic    BootWare Version:  1.02
Extended BootWare Version:  1.02
[SUBSLOT  0]GE2/0/0                (Hardware)2.0    (Driver)1.0,   (Cpld)1.0
[SUBSLOT  0]GE2/0/1                (Hardware)2.0    (Driver)1.0,   (Cpld)1.0
[SUBSLOT  0]GE2/0/2                (Hardware)2.0    (Driver)1.0,   (Cpld)1.0
[SUBSLOT  0]GE2/0/3                (Hardware)2.0    (Driver)1.0,   (Cpld)1.0
[SUBSLOT  0]CELLULAR2/0/0          (Hardware)2.0    (Driver)1.0,   (Cpld)1.0
[SUBSLOT  0]CELLULAR2/0/1          (Hardware)2.0    (Driver)1.0,   (Cpld)1.0
[SUBSLOT  1]HMIM-4SAE              (Hardware)3.0    (Driver)1.0,   (Cpld)4.0
Displaying the slot number of the active MPU
Display the slot number of the active MPU. By default, the standby MPU will automatically synchronize the image files from active MPU.
<Sysname>display device
 Slot No.      Board Type                Status        Primary        SubSlots
 0             MPU-100                   Normal        Master            0
 1             MPU-100                   Normal        Standby           0
 2             SPU-100                   Normal        N/A               10
<Sysname>
<Sysname>save
Please input the file name(*.cfg)[cfa0:/startup.cfg]
<Sysname>
2.       Identify the system software image and configuration file names and verify that the CF card has sufficient space for the new system software image.
<Sysname>dir
Directory of cfa0:
   0 drw-           - Jan 07 2013 14:02:12   diagfile
   1 -rw-         307 Jan 22 2013 17:02:02   ifindex.dat
   2 drw-           - Jan 07 2013 14:02:12   license
   3 drw-           - Jan 22 2013 13:42:00   logfile
   4 -rw-    21412864 Jan 22 2013 16:49:00   MSR56-cmw710-boot-r0005p01.bin
   5 -rw-     1123328 Jan 22 2013 16:50:30   MSR56-cmw710-data-r0005p01.bin
   6 -rw-       11264 Jan 22 2013 16:50:26   MSR56-cmw710-security-r0005p01.bin
   7 -rw-    45056000 Jan 22 2013 16:49:34   MSR56-cmw710-system-r0005p01.bin
   8 -rw-     2746368 Jan 22 2013 16:50:26   MSR56-cmw710-voice-r0005p01.bin
   9 drw-           - Jan 07 2013 14:02:12   seclog
  10 -rw-        2166 Jan 22 2013 17:02:02   startup.cfg
  11 -rw-       34425 Jan 22 2013 17:02:02   startup.mdb
507492 KB total (438688 KB free)
<Sysname>
Using TFTP
Download the system software image file (for example,  msr56.ipe) to the CF card on the router.
<Sysname>tftp 192.168.1.100 get msr56.ipe
 45 67.0M   45 30.4M    0     0   792k      0  0:01:26  0:00:39  0:00:47  844k
100 67.0M  100 67.0M    0     0   772k      0  0:01:28  0:01:28 --:--:--  745k
<Sysname>
Using FTP
1.       From FTP client view, download the system software image file (for example, msr56.ipe) to the CF card on the router.
ftp> get msr56.ipe
msr56.ipe already exists. Overwrite it? [Y/N]:y
[ftp]
[ftp]quit
<Sysname>
Copying the image file to CF card root directory of the standby MPU
<Sysname> copy msr56.ipe slot1#cfa0:/
Copy cfa0:/msr56.ipe to slot1#cfa0:/msr56.ipe?[Y/N]:y
Copying file cfa0:/msr56.ipe to slot1#cfa0:/ msr56.ipe...Done.
