09-IP Multicast
HomeSupportReference GuidesMIB CompanionH3C S6805 & S6825 & S6850 & S9850 & S9820-64H MIB Companion-Release 671x-6W10009-IP Multicast
03-HH3C-MULTICAST-SNOOPING-MIB
03-HH3C-MULTICAST-SNOOPING-MIB 91.53 KB
About this MIB
Multicast snooping runs on a Layer 2 device as a multicast constraining mechanism to improve multicast forwarding efficiency. It creates Layer 2 multicast forwarding entries from IGMP or MLD packets that are exchanged between the hosts and the Layer 3 device.
Use this MIB to manage IGMP snooping and MLD snooping.
MIB file name
hh3c-multicast-snooping.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMulticastSnoop(123)
Tabular objects
hh3cMcsGlobalConfigTable
About this table
This table contains the global configuration of IGMP or MLD snooping.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cMcsGlbSnoopingType.
Object (OID)
Access
Value range
Implementation
hh3cMcsGlbSnoopingType (1.3.6.1.4.1.25506.2.123.1.1.1.1)
not-accessible
InetAddressType
IPv4: IGMP snooping
IPv6: MLD snooping
Type of the global configuration.
As per the MIB.
hh3cMcsGlbRowStatus (1.3.6.1.4.1.25506.2.123.1.1.1.2)
read-create
RowStatus
active(1)
createAndGo(4)
destroy(6)
Row status.
Supports only the following values: active(1), createAndGo(4), and destroy(6).
hh3cMcsGlbEntryLimit(1.3.6.1.4.1.25506.2.123.1.1.1.3)
read-create
Unsigned32
Standard MIB values.
Global maximum number of IGMP or MLD snooping forwarding entries.
As per the MIB.
hh3cMcsGlbHostAgingTime(1.3.6.1.4.1.25506.2.123.1.1.1.4)
read-create
Unsigned32
Unsigned32 (1.. 8097894)
Global aging time of the multicast group on ports.
As per the MIB.
hh3cMcsGlbMaxResponseTime(1.3.6.1.4.1.25506.2.123.1.1.1.5)
read-create
Unsigned32
Unsigned32(1..3174)
Global maximum query response time.
As per the MIB.
hh3cMcsGlbRouterAgingTime(1.3.6.1.4.1.25506.2.123.1.1.1.6)
read-create
Unsigned32
Global aging time of router ports.
As per the MIB.
hh3cMcsGlbLastMemQryInterval(1.3.6.1.4.1.25506.2.123.1.1.1.7)
read-create
Unsigned32
Unsigned32(1..25)
Global last member query interval.
As per the MIB.
hh3cMcsGlbDropUnknownEnabled(1.3.6.1.4.1.25506.2.123.1.1.1.8)
read-create
TruthValue
true(1),
false(2)
Whether the feature of dropping unknown packets is enabled globally.
Implementation varies by product.
Default: Disabled.
hh3cMcsVirtualUnitConfigTable
About this table
This table contains IGMP or MLD snooping settings for a virtual unit (VLAN or VSI).
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are hh3cMcsVUType, hh3cMcsVUID, and hh3cMcsVUSnoopingType.
Object (OID)
Access
Value range
Implementation
hh3cMcsVUType (1.3.6.1.4.1.25506.2.123.1.2.1.1)
not-accessible
Hh3cVirtualUnitType
INTEGER{ vlan(1), vsi(2) }
Type of a virtual unit.
As per the MIB.
hh3cMcsVUID (1.3.6.1.4.1.25506.2.123.1.2.1.2)
not-accessible
Unsigned32,
VLAN ID or VSI Index.
As per the MIB.
hh3cMcsVUSnoopingType(1.3.6.1.4.1.25506.2.123.1.2.1.3)
not-accessible
InetAddressType
IPv4: igmp snooping
IPv6: mld snooping
Type of the snooping configuration.
As per the MIB.
hh3cMcsVURowStatus (1.3.6.1.4.1.25506.2.123.1.2.1.4)
read-create
RowStatus
active(1)
createAndGo(4)
destroy(6)
Row status.
hh3cMcsVUHostAgingTime(1.3.6.1.4.1.25506.2.123.1.2.1.5)
read-create
Unsigned32
Unsigned32 (0.. 8097894)
Aging time of the multicast group on ports in the VLAN or VSI.
