| 01-Text | 14.08 MB |
Examining the installation site
Installing a cable management bracket
Installing the router in a 19-inch rack
Installing the router by using mounting brackets and a rack shelf
Installing the router by using mounting brackets and slide rails
Installing an MPU and a switching fabric module
Installing an SFE-X1 switching fabric module
Installing optional components
Installing a lightning protector for a network port
Connecting the AC power supply to a power strip with lightning protection
Installing transceiver modules and optical fibers
Connecting a serial port cable
Logging in through the console port
Setting up a configuration environment
Logging in to the router through Telnet/SSH
Replacing an MPU and a switching fabric module
Replacing a transceiver module
Replacing a fan tray for an SR6604-X/SR6608-X router
Replacing a fan tray for an SR6616-X router
Replacing an air filter for an SR6604-X/SR6608-X router
Replacing an air filter for an SR6616-X router
6 Hardware management and maintenance
Displaying the hardware information of the router
Displaying the version information of the router
Displaying the running statistics for the router
Displaying detailed information about a card
Displaying the electrical label data
Displaying the CPU usage statistics
Displaying the MPU memory usage
Displaying the CF card information
Displaying the fan operating status
Displaying the power module operating status
Displaying the alarming thresholds of a card
Port configuration and management
Displaying and verifying transceiver modules
ALM LED is steady on or flashes
No response from the serial port
Dealing with console login password loss
Examining the state of password recovery capability
Skipping current system configuration
Skipping authentication for console login
Restoring to factory default configuration
HIM/MIM/MIC, cable, and connection failure
No response from the serial port of the MPU
System software image file missing errors
1 Preparing for installation
The H3C SR6600-X routers include the following models: SR6602-X, SR6604-X, SR6608-X, and SR6616-X.
Safety recommendations
To avoid any equipment damage or bodily injury caused by improper use, read the following safety recommendations before installation. Note that the recommendations do not cover every possible hazardous condition.
Safety symbols
When reading this document, note the following symbols:
WARNING means an alert that calls attention to important information that if
not understood or followed can result in personal injury.
CAUTION means an alert that calls attention to important information that if
not understood or followed can result in data loss, data corruption, or damage
to hardware or software.
Electricity safety
· Locate the emergency power-off switch in the room before installation. Shut the power off at once in case accident occurs. Disconnect the power cord of the router if necessary.
· Use an uninterrupted power supply (UPS).
· Do not work alone when the router has power. Do not touch any power plug when it is connected.
· Always make sure the power has been disconnected during installation and replacement.
Laser safety
WARNING! · Do not stare into any fiber port when the router has power. The laser light emitted from the optical fiber might hurt your eyes. · Use fiber test equipment, rather than a microscope or magnifier to observe an operating fiber connector or port when you test link connectivity or system parameters. |
The routers are Class 1 laser devices.
When you connect an optical fiber, follow these guidelines:
· Some interface modules on the router provide shielded covers for the fiber ports (such as SFP ports). Before using such fiber ports, remove the shielded covers. Keep the shielded covers secure. When the fiber ports are not in use, install the shielded covers.
· Fiber connectors are fitted with dust caps. Keep the dust caps secure when the fiber connectors are in use. Install dust caps when the fiber connectors are not in use to avoid damage to their end face. Replace the dust cap if it is loose or polluted.
· Before connecting an optical fiber, use dust free paper and absolute alcohol to clean the end face of the two fiber connectors. You can brush the end faces only in one direction.
· After a fiber is installed well, the bend radius must be not less than 10 cm (3.94 in).
· If the fiber has to pass through a metallic board hole, the hole must have a sleek and fully filleted surface. (The filleting radius must be not less than 2 mm, or 0.08 in.) When passing through a metallic board hole or bending along the acute side of mechanical parts, the fiber must wear jackets or cushions.
Router moving
CAUTION: Do not hold the handle of the fan tray or power supply, the handle of the rear cover of the chassis, or the air vents of chassis. Any attempt to carry the router with these parts might cause equipment damage or even bodily injury. |
When you move a router, follow these guidelines:
· Lift and put down the chassis slowly and never move suddenly.
· When you move a heavy router or multiple routers, use a pallet jack.
· Before moving the chassis, turn off the power switch and remove all cables, USB devices, and mounting brackets.
· If the router needs to be moved over a long distance, remove all field replacement units (FRUs), such as HIMs/MIMs/MICs, put them separately in anti-static bags, and install the filler panels supplied with router.
· If the router needs to be moved over a short distance, make sure all FRUs are securely seated in slots and the screws are fastened.
· Make sure the accessories of the router are not lost or damaged during router moving.
· Make sure the ground is dry and flat and anti-slip measures are in place.
· Keep the chassis and installation tools away from walk areas.
ESD prevention
CAUTION: Make sure the resistance reading between human body and the ground is in the range of 1 to 10 megohms (Mohms). |
To prevent electrostatic discharge (ESD), follow these guidelines:
· Make sure the router and the rack are well grounded.
· An anti-static floor is installed and well grounded.
· Take dust-proof measures for the equipment room.
· Maintain the humidity and temperature in the acceptable range.
· Always wear an ESD wrist strap and ESD cloth when touching a circuit board or transceiver module.
· Place the removed CF card or LPU on an antistatic workbench, with the face upward, or put it into an antistatic bag.
· Touch only the edges, instead of electronic components when you observe or move a removed CF card or LPU.
To attach an ESD wrist strap:
1. Wear the wrist strap on your wrist.
2. Lock the wrist strap tight around your wrist to keep good contact with the skin.
3. Insert the ESD plug into the ESD socket.
4. Make sure the rack is well grounded.
Figure1-1 Attaching an ESD wrist strap
(1) ESD wrist strap |
(2) Lock |
(3) ESD plug |
The routers can only be used indoors. To make sure the router operates correctly and to prolong its service lifetime, the installation site must meet the following requirements:
Weight support
Make sure the floor can support the total weight of the router and accessories (such as the rack and HIMs/MIMs/MICs). For the weight of the router and accessories, see H3C SR6604-X/SR6608-X/SR6616-X Routers Hardware Information and Specifications.
Temperature
If the temperature in the equipment room is too high, too low, or changes dramatically, the router reliability is reduced and its service lifetime is shortened. For long-term, highly available operation of the router, make sure temperature in the equipment room meets the requirements described in Table1-1.
Table1-1 Temperature requirements
Item |
Temperature |
Operating Temperature |
0°C to 45°C (32°F to 113°F) |
Storage Temperature |
–40°C to +70°C (–40°F to +158°F) |
Humidity
Maintain appropriate humidity in your equipment room, as described in Table1-2.
· Lasting high relative humidity can cause poor insulation, electricity leakage, mechanical property change of materials, and metal corrosion.
· Lasting low relative humidity can cause washer contraction and ESD and bring problems including loose screws and circuit failure.
Table1-2 Humidity requirements
Item |
Humidity |
Operating humidity (noncondensing) |
10% RH to 95% RH |
Storage humidity (noncondensing) |
5% RH to 95% RH |
Cleanliness
Dust buildup on the chassis might result in electrostatic adsorption, which causes poor contact of metal components and contact points, especially when indoor relative humidity is low. In the worst case, electrostatic adsorption can cause communication failure.
Table1-3 Router requirement for cleanliness
Substance |
Particle diameter |
Concentration limit |
Dust particles |
≥ 0.5 µm |
≤ 1.8 × 107 particles/m3 |
Corrosive gases can accelerate corrosion and aging of metal components. Make sure the corrosive gases do not exceed the concentration limits as shown in Table1-4.
Table1-4 Corrosive gas concentration limits
Gas |
Average concentration (mg/m3) |
Maximum concentration (mg/m3) |
SO2 |
0.3 |
1.0 |
H2S |
0.1 |
0.5 |
Cl2 |
0.1 |
0.3 |
HCI |
0.1 |
0.5 |
HF |
0.01 |
0.03 |
NH3 |
1.0 |
3.0 |
O3 |
0.05 |
0.1 |
NOX |
0.5 |
1.0 |
Cooling system
Fan trays of the routers are hot swappable and support automatic fan speed adjustment. To ensure good ventilation, the following requirements must be met:
· Leave a minimum clearance of 10 cm (3.94 in) at the inlet and outlet air vents.
· The installation site has a good cooling system.
The SR6604-X and SR6608-X routers use the same airflow design.
Figure1-2 Airflow through the SR6608-X chassis
Figure1-3 Airflow through the SR6616-X chassis
EMI
All electromagnetic interference (EMI) sources, from outside or inside of the router and application system, adversely affect the router in the following ways:
· A conduction pattern of capacitance coupling.
· Inductance coupling.
· Electromagnetic wave radiation.
· Common impedance (including the grounding system) coupling.
To prevent EMI, use the following guidelines:
· Take effective measures to filter interference from the power grid.
· Separate the grounding equipment of the router from the grounding facility and lightning protection facility of the other electrical devices as far as possible.
· Keep the router far away from radio transmitting stations, radar stations, and high-frequency devices.
· Use electromagnetic shielding when necessary.
Lightning protection
To protect the router from lightning, perform the following tasks:
· Make sure the grounding cable of the chassis is well grounded. For how to connect the grounding cable, see "Grounding the router."
· Make sure the grounding terminal of the AC power receptacle is well grounded.
· Install a lightning arrester at the input end of the power supply to enhance the lightning protection capability of the power supply.
· Install a special lightning arrester at the input end of outdoor signal lines (for example, E1 line) to which interface modules of the router are connected to enhance the lightning protection capability.
For how to install lightning protectors and surge protector, see "Connecting the AC power supply to a power strip with lightning protection" and "Installing a surge protector."
Space
For easy installation and maintenance, follow these space requirements:
· Reserve a minimum of 1 m (3.28 ft) of clearance between the rack and walls or other devices.
· For heat dissipation, make sure the headroom in the equipment room is not less than 3 m (9.84 ft).
· Make sure the rack has enough space to accommodate the router. See Table1-5 for rack requirements. For more information about chassis dimensions, see H3C SR6604-X/SR6608-X/SR6616-X Routers Hardware Information and Specifications.
