01-Fundamentals Command Reference
HomeSupportSwitchesH3C S7500X Switch SeriesReference GuidesCommand ReferencesH3C S7500X Switch Series Command References-Release7634Pxx-6W10001-Fundamentals Command Reference
13-Device management commands
13-Device management commands 546.77 KB
Device management commands· 1
clock datetime· 1
clock protocol 2
clock summer-time· 3
clock timezone· 4
command· 5
copyright-info enable· 6
display alarm·· 7
display asset-info· 8
display clock· 9
display copyright 10
display cpu-usage· 10
display cpu-usage configuration· 12
display cpu-usage history· 13
display device· 15
display device manuinfo· 16
display device manuinfo chassis-only· 17
display device manuinfo fan· 18
display device manuinfo power 18
display device uptime· 19
display diagnostic-information· 20
display environment 22
display environment history· 23
display fan· 26
display hardware-failure-detection· 27
display memory· 28
display memory-threshold· 30
display power 32
display power-supply· 34
display resource-monitor 36
display scheduler job· 37
display scheduler logfile· 37
display scheduler reboot 38
display scheduler schedule· 39
display serial-no· 40
display switch-mode status· 41
display system health· 43
display system health history· 45
display system stable state· 46
display system-working-mode· 48
display transceiver alarm·· 48
display transceiver diagnosis· 49
display transceiver interface· 50
display transceiver manuinfo· 51
display version· 51
display version-update-record· 52
display xbar 53
fabric load-sharing mode· 54
forward-path-detection enable· 55
hardware-failure-detection· 55
header 56
job· 57
memory-threshold· 58
memory-threshold usage· 60
monitor cpu-usage enable· 61
monitor cpu-usage interval 62
monitor cpu-usage logging interval 63
monitor cpu-usage threshold· 63
monitor handshake-timeout disable-port 64
monitor memory-usage logging interval 65
monitor resend cpu-usage· 66
monitor resend memory-threshold· 67
parity-error consistency-check log enable· 68
parity-error consistency-check threshold· 69
parity-error monitor log enable· 70
parity-error monitor period· 70
parity-error monitor threshold· 71
parity-error unrecoverable log enable· 72
parity-error unrecoverable period· 73
parity-error unrecoverable reboot 74
parity-error unrecoverable threshold· 74
password-recovery enable· 75
power-supply off 76
power-supply on· 77
power-supply policy enable· 77
power-supply policy priority· 78
power-supply policy redundant 79
reboot 80
reset asset-info· 82
reset scheduler logfile· 83
reset version-update-record· 83
resource-monitor minor resend enable· 84
resource-monitor output 85
resource-monitor resource· 86
restart standby· 88
restore factory-default 88
scheduler job· 89
scheduler logfile size· 90
scheduler reboot at 90
scheduler reboot delay· 91
scheduler schedule· 92
set asset-info· 93
set serial-no· 94
shutdown-interval 95
switch-mode· 96
sysname· 98
system switchover 99
system-working-mode· 99
temperature-limit 100
time at 102
time once· 102
time repeating· 104
transceiver phony-alarm-disable· 105
user-role· 106
xbar 107
clock datetime
Use clock datetime to set the system time.
clock datetime time date
The factory-default system time is used.
time: Specifies a time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
date: Specifies a date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION
CAUTION:
Change of the system time affects execution of system time-related features (such as scheduled tasks) and cooperative operation with other devices (such as log reporting and statistics collection). Before executing this command, make sure you understand its impact on the live network.
This command is supported only on the default MDC.
Correct system time is essential to network management and communication. You must configure the system time correctly before you run the device on the network.
For the device to use the local system time, execute the clock protocol none command and this command in turn. The specified system time takes effect immediately. Then, the device uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
# Set the system time to 08:08:08 01/01/2015.
<Sysname> clock datetime 8:8:8 1/1/2015
# Set the system time to 08:10:00 01/01/2015.
<Sysname> clock datetime 8:10 2015/1/1
clock protocol
clock summer-time
clock timezone
display clock
clock protocol
Use clock protocol to specify the system time source.
Use undo clock protocol to restore the default.
clock protocol { none | { ntp | ptp } mdc mdc-id }
undo clock protocol
The device obtains the UTC time from an NTP time source specified on the default MDC.
none: Uses the system time set by using the clock datetime command.
ptp: Uses PTP to obtain the UTC time. You must configure PTP correctly. For more information about PTP and PTP configuration, see Network Management and Monitoring Configuration Guide.
ntp: Uses NTP to obtain the UTC time. You must configure NTP correctly. For more information about NTP and NTP configuration, see Network Management and Monitoring Configuration Guide.
mdc mdc-id: Specifies the MDC to be used for time synchronization. The value range is 1 to 5.
The device can use the locally set system time, or obtain the UTC time from a time source on the network and calculate the system time.
If you execute the clock protocol none command, the device uses the locally set system time. The device then uses the clock signals generated by its built-in crystal oscillator to maintain the system time.
If you execute the clock protocol { ntp | ptp } command, the device obtains the UTC time through NTP or PTP and calculates the system time. The device then periodically synchronizes the UTC time and recalculates the system time.
All MDCs on the device use the same system time. After obtaining the system time from an MDC, the device automatically synchronizes the system time to the other MDCs.
# Configure the device to use the local UTC time.
[Sysname] clock protocol none
clock summer-time
Use clock summer-time to set the daylight saving time.
Use undo clock summer-time to restore the default.
The daylight saving time is not set.
name: Specifies a name for the daylight saving time schedule, a case-sensitive string of 1 to 32 characters.
start-time: Specifies the start time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
start-date: Specifies the start date in one of the following formats:
·     MM/DD. The value range for MM is 1 to 12. The value range for DD varies by month.
·     month week day, where:
¡     month—Takes January, February, March, April, May, June, July, August, September, October, November or December.
¡     week—Represents week of the month. It takes first, second, third, fourth, fifth, or last.
¡     day—Takes Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, or Saturday.
end-time: Specifies the end time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
end-date: Specifies the end date in one of the following formats:
add-time: Specifies the time to be added to the standard time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the daylight saving time, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same daylight saving time as the local time.
# Set the system time ahead 1 hour for the period between 06:00:00 on 08/01 and 06:00:00 on 09/01.
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
clock datetime
clock timezone
display clock
clock timezone
Use clock timezone to set the time zone.
Use undo clock timezone to restore the default.
undo clock timezone
The UTC time zone is used.
zone-name: Specifies a time zone by its name, a case-sensitive string of 1 to 32 characters.
add: Adds an offset to the UTC time.
minus: Decreases the UTC time by an offset.
zone-offset: Specifies an offset to the UTC time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
After you set the time zone, the device recalculates the system time. To view the system time, use the display clock command.
Make sure all devices on the network are using the same time zone as the local time.
# Set the name of the time zone to Z5, and add 5 hours to the UTC time.
[Sysname] clock timezone Z5 add 5
clock datetime
clock summer-time
display clock
command
Use command to assign a command to a job.
Use undo command to revoke a command.
command id command
undo command id
No command is assigned to a job.
Job view
id: Specifies an ID for the command, in the range of 0 to 4294967295. A command ID uniquely identifies a command in a job. Commands in a job are executed in ascending order of their command IDs.
command: Specifies the command to be assigned to the job.
To assign a command (command A) to a job, you must first assign the job the command or commands for entering the view of command A.
If you specify the ID of an existing command for another command, the existing command is replaced.
Make sure all commands in a schedule are compliant to the command syntax. The system does not examine the syntax when you assign a command to a job.
If a command requires a yes or no answer, the system always assumes that a Y or Yes is entered. If a command requires a character string input, the system assumes that either the default character string (if any) or a null string is entered.
A job cannot contain the telnet, ftp, ssh2, or monitor process command.
# Assign commands to the backupconfig job to back up the startup.cfg file to the TFTP server at 192.168.100.11.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# Assign commands to the shutdownGE job to shut down Ten-GigabitEthernet 1/0/1.
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface ten-gigabitethernet 1/0/1
[Sysname-job-shutdownGE] command 3 shutdown
scheduler job
Use copyright-info enable to enable copyright statement display.
Use undo copyright-info enable to disable copyright statement display.
Copyright statement display is enabled.
# Enable copyright statement display.
[Sysname] copyright-info enable
The device will display the following statement when a user logs in:
* Without the owner's prior written consent,                                 *
* no decompiling or reverse-engineering shall be allowed.                    *
display alarm
Use display alarm to display alarm information.
In standalone mode:
display alarm [ slot slot-number ]
In IRF mode:
display alarm [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays alarm information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays alarm information for all cards. (In IRF mode.)
# (In standalone mode.) Display alarm information.
<Sysname> display alarm
Slot CPU Level   Info
1    0   ERROR   faulty
Slot
Slot that generated the alarm. If the alarm was generated by the frame, this field displays a hyphen (-).
Level
Alarm severity. Possible values include ERROR, WARNING, NOTICE, and INFO, in descending order.
Info
Detailed alarm information:
·     faulty—The slot is starting up or faulty.
·     Fan n is absent—The specified fan is absent.
·     Fan n is faulty—The specified fan is faulty.
·     Power n is absent—The specified power supply is absent.
·     Power n is faulty—The specified power supply is faulty.
·     Slot n temperature is too high, above the shutdown/alarm/warning limit—The temperature of the card is higher than the high-temperature shutdown, alarming, or warning threshold. (In standalone mode.)
·     Chassis n slot m temperature is too high, above the shutdown/alarm/warning limit—The temperature of the card is higher than the high-temperature shutdown, alarming, or warning threshold. (In IRF mode.)
·     Slot n temperature is too low, below the lower limit—The temperature of the card is lower than the low-temperature threshold. (In standalone mode.)
·     Chassis n slot m temperature is too low, below the lower limit—The temperature of the card is lower than the low-temperature threshold. (In IRF mode.)
display asset-info
Use display asset-info to display the asset profile for a physical component.
In standalone mode:
display asset-info { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom| department | description | location | service-date | state ]
In IRF mode:
display asset-info chassis chassis-number { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom| department | description | location | service-date | state ]
chassis: Displays the asset profile for the frame. The device does not support this keyword.
fan fan-id: Displays the asset profile for the specified fan tray. The device does not support this option.
power power-id: Displays the asset profile for the specified power module. The device does not support this option.
slot slot-number: Displays the asset profile for the card in the specified slot.
csn: Displays the asset ID for the asset.
custom: Displays the customized asset items.
department: Displays the department name.
description: Displays the asset description.
service-date: Displays the service start date.
state: Displays the asset usage status.
chassis chassis-number: Specifies an IRF member device by its member ID. (In IRF mode.)
To display an item in an asset profile, specify the corresponding keyword for the command. To display all items in an asset profile, do not specify the item keywords.
If an item is not configured, the system displays an empty field.
# (In standalone mode.) Display the asset ID for slot 0.
<Sysname> display asset-info slot 0 csn
Type        : Slot 0
csn         : 123456
# (In standalone mode.) Display the asset information for slot 0.
Type        : Slot 0
csn         : 123456
description : Slot 0
service-date:
department  :
state       : Normal
custom      : 1:789
reset asset-info
set asset-info
display clock
Use display clock to display the system time, date, time zone, and daylight saving time.
display clock
# Display the system time and date when the time zone is not specified.
<Sysname> display clock
10:09:00.258 UTC Fri 03/16/2015
The time is in the hour:minute:second.milliseconds format.
# Display the system time and date when the time zone Z5 is specified.
15:10:00.152 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# Display the system time and date when the time zone Z5 and daylight saving time PDT are specified.
15:11:00.211 Z5 Fri 03/16/2015
clock datetime
clock timezone
clock summer-time
display copyright
Use display copyright to display the copyright statement.
display copyright
# Display the copyright statement.
<Sysname> display copyright
display cpu-usage
Use display cpu-usage to display the current CPU usage statistics.
In standalone mode:
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number| all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ slot slot-number [ cpu cpu-number ]
In IRF mode:
display cpu-usage [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
display cpu-usage [ control-plane | data-plane ] [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ]
control-plane: Displays CPU usage statistics for the control plane. If you do not specify this keyword or the data-plane keyword, the command displays the total CPU usage statistics.
data-plane: Displays CPU usage statistics for the data plane. If you do not specify this keyword or the control-plane keyword, the command displays the total CPU usage statistics.
summary: Displays CPU usage statistics in table form. If you do not specify this keyword, the command displays CPU usage statistics in text form.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the CPU usage statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays CPU usage statistics for all cards. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number.
core core-number: Specifies a CPU core by its number.
core all: Specifies all CPU cores.
Executing this command on an MDC displays the current CPU usage statistics for the MDC.
If two hyphens (--) are displayed for the CPU usage during the most recent 5-second, 1-minute, and 5-minute intervals, the command might fail to obtain data from the database on the device. Try the command later.
# (In standalone mode.) Display the current CPU usage statistics in text form.
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
# (In standalone mode.) Display the current CPU usage statistics in table form.
Slot CPU        Last 5 sec        Last 1 min        Last 5 min
1    0          17%               29%               28%
x% in last 5 seconds
Last 5 sec
Average CPU or CPU core usage during the most recent 5-second interval.
y% in last 1 minute
Last 1 min
Average CPU or CPU core usage during the most recent 1-minute interval.
z% in last 5 minutes
Last 5 min
Average CPU or CPU core usage during the most recent 5-minute interval.
Use display cpu-usage configuration to display CPU usage monitoring settings.
In standalone mode:
In IRF mode:
display cpu-usage configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the CPU usage monitoring settings for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays the CPU usage monitoring settings for the global active MPU. (In IRF mode.)
Executing this command on an MDC displays CPU usage monitoring settings for the MDC.
# Display the CPU usage monitoring settings.
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 90%.
Current minor alarm threshold is 80%.
