| 03-Feature navigator | 136.34 KB |
Feature navigator
Menu items and icons available to you depend on the user roles you have. By default, you can use any user roles to display information. To configure features, you must have the network-admin user role. This chapter describes all menus available for the network-admin user role.
Top-level menus differ in system view and in network view. You can toggle between these two views by clicking the view tab at the bottom of the page. For each top menu, a navigator table is provided. Use the navigator tables to navigate to the pages for the tasks you want to perform.
For example:
· To change the default device name, perform the following tasks:
a. Click the system view tab at the bottom of the page.
b. From the navigation tree, select System > Management. You are placed on the Settings tab.
· To delete an IPv4 ACL, perform the following tasks:
b. From the navigation tree, select System > Resource. You are placed on the IPv4 ACL tab.
NOTE: In the navigator tables, a menu is in boldface if it has submenus. |
Feature navigator in system view
Top-level menus in system view include Dashboard, Network Configuration, Network Security, System, and Tools.
Dashboard menu
The dashboard menu provides an overview of the system and its running status, including the following information:
· Event logs.
· AP statistics.
· System utilization information.
· Wireless service statistics.
· Client statistics.
· Traffic monitoring statistics.
This menu does not contain submenus.
Network configuration menu
Use Table 1 to navigate to the tasks you can perform from the Network Configuration menu.
Table 1 Network configuration menu navigator
Menus |
Tasks |
Network Interfaces |
Interfaces |
· Display interfaces and their attributes, including: ¡ Interface status. ¡ IP address. ¡ Speed and duplex mode. ¡ Interface description. · Delete logical interfaces. · Modify interfaces. |
Link Aggregation |
Create, modify, or delete Layer 2 aggregation groups. |
VLAN |
VLAN |
· Configure port-based VLANs. · Create VLAN-interfaces. |
MAC |
· Create or delete static MAC entries, dynamic MAC entries, and blackhole MAC entries. · Display existing MAC entries. |
STP |
· Enable or disable STP globally or on a specific interface · Set the STP, RSTP, MSTP, or PVST mode · Configure instance priorities · Configure MST regions |
Network Routing |
Routing Table |
Display IPv4 and IPv6 routing table information, including brief routing table information and route statistics. |
Static Routing |
· Display IPv4 and IPv6 static routing entries. · Create, modify, or delete IPv4 and IPv6 static routing entries. |
Network Services-IP Services |
IP |
· Configure the method to obtain an IP address (DHCP or static). · Configure the IP address or MTU of an interface. · Create a loopback interface. |
IPv6 |
· Configure the method to obtain an IPv6 address (manual assignment, dynamic assignment, or auto generation). · Configure the IPv6 address of an interface. · Create a loopback interface. |
Network Services-DHCP/DNS |
DHCP |
· Configure DHCP server functions, including: ¡ Configure DHCP services. ¡ Configure the interface to operate in the DHCP server mode. ¡ Configure DHCP address pools. ¡ Configure IP address conflict detection. · Configure DHCP relay agent functions, including: ¡ Configure DHCP services. ¡ Configure the DHCP relay agent mode. ¡ Configure the IP address of the DHCP server. · Configure settings for DHCP relay entry, include: ¡ Recording of DHCP relay entries. ¡ Periodic refreshing of DHCP relay entries. ¡ Interval for refreshing DHCP relay entries. |
IPv4 DNS |
· Configure IPv4 static domain name resolution. · Configure IPv4 dynamic domain name resolution. · Configure the DNS proxy. · Configure IPv4 domain name suffixes. |
IPv6 DNS |
· Configure static and dynamic IPv6 domain name resolution. · Configure the IPv6 DNS proxy. · Configure IPv6 domain name suffixes. |
Network Services-Multicast |
IGMP Snooping |
