- 04-Layer 2—LAN Switching Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-M-LAG commands
- 04-Port isolation commands
- 05-VLAN commands
- 06-MVRP commands
- 07-QinQ commands
- 08-VLAN mapping commands
- 09-Loop detection commands
- 10-Spanning tree commands
- 11-LLDP commands
- 12-Layer 2 forwarding commands
| 09-Loop detection commands | 77.63 KB |
loopback-detection delay-timer
loopback-detection global action
loopback-detection global enable
loopback-detection interval-time
MDC is supported only when the device operates in standalone mode. For more information about standalone mode, see IRF configuration in Virtual Technologies Configuration Guide. For more information about MDC and device models that support MDC, see MDC configuration in Virtual Technologies Configuration Guide.
display loopback-detection
Use display loopback-detection to display the loop detection configuration and status.
In the command output, a port shut down by loop detection stays in looped state until it comes up.
Example
# Display the loop detection configuration and status.
<Sysname> display loopback-detection
Loop detection is enabled.
Global loop detection interval is 30 second(s).
Loop is detected on following interfaces:
Interface Action mode VLANs/VSI
Ten-GigabitEthernet3/0/3 None 10
Action mode |
Loop protection action: · Block—When a loop is detected on an interface, the device performs the following operations: ¡ Generates a log. ¡ Disables the interface from learning MAC addresses. ¡ Blocks the interface. · None—When a loop is detected on an interface, the device generates a log but performs no action on the interface. · No-learning—When a loop is detected on an interface, the device generates a log and disables the interface from learning MAC addresses. · Shutdown—When a loop is detected on an interface, the device performs the following operations: ¡ Generates a log. ¡ Shuts down the interface to disable the interface from receiving or sending frames. The device automatically sets the interface to the forwarding state after a time interval. Set the time interval by using the shutdown-interval command (see Fundamentals Command Reference). |
VLANs/VSI |
VLANs or VSI to which the interface belongs and where loops are detected. |
loopback-detection action
Use loopback-detection action to set the loop protection action on an interface.
Use undo loopback-detection action to restore the default.
loopback-detection action { block | no-learning | shutdown }
When the device detects a loop on an interface, it generates a log but performs no action on the interface.
block: Enables the block mode. If a loop is detected, the device performs the following operations:
· Generates a log.
· Disables MAC address learning.
· Blocks the interface.
no-learning: Enables the no-learning mode. If a loop is detected, the device generates a log and disables MAC address learning on the interface. Layer 2 aggregate interfaces do not support this keyword.
shutdown: Enables the shutdown mode. If a loop is detected, the device generates a log and shuts down the interface. The device automatically sets the interface to the forwarding state after the time interval set by using the shutdown-interval command (see Fundamentals Command Reference).
To set the loop protection action globally, use the loopback-detection global action command.
The global action applies to all interfaces. An interface-specific action applies only to the interface on which the action is configured. On an interface, the interface-specific action takes precedence over the global action.
Example
# Set the loop protection action to shutdown on Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[System-Ten-GigabitEthernet3/0/1] loopback-detection action shutdown
Use loopback-detection delay-timer to set the loop protection delay timer on an interface.
Use undo loopback-detection delay-timer to disable loop protection delay on an interface.
loopback-detection delay-timer time
Loop protection delay is disabled on an interface.
time: Sets the loop protection delay timer, in seconds. The value range for this argument is 1 to 1000.
On a network protected by loop detection, the shutdown or block action taken on a looped interface of an upstream device might cause traffic interruption to its downstream devices. To minimize the impacts of loop detection on downstream traffic, set the loop protection delay timer on upstream devices. This delay allows the downstream devices to remove loops before the upstream devices take an action.
The global delay timer applies to all interfaces enabled with loop detection. An interface-specific delay timer applies only to the interface on which it is configured. On an interface, the interface-specific delay timer takes precedence over the global delay timer.
Example
# Set the loop protection delay timer to 100 seconds on Ten-GigabitEthernet 3/0/1.
[System-Ten-GigabitEthernet3/0/1] loopback-detection delay-timer 100
loopback-detection global delay-timer
loopback-detection enable
Use loopback-detection enable to enable loop detection on an interface.
Use undo loopback-detection enable to disable loop detection on an interface.
loopback-detection enable vlan { vlan-id-list | all }
undo loopback-detection enable vlan { vlan-id-list | all }
Loop detection is disabled on interfaces.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The ID for vlan-id2 must be no less than the ID for vlan-id1.
all: Specifies all existing VLANs.
You can enable loop detection globally or on a per-interface basis. When an interface receives a detection frame in any VLAN, the loop protection action is triggered on that interface, regardless of whether loop detection is enabled on it.
Example
# Enable loop detection on Ten-GigabitEthernet 3/0/1 for VLAN 10 through VLAN 20.
[System-Ten-GigabitEthernet3/0/1] loopback-detection enable vlan 10 to 20
Use loopback-detection global action to set the global loop protection action.
Use undo loopback-detection global action to restore the default.
loopback-detection global action shutdown
shutdown: Enables the shutdown mode. If a loop is detected, the device generates a log and shuts down the interface. The device automatically sets the interface to the forwarding state after you set the time interval by using the shutdown-interval command (see Fundamentals Command Reference).
To set the loop protection action on a per-interface basis, use the loopback-detection action command in interface view.
The global action applies to all interfaces. An interface-specific action applies only to the interface on which it is configured. On an interface, the interface-specific action takes precedence over the global action.
Example
# Set the global loop protection action to shutdown.
[System] loopback-detection global action shutdown
Use loopback-detection delay-timer to set the global loop protection delay timer.
Use undo loopback-detection delay-timer to disable loop protection delay globally.
Loop protection delay is disabled on globally.
Example
# Set the global loop protection delay timer to 100 seconds.
[Sysname] loopback-detection global delay-timer 100
Use loopback-detection global enable to enable loop detection globally.
Use undo loopback-detection global enable to disable loop detection globally.
loopback-detection global enable vlan { vlan-id-list | all }
undo loopback-detection global enable vlan { vlan-id-list | all }
Loop detection is globally disabled.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The ID for vlan-id2 must be equal to or greater than the ID for vlan-id1.
Example
# Globally enable loop detection for VLAN 10 through VLAN 20.
[System] loopback-detection global enable vlan 10 to 20
Use loopback-detection interval-time to set the loop detection interval.
Use undo loopback-detection interval-time to restore the default.
loopback-detection interval-time interval
The loop detection interval is 30 seconds.
interval: Sets the loop detection interval in the range of 1 to 300 seconds.
With loop detection enabled, the device sends loop detection frames at the specified interval. A shorter interval offers more sensitive detection but consumes more resources. Consider the system performance and loop detection speed when you set the loop detection interval.
Example
# Set the loop detection interval to 10 seconds.
[Sysname] loopback-detection interval-time 10