Current recovery-threshold is 40%.
CPU usage monitor is xxx.
Whether CPU usage tracking is enabled.
Current monitor interval is xxx.
Sampling interval for CPU usage tracking.
Current severe alarm threshold is xxx.
Severe CPU usage alarm threshold.
Current minor alarm threshold is xxx.
Minor CPU usage alarm threshold.
Current recovery threshold is xxx.
CPU usage recovery threshold.
Use display cpu-usage history to display the historical CPU usage statistics in a coordinate system.
In standalone mode:
In IRF mode:
display cpu-usage history [ job job-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
job job-id: Specifies a process by its ID. The value range for job-id is 1 to 2147483647. If you do not specify a process, this command displays the statistics for the entire system's CPU usage (the total CPU usage of all processes). To view the IDs and names of the running processes, use the display process command. For more information, see Network Management and Monitoring Configuration Guide.
slot slot-number: Specifies a card by its slot number. If you specify a process but do not specify a card, this command displays the statistics for the process on the active MPU. If you do not specify any options, this command displays the statistics for all processes on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you specify a process but do not specify a card, this command displays the statistics for the process on the global active MPU. If you do not specify any options, this command displays the statistics for all processes on all cards. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. If you specify a process but do not specify a CPU, this command displays the statistics for the default CPU. If you do not specify a process or CPU, this command displays the historical statistics for all CPUs.
After CPU usage monitoring is enabled, the system regularly samples CPU usage and saves the samples to the history record buffer. This command displays the most recent 60 samples in a coordinate system as follows:
·     The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
·     The horizontal axis represents the time.
·     Pound signs (#) indicate the CPU usage. The value on the vertical axis for the topmost pound sign at a specific time represents the CPU usage at that time.
Executing this command on an MDC displays the historical CPU usage statistics for the MDC.
# (In standalone mode.) Display the historical CPU usage statistics.
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
The output shows the following items:
·     Process name. The name SYSTEM represents the entire system.
·     CPU that is holding the process: CPU 0 in slot 1.
·     Historical CPU usage statistics for the entire system during the last 60 minutes.
¡     12 minutes ago—Approximately 5%.
¡     13 minutes ago—Approximately 10%.
¡     14 minutes ago—Approximately 15%.
¡     15 minutes ago—Approximately 10%.
¡     16 and 17 minutes ago—Approximately 5%.
¡     18 minutes ago—Approximately 10%.
¡     19 minutes ago—Approximately 5%.
¡     Other time—2% or lower.
display device
Use display device to display device information.
In standalone mode:
display device[ flash ] [ slot slot-number | verbose ]
In IRF mode:
display device[ flash ]  [ chassis chassis-number [ slot slot-number ] | verbose ]
flash: Displays flash memory information.
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information for all member devices. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for all cards.
verbose: Displays detailed information. If you do not specify this keyword, this command displays brief information.
If you do not specify the flash keyword, this command displays information about cards.
This command displays information about the physical device, whether you execute it on the default MDC or a non-default MDC.
# (In standalone mode.) Display device information.
<Sysname> display device
Slot No. Brd Type             Brd Status  Subslot  Sft Ver            Patch Ver
 0       LSQM2SUPA0           Master      0        S7500X-7595        None
 1       NONE                 Absent      0        NONE               None
 2       NONE                 Absent      0        NONE               None
 3       LSQM1CQGS12SG0       Normal      0        S7500X-7595        None
 4       NONE                 Absent      0        NONE               None
 5       NONE                 Absent      0        NONE               None
 6       NONE                 Absent      0        NONE               None
 7       NONE                 Absent      0        NONE               None
Table 4 Command output (in standalone mode)
Brd Type
Hardware type of the card.
Brd Status
Card status:
·     Standby—The card is the standby MPU.
·     Master—The card is the active MPU.
·     Absent—The slot is not installed with a card.
·     Fault—The card cannot start up, is starting up, or is powered off.
·     Normal—The card is an interface card and is operating correctly.
Subslot
Maximum number of subcards supported on the card.
Sft Ver
Software version of the card.
Patch Ver
Patch version of the card.
Use display device manuinfo to display electronic label information for the device.
In standalone mode:
In IRF mode:
display device manuinfo [ chassis chassis-number [ slot slot-number ] ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays electronic label information for all member devices. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays electronic label information of all cards.
An electronic label contains the permanent configuration information, including the hardware serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during hardware debugging or testing. This command displays only part of the electronic label information.
# Display electronic label information for the device.
<Sysname> display device manuinfo
Use display device manuinfo chassis-only to display electronic label information for the backplane.
In standalone mode:
In IRF mode:
display device manuinfo chassis chassis-number chassis-only
# (In standalone mode.) Display electronic label information for the backplane.
<Sysname> display device manuinfo chassis-only
Use display device manuinfo fan to display electronic label information for a fan tray.
In standalone mode:
display device manuinfo fan fan-id
In IRF mode:
display device manuinfo chassis chassis-number fan fan-id
fan-id: Specifies a fan tray by its ID.
This command correctly displays electronic label information for fan trays only after you use the set serial-no command to set serial numbers for fan trays.
# (In standalone mode.) Display electronic label information for a fan tray.
<Sysname> display device manuinfo fan 1
set serial-no
Use display device manuinfo power to display electronic label information for a power module.
In standalone mode:
display device manuinfo power power-id
In IRF mode:
display device manuinfo chassis chassis-number power power-id
power-id: Specifies a power module by its ID.
# (In standalone mode.) Display electronic label information for a power module.
<Sysname> display device manuinfo power 1
set serial-no
Use display device uptime to display information about card uptime since the latest startup.
# (In standalone mode.) Display information about card uptime since the latest startup.
<Sysname> display device uptime
Slot No.        Brd Type                 Brd Status  Subslot    UP time(DD:HH:MM)
 0              LSQM1MPUSA0              Master      0          0000:03:03
 1              LSQM1MPUSA0              Standby     0          0000:01:05
 2              LSQM2GP24SA0             Normal      0          0000:01:43
 3              NONE                     Absent      0          None
 4              NONE                     Absent      0          None
# (In IRF mode.) Display information about card uptime since the latest startup.
Slot   Type                  State    Subslot  UP time(DD:HH:MM)
1/0    LSQM2SUPA0            Master   0        0000:01:43
1/1    NONE                  Standby  0        None
1/2    LSQM2GP24SA0          Normal   0        0000:01:41
1/3    NONE                  Absent   0        None
1/4    NONE                  Absent   0        None
1/5    NONE                  Absent   0        None
1/6    NONE                  Absent   0        None
1/7    NONE                  Absent   0        None
Use display diagnostic-information to display or save operating information for features and hardware modules.
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ key-info ] [ filename ]
hardware: Specifies hardware-related operating information.
infrastructure: Specifies operating information for the fundamental features.
l2: Specifies operating information for the Layer 2 features.
l3: Specifies operating information for the Layer 3 features.
service: Specifies operating information for Layer 4 and upper-layer features.
key-info: Displays or saves only critical operating information. The device might have a large amount of operating information if an exception occurs or after the device runs for a long period of time. Specifying this keyword reduces the command execution time and helps you focus on critical operating information. If you do not specify this keyword, the command displays or saves both critical and non-critical operating information.
filename: Saves the information to a file. The filename argument must use the .tar.gz extension. If you do not specify this argument, the command prompts you to choose whether to save the information to a file or display the information.
You can use one of the following methods to collect operating statistics for diagnostics and troubleshooting:
·     Use separate display commands to collect operating information feature by feature or module by module.
·     Use the display diagnostic-information command to collect operating information for multiple or all features and hardware modules.
To save storage space, this command automatically compresses the information before saving the information to a file. To view the file content:
1.     Use the tar extract command to extract the file.
2.     Use the gunzip command to decompress the extracted file.
3.     Use the more command to view the content of the decompressed file.
If you abort the display diagnostic-information command, the gunzip command might not be able to decompress the extracted file. To decompress the extracted file, export the extracted file to a PC that is running Linux, and use the gunzip -c command.
If you do not specify a file name for the command, the system prompts you to choose whether to display or save the information. If you choose to save the information, the system automatically assigns a file name and displays the file name in brackets. For file name uniqueness, the file name includes the device name and the current system time. If the device name contains any of the following special characters, the system uses an underscore (_) to replace each special character: forward slashes (/), backward slashes (\), colons (:), asterisks (*), question marks (?), less than signs (<), greater than signs (>), pipeline signs (|), and quotation marks ("). For example, device name A/B will change to A_B in the file name, as in flash:/diag_A_B_20160101-000438.tar.gz.
If you do not specify any feature parameters, this command displays or saves the operating information for all features and modules.
This command does not support the |, >, and >> options.
To execute the display diagnostic-information command, make sure the CPU usage is less than 100% and the memory usage is equal to or less than 90%. To view the CPU usage and the memory usage, use the display cpu-usage and display memory commands.
While the device is executing this command, do not execute any other commands. Executing other commands might affect the collected operating information.
# Display the operating information for all features and modules.
14:03:55 UTC Thu 01/05/2015
# Save the operating information to the default file.
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
Press Enter when the system prompts you to enter the file name.
# Save the operating information for all features and modules to file test.tar.gz.
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
gunzip
more
tar extract
display environment
Use display environment to display temperature information.
In standalone mode:
In IRF mode:
display environment [ chassis chassis-number [ slot slot-number ] ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays temperature information for all member devices. (In IRF mode.)
(In standalone mode.) This command displays information about all temperature sensors on the device if you do not specify a card.
(In IRF mode.) This command displays information about all temperature sensors in the IRF fabric if you do not specify an IRF member device. If you specify an IRF member device but do not specify a card, this command displays information about all sensors on the member device.
The LSQM1SDNB0, LSQM1EPSB0, or LSQM1WBCZ720X card reboots instead of shutting down when the sensor temperature reaches the shutdown temperature threshold.
# (In standalone mode.) Display information about all temperature sensors on the device.
<Sysname> display environment
System temperature information (degree centigrade):
 Slot  Sensor    Temperature  Lower  Warning  Alarm  Shutdown
 0     inflow  1 28           0      68       80     NA
 0     outflow 1 34           0      68       80     NA
 0     hotspot 1 44           0      88       100    NA
 2     hotspot 1 35           0      80       97     110
 2     hotspot 2 41           0      80       97     110
 4     hotspot 1 34           0      80       97     NA
Table 5 Command output
System Temperature information (degree centigrade)
Temperature information (°C).
sensor
Temperature sensor:
·     hotspot—Hotspot sensor.
·     inflow—Air inlet sensor.
·     outflow—Air outlet sensor.
Slot
Sensor position.
Temperature
Current temperature.
Lower
Lower temperature limit. If the device does not support this field, this field displays NA.
Warning
Warning temperature threshold. If the device does not support this field, this field displays NA.
Alarm
Alarming temperature threshold. If the device does not support this field, this field displays NA.
Shutdown
Shutdown temperature threshold. When the following conditions are met, the system shuts down automatically:
·     A fan has failed or is absent.
·     The sensor temperature is greater than this threshold for over 10 seconds.
Use display environment history to display historical temperature information in a coordinate system.
In standalone mode:
display environment history slot slot-number { 30days | day | hour } [ { hotspot | inflow | outflow } sensor-number ]
In IRF mode:
display environment history chassis chassis-number slot slot-number { 30days | day | hour } [ { hotspot | inflow | outflow } sensor-number ]
30days: Displays the historical temperature information during the past 30 days.
day: Displays the historical temperature information during the past 24 hours.
hour: Displays the historical temperature information during the past 60 minutes.
hotspot: Displays the historical temperature information of the hotspot sensors. A hotspot sensor is typically located near a high-heat chip to monitor the chip temperature.
inflow: Displays the historical temperature information of the inflow sensors. An inflow sensor is located near an air inlet to monitor the ambient temperature. Support for this keyword depends on the device model.
outflow: Displays the historical temperature information of the outflow sensors. An outflow sensor is located near an air outlet to monitor the device temperature. Support for this keyword depends on the device model.
sensor-number: Specifies a sensor by its number. To view the value range, enter a question mark (?) in the place of this argument.
The device periodically takes temperature readings from sensors and buffers the readings. When you execute this command, the device calculates and displays the most recent average temperature values as follows:
·     For historical temperature information during the past 60 minutes, the device calculates the average temperature value during every 1-minute interval.
·     For historical temperature information during the past 24 hours, the device calculates the average temperature value during every 1-hour interval.
·     For historical temperature information during the past 30 days, the device calculates the average temperature value during every 1-day interval.
This command displays temperature values in a coordinate system.
·     The vertical axis represents the temperature in degrees centigrade.
¡     If a value is not a multiple of the 5-degree step, it is rounded up or down to the closest multiple of the step. For example, value 23 is rounded up to 25, and value 22 is rounded down to 20.
¡     The default value range for the vertical axis is 0 to 100. If a temperature value is higher than 100 °C or lower than 0°C, the value range automatically expands.
·     The horizontal axis represents the time. The unit varies by the specified time keyword.
·     Pound signs (#) indicate the temperature values. The value on the vertical axis for the topmost pound sign at a specific time represents the temperature value at that time.
If you do not a sensor for the command, the command displays the historical temperature information of all sensors on the specified component.
# (In standalone mode.) Display the historical temperature information of hotspot sensor 1 on a slot during the past 24 hours.
<Sysname> display environment history slot 1 day hotspot 1
Temperature readings of hotspot sensor 1 (in slot 1) during the past 24 hours:
Highest temperature is 27 degrees centigrade.
Lowest temperature is 25 degrees centigrade.
