- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-Emergency shell configuration
- 09-Automatic configuration
- 10-Device management configuration
- 11-Tcl configuration
- 12-Python configuration
- 13-License management
| 13-License management | 108.97 KB |
Licenses for different device types
Restrictions: Hardware compatibility with license management
Restrictions and guidelines: License management
License consistency in an IRF fabric
License registration and installation flowchart
License management tasks at a glance
Identifying the license storage
Compressing the license storage
Obtaining required information for license registration
Registering licenses for the first time
Restrictions and guidelines for license installation
Restrictions and guidelines for license uninstallation
Uninstalling an activation file
Display and maintenance commands for license management
Managing licenses
About licenses
License-based features, such as Comware software package, RTC terminal access, POS terminal access, IPS signature database, ACG signature database, SSL VPN, and Web caching., require licenses to run on your device.
License types
Licenses include trial licenses and formal licenses. Trial licenses typically have time limits. After a trial license expires, the license-based feature is not available unless you purchase and install a formal license for the feature.
(In standalone mode.) You must purchase a license key for the entire device. To license the device, use the license key and the device's SN and DID to register an activation file and install the activation file on the device.
You must purchase a license key for each IRF member device. To license an IRF member device, use the license key and the member's SN and DID to register an activation file and install the activation file on the IRF member device. An IRF member device is licensed even if the device joins another IRF fabric.
Licenses for devices include package licenses and feature licenses.
H3C website provides the same license registration procedure for package licenses and feature licenses.
Comware package license
For the support of hardware platforms for Comware packages, the following matrixes show the necessity of Comware package license:
Hardware |
Comware package license necessity |
MSR5620 |
No |
MSR5660, MSR5680 |
· When MPU-100 is installed: Yes · When MPU-100-X1 is installed: No |
The device software image includes the following software:
· Boot ROM image
· System image
· Feature packages:
¡ Data feature package—Includes the features such as MPLS and DLSw.
¡ Security feature package—Includes the features such as VPN.
¡ Voice feature package—Includes the features such as BUSYOUT and voice.
The Boot ROM image and system image are required for the system to work, and they do not need any licenses.
The feature packages are all license-based features. You must register and activate the license for a feature to run on your device.
After a Comware package license is correctly installed, the system will automatically search the storage media for a matching feature package. If no match is found, you are required to load the feature package and install it. If a match is found, the system will install the feature package. If the installation fails because of device poweroff or reboot, you are required to manually install the feature package when the device is powered on again. Use the display boot-loader command to verify that the feature package is installed successfully.
IMPORTANT: During the installation of feature packages, do not execute the save command. The violation will cause configuration loss. |
Feature license
ATC license
To use the RTC terminal access feature, you must install ATC licenses.
IP POS license
The following compatibility matrix shows the support of hardware platforms for IP POS license:
Hardware |
IP POS license compatibility |
MSR5620 |
No |
MSR5660, MSR5680 |
Yes Supports a maximum of 4096 TCP connections with POS terminals. |
To establish TCP connections with POS terminals, you must install IP POS licenses on the device. The IP POS licenses control the number of TCP connections established between the device and POS terminals. When the device is installed with an IP POS license, the device is allowed to establish a maximum of 256 TCP connections with POS terminals. You can increase the number of allowed TCP connections by installing multiple IP POS licenses.
The E1POS interface modules are not subject to IP POS licenses. An E1POS interface module can function correctly even if no IP POS licenses are installed.
IPS license
To update the IPS signature database, you must install IPS licenses on the device.
IPS licenses are time-based, including licenses valid for one year and licenses valid for three years. The license validity period can be accumulated by installing multiple IPS licenses.
ACG license
To update the ACG signature database, you must install ACG licenses on the device.
ACG licenses are time-based, including licenses valid for one year and licenses valid for three years. The increase validity period can be accumulated by by installing multiple ACG licenses.
SSL VPN license
By default, no SSL VPN license is installed and the device allows 15 SSL VPN users to come online. To allow more SSL VPN users to come online, you can install SSL VPN licenses on the device. The SSL VPN licenses control the number of online SSL VPN users. Based on the allowed user number, SSL VPN licenses include the following types:
· SSL VPN licenses that allow a maximum of 30 online SSL VPN users.
· SSL VPN licenses that allow a maximum of 200 online SSL VPN users.
You can increase the number of allowed online SSL VPN users by installing multiple SSL VPN licenses.
Web cache license
To use the Web caching feature, you must install the activation file for the Web cache license.
Management operation
Make sure no one else is performing license management tasks on the device you are working with.
Activation file operations
When you manage activation files, follow these restrictions and guidelines:
· Do not open and edit the files to avoid file corruption.
· Do not modify the names of the files to avoid licensing error.
· For licensed features to function correctly, do not delete files that are usable or in use in the flash:/license directory. The license management feature uses this directory for license management.
For licensed features to function correctly in an IRF fabric, make sure all IRF member devices are installed with the same licenses.