As per the MIB.
hh3cMcsVUMaxResponseTime(1.3.6.1.4.1.25506.2.123.1.2.1.6)
read-create
Unsigned32
Unsigned32(0..3174)
Maximum query response time in the VLAN or VSI.
As per the MIB.
hh3cMcsVURouterAgingTime(1.3.6.1.4.1.25506.2.123.1.2.1.7)
read-create
Unsigned32
Aging time of the router port in the VLAN or VSI.
As per the MIB.
hh3cMcsVULastMemQryInterval(1.3.6.1.4.1.25506.2.123.1.2.1.8)
read-create
Unsigned32
Unsigned32(0..25)
Last member query interval in the VLAN or VSI.
As per the MIB.
hh3cMcsVUDropUnknownEnabled(1.3.6.1.4.1.25506.2.123.1.2.1.9)
read-create
TruthValue
true(1),
false(2)
Whether the feature of dropping unknown packets is enabled in the VLAN or VSI.
As per the MIB.
hh3cMcsVUPimSnoopingEnabled(1.3.6.1.4.1.25506.2.123.1.2.1.10)
read-create
TruthValue
true(1),
false(2)
Whether PIM snooping is enabled in the VLAN or VSI.
As per the MIB.
hh3cMcsVUVersion(1.3.6.1.4.1.25506.2.123.1.2.1.11)
read-create
Unsigned32
2|3
Version of IGMP or MLD snooping that is running on the VLAN or VSI.
As per the MIB.
·     2—IGMPv2 snooping or MLDV1 snooping.
·     3—IGMPv3 snooping or MLDv2 snooping.
hh3cMcsVUQuerierEnabled(1.3.6.1.4.1.25506.2.123.1.2.1.12)
read-create
TruthValue
true(1),
false(2)
Whether the querier feature is enabled in the VLAN or VSI.
As per the MIB.
hh3cMcsVUQuerierInterval (1.3.6.1.4.1.25506.2.123.1.2.1.13)
read-create
Unsigned32
Unsigned32(2..31744)
General query interval in the VLAN or VSI.
As per the MIB.
hh3cMcsVUGeneQuerierSourceAddress(1.3.6.1.4.1.25506.2.123.1.2.1.14)
read-create
InetAddress
OCTET STRING (0..255)
Source IP address of IGMP or MLD general query packets.
As per the MIB.
hh3cMcsVUSpecQuerierSourceAddress(1.3.6.1.4.1.25506.2.123.1.2.1.15)
read-create
InetAddress
Source IP address of IGMP or MLD group-specific query packets.
As per the MIB.
hh3cMcsVULeaveSourceAddress(1.3.6.1.4.1.25506.2.123.1.2.1.16)
read-create
InetAddress
Source IP address of IGMP or MLD leave packets.
As per the MIB.
hh3cMcsVUReportSourceAddress(1.3.6.1.4.1.25506.2.123.1.2.1.17)
read-create
InetAddress
Source IP address of IGMP or MLD report packets.
As per the MIB.
hh3cMcsVUProxyEnabled(1.3.6.1.4.1.25506.2.123.1.2.1.18)
read-create
TruthValue
true(1),
false(2)
Whether the proxy feature is enabled in the VLAN or VSI.
As per the MIB.
hh3cMcsVUQuerierElection(1.3.6.1.4.1.25506.2.123.1.2.1.19)
read-create
TruthValue
true(1),
false(2)
Whether the querier election feature is enabled in the VLAN or VSI.
As per the MIB.
hh3cMcsL2EntryTable
About this table
This table containing a list of Layer 2 multicast group entries in a VLAN or VSI.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cMcsL2EntryVUType, hh3cMcsL2EntryVUID, hh3cMcsL2EntryAddressType, hh3cMcsL2EntryGroupAddress, hh3cMcsL2EntrySourceAddress, and hh3cMcsL2EntryIfIndex.