Temperature (degrades centigrade)
100|
 95|
 90|
 85|
 80|
 75|
 70|
 65|
 60|
 55|
 50|
 45|
 40|
 35|
 30|
 25| # # # # # # # # # # # # # # # # # # # # # # # #
 20| # # # # # # # # # # # # # # # # # # # # # # # #
 15| # # # # # # # # # # # # # # # # # # # # # # # #
 10| # # # # # # # # # # # # # # # # # # # # # # # #
               6           12          18          24 (hours)
# (In IRF mode.) Display the historical temperature information of outflow sensor 1 on a slot during the past 30 days.
<Sysname> display environment history chassis 0 slot 1 30days outflow 2
Temperature readings of outflow sensor 2 (in chassis 1 slot 1) during the past 30 days:
100|
 95|
 90|
 85|
 80|
 75|
 70|
 65|
 60|
 55|
 50|
 45|
 40|
 35|
 30|
 25| # # # # # # # # # # # # # # # # # # # # # # # # # # # # # #
 20| # # # # # # # # # # # # # # # # # # # # # # # # # # # # # #
 15| # # # # # # # # # # # # # # # # # # # # # # # # # # # # # #
 10| # # # # # # # # # # # # # # # # # # # # # # # # # # # # # #
                       10                  20                  30 (days)
display environment
temperature-limit
display fan
Use display fan to display fan tray operating status information.
In standalone mode:
display fan [ fan-id ]
In IRF mode:
display fan [ chassis chassis-number [ fan-id ] ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays fan tray operating status information for all member devices. (In IRF mode.)
fan-id: Specifies a fan tray by its ID. If you do not specify a fan tray, this command displays operating status information for all fan trays at the specified position.
# Display the operating states of all fan trays.
<Sysname> display fan
Fan Frame 0  State: Normal
Table 6 Command output
Fan Frame
Fan tray number.
Fan tray status:
·     Absent—The slot is not installed with a fan tray.
·     Faulty—The fan tray is faulty.
·     Normal—The fan tray is operating correctly.
Use display hardware-failure-detection to display the hardware failure detection settings and the latest 10 fix records for each card.
In standalone mode, the fix records are stored on the active MPU. You can use the display hardware-failure-detection command to display the records for a card even if the card is removed or replaced. The fix records are lost only when you remove or power cycle the active MPU.
In IRF mode, the fix records are stored on the local active MPU. You can use the display hardware-failure-detection command to display the records for a card even if the card is removed or replaced. The fix records are lost only when you remove or power cycle the local active MPU.
# (In standalone mode.) Display hardware failure detection settings and fix records.
<Sysname> display hardware-failure-detection
Current level:
    chip       : isolate
    board      : isolate
    forwarding : warning
Recent record:
--------------------------Slot  0 executed records:-----------------------------
                 There is no record.
--------------------------Slot  0 trapped records:-----------------------------
                 There is no record.
Table 7 Command output
Current level
Fix actions specified for hardware failures.
chip
Fix action for hardware failures on components of cards.
board
Fix action for hardware failures on cards.
forwarding
Fix action for hardware failures on the forwarding plane.
Recent record
Recent failure fix records.
xxx executed records
Fix records stored on an MPU.
xxx trapped records
Trap records stored on an MPU.
display memory
Use display memory to display memory usage information.
In standalone mode:
In IRF mode:
display memory [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
summary: Displays brief information about memory usage. If you do not specify this keyword, the command displays detailed information about memory usage.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays memory usage for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays memory usage for all MPUs. (In IRF mode.)
Executing this command on an MDC displays memory usage information for the MDC.
If two hyphens (--) are displayed for all the fields in a line of the command output, the command might fail to obtain data from the database on the device. Try the command later.
# (In standalone mode.) Display detailed memory usage information.
<Sysname> display memory
Memory statistics are measured in KB:
Slot 1:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:        984560    456128    528432         0         4     45616       53.7%
-/+ Buffers/Cache:    410508    574052
Swap:            0         0         0
LowMem:     739824    375552    364272        --        --        --       49.2%
HighMem:    244736     80576    164160        --        --        --       67.1%
# (In standalone mode.) Display brief memory usage information.
<Sysname> display memory summary
Slot CPU        Total      Used      Free  Buffers    Caches FreeRatio
   1   0       984560    456128    528432        4     45616     53.7%
Low memory statistics are measured in KB:
   1   0       739824    375552    364272       --        --     49.2%
High memory statistics are measured in KB:
   1   0       244736     80576    164160       --        --     67.1%
Table 8 Command output
Mem
Memory usage information.
Total
Total size of the physical memory space that can be allocated.
The memory space is virtually divided into two parts. Part 1 is solely used for kernel code, kernel management, and ISSU functions. Part 2 can be allocated and used for such tasks as running service modules and storing files. The size of part 2 equals the total size minus the size of part 1.
Used
Used physical memory.
Free
Free physical memory.
Shared
Physical memory shared by processes.
If this field is not supported, two hyphens (--) are displayed.
Buffers
Physical memory used for buffers.
Cached
Caches
Physical memory used for caches. If a memory threshold is reached, part of memory used for caches can be automatically released for other services.
FreeRatio
Free memory ratio. The free memory includes the free physical memory and the part of memory used for caches that can be automatically released for other services when a memory threshold is reached.
-/+ Buffers/Cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications.
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications.
Swap
Memory space for swapping.
LowMem
Low-memory usage information.
HighMem
High-memory usage information.
Use display memory-threshold to display memory alarm thresholds and statistics.
In standalone mode:
In IRF mode:
display memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the memory usage thresholds and statistics for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays the memory usage thresholds and statistics for the global active MPU. (In IRF mode.)
For more information about memory usage notifications, see log information containing MEM_EXCEED_THRESHOLD or MEM_BELOW_THRESHOLD.
# Display memory alarm thresholds and statistics.
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free-memory thresholds:
    Minor: 96M
    Severe: 64M
    Critical: 48M
    Normal: 128M
    Early-warning: 256M
    Secure: 304M
Current free-memory state: Normal (secure)
Free-memory event statistics:
 [Back to secure state]
    First notification: 0.0
    Latest notification: 0.0
    Total number of notifications sent: 0
 [Entered early-warning state]
    First notification at: 0.0
    Latest notification at: 0.0
 [Back to normal state]
 [Entered minor alarm state]
 [Back to minor alarm state]
 [Entered severe alarm state]
 [Back to severe alarm state]
 [Entered critical alarm state]
Table 9 Command output
    Minor
    Severe
    Critical
    Normal
    Early-warning
    Secure
·     Minor—Minor alarm threshold in MB.
·     Severe—Severe alarm threshold in MB.
·     Critical—Critical alarm threshold in MB.
·     Normal—Normal state threshold in MB.
Current state of the free memory in the system:
·     Normal—Normal state.
·     Minor—Minor alarm threshold.
·     Severe—Severe alarm threshold.
·     Critical—Critical alarm threshold.
Time when the alarm notification was sent for the first time, in the format of yyyy-mm-dd hh:mm:ss.msec.
Time when the alarm notitication was sent most recently in the format of yyyy-mm-dd hh:mm:ss.msec.
Total number of notification send
Total number of the alarm notifications that were sent.
display power
Use display power to display power module information.
In standalone mode:
display power [ power-id | verbose ]
In IRF mode:
display power [ chassis chassis-number [ power-id | verbose ] ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays power module information for all member devices. (In IRF mode.)
power-id: Specifies a power module by its ID. If you do not specify a power module, this command displays information about all power modules at the specified position.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display brief power supply information.
<Sysname> display power
 Input Power: 317.0 W
 PowerID  State  Mode   Current(A)  Voltage(V)  Power(W) FanDirection
 1        Normal AC     --          --          --       --
 2        Absent --     --          --          --       --
Table 10 Command output
Input Power
Rated power.
PowerID
Power supply ID.
Power supply status.
·     Absent—The slot is not installed with a power supply.
·     Faulty—The power supply is faulty.
·     Normal—The power supply is operating correctly.
Mode
Mode of the power supply:
·     ACAC power supply.
·     DCDC power supply.
Current(A)
Output current of the power supply, in amperes.
Voltage(V)
Output voltage of the power supply, in volts.
Power(W)
Output power of the power supply, in watts.
FanDirection
Airflow direction of the power supply.
# (In standalone mode.) Display detailed power module information.
<Sysname> display power verbose
System power information:
 Power modules installed: 1
 Power modules usable: 1
 Rated power: 1400 W
 Usable power: 1370 W
 Used power: 317.0 W
 Redundant power: 0 W
 Total DC output : -- A
 PowerID State   InVoltage(V) InPower(W) OutVoltage(V) OutCurrent(A) OutPower(W)
 1       Normal  --           --         --            --            --
 Power information by slot:
 Slot   Type               Current(A)    Power(W)    Status
 0      None               --            --          Absent
 1      None               --            60.0        Absent
Table 11 Command output
Number of power modules installed on the device.
Number of available power modules.
Rated power
Total rated power of power modules that are in Normal state, in watts.
Usable power
Total available power of power modules that are in Normal state, in watts.
Used power
Total used power, in watts.
Redundant power
Redundant power, in watts.
Total DC output
Total output current of all power modules, in amperes.
PowerID
Power module ID.
Power module status:
·     Absent—The slot is not installed with a power module.
·     Fault—The power module is faulty.
·     Normal—The power module is operating correctly.
InVoltage(V)
Input voltage of the power module, in volts.
InPower(W)
Input power of the power module, in watts.
OutVoltage(V)
Output voltage of the power module, in volts.
OutCurrent(A)
Output current of the power module, in amperes.
OutPower(W)
Output power of the power module, in watts.
Power module usage information for slots.
Card type.
Current(A)
Input current of the card, in amperes.
Power(W)
Rated power of the card, in watts.
Status
Status of the card:
·     Fault—The card is faulty.
·     Normal—The card is operating correctly.
Use display power-supply to display power supply management information.
In standalone mode:
In IRF mode:
display power-supply [ chassis chassis-number ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays power supply management information for all member devices. (In IRF mode.)
# Display power supply management information.
<Sysname> display power-supply
 Power supply policy:  Disable
 Power modules redundant (setting):  0
 Board power supply information:
 Slot   Type                  Priority        Status
 0      LSQM2SUPA0            --              Powered On
 1      None                  --              Reserved
 2      LSQM2GT24PTSSC0       5               Powered On
 3      None                  5               Absent
 4      LSQM4GV48SA0          5               Powered On
 5      None                  5               Absent
 6      None                  5               Absent
 7      None                  5               Absent
Table 12 Command output
Power supply policy
Status of the power supply management feature:
·     Disable—The feature is disabled.
·     Enable—The feature is enabled.
Number of redundant power supplies specified.
Slot
Slot number of the card.
Card type.
Priority
Power supply priority for the card.
Status
Card status:
·     Powered On—The card is powered on.
·     Powered Off—The power is not enough for powering on the card.
·     Reserved—This slot is not installed with a card but the system has reserved power for this slot.
·     Off(manual)—The card has been powered off manually.
·     Off(Temp)—The card has been powered off because of high temperature.
·     Off(Isolated)—The card is isolated.
·     --—The command failed to obtain power information about the card.
Use display resource-monitor to display resource monitoring information.
In standalone mode:
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display resource-monitor [ resource resource-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
resource resource-name: Specifies a resource type by its name.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays resource monitoring information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays resource monitoring information for all cards. (In IRF mode.)
# (In standalone mode.) Display ARP resource monitoring information.
<Sysname> display resource-monitor resource arp
Minor alarms resending: Enabled
Slot 1:
Resource                         Minor Severe Free/Total
                                 (%)   (%)    (absolute)
arp                              50    20     90095/90098
Table 13 Command output
Status of the minor resource depletion alarm resending feature, Enabled or Disabled.
Resource
Monitored resource type.
Minor
Minor resource depletion threshold, in percentage.
Severe
Severe resource depletion threshold, in percentage.
Free/Total
(absolute)
Numbers of available resources and total resources, in absolute values. ‌
Use display scheduler job to display job configuration information.
job-name: Specifies a job by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a job, this command displays configuration information for all jobs.
# Display configuration information for all jobs.
<Sysname> display scheduler job
Job name: saveconfig
 copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
 vlan 100
// The output shows that the device has three jobs: the first has one command, the second does not have any commands, and the third has two commands. Jobs are separated by blank lines.
Use display scheduler logfile to display job execution log information.
# Display job execution log information.
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name        : shutdown
Schedule name   : shutdown
Execution time  : Tue Dec 27 10:44:42 2015
Completion time : Tue Dec 27 10:44:47 2015
<Sysname>system-view
[Sysname]interface rang ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/3
[Sysname-if-range]shutdown
Table 14 Command output
Logfile Size
Size of the log file, in bytes.
Schedule name
Schedule to which the job belongs.
Execution time
Time when the job was started.
Completion time
Time when the job was completed. If the job has never been executed or the job does not have any commands, this field is blank.
Job output
Commands in the job and their output.
Use display scheduler reboot to display the automatic reboot schedule.
# Display the automatic reboot schedule.
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2015 (in 1 hours and 39 minutes).
scheduler reboot at
Use display scheduler schedule to display schedule information.
schedule-name: Specifies a schedule by its name, a case-sensitive string of 1 to 47 characters. If you do not specify a schedule, this command displays information about all schedules.
# Display information about all schedules.
<Sysname> display scheduler schedule
Schedule type        : Run once after 0 hours 2 minutes
Start time           : Tue Dec 27 10:44:42 2015
Last execution time  : Tue Dec 27 10:44:42 2015
Last completion time : Tue Dec 27 10:44:47 2015
Execution counts     : 1
shutdown                                          Successful
Table 15 Command output
Schedule type
Execution time setting of the schedule. If no execution time is specified, this field is not displayed.
Start time
Time to execute the schedule for the first time. If no execution time is specified, this field is not displayed.
Last execution time
Last time when the schedule was executed. If no execution time is specified, this field is not displayed. If the schedule has never been executed, "Yet to be executed" is displayed for this field.
