11-Security Command Reference
HomeSupportNFVH3C VSRReference GuidesCommand ReferencesH3C VSR Series Virtual Services Routers Command References(V7)-R0633-6W50111-Security Command Reference
05-Password control commands
05-Password control commands 143.24 KB
display password-control
Use display password-control to display password control configuration.
display password-control [ super ]
super: Displays the password control information for the super passwords. If you do not specify this keyword, the command displays the global password control configuration.
# Display the global password control configuration.
 Password control:                     Enabled (device management users)
                                       Enabled (network access users)
 Password aging:                       Enabled (90 days)
 Password length:                      Enabled (10 characters)
 Password composition:                 Enabled (1 types, 1 characters per type)
 Password history:                     Enabled (max history records:4)
 Early notice on password expiration:  7 days
 Maximum login attempts:               3
 Action for exceeding login attempts:  Lock user for 1 minutes
 Password history was last reset:      0 days ago (device management users)
                                       0 days ago (network access users)
 Minimum interval between two updates: 24 hours
 User account idle time:               90 days
 Logins with aged password:            3 times in 30 days
 Password complexity:                  Disabled (username checking)
                                       Disabled (repeated characters checking)
 Password change:                      Enabled (first login)
                                       Enabled (mandatory weak password change)
# Display the password control configuration for super passwords.
Password control
Whether the password control feature is enabled for device management users or network access users.
Password aging
Whether password expiration is enabled and, if enabled, the aging time.
Password length
Whether the minimum password length restriction feature is enabled and, if enabled, the setting.
Whether the password composition restriction feature is enabled and, if enabled, the settings.
Password history
Whether the password history management feature is enabled and, if enabled, the setting.
Number of days during which the user is notified of the pending password expiration.
Allowed maximum number of consecutive failed login attempts for FTP and VTY users.
Action to be taken after a user fails to log in after the specified number of attempts.
Last time when the password history records of the device management or network access users were deleted.
Minimum password update interval.
Number of times and maximum number of days a user can log in using an expired password.
Password complexity
Whether the following password complexity checking is enabled:
·     username checking—Checks whether a password contains the username or the reverse of the username.
·     repeated characters checking—Checks whether a password contains any character that appears consecutively three or more times.
Password change
Status of the password change features:
·     Enabled (first login).
·     Disabled (first login).
·     Enabled (mandatory weak password change).
·     Disabled (mandatory weak password change).
display password-control blacklist
Use display password-control blacklist to display password control blacklist information.
display password-control blacklist [ user-name user-name | ip ipv4-address | ipv6 ipv6-address ]
user-name user-name: Specifies a user by its username, a case-sensitive string of 1 to 55 characters.
ip ipv4-address: Specifies the IPv4 address of a user.
ipv6 ipv6-address: Specifies the IPv6 address of a user.
If you do not specify any parameters, this command displays information about all users in the password control blacklist.
The users' IP addresses and user accounts are added to the password control blacklist when the users fail authentication. You can use this command to view information about blacklisted FTP and virtual terminal line (VTY) users.
Users accessing the system through the console interface are not blacklisted for the following reasons:
·     The system is unable to obtain the IP addresses of these users.
·     These users are privileged and, therefore, relatively secure to the system.
# Display password control blacklist information.
<Sysname> display password-control blacklist
 Blacklist items matched: 2.
 Username                     IP address           Login failures   Lock flag
 abcd                         169::168:34:1        4                lock
 admin                        192.168.34.1         1                unlock
Number of blacklisted users.
IP address
IP address of the user.
Login failures
Number of login failures.
Lock flag
Whether the user account is locked for the user:
·     unlock—Not locked.
·     lock—Locked temporarily or permanently, depending on the password-control login-attempt command. The user cannot use the locked user account to log in from the locked IP address.
password-control { aging | composition | history | length } enable
Use password-control { aging | composition | history | length } enable to enable a password restriction feature.
