- H3C SecPath M9000-AI-E8[E16] Multi Service Security Gateway Series Installation Guides-6W102
- 01-Chapter 1 Chassis views
- 02-Chapter 2 Preparing for Installation
- 03-Chapter 3 Installing the Gateway
- 04-Chapter 4 Accessing the Gateway and Configuring Basic Settings
- 05-Chapter 5 Troubleshooting
- 06-Chapter 6 Replacing Removable Components
- 07-Appendix A FRUs and Compatibility Matrixes
- 08-Appendix B Technical Specifications
- 09-Appendix C LEDs
- 10-Appendix D Cables
- 11-Appendix E Slot arrangement and interface numbering
- 12-Appendix F Engineering labels
- 13-Appendix G Cabling Recommendations
- 14-Appendix H Repackaging the Gateway
| 09-Appendix C LEDs | 335.59 KB |
Management Ethernet fiber/copper port LEDs
NSQM5AIASKA1/NSQM5AIASKB1 AI security engine module LEDs
NS-AFCEMPC0/NS-ADEEMPA0/NS-ADEEMPC0 module LEDs
NS-FWEMPA1 firewall module LEDs
NS-FWEMPB1 firewall module LEDs
NS-AFC2000EMPA1/NS-AFC2000EMPB1/NS-FWEMPB1 module LEDs
NSQM5FAB08A1 switching fabric module LEDs
NSQM5FAB16A1 switching fabric module LED
Appendix C LEDs
The M9000-AI gateway series provides a lot of LEDs. You can determine the gateway operating status by examining the LEDs.
Supervisor engine module LEDs
Figure 1 shows the LEDs on the supervisor engine module (SEM).
Figure 1 NSQM5SUP08A1 SEM LEDs
(1) Management Ethernet fiber port LEDs |
(2) Management Ethernet copper port LEDs |
(3) SEM active/standby status LED |
(4) Card status LEDs |
(5) Power status LEDs |
(6) Fan tray status LEDs |
Figure 2 NSQM5SUP08A0-CN SEM LEDs
(1) Fan tray status LED |
(2) Card status LEDs |
(4) Power status LED (PWR) |
(5) Management Ethernet fiber port LED |
(6) Management Ethernet copper port LED |
Figure 3 NSQM5SUP16A1 SEM LEDs
(2) Power status LED |
(3) Card status LEDs |
(4) SEM active/standby status LED |
(5) Management Ethernet fiber port LEDs |
(6) Management Ethernet copper port LEDs |
Each SEM has a LED for each management Ethernet fiber/copper port to indicate their link status and data forwarding status.
Table 1 Management Ethernet fiber/copper port LED description
LINK |
Flashing |
A link is present on the port, and the port is receiving or sending data. |
On |
A link is present on the port. |
Off |
No link is present on the port. |
Power status LED
Each SEM provides a power status LED PWR to indicate the operating status of power supplies.
Table 2 Description for the power status LED on the NSQM5SUP08A1
OK |
FAIL |
On |
Off |
The power supplies are operating correctly. |
Off |
On |
A power supply is faulty. |
Off |
Off |
The gateway is not powered on. |
Table 3 Description for the power status LED on the NSQM5SUP08A0-CN
Status |
Steady green |
All power supplies are operating correctly. |
Steady red |
A minimum of one power supply is faulty. |
Off |
Table 4 Description for the power status LED on the NSQM5SUP16A1
Status |
Steady green |
Steady red |
Off |
Fan tray LEDs
Each SEM provides a fan tray LED FAN to indicate the operating status of fan trays.
Table 5 Description for the fan LED on NSQM5SUP08A1
OK |
FAIL |
On |
Off |
All fan trays are operating correctly. |
Off |
On |
A fan tray has failed or a minimum of one fan tray is not present. |
Off |
Off |
Table 6 Description for the fan LED on NSQM5SUP08A0-CN
Status |
Steady green |
Steady red |
A fan tray is faulty, or no fan tray is present in the device. |
Off |
Table 7 Description for the fan LED on the NSQM5SUP16A1
Status |
Steady green |
The fan trays are operating correctly. |
Steady red |
Off |
Each SEM has one ACTIVE LED to indicate the active or standby status of the SEM.