Last time when the schedule was completed. If no execution time is specified, this field is not displayed.
Execution counts
Number of times the schedule has been executed. If the schedule has never been executed, this field is not displayed.
Job name
Name of a job under the schedule.
Result of the most recent execution:
·     Successful.
·     Failed.
·     Waiting—The device is executing the schedule and the job is waiting to be executed.
·     In process—The job is being executed.
·     -NA-—The execution time has not arrived yet.
To view information about whether the commands in the job has been executed and the execution results, execute the display scheduler logfile command.
display serial-no
Use display serial-no to display serial numbers for fan trays and power modules.
In standalone mode:
display serial-no { fan fan-id | power power-id }
In IRF mode:
display serial-no chassis chassis-number { fan fan-id | power power-id }
fan fan-id: Specifies a fan tray by its ID. The value range for the fan-id argument is 0 to 14.
power power-id: Specifies a power module by its ID. The value range for the power-id argument is 0 to 15.
This command is available only for fan trays and power modules that support the set serial-no command.
# (In standalone mode.) Display the serial number for fan tray 0.
<Sysname> display serial-no fan 0
DEVICE_SERIAL_NUMBER : 210212A0561234560001
set serial-no
display switch-mode status
Use display switch-mode status to display operating mode and proxy mode information about modules.
In standalone mode:
In IRF mode:
display switch-mode status chassis chassis-number
If a module does not have an operating mode or a proxy mode specified, the Config field displays NONE. The module will operate in the default mode after you save the running configuration and reboot the module.
# (In standalone mode.) Display operating mode and proxy mode information about all modules on the device.
<Sysname> display switch-mode status
LPU switch mode and proxy mode:
Slot    Current                            Config
 0      MIX               [NONE         ]  NONE              [NONE         ]
 2      NORMAL            [NONE         ]  NONE              [NONE         ]
 3      NONE              [NONE         ]  NONE              [NONE         ]
Table 16 Command output
Slot
Slot number.
Operating mode and proxy mode information.
Current
Current operating mode or proxy mode of the module:
·     NONE—The module does not support operating mode or proxy mode configuration.
·     BALANCE—The module is operating in balanced mode.
·     BRIDGING—The module is operating in extended MAC mode.
·     ENHANCE-BRIDGING—The module is operating in enhanced MAC mode.
·     NORMAL—The module is operating in normal mode.
·     ROUTING—The module is operating in extended routing mode.
·     LEGACY_LAYER3—The module is operating in legacy Layer 3 mode.
·     MIX—The module is operating in extended hybrid mode.
·     IPv6—The module is operating in IPv6 mode.
·     STANDARD-IPV6—The module is operating in IPv6 standard mode.
·     ROUTE-HIGH—The module is operating in the route proxy mode (route-proxy-high mode).
·     ROUTE-LOW—The module is operating in the route principal mode (route-proxy-low mode).
·     ADJ-HIGH—The module is operating in the ARP/ND proxy mode (adj-proxy-high mode).
·     ADJ-LOW—The module is operating in the ARP/ND principal mode (adj-proxy-low mode).
·     L3-HIGH—The module is operating in the route/ARP/ND proxy mode (l3-proxy-high mode).
Config
Operating mode or proxy mode specified for the module:
·     NONE—No operating mode or proxy mode is specified for the module.
·     BALANCE—The balanced mode is specified for the module.
·     BRIDGING—The extended MAC mode is specified for the module.
·     ENHANCE-BRIDGING—The enhanced MAC mode is specified for the module.
·     NORMAL—The normal mode is specified for the module.
·     ROUTING—The extended routing mode is specified for the module.
·     LEGACY_LAYER3—The legacy Layer 3 mode is specified for the module.
·     MIX—The extended hybrid mode is specified for the module.
·     IPv6—The IPv6 mode is specified for the module.
·     STANDARD-IPV6—The IPv6 standard mode is specified for the module.
·     ROUTE-HIGH—The route proxy mode is specified for the module (route-proxy-high mode).
·     ROUTE-LOW—The route principal mode is specified for the module (route-proxy-low mode).
·     ADJ-HIGH—The ARP/ND proxy mode is specified for the module (adj-proxy-high mode).
·     ADJ-LOW—The ARP/ND principal mode is specified for the module (adj-proxy-low mode).
·     L3-HIGH—The route/ARP/ND proxy mode is specified for the module (l3-proxy-high mode).
* indicates the mode is not supported.
The module does not support the operating mode specified for it. The module will use the default operating mode after reboot.
switch-mode
display system health
Use display system health to display system health status information.
In standalone mode:
In IRF mode:
display system health [ chassis chassis-number ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays health status information about the master device. (In IRF mode.)
The device periodically performs a series of checks to identify the health status of the device. The check items are already defined in the factory-default configuration. The check results can be used by the internal service modules such as IRF and M-LAG in the device. You can execute this command to view these check results.
# (In standalone mode.) Display system health status information.
<Sysname> display system health
Health: Faulty(3)
    Memory: Normal(0)
    Communication: Normal(0)
    DBM monitor: Normal(0)
    Chip jam: Normal(0)
    CPU deadloop: Normal(0)
    Forwarding channel: Normal(0)
    HG: Normal(0)
    External TCAM: Normal(0)
    LSW CPU: Normal(0)
    MMU: Normal(0)
    LSW port: Normal(0)
    Board status: Faulty(3)
    Fan status: Normal(0)
    Temperature: Normal(0)
# (In IRF mode.) Display system health status information.
Chassis  1 health: Normal(0)
    Memory: Normal(0)
    Chip jam: Normal(0)
    HG: Normal(0)
    LSW CPU: Normal(0)
    MMU: Normal(0)
    LSW port: Normal(0)
    Board status: Normal(0)
Chassis  2 health: Normal(0)
    Memory: Normal(0)
    Chip jam: Normal(0)
    HG: Normal(0)
    LSW CPU: Normal(0)
    MMU: Normal(0)
    LSW port: Normal(0)
Table 17 Command output
Health: Normal(0)
System health status:
·     Normal(0)—The system is healthy.
·     Faulty(n)—The system is faulty. A greater value of n indicates a worse situation.
Memory
Memory health status.
Communication
Communication health status.
DBM monitor
DBM health status.
Chip jam
Chip jam status.
CPU deadloop
CPU deadloop status.
Forwarding channel
Health status of cross-card services on the device.
HG
HG health status.
External TCAM
External TCAM health status.
LSW CPU
LSW CPU health status.
MMU
MMU health status.
LSW port
LSW port health status.
Board status
Card health status.
Fan status
Fan health status.
Temperature
Temperature sensor health status.
display system health history
Use display system health history to display historical system health status change information.
In standalone mode:
In IRF mode:
display system health history[ chassis chassis-number ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays historical health status change information about the master device. (In IRF mode.)
# Display historical system health status change information.
<Sysname> display system health history
Health: Faulty(1)
  Chip jam:
    Faulty(1)  2019-10-10 18:00:00 on slot 1
    Normal(0)  2019-10-08 17:00:00 on slot 1
    Faulty(1)  2019-10-07 18:00:00 on slot 1
Table 18 Command output
Health: Normal(0)
Chip jam:
Historical status change information of items. For more information about the supported items on the device, see Table 17.
A maximum of 30 historical status change entries are supported for each item.
display system stable state
Use display system stable state to display system stability and status information.
display system stable state[ mdc { mdc-id | all } ]  [ summary ]
mdc { mdc-id | all }: Specifies an MDC by its ID or specifies all MDCs. The value range is 1 to 5.
summary: Displays brief information about system status, redundancy status, and NSR status. If you do not specify this keyword, the command displays detailed information about system status, redundancy status, and CPU role and status.
If you do not specify an MDC, this command displays stability information for the system.
Before performing an ISSU or a switchover, execute this command multiple times to identify whether the system is operating stably. If the value of the System State field is not Stable, you cannot perform an ISSU. If the value of the Redundancy Stable field is not Stable, you cannot perform a switchover.
The device/card/MDC startup process takes some time. If the values of the status fields do not change to Stable, execute this command multiple times to identify the devices/cards/MDCs that are not in Stable state. You can also use other commands to identify the faulty components. For example:
·     Use the display device command to identify the device operating status.
·     Use the display ha service-group command to display the status of HA service groups and identify the groups in batch backup state.
·     Use the display system internal process state command in probe view to display service operating status.
# Display brief system stability and status information.
<Sysname> display system stable state summary
System state      : Stable
Redundancy state  : No redundancy
NSR     state     : No standby
# (In standalone mode.) Display system stability and status information.
Redundancy state : Stable
  Slot    CPU    Role       State
  0       0      Active     Stable
  1       0      Standby    Stable
  3       0      Other      Stable
  15      0      Other      Stable
Table 19 Command output
System state
Operating status of all cards:
·     Stable—All cards are operating stably.
·     Not ready—One or more cards are not operating stably. You cannot perform an ISSU.
Redundancy state
System redundancy status:
·     Stable—Both MPUs are operating stably. You can perform a switchover.
·     No redundancy—The system has only one MPU. You cannot perform a switchover.
·     Not ready—The system is not operating stably. You cannot perform a switchover.
NSR state
NSR status of all cards:
·     Ready—NSR is operating correctly on all cards where it is enabled.
·     Not ready—NSR is not operating correctly on all cards where it is enabled. You cannot perform a process or MPU switchover or an ISSU.
·     No standby—The system has only one MPU.
·     Not configured—NSR is not enabled.
Role
Role of the card in the system:
·     Active—The card is the active MPU.
·     Other—The card is a service card.
Operating status of the card:
·     Stable—The card is operating stably.
·     Board inserted—The card has just been installed.
·     Kernel initiating—Card kernel is being initialized.
·     Service starting—Services are starting.
·     Service stopping—Services are stopping.
·     HA Batch backup—An HA batch backup is going on.
·     Interface data batch backup—An interface data batch backup is in progress.
·     MDC starting—MDCs are starting.
·     MDC stopping—MDCs are stopping.
·     Automatic configuration—MDCs are being automatically configured.
The object is not operating stably.
display context (Virtual Technologies Command Reference)
display device
display ha service-group (High Availability Command Reference)
display system-working-mode
Use display system-working-mode to display system working mode information.
This command is supported only on the default MDC.
# Display system working mode information.
<Sysname> display system-working-mode
The current system working mode is standard.
The system working mode for next startup is standard.
display transceiver alarm
Use display transceiver alarm to display transceiver alarms.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the alarms present on every transceiver module.
Table 20 shows the common transceiver alarm components. If no error occurs, None is displayed.
Table 20 Common transceiver alarm components
APD
Avalanche photo diode
PCS
Physical coding sublayer
PHY XS
PHY extended sublayer
PMA/PMD
Physical medium attachment/physical medium dependent
power
Optical power
REFCLK
Reference clock
RX
Receive
TEC
Thermoelectric cooler
Temp
Temperature
TX
Transmit
WIS
WAN interface sublayer
CDR
Clock and data recovery
LOL
Loss of lock
eq
Equivalent
# Display the alarms present on the transceiver module in interface Ten-GigabitEthernet 1/0/1.
<Sysname> display transceiver alarm interface ten-gigabitethernet 1/0/1
Ten-GigabitEthernet1/0/1 transceiver current alarm information:
  RX signal loss
  RX power low
Table 21 Command output
Alarms present on the transceiver module.
RX signal loss
Inbound signal loss occurred.
RX power low
Received power is low.
display transceiver diagnosis
Use display transceiver diagnosis to display the current values of the digital diagnosis parameters on transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the current values of the digital diagnosis parameters on every transceiver module.
# Display the current values of the digital diagnosis parameters on the transceiver module in interface Ten-GigabitEthernet 1/0/1.
<Sysname> display transceiver diagnosis interface ten-gigabitethernet 1/0/1
Ten-GigabitEthernet1/0/1 transceiver diagnostic information:
    Temp.(C)   Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    36         3.31        6.13      -35.64          -5.19
  Alarm thresholds:
    High  50         3.55        1.44      -10.00         5.00
    Low   30         3.01        1.01      -30.00         0.00
Table 22 Command output
Digital diagnosis information for the transceiver module in the interface.
Temp.(C)
Temperature in °C, accurate to 1°C.
Voltage(V)
Voltage in V, accurate to 0.01 V.
Bias(mA)
Bias current in mA, accurate to 0.01 mA.
RX power(dBm)
Receive power in dBm, accurate to 0.01 dBm.
TX power(dBm)
Transmit power in dBm, accurate to 0.01 dBm.
display transceiver interface
Use display transceiver interface to display the key parameters of transceiver modules.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the key parameters of every transceiver module.
# Display the key parameters of the transceiver module in interface Ten-GigabitEthernet 1/0/1.
<Sysname> display transceiver interface ten-gigabitethernet 1/0/1
display transceiver manuinfo
Use display transceiver manuinfo to display electronic label information for transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays electronic label information for all transceiver modules.
# Display electronic label information for the transceiver module in interface GigabitEthernet 1/0/1.
<Sysname> display transceiver manuinfo interface gigabitethernet 1/0/1
display version
Use display version to display system version information.
display version
# Display system version information.
<Sysname> display version
display version-update-record
Use display version-update-record to display startup software image upgrade records.
The device records its current startup software version information whenever it starts up, and records all software version update information. Such information can survive reboots.
# Display the startup software image upgrade records.
<Sysname> display version-update-record
Record 1  (updated on Apr 18 2015 at 06:23:54):
 *Name        : boot-test.bin
  Version     : 7.1.070 Test 0001
  Compile time: Mar 25 2015 15:52:43
 *Name        : system-test.bin
Table 23 Command output
Record n
Number of the startup software image upgrade record. Record 1 is the most recent record.
Name
Software image file name.
The software image version changed during the upgrade.
reset version-update-record
display xbar
Use display xbar to display the load modes for MPUs.