Use undo password-control { aging | composition | history | length } enable to disable a password restriction feature.
The password restriction features are all enabled.
aging: Enables the password expiration feature.
composition: Enables the password composition restriction feature.
history: Enables the password history management feature.
length: Enables the minimum password length restriction feature.
The password expiration feature or the password history management feature takes effect only after the global password control is also enabled.
In non-FIPS mode, the password composition restriction and the minimum password length restriction are enabled by default regardless of whether or not the global password control feature is enabled. By default, a password must contain a minimum of four different characters.
In FIPS mode: The password composition restriction or the minimum password length restriction takes effect only after the global password control is also enabled. When the password composition restriction takes effect, a password, by default, must contain a minimum of 15 characters. When the minimum password length restriction takes effect, a password, by default, must contain a minimum of 4 different characters.
If a password of a device management user is in hashed form, a restriction setting does not take effect for the password even when the following requirements are met:
·     The global password control is enabled.
·     The specific password restriction feature is enabled.
For more information about configuring a password for a device management user, see "AAA commands."
If the password history management is disabled, the system will not compare the new password with history passwords, but the system will not stop recording history passwords. When the number of history password records of a user reaches the maximum number set by the password-control history command, the newest history record overwrites the earliest one.
# Enable the password control feature globally.
# Enable the password composition restriction feature.
[Sysname] password-control composition enable
# Enable the password expiration feature.
[Sysname] password-control aging enable
# Enable the minimum password length restriction feature.
[Sysname] password-control length enable
# Enable the password history management feature.
[Sysname] password-control history enable
Use password-control aging to set the password aging time.
Use undo password-control aging to restore the default.
A password expires after 90 days. The password aging time for a user group equals the global setting. The password aging time for a local user equals that of the user group to which the local user belongs.
User group view
Local user view
aging-time: Specifies the password aging time in days, in the range of 1 to 365.
The aging time depends on the view:
·     The time in system view has global significance and applies to all user groups.
·     The time in user group view applies to all local users in the user group.
·     The time in local user view applies only to the local user.
A password aging time with a smaller application scope has higher priority. The system prefers to use the password aging time in local user view for a local user.
·     If no password aging time is configured for the local user, the system uses the password aging time for the user group to which the local user belongs.
·     If no password aging time is configured for the user group, the system uses the global password aging time.
# Globally set the passwords to expire after 80 days.
[Sysname] password-control aging 80
# Set the passwords for user group test to expire after 90 days.
[Sysname] user-group test
[Sysname-ugroup-test] password-control aging 90
[Sysname-ugroup-test] quit
# Set the password for device management user abc to expire after 100 days.
[Sysname] local-user abc class manage
[Sysname-luser-manage-abc] password-control aging 100
display local-user ‌
display user-group ‌
password-control alert-before-expire
Use password-control alert-before-expire to set the number of days before a user's password expires during which the user is notified of the pending password expiration.
Use undo password-control alert-before-expire to restore the default.
The default is 7 days.
alert-time: Specifies the number of days before a user password expires during which the user is notified of the pending password expiration. The value range is 1 to 30.
This command is effective only for non-FTP users. FTP users can only have their passwords changed by the administrator.
# Configure the device to notify a user about pending password expiration 10 days before the user's password expires.
[Sysname] password-control alert-before-expire 10
password-control change-password first-login enable
Use password-control change-password first-login enable to enable the password change at first login feature.
Use undo password-control change-password first-login enable to disable the password change at first login feature.
The password change at first login feature is enabled.
For the password change at first login feature to take effect, make sure the global password control is enabled.
In FIPS mode, the password change at first login feature cannot be disabled.
# Enable the password change at first login feature.
[Sysname] password-control change-password first-login enable
password-control change-password weak-password enable
Use password-control change-password weak-password enable to enable mandatory weak password change.
Use undo password-control change-password weak-password enable to disable mandatory weak password change.