Configure IGMP snooping functions, including: · Enable or disable IGMP snooping in a VLAN. · Query IGMP snooping entries. · Enable dropping unknown multicast data. · Configure the IGMP snooping querier. · Enable fast-leave processing. · Set the maximum number of multicast groups on a port. |
MLD Snooping |
Configure MLD snooping functions, including: · Enable or disable MLD snooping in a VLAN. · Query MLD snooping entries. · Enable dropping unknown IPv6 multicast data. · Configure the MLD snooping querier. · Enable fast-leave processing. · Set the maximum number of IPv6 multicast groups on a port. |
Network Services-ARP |
ARP |
· Add static ARP entries. · Delete dynamic ARP entries and static ARP entries. · Configure the ARP proxy. · Configure gratuitous ARP. · Configure ARP attack protection. |
Network Services-ND |
ND |
· Add static ND entries. · Delete dynamic ND entries and static ND entries. · Configure the aging time for stale ND entries. · Enable or disable link local ND entry minimization. · Configure hop limit. · Configure RA prefix attributes, including: ¡ Address prefix. ¡ Prefix length. ¡ Valid lifetime. ¡ Preferred lifetime. · Configure RA settings for an interface, including: ¡ RA message suppression. ¡ Maximum and minimum intervals for sending RA messages. ¡ M-flag. ¡ MTU option. ¡ Hop limit. ¡ O-flag. ¡ Router lifetime. ¡ NS message retransmit interval. ¡ Router preference. ¡ Neighbor reachable time. · Enable common and local ND proxy on an interface. · Configure ND rules for the interface, including: ¡ Maximum number of dynamic neighbor entries. ¡ Maximum number of DAD attempts. |
Management Protocols |
HTTP/HTTPS |
· Enable or disable HTTP service. · Enable or disable HTTPS service. · Set the Web connection timeout. · Set the HTTP service port number. · Set the HTTPS service port number. · Specify Web access control ACLs. |
Telnet |
· Enable or disable Telnet service. · Set the DSCP values for the device to use for outgoing IPv4 or IPv6 Telnet packets. · Specify Telnet access control ACLs. |
SSH |
· Enable or disable the Stelnet, SFTP, and SCP services. · Configure SSH parameters. |
NTP |
· Enable or disable the NTP service. · Configure the IP address and stratum level of the local clock. · Set an NTP authentication key. |
LLDP |
· Enable or disable LLDP. · Enable or disable CDP compatibility. · Configure LLDP parameters. · Display interface status. · Configure the interface status. · Display LLDP neighbors. · Configure LLDP to advertise the specified TLVs. |
Settings |
· Enable or disable log output to the log buffer, and configure the maximum number of logs in the log buffer. · Configure the address and port number of log hosts. |
Network security menu
Use Table 2 to navigate to the tasks you can perform from the Network Security menu.
Table 2 Network security menu navigator
Menus |
Tasks |
Packet Filter |
Packet Filter |
· Create, modify, or delete a packet filter for an interface. · Configure the default action for the packet filter. |
Traffic Policy |
QoS Policies |
Create, modify, or delete interface QoS policies. |
Priority Mapping |
· Query or configure the port priority. · Configure the priority trust mode for a port. · Query or modify the priority mapping table. |
Access Control |
802.1X |
· Enable or disable 802.1X. · Configure the 802.1X authentication method. · Configure the port access control method. · Configure the maximum number of concurrent 802.1X users on the port. · Configure advanced 802.1X features. |
Authentication |
ISP Domains |
· Add, modify, or delete ISP domains. · Configure the domain name, state, access method, and advanced settings for an IPS domain. · Configure the default ISP domain. |
RADIUS |
· Add, modify, or delete RADIUS schemes. · Configure the scheme name, authentication server, accounting server, shared key, and advanced settings. · Enable or disable receiving of session control packets. |
User Management |
Local Users |
· Add, modify, or delete local users. · Add, modify, or delete local user groups. |
System menu
Use Table 3 to navigate to the tasks you can perform from the System menu.