In standalone mode:
display xbar
In IRF mode:
display xbar [ chassis chassis-number ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the MPU load mode information for all member devices. (In IRF mode.)
The running load mode might be different from the configured load mode. The load-balance mode takes effect only when both the active and standby MPUs are present. If the standby MPU is not present, the active MPU operates in load-single mode.
# (In standalone mode.) Display the load modes for MPUs.
<Sysname> display xbar
The configured system HA xbar load mode is BALANCE
The activated system HA xbar load mode is SINGLE
The output shows that the configured load mode is the load-balance mode but the running load mode is the load-single mode.
xbar
fabric load-sharing mode
Use fabric load-sharing mode to specify load sharing modes for a service card.
Use undo fabric load-sharing mode to restore the default.
In standalone mode:
fabric load-sharing mode { { destination-ip | destination-mac | ingress-port | source-ip | source-mac } * | flexible } slot slot-number
undo fabric load-sharing mode [ { destination-ip | destination-mac | ingress-port | source-ip | source-mac } * | flexible ] slot slot-number
In IRF mode:
fabric load-sharing mode { { destination-ip | destination-mac | ingress-port | source-ip | source-mac } * | flexible } chassis chassis-number slot slot-number
undo fabric load-sharing mode [ { destination-ip | destination-mac | ingress-port | source-ip | source-mac } * | flexible ] chassis chassis-number slot slot-number
See Fundamentals Configuration Guide.
destination-ip: Balances load based on destination IP address.
destination-mac: Balances load based on destination MAC address.
ingress-port: Balances load based on ingress interface.
source-ip: Balances load based on source IP address.
source-mac: Balances load based on source MAC address.
flexible: Selects a balance mode based on the packet type (for example, Layer 2 packet or IPv4 packet).
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
# (In standalone mode.) Set the load sharing mode to destination-mac for a card.
[Sysname] fabric load-sharing mode destination-mac slot 2
display xbar
forward-path-detection enable
Use forward-path-detection enable to enable data forwarding path failure detection.
Use undo forward-path-detection enable to disable data forwarding path failure detection.
Data forwarding path failure detection is enabled.
You can enable the device to automatically detect data forwarding path failures and output log information for notification.
# Enable data forwarding path failure detection.
[Sysname] forward-path-detection enable
Use hardware-failure-detection to specify the action to be taken in response to hardware failures.
Use undo hardware-failure-detection to restore the default.
hardware-failure-detection { board | chip | forwarding } { isolate | off | reset | warning }
undo hardware-failure-detection { board | chip | forwarding }
The system takes the action of reset in response to hardware failures on chips, the card, and the forwarding plane.
board: Specifies failures on control paths.
chip: Specifies failures on components of cards such as the chips, capacitances, resistances.
forwarding: Specifies failures on the forwarding plane (including services and other relevant items).
isolate: Takes one or more of the following actions:
·     Prohibits loading software for the relevant cards.
·     Isolates the relevant cards.
·     Powers off the relevant cards to reduce impact from the failures.
off: Takes no action.
reset: Restarts the relevant components or cards to recover from failures.
warning: Sends traps to notify you of the failures. If a card failure is detected on control paths, the system will try to recover from the failure by restarting the card.
The device automatically detects hardware failures on components, cards, and the forwarding plane. You can specify the actions to be taken in response to detected failures.
# Configure the device to send traps in response to failures on components.
[Sysname] hardware-failure-detection chip warning
header
Use header to configure a banner.
Use undo header to delete a banner.
header { legal | login | motd | shell } text
undo header { legal | login | motd | shell }
The device does not have banners.
incoming: Configures the banner to be displayed before a modem dial-in user accesses user view. If authentication is required, the incoming banner appears after the authentication is passed. Modem dial-in is not supported in the current software version.
legal: Configures the banner to be displayed before a user inputs the username and password to access the CLI.
login: Configures the banner to be displayed before password or scheme authentication is performed for a login user.
motd: Configures the greeting banner to be displayed before the legal banner appears.
shell: Configures the banner to be displayed before a non-modem dial-in user accesses user view.
text: Specifies the banner message. You can enter the banner message on the same line as the keywords or on different lines. For more information, see Fundamentals Configuration Guide.
# Configure the legal banner.
[Sysname] header legal
Welcome to use the legal banner%
job
Use job to assign a job to a schedule.
Use undo job to revoke a job.
job job-name
undo job job-name
No job is assigned to a schedule.
Schedule view
job-name: Specifies the job name, a case-sensitive string of 1 to 47 characters.
You can assign multiple jobs to a schedule. The jobs in a schedule are executed concurrently.
The jobs to be assigned to a schedule must already exist. To create a job, use the scheduler job command.
# Assign job save-job to schedule saveconfig.
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
scheduler job
scheduler schedule
memory-threshold
Use memory-threshold to set free-memory thresholds.
Use undo memory-threshold to restore the defaults.
In standalone mode:
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ ratio ] minor minor-value severe severe-value critical critical-value normal normal-value [ early-warning early-warning-value secure secure-value ]
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Minor alarm threshold: 10 % of the total memory on the slot.
Severe alarm threshold: 7 % of the total memory on the slot.
Critical alarm threshold: 4 % of the total memory on the slot.
Normal state threshold: 13 % of the total memory on the slot.
Early-warning threshold: 16 % of the total memory on the slot.
Sufficient-memory threshold: 18 % of the total memory on the slot.
ratio: Specifies free-memory thresholds in percentage. If you do not specify this keyword, the command sets free-memory thresholds in MB.
minor minor-value: Specifies the minor alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the minor-value argument. Setting this threshold to 0 disables the minor alarm feature.
severe severe-value: Specifies the severe alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the severe-value argument. Setting this threshold to 0 disables the severe alarm feature.
critical critical-value: Specifies the critical alarm threshold. To view the value range for this threshold, enter a question mark (?) in the place of the critical-value argument. Setting this threshold to 0 disables the critical alarm feature.
normal normal-value: Specifies the normal state threshold. To view the value range for this threshold, enter a question mark (?) in the place of the normal-value argument.
early-warning early-warning-value: Specifies the early-warning threshold. To view the value range for this threshold, enter a question mark (?) in the place of the early-warning-value argument. Setting this threshold to 0 disables the early warning feature.
secure secure-value: Specifies the sufficient-memory threshold. To view the value range for this threshold, enter a question mark (?) in the place of the secure-value argument.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets free-memory thresholds for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command sets free-memory thresholds for the global active MPU. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. If the amount of free memory space decreases to or below the minor, severe, or critical alarm threshold, the system issues an alarm to affected service modules or processes.
For slots that support low memory, the system monitors only the amount of free low-memory space. You can use the display memory command to display memory usage information. If the LowMem field is displayed for a slot, the slot supports low memory.
The early warning feature warns you of an approaching insufficient-memory condition.
If a memory alarm occurs, delete unused configuration items or disable some features to increase the free memory space. Because the memory space is insufficient, some configuration items might not be able to be deleted.
For more information about the thresholds, see Fundamentals Configuration Guide.
After you execute this command, if the amount of the free memory space reaches an alarm threshold, the system does not support creating a segment or entering its view. However, an existing microsegment will not be affected by this command.
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 64 MB, 48 MB, 32 MB, and 96 MB, respectively.
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 3%, 2%, 1%, and 5% of the total memory size, respectively.
[Sysname] memory-threshold ratio minor 3 severe 2 critical 1 normal 5
memory-threshold usage
Use memory-threshold usage to set the memory usage threshold.
Use undo memory-threshold usage to restore the default.
In standalone mode:
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
In IRF mode:
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage memory-threshold
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage
The memory usage threshold is 100%.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the memory usage threshold for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command sets the memory usage threshold for the global active MPU. (In IRF mode.)
memory-threshold: Specifies the memory usage threshold in percentage. The value range is 0 to 100.
The device samples memory usage at 1-minute intervals. If the sample is greater than the memory usage threshold, the device sends a trap.
# Set the memory usage threshold to 80%.
[Sysname] memory-threshold usage 80
monitor cpu-usage enable
Use monitor cpu-usage enable to enable CPU usage monitoring.
Use undo monitor cpu-usage enable to disable CPU usage monitoring.
In standalone mode:
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU usage monitoring is enabled.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command enables CPU usage monitoring for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command enables CPU usage monitoring for the global active MPU. (In IRF mode.)
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the interval specified by the monitor cpu-usage interval command. You can use the display cpu-usage history command to view recent CPU usage.
# Enable CPU usage monitoring.
[Sysname] monitor cpu-usage enable
display cpu-usage configuration
Use monitor cpu-usage interval to set the sampling interval for CPU usage monitoring.
Use undo monitor cpu-usage interval to restore the default.
In standalone mode:
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor cpu-usage interval interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The system samples CPU usage every 1 minute.
interval: Specifies the sampling interval for CPU usage monitoring. Valid values include 5Sec (5 seconds), 1Min (1 minute), and 5Min (5 minutes), case insensitive.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the interval for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command sets the interval for the global active MPU. (In IRF mode.)
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the specified interval. You can use the display cpu-usage history command to view recent CPU usage.
# Set the sampling interval for CPU usage monitoring to 5 seconds.
[Sysname] monitor cpu-usage interval 5Sec
monitor cpu-usage logging interval
Use monitor cpu-usage logging interval to enable periodic CPU usage logging.
Use undo monitor cpu-usage logging interval to disable periodic CPU usage logging.
monitor cpu-usage logging interval interval-time
Periodic CPU usage logging is disabled.
interval interval-time: Specifies the logging interval in seconds, a multiple of five in the range of 5 to 300.
# Enable periodic CPU usage logging and set the logging interval to 60 seconds.
[Sysname] monitor cpu-usage logging interval 60
monitor cpu-usage threshold
Use monitor cpu-usage threshold to set CPU usage alarm thresholds.
Use undo monitor cpu-usage threshold to restore the default.
In standalone mode:
monitor cpu-usage threshold severe-threshold minor-threshold minor-threshold recovery-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold minor-threshold recovery-threshold [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor cpu-usage threshold severe-threshold minor-threshold minor-threshold recovery-threshold recovery-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold minor-threshold recovery-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Severe CPU usage alarm threshold: 99%.
Minor CPU usage alarm threshold: 80%.
CPU usage recovery threshold: 60%.
severe-threshold: Specifies the severe CPU usage alarm threshold in percentage. The value range for this argument is 2 to 100.
minor-threshold minor-threshold: Specifies the minor CPU usage alarm threshold in percentage. The value range for this argument is 1 to the severe CPU usage alarm threshold minus 1.
recovery-threshold recovery-threshold: Specifies the CPU usage recovery threshold in percentage. The value range for this argument is 0 to the minor CPU usage alarm threshold minus 1.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets the CPU usage threshold for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command sets the CPU usage threshold for the global active MPU. (In IRF mode.)
CAUTION
CAUTION:
If you set the severe CPU usage alarm threshold to a too low value, the device will reach the threshold easily. Normal services will be affected.
The device samples CPU usage and CPU core usage at 1-minute intervals. If the sample is greater than the CPU usage threshold, the device sends a trap.
# Set the severe CPU usage alarm threshold to 90%, minor CPU usage alarm threshold to 80%, and CPU usage recovery threshold to 70%.
[Sysname] monitor cpu-usage threshold 90 minor-threshold 80 recovery-threshold 70
monitor handshake-timeout disable-port
Use monitor handshake-timeout disable-port to enable the port-down feature globally.
Use undo monitor handshake-timeout disable-port to disable the feature globally.
The port-down feature is enabled.
The port-down feature applies to scenarios where two devices (one active and one standby) are used for high availability, for example, a network deployed with VRRP. This feature shuts down all service ports on the active device immediately after both MPUs on the active device are removed or reboot abnormally. The shutdown operation ensures quick service switchover to the standby device.
This feature takes effect only when no MPUs are available on the active device.
# Enable the port-down feature globally.
[Sysname] monitor handshake-timeout disable-port
Set successful!
monitor memory-usage logging interval
Use monitor memory-usage logging interval to enable periodic memory usage logging.
Use undo monitor memory-usage logging interval to disable periodic memory usage logging.
monitor memory-usage logging interval interval-time
Periodic memory usage logging is disabled.
# Enable periodic memory usage logging and set the logging interval to 60 seconds.
[Sysname] monitor memory-usage logging interval 60
monitor resend cpu-usage
Use monitor resend cpu-usage to set CPU usage alarm resending intervals.
Use undo monitor resend cpu-usage to restore the default.
In standalone mode:
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor resend cpu-usage { minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The minor alarm resending interval is 300 seconds. The severe alarm resending interval is 60 seconds.
minor-interval minor-interval: Specifies the minor alarm resending interval in seconds, a multiple of five in the range of 10 to 3600.
severe-interval severe-interval: Specifies the severe alarm resending interval in seconds, a multiple of five in the range of 10 to 3600.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command sets alarm resending intervals for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command sets alarm resending intervals for the global active MPU. (In IRF mode.)
The device samples CPU usage periodically and compares the sample with the CPU usage threshold. If the sample increases above an alarm threshold, the CPU usage enters an alarm state and the device sends an alarm.
While the CPU usage is in minor alarm state, the device sends minor alarms periodically until the CPU usage increases above the severe threshold or the minor alarm is removed.
While the CPU usage is in severe alarm state, the device sends severe alarms periodically until the severe alarm is removed.
You can use this command to change CPU usage alarm resending intervals.
If you do not specify the minor-interval or severe-interval keyword, the undo monitor resend cpu-usage command restores default settings for both the minor and severe alarm resending intervals.
# (In standalone mode.) Set the CPU usage minor alarm resending interval to 60 seconds for CPU 0 in slot 1.
[Sysname] monitor resend cpu-usage minor-interval 60 slot 1 cpu 0
monitor resend memory-threshold
Use monitor resend memory-threshold to set memory depletion alarm resending intervals.