The mandatory weak password change feature is disabled.
The system checks for weak login passwords for Telnet, SSH, HTTP, or HTTPS device management users. A password is weak if it does not meet the following requirements:
·     Password composition restriction.
·     Minimum password length restriction.
·     Password complexity checking policy.
By default, the system displays a message about a weak password but does not force the user to change it. To improve the device security, you can enable the mandatory weak password change feature, which forces the users to change the identified weak passwords. The users can log in to the device only after their passwords meet the password requirements.
To view the password control settings, use the display password-control command. To change the password composition restriction, minimum password length, and password complexity checking policy, use the password-control composition, password-control length, and password-control complexity commands, respectively.
# Enable the mandatory weak password change feature.
[Sysname] password-control change-password weak-password enable
Use password-control complexity to configure the password complexity checking policy.
Use undo password-control complexity to remove a password complexity checking item.
undo password-control complexity { same-character | user-name } check
In non-FIPS mode:
The global password complexity checking policy is that username checking is enabled and repeated character checking is disabled. The password complexity checking policy for a user group equals the global setting. The password complexity checking policy for a local user equals that of the user group to which the local user belongs.
In FIPS mode:
The global password complexity checking policy is that both username checking and repeated character checking are disabled. The password complexity checking policy for a user group equals the global setting. The password complexity checking policy for a local user equals that of the user group to which the local user belongs.
User group view
Local user view
same-character: Refuses a password that contains a minimum of three consecutive identical characters. For example, the password aaabc is not complex enough.
user-name: Refuses a password that contains the username or the reverse of the username. For example, if the username is 123, a password such as abc123 or 321df is not complex enough.
The password complexity checking policy depends on the view:
·     The policy in system view has global significance and applies to all user groups.
·     The policy in user group view applies to all local users in the user group.
·     The policy in local user view applies only to the local user.
A password complexity checking policy with a smaller application scope has higher priority. The system prefers to use the password complexity checking policy in local user view for a local user.
·     If no policy is configured for the local user, the system uses the policy for the user group to which the local user belongs.
·     If no policy is configured for the user group, the system uses the global policy.
In non-FIPS mode: Username checking is independent of whether or not the global password control feature is enabled.
In FIPS mode: The password complexity checking takes effect only after you enable the global password control feature and execute the password-control complexity command.
You can enable both username checking and repeated character checking.
# Configure the password complexity checking policy, refusing any password that contains the username or the reverse of the username.
Use password-control composition to configure the password composition policy.
Use undo password-control composition to restore the default.
In non-FIPS mode:
The password using the global composition policy must contain a minimum of two character types and a minimum of one character for each type. The password composition policy for a user group is the same as the global policy. The password composition policy for a local user is the same as that of the user group to which the local user belongs.
In FIPS mode:
The password using the global composition policy must contain a minimum of four character types and a minimum of one character for each type. The password composition policy for a user group is the same as the global policy. The password composition policy for a local user is the same as that of the user group to which the local user belongs.
User group view
Local user view
type-number type-number: Specifies the minimum number of character types that a password must contain. The value range for the type-number argument is 1 to 4 in non-FIPS mode and fixed at 4 in FIPS mode.
type-length type-length: Specifies the minimum number of characters that are from each type in the password. The value range for the type-length argument is 1 to 63 in non-FIPS mode, and 1 to 15 in FIPS mode.
The password composition policy depends on the view:
A password composition policy with a smaller application scope has higher priority. The system prefers to use the password composition policy in local user view for a local user.
The product of the minimum number of character types and minimum number of characters for each type cannot be greater than the maximum length of passwords.
# Specify that all passwords must each contain a minimum of four character types and a minimum of five characters for each type.
[Sysname] password-control composition type-number 4 type-length 5
# Specify that passwords in user group test must contain a minimum of four character types and a minimum of five characters for each type.