1.       Specify the msr56.ipe file as the main image file for the active MPU on slot 0 at the next reboot.
<Sysname>boot-loader file flash:/msr56.ipe slot 0 main
Images in IPE:
  msr56-cmw710-boot-a0005.bin
  msr56-cmw710-system-a0005.bin
  msr56-cmw710-security-a0005.bin
  msr56-cmw710-voice-a0005.bin
  msr56-cmw710-data-a0005.bin
Successfully copied flash:/msr56-cmw710-boot-a0005.bin to cfa0:/msr56-cmw710-boot-a0005.bin.
Successfully copied flash:/msr56-cmw710-system-a0005.bin to cfa0:/msr56-cmw710-system-a0005.bin.
Successfully copied flash:/msr56-cmw710-security-a0005.bin to cfa0:/msr56-cmw710-security-a0005.bin.
Successfully copied flash:/msr56-cmw710-voice-a0005.bin to cfa0:/msr56-cmw710-voice-a0005.bin.
Successfully copied flash:/msr56-cmw710-data-a0005.bin to cfa0:/msr56-cmw710-data-a0005.bin.
<Sysname>
2.       Specify the msr56.ipe file as the main image file for the standby MPU on slot 1 at the next reboot.
Images in IPE:
<Sysname>
3.       Verify that the file has been loaded.
Software images on slot 0:
  cfa0:/MSR56-cmw710-boot-r0005p01.bin
  cfa0:/MSR56-cmw710-system-r0005p01.bin
  cfa0:/MSR56-cmw710-security-r0005p01.bin
  cfa0:/MSR56-cmw710-voice-r0005p01.bin
  cfa0:/MSR56-cmw710-data-r0005p01.bin
  None
Software images on slot 1:
  None
<Sysname>reboot
<Sysname>
CPU ID: 0x3
PCB               Version:  2.0
CPLD              Version:  1.0
CPU ID: 0x3
PCB               Version:  2.0
CPLD              Version:  1.0
CPU ID: 0x5
PCB               Version:  2.0
CPLD              Version:  1.0
You can use the following methods to upgrade software from the BootWare menu:
·         Using TFTP/FTP to upgrade software through an Ethernet port
·         Using XMODEM to upgrade software through the console port
Accessing the BootWare menu
1.       Power on the router (for example, an H3C MSR 26-30 router), and you can see the following information:
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing....Done.
*                  H3C MSR26-30 BootWare, Version 1.20                      *
Copyright (c) 2004-2012 Hangzhou H3C Technologies Co., Ltd.
Compiled Date       : Jun 22 2013
CPU ID              : 0x1
Memory Type         : DDR3 SDRAM
Memory Size         : 1024MB
Flash Size          : 2MB
Nand Flash size     : 256MB
CPLD Version        : 2.0
PCB Version         : 3.0
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
2.       Press Ctrl + B to access the BootWare menu.
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip authentication for console login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Enter your choice(0-9):
Table 49 BootWare menu options
Item
<1> Boot System
Boot the system software image.
Access the Serial submenu (see Table 52 ) for upgrading system software through the console port or changing the serial port settings.
Access the Ethernet submenu (see Table 50) for upgrading system software through an Ethernet port or changing Ethernet settings.
<4> File Control
Access the File Control submenu (see Table 53) to retrieve and manage the files stored on the router.
Delete the next-startup configuration files and load the factory-default configuration.
Start the router with the factory default configuration. This is a one-time operation and does not take effect at the next reboot. You use this option when you forget the console login password.
Access the BootWare Operation menu for backing up, restoring, or upgrading BootWare. When you upgrade the system software image, BootWare is automatically upgraded. H3C does not recommend upgrading BootWare separately. This document does not cover using the BootWare Operation menu.
Clear all the authentication schemes on the console port.
Access the Storage Device Operation menu to manage storage devices. Using this option is beyond this chapter.
<0> Reboot
Restart the router.
1.       Enter 3 in the BootWare menu to access the Ethernet submenu.
===============================<File CONTROL>===============================
|Note:the operating device is flash                                        |
|<1> Download Image Program To SDRAM And Run                               |
|<2> Update Main Image File                                                |
|<3> Update Backup Image File                                              |
|<4> Download Files(*.*)                                                   |
|<5> Modify Ethernet Parameter                                     |
|<0> Exit To Main Menu                                                      |
Enter your choice(0-4):
Table 50 Ethernet submenu options
Item
<1> Download Application Program To SDRAM And Run
Download a system software image to the SDRAM and run the image.