Menus |
Tasks |
Event Logs |
Event Logs |
Query, collect, or delete log information. |
Resource |
IPv4 ACL |
· Create, modify, or delete an IPv4 basic ACL. · Create, modify, or delete an IPv4 advanced ACL. |
IPv6 ACL |
· Create, modify, or delete an IPv6 basic ACL. · Create, modify, or delete an IPv6 advanced ACL. |
Layer 2 ACLs |
Create, modify, or delete an Ethernet frame header ACL. |
Time range |
Create, modify, or delete a time range. |
File Systems |
File System Management |
Upload, download, or delete files. |
Administrators |
Administrators |
· Create, modify, or delete roles. · Create, modify, or delete administrators. · Configure the role of administrators. · Control administrator access authority. · Manage passwords. |
Management |
Settings |
· Set the name, location, and contact information of the device. · Set the system time. |
Configuration |
· Save or export the running configuration. · Import configuration. · Display the running configuration. · Restore the settings to the factory defaults. |
Upgrade |
· Upgrade system software. · Display system software lists, including: ¡ List of software enabled at the current system startup. ¡ List of main software to be enabled at the next system startup. |
Reboot |
Reboot the device. |
About |
Display basic device information, including device name, serial number, model, description, location, contact information, version, electronic label, and statement. |
Tools menu
Use Table 4 to navigate to the tasks you can perform from the Tools menu.
Menus |
Tasks |
Debug |
Diagnostics |
Collect diagnostic information for locating problems. |
Ping |
IPv4 Ping |
Identify whether an IPv4 address is reachable. |
IPv6 Ping |
Identify whether an IPv6 address is reachable. |
Tracert |
IPv4 Tracert |
Trace the path of IPv4 packets from source to destination. |
IPv6 Tracert |
Trace the path of IPv6 packets from source to destination. |
Feature navigator in network view
Top-level menus in network view include Dashboard, Quick Start, Monitoring, Wireless Configuration, Network Security, System , Tools, and Reporting.
Dashboard menu
· Event logs.
· AP statistics.
Quick start menu
Use Table 5 to navigate to the tasks you can perform from the Quick Start menu.
Table 5 Quick start menu navigator
Menus |
Tasks |
Add New AP |
Add New AP |
Add new APs manually. |
Add New SSID |
Add New SSID |
· Configure wireless services. · Configure link layer authentication. · Enable or disable authorization. · Enable or disable intrusion detection. · Configure key management. · Bind APs. |
Add New User |
Add New User |
Add new users. |
Monitoring menu
Use Table 6 to navigate to the tasks you can perform from the Monitoring menu.
Table 6 Monitoring menu navigator
Menus |
Tasks |
Wireless Networks |
Wireless Services |
Display wireless services. |
Access Points |
APs |
Display AP statistics. |
AP Groups |
Display AP groups. |
Clients |
Clients |
Display client statistics. |
Wireless Security |
WIPS |
Display WIPS statistics. |
RRM |
RF Optimization |
Display channel and power adjustment information. |
Application Monitoring |
Bonjour |
· Display Bonjour service information discovered by Bonjour gateways. · Clear Bonjour service resource information. |
Multicast Optimization |
Display IPv4 and IPv6 multicast statistics. |
Wireless configuration menu
Use Table 7 to navigate to the tasks you can perform from the Wireless Configuration menu.
Table 7 Wireless configuration menu navigator
Menus |
Tasks |
Wireless Networks |
Wireless Networks |
· Display wireless services. · Add, delete, or modify wireless services. · Configure link layer authentication. · Enable or disable authorization and intrusion detection. · Manage keys. · Bind APs. · Configure access control. |
AP Management |
AP |
Add, modify, delete, or query APs. |
AP Groups |
Create, query, modify, or delete AP groups. |
AP Global Settings |
· Configure AP region codes. · Enable or disable region code lock. · Enable or disable AP software upgrade. · Enable or disable auto AP. · Enable or disable auto-AP persistence. |
Wireless QoS |
Client Rate Limiting |
· Display detailed information about client rate limit. · Configure client-type-based client rate limit. · Configure service-based client rate limit. · Configure AP radio or AP group radio-based client rate limit. |
Bandwidth Guaranteeing |
· Display detailed information about intelligent bandwidth guarantee. · Set the maximum radio bandwidth. · Configure intelligent bandwidth guarantee for an AP or AP group. |
Wi-Fi Multimedia |