Table 8 SEM ACTIVE LED description
LED status |
On |
The SEM is active. |
Off |
· The SEM is in standby status. · The SEM has failed. Examine the card LED for an SEM problem. |
Card LEDs
Each SEM has the LEDs numbered the same as card slots to indicate the status of the active SEM, standby SEM, interface switch modules, service modules, and switching fabric modules in the slots. Table 9, Table 10, and Table 11 show the LED descriptions.
Table 9 Description for the card LEDs on NSQM5SUP08A1
RUN |
ALM |
Flashing (4 Hz) |
On |
The card is loading software. If the LEDs keep in this state, the card software version is not compatible with the gateway software version. |
Flashing (0.5 Hz) |
Off |
The card is operating correctly. |
Flashing (0.25 Hz) |
The card temperature has exceeded the upper warning threshold or dropped below the lower warning threshold. |
On |
On |
The card is in boot state or has failed. |
Off |
Off |
The card is not present. |
Table 10 Description for the card LEDs on NSQM5SUP08A0-CN
LED status |
Flashing green (0.5 Hz) |
Flashing green (4 Hz) |
Steady green |
The card is starting up. |
Steady red |
A critical alarm or failure has occurred on the card. |
Flashing red (0.25 Hz) |
Off |
The card is not present or the card has failed. |
Table 11 Description for the card LEDs on NSQM5SUP16A1
LED status |
Flashing green |
The card is loading software. |
Steady green |
The card has not started or is operating correctly. |
Steady red |
Service module LEDs
The NSQM5AIASKA1/NSQM5AIASKB1 AI security engine module provides LEDs to indicate the operation status for the module.
Table 12 NSQM5AIASKA1/NSQM5AIASKB1 AI security engine module LED description
LED |
Mark |
Status |
System status LED |
Steady green |
The system is operating correctly. |
Flashing green |
HDM is initializing. |
Flashing green and yellow |
A general alarm has occurred, including HDM alarms and hardware alarms. |
Flashing amber |
A severe alarm has occurred, including HDM alarms, hardware alarms, and processor alarms. |
System power LED |
Steady green |
The system has started. |
Flashing green |
The system is starting. |
Steady amber |
The system is in standby state. |
Flashing amber |
Abnormal power input. |
Off |
No power input. |
UID button LED |
UID |
On |
UID LED is activated. |
Flashing (1 Hz) |
The firmware is being upgraded or the system is being managed from HDM. |
Flashing (4 Hz) |
HDM is restarting. |
Off |
UID LED is not activated. |
The NS-AFCEMPC0/NS-ADEEMPA0/NS-ADEEMPC module provides LEDs to indicate the operation status for the module.
Table 13 NS-AFCEMPC0/NS-ADEEMPA0/NS-ADEEMPC0 module LED description
LED |
Status |
CPU status LED (RUN/ALM) |
Fast flashing green (4 Hz) |
Software is being loaded. |
Slow flashing green (1 Hz) |
The CPU is operating correctly. |
Off |
The CPU is not operating. |
LINK: On ACT: Flashing |
A link is present on the port and the port is sending or receiving data. |
LINK: On ACT: Off |
LINK: Off ACT: Off |
The NS-FWEMPA1 firewall module provides multiple LEDs to indicate its operating status.
Table 14 NS-FWEMPA1 firewall module LED description
LED |
Status |
Slow flashing green (0.5 Hz) |
Steady red |
The CPU is faulty. |
Off |
Management Ethernet port copper LED |
LINK: On ACT: Off |
The NS-FWFAMB1 firewall module provides multiple LEDs to indicate its operating status.