[Sysname-ugroup-test] password-control composition type-number 4 type-length 5
# Specify that the password of device management user abc must contain a minimum of four character types and a minimum of five characters for each type.
[Sysname-luser-manage-abc] password-control composition type-number 4 type-length 5
Use password-control enable to enable the password control feature globally.
Use undo password-control enable to disable the password control feature globally.
password-control enable [ network-class ]
 undo password-control enable [ network-class ]
In non-FIPS mode:
The password control feature is disabled globally for device management and network access users.
In FIPS mode:
The password control feature is enabled globally and cannot be disabled for device management users.
The password control feature is disabled globally for network access users.
network-class: Enables global password control for network access users. If you do not specify this keyword, the command enables global password control for device management users.
When you enable global password control, the device automatically generates a .dat file and saves the file to the storage media. The file is used to record authentication and login information of local users. Do not manually delete or modify the file.
The password composition restriction, minimum password length, and username checking are independent of the global password control feature. Other password control features (such as password expiration or password history management) can take effect only after the global password control feature is also enabled.
After the global password control feature is enabled, the passwords configured for local users must contain a minimum of four different characters.
After the global password control feature is enabled for device management users, you cannot display the password and super password configuration for device management users by using the corresponding display commands.
After the global password control feature is enabled for network access users, you cannot display the password configuration for network access users by using the corresponding display commands.
You can configure all password control features for device management users.
You can configure only the following password control features for network access users:
·     Password composition policy.
·     Minimum password length.
·     Minimum password update interval.
·     Maximum number of history password records for each user.
# Enable the password control feature globally for device management users.
# Enable the password control feature globally for network access users.
[Sysname] password-control enable network-class
password-control update-interval
password-control expired-user-login
Use password-control expired-user-login to set the maximum number of days and maximum number of times that a user can log in after the password expires.
Use undo password-control expired-user-login to restore the defaults.
A user can use an expired password to log in three times within 30 days after the password expires. If all the three attempts fail or the user makes a login attempt after 30 days, the system prompts the user to set a new password.
delay delay: Specifies the maximum number of days during which a user can log in using an expired password. The value range for the delay argument is 1 to 90.
times times: Specifies the maximum number of times a user can log in after the password expires. The value range is 0 to 10. For a user to set a new password at the system prompt immediately after the password expires, set the value to 0.
This command is effective only on non-FTP login users. An FTP user cannot continue to log in after its password expires.
# Allow a user to log in five times within 60 days after the password expires.
Use password-control history to set the maximum number of history password records for each user.
Use undo password-control history to restore the default.
password-control history max-record-number
The maximum number of history password records for each user is 4.
max-record-number: Specifies the maximum number of history password records for each user. The value range is 2 to 15.
The global password control feature enables the system to record history passwords. When the number of history password records of a user reaches the maximum number, the newest history record overwrites the earliest one.
To delete the existing records, use one of the following methods:
·     Use the undo password-control enable command to disable the password control feature globally.
·     Use the reset password-control history-record command to clear the passwords manually.
# Set the maximum number of history password records for each user to 10.
[Sysname] password-control history 10
reset password-control blacklist
Use password-control length to set the minimum password length.
Use undo password-control length to restore the default.
In non-FIPS mode:
The global minimum password length is 10 characters.The minimum password length for a user group equals the global setting. The minimum password length for a local user equals that of the user group to which the local user belongs.
In FIPS mode:
The global minimum password length is 15 characters. The minimum password length for a user group equals the global setting. The minimum password length for a local user equals that of the user group to which the local user belongs.
User group view
Local user view
length: Specifies the minimum password length in characters. The value range for this argument is 4 to 32 in non-FIPS mode, and 15 to 32 in FIPS mode.
The minimum length setting depends on the view:
·     The setting in system view has global significance and applies to all user groups.
·     The setting in user group view applies to all local users in the user group.
·     The setting in local user view applies only to the local user.
