H3C SecPath M9000-AI-E8[E16] Multi Service Security Gateway Series Installation Guides-6W102
HomeSupportSecurityH3C SecPath M9000-AI-EInstall & UpgradeInstallation GuidesH3C SecPath M9000-AI-E8[E16] Multi Service Security Gateway Series Installation Guides-6W102
08-Appendix B Technical Specifications
08-Appendix B Technical Specifications 124.50 KB
Appendix B  Technical specifications
Weights and dimensions
Table 1 Gateway weights and dimensions
Model
Net weight
Height
Width
Depth
M9000-AI-E8
33 kg (72.75 lb)
264 mm (10.39 in) (6 RU)
440 mm (17.32 in)
857 mm (33.74 in)
M9000-AI-E16
86.8 kg (191.36 lb)
841.7 mm (33.14 in) (19 RU)
440 mm (17.32 in)
640 mm (25.20 in)
·     Rack height is measured in RUs. One RU is 44.45 mm (1.75 in).
·     The dimensions listed in Table 1 are for the gateway chassis, excluding mounting brackets, cable management brackets, cards, and power supplies.
Table 2 Card weights and dimensions
Card model
Weight
Height
Width
Depth
NSQM5SUP08A1
2.8 kg (6.17 lb)
39.8 mm (1.57 in)
200.5 mm (7.89 in)
411 mm (16.18 in)
NSQM5SUP08A0-CN
2.78 kg (6.13 lb)
39.8 mm (1.57 in)
201 mm (7.91 in)
412 mm (16.22 in)
NSQM5SUP16A1
4 kg (8.82 lb)
44.5 mm (1.75 in)
284.4 mm (11.20 in)
511.9 mm (20.15 in)
NSQM5FAB08A1
2 kg (4.41 lb)
39.8 mm (1.57 in)
243 mm (9.57 in)
278.4 mm (10.96 in)
NSQM5FAB16A1
4 kg (8.82 lb)
39.8 mm (1.57 in)
284.4 mm (11.20 in)
520.6 mm (20.50 in)
NSQM5AIASKA1
9.64 kg (21.25 lb)
50 mm (1.97 in)
433 mm (17.05 in)
520 mm (20.47 in)
NSQM5AIASKB1
8.96 kg (19.75 lb)
50 mm (1.97 in)
433 mm (17.05 in)
520 mm (20.47 in)
NSQM5MBSHA1
5.9 kg (13.01 lb)
50 mm (1.97 in)
432.6 mm (17.03 in)
512.3 mm (20.17 in)
NS-FWEMPA1
2.4 kg (5.29 lb)
44 mm (1.73 in)
191 mm (7.52 in)
365.3 mm (14.38 in)
NS-AFCEMPC0
2.45 kg (5.40 lb)
44 0mm (1.73 in)
191 mm (7.52 in)
365 mm (14.37 in)
NS-AFC2000EMPA1
2.38 kg (5.25 lb)
44 mm (1.73 in)
191 mm (7.52 in)
365.3 mm (14.38 in)
NS-ADEEMPA0
2.45 kg (5.40 lb)
44 mm (1.73 in)
191 mm (7.52 in)
365.3 mm (14.38 in)
NS-ADEEMPC0
2.45 kg (5.40 lb)
44 mm (1.73 in)
191 mm (7.52 in)
365.3 mm (14.38 in)
NS-C300-QG4TG16A1
1.5 kg (3.31 lb)
44 mm (1.73 in)
191 mm (7.52 in)
365.3 mm (14.38 in)
NS-C300-TG24A1
1.52 kg (3.35 lb)
44 mm (1.73 in)
191 mm (7.52 in)
365.3 mm (14.38 in)
NS-C600-CGQ6A1
1.42 kg (3.13 lb)
44 mm (1.73 in)
191 mm (7.52 in)
365.3 mm (14.38 in)
NS-C300-CGQ2TG16A1
1.52 kg (3.35 lb)
44 mm (1.73 in)
191 mm (7.52 in)
365.3 mm (14.38 in)
·     The card model is printed on the card front panel.
·     Card dimensions are expressed as H x W x D:
¡     H—Height of the front panel of the card.
¡     W—Width of the front panel of the card.
¡     D—Depth from the front panel of the card to the connector.
Table 3 Power supply weights and dimensions
Model
Weight
Height
Width
Depth
PSR2400-54A
1.9 kg (4.19 lb)
41 mm (1.61 in)
100 mm (3.94 in)
332 mm (13.07 in)
PSR2400-54D
1.9 kg (4.19 lb)
41 mm (1.61 in)
100 mm (3.94 in)
332 mm (13.07 in)
PSR3000-54A
2.1 kg (4.63 lb)
41 mm (1.61 in)
100 mm (3.94 in)
332 mm (13.07 in)
PSR3000-54AHD
2.1 kg (4.63 lb)
41 mm (1.61 in)
100 mm (3.94 in)
332 mm (13.07 in)
Table 4 Fan tray weights and dimensions
Fan tray
Weight
Height
Width
Depth
M9000-AI-E8 fan tray
1.8 kg (3.97 lb)
144 mm (5.67 in)
263 mm (10.35 in)
97 mm (3.82 in)
M9000-AI-E16 fan tray
1.75 kg (3.86 lb)
128 mm (5.04 in)
367 mm (14.45 in)
90 mm (3.54 in)
Module power consumption and system power consumption
Card power consumption
The power consumption of the cards depends on the card model and state. Table 5 shows the power consumption for different card models.