Object (OID)
Access
Value range
Implementation
hh3cMcsL2EntryVUType (1.3.6.1.4.1.25506.2.123.1.3.1.1)
not-accessible
Hh3cVirtualUnitType
As per the MIB.
hh3cMcsL2EntryVUID (1.3.6.1.4.1.25506.2.123.1.3.1.2)
not-accessible
Unsigned32,
VLAN ID or VSI index.
As per the MIB.
hh3cMcsL2EntryAddressType(1.3.6.1.4.1.25506.2.123.1.3.1.3)
not-accessible
InetAddressType
IPv4: IGMP snooping
IPv6: MLD snooping
Type of the multicast group address.
As per the MIB.
hh3cMcsL2EntryGroupAddress(1.3.6.1.4.1.25506.2.123.1.3.1.4)
not-accessible
InetAddress
Address of the multicast group which the port joined.
As per the MIB.
hh3cMcsL2EntrySourceAddress(1.3.6.1.4.1.25506.2.123.1.3.1.5)
not-accessible
InetAddress
IP address of the unicast source which the port joined.
As per the MIB.
hh3cMcsL2EntryIfIndex(1.3.6.1.4.1.25506.2.123.1.3.1.6)
not-accessible
InterfaceIndex
Integer32(1..2147483647)
Index of an outgoing interface.
As per the MIB.
hh3cMcsL2EntryPortType (1.3.6.1.4.1.25506.2.123.1.3.1.7)
read-only
INTEGER
interface(1),
ac(2),
npw(3),
upw(4),
trill(5),
tunnel(6),
mtunnel(7)
Type of the outgoing interface.
As per the MIB.
hh3cMcsL2EntryPorAttribute (1.3.6.1.4.1.25506.2.123.1.3.1.8)
read-only
BITS
BITS {
d(0),
s(1),
p(2),
k(3),
r(4),
w(5),
b(6),
e(7),
de(8),
ee(9),
suc(10),
f(11)
Attributes of the outgoing interface.
As per the MIB.
hh3cMcsPacketStatisticsTable
About this table
This table contains IGMP or MLD packets statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cMcsStatisticsSnoopingType.
Object (OID)
Access
Value range
Implementation
hh3cMcsStatisticsSnoopingType(1.3.6.1.4.1.25506.2.123.1.4.1.1)
not-accessible
InetAddressType
IPv4: IGMP Snooping
IPv6: MLD Snooping
As per the MIB.
hh3cMcsRxGeneryQueryNum(1.3.6.1.4.1.25506.2.123.1.4.1.2)
read-only
Counter64
INTEGER(0..18446744073709551615)
Number of IGMP or MLD general query packets received on the device.
As per the MIB.
hh3cMcsRxV2SpecificQueryNum(1.3.6.1.4.1.25506.2.123.1.4.1.3)
read-only
Counter64
Number of IGMPv2 or MLDv1 group-specific query packets received on the device.
As per the MIB.
hh3cMcsRxV3SpecificQueryNum(1.3.6.1.4.1.25506.2.123.1.4.1.4)
read-only
Counter64
Number of IGMPv3 or MLDv2 group-specific query packets received on the device.
As per the MIB.
hh3cMcsRxV1ReportNum (1.3.6.1.4.1.25506.2.123.1.4.1.5)
read-only
Counter64
Number of IGMPv1 report packets received on the device.
As per the MIB.
hh3cMcsRxV2ReportNum (1.3.6.1.4.1.25506.2.123.1.4.1.6)
read-only
Counter64
Number of IGMPv2 or MLDv1 report packets received on the device.
As per the MIB.
hh3cMcsRxV3ReportNum (1.3.6.1.4.1.25506.2.123.1.4.1.7)
read-only
Counter64
Number of IGMPv3 or MLDv2 report packets received on the device.
As per the MIB.
hh3cMcsRxV3ErrCorReportNum(1.3.6.1.4.1.25506.2.123.1.4.1.8)
read-only
Counter64
Number of IGMPv3 or MLDv2 report packets with correct and incorrect records received on the device.
As per the MIB.
hh3cMcsRxLeaveNum (1.3.6.1.4.1.25506.2.123.1.4.1.9)
read-only
Counter64
Number of leave packets received on the device.