Use undo monitor resend memory-threshold to restore the default.
In standalone mode:
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor resend memory-threshold { critical-interval critical-interval | early-warning-interval early-warning-interval | minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
·     Early warning resending interval: 1 hour.
·     Minor alarm resending interval: 12 hours.
·     Severe alarm resending interval: 3 hours.
·     Critical alarm resending interval: 1 hour.
critical-interval critical-interval: Specifies the critical alarm resending interval in hours, in the range of 1 to 48.
early-warning-interval early-warning-interval: Specifies the early warning resending interval in hours, in the range of 1 to 48.
minor-interval minor-interval: Specifies the minor alarm resending interval in hours, in the range of 1 to 48.
severe-interval severe-interval: Specifies the severe alarm resending interval in hours, in the range of 1 to 48.
The device samples the amount of free memory space periodically and compares the sample with free-memory thresholds. If the sample decreases to or below a threshold, the device enters a memory depletion alarm state and sends an alarm.
In critical alarm state, the device sends critical alarm notifications periodically until the critical alarm is removed.
In a lower alarm state, the device sends notifications for the alarm state periodically until it enters a higher alarm state or the current alarm is removed.
You can use this command to change the alarm resending intervals.
If you do not specify any memory depletion alarm resending intervals, the undo monitor resend memory-threshold command restores default settings for all memory depletion alarm resending intervals.
# (In standalone mode.) Set the minor memory depletion alarm resending interval to 12 hours for CPU 0 in slot 1.
[Sysname] monitor resend memory-threshold minor-interval 12 slot 1 cpu 0
parity-error consistency-check log enable
Use parity-error consistency-check log enable to enable consistency error logging for software and hardware forwarding entries.
Use undo parity-error consistency-check log enable to disable consistency error logging for software and hardware forwarding entries.
Consistency error logging is disabled for software and hardware forwarding entries.
To forward packets, the device generates hardware forwarding entries on forwarding chips and software forwarding entries in memory at the same time. The device automatically detects whether the hardware forwarding entries and the software forwarding entries are consistent.
After you execute this command, the device collects consistency errors periodically. If the number of consistency errors in a statistics period reaches or exceeds the logging threshold, the device generates and sends a log message to the information center module. The information center module determines how and where to send the message. For more information about the information center module, see information center configuration in Network Management and Monitoring Configuration Guide.
# Enable consistency error logging for software and hardware forwarding entries.
[Sysname] parity-error consistency-check log enable
parity-error consistency-check threshold
Use parity-error consistency-check period to set the logging threshold for consistency errors between software and hardware forwarding entries.
Use undo parity-error consistency-check period to restore the default.
parity-error consistency-check threshold value
undo parity-error consistency-check threshold
The logging threshold is 10.
value: Specifies the logging threshold for consistency errors between software and hardware forwarding entries, in the range of 1 to 2147483647.
After you enable consistency error logging for software and hardware forwarding entries, the device collects statistics for consistency errors periodically. If the number of consistency errors reaches or exceeds the logging threshold, the device generates a log message.
# Set the logging threshold to 20 for consistency errors between software and hardware forwarding entries.
[Sysname] parity-error consistency-check threshold 20
parity-error monitor log enable
Use parity-error monitor log enable to enable parity error and ECC error logging for entries on forwarding chips.
Use undo parity-error monitor log enable to disable parity error and ECC error logging for entries on forwarding chips.
Parity error and ECC error logging is disabled for entries on forwarding chips.
The device automatically detects parity errors and ECC errors in entries on forwarding chips.
After you execute this command, the device collects parity errors and ECC errors periodically. If the number of parity errors and ECC errors in a statistics period reaches or exceeds the logging threshold, the device generates and sends a parity error and ECC error log message to the information center module. The information center module determines how and where to send the message. For more information about the information center module, see information center configuration in Network Management and Monitoring Configuration Guide.
# Enable parity error and ECC error logging for entries on forwarding chips.
[Sysname] parity-error monitor log enable
parity-error monitor period
parity-error monitor threshold
Use parity-error monitor period to set the parity error and ECC error statistics period for entries on forwarding chips.
Use undo parity-error monitor period to restore the default.
parity-error monitor period value
The parity error and ECC error statistics period is 60 seconds for entries on forwarding chips.
period: Specifies the parity error and ECC error statistics period in seconds, in the range of 1 to 86400.
The device automatically detects parity errors and ECC errors in entries on forwarding chips. The parity error and ECC error logging feature collects parity error and ECC error statistics periodically, and generates a log message if the number of parity error and ECC errors reaches the logging threshold.
This command determines the period for the device to collect parity error and ECC error statistics.
# Set the parity error and ECC error statistics period to 120 seconds.
[Sysname] parity-error monitor period 120
Use parity-error monitor threshold to set the parity error and ECC error logging threshold for entries on forwarding chips.
Use undo parity-error monitor threshold to restore the default.
parity-error monitor threshold value
The parity error and ECC error logging threshold is 5000 for entries on forwarding chips.
value: Specifies the parity error and ECC error logging threshold for entries on forwarding chips, in the range of 1 to 1000000.
The device detects parity error and ECC errors in entries on forwarding chips. The parity error and ECC error logging feature collects parity error and ECC error statistics periodically, and generates a log message if the number of parity error and ECC errors reaches the logging threshold. This command sets the logging threshold.
# Set the parity error and ECC error logging threshold to 8000 for entries on forwarding chips.
[Sysname] parity-error monitor threshold 8000
parity-error unrecoverable log enable
Use parity-error unrecoverable log enable to enable uncorrectable parity error and ECC error logging for entries on forwarding chips.
Use undo parity-error unrecoverable log enable to disable uncorrectable parity error and ECC error logging for entries on forwarding chips.
Uncorrectable parity error and ECC error logging is enabled for entries on forwarding chips
The device automatically detects parity errors and ECC errors in entries on forwarding chips and tries to correct the error when an error is detected. The uncorrectable parity error and ECC error logging feature enables the device to collect uncorrectable parity error and ECC error statistics periodically. If the number of uncorrectable parity errors and ECC errors reaches or exceeds the logging threshold, the device generates and sends an uncorrectable parity error and ECC error log message to the information center module. The information center module determines how and where to send the log message. For more information about the information center module, see information center configuration in Network Management and Monitoring Configuration Guide.
# Enable uncorrectable parity error and ECC error logging for entries on forwarding chips
[Sysname] parity-error unrecoverable log enable
parity-error unrecoverable period
parity-error unrecoverable reboot
parity-error unrecoverable threshold
Use parity-error unrecoverable period to set the statistics period for uncorrectable parity errors and ECC errors for entries on forwarding chips.
Use undo parity-error unrecoverable period to restore the default.
parity-error unrecoverable period period
The statistics period for uncorrectable parity errors and ECC errors for entries on forwarding chips is 60 seconds.
period: Specifies the statistics period for uncorrectable parity errors and ECC errors for entries on forwarding chips. The value is in the range of 1 to 86400, in seconds.
The device automatically detects parity errors and ECC errors in entries on forwarding chips and tries to correct the error when an error is detected. The uncorrectable parity error and ECC error logging feature enables the device to collect uncorrectable parity error and ECC error statistics periodically. If the number of uncorrectable parity errors and ECC errors reaches or exceeds the logging threshold, the device generates an uncorrectable parity error and ECC error log message.
This command sets the period for the device to collect uncorrectable parity error and ECC error statistics.
# Set the statistics period for uncorrectable parity errors and ECC errors in entries on forwarding chips to 120 seconds.
[Sysname] parity-error unrecoverable period 120
Use parity-error unrecoverable reboot to enable automatic system reboot upon generation of an uncorrectable parity error and ECC error log.
Use undo parity-error unrecoverable reboot to disable automatic system reboot upon generation of an uncorrectable parity error and ECC error log
The system reboots automatically upon generation of an uncorrectable parity error and ECC error log.
Uncorrectable parity errors and ECC errors in entries on forwarding chips might affect system services. To remove the errors from the entries on forwarding chips, you can configure this command to enable automatic system reboot upon generation of an uncorrectable parity error and ECC error log.
# Enable automatic system reboot upon generation of an uncorrectable parity error and ECC error log.
[Sysname] parity-error unrecoverable reboot
Use parity-error unrecoverable threshold to set the logging threshold for uncorrectable parity errors and ECC errors on entries on forwarding chips.
Use undo parity-error unrecoverable threshold to restore the default.
parity-error unrecoverable threshold value
The logging threshold for uncorrectable parity errors and ECC errors in entries on forwarding chips is 1.
value: Specifies the logging threshold for uncorrectable parity errors and ECC errors in entries on forwarding chips. The value is in the range of 1 to 1000000.
# Set the logging threshold for uncorrectable parity errors and ECC errors in entries on forwarding chips to 10.
[Sysname] parity-error unrecoverable log threshold 10
password-recovery enable
Use password-recovery enable to enable password recovery capability.
Use undo password-recovery enable to disable password recovery capability.
Password recovery capability is enabled.
Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure new passwords.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
(In standalone mode.) (In IRF mode.) To access the device configuration without authentication, you must connect to the active MPU and access the BootWare menu while the MPU is starting up.
Availability of BootWare menu options depends on the password recovery capability setting. For more information, see Fundamentals Configuration Guide. .
# Disable password recovery capability.
[Sysname] undo password-recovery enable
power-supply off
Use power-supply off to power off a card.
In standalone mode:
power-supply off slot slot-number
In IRF mode:
power-supply off chassis chassis-number slot slot-number
CAUTION
CAUTION:
A card cannot receive or send packets after a forced power-off. Before executing this command, make sure you understand its impact on the live network.
To use this command, you must enable power supply management first.
When power is insufficient, you can power off interface cards that are idle or connected to unimportant network nodes to ensure power supply to critical interface cards.
(In IRF mode.) Do not power off an interface card that contains IRF physical interfaces.
# (In standalone mode.) Power off a card.
<Sysname> power-supply off slot 2
power-supply policy enable
power-supply on
Use power-supply on to power on a card or subcard.
In standalone mode:
power-supply on slot slot-number
In IRF mode:
power-supply on chassis chassis-number slot slot-number
# (In standalone mode.) Power on a card.
<Sysname> power-supply on slot 2
Use power-supply policy enable to enable power supply management.
Use undo power-supply policy enable to disable power supply management.
In standalone mode:
In IRF mode:
power-supply policy chassis chassis-number enable
undo power-supply policy chassis chassis-number enable
Power supply management is disabled.
chassis chassis-number: Specifies an IRF member device by its member ID. (In IRF mode.)
# (In standalone mode.) Enable power supply management.
[Sysname] power-supply policy enable
power-supply policy priority
Use power-supply policy priority to specify a power supply priority for an interface card.
Use undo power-supply policy priority to restore the default.
In standalone mode:
power-supply policy slot slot-number priority priority
undo power-supply policy slot slot-number priority
In IRF mode:
power-supply policy chassis chassis-number slot slot-number priority priority
undo power-supply policy chassis chassis-number slot slot-number priority
The power supply priority is 5 for an interface card.
priority: Specifies the priority value. The value range is 0 to 10. A smaller priority value represents a higher priority.
slot slot-number: Specifies an interface card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an interface card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
This command takes effect only if power supply management is enabled.
Specify smaller priority values for critical-service cards so they are preferentially powered.
The system automatically guarantees that an interface card that holds IRF physical interfaces receives a higher priority.
·     After you bind interfaces on an interface card to IRF ports, the system automatically assigns the interface card a higher priority. You cannot use this command to change the power supply priority for the card anymore.
·     If you specify a power supply priority for an interface card and then bind its interfaces to IRF ports, the priority setting is retained but does not take effect.
# (In standalone mode.) Set the power supply priority for a card to 10.
[Sysname] power-supply policy slot 2 priority 10
power-supply policy redundant
Use power-supply policy redundant to specify the number of redundant power modules.
Use undo power-supply policy redundant to restore the default.
In standalone mode:
power-supply policy redundant module-count
In IRF mode:
power-supply policy chassis chassis-number redundant module-count
undo power-supply policy chassis chassis-number redundant
The number of redundant power supplies is 0.
module-count: Specifies the number of redundant power modules. To view the value range for this argument, enter a question mark (?) in the place of this argument. The upper limit for the value range is the maximum number of redundant power modules supported by the system. The actual number of redundant power modules that you can specify varies by the number of the interface cards and their power consumption. The actual number is smaller than or equal to the maximum number.
# (In standalone mode.) Set the number of redundant power modules to 1.
[Sysname] power-supply policy redundant 1
reboot
Use reboot to reboot the device.
In standalone mode:
In IRF mode:
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify an IRF member device, the command reboots all IRF member devices. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command reboots the IRF member device. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command reboots the entire device. (In standalone mode.)
force: Reboots the device immediately without performing software or hard disk check. If this keyword is not specified, the system first identifies whether the reboot might result in data loss or a system failure. For example, the system identifies whether the main system software image file exists and whether a write operation is in progress on a storage medium. If the reboot might cause problems, the system does not reboot the device.
CAUTION
CAUTION:
·     A reboot might interrupt network services.
·     Use the force keyword only when the device fails or a reboot command without the force keyword cannot perform a reboot correctly. A reboot command with the force keyword might result in file system corruption because it does not perform data protection.
If the main startup software images are corrupt or missing, you must re-specify a set of main startup software images before executing the reboot command.
For data security, the device does not reboot if you reboot the device while the device is performing file operations.
In standalone mode:
If the device does not have a standby MPU, rebooting the active MPU reboots the entire device. If the device has a standby MPU and the standby MPU is operating correctly, rebooting the active MPU triggers a switchover.
To ensure correct operation of the system and cards, do not trigger a switchover by rebooting the active MPU if the standby MPU is not in Stable state. To view the status of the standby MPU, execute the display system stable state command.