·     The static power consumption of a card refers to the power consumed by the card when the card is running but all ports on the card are down and when no transceiver module is available on the optical interface of the card.
·     The dynamic power consumption of a card refers to the power consumed by the card when all the ports on the card are link up and send broadcasts.
Table 5 Card power consumption
Model
Minimum static power consumption
Maximum dynamic power consumption
NSQM5SUP08A1
46 W
50 W
NSQM5SUP08A0-CN
27 W
43 W
NSQM5SUP16A1
35 W
45 W
NSQM5FAB08A1
2 W
60 W
NSQM5FAB16A1
83 W
108 W
NSQM5AIASKA1
165 W
462 W
NSQM5AIASKB1
131 W
286 W
NSQM5MBSHA1
79 W
89 W
NS-FWEMPA1
178 W
205 W
NS-AFCEMPC0
156 W
204 W
NS-AFC2000EMPA1
178 W
205 W
NS-ADEEMPA0
156 W
188 W
NS-ADEEMPC0
156 W
204 W
NS-C300-QG4TG16A1
7 W
34 W
NS-C300-TG24A1
5 W
36 W
NS-C600-CGQ6A1
10 W
42 W
NS-C300-CGQ2TG16A1
7 W
38 W
Fan tray power consumption
The gateway uses fan trays with the automatic speed adjustment function. The fan speed is automatically adjusted based on the heat dissipation condition of the gateway. The power consumed by a fan tray depends on the fan speed. Table 6 shows the power consumption of different fan trays.
Table 6 Fan tray power consumption
Model
Minimum fan tray power consumption
Maximum fan tray power consumption
14 W
255 W
75 W
264 W
System power consumption
The system power consumption of the gateway depends on the type and number of cards and the fan tray power consumption.
·     The minimum system power consumption is the total static power consumption of all cards plus the minimum fan tray power consumption.
·     The maximum system power consumption is the total dynamic power consumption of all cards plus the maximum fan tray power consumption.
For example, for an M9000-AI-E8 gateway that has two NSQM5SUP08A1 SEMs, two NSQM5FAB08A1 switching fabric modules, one NSQM5MBSHA1 interface switch module, one NS-C300-QG4TG16A1 interface module, one NS-FWEMPA1 service module, and two M9000-AI-E8 fan trays, the minimum system power consumption of the gateway is 2 × 46 + 2 × 2 + 1 × 79 + 1 × 7 + 1 × 178 + 2 × 14 = 388 W, and the maximum system power consumption of the gateway is 2 × 50 + 2 × 60 + 1 × 89 + 1 × 34 + 1 × 205 + 2 × 255 = 1058 W.
Modules
Supervisor engine modules
You can install one supervisor engine module (SEM), or two SEMs for redundancy for the gateway. The NSQ1SUPB0 SEM is available for the gateway. Table 7 describes the NSQ1SUPB0 SEM specifications.
Table 7 NSQ1SUPB0 SEM specifications
SEM model
Item
NSQM5SUP08A1
Ports
·     One console port
·     One USB port (reserved for future use)
·     Two management Ethernet copper ports
·     Two management Ethernet fiber ports
Port transmission rate
·     Console port: 9600 bps (default) to 115200 bps
·     Management Ethernet copper port: 10/100/1000 Mbps
·     Management Ethernet fiber port: 1000 Mbps
Cables and max transmission distance
·     Console port: ≤ 15 m (49.21 ft) over an asynchronous serial interface cable
·     Management Ethernet copper port: 100 m (328.08 ft) over a Category-5 twisted pair cable
NSQM5SUP08A0-CN
Ports
·     1 × console port
·     1 × USB console port
·     2 × network management ports, including one 10/100/1000BASE-T port and one SFP port
·     1 × USB port (HOST)
·     Console port/USB console port: 9600 bps (default) to 115200 bps
·     Console port/USB console port: ≤ 15 m (49.21 ft) over an asynchronous serial interface cable
NSQM5SUP16A1
Ports
·     One console port
·     One mini USB console port (reserved for future use)
AI security engine modules
The AI security engine modules available for the device are described in Table 8.
Table 8 AI security engine module specifications
Model
Port
Connector
NSQM5AIASKA1
One console port
RJ-45
One BMC console port
RJ-45
One BMC network port
One management Ethernet copper port
RJ-45
Two 10GE fiber ports
LC
One SUV connector
SUV
One USB port
USB
NSQM5AIASKA1
One console port
RJ-45
RJ-45
RJ-45
LC
One SUV connector
SUV
One USB port
USB
Service modules
The service modules available for the device are described in Table 9.