As per the MIB.
hh3cMcsRxPimHelloNum (1.3.6.1.4.1.25506.2.123.1.4.1.10)
read-only
Counter64
Number of PIM hello packets received on the device.
As per the MIB.
hh3cMcsRxErrorPacketNum (1.3.6.1.4.1.25506.2.123.1.4.1.11)
read-only
Counter64
Number of error IGMP or MLD packets received on the device.
As per the MIB.
hh3cMcsTxV2SpecificQueryNum(1.3.6.1.4.1.25506.2.123.1.4.1.12)
read-only
Counter64
Number of IGMPv2 or MLDv1 group-specific query packets sent from the device.
As per the MIB.
hh3cMcsTxV3SpecificQueryNum(1.3.6.1.4.1.25506.2.123.1.4.1.13)
read-only
Counter64
Number of IGMPv3 or MLDv2 group-specific query packets sent from the device.
As per the MIB.
hh3cMcsTxV3SpecificSGQueryNum(1.3.6.1.4.1.25506.2.123.1.4.1.14)
read-only
Counter64
Number of IGMPv3 or MLDv2 group-and-source-specific query packets sent from the device.
As per the MIB.
hh3cMcsPortJoinGroupConfigTable
About this table
This table contains settings of a port configured as a simulated member host for a multicast group.
Create
Edit/Modify
Delete
Read
Supported only when global IGMP or MLD snooping is enabled.
Supported
Supported
Supported
Columns
The table indexes are hh3cMcsPortJoinGroupIfIndex, hh3cMcsPortJoinGroupSnoopingType, hh3cMcsPortJoinGroupVlanID, hh3cMcsPortJoinGroupGroupAddress, and hh3cMcsPortJoinGroupSourceAddress.
Object (OID)
Access
Value range
Implementation
hh3cMcsPortJoinGroupIfIndex(1.3.6.1.4.1.25506.2.123.1.5.1.1)
not-accessible
InterfaceIndex
Index of the port for which this entry contains information.
As per the MIB.
hh3cMcsPortJoinGroupSnoopingType(1.3.6.1.4.1.25506.2.123.1.5.1.2)
not-accessible
InetAddressType
IPv4: igmp snooping
IPv6: mld snooping
Type of snooping configuration, which also indicates the protocol type of addresses.
As per the MIB.
hh3cMcsPortJoinGroupVlanID(1.3.6.1.4.1.25506.2.123.1.5.1.3)
not-accessible
Unsigned32
Unsigned32(1..4094)
VLAN ID.
As per the MIB.
hh3cMcsPortJoinGroupGroupAddress(1.3.6.1.4.1.25506.2.123.1.5.1.4)
not-accessible
InetAddress
IP address of the group to which the host belongs.
As per the MIB.
hh3cMcsPortJoinGroupSourceAddress(1.3.6.1.4.1.25506.2.123.1.5.1.5)
not-accessible
InetAddress
IP address of the source.
As per the MIB.
hh3cMcsPortJoinGroupStatus(1.3.6.1.4.1.25506.2.123.1.5.1.6)
read-create
RowStatus
active(1)
createAndGo(4)
destroy(6)
Row status.
hh3cMcsPortStaticGroupConfigTable
About this table
This table contains static group membership entries on a port.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Columns
The table indexes are hh3cMcsPortStaticGroupIfIndex, hh3cMcsPortStaticGroupSnoopingType, hh3cMcsPortStaticGroupVlanID, hh3cMcsPortStaticGroupGroupAddress, and hh3cMcsPortStaticGroupSourceAddress.
Object (OID)
Access
Value range
Implementation
hh3cMcsPortStaticGroupIfIndex(1.3.6.1.4.1.25506.2.123.1.6.1.1)
not-accessible
InterfaceIndex
As per the MIB.
hh3cMcsPortStaticGroupSnoopingType (1.3.6.1.4.1.25506.2.123.1.6.1.2)
not-accessible
InetAddressType
IPv4: IGMP snooping
IPv6: MLD snooping
As per the MIB.
hh3cMcsPortStaticGroupVlanID(1.3.6.1.4.1.25506.2.123.1.6.1.3)
not-accessible
Unsigned32
Unsigned32(1..4094)
VLAN ID.