Table1-5 Router dimensions and rack requirements
Model |
Chassis dimensions |
Rack requirements |
SR6604-X AC |
· Height—220 mm (8.66 in)/5 RU · Width—436 mm (17.17 in) · Depth—576 mm (22.68 in) ¡ 480 mm (18.90 in) for the chassis ¡ 95 mm (3.74 in) for the cable management brackets at the chassis front ¡ 11 mm (0.43 in) for the grounding screw at the chassis rear |
· A minimum of 95 mm (3.74 in) between the front rack posts and the front door. · A minimum of 481 mm (18.94 in) between the front rack posts and the rear door. As a best practice, use a rack a minimum of 0.8 m (2.62 ft) in depth. |
SR6608-X AC |
· Height—308 mm (12.13 in)/7 RU · Width—436 mm (17.17 in) · Depth—576 mm (22.68 in) ¡ 480 mm (18.90 in) for the chassis ¡ 95 mm (3.74 in) for the cable management brackets at the chassis front ¡ 11 mm (0.43 in) for the grounding screw at the chassis rear |
SR6616-X AC |
· Height—886 mm (34.89 in)/20 RU · Width—436 mm (17.17 in) · Depth—591 mm (23.27 in) ¡ 480 mm (18.90 in) for the chassis ¡ 102 mm (4.02 in) for the cable management brackets at the chassis front ¡ 11 mm (0.43 in) for the grounding screw at the chassis rear |
· A minimum of 102 mm (4.02 in) between the front rack posts and the front door. · A minimum of 490 mm (19.29 in) between the front rack posts and the rear door. As a best practice, use a rack a minimum of 0.8 m (2.62 ft) in depth. |
NOTE: The signal cables and power cords are routed through the front of the chassis. If you use power cords that has a conductor cross-section area of a minimum of 16 sq mm (0.02 sq in), leave more space between the front rack posts and the front door as appropriate. |
Power supply
· Make sure the power supply system at the installation site is stable and meets the requirements of the power modules, including the rated input voltage.
· Select power modules based on the power consumption of the cards and fan trays. For more information about system power consumption and technical specifications of power modules, see H3C SR6604-X/SR6608-X/SR6616-X Routers Hardware Information and Specifications.
Installation accessories
ESD gloves (user supplied) |
Grounding cable (provided) |
ESD wrist strap (provided) |
Mounting bracket and cable management bracket for the SR6604-X (provided). The appearance might vary depending on the mounting bracket and cable management bracket you are provided. |
Mounting bracket and cable management bracket for the SR6608-X (provided). The appearance might vary depending on the mounting bracket and cable management bracket you are provided. |
Mounting brackets for the SR6616-X (provided) |
Cable management bracket for the SR6616-X (provided) |
M6 cage nut (provided) |
M6 screws (provided) |
Cable tie (user supplied) |
2 Installing the router
Installation flow
Figure2-1 Installation flow
The cable management brackets of the SR6604-X and SR6608-X are provided with mounting brackets.
You need to install a cable management bracket for an SR6616-X router.
To install a cable management bracket:
1. Face the front of the router.
2. Align the screw holes on the cable management bracket with the screw holes on the front panel of chassis, and fasten the screws.
Figure2-2 Installing a cable management bracket
The procedures are similar for installing an SR6604-X, SR6608-X, and SR6616-X router in a rack. This section uses an SR6604-X router as an example.
You can install the router in a rack by using mounting brackets and a rack shelf or using mounting brackets and slide rails. Select an installation method as required.
Attaching cage nuts to the rack
1. Locate the installation position for the router and then attach a rack shelf to the rack.
2. As shown in Figure2-3, align the bottom of the front mounting bracket with the rack shelf and mark the installation positions of cage nuts on the front rack posts.
Figure2-3 Marking the positions of cage nuts
3. Insert one edge of a cage nut into the hole.
4. Compress the other edge of the cage nut, and then push the cage nut fully into the hole.
5. Repeat steps 3 and 4 to install other cage nuts to all the marked positions on the rack post.
Figure2-4 Installing a cage nut
Attaching the mounting brackets to the router
If you have ordered an air filter, install it on the router before you install the mounting brackets. For the installation procedure, see "Installing an air filter."
Before you install the router in a rack, attach the front mounting brackets to the left and right sides of the router.
To attach the front mounting brackets to the router, align the screw holes on the mounting brackets with the screw holes on the left and right sides of the chassis, and then fasten the screws.
Figure2-5 Attaching the front mounting brackets to the two sides of the router
1. Put the router on the rack shelf.
2. Slide the router into the rack so the screw holes on the mounting brackets are aligned with holes that are installed with cage nuts on the rack posts.
3. Use M6 screws to attach the mounting brackets to the rack posts. Make sure the rack shelf is even and stable.
Figure2-6 Installing the router in a rack
The procedure is similar for installing the router by using mounting brackets and slide rails and by using mounting brackets and a rack shelf. For more information, see "Installing the router by using mounting brackets and a rack shelf."
Before installing the router in the rack, attach slides rails to the rack. As a best practice, purchase slide rails from H3C. Table2-1 describes the slide rails available for the router. For information about installing the slide rails, see the installation guide shipped with the slide rails.
If the rack has slide rails installed, skip this section.
IMPORTANT: Select slide rails for the router based on the total chassis weight. |
Table2-1 Slide rails available for the router
Router model |
Chassis weight with full configuration |
Available slide rails |
Slide rail model |
Max. load-bearing capacity |
Adjustment range |
Occupied space |
Remarks |
SR6604-X |
39 kg (85.98 lb) |
LSXM1BSR |
450 kg (992.06 lb) |
630 to 900 mm (24.80 to 35.43 in) |
1 RU |
Select one of the slide rail models |
LSTM1KSGD0 |
280 kg (617.28 lb) |
300 to 500 mm (11.81 to 19.69 in) |
2 RU |
LSTM2KSGD0 |
360 kg (793.65 lb) |
500 to 800 mm (19.69 to 31.50 in) |
2 RU |
SR6608-X |
51 kg (112.43 lb) |
LSXM1BSR |
1 RU |
LSTM1KSGD0 |
2 RU |
LSTM2KSGD0 |
2 RU |
SR6616-X |
102 kg (224.87 lb) |
LSXM1BSR |
1 RU |
LSTM1KSGD0 |
2 RU |
LSTM2KSGD0 |
2 RU |
WARNING! Correctly connecting the router grounding cable is crucial to lightning protection and EMI protection. |
To connect the grounding cable:
1. Remove the two grounding screws from the grounding terminal on the rear panel of the chassis.
2. Use the grounding screws to attach the lug of the grounding cable to the grounding terminal and fasten the screws.
3. Connect the other end of the grounding cable to the grounding strip of the rack.
Figure2-7 Connecting the grounding cable to the grounding hole of router
IMPORTANT: · The resistance reading should be smaller than 5 ohms between the chassis and the ground. · To guarantee the grounding effect, use the grounding cable provided with the router to connect to the grounding strip in the equipment room as long as possible. |
Installing a power module
Each of an SR6604-X and an SR6608-X router provides two power module slots. An SR6616-X router provides four power module slots. Slots except Slot 1 (PWR1) are provided with filler panels. The routers support both AC (PSR650-A and PSR1200-A) and DC (PSR650-D and PSR1200-D) power modules, but AC and DC power modules cannot work together. The power modules in use must be of the same specification.
Before you install the power module, make sure the power switch is off and the grounding cable is well grounded.
The procedures for installing power modules are the same. This section uses a PSR650-A as an example.
To install a power module:
1. Face the front of the router and locate the slot to be used.
2. Loosen the captive screws on the filler panel in the slot, and then remove the filler panel.
Keep the removed filler panel for future use.
Skip this step if you install the power module to the PWR1 slot.
3. Holding the handle of the power module with one hand and supporting the bottom of the power module with the other hand, insert the power module slowly along the slide rails until it makes close contact with the backplane.
4. Fasten the captive screws on the two sides of the power module.
For more information about the power module LED description, see H3C SR6604-X/SR6608-X/SR6616-X Routers Hardware Information and Specifications.
Figure2-8 Installing a power module
Installing an MPU
CAUTION: The RUN LED flashes fast when the MPU is starting up. Do not install or remove the MPU during this period to avoid hardware damage. |
Before the installation, make sure the ejector levers of the MPU are outwards.
Slot 4 on the SR6616-X does not have a filler panel.
The installation procedures for the RSE-X2 and RSE-X3 MPUs are the same. The following example uses the RSE-X2.
To install an MPU:
Skip this step if you install the MPU to slot 4 of an SR6616-X router.
3. Insert the MPU slowly along the slide rails until it makes close contact with the backplane, and then push the ejector levers inward to lock the MPU in position.
4. Fasten the captive screws on the two sides of the MPU.
For the MPU LED description, see H3C SR6604-X/SR6608-X/SR6616-X Routers Hardware Information and Specifications.
Figure2-9 Installing an MPU
On the SR6616-X, slot 6 must have an SFE-X1 switching fabric module installed.
Before the installation, make sure the ejector levers of the SFE-X1 are outwards.
To install an SFE-X1:
1. Face the front of the router and locate the slot.
3. Insert the SFE-X1 slowly along the slide rails until positioning pins on the backplane are seated in the positioning holes, and then push the ejector levers inward to lock the SFE-X1 in position.
4. Fasten the captive screws on the two sides of the SFE-X1.
For the SFE-X1 LED description, see H3C SR6604-X/SR6608-X/SR6616-X Routers Hardware Information and Specifications.
Figure2-10 Installing an SFE-X1
Installing an LPU
CAUTION: The RUN LED flashes fast when the FIP is starting up. To avoid hardware damage, do not install or remove a HIM/MIM/MIC during this period. |
Slot 3 of the SR6604-X/SR6608-X and Slot 7 of the SR6616-X are not provided with filler panels.
Before the installation, make sure the ejector levers of the LPU are outwards.
The procedures for installing LPUs are similar. This section uses a FIP-210 as an example.
To install a FIP-210:
2. Loosen the captive screws on the filler panel in the slot and then remove the filler panel.
Skip this step if you install the FIP-210 to Slot 3 of the SR6604-X/SR6608-X, or Slot 7 of the SR6616-X.
3. Gently push the FIP-210 into the slot along the slide rails until positioning pins on the backplane are seated in the positioning holes, and then push the ejector levers inward to lock the FIP-210 in position.
4. Fasten the captive screws on the two sides of the FIP-210.
For more information about the FIP LED description, see H3C SR6604-X/SR6608-X/SR6616-X Routers Hardware Information and Specifications.
Installing a HIM/MIM/MIC
CAUTION: HIMs, MIMs, and MICs support hot swapping. Before removing a HIM/MIM/MIC, first execute the remove slot number command to stop the HIM/MIM/MIC from operating. |
The procedures for installing HIMs, MIMs, and MICs are the same.
To install a HIM/MIM/MIC:
1. Face the front of the router and locate the slot to install the HIM/MIM/MIC on the FIP module.
2. Loosen the captive screws on the filler panel, and then remove the filler panel.
3. Use even pressure to push the HIM/MIM/MIC slowly along the slide rails into the slot, and then close the ejector levers.
Install a HIM/MIM with the components upward and install an MIC with the components downward.
4. Fasten the captive screws on the HIM/MIM/MIC.
5. Observe the LED for the slot on the router front panel to verify that the HIM/MIM/MIC is installed correctly.
If the LED is on after the HIM/MIM/MIC initialization completes, the HIM/MIM/MIC has been installed correctly and is operating correctly. If the LED is off, the HIM/MIM/MIC has failed the POST.