· Display wireless QoS status and information. · Display radio EDCA parameters. · Display radio and client negotiation parameters. · Display WMM statistics for clients. · Display transport stream information. |
Wireless Security |
WIPS |
· Display detailed WIPS information. · Enable WIPS. · Configure VSDs. · Configure classification policies. · Configure attack detection policies. · Configure signature policies. · Configure countermeasure policies. · Configure AP classification rules. · Configure signatures. · Add MAC addresses to the alarm-ignored device list. |
Whitelist and blacklist |
· Configure whitelists. · Configure static and dynamic blacklists. |
Radio Management |
Radio Configuration |
Display detailed model and radio information for all APs in an AP group. |
RRM |
· Display channel and power adjustment information. · One-key channel and power optimization. · Configure RRM for APs and AP groups: ¡ Configure RRM holddown groups. ¡ Configure radio baselines. · Display RRM adjustment history. |
Load Balancing |
· Enable load balancing. · Configure the load balancing mode. · Configure load balancing groups. · Configure load balancing parameters. |
Band Navigation |
· Enable or disable global band navigation. · Enable or disable band navigation for APs and AP groups. · Configure band navigation parameters. |
Applications |
· Display IPv4 multicast optimization. · Configure IPv4 multicast optimization. · Display IPv6 multicast optimization. · Configure IPv6 multicast optimization. |
Bonjour |
· Enable or disable the Bonjour gateway feature. · Create and activate Bonjour service types. · Change the Bonjour gateway mode. · Configure Bonjour policies. |
Use Table 8 to navigate to the tasks you can perform from the Network Security menu.
Table 8 Network security menu navigator
Menus |
Tasks |
Packet Filter |
Packet Filter |
Traffic Policy |
QoS Policies |
Priority Mapping |
· Query and configure the port priority. · Configure the priority trust mode for a port. · Query and modify the priority mapping table. |
Access Control |
802.1X |
Authentication |
ISP Domains |
· Add, modify, or delete ISP domains. · Configure the domain name, state, access method, and advanced settings of an IPS domain. · Configure the default ISP domain. |
RADIUS |
User Management |
Local Users |
· Add, modify, or delete local users. · Add or modify local user groups. |
Guest Management |
Guest List |
Query, add, or export guests. |
Import Guests |
Import guests. |
Generate Guest Accounts |
Generate guests in bulk. |
Approve Guest |
Approve guests. |
Guest Configuration |
Configure guest parameters. |
Access Control |
MAC Authentication |
· Enable or disable MAC authentication. · Enable MAC authentication for an interface and set the maximum number of concurrent MAC authentication users on a port. · Configure the quiet timer. · Configure advanced MAC authentication settings. |
Port Security |
· Enable or disable port security. · Specify the port security mode. · Configure advanced port security settings. |
Portal |
· Configure the portal authentication server. · Configure the portal Web server. · Configure the local portal Web server. · Configure portal-free rules. · Configure interface policies. · Configure online user information. |
System menu
Use Table 9 to navigate to the tasks you can perform from the System menu.
Menus |
Tasks |
Resource |
IPv4 ACL |
· Create basic or advanced IPv4 ACLs. · Modify or delete ACLs on this page and other service module pages, such as the packet filtering page. |
IPv6 ACL |
· Create basic or advanced IPv6 ACLs. · Modify or delete ACLs on this page and other service module pages, such as the packet filtering page. |
Layer 2 ACLs |
· Create Ethernet ACLs. · Modify or delete ACLs on this page and other service module pages, such as the packet filtering page. |
Time range |
Create, modify, or delete time ranges. |
Tools menu
Use Table 10 to navigate to the tasks you can perform from the Tools menu.
Menus |
Tasks |
Wireless Capture |
Wireless Capture |
Display captured wireless packets. |
Debug |
Diagnostics |
Reporting menu
Use Table 11 to navigate to the tasks you can perform from the Reporting menu.
Table 11 Reporting menu navigator
Menus |
Tasks |
Client Statistics |
AC Frame |
Display transmitted/received/dropped AC frames. |
AC Bytes |
Display transmitted/received/dropped AC bytes. |
Total Frame |
Display total transmitted, received, and dropped frames. |
Total Bytes |
Display total transmitted, received, and dropped bytes. |
AP Statistics |
AP Statistics |
Wireless Service Statistics |
Display wireless service statistics. |