As per the MIB.
hh3cMcsPortStaticGroupGroupAddress(1.3.6.1.4.1.25506.2.123.1.6.1.4)
not-accessible
InetAddress
Address of the multicast group.
As per the MIB.
hh3cMcsPortStaticGroupSourceAddress(1.3.6.1.4.1.25506.2.123.1.6.1.5)
not-accessible
InetAddress
As per the MIB.
hh3cMcsPortStaticGroupStatus(1.3.6.1.4.1.25506.2.123.1.6.1.6)
read-create
RowStatus
active(1)
createAndGo(4)
destroy(6)
Row status.
hh3cMcsRouterPortConfigEntry
About this table
This table contains static router port entries for a port.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Columns
The table indexes are hh3cMcsRouterPortConfigIfIndex, hh3cMcsRouterPortConfigSnoopingType, and hh3cMcsRouterPortConfigVlanID.
Object (OID)
Access
Value range
Implementation
hh3cMcsRouterPortConfigIfIndex(1.3.6.1.4.1.25506.2.123.1.7.1.1)
not-accessible
InterfaceIndex
As per the MIB.
hh3cMcsRouterPortConfigSnoopingType(1.3.6.1.4.1.25506.2.123.1.7.1.2)
not-accessible
InetAddressType
IPv4: IGMP snooping
IPv6: MLD snooping
Type of snooping configuration.
As per the MIB.
hh3cMcsRouterPortConfigVlanID(1.3.6.1.4.1.25506.2.123.1.7.1.3)
not-accessible
Unsigned32
Unsigned32(1..4094)
VLAN ID
As per the MIB.
hh3cMcsRouterPortConfigRowStatus(1.3.6.1.4.1.25506.2.123.1.7.1.4)
read-create
RowStatus
active(1)
createAndGo(4)
destroy(6)
Row status.
hh3cMcsPortConfigTable
About this table
This table contains the fast-leaving status, group limit number, group policy parameters and overflow replacement status on a port.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are hh3cMcsPortConfigIfIndex, hh3cMcsPortConfigSnoopingType, and hh3cMcsPortConfigVlanID.
Object (OID)
Access
Value range
Implementation
hh3cMcsPortConfigIfIndex(1.3.6.1.4.1.25506.2.123.1.8.1.1)
not-accessible
InterfaceIndex
As per the MIB.
hh3cMcsPortConfigSnoopingType(1.3.6.1.4.1.25506.2.123.1.8.1.2)
not-accessible
InetAddressType
IPv4: IGMP snooping
IPv6: MLD snooping
As per the MIB.
hh3cMcsPortConfigVlanID (1.3.6.1.4.1.25506.2.123.1.8.1.3)
not-accessible
Unsigned32
Unsigned32(1..4094)
VLAN ID.
As per the MIB.
hh3cMcsPortConfigGroupLimitNumber(1.3.6.1.4.1.25506.2.123.1.8.1.4)
read-create
Unsigned32
Group limit number of the port.
As per the MIB.
hh3cMcsPortConfigFastLeaveStatus(1.3.6.1.4.1.25506.2.123.1.8.1.5)
read-create
TruthValue
true(1),
false(2)
Fast-leaving status of the port.
As per the MIB.
hh3cMcsPortConfigGroupPolicyParameter(1.3.6.1.4.1.25506.2.123.1.8.1.6)
read-create
Unsigned32
Unsigned32(0|2000..3999)
ACL number which is used as the group policy parameter of the port.
As per the MIB.
hh3cMcsPortConfigOverflowReplace(1.3.6.1.4.1.25506.2.123.1.8.1.7)
read-create
TruthValue
true(1),
false(2)
Status of overflow replacement for the hh3cMcsPortConfigGroupLimitNumber object.
As per the MIB.
hh3cMcsPortConfigRowStatus(1.3.6.1.4.1.25506.2.123.1.8.1.8)
read-create
RowStatus
active(1) createAndGo(4)
destroy(6)
Row status.