Upgrade the main system software image.
Upgrade the backup system software image.
Download a system software image to the Flash or CF card.
Modify network settings.
Return to the BootWare menu.
2.       Enter 5 to configure the network settings.
=========================<ETHERNET PARAMETER SET>=========================
|Note:       '.' = Clear field.                                            |
|            '-' = Go to previous field.                                   |
|          Ctrl+D = Quit.                                                  |
Protocol (FTP or TFTP) :ftp
Load File Name         :msr26.ipe
Target File Name       :msr26.ipe
Server IP Address      :192.168.1.1
Local IP Address       :192.168.1.100
Subnet Mask            :255.255.255.0
Gateway IP Address     :0.0.0.0
FTP User Name          :user001
FTP User Password      :********
Table 51 Network parameter fields and shortcut keys
'.' = Clear field
Press a dot (.) and then Enter to clear the setting for a field.
Press a hyphen (-) and then Enter to return to the previous field.
Ctrl+D = Quit
Press Ctrl + D to exit the Ethernet Parameter Set menu.
Set the file transfer protocol to FTP or TFTP.
Load File Name
Set the name of the file to be downloaded.
Target File Name
Set a file name for saving the file on the router. By default, the target file name is the same as the source file name.
Server IP Address
Set the IP address of the FTP or TFTP server. If a mask must be set, use a colon (:) to separate the mask length from the IP address. For example, 192.168.80.10:24.
Local IP Address
Set the IP address of the router.
Subnet Mask
Subnet Mask of the local IP address.
Gateway IP Address
Set a gateway IP address if the router is on a different network than the server.
FTP User Name
Set the username for accessing the FTP server. This username must be the same as configured on the FTP server. This field is not available for TFTP.
FTP User Password
Set the password for accessing the FTP server. This password must be the same as configured on the FTP server. This field is not available for TFTP.
3.       Select an option in the Ethernet submenu to upgrade a system software image. For example, enter 2 to upgrade the main system software image.
Loading.....................................................................
.........................................Done.
37691392 bytes downloaded!
The file is exist,will you overwrite it? [Y/N]Y
Image file msr26-cmw710-boot-a0005.bin is self-decompressing...
Saving file flash:/msr26-cmw710-boot-a0005.bin .............................
......Done.
Image file msr26-cmw710-system-a0005.bin is self-decompressing...
Saving file flash:/msr26-cmw710-system-a0005.bin ...........................
Image file msr26-cmw710-security-a0005.bin is self-decompressing...
Saving file flash:/msr26-cmw710-security-a0005.bin Done.
Image file msr26-cmw710-voice-a0005.bin is self-decompressing...
Saving file flash:/msr26-cmw710-voice-a0005.bin ......Done.
Image file msr26-cmw710-data-a0005.bin is self-decompressing...
Saving file flash:/msr26-cmw710-data-a0005.bin ..Done.
==========================<Enter Ethernet SubMenu>==========================
|<3> Update Backup Image File                                              |                                                        |<4> Download Files(*.*)                                                   |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
4.       Enter 0 to return to the BootWare menu
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<5> Modify BootWare Password                                              |
|<0> Reboot        |
5.       1 to boot the system.
Loading the main image files...
Loading file flash:/msr26-cmw710-system-a0005.bin..........................
Done.
Loading file flash:/msr26-cmw710-boot-a0005.bin..............Done.
Image file flash:/msr26-cmw710-boot-a0005.bin is self-decompressing.........
.....Done.
System image is starting...
Line aux0 is available.
Press ENTER to get started.
1.       Enter 2 in the BootWare menu to access the Serial submenu.
===========================<Enter Serial SubMenu>===========================
|<5> Modify Serial Interface Parameter                                     |
Table 52 Serial submenu options
Item
Download an application to SDRAM through the serial port and run the program.