In IRF mode:
If the IRF fabric has only one MPU, rebooting the MPU reboots the entire IRF fabric. If the IRF fabric has a global standby MPU and the MPU is operating correctly, rebooting the global active MPU triggers a switchover.
To ensure correct operation of the IRF fabric and cards, do not trigger a switchover by rebooting the global active MPU if no global standby MPUs are in Stable state. To view the status of global standby MPUs, execute the display system stable state command.
# (In standalone mode.) Reboot the device. Save the running configuration at prompt.
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to mainboard device successfully.
Now rebooting, please wait...
# Reboot the device immediately without performing software check.
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
reset asset-info
Use reset asset-info to clear the asset profile for a physical component.
In standalone mode:
reset asset-info { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom | department | description | location | service-date | state ]
In IRF mode:
reset asset-info chassis chassis-number { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom| department | description | location | service-date | state ]
chassis: Clears the asset profile for the frame. The device does not support this keyword.
fan fan-id: Clears the asset profile of the specified fan tray. The device does not support this option.
power power-id: Clears the asset profile for the specified power module. The device does not support this option.
slot slot-number: Clears the asset profile for the card in the specified slot.
csn: Clears the asset ID.
custom: Clears customized asset items.
department: Clears the department name.
description: Clears the asset description.
service-date: Clears the service start date.
state: Clears the usage status
To clear an item in an asset profile, specify the corresponding keyword for the command. To clear all items in an asset profile, do not specify the item keywords.
# (In standalone mode.) Clear the asset ID for slot 0.
[Sysname] reset asset-info slot 0 csn
display asset-info
set asset-info
reset scheduler logfile
Use reset scheduler logfile to clear job execution log information.
# Clear job execution log information.
<Sysname> reset scheduler logfile
display scheduler logfile
Use reset version-update-record to clear startup software image upgrade records.
# Clear the startup software image upgrade records.
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
resource-monitor minor resend enable
Use resource-monitor minor resend enable to enable resending of minor resource depletion alarms.
Use undo resource-monitor minor resend enable to disable resending of minor resource depletion alarms.
Resending of minor resource depletion alarms is enabled.
This feature is not supported when uRPF is configured on the device. For more information about uRPF, see Security Configuration Guide.
This feature is not supported when the arp mode uni command is configured on the device. For more information, see ARP configuration in Layer 3–IP Services Configuration Guide.
This feature is not supported when the ipv6 nd mode uni command is configured on the device. For more information, see IPv6 basics in Layer 3–IP Services Configuration Guide.
This feature is not supported on EC, SF, or SA interface modules.
This feature is not supported on FD, FE, or SG interface modules when the service module operating mode is bridging or enhance-bridge.
When a resource type enters minor alarm state, the device issues a minor alarm. If the resource type stays in minor alarm state or changes from severe alarm state to minor alarm state, the device identifies whether resending of minor resource depletion alarms is enabled. If the feature is disabled, the device does not issue additional minor alarms. If the feature is enabled, the device resends minor alarms periodically.
The resending period is fixed at 24 hours for a severe alarm and is fixed at 7 * 24 hours for a minor alarm.
# Enable resending of minor resource depletion alarms.
[Sysname] resource-monitor minor resend enable
display resource-monitor
resource-monitor output
resource-monitor resource
Use resource-monitor output to specify destinations for resource depletion alarms.
Use undo resource-monitor output to remove destinations for resource depletion alarms.
undo resource-monitor output [ netconf-event | snmp-notification | syslog ] *
Resource depletion alarms are sent to NETCONF, SNMP, and the information center.
netconf-event: Sends resource depletion alarms to the NETCONF feature to encapsulate the alarms in NETCONF events. For more information, see NETCONF in Network Management and Monitoring Configuration Guide.
snmp-notification: Sends resource depletion alarms to the SNMP feature to encapsulate the alarms in SNMP traps and informs. For more information, see SNMP in Network Management and Monitoring Configuration Guide.
syslog: Sends resource depletion alarms to the information center to encapsulate the alarms in log messages. For more information, see information center in Network Management and Monitoring Configuration Guide.
This feature is not supported on EC, SF, SA interface modules.
If you do not specify any keywords for the undo resource-monitor output command, the command disables resource depletion alarm output.
# Specify the information center module as the output destination for resource depletion alarms.
[Sysname] resource-monitor output syslog
Use resource-monitor resource to set resource depletion thresholds.
Use undo resource-monitor resource to disable resource depletion thresholds.
In standalone mode:
undo resource-monitor resource resource-name slot slot-number cpu cpu-number
In IRF mode:
resource-monitor resource resource-name  chassis chassis-number slot slot-number cpu cpu-number by-percent minor-threshold minor-threshold severe-threshold severe-threshold
undo resource-monitor resource resource-name chassis chassis-number slot slot-number cpu cpu-number
The default settings vary by resource type. Use the display resource-monitor command to display the resource depletion thresholds.
resource-name: Specifies a resource type by its name. The values for this argument are case insensitive and cannot be abbreviated. Table 24 shows the resource types that can be monitored.
Table 24 Resource types that can be monitored
Resource type
ac
Ethernet service instances.
agg_group
Aggregation group resources.
arp
ARP resources.
ecmpgroup
ECMP group resources.
host
Host route resources.
ipmc
Layer 3 multicast replication table resources.
ipv6_127
Resources for IPv6 routes with a prefix length of 65 to 127 bits.
ipv6_128
Resources for IPv6 routes with a prefix length of 128 bits.
ipv6_64
Resources for IPv6 routes with a prefix length of 0 to 64 bits.
l2mc
Multicast replication table resources for a VLAN.
mac
MAC address table resources.
mqcin
Inbound MQC resources.
mqcout
Outbound MQC resources.
nd
ND resources.
nexthoppool1
Next-hop pool resources for the underlay network.
openflow
OpenFlow resources.
pbr
PBR resources.
pfilterin
Inbound packet filter resources.
pfilterout
Outbound packet filter resources.
route
Routing resources.
rport
Layer 3 Ethernet interface resources.
vlaninterface
VLAN interface resources.
vrf
VPN instance resources.
vsi
VSIs.
vsiintf
VSI interface resources.
by-percent: Specifies resource depletion thresholds in percentage.
minor-threshold minor-threshold: Specifies the minor resource depletion threshold. To view the value range, enter a question mark (?) in the place of the minor-threshold argument.
severe-threshold severe-threshold: Specifies the severe resource depletion threshold. To view the value range, enter a question mark (?) in the place of the severe-threshold argument.
After you execute this command for a resource type, the device monitors the available amount of the type of resources. The device samples the available amount at intervals, compares the sample with the resource depletion thresholds to identify the resource depletion status, and sends alarms as configured.
# (In standalone mode.) Set the minor resource depletion threshold to 30% and the severe resource depletion threshold to 10% for ARP entry resources on slot 1.
[Sysname] resource-monitor resource arp slot 1 cpu 0 by-percent minor-threshold 30 severe-threshold 10
restart standby
Use restart standby to reboot the standby MPU.
restart standby
This command is available only in standalone mode.
This command is supported only on the default MDC.
Executing this command has the same effect as specifying the slot number for the reboot slot slot-number command and executing the command. This command does not require an argument and is easier to use.
# Reboot the standby MPU.
[Sysname] restart standby
Rebooting the standby MPU. Continue?[Y/N]:y
The standby MPU is rebooting. Please wait...
reboot
restore factory-default
Use restore factory-default to restore the factory-default configuration for the device.
CAUTION
CAUTION:
This command restores the device to the factory default settings. Before executing this command, make sure you understand its impact on the live network.
This command is disruptive. Use this command only when you cannot troubleshoot the device by using other methods, or you want to use the device in a different scenario.
# Restore the factory-default configuration for the device.
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
reboot
scheduler job
Use scheduler job to create a job and enter its view, or enter the view of an existing job.
Use undo scheduler job to delete a job.
scheduler job job-name
undo scheduler job job-name
No job exists.
A job can be referenced by multiple schedules. In job view, you can assign commands to the job.
# Create a job named backupconfig and enter job view.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig]
command
scheduler schedule
scheduler logfile size
Use scheduler logfile size to set the size of the job execution log file.
scheduler logfile size value
The size of the job execution log file is 16 KB.
value: Specifies the size of the job execution log file, in KB. The value range is 16 to 1024.
The job execution log file saves the execution information of jobs. If the file is full, old records are deleted to make room for new records. If the size of the log information to be written to the file is greater than the file size, the excessive information is not written to the file.
# Set the size of the job execution log file to 32 KB.
[Sysname] scheduler logfile size 32
scheduler reboot at
Use scheduler reboot at to specify the reboot date and time.
Use undo scheduler reboot to delete the reboot schedule configuration.
No reboot date or time is specified.
time: Specifies the reboot time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the reboot date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION
CAUTION:
This command enables the device to reboot at a scheduled time, which causes service interruption. Before using this command, make sure you fully understand its impact on your live network.
When the date argument is not specified, the system uses the following rules to determine the reboot time:
·     If the reboot time is later than the current time, a reboot occurs at the reboot time of the current day.
·     If the reboot time is earlier than the current time, a reboot occurs at the reboot time the next day.
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and scheduler reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
For data security, the system does not reboot at the reboot time if a file operation is being performed.
# Configure the device to reboot at 12:00 p.m. This example assumes that the current time is 11:43 a.m. on June 6, 2015.
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2015 (in 0 hours and 16 minutes). Confirm? [Y/N]:
Use scheduler reboot delay to specify the reboot delay time.
scheduler reboot delay time
No reboot delay time is specified.
time: Specifies the reboot delay time in the hh:mm or mm format. This argument can contain up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
CAUTION
CAUTION:
The device supports only one device reboot schedule. If you execute both the scheduler reboot delay and schedule reboot at commands or execute one of the commands multiple times, the most recent configuration takes effect.
# Configure the device to reboot after 88 minutes. This example assumes that the current time is 11:48 a.m. on June 6, 2015.
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2015(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule
Use scheduler schedule to create a schedule and enter its view, or enter the view of an existing schedule.
Use undo scheduler schedule to delete a schedule.
undo scheduler schedule schedule-name
No schedule exists.
schedule-name: Specifies the schedule name, a case-sensitive string of 1 to 47 characters.
You can configure a schedule to have the device automatically run a command or a set of commands without administrative interference.
To configure a schedule:
1.     Use the scheduler job command to create a job and enter job view.
2.     Use the command command to assign commands to the job.
3.     Use the scheduler schedule command to create a schedule and enter schedule view.
4.     Use the job command to assign the job to the schedule. You can assign multiple jobs to a schedule. The jobs must already exist.
5.     Use the user-role command to assign user roles to the schedule. You can assign up to 64 user roles to a schedule.
6.     Use the time at, time once, or time repeating command to specify an execution time for the schedule. You can specify only one execution time for a schedule.
# Create a schedule named saveconfig.
job
time at
time once
set asset-info
Use set asset-info to configure an asset profile for a physical component.
In standalone mode:
set asset-info { chassis | fan fan-id | power power-id | slot slot-number } { csn csn-number | custom name value | department department | description description | location location | service-date date | state state }
In IRF mode:
set asset-info chassis chassis-number { chassis | fan fan-id | power power-id | slot slot-number } { csn csn-number | custom name value | department department | description description | location location | service-date date | state state }
chassis: Configures an asset profile for the frame. The device does not support this keyword.
fan fan-id: Configures an asset profile for the specified fan tray. The device does not support this option.
power power-id: Configures an asset profile for the specified power module. The device does not support this option.
slot slot-number: Configures an asset profile for the card in the specified slot.
csn csn-number: Specifies an asset ID for the asset, a string of 1 to 64 characters.
custom name value: Defines an asset profile item and specifies the value. The value can be a string of 1 to 64 characters.
department department: Specifies the department name, a string of 1 to 64 characters.
description description: Specifies the asset description, a string of 1 to 64 characters.
location location: Specifies the asset location, a string of 1 to 64 characters.
service-date date: Specifies the service start date, a string of 1 to 25 characters.
state state: Specifies the asset usage status, a string of 1 to 64 characters.
# (In standalone mode.) Set the asset ID to 123456 for slot 0.
[Sysname] set asset-info slot 0 csn 123456
display asset-info
reset asset-info
set serial-no
Use set serial-no to specify a serial number for a fan tray or power module.
In standalone mode:
set serial-no { fan fan-id | power power-id } serial-no
In IRF mode:
set serial-no chassis chassis-number { fan fan-id | power power-id } serial-no
fan fan-id: Specifies a fan tray by its ID. The value range for the fan-id argument is 0 to 14.
power power-id: Specifies a power module by its ID. The value range for the power-id argument is 0 to 15.
serial-no: Specifies the serial number for the fan tray or power module, in the range of 1 to 24.
The system provides a prompt if a fan tray or power module does not support this command.
# (In standalone mode.) Specify a serial number for fan tray 0.
[Sysname] set serial-no fan 0 210212A0561234560001
Set the serial number successfully.
# (In standalone mode.) Specify a serial number for power module 1.
[Sysname] set serial-no power 1 210212A0561234560001
DEVICE_SERIAL_NUMBER:210231A2AC0000000002
Please check the current serial number.
Continue to execute the command?[Y/N]:y
display device manuinfo fan
display device manuinfo power
display serial-no
shutdown-interval
Use shutdown-interval to set the port status detection timer.
Use undo shutdown-interval to restore the default.
shutdown-interval interval
The port status detection timer setting is 30 seconds.
interval: Specifies the port status detection timer value in seconds. The value range is 0 to 300. The value of 0 indicates that port status detection is not automatically performed, and you need to execute the undo shutdown command to restore the port status manually.