A minimum password length with a smaller application scope has higher priority. The system prefers to use the minimum password length in local user view for a local user.
·     If no minimum password length is configured for the local user, the system uses the minimum password length for the user group to which the local user belongs.
·     If no minimum password length is configured for the user group, the system uses the global minimum password length.
# Set the global minimum password length to 16 characters.
# Set the minimum password length to 16 characters for the user group test.
[Sysname-ugroup-test] password-control length 16
# Set the minimum password length to 16 characters for the device management user abc.
[Sysname-luser-manage-abc] password-control length 16
password-control login idle-time
Use password-control login idle-time to set the maximum account idle time.
Use undo password-control login idle-time to restore the default.
The maximum account idle time is 90 days.
idle-time: Specifies the maximum account idle time in days. The value range is 0 to 365. 0 means no restriction for account idle time.
If a user account is idle for this period of time, the account becomes invalid and can no longer be used to log in to the device.
The account might become invalid if the system time changes after your last successful login. You cannot use an invalid account to log in. To disable the account idle time restriction, set the idle time value to 0.
# Set the maximum account idle time to 30 days.
Use password-control login-attempt to configure the login attempt limit. The settings include the maximum number of consecutive login failures and the action to be taken when the maximum number is reached.
Use undo password-control login-attempt to restore the default.
The global login-attempt settings:
·     The maximum number of consecutive login failures is 3.
·     The locking period is 1 minute.
The login-attempt settings for a user group equal the global settings.
The login-attempt settings for a local user equal those for the user group to which the local user belongs.
User group view
Local user view
login-times: Specifies the maximum number of consecutive login failures. The value range is 2 to 10.
exceed: Specifies an action if the user fails the maximum number of consecutive login attempts.
·     lock: Locks the user account and the user's IP address permanently. No one can use this user account to log in from this locked IP address.
·     lock-time time: Locks the user account and the user's IP address for a period of time. When the locking timer expires, users can use this user account to log in from the IP address. The value range for the time argument is 1 to 360 minutes.
·     unlock: Does not lock the user account. The user can continue using this account to make login attempts from the current IP address.
The login-attempt policy depends on the view:
A login-attempt policy with a smaller application scope has higher priority. The system prefers to use the login-attempt policy in local user view for a local user.
If an FTP or VTY user fails to log in, the system adds the user account and the user's IP address to the password control blacklist. When the maximum number of consecutive login failures is reached, the login attempt limit feature is triggered.
Whether a blacklisted user and user account are locked depends on the locking setting:
·     If a user account is permanently locked for a user, the user cannot use this account unless this account is removed from the password control blacklist. To remove the user account, use the reset password-control blacklist command.
·     To use a temporarily locked user account, the user can perform either of the following tasks:
¡     Wait until the locking timer expires.
¡     Remove the user account from the password control blacklist.
·     If the user account and the user are blacklisted but not locked, the user can continue using this account to log in. The account and the user's IP address are removed from the password control blacklist when the user uses the account to successfully log in to the device.
This account is locked only for the user at the locked IP address. A user from an unlocked IP address can still use this account, and the user at the locked IP address can use other unlocked user accounts.
The password-control login-attempt command takes effect immediately after being executed, and can affect the users already in the password control blacklist.
# Allow a maximum of four consecutive login failures on a user account, and lock the user account and the user's IP address permanently if the limit is reached.
[Sysname] password-control login-attempt 4 exceed lock
# Use the user account test to log in to the device, and enter incorrect password for four times.
# Display the password control blacklist. The output shows that the user account is on the blacklist, and its status is lock.
[Sysname] display password-control blacklist
 Blacklist items matched: 1.
 test                         192.168.44.1         4                lock
# Verify that the user at 192.168.44.1 cannot use this user account to log in.
# Allow a maximum of two consecutive login failures on a user account, and lock the account for 3 minutes if the limit is reached.