Figure2-12 Installing a HIM/MIM/MIC
Installing a CF card
1. Push the CF card eject button all the way into the slot, and make sure the button does not project from the panel.
2. Insert the CF card into the slot following the direction shown in Figure2-13, and make sure it does not project from the slot.
Figure2-13 Inserting the CF card into the slot
Optional components (including the air filter and lightning protectors) are not provided with the router. Purchase them if necessary.
Installing an air filter on an SR6604-X/SR6608-X
The methods for installing air filters on the SR6604-X and SR6608-X are the same. This section uses an SR6608-X as an example.
To install an air filter:
1. Face the left side (side of the inlet vents) of the router.
2. Install the upper and lower slide rails on the chassis as shown in Figure2-14.
3. Fasten the fastening screws on the upper and lower slide rails.
Figure2-14 Installing the upper and lower slide rails
4. Push the air filter along the slide rails from the rear side of the chassis to the front.
Figure2-15 Inserting the air filter to the slide rail
5. Fasten the captive screws on the rear side of the air filter.
Figure2-16 Fastening the captive screws
Installing an air filter on an SR6616-X
2. Align the positioning pins on the air filter with the screw holes on the inlet vent area, and fasten the screws on the air filter.
Figure2-17 Installing an air filter on an SR6616-X
Read the instructions for the lightning protector carefully before you install it.
The lightning protector for a network port is only applicable to a copper Ethernet port.
If part of the network cable of a copper Ethernet port must be routed outdoors, connect a lightning protector to the cable before you plug the cable into the port.
You can install the following port lightning protectors to the router:
Type |
Port description |
Max. discharge current (8/20μs waveform) |
Output voltage |
10 Mbps/100 Mbps port lightning protector |
Single port |
2.5 KA |
· Core-core ≤ 15 V · Core-ground ≤ 300 V |
1000 Mbps port lightning protector |
Single port |
3 KA |
· Core-core ≤ 15 V · Core-ground ≤ 350 V |
Installation procedure
1. Use a double-faced adhesive tape to stick the lightning protector onto the router chassis, and make sure it is as close to the grounding screw of the router as possible.
2. Measure the distance between the protector and the grounding screw of the router, cut the ground wire of the protector as appropriate, and securely tighten the ground wire to the grounding screw of the router.
3. Use the multimeter to measure whether the ground wire of the protector contacts well with the grounding screw of chassis.
4. Insert the outdoor network cable into the protector's IN end, and the cable connected to the router into the OUT end, and examine the indicators on the lightning protector to verify that the connection is correct.
5. Use nylon ties to bundle the cables neatly.
Figure2-18 Installing a lightning protector for a network port
(1) Grounding cable |
(2) Lightning protector |
Installation precautions
The performance of the port lightning protector might be affected in the following cases:
· The port lightning protector is installed in reverse direction. Connect the IN end to the outdoor network cable and the OUT end to the network port on the router.
· The port lightning protector is not well grounded. After the connection, use the multimeter to confirm that the ground wire for the protector is as short as possible to ensure its good contact with the grounding screw of the router.
· The installed port lighting protectors are not sufficient. If the router has more than one network port connected with other devices through cables outdoor, install a lightning protector for each network port.
CAUTION: Make sure the PE terminal of the power socket has been securely grounded. |
If part of the AC power line is routed outdoors, use a power strip with lightning protection to connect the AC power cord of the router to the AC power line to protect the router from being damaged by lightning strikes.
You can attach the power strip to the rack, workbench, or wall of equipment room.
After you connect the AC power cord from the router to a socket on the power strip, verify that the green RUN LED on the strip is on and the red LED is off.
If the red LED is on, use a multimeter to check the polarity of the wires in the power socket for wrong connections. If the zero wire (left) and the live wire (right) are correctly connected, check for missing grounding connection.
Figure2-19 Power strip with lightning protection
(1) Operating LED (green) |
On means the circuit is operating correctly. Off means the circuit is damaged. |
(2) Grounding/pole detection LED (red) |
On indicates a wrong wire connection. (The wire is not grounded or the live line and null line are reversely connected.) In this case, you need to check the power supply line. |
(3) Power switch |
(4) IEC standard socket |
It is used to connect to the power supply in the equipment room through a power cord. |
(5) Overload automatic protector |
The protector automatically opens the electric circuit when the current exceeds the threshold and closes the electric circuit when the current drops below the threshold. |
(6) Multifunctional socket |
It is used to connect the power module of the router. |
CAUTION: Ground the surge protector as near as possible. The grounding resistance must be less than 4 ohms. The grounding resistance must be less than 1 ohm if there are special grounding requirements. |
Read the instructions carefully before installing the surge protector.
Generally, you need to connect a surge protector before connecting a signal cable to the router. This can protect electronic devices against surge over-voltage resulting from lightning strokes and other interferences, and minimize impact on the router.
The surge protector is serially connected to a signal cable, so the surge protector must satisfy the requirements of network performance indexes such as data transmission bandwidth, as well as the lightning protection performance requirement. Before installing a surge protector, consider such performance indexes of the surge protector as lightning protection, bandwidth, transmission loss, and port type.
The router supports the following types of surge protectors:
· Surge protector—Maximum discharge current 2.5KA/protection voltage 25V--SMB-75J/ SMB-75J-1W-10Mbps
· Surge protector—Maximum discharge current 2.5KA/protection voltage 25V-BNC-75K/ BNC-75K-10Mbps
· Surge protector (U port)—Maximum discharge current 3KA/common-mode 400V/differential mode 170V-RJ11
To install a surge protector:
1. Use a double-faced adhesive tape to stick the surge protector onto the router chassis, and make sure it is as close to the grounding screw of the router as possible.
4. Insert the outdoor network cable into the protector's IN end, and the cable connected to the router into the OUT end, and look at the indicators on the surge protector to verify that the connection is correct.
Figure2-20 Installing a surge protector
(2) Surge protector |
The performance of the surge protector might be affected in the following cases:
· The surge protector is installed in reverse direction. Connect the IN end to the outdoor network cable and the OUT end to the network port on the router.
· The surge protector is not well grounded. After the connection, use the multimeter to confirm that the ground wire for the protector is as short as possible to ensure its good contact with the grounding screw of the router.
· The installed surge protectors are not sufficient. If the router has more than one cable connected with other devices through cables outdoor, install a surge protector for each cable.
Connecting the power cord
Connecting an AC power cord
1. Make sure the router is well grounded, and the power switch on the router is in the OFF position.
2. Connect one end of the AC power cord to the AC receptacle on the router, and the other end to the AC power source.
3. Use cable ties to secure the power cord to the rack post.
Figure2-21 Connecting an AC power cord to the router
Connecting DC power cords
Connecting power cords for the PSR650-D
WARNING! To avoid connection mistakes, identify the label on the DC power cord. |
Figure2-22 DC power cords
To connect DC power cords:
1. Switch off the power supply.
2. Remove the protection cover of the DC power module, and remove the screws from the DC-input terminal block.
3. Connect the end marked with "– " to the negative terminal (–) on the DC-input terminal block and fasten the screw.
4. Connect the end marked with "+" to the positive terminal (+) on the DC-input terminal block and fasten the screw.
5. Connect the other end of each DC power cord to the DC power source.
6. Install the protection cover of the DC power module.
Figure2-23 Connecting DC power cords
Connecting power cords for the PSR1200-D
Figure2-24 DC power cords
1. Loosen the captive screws on the power module and remove the power module connector.
Figure2-25 Removing the power module connector.
2. Connect the end marked with "– " to the negative terminal (–) on the power module connector and fasten the fastening screw.
3. Connect the end marked with "+"to the positive terminal (+) on the power module connector and fasten the fastening screw.
Figure2-26 Attaching the power cords to the power module connector
4. Insert the power module connector in right direction into the power module, and fasten the captive screws.
Figure2-27 Installing the power module connector to the power module
5. Connect the other end of each power cord to the DC power source.
6. Use cable ties to secure the power cords to the rack post.
3 Connecting interface cables
Connecting the AUX cable
Overview
An AUX cable has a crimped RJ-45 connector at one end for connecting to the AUX port of the router, and D9 male connectors at the other end for connecting to the serial port of the modem.
Figure3-1 AUX cable
1. Plug the D9 male connector at one end of the AUX cable into the serial port on the modem.
2. Plug the RJ-45 connector of the AUX cable into the AUX port on the router.
Figure3-2 Connecting the AUX port to a modem
Connecting an Ethernet cable
Overview
10/100 Mbps Ethernet uses category-5 twisted pair cables, while 1000 Mbps Ethernet uses category-5 enhanced or category-6 twisted pair cables. Twisted pair cables include straight-through cables and crossover cables.
Category-5 cables provide a transmission frequency of 100 MHz for voice and data transmission; they are mainly used in 100Base-T and 10Base-T networks. Category-5 cables are common Ethernet cables, which can also be used to transmit 1000 Mbps Ethernet data.
Category-5 enhanced cables feature low attenuation and crosstalk, providing higher attenuation to crosstalk ratio (ACR), less delay error and higher performance than category-5 cables. Category-5 enhanced cables are mainly used in 1000 Mbps Ethernet networks.
Category-6 cables provide a transmission frequency of 1 MHz to 250 MHz, and improve the performance on crosstalk and return loss. A fine better return loss performance is extremely important for new-generation full-duplex high-speed networks. Category-6 cables have sufficient power sum ACR (PS-ACR) when working at 200 MHz. They provide a bandwidth two times than that of category-5 enhanced cables, thus featuring a higher transmission performance. Therefore, category-6 cables are suitable for applications requiring a transmission speed of more than 1 Gbps.
The 10/100 Mbps Ethernet uses two pairs of cables, orange/white, orange, green/white and green cables, to transmit and receive data, while the 1000 Mbps Ethernet uses four pairs of cables to transmit and receive data.
An Ethernet twisted pair cable connects network devices through the RJ-45 connectors at the two ends. Figure3-3 shows the pinouts of an RJ-45 connector.
Figure3-3 RJ-45 connector pinout
EIA/TIA cabling specifications define two standards, 568A and 568B, for cable pinouts.
· Standard 568A—Pin 1: white/green stripe, pin 2: green steady, pin 3: white/orange stripe, pin 4: blue steady, pin 5: white/blue stripe, pin 6: orange steady, pin 7: white/brown stripe, pin 8: brown steady.
· Standard 568B—Pin 1: white/orange stripe, pin 2: orange steady, pin 3: white/green stripe, pin 4: blue steady, pin 5: white/blue stripe, pin 6: green steady, pin 7: white/brown stripe, pin 8: brown steady.
Ethernet twisted pair cables can be classified into straight-through and crossover cables based on their pinouts.
For the pinouts of the twisted pair cables, see the following tables. (A and B represent the two ends of a cable, respectively.)