The device starts a port status detection timer when a port is shut down by a protocol. If the port has been in down state before the timer expires, the device will set the port status to the port's physical status.
If you change the timer setting during port detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
If T < T1, the port will be brought up after T1 – T seconds.
If T ≥ T1, the port is brought up immediately.
For example, the timer setting is 30 seconds. If you change it to 10 seconds 2 seconds after the port is shut down, the port will come up 8 seconds later. If you change the timer setting to 2 seconds 10 seconds after the port is shut down, the port comes up immediately.
# Set the port status detection timer to 100 seconds.
[Sysname] shutdown-interval 100
switch-mode
Use switch-mode to specify an operating mode and a proxy mode for an interface module.
Use undo switch-mode to remove the operating mode and proxy mode settings for an interface module. The interface module does not have an operating mode or a proxy mode specified.
In standalone mode:
switch-mode { balance | bridging | enhance-bridging | ipv6 | routing | legacy-layer3 | mix-bridging-routing | normal | standard-ipv6 } [ adj-proxy-high | adj-proxy-low | l3-proxy-high | route-proxy-high | route-proxy-low ] slot slot-number
undo switch-mode slot slot-number
In IRF mode:
switch-mode { balance | bridging | enhance-bridging | ipv6 | routing | legacy-layer3 | mix-bridging-routing | normal | standard-ipv6 } [ adj-proxy-high | adj-proxy-low | l3-proxy-high | route-proxy-high | route-proxy-low ] chassis chassis-number slot slot-number
undo switch-mode chassis chassis-number slot slot-number
For information about the default operating mode of an interface module, see device management in Fundamentals Configuration Guide.
An interface module does not operate in any proxy mode.
balance: Specifies the balanced mode.
ipv6: Specifies the IPv6 mode.
bridging: Specifies the extended MAC mode.
enhance-bridging: Specifies the enhanced MAC mode.
normal: Specifies the normal mode.
routing: Specifies the extended routing mode.
legacy-layer3: Specifies the legacy Layer 3 mode.
mix-bridging-routing: Specifies the extended hybrid mode.
standard-ipv6: Specifies the standard IPv6 mode.
route-proxy-high: Specifies the route proxy mode.
route-proxy-low: Specifies the route principal mode.
adj-proxy-high: Specifies the ARP/ND proxy mode.
adj-proxy-low: Specifies the ARP/ND principal mode.
l3-proxy-high: Specifies the route/ARP/ND proxy mode.
slot slot-number: Specifies the number of the slot where the interface module resides.
chassis chassis-number: Specifies the ID of the IRF member device. (In IRF mode.)
Different types of interface modules support different operating modes and proxy modes. For more information, see Fundamentals Configuration Guide.
Change to the operating or proxy mode takes effect after you save the running configuration and reboot the interface module.
Proxy modes apply to scenarios where the capacity of the routing table, ARP table, or ND table of an interface module cannot meet the requirement. You can configure the interface module as a principal and configure a second interface module that has sufficient table resources as the proxy. Then, when the principal receives a packet to be forwarded, it redirects the packet to the proxy. The proxy looks up its table for a forwarding entry.
Follow these guidelines when you set the proxy mode for an interface module:
·     If you configure an interface module as a principal or proxy, you must configure another interface module on the device as the proxy or principal. If you fail to do so, the proxy function might not operate. For example, if you set the proxy mode to route-proxy-low for an interface module, you must set the proxy mode to route-proxy-high or l3-proxy-high for another interface module on the device.
·     Do not terminate tunneled packets or MPLS packets on an interface module that is operating in route-proxy-low mode. For more information about tunneling and MPLS, see Layer 3—IP Services Configuration Guide and MPLS Configuration Guide.
·     The apply default-next-hop command in a routing policy does not take effect if the policy is applied to an interface module operating in route-proxy-low mode. For more information about policy-based routing, see Layer 3—IP Routing Configuration Guide.
·     Routing interfaces on an interface module that is operating in route-proxy-low mode do not support forwarding VPN packets. For more information about VPN, see MPLS L3VPN in MPLS Configuration Guide.
·     Routing interfaces on an interface module that is operating in route-proxy-low or adj-proxy-low mode do not support ICMP redirect or ICMPv6 redirect. For more information about ICMP redirect and ICMPv6 redirect, see IP performance optimization configuration and IPv6 basics configuration in Layer 3IP Services Configuration Guide.
·     The proxy mode does not affect forwarding of multicast packets. For more information about multicast, see multicast routing and forwarding in IP Multicast Configuration Guide.
·     The following interface modules do not support forwarding Layer 3 VXLAN traffic when operating in route-proxy-low mode:
¡     FD interface modules.
¡     FE interface modules.
¡     SG interface modules
# (In standalone mode.) Specify the standard IPv6 operating mode for the interface module in slot 2.
[Sysname] switch-mode standard-ipv6 slot 2
# (In standalone mode.) Set the operating mode to bridging and the proxy mode to route principal for the interface module in slot 2.
[Sysname] switch-mode bridging route-proxy-low slot 2
display switch-mode status
sysname
Use sysname to set the device name.
Use undo sysname to restore the default.
sysname sysname
undo sysname
The device name is H3C.
sysname: Specifies a name for the device, a string of 1 to 64 characters.
A device name identifies a device in a network and is used in CLI view prompts. For example, if the device name is Sysname, the user view prompt is <Sysname>.
# Set the name of the device to R2000.
[Sysname] sysname R2000
[R2000]
system switchover
Use system switchover to manually trigger an active/standby switchover.
system switchover
As a best practice, save the running configuration before executing this command. After you execute this command, the current active MPU reboots.
# Manually trigger an active/standby switchover when the running configuration is the same as the startup configuration.
[Sysname] system switchover
Switching to the standby MPU. Continue? [Y/N]:y
This command will perform a switchover. Continue? [Y/N]:y
# Manually trigger an active/standby switchover when the running configuration is different from the startup configuration.
Current configuration may be lost after the reboot, save current configuration?
[Y/N]:y
Please input the file name(*.cfg)[flash:/mqc.cfg]
flash:/mqc.cfg exists, overwrite? [Y/N]:y
system-working-mode
Use system-working-mode to set the system operating mode.
Use undo system-working-mode to restore the default.
system-working-mode { advance | expert | standard }
The device operates in standard mode.
advance: Sets the system operating mode to advanced.
expert: Sets the system operating mode to expert.
standard: Sets the system operating mode to standard.
The system operating mode determines the supported features and the feature specifications. For more information, see device management in Fundamentals Configuration Guide.
Change to the operating mode takes effect after a reboot.
# Set the system operating mode to advanced.
[Sysname] system-working-mode advance
Do you want to change the system working mode? [Y/N]:y
The system working mode is changed, please save the configuration and reboot the system to make it effective.
temperature-limit
Use temperature-limit to set the temperature alarm thresholds.
Use undo temperature-limit to restore the default.
In standalone mode:
temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number{ hotspot | inflow | outflow } sensor-number
In IRF mode:
temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number
The defaults vary by temperature sensor model. To view the defaults, execute the undo temperature-limit and display environment commands in turn.
hotspot: Configures temperature alarm thresholds for hotspot sensors. A hotspot sensor is typically located near a high-heat chip to monitor the chip temperature.
inflow: Configures temperature alarm thresholds for inlet sensors. An inflow sensor is located near an air inlet to monitor the ambient temperature.
outflow: Configures temperature alarm thresholds for outlet sensors. An outflow sensor is located near an air outlet to monitor the device temperature.
sensor-number: Specifies a sensor by its number. To view the value range, enter a question mark (?) in the place of this argument.
lowlimit: Specifies the low-temperature threshold in Celsius degrees. The value range varies by temperature sensor. To view the value range, enter a question mark (?) in the place of this argument.
warninglimit: Specifies the high-temperature warning threshold in Celsius degrees. This threshold must be greater than the low-temperature threshold. To view the value range, enter a question mark (?) in the place of this argument.
alarmlimit: Specifies the high-temperature alarming threshold in Celsius degrees. This threshold must be greater than the warning threshold. To view the value range, enter a question mark (?) in the place of this argument.
When the device temperature drops below the low-temperature threshold or reaches the high-temperature warning or alarming threshold, the device performs the following operations:
·     Sends log messages and traps.
·     Sets LEDs on the device panel.
# (In standalone mode.) Set temperature alarm thresholds for hotspot sensor 1 in a slot.
[Sysname] temperature-limit slot 1 hotspot 1 -10 50 60
display environment
time at
Use time at to specify an execution date and time for a non-periodic schedule.
Use undo time to delete the execution date and time configuration for a non-periodic schedule.
time at time date
undo time
No execution time or date is specified for a non-periodic schedule.
Schedule view
time: Specifies the schedule execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the schedule execution date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
The specified time (date plus time) must be later than the current system time.
The time at command, the time once command, and the time repeating command overwrite one another. The most recently executed command takes effect.
# Configure the device to execute schedule saveconfig at 01:01 a.m. on May 11, 2015.
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] time at 1:1 2015/05/11
scheduler schedule
time once
Use time once to specify one or more execution days and the execution time for a non-periodic schedule.
Use undo time to delete the execution day and time configuration for a non-periodic schedule.
time once delay time
undo time
No execution time or day is specified for a non-periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
month-date month-day: Specifies a day in the current month, in the range of 1 to 31. If you specify a day that does not exist in the current month, the configuration takes effect on that day in the next month.
week-day week-day&<1-7>: Specifies a space-separated list of up to seven week days for the schedule. Valid week day values include Mon, Tue, Wed, Thu, Fri, Sat, and Sun.
delay time: Specifies the delay time for executing the schedule, in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
If the specified time has already occurred, the schedule will be executed at the specified time the following day.
If the day in the month has already occurred, the schedule will be executed at the specified day in the following month.
If the specified day in a week has already occurred, the schedule will be executed at the specified day in the following week.
# Configure the device to execute schedule saveconfig once at 15:00.
[Sysname-schedule-saveconfig] time once at 15:00
Schedule starts at 15:00 5/11/2011.
# Configure the device to execute schedule saveconfig once at 15:00 on the coming 15th day in a month.
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# Configure the device to execute schedule saveconfig at 12:00 p.m. on the coming Monday and Friday.
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# Configure the device to execute schedule saveconfig after 10 minutes.
[Sysname-schedule-saveconfig] time once delay 10
scheduler schedule
time repeating
Use time repeating to specify an execution time table for a periodic schedule.
Use undo time to delete the execution time table configuration for a periodic schedule.
time repeating [ at time [ date ] ] interval interval
undo time
No execution time table is specified for a periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. If you do not specify this option, the current system time is used as the execution time.
date: Specifies the start date for the periodic schedule, in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month. If you do not specify this argument, the execution start date is the first day when the specified time arrives.
interval interval: Specifies the execution time interval in the hh:mm or mm format. This argument can have up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59. When in the mm format, this argument must be equal to or greater than 1 minute.
month-date [ month-day | last ]: Specifies a day in a month, in the range 1 to 31. The last keyword indicates the last day of a month. If you specify a day that does not exist in a month, the configuration takes effect on that day in the next month.
The time repeating [ at time [ date ] ] interval interval command configures the device to execute a schedule at intervals from the specified time on.
The time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ] command configures the device to execute a schedule at the specified time on every specified day in a month or week.
The time at command, the time once command, and the time repeating command overwrite one another, whichever is executed most recently takes effect.
# Configure the device to execute schedule saveconfig once an hour from 8:00 a.m. on.
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# Configure the device to execute schedule saveconfig at 12:00 p.m. every day.
[Sysname-schedule-saveconfig] time repeating at 12:00
# Configure the device to execute schedule saveconfig at 8:00 a.m. on the 5th of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# Configure the device to execute schedule saveconfig at 8:00 a.m. on the last day of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# Configure the device to execute schedule saveconfig at 8:00 a.m. every Friday and Saturday.
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
scheduler schedule
transceiver phony-alarm-disable
Use transceiver phony-alarm-disable to disable transceiver module source alarm.
Use undo transceiver phony-alarm-disable to restore the default.
Transceiver module source alarm is enabled.
Disable transceiver module source alarm if the transceiver modules were manufactured or sold by HPE.
The device regularly detects transceiver modules that have a vendor name other than HPE or do not have a vendor name. Upon detecting such a transceiver module, the device repeatedly outputs traps and logs to notify the user to replace the module.
# Disable transceiver module source alarm.
[Sysname] transceiver phony-alarm-disable
display transceiver manuinfo
user-role
Use user-role to assign user roles to a schedule.
Use undo user-role to remove user roles from a schedule.
user-role role-name
undo user-role role-name
A schedule has the user roles of the schedule creator.
Schedule view
role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. The user role can be user-defined or predefined. Predefined user roles include network-admin, network-operator, mdc-admin, mdc-operator, and level-0 to level-15.
A schedule must have one or more user roles. A command in a schedule can be executed if it is permitted by one or more user roles of the schedule. For more information about user roles, see the RBAC configuration in Fundamentals Configuration Guide.
A schedule can have a maximum of 64 user roles. After the limit is reached, you cannot assign additional user roles to the schedule.
# Assign user role rolename to schedule test.
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
command
scheduler schedule
xbar
Use xbar to set the load mode for MPUs.
In standalone mode:
xbar { load-balance | load-single }
In IRF mode:
xbar chassis chassis-number { load-balance | load-single }
The MPUs operate in load-balance mode.
load-balance: Configures the active MPU and standby MPUs to balance the load for processing and forwarding packets.
load-single: Configures the MPUs so only the active MPU processes and forwards packets. The standby MPU backs up data and monitors the status of the active MPU.
A single-MPU device supports only the load-single mode. If you set the MPU load mode to load-balance, the device automatically switches to load-single mode.
# (In standalone mode.) Set the load mode for the active MPU and the standby MPUs to load-balance.
[Sysname] xbar load-balance
display xbar