[Sysname] password-control login-attempt 2 exceed lock-time 3
# Use the user account test to log in to the device, and enter incorrect password for two attempts.
# Display the password control blacklist. The output shows that the user account is on the blacklist and its status is lock.
 test                         192.168.44.1         2                lock
# Verify that after 3 minutes, the user account is removed from the password control blacklist and the user at 192.168.44.1 can use this account.
password-control super aging
Use password-control super aging to set the aging time for super passwords.
Use undo password-control super aging to restore the default.
A super password expires after 90 days.
aging-time: Specifies the super password aging time in days, in the range of 1 to 365.
# Set the super passwords to expire after 10 days.
[Sysname] password-control super aging 10
password-control super composition
Use password-control super composition to configure the composition policy for super passwords.
Use undo password-control super composition to restore the default.
In non-FIPS mode:
A super password must contain a minimum of two character types and a minimum of one character for each type.
In FIPS mode:
A super password must contain a minimum of four character types and a minimum of one character for each type.
type-number type-number: Specifies the minimum number of character types that a super password must contain. The value range for the type-number argument is 1 to 4 in non-FIPS mode and fixed at 4 in FIPS mode.
type-length type-length: Specifies the minimum number of characters that are from each character type. The value range for the type-length argument is 1 to 63 in non-FIPS mode, and 1 to 15 in FIPS mode.
The product of the minimum number of character types and minimum number of characters for each type cannot be greater than the maximum length of the super password.
# Specify that a super password must contain a minimum of four character types and a minimum of five characters for each type.
password-control super length
Use password-control super length to set the minimum length for super passwords.
Use undo password-control super length to restore the default.
In non-FIPS mode:
The minimum super password length is 10 characters.
In FIPS mode:
The minimum super password length is 15 characters.
length: Specifies the minimum length of super passwords in characters. The value range for this argument is 4 to 63 in non-FIPS mode, and 15 to 63 in FIPS mode.
# Set the minimum length of super passwords to 16 characters.
[Sysname] password-control super length 16
Use password-control update-interval to set the minimum password update interval, which is the minimum interval at which users can change their passwords.
Use undo password-control update-interval to restore the default.
password-control update-interval interval
The minimum password update interval is 24 hours.
interval: Specifies the minimum password update interval in hours, in the range of 0 to 168. 0 means no requirements for password update interval.
The set minimum interval is not effective on a user who is prompted to change the password at the first login or after the password expires.
# Set the minimum password update interval to 36 hours.
Use reset password-control blacklist to remove blacklisted users.
reset password-control blacklist [ user-name user-name ]
user-name user-name: Specifies the username of a user account to be removed from the password control blacklist. The username is a case-sensitive string of 1 to 55 characters.
You can use this command to remove a user account and the user's IP address that are blacklisted due to excessive login failures. Then the user at this IP address can use this user account to log in.
# Remove the user account named test from the password control blacklist.
<Sysname> reset password-control blacklist user-name test
Are you sure to delete the specified user in blacklist? [Y/N]:
Use reset password-control history-record to delete history password records.
reset password-control history-record [ super [ role role name ] | user-name user-name | network-class [ user-name user-name ] ]
super: Deletes the history records of the specified super password or all super passwords.
role role name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the command deletes the history records of all super passwords.
network-class: Deletes the history password records of network access users. If you do not specify this keyword, the command deletes the history password records of device management users.
user-name user-name: Specifies the username of the user whose password records are to be deleted. The user-name argument is a case-sensitive string of 1 to 55 characters. If you do not specify this option, the command deletes all history password records of the specified user type.
If you do not specify any parameters, this command deletes the history password records of all device management users.
# Clear the history password records of all device management users.
<Sysname> reset password-control history-record
Are you sure to delete all local user's history records? [Y/N]:y
# Delete the history password records of all network access users.
<Sysname> reset password-control history-record network-class
Are you sure you want to delete all network access users' history records? [Y/N]:y