Table3-1 Straight-through cable pinouts
Pinout No. |
A |
B |
1 |
Orange/white |
Orange/white |
2 |
Orange |
Orange |
3 |
Green/white |
Green/white |
4 |
Blue |
Blue |
5 |
Blue/white |
Blue/white |
6 |
Green |
Green |
7 |
Brown/white |
Brown/white |
8 |
Brown |
Brown |
Table3-2 Crossover cable pinouts
Pinout No. |
A |
B |
1 |
Orange/white |
Green/white |
2 |
Orange |
Green |
3 |
Green/white |
Orange/white |
4 |
Blue |
Blue |
5 |
Blue/white |
Blue/white |
6 |
Green |
Orange |
7 |
Brown/white |
Brown/white |
8 |
Brown |
Brown |
NOTE: To avoid affecting communication quality, strictly follow the pinouts in the above tables when identifying or making the two types of Ethernet cables. |
Making an Ethernet cable
1. Cut the cable to a required length with the crimping pliers.
2. Strip off an appropriate length of the cable sheath. The length is typically that of the RJ-45 connector.
3. Untwist the pairs so that they can lay flat, and arrange the colored wires based on the wiring specifications.
4. Cut the top of the wires even with one another. Insert the wires into the RJ-45 end and make sure the wires extend to the front of the RJ-45 end and make good contact with the metal contacts in the RJ-45 end and in the correct order.
5. Crimp the RJ-45 connector with the crimping pliers until you hear a click.
6. Use a cable tester to verify the correct connectivity of the cable.
1. Plug one end of an Ethernet twisted pair cable into the copper Ethernet port (RJ-45 port) or the management Ethernet port to be connected on the router and the other end of the cable into the Ethernet port of the peer device. The 10/100/1000Base-T copper ports of the router support MDI/MDI-X auto-sensing. They are connected to the network through category-5 or above twisted pairs that are equipped with RJ-45 connectors.
2. Examine the status LED of the Ethernet ports. For more information about the LED status, see H3C SR6604-X/SR6608-X/SR6616-X Routers Hardware Information and Specifications.
Connecting a fiber cable
Transceiver module overview
When you use a fiber port, you need an SFP, XFP, SFP+, or QSFP+ transceiver module and a fiber cable with an LC or MPO connector. For the compatibility between the cards and transceiver modules, see H3C SR6600/SR6600-X Routers Interface Module Guide.
Figure3-4 SFP transceiver module
Figure3-5 SFP+ transceiver module
Figure3-6 XFP transceiver module
Figure3-7 QSFP+ transceiver module (LC connector)
Figure3-8 QSFP+ transceiver module (MPO connector)
Fiber cable overview
CAUTION: · Never exert a fierce force when you insert or remove a fiber connector. · Never pull, press, or extrude the fiber fiercely. |
Optical fibers can be classified into single-mode optical fibers and multi-mode optical fibers. A single-mode optical fiber carries only a single ray of light, and a multi-mode optical fiber carries multiple modes of lights.
Table3-3 Characteristics of single-mode and multi-mode optical fibers
Item |
Single-mode optical fiber |
Multi-mode optical fiber |
Core |
Small core (10 micrometers or less) |
Larger core than single-mode optical fiber (50 micrometers, 62.5 micrometers or greater) |
Dispersion |
Less dispersion |
Allows greater dispersion and therefore, signal loss exists |
Light source and transmission distance |
Users lasers as the light source often within campus backbones for distance of several thousand meters |
Uses LEDs as the light source often within LANs or distances of a couple hundred meters within a campus network |
Table3-4 lists the allowed maximum tensile load and crush load for the fiber.
Table3-4 Allowed maximum tensile force and crush load
Period of force |
Tensile load (N) |
Crush load (N/mm) |
Short period |
150 |
500 |
Long term |
80 |
100 |
Fiber connectors are indispensable passive components in an optical fiber communication system. They allow the removable connection between optical channels, which makes the optical system debugging and maintenance more convenient. Figure3-9 and Figure3-10 show an LC connector and an MPO connector, respectively.
(1) LC connector |
(2) Optical fiber |
CAUTION: If you are not to use a fiber port or transceiver module, insert dust plugs into the port or module. If you are not to connect an optical fiber, install dust caps for the fiber connector. |
To install a transceiver module and optical fiber:
1. Wear an ESD wrist strap and make sure the wrist strap is reliably grounded.
2. Remove the dust plug from the target fiber port.
3. Pull the bail latch on the transceiver module upwards.
4. Take the transceiver module by its two sides and push the end without the bail latch gently into the port until it is firmly seated in the fiber port.
5. Remove the dust plug and dust cap from the transceiver module and fiber connector, respectively.
6. Connect the optical fiber to the transceiver module.
¡ LC connector—Identify the Rx and Tx ports on the transceiver module. Use the optical fiber to connect the Rx port and Tx port on the transceiver module to the Tx port and Rx port on the peer end, respectively.
¡ MPO connector—Orient the connector with the white spot on it facing right. Insert the MPO fiber connector straight into the transceiver module and push it slightly forward until it clicks into place.
7. Use cable ties to bind optical fibers every 150 mm (5.91 in).
8. Label optical fibers according to the cable labeling specifications.
Figure3-11 Installing a transceiver module and optical fiber (LC port)
Figure3-12 Installing a transceiver module and optical fiber (MPO port)
Connecting an E1/T1 cable
Overview
E1 cable
You can use an 8E1 interface cable to connect to MIM-8E1(75)/MIM-8E1(75)-F modules.
NOTE: The coaxial connector and 75-ohm E1 adapter cable are optional accessories, and must be purchased separately if needed. |
T1 cable
CAUTION: When connecting the interface cable, pay attention to the mark on the interface to avoid wrong insertion, which might damage the interface module or even the router. |
As a best practice, install a lightning protector at the input end of the 8T1 cables to protect them against lightning strikes more efficiently when they are led outdoors.
You can use an 8T1 interface cable to connect to MIM-8T1/MIM-8T1-F modules.
Figure3-14 8T1 splitter cable
Connecting an E1 cable (D68 <----> BNC)
· If you do not need to extend the cable, you can directly connect the BNC connectors of the E1 75-ohm cable to the remote network device as follows.
a. Connect the D68 connector of the E1 75-ohm cable to the D68 interface of the interface module and fasten the bolts to fix the cable.
b. The other end of the cable provides one pair or multiple pairs of 75-ohm BNC connectors. Connect the TX connectors and the RX connectors on this end to the RX connectors and the TX connectors on the remote device respectively.
Figure3-15 Connecting an E1 75-ohm cable
· If you want to extend the cable, connect each BNC connector of the E1 75-ohm cable to one end of a coaxial connector, and connect the remote device to the other end of the coaxial connector through an E1 75-ohm adapter cable.
Figure3-16 Connecting an E1 75-ohm cable
· If the impedance of the E1 interface on the remote device is 120 ohms, you must use an impedance converter to adapt the impedance.
Figure3-17 Connecting an impedance converter
Connecting a T1 cable
1. Connect the D68 connector of the 8-port T1 cable to the D68 interface on the interface module and fasten the bolts to fix the cable.
2. The other end of the cable provides eight RJ-45 connectors. Connect them to the RJ-45 interface on the remote device as needed.
Figure3-18 Connecting an 8T1 cable
Connecting a CE3/CT3/T3 cable
Overview
As a best practice, install a special lightning protector at the input end of the E3/T3 cables to protect them against lightning strikes more efficiently when they are routed outdoors.
You can use an E3/T3 interface cable to connect the MIM-1CE3, MIM-1CT3, and MIM-1T3-V2 modules.
1. Connect the SMB connector of an E3/T3 cable to the Tx port on the interface module and the other end to the Rx port on the device to be connected.
2. Connect the SMB connector of another E3/T3 cable to the Rx port of interface module and the other end to the Tx port on the device to be connected.
Figure3-20 Connecting a CE3/CT3/T3 cable
Overview
You can use a serial port cable to connect to the MIM-2SAE/MIM-4SAE/MIM-8SAE module. Select a serial port cable according to the link type.
Figure3-21 V.24 DTE cable
Figure3-22 V.24 DCE cable
Figure3-23 V.35 DTE cable
Figure3-24 V.35 DCE cable
Figure3-25 X.21 DTE cable
Figure3-26 X.21 DCE cable
Figure3-27 RS449 DTE cable
Figure3-28 RS449 DCE cable
Figure3-29 RS530 DTE cable
Figure3-30 RS530 DCE cable
1. Check port type of the peer device and choose the synchronous serial interface cable of correct type.
2. Plug the D28 end of the synchronous serial interface cable into the D28 interface of the SAE interface module.
3. If the WAN uses DDN line, connect the cable to the port of the CSU/DSU.
4. Identify the LINK LED on the SAE panel.
¡ If the LED is on, a link is present.
¡ If the LED is off, a fault has occurred on the link and signal is out of synchronization. In this case, examine the link.
4 Accessing the router
Login methods
The following logins methods are available for you to log in to the router:
· Logging in through the console port, which is the most common way to log in to a router and also the prerequisite for configuring other login methods.
· Logging in through Telnet or SSH.
· Logging in through the AUX port.
You can log in only through the console port the first time you log in to your router.
Introduction to console cables
As shown in Table4-1, two types of console cables can be used for connecting the router to a configuration terminal. No console cable is provided with the router. Purchase a console cable as required.
Table4-1 Introduction to console cables
Console cable type |
Console cable view |
Router-side connector |
Configuration terminal-side connector |
Connection method |
DB9-to-RJ45 console cable |
DB-9 female connector |
RJ-45 |
USB-to-RJ45 console cable |
USB |
RJ-45 |
Connecting a DB9-to-RJ45 console cable
CAUTION: When you disconnect a PC from a powered-on router, disconnect the DB-9 connector of the console cable from the PC after disconnecting the RJ-45 connector from the router. |
To set up a configuration environment:
1. Plug the DB-9 female connector to the serial port of the configuration terminal.
2. Connect the RJ-45 connector to the console port of the router.
Figure4-1 Connecting the console cable
Connecting a USB-to-RJ45 console cable
IMPORTANT: · To use a USB-to-RJ45 console cable to connect the router to a configuration terminal, first download and install the USB-to-RJ45 console driver on the configuration terminal, and then connect the USB-to-RJ45 console cable to the configuration terminal. To download the USB-to-RJ45 console driver, access the H3C official website or scan the QR code on the cable package. · If you have connected a USB-to-RJ45 console cable to the configuration terminal before installing the driver, remove and reconnect the USB-to-RJ45 console cable to the configuration terminal after driver installation. |
The following installs the driver on the Windows system. To install the driver on other operating systems, see the installation guide in the driver compression package named by using the corresponding operating system.