Table 9 Service module specifications
Model
Port
Connector
NS-FWEMPA1
Firewall module
Two console ports
RJ-45
Two USB ports (reserved for future use)
USB
RJ-45
NS-AFCEMPC0
Anomaly flow cleaner module
Two console ports
RJ-45
Two USB ports (for power supply only)
USB
RJ-45
NS-AFC2000EMPA1
Two console ports
RJ-45
USB
RJ-45
NS-ADEEMPA0
Application delivery engine
Two console ports
RJ-45
USB
RJ-45
NS-ADEEMPC0
Two console ports
RJ-45
USB
RJ-45
Interface modules
The interface modules available for the device are described in Table 10.
Table 10 Interface module specifications
Interface module model
Connector
Number of ports
Available transceiver modules
NS-C300-CGQ2TG16A1
2-port 100-Gigabit Ethernet optical interface+16-port 10-Gigbit Ethernet optical interface module
LC
MPO
18
10 Gbps
10-Gigabit SFP+ transceiver module
100/40 Gbps
·     QSFP28 transceiver module
·     QSFP+ transceiver module
NS-C300-QG4TG16A1
4-port 40-Gigabit Ethernet optical interface+16-port 10-Gigbit Ethernet optical interface module
LC
MPO
20
10 Gbps
40 Gbps
NS-C300-TG24A1
24-port 10-Gigbit Ethernet optical interface module
LC
24
10 Gbps
10-Gigabit transceiver SFP+ module
NS-C600-CGQ6A1
6-port 100-Gigbit Ethernet optical interface module
LC
MPO
6
100/40 Gbps
Power supplies
The gateway supports power supplies of models NSQM1AC2500 and NSQM1DC2400. An NSQM1AC2500 power supply is an AC-input, DC-output power supply that provides a maximum DC output power of 2500 W. An NSQM1DC2400 power supply is a DC-input, DC-output power supply that provides a maximum DC output power of 2400 W.
Table 11 NSQM1AC2500 and NSQM1DC2400 power supply specifications
PSR2400-54A
PSR2400-54D
PSR3000-54A
PSR3000-54AHD
Rated input voltage range
100 VAC to 240 VAC @ 50/60 Hz
–48 VDC to –60 VDC
240 VDC
–48 VDC to –60 VDC
Rated output voltage
54 VDC
54 VDC
54 VDC
54 VDC
Maximum input current
16 A
80 A
16 A
20 A
Maximum output current
44.5 A
44.5 A
55.6 A
·     27.8 A (100 VAC to 175 VAC)
·     55.6 A (175 VAC to 240 VAC, 240 VDC to 380 VDC)
Maximum output power
·     1200 W (110 VAC)
·     2400 W (220 VAC)
2400 W
·     1200 W (110 VAC)
·     2400 W (175 VAC to 200 VAC)
·     3000 W (220 VAC)
·     3000 W (240 VDC)
·     1500 W (100 VAC to 175 VAC)
·     3000 W (175 VAC to 240 VAC, 240 VDC to 380 VDC)
Temperature requirements
Operating temperature
–10°C to +50°C (14°F to 122°F)
Storage temperature
–40°C to +70°C (–40°F to +158°F)
You can select a certain number of power supplies based on the actual power consumption requirements. Make sure the total maximum output power of the ordered power supplies is greater than the system power consumption. As a best practice, reserve 20% of the maximum output power.
When the temperature of a power supply exceeds the normal operating temperature, the power supply is automatically powered off. When the temperature recovers to the normal temperature, the power supply is automatically powered on.
Fan trays
Table 12 shows the fan trays that each M9000-AI gateway supports. Every M9000-AI gateway comes with fan trays installed.
Table 12 Fan tray specifications
Fan tray
Number of fans
Fan diameter
Maximum air flow rate
2
120 mm (4.72 in)
340 CFM
2
120 mm (4.72 in)
580 CFM
Heat dissipation
Heat dissipation is measured in BTU/h, and 1 W equals 3.4121BTU/h.
The heat dissipation of a gateway depends on its power consumption. To calculate heat dissipation of the gateway, assume 90% power consumption is converted to heat, and the efficiency of the power supply is 90%. Heat dissipation/hour of the gateway is 0.9 × (total power consumption of the cards plus power consumption of the fan tray)/0.9 × 3.4121.
For the power consumption of the cards and fan trays of the gateways, see "Module power consumption and system power consumption."
Noise
The gateway uses fans with the automatic speed adjustment function, so the sound pressure levels are different when the fan speeds are different. For more information, see Table 13.
Table 13 Sound pressure levels
Model
Sound pressure level under normal temperature
Sound pressure level when the fan tray operates at full speed
M9000-AI-E8
67.5dBA
85.3dBA
M9000-AI-E16
61.2dBA
89.5dBA