Figure 1 License registration and installation flowchart
To manage licenses, perform the following tasks:
1. Identifying the license storage
2. (Optional.) Compressing the license storage
3. Obtaining required information for license registration
6. Managing installed licenses
¡ Recovering an activation file
To identify the license storage, execute the following command in any view:
display license feature
From the command output, view the Total and Usage fields to examine whether the remaining license storage is sufficient for installing new licenses. If the remaining license storage is not sufficient, compress the license storage.
Compress the license storage to delete expired and uninstalled license information to ensure sufficient storage space for installing new licenses.
The compression operation clears expired licenses and uninstalled licenses that are installed by using activation files.
If uninstalled licenses or expired licenses exist on the device, the compression operation will make the DID change. Before performing a compression, make sure all licenses registered with the old DID have been installed. You will be unable to install such licenses after the compression.
1. Back up the Uninstall keys of uninstalled licenses.
When you uninstall an unexpired license, an Uninstall key is created. The Uninstall key is required for transferring the license.
2. Make sure all licenses generated based on the old DID have been installed.
3. Enter system view.
4. Compress the license storage.
In standalone mode:
license compress
In IRF mode:
license compress chassis chassis-number
1. Identify whether the required features need to be licensed on the device.
Execute the following command in any view:
2. Execute the following command in any view to display the current license status.
In standalone mode:
display license [ activation-file ] [ slot slot-number ]
In IRF mode:
display license [ activation-file ] [ chassis chassis-number slot slot-number ]
3. Obtain the license key by purchasing a license.
The authorization serial number in the Software License Certificate is the license key.
4. Execute the following command in any view to obtain the SN and DID information.
In standalone mode:
display license device-id slot slot-number
In IRF mode:
display license device-id chassis chassis-number slot slot-number
5. Back up the license key in case of loss.
Registering a license
About registering a license
License registration has the following procedures:
· Registering licenses for the first time—Register a license for a device that has not previously been registered.
· Registering upgrade licenses—Register licenses for capacity expansion, feature enhancement, or a time extension. This procedure is also applicable to the scenario that you register a new license for a device that has expired or uninstalled licenses.
If you do not know which registration procedure should be used, select registering licenses for the first time. If the selection is not correct, the website will display messages for the correct registration choice after you enter the required information.
If you cannot download the activation file due to problems such as operating system and browser errors, try to re-register the license. If the problem persists, contact H3C Support.
1. Visit the H3C website at http://www.h3c.com/en/License/.
2. Select Register the First Time.
3. Enter the authorization serial number in the Input the license key field and click Submit.
A dialog box opens, displaying product categories matching the license key.
4. In the dialog box, select a product category from the Product category dropdown list and click OK.
5. Enter the device S/N.
6. Upload the DID file.
7. Enter the required contact information and verify code, select I accept all terms of H3C Legal Statement, and click Get activation key or file.
8. Download the activation file to the PC.
A copy of the activation file will also be sent to the email address that you enter in the contact information.
2. Select Register Upgrade Licenses.
6. Upload the DID file and click Submit.
Installing a license
When installing a license, the system automatically searches the storage media for a matching feature package. When a match is found, it stops searching and installs the package.
Installing an activation file
1. Enter system view.
2. Install an activation file.
In standalone mode:
license activation-file install license-file
In IRF mode:
license activation-file install license-file chassis chassis-number
Uninstalling a license
About license uninstallation
Perform this task to uninstall an unexpired formal license when the license remains unused for a while or needs to be transferred to another device.
After uninstallation, Uninstall keys are generated, which will be used for license transfer.
Trial licenses cannot be transferred. Uninstall a trial license does not create any uninstallation information.
Expired licenses cannot be uninstalled.
A license that was uninstalled on a device cannot be re-installed on the device. It can only be transferred to another device.
2. Uninstall an activation file.
In standalone mode:
license activation-file uninstall license-file
In IRF mode:
license activation-file uninstall license-file chassis chassis-number
Only unexpired activation files can be uninstalled.
Transferring a license
You can transfer a license from one device to another if the license has not expired.
1. Log in to the source device, and uninstall the license to obtain the uninstallation information. For more information, see "Uninstalling a license."
2. Obtain the Uninstall key of the license by using the display license command.
3. Access the target device and obtain SN and DID information. For more information, see "Obtaining required information for license registration."
4. Register a license for the target device. For more information, see "Registering a license."
During the license register, you must provide SN and DID information of the target device and the Uninstall key of the source device.
5. Install the new license on the target device. For more information, see "Installing a license."
If you mistakenly delete an activation file, use the following procedure to recover the activation file:
1. Use the copy command to copy the backup activation file to directory flash:/license.
2. Use the display license command to verify that the state of the recovered activation file is In use.
3. Restart the device if the license state is In use but the licensed feature cannot function correctly.
Task |
Command |
Display detailed license information. |
In standalone mode: display license [ activation-file ] In IRF mode: display license [ activation-file ] [ chassis chassis-number ] |
Display the SN and DID information. |
In standalone mode: display license device-id In IRF mode: display license device-id chassis chassis-number |
Display brief feature license information. |
display license feature |