To connect the router to a configuration terminal by using a USB-to-RJ45 console cable:
1. Click the following link, or copy it to the address bar on your browser and download the USB-to-RJ45 console driver.
http://www.h3c.com/en/home/USB_to_RJ45_Console/
2. View the TXT file Read me in the Windows folder to check whether the Windows system of the configuration terminal supports the driver.
3. If the Windows system supports the driver, install PL23XX-M_LogoDriver_Setup_v200_20190815.exe.
4. Click Next on the welcome page of the driver installation wizard.
Figure4-2 Driver installation wizard
5. Click Finish after the drive installation is completed.
Figure4-3 Finishing the driver installation
6. Connect the standard USB connector of the cable to the USB port of the configuration terminal.
7. Connect the RJ-45 connector of the cable to the console port of the router.
Setting terminal parameters
1. Select Start > All Programs > Accessories > Communications > HyperTerminal.
The Connection Description dialog box appears.
Figure4-4 Connection description
2. Select the serial port to be used from the Connect using list, and click OK.
Figure4-5 Setting the serial port used by the HyperTerminal connection
3. Set Bits per second to 9600, Data bits to 8, Parity to None, Stop bits to 1, and Flow control to None, and click OK.
Figure4-6 Setting the serial port parameters
4. Select File > Properties in the HyperTerminal window.
Figure4-7 HyperTerminal window
5. On the Settings tab, set the emulation to VT100 and click OK.
Figure4-8 Setting terminal emulation in test Properties dialog box
Powering on the router
Verifying before power-on
Before powering on the router, verify the following items:
· The power modules and fan trays are correctly installed.
· The power cord and grounding cable are correctly connected.
· The power source voltage meets the requirement of the router.
· The console cable is correctly connected, the terminal or PC used for configuration has started, and the configuration parameters have been set.
· If a CF card is used, verify that the CF card is in position.
· Make sure the installed LPUs and HIMs/MIMs/MICs are in position.
· Turn on the switch of the power supply system for the router.
· Turn on the switch of the AC or DC power modules.
Displaying boot information
Power on the router, and you can see the following information:
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Press Ctrl+T to start memory test
Booting Normal Extend BootWare........
The Extend BootWare is self-decompressing........................Done!
* H3C SR66 BootWare, Version 2.06 *
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd.
Compiled Date : Apr 6 2017
CPU Type : P2020
CPU L1 Cache : 32KB
CPU Clock Speed : 1000MHz
Memory Type : DDR3 SDRAM
Memory Size : 4096MB
Memory Speed : 667MHz
Flash Size : 8MB
cfa0 Size : 999MB
NVRAM Size : 128KB
BASIC CPLD Version : 2.0
EXTENDED CPLD Version: 2.0
PCB Version : Ver.B
BootWare Validating...
Press Ctrl+B to enter extended boot menu...
Starting to get the main application file--cfa0:/sr6600-x.bin!............
The main application file is self-decompressing.............................
....................................................................Done!
System application is starting...
Mainboard 1 is master.
User interface con1 is available.
Press ENTER to get started.
Press Enter, and the following prompt appears:
<H3C>
You can now configure the router.
1. After powering on the router, log in to the router through the console port.
2. Use the telnet server enable command and the ssh server enable command to enable the Telnet and SSH function on the router, respectively, and use the user privilege level command to set the user privilege level.
3. Connect the PC to the management Ethernet port or the copper Ethernet port on the router and specify an IP address for the port.
4. Specify an IP address for the PC, making sure the PC and the port are in the same network segment.
For more information about how to log in to the router through Telnet/SSH, see H3C SR6600/SR6600-X Routers Configuration Guides.
Configuring basic settings
Step |
Command |
Remarks |
1. Set the current time and date. |
clock datetime time date |
Optional. Available in user view. |
2. Enter system view. |
system-view |
3. Enter Ethernet interface view. |
N/A |
4. Specify an IP address for the interface. |
ip address ip-address { mask-length | mask } [ sub ] |
By default, no IP address is assigned to any interface. |
5. Return to system view. |
quit |
Available in any view. |
6. Specify a static route. |
ip route-static dest-address { mask | mask-length } { next-hop-address | interface-type interface-number [ next-hop-address ] | vpn-instance d-vpn-instance-name next-hop-address } track track-entry-number [ preference preference-value ] [ tag tag-value ] [ description description-text ] |
By default, the preference of a static route is 60, tag is 0, and no description is configured. |
7. Save the current configuration to the startup configuration file in the root directory of the storage media. |
save [ safely ] [ backup | main ] [ force ] |
8. Verify the running configuration. |
display current-configuration |
5 Replacement procedures
The router uses modular design. All modules for the router are hot swappable.
· Always wear an ESD wrist strap or ESD gloves when you replace the modules.
· To hot swap an LPU or HIM/MIM/MIC, first use the remove command to stop the card from operating.
· When you replace FRUs, such as MPUs, LPUs, memory modules, the CF card, and HIMs/MIMs/MICs, follow these guidelines:
¡ Ensure good alignment with the slot to avoid damage to the module during installation or removal.
¡ To prevent module panel deformation, make sure the captive screws are completely loosened before removing a module.
¡ Avoid touching any components on the PCB during observing or moving the module.
¡ Put the removed module on an antistatic workbench with the PCB side facing upward or place them in antistatic bags.
Replacing a power module
The replacement procedures for an AC power module and a DC power module are the same. This section uses an AC power module as an example.
To replace a power module:
1. Face the front of the router and locate the power module to be removed.
2. Completely loosen the captive screws of the power module.
3. Holding the handle of the power module with one hand and supporting the bottom of the power module with the other hand, gently pull the power module out of the slot along the slide rails.
Put the removed power module on an antistatic workbench or into an antistatic bag.
Figure5-1 Pulling the power module out of the slot
4. Install a new power module. For the installation procedure, see "Installing a power module."
If you do not install a new power module in the slot, install a filler panel.
IMPORTANT: When the system has a card that does not operate stably, do not use the reboot command to trigger an active/standby switchover. To display stability information for the system, execute the display system stable state command. |
· If the router is installed with only one MPU, make sure all power sources to the router are turned off before replacing the MPU.
· If the router is installed with two MPUs, make sure both MPUs operate correctly before replacing one MPU.
¡ To replace the active MPU, execute the reboot command in system view on the MPU to trigger an active/standby switchover. For more information about the command, see the command reference for the router.
¡ To replace the standby MPU, remove it directly.
Replacing an MPU
The replacement procedures for the RSE-X2 and RSE-X3 MPUs are the same. The following example uses an RSE-X2.
To replace an MPU:
1. Face the front of the router and locate the MPU to be removed.
2. Completely loosen the captive screws of the MPU.
3. Holding the ejector levers of the MPU with both hands, pull the ejector levers outward, and gently pull the MPU out of the slot along the slide rails.
Figure5-2 Pulling the RSE-X2 MPU out of the slot
4. Install a new MPU. For the installation procedure, see "Installing an MPU."
If you do not install a new MPU in the slot, install a filler panel.
Replacing an SFE-X1
1. Face the front of the router and locate the SFE-X1 to be removed.
2. Completely loosen the captive screws on the SFE-X1.
3. Holding the ejector levers of the SFE-X1 with both hands, pull the ejector levers outward, and gently pull the SFE-X1 out of the slot along the slide rails.
Figure5-3 Pulling the SFE-X1 out of the slot (SR6616-X)
4. Install a new SFE-X1. For the installation procedure, see "Installing an SFE-X1 switching fabric module."
If you do not install a new SFE-X1 in the slot, install a filler panel.
Replacing an LPU
CAUTION: To avoid hardware damage, do not replace the LPU when its RUN LED is fast flashing. |
To replace an LPU:
1. Face the front of the router and locate the FIP module to be removed.
2. Completely loosen the captive screws of the FIP module.
3. Holding the ejector levers of the FIP module with both hands, pull the ejector levers outward, and gently pull the FIP module out of the slot along the slide rails.
Figure5-4 Pulling the FIP module out of the slot
4. Install a new FIP module. For the installation procedure, see "Installing an LPU."
If you do not install a new FIP module in the slot, install a filler panel.
Replacing a HIM/MIM/MIC
IMPORTANT: After you remove a HIM/MIM/MIC from a FIP, the HIM/MIM/MIC settings will not automatically restore if you reinstall the HIM/MIM/MIC on the FIP after the FIP reboots. To save the settings, make sure the HIM/MIM/MIC is in position before rebooting the FIP module or inserting the FIP module into the router. |
The replacement procedures for HIMs, MIMs, and MICs are similar.
To replace a HIM/MIM/MIC:
1. Face the front of the router and locate the HIM/MIM/MIC to be removed.
2. Completely loosen the captive screws of the HIM/MIM/MIC.
3. Fully open the ejector levers on the HIM/MIM/MIC. Hold the ejector levers and then gently pull the HIM/MIM/MIC out of the slot along the slide rails.
The ejector levers of the FIP module are long. When removing the HIM/MIM/MIC in slot 1 on the FIP module, avoid touching the right ejector lever of the FIP module.
Figure5-5 Removing a HIM/MIM/MIC
4. Install a new MIM. For the installation procedure, see "Installing a HIM/MIM/MIC."
If you do not install a new MIM in the slot, install a filler panel.
Replacing a CF card
CAUTION: To avoid hardware damage, do not remove the CF card when the router is booting or the CF LED is flashing. |
1. Press the CF card eject button of the CF card reader so that the eject button projects from the panel.
2. Press the eject button again to eject the CF card part-way out of the CF card reader, and then pull the CF card out of the CF card reader.
Figure5-6 Removing a CF card
3. Install a new CF card. For the installation procedure, see "Installing a CF card."
The removal procedure is the same for the transceiver modules with LC connectors and MPO connectors. This section uses a transceiver module that has LC connectors as an example.
To replace a transceiver module:
1. Pressing the tab of the LC connector, pull out the LC connector from the transceiver module.
Put on the dust cap for the LC connector.
2. Pivot the clasp of the transceiver module down to the horizontal position.
3. Hold the clasp to gently pull the transceiver module out.
Put the dust plug on the removed module, and put the removed module into its original shipping materials.
4. Install a new transceiver module. For the installation procedure, see "Connecting a fiber cable."
If you do not install a new transceiver module in the interface, install a dust-proof plug in the interface.
Figure5-7 Removing a transceiver module
CAUTION: · Keep your hands away from the spinning fan blades when removing the fan tray. · Do not keep the router working without a fan tray for more than two minutes because poor ventilation might result in damage to the router. |
The methods for replacing fan trays for the SR6604-X and SR6608-X are the same. This section uses an SR6608-X as an example.
To replace a fan tray:
2. Completely loosen the captive screws of the fan tray to be removed.
3. Holding the handle of the fan tray with one hand and supporting the bottom of the fan tray with the other hand, gently pull the fan tray out of the slot along the slide rails.
Figure5-8 Pulling out the fan tray
4. Holding the handle of the fan tray with one hand and supporting the bottom of the fan tray with the other hand, gently push the fan tray into the slot along the slide rails until it is completely seated.