<4>Download Files(*.*)
Modify serial port parameters
2.       Enter 5 Select an appropriate baud rate for the console port. For example, enter 5 to select 115200 bps.
===============================<BAUDRATE SET>===============================
|Note:'*'indicates the current baudrate                                    |
|     Change The HyperTerminal's Baudrate Accordingly                      |
|---------------------------<Baudrate Available>---------------------------|
|<1> 9600(Default)*                                                        |
|<2> 19200        |
|<3> 38400        |
|<4> 57600        |
|<5> 115200        |
|<0> Exit        |
Enter your choice(0-5):
The following messages appear:
Baudrate has been changed to 115200 bps.
Please change the terminal's baudrate to 115200 bps, press ENTER when ready.
Typically the size of a .bin file is over 10 MB. Even at 115200 bps, the download takes about 30 minutes.
3.       Select Call > Disconnect in the HyperTerminal window to disconnect the terminal from the router.
Figure 2 Disconnect the terminal connection
If the baud rate of the console port is 9600 bps, jump to step 9.
4.       Select File > Properties, and in the Properties dialog box, click Configure.
Figure 3 Properties dialog box
5.       Select 115200 from the Bits per second list and click OK.
Figure 4 Modify the baud rate
6.       Select Call > Call to reestablish the connection.
Figure 5 Reestablish the connection
7.       Press Enter.
The following menu appears:
The current baudrate is 115200 bps
|<1> 9600(Default)                                                         |
|<2> 19200        |
|<3> 38400        |
|<4> 57600        |
|<5> 115200*                                                               |
|<0> Exit        |
8.       Enter 0 to return to the Serial submenu.
9.       Select an option from options 2 to 3 to upgrade a system software image. For example, enter 2 to upgrade the main system software image.
Please Start To Transfer File, Press <Ctrl+C> To Exit.
Waiting ...CCCCC
10.     Select Transfer > Send File in the HyperTerminal window.
Figure 6 Transfer menu
11.     In the dialog box that appears, click Browse to select the source file, and select Xmodem from the Protocol list.
Figure 7 File transmission dialog box
12.     Click Send. The following dialog box appears:
Figure 8 File transfer progress
13.     When the Serial submenu appears after the file transfer is complete, enter 0 at the prompt to return to the BootWare menu.
Download successfully!
Input the File Name:main.bin
Updating File flash:/main.bin..............................................
.....................................................Done!
14.     Enter 1 in the BootWare menu to boot the system.
15.     If you are using a download rate other than 9600 bps, change the baud rate of the terminal to 9600 bps. If the baud rate has been set to 9600 bps, skip this step.
Managing files from the BootWare menu
To change the type of a system software image, retrieve files, or delete files, enter 4 in the BootWare menu.
The File Control submenu appears:
|Note:the operating device is cfa0                                       |
|<1> Display All File(s)                                                 |
|<2> Set Image File type                                           |
|<3> Set Bin File type                                                   |
|<4> Set Configuration File type                                         |
|<5> Delete File                                                         |
|<6> Copy File                                                           |
Enter your choice(0-6):
Table 53 File Control submenu options
Item
Display all files.
Change the type of a system software image (.ipe).
Change the type of a system software image (.bin).
Change the type of a configuration file.
<5> Delete File
Delete files.
