04-Layer 3—IP Services Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Command References-R63xx-6W10504-Layer 3—IP Services Command Reference
13-NAT commands
13-NAT commands 61.22 KB
NAT commands
NAT is supported only in Release 6328 and later.
display nat session
Use display nat session to display NAT sessions.
display nat session [ { source-ip source-ip | destination-ip destination-ip } * ] [ slot slot-number ] [ verbose ]
source-ip source-ip: Displays NAT sessions for the source IP address specified by the source-ip argument. The IP address must be the source IP address of the packet that triggers the session establishment.
destination-ip destination-ip: Displays NAT sessions for the destination IP address specified by the destination-ip argument. The IP address must be the destination IP address of the packet that triggers the session establishment.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays NAT sessions for all member devices.
verbose: Displays detailed information about NAT sessions. If you do not specify this keyword, this command displays brief information about initiators of NAT sessions.
If you do not specify any parameters, this command displays detailed information about initiators of all NAT sessions.
# Display detailed information about NAT session initiators for the specified slot.
<Sysname> display nat session
Slot 1:
Initiator:
  Source      IP/port: 5.5.5.5/551
  Destination IP/port: 2.2.2.2/2048
  DS-Lite tunnel peer: -
  VPN instance/VLAN ID/VLL ID: -/-/-
  Protocol: ICMP(1)
  Inbound interface: Vlan-interface100
Total sessions found: 1
# Display detailed information about NAT sessions for the specified slot.
<Sysname> display nat session verbose
Slot 1:
Initiator:
  Source      IP/port: 5.5.5.5/546
  Protocol: ICMP(1)
Responder:
  Source      IP/port: 2.2.2.2/546
  Destination IP/port: 2.2.2.1/0
  Protocol: ICMP(1)
  Inbound interface: Vlan-interface101
State: ICMP_REPLY
Application: OTHER
Start time: 2021-04-13 10:27:23  TTL: 27s
Initiator->Responder:            0 packets          0 bytes
Responder->Initiator:            0 packets          0 bytes
Source IP/port
Source IP address and port number.
Destination IP/port
Destination IP address and port number.
DS-Lite tunnel peer
Destination address of the DS-Lite tunnel interface. If the session does not belong to any DS-Lite tunnel, this field displays a hyphen (-).
The fields identify the following information:
·     VPN instance—MPLS L3VPN instance to which the session belongs.
·     VLAN ID—VLAN to which the session belongs for Layer 2 forwarding.
·     VLL ID—INLINE to which the session belongs for Layer 2 forwarding.
If no VPN instance, VLAN ID, or VLL ID is specified, a hyphen (-) is displayed for the related field.
Protocol
Transport layer protocol type: DCCP, ICMP, Raw IP, SCTP, TCP, UDP, or UDP-Lite.
Inbound interface
Input interface.
NAT session state.
Application
Application layer protocol type, such as FTP and DNS.
This field displays OTHER for the protocol types identified by non-well-known ports.
Start time
Time when the session starts.
TTL
Remaining NAT session lifetime in seconds.
Number of packets and bytes from the initiator to the responder.
Number of packets and bytes from the responder to the initiator.
Total number of sessions.
reset nat session
display nat static
Use display nat static to display static NAT mappings.
display nat static
# Display static NAT mappings.
<Sysname> display nat static
Static NAT mappings:
  Totally 1 outbound static NAT mappings.
  IP-to-IP:
    Local IP     : 4.4.4.4
    Global IP    : 5.5.5.5
    Config status: Active
Interfaces enabled with static NAT:
  Totally 1 interfaces enabled with static NAT.
  Interface: Vlan-interface100
    Service card : ---
Static NAT mappings
Information about static NAT mappings.
Totally n outbound static NAT mappings
Total number of inbound static NAT mappings.
IP-to-IP
One-to-one static NAT mapping.
Local IP
Private IP address or address range.
Global IP
Public IP address or address range.
Interfaces that are enabled with static NAT.
Totally n interfaces enabled with static NAT
Total number of interfaces enabled with static NAT.
Interface enabled with static NAT.
Service card
Service card that processes NAT traffic. If no service card is specified on the interface, this field displays hyphens (---).
Config status
Status of the static NAT mapping configuration: Active or Inactive.
nat static
nat static enable
nat static enable
Use nat static enable to enable static NAT on an interface.
Use undo nat static enable to disable static NAT on an interface
nat static enable
Static NAT is disabled.
Interface view
Static NAT mappings take effect on an interface only after you enable static NAT on the interface.
If you configure modular QoS configuration (MQC) on a device enabled with static NAT, packets that match an ACL rule are sent to the CPU. If the packet IP addresses match a NAT rule, the device generates NAT sessions and performs forwarding in software, which might cause packet loss of established NAT sessions.
# Configure an outbound static NAT mapping between private IP address 192.168.1.1 and public IP address 2.2.2.2, and enable static NAT on VLAN-interface 100.
[Sysname] nat static outbound 192.168.1.1 2.2.2.2
[Sysname-Vlan-interface100] nat static enable
display nat static
nat static outbound
nat static outbound
Use nat static outbound to configure a mapping for outbound static NAT.
Use undo nat static outbound to remove a mapping for outbound static NAT.
nat static outbound local-ip global-ip
undo nat static outbound local-ip
No NAT mappings exist.
local-ip: Specifies a private IP address.
global-ip: Specifies a public IP address.
When the source IP address of an outgoing packet matches the local-ip, the IP address is translated into the global-ip. When the destination IP address of an incoming packet matches the global-ip, the destination IP address is translated into the local-ip.
# Configure an outbound static NAT mapping between public IP address 2.2.2.2 and private IP address 192.168.1.1.
display nat session
display nat static
nat static enable
reset nat session
Use reset nat session to clear NAT sessions.
reset nat session [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears NAT sessions for all member devices.
# Clear NAT sessions for the specified slot.
<Sysname> reset nat session slot 1
display nat session