5. Fasten the captive screws on the fan tray.
Replacing a fan tray for an SR6616-X router
2. Press the fan tray release button with the thumb, slightly pull the fan tray away from the chassis, and slowly pull the fan tray out along the slide rails when fans stop spinning.
3. Holding the front part of the fan tray with one hand, pressing down the release button with the thumb, and supporting the bottom of the fan tray with the other hand, push the fan tray into the slot along the slide rails until the fan tray makes complete contact with the backplane.
Figure5-9 Pulling out the fan tray
Replacing an air filter
IMPORTANT: You can clean the air filter with water, but wait until it is completely dry before installing it again. |
Replacing an air filter for an SR6604-X/SR6608-X router
1. Face the left side of the router.
2. Completely loosen the captive screws of the air filter.
Figure5-10 Loosening the captive screws of the air filter
3. Gently pull the air filter out along the slide rails.
Figure5-11 Pulling the air filter out along the slide rails
4. Install a new air filter. For the installation procedure, see "Installing an air filter on an SR6604-X/SR6608-X."
Replacing an air filter for an SR6616-X router
Figure5-12 Removing the air filter
3. Install a new air filter. For the installation procedure, see "Installing an air filter on an SR6616-X."
Replacing a memory module
CAUTION: For the router to operate correctly, use the memory modules provided by H3C only. |
The MPUs and LPUs are equipped with memory modules. Before you install or remove a memory module, remove the MPU or LPU from the chassis first. For more information, see "Replacing an MPU and a switching fabric module" and "Replacing an LPU."
For the memory module specifications, see H3C SR6604-X/SR6608-X/SR6616-X Routers Hardware Information and Specifications.
Memory module structure
Figure5-13 Memory module structure (DDR2)
(1) Connector edge |
(2) Polarization notch |
(3) Latch notch |
Figure5-14 Memory module structure (DDR3)
(3) Latch notch |
The methods for replacing memory modules are similar. This example replaces a memory module on an RSE-X2.
To replace a memory module:
1. Pull the release latches away from the memory module at both ends so that the memory module is lifted from the memory module slot.
2. Holding the non-conductive edge, remove the memory module.
3. Align the polarization notch of the memory module with the key in the connector.
4. Insert the memory module into the slot.
5. Carefully and firmly press the memory module at both ends until you hear a click. This indicates the memory module is seated in the memory module slot.
6. Verify that the release latches have firmly locked the memory module in position.
Figure5-15 Replacing a memory module
6 Hardware management and maintenance
The output depends on your router model and software version. For more information about the commands used in this chapter, see H3C SR6600/SR6600-X Routers Command References.
Displaying the hardware information of the router
Displaying the version information of the router
Use the display version command to display software and hardware version information of the router. The output includes the following information: the current software version and hardware version, router operating time, type and operating time of each MPU and LPU.
<Sysname> display version
H3C Comware Platform Software
Comware Software, Version 5.20, A2706P02
Copyright (c) 2004-2012 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C SR6616-X uptime is 0 week, 0 day, 0 hour, 15 minutes
Slot 0: SAP-4EXP uptime is 0 week, 0 day, 0 hour, 13 minutes
CPU type: FREESCALE P4080 1500MHz
4096M bytes DDR3 SDRAM Memory
8M bytes Flash Memory
128K bytes NVRAM
PCB Version: Ver.A
Logic Version: 1.0
Basic BootWare Version: 1.06
Extend BootWare Version: 1.06
[FIXED PORT] XGE0/0/0 (Hardware)Ver.A, (Driver)1.0, (Cpld)1.0
[FIXED PORT] XGE0/0/1 (Hardware)Ver.A, (Driver)1.0, (Cpld)1.0
[FIXED PORT] XGE0/0/2 (Hardware)Ver.A, (Driver)1.0, (Cpld)1.0
[FIXED PORT] XGE0/0/3 (Hardware)Ver.A, (Driver)1.0, (Cpld)1.0
Slot 4: RSE-X2 uptime is 0 week, 0 day, 0 hour, 15 minutes
CPU type: FREESCALE P2020 1000MHz
128K bytes NVRAM
PCB Version: Ver.B
Basic Logic Version: 1.0
Extend Logic Version: 1.0
Basic BootWare Version: 1.01
Extend BootWare Version: 1.01
[FIXED PORT] CON (Hardware)Ver.B, (Driver)1.0, (Cpld)1.0
[FIXED PORT] AUX (Hardware)Ver.B, (Driver)1.0, (Cpld)1.0
[FIXED PORT] MGE4/0/0 (Hardware)Ver.B, (Driver)1.0, (Cpld)1.0
Displaying the running statistics for the router
For diagnosis or troubleshooting, you can use separate display commands to collect running status data module by module, or use the display diagnostic-information command to bulk collect running data for multiple modules. This command displays the output of the display clock, display version, display device, and display current-configuration commands.
· Save the operating statistics for each module of the router.
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.diag)[cfa0:/default.diag]:aa.diag
Diagnostic information is outputting to cfa0:/aa.diag.
Please wait...
Recv slot 4 response packet.
Save successfully.
Execute the more aa.diag command in user view, and then press the Page Up and Page Down keys to view the contents of the file aa.diag.
· Display the operating statistics for each module of the router.
08:54:16 UTC Fri 15/06/2012
Displaying detailed information about a card
· Use the display device verbose command to display detailed information about all cards.
<Sysname>display device verbose
System-mode(Current/After Reboot): Normal/Normal
Slot No. Board type Status Primary SubSlots
0 N/A Absent N/A N/A
1 RSE-X2 Normal Master 0
2 N/A Absent N/A N/A
3 N/A Absent N/A N/A
4 FIP-110 Normal N/A 4
5 N/A Absent N/A N/A
Slot 4 : FIP-110(4 Subslots)
Subslot 1 : MIM-2GBE
Subslot 2 : MIM-2GBE
· Use the display device slot slot-number command to display detailed information about the card in the specified slot.
<Sysname> display device slot 1
Slot 1 : RSE-X2
SubSlot No. Card Type Status Max Ports
1 Fixed SubCard Normal 3
Table6-1 Command output
Slot No. |
Slot number of the card. |
Card Type |
Card model. The value NONE indicates that no card is present in the slot. |
Status |
Running status of the card: · Absent—No card is present in the slot. · Fault—The card in the slot is booting, or the card has failed and cannot boot correctly. · Normal—The card in the slot is operating correctly. |
Max Ports |
Maximum number of ports that the card supports. |
Displaying the electrical label data
Electrical label data is also called permanent configuration data or archive information, which includes the card name, serial number, MAC address, and vendor name.
· Use the display device manuinfo command to display the electrical label data for the card in each slot.
<Sysname> display device manuinfo
Slot 0:
DEVICE_NAME: RT-RSE-X2
DEVICE_SERIAL_NUMBER: 210231A1RG0000000002
MAC_ADDRESS: 00FE-1230-1230
MANUFACTURING_DATE: 2011-12-12
VENDOR_NAME:H3C
· Use the display device manuinfo slot slot-number command to display the electrical label data for the card in the specified slot.
<Sysname> display device manuinfo slot 0
Slot 0:
VENDOR_NAME:H3C
Table6-2 Command output
DEVICE_NAME |
Card type. |
DEVICE_SERIAL_NUMBER |
Card serial number. |
MAC_ADDRESS |
MAC address of the card: · An MPU has a MAC address. · An LPU does not have a MAC address, and the field displays NONE. |
MANUFACTURING_DATE |
Manufacturing date of the card. |
The operation is not supported on the specified board or subslot |
The display device manuinfo command is not supported on a card that is virtualized through the MPU. |
Displaying the CPU usage statistics
Use the display cpu-usage command to display the CPU usage statistics for all cards.
<Sysname> display cpu-usage
Slot 0 CPU usage:
2% in last 5 seconds
2% in last 1 minute
1% in last 5 minutes
Slot 5 CPU usage:
1% in last 5 seconds
1% in last 1 minute
Table6-3 Command output
Slot 0 CPU usage |
CPU usage of the card in slot 0. If the card in the slot has multiple CPUs, "Slot 0 CPU usage" displays the usage of the master CPU of the card in slot 0, and "Slot 0 CPU 1 CPU usage" displays the usage of the auxiliary CPU of the card in slot 0. |
1% in last 5 seconds |
After a boot, the system calculates and records the average CPU usage rate every five seconds. This field displays the average CPU usage rate in the last five seconds. |
1% in last 1 minute |
After a boot, the system calculates and records the average CPU usage rate every one minute. This field displays the average CPU usage rate in the last minute. |
1% in last 5 minutes |
After a boot, the system calculates and records the average CPU usage rate every five minutes. This field displays the average CPU usage rate in the last five minutes. |
Displaying the MPU memory usage
Use the display memory command to display the active MPU memory information.
<Sysname> display memory
System Total Memory(bytes): 4069505360
Total Used Memory(bytes): 277820968
Used Rate: 6%
Table6-4 Command output
System Total Memory(bytes) |
Physical memory size (in bytes) of the MPU. |
Total Used Memory(bytes) |
Used memory size (in bytes) of the MPU. |
Used Rate |
Memory usage of the MPU. |
Displaying the CF card information
Use the display device cf-card command to display the CF card information.
<Sysname> display device cf-card
Slot No. Dev No. Status Size(M)
0 0 Normal 999
0 1 Absent N/A
Table6-5 Command output
Slot No. |
Slot number of the CF card. |
Dev No. |
Device number of the CF card: · 0 for a built-in CF card. · 1 for an external CF card. |
Status: |
Operating status of the CF card: · Absent—No CF card is present in the slot. · Fault—The CF card has failed. · Normal—The CF card is operating correctly. |
Storage capacity of the CF card. |
Displaying the fan operating status
Use the display fan command to display the fan operating status.
<Sysname> display fan
Fan 1 State: Normal
Table6-6 Command output
Fan 1 |
Number of the fan. |
State |
Fan state: · Normal—The fan is operating correctly. · Absent—The fan is not in position. · Fault—The fan has failed. |
Displaying the power module operating status
Use the display power-supply command to display the power module operating status.
<Sysname> display power-supply
Power No. State Description
1 Absent Unknown
2 Normal VAPEL-300AC
Table6-7 Command output
Power No. |
Slot number of the power module. |
State |
Power module state: · Normal—The power module is operating correctly. · Absent—The power module is not in position. · Fault—The power module has failed. |
Description for the power module. |
Displaying the alarming thresholds of a card
Use the display environment command to display the temperature information and alarming thresholds of a card.