Table 15 NS-FWEMPB1 firewall module LED description
LED |
Status |
Fast flashing green |
Slow flashing green |
Steady red |
Off |
Steady green |
Flashing green |
Off |
The NS-AFC2000EMPA1/NS-AFC2000EMPB1/NS-FWEMPB1 module provides LEDs to indicate the operation status for the module.
Table 16 NS-AFC2000EMPA1/NS-AFC2000EMPB1/NS-FWEMPB1 module LED description
LED |
Status |
CPU running status LED (RUN/ALM) |
Fast flashing green (8 Hz) |
The CPU is loading software. |
Steady red |
Off |
The CPU is not running. |
LINK: On ACT: Off |
Switching fabric module LEDs
An NSQM5FAB08A1 switching fabric module and the fan tray that convers the switching fabric module both provide a status LED to indicate the operation status for the switching fabric module.
Table 17 NSQM5FAB08A1 switching fabric module LED description
LED |
Status |
RUN/ALM |
Flashing green |
The switching fabric module is operating correctly. |
Steady red |
The switching fabric module is faulty. |
Off |
The switching fabric module is not present. |
Table 18 Description for the switching fabric module LED on the fan tray
RUN LED |
ALM LED |
Flashing (1 Hz) |
Off |
Off |
On |
Flashing (1 Hz) |
On |
The switching fabric module is loading software or is operating incorrectly, for example, the temperature of the switching fabric module has exceeded the upper or lower limit. |
Off |
Off |
The switching fabric module has not started or is not powered on. |
On |
On |
The switching fabric module is in boot state. |
An NSQM5FAB16A1 switching fabric module provides a status LED to indicate the operation status for the switching fabric module.
Table 19 NSQM5FAB16A1 switching fabric module LED description
LED |
Status |
RUN/ALM |
Steady green |
Steady red |
The switching fabric module is faulty or is loading software. |
Off |
The switching fabric module is not powered on or has not loaded any software. |
Interface module LEDs
The interface modules provide port LEDs to indicate the link status and data receiving/forwarding status of the ports.
10GE fiber port LED
Table 20 10GE fiber port LED description
LED status |
Flashing |
The port is receiving or sending data at 10 Gbps. |
On |
A 10 Gbps link is present. |
Off |
No link is present. |
40GE fiber port LED
Table 21 40GE fiber port LED description
LED status |
Flashing |
The port is receiving or sending data at 40 Gbps. |
On |
A 40 Gbps link is present. |
Off |
100GE fiber port LEDs
Table 22 100GE fiber port LED description
LED status |
Flashing |
The port is receiving or sending data at 100 Gbps. |
On |
A link is present. |
Off |
The fan trays for the M9000-AI gateways provide LEDs to indicate their operating status.
Table 23 M9000-AI-E8 fan tray LED description
OK |
FAIL |
On |
Off |
The fan tray is operating correctly. |
Off |
On |
The fan tray is faulty. |
Off |
Off |
The fan tray is not powered on. |
Table 24 M9000-AI-E16 fan tray LED description
OK/FAIL LED status |
Off |
The fan tray is faulty or not powered on. |
Steady green |
Steady red |
Power supply LEDs
The PSR2400-54A, PSR2400-54D, and PSR3000-54A power supplies each have one AC OK LED and one DC OK LED to indicate its operating status. The PSR3000-54AHD power supply has one IN OK LED and one OUT OK LED to indicate its operating status.
Table 25 PSR2400-54A/PSR2400-54D/PSR3000-54A power supply LED description
LED |
Status |
AC OK |
Off |
· The power supply does not have power input. · The input voltage is too low, and the power supply is in self protection state. |
Green |
The power supply does not have power input. |
DC OK |
Green |
The power supply is outputting power correctly. |
Amber |
The power supply is in an over-temperature condition. |
Red |
The power supply is experiencing an output problem, including output short-circuit, output overcurrent, output overvoltage, input under-voltage, or remote power off, and has entered self protection state. |
Table 26 PSR3000-54AHD power supply LED description
LED |
Status |
IN OK |
Off |
Green |
OUT OK |
Green |
Amber |
Red |