<6> Copy File
Copy File
Displaying all files
To display all files, enter 1 in the File Control submenu:
Display all file(s) in flash:
 'M' = MAIN      'B' = BACKUP      'N/A' = NOT ASSIGNED
|NO. Size(B)   Time                 Type   Name                            |
|1   37691392  Aug/16/2012 07:09:16 N/A    flash:/msr26.ipe                |
|2   25992     Aug/15/2012 12:18:00 N/A    flash:/startup.mdb              |
|3   1632      Aug/15/2012 12:18:00 M      flash:/startup.cfg              |
|4   84        Aug/15/2012 12:17:59 N/A    flash:/ifindex.dat              |
|5   11029     Aug/15/2012 13:31:16 N/A    flash:/logfile/logfile1.log     |
|6   17        Aug/16/2012 07:47:24 N/A    flash:/.pathfile                |
|7   1006592   Aug/16/2012 07:44:16 M    flash:/msr26-cmw710-data-a0005.bin|
|8   815       Aug/15/2012 12:03:14 N/A    flash:/license/DeviceID.did     |
|9   1180672   Aug/16/2012 07:44:15 M    flash:/msr26-cmw710-voice-a0005. bin|
|10  10240     Aug/16/2012 07:44:15 M    flash:/msr26-cmw710-security-a0005.bin|
|11  24067072  Aug/16/2012 07:44:10 M      flash:/msr26-cmw710-system-a0005.bin|
|12  11418624  Aug/16/2012 07:44:05 M      flash:/msr26-cmw710-boot-a0005.bin|
Changing the type of a system software image
System software image file attributes include main (M), and backup (B). You can store only one main image, and one backup image on the router. A system software image can have any combination of the M, and B attributes. If the file attribute you are assigning has been assigned to an image, the assignment removes the attribute from that image. The image is marked as N/A if it has only that attribute.
To change the type of a system software image:
1.       Enter 2 in the File Control submenu.
|0   Exit        |
Enter file No:1
2.       Enter the number of the file you are working with, and press Enter.
Modify the file attribute:
|<1> +Main                                                               |
|<2> +Backup                                                             |
|<0> Exit        |
Enter your choice(0-2):
3.       Enter a number in the range of 1 to 4 to add or delete a file attribute for the file.
Set the file attribute success!
Deleting files
When storage space is insufficient, you can delete obsolete files to free up storage space.
To delete files:
1.       Enter 5 in the File Control submenu.
Deleting the file in cfa0:
Deleting the file in flash:
0   Exit
Enter file No.:
2.       Enter the number of the file to delete.
3.       When the following prompt appears, enter Y.
The file you selected is flash:/msr26-cmw710-security-a0005.bin,Delete it?
[Y/N]Y
Deleting...Done.
Handling software upgrade failures
If a software upgrade fails, the system runs the old software version. To handle a software failure:
1.       Check the physical ports for a loose or incorrect connection.
2.       If you are using the console port for file transfer, check the HyperTerminal settings (including the baud rate and data bits) for any wrong setting.
3.       Check the file transfer settings:
¡  If XMODEM is used, you must set the same baud rate for the terminal as for the console port.
¡  If TFTP is used, you must enter the same server IP addresses, file name, and working directory as set on the TFTP server.
¡  If FTP is used, you must enter the same FTP server IP address, source file name, working directory, and FTP username and password as set on the FTP server.
4.       Check the FTP or TFTP server for any incorrect setting.
5.       Check that the storage device has sufficient space for the upgrade file.
6.       If the message "Something is wrong with the file” appears, check the file for file corruption.
Appendix C Handling console login password loss
Disabling password recovery capability
Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure new passwords.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
Table 54 summarizes options whose availability varies with the password recovery capability setting.
Table 54 BootWare options and password recovery capability compatibility matrix
Password recovery enabled
Password recovery disabled
Tasks that can be performed
Yes
No
Load and run Comware software images in SDRAM.
Skip Authentication for Console Login
Yes
No
Enable console login without authentication.
Yes
No
Load the factory-default configuration without deleting the next-startup configuration files.
No
Yes
To disable password recovery capability:
Step
Remarks
1.       Enter system view.
N/A
2.       Disable password recovery capability.
undo password-recovery enable
By default, password recovery capability is enabled.
When password recovery capability is disabled, you cannot downgrade the device software to a version that does not support the capability through the BootWare menus. You can do so at the CLI, but the BootWare menu password configured becomes effective again.
CAUTION
CAUTION:
Handling console login password loss causes service outage.
The method for handling console login password loss depends on the password recovery capability setting (see Figure 9).
Figure 9 Handling console login password loss
Examining the password recovery capability setting
7.       Reboot the router.
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Press Ctrl+T to start heavy memory test
Booting Normal Extended BootWare........
The Extended BootWare is self-decompressing....Done.