<Sysname> display environment
System temperature information (degree centigrade):
Slot Sensor Temperature LowerLimit WarningLimit AlarmLimit ShutdownLimit
Vent Hotspot 1 28 0 120 255 255
0 Outflow 1 37 0 53 57 255
0 Hotspot 1 28 0 65 80 255
1 Inflow 1 28 0 50 57 255
1 Outflow 1 31 0 53 60 255
Table6-8 Command output
System Temperature information (degree centigrade) |
Temperature information (°C). |
sensor |
Temperature sensor: · Hotspot—Hotspot sensor. · Inflow—Air inlet sensor. · Outflow—Air outlet sensor. |
Slot |
Sensor position. For a sensor on the chassis for fan tray, this field displays Vent. |
Temperature |
Current temperature. |
LowerLimit |
Lower temperature limit. |
WarningLimit |
Warning temperature threshold. |
AlarmLimit |
Alarming temperature threshold. |
ShutdownLimit |
Shutdown temperature threshold. When the sensor temperature reaches this limit, the system shuts down automatically. |
Port configuration and management
Configuring a combo interface
A combo interface is a logical interface that contains an SFP port of a transceiver module and an RJ-45 Ethernet port. The two ports share one forwarding interface, so they cannot work simultaneously. When you enable either port, the other port is automatically disabled. You can select to activate a port as needed.
Use the display interface interface-type interface-number command to find out which port is an SFP port and which port is an RJ-45 Ethernet port.
· If the output includes "Media type is optical fiber," it means that the port is an SFP port. For example, the following output shows that GigabitEthernet 5/0/1 is an SFP port.
[Sysname] display interface GigabitEthernet 5/0/1
GigabitEthernet5/0/1 current state: DOWN
Line protocol current state: DOWN
Description: GigabitEthernet5/0/1 Interface
The Maximum Transmit Unit is 1500
Internet protocol processing : disabled
IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 2222-2222-2122
IPv6 Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 2222-2222-2122
Media type is optical fiber, loopback not set, promiscuous mode not set
· If the output includes "Media type is twisted pair," it means that the interface is an RJ-45 Ethernet port. For example, the following output shows that GigabitEthernet 5/0/0 is an RJ-45 Ethernet port.
[Sysname] display interface GigabitEthernet 5/0/0
GigabitEthernet5/0/0 current state: DOWN
Description: GigabitEthernet5/0/0 Interface
Media type is twisted pair, loopback not set, promiscuous mode not set
To configure a combo interface:
Step |
Command |
Remarks |
9. Enter system view. |
system-view |
N/A |
10. Enter view of the SFP port or RJ-45 port of the combo interface. |
N/A |
11. Activate the RJ-45 Ethernet port or SFP port. |
combo enable { copper | fiber } |
By default, the fiber port is active. |
Displaying and verifying transceiver modules
Table6-9 Commonly used transceiver modules
Transceiver module type |
Application scenarios |
Whether can be an optical transceiver |
Whether can be an copper transceiver |
SFP (small form-factor pluggable) |
Generally used for 100M/1000M Ethernet interfaces or POS 155M/622M/2.5G interfaces |
Yes |
Yes |
XFP (10-Gigabit small form-factor pluggable) |
Generally used for 10G interfaces |
Yes |
No |
SFP+ (enhanced small form-factor pluggable) |
Yes |
No |
QSFP+ |
Generally used for 40G interfaces |
Yes |
No |
Displaying transceiver module information
To identify transceiver modules, you can use the following command to view the key parameters of the transceiver modules, including transceiver module type, connector type, central wavelength of the laser sent, transmission distance, and vendor name or name of the vendor who customizes the transceiver modules.
To display transceiver module information:
Task |
Command |
Remarks |
Display key parameters of the transceiver module in a specified interface. |
display transceiver interface [ interface-type interface-number ] |
Available for all transceiver modules. |
Verifying transceiver modules
The system outputs alarm information for you to locate and troubleshoot faults of transceiver modules. For the H3C-customized transceiver modules, the system can also monitor the key parameters, such as temperature, voltage, laser bias current, TX power, and RX power. When these parameters are abnormal, you can take corresponding measures to prevent transceiver module faults.
To display the alarming information or fault detection parameters of a transceiver module:
Task |
Command |
Remarks |
Display the current alarm information of the transceiver module in a specified interface. |
display transceiver alarm interface [ interface-type interface-number ] |
For more information about the transceiver module displaying commands, see H3C SR6600/SR6600-X Routers Command References.
Rebooting a card or router
When upgrading and maintaining the system software image or configuration file for the router, you need to reboot the router. After you change the operating mode of a MPU or LPU, you must restart the corresponding module.
To reboot a router, use one of the following methods:
· Power off and then power on the router. This method might cause data loss, and is the least-preferred method.
· Immediately reboot the router at the CLI.
· Schedule a reboot at the CLI, so the router automatically reboots at the specified time or after the specified period of time.
The first method is called "cold reboot" or "cold startup". The second and third methods are called "warm reboot" or "warm startup", and can be used remotely.
For data security, if you reboot the router while the router is performing file operations, the router does not reboot.
The precision of the rebooting timer is 1 minute. One minute before the rebooting time, the router prompts “REBOOT IN ONE MINUTE” and reboots in one minute.
If the main startup configuration file does not exist, do not use the reboot command to reboot the router or the active MPU. In this case, you should specify the main startup configuration file first, and then reboot the active MPU.
To reboot the router immediately at the CLI:
Task |
Command |
Remarks |
Reboot the router or the card in the specified slot immediately. |
reboot [ slot slot-number ] |
Available in user view. If you do not specify the slot keyword, the command reboots the router, including the active MPU, standby MPU, and the LPUs. |
To schedule a reboot:
Task |
Command |
Remarks |
Specify a reboot time and date. |
schedule reboot at hh:mm [ date ] |
Available in user view. By default, the reboot date and time is not specified. |
Specify a reboot waiting time. |
schedule reboot delay { hh:mm | mm } |
Available in user view. By default, the reboot delay time is not specified. |
7 Troubleshooting
IMPORTANT: The barcode stuck on the router chassis contains production and servicing information. Before you return a faulty router for serving, provide the barcode information of the router to H3C Support. |
MPU failures
RUN LED is off
Symptom
The RUN LED for the MPU is off. For more information about the RUN LED, see Table7-1.
Solution
To resolve the problem:
1. Verify that the MPU is plugged in a right slot.
2. Verify that the router is powered on correctly. A green power LED indicates that the router is powered on correctly.
3. If the problem persists, contact H3C Support.
RUN LED fast flashes
Symptom
Five minutes after the router is powered on or the MPU is plugged into the router, the RUN LED for the MPU still fast flashes at 8 Hz.
Solution
1. Verify that the terminal display is correct.
2. Verify that the system software file properties are correct in the BootWare menu.
ALM LED is steady on or flashes
Symptom
The ALM LED for the MPU is steady on or flashes.
Solution
1. Examine the output (such as alarms on the system temperature, power voltage or insufficient power for use) on the serial terminal and the software management tool to locate the problem.
2. If the problem persists, record the above information and contact H3C Support,
PALM LED is steady on
Symptom
The PALM LED for the MPU is steady on. For more information about MPU LEDs, see Table7-1.
Solution
1. Verify that the power supply and power consumption match.
For example, if an SR6616-X is installed with a 650 W power module but two SAP-48GBE modules, the power available is not sufficient for the whole power consumption and one SAP module cannot be powered on.
2. Verify that the router has one type of power modules installed: AC power modules or DC power modules.
LED |
Status |
RUN (green) |
Off |
No power is provided or the MPU is faulty. |
Flashing slowly at 1 Hz |
The MPU is operating correctly. |
Flashing fast at 8 Hz |
· The MPU is loading system software images. To avoid MPU damage, do not power off the router or hot-swap the MPU. · The MPU is not operating. |
ACT (green) |
Off |
The MPU is in standby state. |
Steady on |
The MPU is in active state. |
PALM (red) |
Off |
The power supply is operating correctly. |
Steady on |
The power for use is not sufficient, or power modules of different specifications are inserted. |
ALM (red) |
Off |
The system is operating correctly without any alarm. |
Steady on |
The system is faulty. You must view the system logs. |
The system is seriously faulty. An immediate action is needed. |
LPU failures
RUN LED is off
Symptom
The RUN LED for the LPU is off.
Solution
1. Verify that the router is powered on.
2. Verify that the LPU is correctly inserted in a slot.
3. Verify that the system power is sufficient. If the system power is insufficient, the system displays the following information:
%Apr 26 16:46:32:169 2012 H3C DRVMSG/1/InSufficientPwr:
No sufficient power, failed to power on slot 3.
4. Execute the display version command to verify that the LPU is in position:
Slot3:
The Board is present, state is unknown
5. If the problem persists, contact H3C Support.
Symptom
20 minutes after the router is powered on or the LPU is inserted into the router, the RUN LED for the LPU still fast flashes at 8 Hz. If you enter the display device command, the system displays the following output:
<H3C> display device
1 N/A Absent N/A N/A
3 FIP-210 Normal N/A 2
4 RSE-X2 Normal Master 0
6 N/A Absent N/A N/A
7 N/A Absent N/A N/A
8 FIP-210 Startup N/A 2
9 FIP-600 Startup N/A 2
The output shows that LPUs in Slots 8 and 9 have failed.
Solution
To resolve the problem, contact H3C Support.
Power module failures
Power LED is off
Symptom
The router cannot be powered on and the power LED on the front panel is off.
Solution
To resolve the problem::
1. Verify that the power switch is turned on.
2. Verify that the power cords of the router are firmly connected.
3. Verify that the switch of the power source is turned on.
4. Verify that the power cord is not damaged.
Red power LED is on
Symptom
The router cannot be powered on and the red power LED on the front panel is on.
Solution
1. Turn off the power switch, and verify that the power module is firmly seated.
2. Verify that the power source meets the requirements of the router.
Fan failures
Fan tray is absent
Symptom
After the router is booted, the output from the configuration terminal shows that the fan tray is not in position.
#Jun 14 11:57:27:778 2012 H3C DEVM/1/FAN STATE CHANGES TO FAILURE:
Trap 1.3.6.1.4.1.25506.8.35.12.1.6<hh3cfanfailure>: fan ID is 1
%Jun 14 11:57:27:779 2012 H3C DEVM/3/FAN_ABSENT: Fan 1 is absent.
Solution
1. Verify that the fan tray is in position.
2. Verify that the fan tray is in firm contact with the backplane of the router chassis.
ALM LED is red
Symptom
When the router is running, the ALM LED on the fan tray panel might turn red, and the output from the configuration terminal shows that fan 1 is faulty.
%Jun 14 11:26:56:869 2012 H3C DRVMSG/3/FanErr: Fan 1 Error.
#Jun 14 11:26:57:579 2012 H3C DEVM/1/FAN STATE CHANGES TO FAILURE:
%Jun 14 11:26:57:579 2012 H3C DEVM/2/FAN_FAILED: Fan 1 failed.
Solution
1. Verify that no foreign object has entered the fan tray.
2. If the problem persists, contact H3C Support.
HIM/MIM/MIC failures
Symptom
When a HIM/MIM/MIC is hot swapped, the output from the configuration terminal shows that the HIM/MIM/MIC is faulty or the router cannot recognize the HIM/MIM/MIC.
%Jun 14 11:12:36:037 2012 H3C DRVICOUT/1/DrvIcOutStr: -Slot=4;
Card in Slot 4 Sublot 1 can not be recognized !
Solution
1. Verify that the HIM/MIM/MIC is firmly seated.
2. Verify that the HIM/MIM/MIC is correctly inserted into a FIP-210/FIP-600 module. A FIP-110 module does not support HIMs.
3. Verify that the HIM/MIM/MIC connector pins of the FIP module are not bent.
4. If the problem persists, contact H3C Support.
Configuration system problems
If the configuration environment setup is correct, the configuration terminal displays boot information when the router is powered on. If the setup is incorrect, the configuration terminal displays nothing or garbled text.
No terminal display
Symptom
The configuration terminal displays nothing when the router is powered on.
Solution
1. Verify that the power supply system is operating correctly and the console cable is correctly connected.
2. Verify that the console cable is connected to a correct serial port. (The serial port in use must be the one set on the terminal.)
3. Verify that the console terminal settings are as follows:
¡ Bits per second—9,600.
¡ Data bits—8.
¡ Parity—None.
¡ Stop bits—1.
¡ Flow control—None.
¡ Terminal Emulation—VT100.
4. Verify that the console cable is not faulty.
Garbled terminal display
Symptom
Terminal display is garbled.
Solution
1. Verify that the Data bits field is set to 8 for the console terminal. If the Data bits field is set to 5 or 6, the console terminal will display garbled characters.
2. Verify that the Bits per second field is set to 9600 bps. An incorrect Bits per second might also cause the configuration terminal to display garbled characters.
No response from the serial port
Symptom
The serial port gives no response.
Solution
1. Verify that the serial port settings are correct.
For more information about the serial port settings, see "Configuring basic settings."
Dealing with console login password loss
CAUTION: Dealing with console login password loss from BootWare menus requires device reboot and is service-disruptive. |
How to deal with console login password loss depends on the state of password recovery capability (see Figure7-1). Password recovery capability controls console user access to the device configuration and SDRAM from BootWare menus.
· If password recovery capability is enabled, a console user can access the device configuration without authentication and configure new passwords.
· If password recovery capability is disabled, a console user must restore the factory-default configuration before configuring new passwords. Restoring the factory-default configuration deletes the main and backup next-startup configuration files.
To enhance system security, disable password recovery capability.
Figure7-1 Dealing with console login password loss
Examining the state of password recovery capability
1. Reboot the router.
CPU Type : P2020
CPU L1 Cache : 32KB
Flash Size : 8MB
cfa0 Size : 999MB
NVRAM Size : 128KB
PCB Version : Ver.B
2. Press Ctrl + B within three seconds after the "Press Ctrl+B to enter extended boot menu..." prompt message appears.
BootWare password: Not required. Please press Enter to continue.
3. Press Enter and read the password recovery capability state message displayed before the EXTEND-BOOTWARE menu.
Password recovery capability is enabled.
Note: The current operating device is cfa0
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Restore to Factory Default Configuration |
|<6> Skip Current System Configuration |
|<7> BootWare Operation Menu |
|<8> Skip Authentication for Console Login |
|<9> Storage Device Operation |
|<0> Reboot |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Enter your choice(0-9):
Skipping current system configuration
1. Reboot the router to access the EXTEND-BOOTWARE menu, and then enter 6.
The current mode is password recovery.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 6
After the configuration skipping flag is set successfully, the following message appears:
Flag Set Success.
2. When the EXTEND-BOOTWARE menu appears again, enter 0 to reboot the router.
The router starts up with empty configuration.
3. To use the configuration in the next-startup configuration file, load the file in system view.
<sysname> system-view
[sysname] configuration replace file startup.cfg
Current configuration will be lost, save current configuration? [Y/N]:n
Info: Now replacing the current configuration. Please wait...
Info: Succeeded in replacing current configuration with the file startup.cfg.
4. Configure a new console login password.
In the following example, the console login authentication mode is password and the authentication password is 123456. For security, the password is always saved in hashed format to the configuration file, regardless of whether you specify the simple keyword or hash keyword for the set authentication password command.
[sysname] user-interface console 0
[sysname-ui-console0] authentication-mode password
[sysname-ui-console0] set authentication password simple 123456
5. To make the settings take effect after a reboot, save the running configuration to the next-startup configuration file.
[sysname] save
Skipping authentication for console login
1. Reboot the router to access the EXTEND-BOOTWARE menu, and then enter 8.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 8
The router deletes the console login password configuration commands from the main next-startup configuration file. After the operation is completed, the following message appears:
Clear Image Password Success!
3. Configure a new password for console login (see "Configure a new console login password.").
4. To make the setting take effect after a reboot, save the running configuration to the next-startup configuration file.
[sysname] save
Restoring to factory default configuration
1. Reboot the router to access the EXTEND-BOOTWARE menu, and enter 5.
The current mode is no password recovery.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 5
2. At the prompt for confirmation, enter Y.
The router deletes its main and backup next-startup configuration files and restores the factory-default configuration.
The current mode is no password recovery. The configuration files will be
deleted, and the system will start up with factory defaults, Are you sure to
continue?[Y/N]Y
Setting...Done.
3. When the EXTEND-BOOTWARE menu appears again, enter 0 to reboot the router.
The router starts up with the factory-default configuration.
4. Configure a new console login password (see "Configure a new console login password.").
[sysname] save
Cooling system failure
Symptom
When the temperature inside the router exceeds the upper threshold, the following information appears on the configuration terminal:
#Jun 14 11:54:38:178 2012 H3C DEVM/1/BOARD TEMPERATURE UPPER:
Trap 1.3.6.1.4.1.25506.8.35.12.1.16<hh3cBoardTemperatureHigher>: chassisIndex i
s 0, slotIndex 0.1
%Jun 14 11:54:38:179 2012 H3C DEVM/4/BOARD_TEMP_TOOHIGH: Board temperature is to
o high on Chassis 0 Slot 1, type is RSE-X2.
The output shows that the temperature inside the router has exceeded the upper threshold. In this case, the fans of the router will rotate at full speed.
Generally, after the fans rotate at full speed for a certain period, the temperature inside the router will drop below the upper threshold, and the following information appears on the configuration terminal:
#Jun 14 11:56:48:279 2012 H3C DEVM/1/BOARD TEMPERATURE UPPER:
Trap 1.3.6.1.4.1.25506.8.35.12.1.17< hh3cBoardTemperatureFormHigherToNormal >: chassisIndex i
s 0, slotIndex 0.1
%Jun 14 11:56:48:279 2012 H3C DEVM/4/BOARD_TEMP_TOOHIGH: Board temperature changes to normal on Chassis 0 Slot 1, type is RSE-X2.
The output shows that the operating temperature of the router restores to normal state.
When exceptions occur, the temperature inside the router might exceed the critical temperature threshold, and the following information appears on the configuration terminal in this case:
%Jun 14 12:06:58:436 2012 H3C DRVMSG/3/TempCritical:
CPU temperature is greater than alarm upper limit in slot 1, index is 1
At the same time, the ALM LED of the MPU is red, which indicates that the temperature inside the router is abnormal.
Solution
1. Verify that the fans are running correctly.
2. Verify that the operating environment of the router is well ventilated.
3. Use the display environment command to identify whether the temperature in the router keeps rising.
For more information about the display environment command, see H3C SR6600/SR6600-X Routers Fundamentals Command Reference.
4. Power off the router immediately and contact H3C Support.
Ethernet port failure
Symptom
Use unshielded twisted pairs to connect Ethernet ports and a minimum of one end of the link that supports 100Base-TX. The following failures occur:
· No link is present for the end operating at 100 Mbps.
· A link is present for the end operating at 10 Mbps, but the physical layer LED (for example, the Active LED) keeps flashing, and the port cannot transmit or receive traffic correctly.
For the copper FE ports and GE ports, both the rate and duplex mode are auto-negotiated by default.
Solution
1. Change the rate and duplex mode of a port by force, and make sure the rate and duplex mode of the local end are the same as the peer end.
HIM/MIM/MIC, cable, and connection failure
Symptom
Power on the router after a HIM/MIM/MIC is installed. The LEDs on the HIM/MIM/MIC panel might indicate abnormal operation.
Solution
1. Verify that the HIM/MIM/MIC cable is correctly selected.
2. Verify that the HIM/MIM/MIC cable is correctly connected.
3. Use the display command to verify that the interface of the HIM/MIM/MIC has been correctly configured and is operating correctly.
Software upgrade failures
No response from the serial port of the MPU
Symptom
The serial port of the MPU gives no response.
Solution
1. Verify that the serial port settings are correct. (The Bits per second field must be set to 9600 bps.)
TFTP upgrade failure
Symptom
Start the router, and upgrade the software through TFTP. The following problems might occur:
· The CF card has no enough space.
File will be transferred in binary mode
Downloading file from remote TFTP server, please wait...\
Failed to write data into storage device, maybe no enough space on device
· The file to be downloaded is not found.
File not found.
· The configuration of the network port is incorrect.
Can't connect to the remote host
Solution
1. Delete some files in the CF card or use a new CF card so that enough space is available for the system software.
2. Type the correct file name.
3. Configure the network port correctly, and make sure the network port is up and you can successfully ping the TFTP server from the network port.
FTP upgrade failure
Symptom
Start the router, and upgrade the software through FTP. The following problems might occur:
227 Entering Passive Mode (192,168,1,10,10,204)
150 "xxx" file ready to send (xxx bytes) in ASCII mode
FTP: Error Writing Local File(Screen).
227 Entering Passive Mode (192,168,1,10,10,203)
550 Error: File xxx does not exist
FTP: Unrecognized host or wrong IP address!
Solution
3. Configure the network port correctly, and make sure the network port is up and you can successfully ping the FTP server from the network port.
System software image file missing errors
Symptom
When none of the main, backup, and secure system software image files exists, the system displays the following information at startup:
Application program does not exist.
Please input BootWare password:
If you select 1 on the main BootWare menu, the system displays the following information:
Starting to get the main application file--cfa0:/main.bin!
The main application file does not exist--cfa0:/main.bin!
Starting to get the backup application file--cfa0:/backup.bin!
The backup application file does not exist--cfa0:/backup.bin!
Starting to get the secure application file--cfa0:/secure.bin!
The secure application file does not exist--cfa0:/secure.bin!
Booting App fails!
The name of the main, backup, and secure system software image files vary by user settings.
A possible reason for the errors is that the main, backup, and secure system software image files have been deleted or damaged.
Solution
To solve this problem:
1. Download the application package again or set the file attributes in the BootWare file list.