*                  H3C MSR36-40 BootWare, Version 1.11                     *
Copyright (c) 2004-2013 Hangzhou H3C Technologies Co., Ltd.
Compiled Date       : May 13 2013
CPU ID              : 0x2
Memory Size         : 2048MB
BootWare Size       : 1024KB
Flash Size          : 8MB
cfa0 Size           : 247MB
CPLD Version        : 2.0
PCB Version         : 2.0
8.       Press Ctrl + B within three seconds after the "Press Ctrl+B to access EXTENDED-BOOTWARE MENU..." prompt message appears.
9.       Read the password recovery capability setting information displayed before the EXTEND-BOOTWARE menu.
Note: The current operating device is cfa0
|<1> Boot System        |
|<4> File Control        |
|<8> Skip Authentication for Console Login                                        |
|<0> Reboot        |
Ctrl+Z: Access EXTEND ASSISTANT MENU
Using the Skip Current System Configuration option
1.       Reboot the router to access the EXTEND-BOOTWARE menu, and then enter 6.
The current mode is password recovery.
|<1> Boot System        |
|<4> File Control        |
|<0> Reboot        |
Enter your choice(0-9): 6
After the configuration skipping flag is set successfully, the following message appears:
Flag Set Success.
2.       When the EXTEND-BOOTWARE menu appears again, enter 1 to reboot the router.
The router starts up with the factory-default configuration without deleting the next-startup configuration files.
3.       To use the configuration in a next-startup configuration file, load the file in system view.
<H3C> system-view
[H3C] configuration replace file cfa0:/startup.cfg
Current configuration will be lost, save current configuration? [Y/N]:n
Info: Now replacing the current configuration. Please wait...
Info: Succeeded in replacing current configuration with the file startup.cfg.
4.       Configure a new console login authentication mode and a new console login password.
In the following example, the console login authentication mode is password and the authentication password is 123456. For security purposes, the password is always saved in ciphertext, whether you specify the simple or cipher keyword for the set authentication password command.
<H3C> system-view
[H3C] line aux 0
[H3C-line-aux0] authentication-mode password
[H3C-line-aux0] set authentication password simple 123456
Use the line aux 0 command on an MSR 2600 or MSR 3600 router. The console port and the AUX port are the same physical port.
Use the line console 0 command on an MSR 5600 router. An MSR 5600 router has a separate console port.
5.       To make the settings take effect after a reboot, save the running configuration to the next-startup configuration file.
[H3C-line-aux0] save
Using the Skip Authentication for Console Login option
1.       Reboot the router to access the EXTEND-BOOTWARE menu, and then enter 8.
|<1> Boot System        |
|<4> File Control        |
|<0> Reboot        |
Enter your choice(0-9): 8
The router deletes the console login authentication configuration commands from the main next-startup configuration file. After the operation is completed, the following message appears:
Clear Image Password Success!
The router starts up with the main next-startup configuration file.
3.       Configure a console login authentication mode and a new console login password. See "Configure a new console login authentication mode and a new console login password.."
4.       To make the setting take effect after a reboot, save the running configuration to the next-startup configuration file.
Using the Restore to Factory Default Configuration option
CAUTION
CAUTION:
Using the Restore to Factory Default Configuration option deletes both the main and backup next-configuration files.
1.       Reboot the router to access the EXTEND-BOOTWARE menu, and enter 5.
The current mode is no password recovery.
|<1> Boot System        |
|<4> File Control        |
|<0> Reboot        |
Enter your choice(0-9): 5
2.       At the prompt for confirmation, enter Y.
The router deletes its main and backup next-startup configuration files and restores the factory-default configuration.
The current mode is no password recovery. The configuration files will be
deleted, and the system will start up with factory defaults, Are you sure to
 continue?[Y/N]Y
Setting...Done.
3.       When the EXTEND-BOOTWARE menu appears again, enter 1 to reboot the router.
The router starts up with the factory-default configuration.
4.       Configure a new console login authentication mode and a new console login password. See "Configure a new console login authentication mode and a new console login password.."
[H3C] save
